Re: refilling MISPRO cart for the Epson 2200 (more from the original poster)
2005-10-14 by zdirk99
Hmmm...
So, I f'd up on not knowing about the syringe caps but my troubles
continue.
Four of the nine needles I received were either defective when I
received them or broke when I attached them to the syringe for
testing with water.
When broken, the plastic collar either cracks or has a hole in it --
it is impossible to draw water (or ink) through one of these needles
and/or water (or heaven forbid, ink) shoots out at a 90 degree angle
to the needle tip when discharging the syringe.
So, my poor out of the box experience continues.
Are these normal teething pains for a first-time cert refiller? Or
did I have some bad luck in the tools I received on my first order?
Again, any input would be appreciated.
Re: [Digital BW] Re: refilling MISPRO cart for the Epson 2200 (more from the original poster)
2005-10-14 by Steve Kale
No they are not normal teething problems.  The needles simply gently twist
on to the bottom of the syringe (once the protected cap has been removed by
twisting it the other way). Same with the bottom fill adaptor. Honestly it
could not be simpler.  These are stock standard (medical) syringes and
needles.
> From: zdirk99 <ausdlk@...>
> Date: Fri, 14 Oct 2005 15:21:33 -0000
> Subject: [Digital BW] Re: refilling MISPRO cart for the Epson 2200 (more from
> Hmmm...
> continue.
> testing with water.
> gently twist on to the bottom of the syringe (once the protected
> cap has been removed by twisting it the other way). Same with the
> bottom fill adaptor. Honestly it could not be simpler.  These are
> stock standard (medical) syringes and needles.
I agree that this is simple in concept. That's why I'm not a happy
camper.
Only a first time user would not have known that the syringes where
capped. I take responsibility for that snafu.
But once removing this cap, I attached the needles just as you suggest.
On four of the nine I had the problem mentioned. The other five are
okay.
On at least two of the tests with what turned out to be bad needles, I
heard a "snap" as if the needle collar broke as it was being attached
to the syringe. Okay, maybe this would happen if someone was using a
pair of plyers to screw the needle on but I don't expect something
like this to happen when just inserting the needle and hand
tightening. The "snap" occurred at the beginning not the end so I'm
confident that it is not a case of too much force being applied.
Then is it just bad luck?
2005-10-14 by Walt Mucha
refiller? Or
order?
I think you may have damaged the needles when putting them on
over the cap. If you have any good ones left they can be
reused by rinsing them in water. You may be able to tape over
the fill holes untill you get plugs from MIS. That should
prevent ink splashing while the printer is running.
Regards, Walt
http://www.kauaiphotos.biz
---- Original message ----
>Date: Fri, 14 Oct 2005 15:42:55 -0000
>From: "zdirk99" <ausdlk@...>
>To: DigitalBlackandWhiteThePrint@yahoogroups.com
protected
with the
These are
happy
>camper.
where
you suggest.
five are
>okay.
needles, I
attached
using a
something
so I'm
Nope, it's a case of not reading the instructions. It doesen't
take much force to damage plastic. I'd call the order desk at
MIS if you can't get tech support. They always have been very
helpful to me.
Regards, Walt
Sounds like it.  I must admit taking the cap off should have been obvious.
;-)  The breakage of the collars seems a bit odd unless you over tightened
them.  They do not need to be tightened much at all - very gently is enough.
At any rate they don't cost much and sounds like you have a few spares. Try
not to break the bottom fill adaptor. (I'm not sure why you got the big
syringes - 10ml syringes are ok.)  Check the packaging to see if you can
find the rubber plugs for the cartridges (a small re-sealable plastic bag).
MIS doesn't normally forget them.  In the interim some tape over the holes
will do.
BTW when you rinse the syringes it's ok to pull the plunger entirely out of
the cylinder so that things dry a lot faster.
Good luck.
> camper.
> okay.
Re: refilling MISPRO cart for the Epson 2200 (still more)
> obvious. ;-)  The breakage of the collars seems a bit odd unless
> you over tightened them.  They do not need to be tightened much at
> all - very gently is enough. At any rate they don't cost much and
> sounds like you have a few spares. Try not to break the bottom
> fill adaptor. (I'm not sure why you got the big syringes - 10ml
> syringes are ok.)  Check the packaging to see if you can find the
> the holes will do.
> entirely out of the cylinder so that things dry a lot faster.
> Good luck.
I hindsight I guess taking the caps off should have been obvious but
the needle and bottom fill adapters both fit nicely over the end of
the cap and it looked like there was an opening there so it
seemed "obvious" to me initially that that was what was done.
