Epson R2400 Head Cleaning
2007-01-23 by pairofsnowmen
I seem to be having trouble with my yellow on my R2400. No matter how
many head cleanings I do, I can never get a good test from my yellow.
Is there any way to actually manually clean this print head?
Everything else prints fine, but anything with yellow in it gives me
very slight banding. Thanks for the help.
Re: Epson R2400 Head Cleaning
2007-01-23 by Jeff Randall
OEM carts and ink or third party?
How long have you had the printer and when did the problem start?
Specifically what do you mean when you say you can never get a good
test?  Exactly what is wrong.  Under what circumstances do you see the
banding?  Do you see it easily with the naked eye or do you need a
loupe?
-----In DigitalBlackandWhiteThePrint@yahoogroups.com, "pairofsnowmen"
2007-01-24 by pairofsnowmen
I have had the printer for about 6 months and am using the Epson K3
inks. The problem started about a month ago, but since I print
primarily B&W, and when I do print color, not all of them are
affected. Specifically what I mean is that every time I run a head
cleaning, the test afterwards prints beautifully except for the
yellow. I have run several cleanings and although the condition
improves, it has not disappeared. Any time I make a print that has any
significant amount of yellow in it, I get a very faint banding. It can
 be seen with the naked eye, although not easily, and maybe not even
if you weren't looking for it.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Jeff Randall"
> loupe?
2007-01-25 by Jeff Randall
Most likely you have a yellow ink starvation problem (as you
probably have guessed because the banding is only in the yellow and
thus not a paper advance/stepping motor problem).  The nozzle check
doesn't use much ink, so starvation problems don't show up unless
they are significant.  Starvation problems are usually caused by a
partial clog in the printhead or an air leak or some other problem
with the cart.
To conserve your other inks, you can create a 100% yellow test image
and print it to see if the banding changes during printing (ie, gets
worse with longer printing time or not).
The other thing to try is to change out the yellow cart.
Good luck.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "pairofsnowmen"
any
can
even
good
see the
a
> > loupe?
> > -----In
matter how
yellow.
gives me
