Importing 8 bit duotone images into Lightroom w/ PSCS2 compatibility enabled
2007-04-23 by caz
2007-04-23 by caz
Hello, I wonder if someone here might have stumbled upon a situation I am faced with and found a solution. In order to mimick a selenium toned image I converted a 16 bit color image into greyscale then down to 8 bit and finally into a duotone. I tried to import this image in Lightroon but it doesn't want to cooperate. I had similar issues on some images where I hadn't enabled compatibility mode but in this case I even saved it as a copy with compatibility mode enabled but still no joy. Any suggestions? Thanks, Pierre
2007-04-23 by Eric Neilsen Photo
Pierre, My first questions is WHY? If you had a 16bit image Lightroom will be OK, color or B&W. While some may have a color for selenium, I view that as some trying to make platinum prints without platinum. If you just desaturate your 16 bit color image and then "save as" you 'll have an RGB file with no color, then add color, reddish, bluish, or whatever you do to make selenium. Or better yet, just take your RGB 16 bit file into Lightroom and do your color adjustments there. If you're really happy with the duotone color, convert it to RGB and then import that file into LR. This is another situation where Adobe doesn't support their own code. Eric Neilsen Photography 4101 Commerce Street, Suite 9 Dallas, TX 75226 214-827-8301 http://ericneilsenphotography.com Skype : ejprinter _____
From: DigitalBlackandWhiteThePrint@yahoogroups.com [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of caz Sent: Sunday, April 22, 2007 9:00 PM To: DigitalBlackandWhiteThePrint@yahoogroups.com Subject: [Digital BW] Importing 8 bit duotone images into Lightroom w/ PSCS2 compatibility enabled Hello, I wonder if someone here might have stumbled upon a situation I am faced with and found a solution. In order to mimick a selenium toned image I converted a 16 bit color image into greyscale then down to 8 bit and finally into a duotone. I tried to import this image in Lightroon but it doesn't want to cooperate. I had similar issues on some images where I hadn't enabled compatibility mode but in this case I even saved it as a copy with compatibility mode enabled but still no joy. Any suggestions? Thanks, Pierre [Non-text portions of this message have been removed]
2007-04-23 by CDTobie@aol.com
In a message dated 4/22/07 10:00:25 PM, ve2caz@... writes: > I wonder if someone here might have stumbled upon a situation I am > faced with and found a solution. > > In order to mimick a selenium toned image I converted a 16 bit color > image into greyscale then down to 8 bit and finally into a duotone. > > I tried to import this image in Lightroon but it doesn't want to > cooperate. > A duotone is actually a single channel grayscale image, with some tinting data in a special format. Whether any application other than Photoshop (even Lightroom...) will recognize that unusual format is always questionable, few do. I'd suggest using some method other than Photoshop DuoTones to define your tints; they are not a color managed process anyways, so some other method would provide more consistancy and flexibility. C. David Tobie Product Technology Manager ColorVision Business Unit Datacolor Inc. CDTobie@... www.colorvision.com ************************************** See what's free at http://www.aol.com. [Non-text portions of this message have been removed]
2007-04-23 by Brian
> I wonder if someone here might have stumbled upon a situation I am > faced with and found a solution. > > In order to mimick a selenium toned image I converted a 16 bit color > image into greyscale then down to 8 bit and finally into a duotone. > > I tried to import this image in Lightroon but it doesn't want to > cooperate. > Eric Converting the Duotone to RGB will usually do it. Brian Price
2007-04-23 by Pierre Archambault