I got the 30mm syringes because that's that MIS sold me. They knew
what I was doing (refilling 2200 carts obviously) and that's what
they said to get. I didn't know any better. I agree that these are
too big and clumsy. My ordering experiences with MIS have not been
flawless -- it seems that at least in my case that one of their
hands didn't know what the other one was doing.
No rubber plugs to be found. I don't have the original package any
more so it possible that they were overlooked and discarded but I
see no mention of them on the otherwise comprehensive invoice.
So, finally have been able to refill two Eboni cartridges that I had
bought previously (that have the little caps).
I do have another question.
After using the bottom fill adapter to draw out about 1ml of ink, I
went to top off the cartridge with the ink that was withdrawn. One
of the two refilled carts clearly has about 3/8 of inch of emptiness
at the top so I think it is safe to assume that it is not full.
Strangely when attempting to top off this cart (using an inserted
needle), it simply would not accept any ink -- it just bubbled up
from the hole. (But I was able to top off the second cartridge.)
I can't figure that one out though. Physics hints at some kind of
pressure thing but I'm baffled why I cannot top off this cartridge.
Am I nuts? Is this how these things are designed -- that is, once
the bottom fill adapter is used to move some of the ink around
inside the cartridge, is there some reason why more ink cannot be
added?
Man, I feel like I'm back in the first grade...
2005-10-14 by kenstrain2000
> added?
Try tilting the cartridge a little so that the ink fills more of the
space at the other end from the fill hole.  Make sure the needle is
far enough in (it can be under the ink surface, for example).
I think it is fair to say that the lure-lock needle fitting is not
very robust.  On the other hand I have two needles, one to use for
every ink and one as a spare.  They are the simplest part of the kit
to clean (inside and out).  Your remaining needles are plenty.
The plugs are not shown separately on the invoice (they are not
charged separately) - the little bag is easy to lose.  If you take
care and look critically at what you are doing it should all go fine.
(On the other hand I had problems too, with leaks.)
Ken
I'd agree with you if I had attempted to fit *all* of the needles
(incorrectly) over the syringe cap. I did this with one, maybe two
of the needles -- but definitely not with all four of them that are
broken.
On the filler cap issue, I was told my MIS in an e-mail from support
that THERE ARE NO CAPS for these 2200 cartridges, that caps are only
necessary when used with CFS systems...
Funny but I have two pre-filled cartridges (identical to my new,
empty ones) that DO have caps.
All responses here on the forum talk about caps, yet a
representative of the vendor say caps aren't used...
Is this another case in my short dealings with MIS where one hand
doesn't know about the other?
Comments?
Tried all that. I must say that is looked very strange -- ink bubbling
out of the hole actually far away from the end of the needle even when
the needle was submerged in ink (or not). Like it is some kind of air
pressure thing that I do not understand.
>very robust.
That's my conclusion too.
I will use your method from now on.
As I posted a little while ago, an e-mail from MIS support said that
plugs are not used on these clear 2200 cartridges...
Oh crap, I don't need to here about that...! :)
Thanks, Ken, for your feedback.
Well if the hole is meant to be open there can't be a problem due to
any small leaks:)  I am not sure which cartridges you have.  Your
first post mentioned the online support for them as saying there were
plugs.
Ken
2005-10-28 by Mike Dobbs
Over on the DPReview.com forum, there has been some discussion of the
MIS Clear Cartridges and those little rubber plugs...some folks have
reported ink leaks at the print head and suspect the rubber plugs are
not sealing correctly, letting air in as the ink flows out t he
bottom. I'm thinking a litte bit of black electrical tape over these
holes (with ot without the rubber plugs in place) should do a very
acceptable job of making an air tight seal...and will be easy to lift
off for refilling later.
Mike.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "kenstrain2000"
that
> plugs.
> Ken
Re: [Digital BW] Re: refilling MISPRO cart for the Epson 2200 (still more)
2005-10-28 by Steve Kale
Why would letting air in be a problem?  Air has to come in else no ink can
come out.  I would think the plugs are simply there to prevent spillage if
the cart not placed in an upright position. Surely leaks at the print head
are an issue with the poppet valves.
> From: Mike Dobbs <mdobbs@...>
> Mike.
> that
>> plugs.
>> Ken
2005-10-28 by Greg
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Steve Kale
ink can
spillage if
head
Or the "O" ring that seals the cart to the head.
There is a vent system built into the top of the carts...it's the
very little hole that is initially sealed over when you get the new
cart...you remove the covering tape before using the cart. This vent
hole reaches the inner ink chamber via a long channel snaking it's
way across the top side of  the cart...then to a vertical tbe going
all the way to the bottom of the ink chamber. The vent air is
carefully controlled...too much and the static pressure of the ink
above the ink head will cause leakage by gravity. Too little vent air
and the ink can't get out at all.
