K3 Ink in a 4000/Question for Shilesh Jani
2006-07-10 by Stephen M Martin
Did I read correctly that you are using the K3 ink in a 4000? May I ask how? Thanks.
  Sent: Sunday, July 09, 2006 9:39 AM
  Subject: Re: [Digital BW] fibaprint gloss/ da vinci users
  MIS K4 PK does seem to give me slightly lower dmax compared to Epson
  K3 PK. I get about 2.1 to 2.2 for Innova F Type in both my 2400 and
  4000. Silver Rag and Hahnemuhle Pearl do better with dmax closer to
  2.3 - 2.4.
  Carl
  On Jul 9, 2006, at 9:21 AM, Shilesh Jani wrote:
  > Using Epson 4000 loaded with K3 (4800) PK ink, QTR 1440
  > Super/Better/Ordered I am getting 2.5 when measured with Heiland PM
  > Densitometer. This is NOT a colorimeter.
  > From experience I know this will dry-down to ~2.4+ overnight. A light
  > coat of PrintShield usually bring this up to 2.6+
  > I am getting the same results +/- 0.05D with the K3 PK in 2400
  > printer.
  > Dmax usually comes in at 75% or 80% ink limits.
  > Ernst, maybe it is the MIS PK ink?
  > Shilesh
  > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, Ernst Dinkla
  > <E.Dinkla@...> wrote:
  >> Greg wrote:
  >>> I looked into the dmax numbers a little, and I thik I have a
  > vague
  >>> idea of why they are getting such low numbers. It might (stress
  >>> might) be simply a difference between the measurement mode being
  >>> used. Most of us are using Status T for density, yet the Xrite
  > 810
  >>> says it uses Status A (reflection and still has a 2.5D spec),
  > while
  >>> they may be using Status E measurements to reach the 2.7D. I saw
  > a
  >>> fleeting reference to the difference between Status T and Status
  > E
  >>> being that the E value may be lower. I haven't had the time to go
  > and
  >>> research it yet, so if someone knows what the differences are, or
  > has
  >>> the time to go looking, there might be an answer.
  >> Greg,
  >> I'm busy calibrating Fibaprint Gloss F with a Spectrocam and
  >> do not get a higher Dmax than 1.94 with MIS UT PK on an Epson
  >> 9000. I do not see much difference between the Status T, A or
  >> E with this spectrometer. And the lowest L is 11.80. With QTR
  >> I have to limit on 60 in the calibration strip as there's no D
  >> gain above that. Boosting doesn't help either. I have used the
  >> Premium Glossy Photo Paper setting in QTR but do not expect
  >> any difference with other settings and 1440 unidirectional.
  >> Any suggestions to get a higher Dmax ?
  >> Ernst
  >> Ernst Dinkla
  >> www.pigment-print.com
  >> ( unvollendet )
Re: [Digital BW] K3 Ink in a 4000/Question for Shilesh Jani
2006-07-12 by Carl Schofield
I'm using MIS K4 inks (equivalent to epson K3) in my 4000.  I don't
use the LLK ink.  I make my own profiles for color and B&W printing
using the ColorBurst X-Photo RIP and also QTR for toned B&W.  I also
use the MIS K4 inks (with the LLK) in my 2400 printer, also with
custom profiles.  I don't really see any differences between prints
made with and without LLK in terms of tonal smoothness, GD, or bronzing.
> ask how? Thanks.
> From: Carl Schofield
> 2.3 - 2.4.
> Carl
> light
> > printer.
> > Shilesh
> > vague
> > 810
> > while
> > a
> > E
> > and
> > has
> >> Greg,
> >> Ernst
> >> Ernst Dinkla
> >> ( unvollendet )
2006-07-12 by Steven Karafyllakis
Hi Carl;
Funny you should mention K2; I was just admiring a pair of 16 x 20
k2 prints Shilesh sent me a while back, and I can attest to the fact
that His setup don't need no steenkin' LLK either- they are smooth
and dotless all the way up the scale with good highlight detail,
etc. I think the 4000 is probably the best wide format machine out
there right for the k2 approach, and of course having PK and MK full
time is great. I really think Epson blew it with that aspect of the
X800 machines, and Canon will make them pay for it dearly.
BTW-if you get tired of mucking about with these new overpriced-glam
papers: What I've gone to now is the Oriental Graphica Lustre. Nice
surface, though not as nice as the Sihl Iridium, but clean glowing
highlights and a d-max of 2.35-2.4. For this particular paper it
doesn't seem to matter if its Epson or MIS ink; A greyscale done on
Clayton's R2400 gave me virtually identical dmax as one done on my
R1800 with MIS inks. Now if I could just find a mat board to match
the whiter base....
Best,
Steve Karafyllakis
 --- In DigitalBlackandWhiteThePrint@yahoogroups.com, Carl Schofield
don't
printing
also
prints
bronzing.
May I
> > ask how? Thanks.