Good morning Eric, I recently purchased Lightroom and wanted to use it to allow me to navigate my library of images. This file in particular was process 2 years ago so I wasn't starting fresh from a raw file. As far as my use of the PS duotone mode, it was based on what little experience I had at the time. I usually keep everything in 16 bit throughout my workflow but in this case I noticed that I couldn't use the PS feature unless I when down to 8 bits and at the time I didn't know a better way to achieve this look. Please feel free to suggest some work around that would enable me to see thes few files I have under Lightroom. Thanks, Pierre >From: "Eric Neilsen Photo " <e.neilsen2@...> >Reply-To: DigitalBlackandWhiteThePrint@yahoogroups.com >To: <DigitalBlackandWhiteThePrint@yahoogroups.com> >Subject: RE: [Digital BW] Importing 8 bit duotone images into Lightroom w/ >PSCS2 compatibility enabled >Date: Sun, 22 Apr 2007 22:44:08 -0500 > >Pierre, My first questions is WHY? If you had a 16bit image Lightroom will >be OK, color or B&W. While some may have a color for selenium, I view that >as some trying to make platinum prints without platinum. If you just >desaturate your 16 bit color image and then "save as" you 'll have an RGB >file with no color, then add color, reddish, bluish, or whatever you do to >make selenium. Or better yet, just take your RGB 16 bit file into Lightroom >and do your color adjustments there. > >If you're really happy with the duotone color, convert it to RGB and then >import that file into LR. This is another situation where Adobe doesn't >support their own code. > >Eric Neilsen Photography >4101 Commerce Street, Suite 9 >Dallas, TX 75226 >214-827-8301 >http://ericneilsenphotography.com >Skype : ejprinter > >From: DigitalBlackandWhiteThePrint@yahoogroups.com >[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of caz >Sent: Sunday, April 22, 2007 9:00 PM >To: DigitalBlackandWhiteThePrint@yahoogroups.com >Subject: [Digital BW] Importing 8 bit duotone images into Lightroom w/ >PSCS2 >compatibility enabled > >Hello, > >I wonder if someone here might have stumbled upon a situation I am >faced with and found a solution. > >In order to mimick a selenium toned image I converted a 16 bit color >image into greyscale then down to 8 bit and finally into a duotone. > >I tried to import this image in Lightroon but it doesn't want to >cooperate. > >I had similar issues on some images where I hadn't enabled >compatibility mode but in this case I even saved it as a copy with >compatibility mode enabled but still no joy. > >Any suggestions? > >Thanks, >Pierre _________________________________________________________________ Find the best places on campus to get take out, study & unwind http://www.liveu.ca/explore.aspx
Hi CD, Thanks for the info on the file contents. It wasn't clear to me how different it was under the covers. I haven't produced one of those in 2 years but the next time I get into these kinds of images I will use my PFP Suite to handle duotones. Cheers, Pierre >From: CDTobie@... >Reply-To: DigitalBlackandWhiteThePrint@yahoogroups.com >To: DigitalBlackandWhiteThePrint@yahoogroups.com >Subject: Re: [Digital BW] Importing 8 bit duotone images into Lightroom w/ >PSCS2 compatibility enabled >Date: Mon, 23 Apr 2007 08:44:04 EDT > >In a message dated 4/22/07 10:00:25 PM, ve2caz@... writes: > > > I wonder if someone here might have stumbled upon a situation I am > > faced with and found a solution. > > > > In order to mimick a selenium toned image I converted a 16 bit color > > image into greyscale then down to 8 bit and finally into a duotone. > > > > I tried to import this image in Lightroon but it doesn't want to > > cooperate. > > > >A duotone is actually a single channel grayscale image, with some tinting >data in a special format. Whether any application other than Photoshop >(even >Lightroom...) will recognize that unusual format is always questionable, >few do. >I'd suggest using some method other than Photoshop DuoTones to define your >tints; they are not a color managed process anyways, so some other method >would >provide more consistancy and flexibility. > >C. David Tobie >Product Technology Manager >ColorVision Business Unit >Datacolor Inc. >CDTobie@... >www.colorvision.com _________________________________________________________________ RealLiveMoms: Share your experience with Real Live Moms just like you http://www.reallivemoms.ca/
