Museo 2, 2400 basic settings question
2006-03-08 by ginnylady33
I just tried Museo II, 250 gsm. for the first time in my relatively
new 2400. For the most part, the paper will not feed from the rear feeder.
(About 1 out of 6 times the paper will feed into the printer)
I'm wondering what settings those of you who have tried Museo II in a
2400 use?
What paper do you set the media type for in the driver?
Should I be using the 'thick' setting for 250 GSM. paper?
Should I be using the front single-sheet feeder?
 Basically, I'm not sure if there is a problem with my printer, the
settings or the paper itself. By the way, for media type I was trying
Enhanced Matte and then Heavyweight Matte. (BTW, Enhanced Matte paper
itself feeds just perfectly.)
 Thanks
 Ginny
Re: Museo 2, 2400 basic settings question
2006-03-08 by Clayton Jones
Hello Ginny,
>feeder. (About 1 out of 6 times the paper will feed into the
>printer)
>in a  2400 use?
I've tried Museo II and many other thick papers.  I've been able to
put any thick papers through the top feeder, even as thick as 315 gsm.
 The trick is to put a slight bend in the paper so it's pointing into
the grabber a bit.  Then keep a finger on top and give it a firm but
very slight nudge when it starts, just enough to get it into the jaws
of the grabber.  Press too hard or push it too far in and it will be
rejected.  It also helps to not have the paper fence up against the
paper, but allow about 1/16" of space.  The grabber tends to twist the
paper slightly and then straighten it out again.  If the fence is up
against the paper it doesn't allow the twist and increases the failure
rate a lot.
Clayton
2006-03-08 by Louis Dina
Ginny,
I have a 4000 (not a 2400) and find Museo II feeds fine from the back
slot.  I use a custom paper width setting of 0.7mm in the Epson
driver.  Also, Museo II doesn't perform very well using the EEM
setting on my 4000.  The Textured Fina Art setting lays down less ink
than the EEM setting and gives me much better Dmax and color gamut.
Hopefully, this is relevant to your 2400.
Lou
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "ginnylady33"
feeder.
a
> 2400 use?
trying
paper
>  Thanks
>  Ginny
Thanks Lou.
 I don't believe there is a setting in the 2400 driver for a custom
paper width.
 Anyone?
 The only choice I'm aware for width is to choose the 'thick paper'
setting. Hehe...then one get's a warning with every print that one has
chosen 'thick psper', do you want to continue?
Duh......
 Best
 Ginny
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Louis Dina"
<lbdina@...> wrote:
> Ginny,
> Lou
> feeder.
> a
> > 2400 use?
> trying
> paper
> >  Thanks
> >  Ginny
2006-03-08 by how786
I'm following this thread with great interest. I, too, have 'feed
issues' with my 2400. It does appear to be very finicky with  thicker
papers.
 I recently tried H. Photo Rag 308. It was really hard to get this
paper to feed correctly. I ultimately had to use the single sheet
front feeder. And, even that, was not consistently effective.
 It is discouraging to have paid so much for a printer that has feed
issues with thicker papers.
 Howard
> Thanks Lou.
> paper width.
>  Anyone?
> Duh......
>  Best
>  Ginny
> <lbdina@> wrote:
> > Ginny,
> > Lou
> > feeder.
> > a
> > > 2400 use?
> > trying
> > paper
> > >  Thanks
> > >  Ginny
Howard,
>'feed issues' with my 2400. It does appear to be very finicky
>feed issues with thicker papers.
Please try the procedure I described.  Yes it's finicky, but using
this procedure I have essentially no problems and can feed it anything.
Clayton
RE: [Digital BW] Re: Museo 2, 2400 basic settings question
2006-03-08 by John Moody
I would be concerned about increased microbanding, and general abuse to the
feed mechanism with that procedure.
Is manual feeding such a pain, that those concerns are outweighed, or do you
not see any microbanding difference in the output?
Best regards,
John Moody
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com]On Behalf Of Clayton
Jones
Sent: Wednesday, March 08, 2006 9:20 AM
Subject: [Digital BW] Re: Museo 2, 2400 basic settings question
Howard,
Clayton
Hello John,
>abuse to the feed mechanism with that procedure.  Is manual
>you not see any microbanding difference in the output?
I have not seen any banding of any sort.  I'm not sure how you can
attach the word "abuse" to the procedure I described.  If you read
carefully what I wrote you'll see that I'm not saying to shove the
paper down it's throat.  My observation is that thin papers are bent
slightly by the initial mechanism which moves the paper forward into
the jaws of the grabber.  The thick papers don't have that flexibility
and simply don't get moved forward enough to where the grabber can get
ahold of it.
I found that putting a slight bend in the paper puts it in a position
that is similar to a thinner paper in it's bent state.  In papers up
to 250 and 270 gsm that is usually all that's required.  Anything
heavier needs a slight nudge just to get it moving.  Most of the time
all that's required is the weight of a finger on the paper, without
any push at all.  All it needs is to move slightly forward and the
grabber then pulls it in.
Only with the real thick papers is a slight nudge required.  They
don't seem to be able to slip past the angled edge of the smooth white
piece of plastic which lowers to allow the paper to pass.  The nudge
is just enough to get it past that point.
I also think that it's more difficult to abuse these new paper
feeders as they seem to have a built in protection mechanism.  The
2200 is prone to failure here, and I noticed something very different
with the 2400 (and my R200).  It rejects any sheet that doesn't feed
properly and passes it out the front.  I think this is a protection
mechanism, and it's probably more difficult to cause damage.
This is obvious because if you push the paper too hard, or too far in,
it will be rejected and passed through.  It won't allow you to force
it in.  The only thing that works is to get the paper in the correct
position and then the grabber will pull it in.  With a bit of
experience one can get a feel for just the right amount of pressure.
Putting a small amount of space (1/16") between the paper and the
fence is also very helpful.  If you watch closely you can see that the
grabber twists the paper slightly, like a very brief twitch.  A tight
fence seems to prevent this twist and the grabber rejects it and
passes it through.
Clayton
Clayton,
Thanks for the details.  If you are not seeing any banding, then I can
easily understand the desire to use the standard feed.
By abuse, I am talking about the rollers slipping while attempting to feed
the paper.  Over time, they will lose some of their friction, making feeding
progressively more error prone.  Possibly the 2400 is less susceptible than
the 2200 in this regard; time will tell.  Having a CompUSA protection plan
probably eliminates this worry as well.
On the R200, I find that in addition to your 1/16 space suggestion, pushing
the bottom edge of the paper back against the support helps, and in some
cases eliminates the need for the nudge.  It surprised me when I found that
by accident, as itÂ’s almost opposite of the slight bend and nudge method
that I also use.
Best regards,
John Moody
Jones
Sent: Wednesday, March 08, 2006 10:56 AM
Hello John,
ahold of it.
passes it through.
Clayton
2006-03-09 by Rick
Hey Howard, I use that paper and also the William Turner ,which is 310gsm, in the rear
feader with no problems.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "how786" <how786@...> wrote:
> papers.
>  Howard
> > Thanks Lou.
> > paper width.
> >  Anyone?
> > Duh......
> >  Best
> >  Ginny
> > <lbdina@> wrote:
> > > Ginny,
> > > Lou
> > > feeder.
> > > a
> > > > 2400 use?
> > > trying
> > > paper
> > > >  Thanks
> > > >  Ginny