Epson
and
to
> > 2.3 - 2.4.
> > Carl
Heiland PM
A
> > light
> > > printer.
> > > Shilesh
Dinkla
> > > <E.Dinkla@> wrote:
> > > vague
(stress
being
Xrite
> > > 810
> > > while
saw
> > > a
Status
> > > E
to go
> > > and
are, or
> > > has
> > >> Greg,
> > >> Ernst
> > >> Ernst Dinkla
> > >> ( unvollendet )
Steve,
I tried the old Graphica FB Glossy quite awhile ago when I was using
the original UC inks and thought it looked pretty good, except for
some slight bronzing.  It was pretty pricey back then and there were
no larger sheet sizes or rolls available so I didn't go back to it
with the newer inksets.  Any GD or bronzing with the graphica
lustre?  I'll have to give it a try with my MIS K4 inks.
Carl
On Jul 12, 2006, at 1:25 AM, Steven Karafyllakis wrote:
> Hi Carl;
> the whiter base....
> Best,
> Steve Karafyllakis
> don't
> printing
> also
> prints
> bronzing.
> May I
> > > ask how? Thanks.
> Epson
> and
> to
> > > 2.3 - 2.4.
> > > Carl
> Heiland PM
> > > > From experience I know this will dry-down to ~2.4+ overnight..
> A
> > > light
> > > > printer.
> > > > Shilesh
> Dinkla
> > > > <E.Dinkla@> wrote:
> > > > vague
> (stress
> being
> Xrite
> > > > 810
> > > > while
> saw
> > > > a
> Status
> > > > E
> to go
> > > > and
> are, or
> > > > has
> > > >> Greg,
> > > >> Ernst
> > > >> Ernst Dinkla
> > > >> ( unvollendet )
Carl;
I tried the FB glossy too, and absolutely hated it. The Lustre with
MIS inks at least shows no bronzing and only the slightest GD going
into no-ink highlights. It available in rolls, cost $129 including
shipping- not the cheapest RC paper, but not as pricey as the FB
either. And if you need color, it gives good results there with MIS
Pro, probalby the K4 as well.
Steve Karafyllakis
<list@...> wrote:
> Steve,
using
for
were
it
> Regards,
> Carl
> > Hi Carl;
20
fact
smooth
out
full
glam
Nice
glowing
on
my
match
> > the whiter base....
> > Best,
> > Steve Karafyllakis
Schofield
> > don't
> > printing
> > also
with
> > prints
> > bronzing.
> > May I
> > > > ask how? Thanks.
to
> > Epson
2400
> > and
closer
> > to
> > > > 2.3 - 2.4.
> > > > Carl
> > Heiland PM
overnight..
> > A
> > > > light
2400
> > > > > printer.
> > > > > Shilesh
> > Dinkla
> > > > > <E.Dinkla@> wrote:
have a
> > > > > vague
> > (stress
mode
> > being
> > Xrite
> > > > > 810
spec),
> > > > > while
2.7D. I
> > saw
> > > > > a
> > Status
> > > > > E
time
> > to go
> > > > > and
> > are, or
> > > > > has
> > > > >> Greg,
and
Epson
A or
QTR
no D
used the
expect
unidirectional.
> > > > >> Ernst
> > > > >> Ernst Dinkla
> > > > >> ( unvollendet )
2006-07-12 by tzinzunzan2006
I'd be interested in hearing just how much more archival -- if they
are indeed more archival -- papers like CSR and Innova F-Type Gloss
are than a paper like Graphica Lustre. If there is not much of a
difference in archivality, then is the sizable difference in the
price of these "glam" papers warranted by a proportionate difference
in print quality, surface texture, and overall feel of the paper?
Chris Hargens
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Steven
> the whiter base....
> Best,
> Steve Karafyllakis
2006-07-13 by Steven Karafyllakis
Chris;
The RC papers vary in archivability much more widely than the cotton
papers; Epson semi-matte gets 200+ Wilhelm years with the recent
pigment inks, while many others don't even make the fifty year mark.
As for Graphica Lustre, until someone like Paul does a comparison
fade test, it is an uknown. The only thing I know about it is that
it doesn't yellow as rapidly as some, and that is very sketchy info
indeed, and says nothing about the fade rate per se. All of which
I'm sure you already realize. Given similar performance, however, it
very much becomes a matter of personal taste and perhaps perceived
cachet as to whether the new papers are worth the money. I
personally am not satisfied that the appearance and feel is what I
want, and I also have a need to keep the cost down on some
small/medium size production prints I'm doing, so I'm willing to
take a bit of a chance testing unknown papers-others may not.
Steven Karafyllakis
--- In
DigitalBlackandWhiteThePrint@yahoogroups.com, "tzinzunzan2006"
difference
> Chris Hargens
glam
Nice
glowing
on
my
match
> > the whiter base....
> > Best,
> > Steve Karafyllakis