In a message dated 4/23/07 9:50:38 AM, ve2caz@... writes: > Please feel free to suggest some work around that would enable me to see > thes few files I have under Lightroom. > That really depends on how you plan to print them. The only unique data in a DuoTone is grayscale, so converting to grayscale will get you all the image data, if you plan to print to a system that takes grayscale in and prints neutral or tinted grayscale out. If you want to salvage the tonalities, that would be possible with some workflows. For instance, you could convert the DuoTone to RGB in Photoshop, resave, and that image could be printed through an advanced profile for color and B&W work via the RGB driver. PrintFIX PRO 2.0 would actually allow either of these methods, but most processes would need one, or the other, and might require other elements as well, since as recreating the tonality as a QTR curve set... C. David Tobie Product Technology Manager ColorVision Business Unit Datacolor Inc. CDTobie@... www.colorvision.com ************************************** See what's free at http://www.aol.com. [Non-text portions of this message have been removed]
Pierre, The folks at Adobe really pissed me off with their lack of compatibility with LR and their other image products. I suppose it can't be all things to all people but there are many aspects of LR image management that really stink. NON maximized PSD files will not import into LR either. I also ran across some 325mb Tif files that were report to be too large. I don't know of a search that you can do to identify Duotone, Tritone or Quadtone files. LR will tell you when a file will not be imported but will not allow you to copy or export that list so that you can trouble shoot the list. Sure you could manually write them down and if there were only a few that is work around but with thousands of image files and possibly hundreds that don't flow into LR, you are left with the task of some other tracking system. All Duotone, Tritone or Quadtone files need to be converted to RGB in PS. The conversion will keep the color properties that you assigned them and then can be read by RGB programs. Eric Eric Neilsen Photography 4101 Commerce Street, Suite 9 Dallas, TX 75226 214-827-8301 http://ericneilsenphotography.com Skype : ejprinter _____
From: DigitalBlackandWhiteThePrint@yahoogroups.com [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Pierre Archambault Sent: Monday, April 23, 2007 8:44 AM To: DigitalBlackandWhiteThePrint@yahoogroups.com Subject: RE: [Digital BW] Importing 8 bit duotone images into Lightroom w/ PSCS2 compatibility enabled Good morning Eric, I recently purchased Lightroom and wanted to use it to allow me to navigate my library of images. This file in particular was process 2 years ago so I wasn't starting fresh from a raw file. As far as my use of the PS duotone mode, it was based on what little experience I had at the time. I usually keep everything in 16 bit throughout my workflow but in this case I noticed that I couldn't use the PS feature unless I when down to 8 bits and at the time I didn't know a better way to achieve this look. Please feel free to suggest some work around that would enable me to see thes few files I have under Lightroom. Thanks, Pierre >From: "Eric Neilsen Photo " <e.neilsen2@worldnet <mailto:e.neilsen2%40worldnet.att.net> .att.net> >Reply-To: DigitalBlackandWhit <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> eThePrint@yahoogroups.com >To: <DigitalBlackandWhit <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> eThePrint@yahoogroups.com> >Subject: RE: [Digital BW] Importing 8 bit duotone images into Lightroom w/ >PSCS2 compatibility enabled >Date: Sun, 22 Apr 2007 22:44:08 -0500 > >Pierre, My first questions is WHY? If you had a 16bit image Lightroom will >be OK, color or B&W. While some may have a color for selenium, I view that >as some trying to make platinum prints without platinum. If you just >desaturate your 16 bit color image and then "save as" you 'll have an RGB >file with no color, then add color, reddish, bluish, or whatever you do to >make selenium. Or better yet, just take your RGB 16 bit file into Lightroom >and do your color adjustments there. > >If you're really happy with the duotone color, convert it to RGB and then >import that file into LR. This is another situation where Adobe doesn't >support their own code. > >Eric Neilsen Photography >4101 Commerce Street, Suite 9 >Dallas, TX 75226 >214-827-8301 >http://ericneilsenp <http://ericneilsenphotography.com> hotography.com >Skype : ejprinter > >From: DigitalBlackandWhit <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> eThePrint@yahoogroups.com >[mailto:DigitalBlackandWhit <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> eThePrint@yahoogroups.com] On