So a leaking rubber plug at the fill hole will lead to leakage. I'm
not sure if the ink leaks from the print head itself or from around
the poppet valve seals. So far I have not seen a leak in my system
(refilled it once so far). Next time I will place some tape over the
fill holes as extra protection.
Mike.
ink can
spillage if
print head
> > From: Mike Dobbs <mdobbs@a...>
have
are
these
lift
> > Mike.
> > --- In
> > that
due to
were
> >> plugs.
> >> Ken
RE: [Digital BW] Re: refilling MISPRO cart for the Epson 2200 (still more)
2005-10-28 by John Moody
It was my impression that the long snaking channel is only to reduce
evaporation of the ink.
On the clear carts, there is no sponge on the plug side, so evaporation
would happen even quicker if there were a “vent” on that side, hence the
need to get a good seal there.  The sponge side has the long channel vent.
John
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com]On Behalf Of Mike Dobbs
Sent: Friday, October 28, 2005 11:40 AM
Subject: [Digital BW] Re: refilling MISPRO cart for the Epson 2200 (still
more)
Mike.
> The vent air is
Hmmm sorry but I don't buy it.  I run another brand of (foamless) cartridges
in my 2100 with no plugs at all.
And all the channel does is to catch any spill out of that small whole.
Plenty of air can get in that little whole if ink is draining out the bottom
poppet valve.  Air coming in to the cartridge is a symptom not a cause.
> From: John Moody <moodymz3@...>
> Date: Fri, 28 Oct 2005 12:06:09 -0400
> Subject: RE: [Digital BW] Re: refilling MISPRO cart for the Epson 2200 (still
> more)
> would happen even quicker if there were a ³vent² on that side, hence the
> John
MIS disagrees:
From their refill instruction on the spongeless clear carts, step #4:
"Re-install the rubber plug. Make sure it fits tight. An air leak
here will let ink drain into your printer. If you think the plug is
damaged, use a new one. "
Link to page where you can also see the inner design of the cart:
<http://www.inksupply.com/spongless_carts.cfm>
Mike.
whole.
the bottom
cause.
> > From: John Moody <moodymz3@y...>
2200 (still
> > more)
reduce
evaporation
hence the
channel vent.
> > John
2005-10-29 by John Moody
Good info, thanks, but that is a spongeless cart.   We are talking about the
2200 carts, which have a sponge.
Best regards,
John Moody
Sent: Friday, October 28, 2005 7:20 PM
more)
MIS disagrees:
< http://www.inksupply.com/spongless_carts.cfm>
Mike.
whole.
the bottom
cause.
2200 (still
> > more)
reduce
evaporation
hence the
channel vent.
> > John
2005-10-29 by Nick H. Nugent
Try this link. Not exactly the same wording but it's the same idea
that the plug is very important.
http://www.inksupply.com/c82refill.cfm
colotbat.com has yet another clear cart that has a metal tube which
acts like the CIS tubing. You can consider this one a self contained
CIS without tubing. The fill hole requires no plug so refilling is
somewhat easier. Now can you guess why this color bat cart doesn't
require the plug  :?
--nick
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "John Moody"
about the
> Best regards,
> John Moody
Mike Dobbs
(still
> more)
> MIS disagrees:
> Mike.
> whole.
> the bottom
> cause.
> 2200 (still
> > > more)
> reduce
> evaporation
> hence the
> channel vent.
> > > John
Well, if it were plugged, in short time the ink would not come out at all.
I can guess that the ink usage is fast enough to not be concerned about
evaporation trough the relatively large vent hole.
Best regards,
John Moody
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com]On Behalf Of Nick H.
Nugent
Sent: Saturday, October 29, 2005 2:30 PM
more)
require the plug  :?
--nick
2005-11-12 by John Moody
There is a clear explanation of the Epson cart design here, including detail
on how the design prevents dripping when the printer is not being used.
http://www.epson.co.jp/e/technology/sankei_7.htm
After reading this, I may give up looking for a 2200 spongeless cart that
performs like the OEM one.  I would be interested if anyone is having
trouble free operation with the spongeless ones available.
Best regards,
John Moody
2005-11-12 by Clayton Jones
Hello John,
>that performs like the OEM one.  I would be interested if anyone is
>having trouble free operation with the spongeless ones available.
I don't know what all the excitement about spongeless is for, but I
used regular MIS clear top fill 2200 carts for a long time without any
problems.  In those days I was doing a lot of experiments with inks
and was swapping in and out a lot and used a few carts over and over
many times.  I never had any problems with dripping or clogs or
anything else.  In all that time (and I'm guessing around two dozen
carts or so) I had one defective cart and one bad chip.
Clayton
Hi Clayton,
That is good to hear.  I’ll end my wait and order up some standard MIS clear
carts.
I guess the excitement about spongeless, is anticipated longer suspension
time for the pigments, and no accumulation of pigments in the sponge, that
reduces the flow over time.  Some vendors suggest a maximum refill number
for the sponge carts because of this.
I called MIS this week, and there is no date in sight for 2200 spongeless
carts from them, and I’m unsure of the ones from WeInk that people have had
to shim, to get them working properly.
Best regards,
John Moody
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com]On Behalf Of Clayton
Jones
Sent: Saturday, November 12, 2005 9:41 AM
more)
Hello John,
Clayton
2005-11-14 by koloshor
<cj@c...> wrote:
> Hello John,
Do you ever change a cart from one color to another, or fill it with
cleaning solution to break up possible clogs in the foam?
2005-11-21 by nsimms
spongeless
> carts from them, and I�m unsure of the ones from WeInk that people
have had
> Best regards,
> John Moody
Were you looking for empty carts? I'm looking for carts to refill with
MISPRO inks for the 2200, and MIS told me today that their prefilled
MP 2200 carts are spongeless, and 'refill friendly'. It's not clear to
me whether they're clear carts - she said they are like the cart
pictured on the top right on this page:
I need to plow through more of the past posts here, but does anyone
have any opinion yet of the MISPRO ink itself? Anyone tried it with a
RIP, QTR in particular?
I'm hoping to set mine up for general color printing, and try BO
printing with Eboni, and possibly try using the color inks with QTR if
possible for toned B&W printing.
Thanks!
Neil S.
> > The vent air is
cartridges
What brand is that?
2005-11-21 by John Moody
I was looking for empty carts, yes.  The info on the pre-filled 2200 carts
is interesting, thanks.  It sure is hard to find them on the website, like
most MIS items are.
Best regards,
John Moody
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com]On Behalf Of nsimms
Sent: Monday, November 21, 2005 9:47 AM
more)
spongeless
have had
> Best regards,
> John Moody
Thanks!
Neil S.
they are often being updated.
page.
them short.
membership without notice.
the membership.
Moderators. See “Group Topic, Rules and Guidelines” in the Files section:
YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE “OWNER” AND
“MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU
GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  “OWNER” AND
“MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE
SPONSORED LINKS
Digital wedding photography
<http://groups.yahoo.com/gads?t=ms&k=Digital+wedding+photography&w1=Digital+
wedding+photography&w2=Learn+digital+photography&w3=Digital+photography+coll
ege&w4=Digital+photography&w5=Digital+photography+web+site&w6=Digital+photog
raphy+course&c=6&%20>
Learn digital photography
<http://groups.yahoo.com/gads?t=ms&k=Learn+digital+photography&w1=Digital+we
dding+photography&w2=Learn+digital+photography&w3=Digital+photography+colleg
e&w4=Digital+photography&w5=Digital+photography+web+site&w6=Digital+photogra
phy+course&c=6&s=%20>
Digital photography college
<http://groups.yahoo.com/gads?t=ms&k=Digital+photography+college&w1=Digital+
Digital photography
<http://groups.yahoo.com/gads?t=ms&k=Digital+photography&w1=Digital+wedding+
photography&w2=Learn+digital+photography&w3=Digital+photography+college&w4=D
igital+photography&w5=Digital+photography+web+site&w6=Digital+photography+co
urse&c=6&s=188&.s%20>
Digital photography web site
<http://groups.yahoo.com/gads?t=ms&k=Digital+photography+web+site&w1=Digital
+wedding+photography&w2=Learn+digital+photography&w3=Digital+photography+col
lege&w4=Digital+photography&w5=Digital+photography+web+site&w6=Digital+photo
graphy+course&c=6%20>
Digital photography course
<http://groups.yahoo.com/gads?t=ms&k=Digital+photography+course&w1=Digital+w
edding+photography&w2=Learn+digital+photography&w3=Digital+photography+colle
ge&w4=Digital+photography&w5=Digital+photography+web+site&w6=Digital+photogr
aphy+course&c=6&s%20>
  _____
YAHOO! GROUPS LINKS
*	 Visit your group " DigitalBlackandWhiteThePrint
<http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint> " on the web.
*	 To unsubscribe from this group, send an email to:
<mailto:DigitalBlackandWhiteThePrint-unsubscribe@yahoogroups.com?subject=Uns
ubscribe>
*	 Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
<http://docs.yahoo.com/info/terms/> .
  _____