Behalf Of caz >Sent: Sunday, April 22, 2007 9:00 PM >To: DigitalBlackandWhit <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> eThePrint@yahoogroups.com >Subject: [Digital BW] Importing 8 bit duotone images into Lightroom w/ >PSCS2 >compatibility enabled > >Hello, > >I wonder if someone here might have stumbled upon a situation I am >faced with and found a solution. > >In order to mimick a selenium toned image I converted a 16 bit color >image into greyscale then down to 8 bit and finally into a duotone. > >I tried to import this image in Lightroon but it doesn't want to >cooperate. > >I had similar issues on some images where I hadn't enabled >compatibility mode but in this case I even saved it as a copy with >compatibility mode enabled but still no joy. > >Any suggestions? > >Thanks, >Pierre __________________________________________________________ Find the best places on campus to get take out, study & unwind http://www.liveu. <http://www.liveu.ca/explore.aspx> ca/explore.aspx [Non-text portions of this message have been removed]
Speaking of which, I output some files yesterday with LR and some PFP colorized profiles and they printed as expected; not too dark. Eric Neilsen Photography 4101 Commerce Street, Suite 9 Dallas, TX 75226 214-827-8301 http://ericneilsenphotography.com Skype : ejprinter _____
From: DigitalBlackandWhiteThePrint@yahoogroups.com [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Pierre Archambault Sent: Monday, April 23, 2007 8:49 AM To: DigitalBlackandWhiteThePrint@yahoogroups.com Subject: Re: [Digital BW] Importing 8 bit duotone images into Lightroom w/ PSCS2 compatibility enabled Hi CD, Thanks for the info on the file contents. It wasn't clear to me how different it was under the covers. I haven't produced one of those in 2 years but the next time I get into these kinds of images I will use my PFP Suite to handle duotones. Cheers, Pierre >From: CDTobie@aol. <mailto:CDTobie%40aol.com> com >Reply-To: DigitalBlackandWhit <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> eThePrint@yahoogroups.com >To: DigitalBlackandWhit <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> eThePrint@yahoogroups.com >Subject: Re: [Digital BW] Importing 8 bit duotone images into Lightroom w/ >PSCS2 compatibility enabled >Date: Mon, 23 Apr 2007 08:44:04 EDT > >In a message dated 4/22/07 10:00:25 PM, ve2caz@hotmail. <mailto:ve2caz%40hotmail.com> com writes: > > > I wonder if someone here might have stumbled upon a situation I am > > faced with and found a solution. > > > > In order to mimick a selenium toned image I converted a 16 bit color > > image into greyscale then down to 8 bit and finally into a duotone. > > > > I tried to import this image in Lightroon but it doesn't want to > > cooperate. > > > >A duotone is actually a single channel grayscale image, with some tinting >data in a special format. Whether any application other than Photoshop >(even >Lightroom...) will recognize that unusual format is always questionable, >few do. >I'd suggest using some method other than Photoshop DuoTones to define your >tints; they are not a color managed process anyways, so some other method >would >provide more consistancy and flexibility. > >C. David Tobie >Product Technology Manager >ColorVision Business Unit >Datacolor Inc. >CDTobie@colorvision <mailto:CDTobie%40colorvision.com> .com >www.colorvision.com __________________________________________________________ RealLiveMoms: Share your experience with Real Live Moms just like you http://www.reallive <http://www.reallivemoms.ca/> moms.ca/ [Non-text portions of this message have been removed]
In a message dated 4/23/07 10:24:10 AM, e.neilsen2@... writes: > Speaking of which, I output some files yesterday with LR and some PFP > colorized profiles and they printed as expected; not too dark. > Pleased to hear you are working with PFP. As for Lightroom, its a strange situation; there's no way to turn off the "flavoring" to print a profiling target, but whether custom profiles (built from targets printed from Photoshop or PFP, NOT from Lightroom) print properly from an image in that "flavored" workflow is an open question... it depends on a number of factors, certainly the settings you use (some settings simply aren't available in Lightroom) and I suspect there may be a factor or two that haven't been disclosed yet. But yes, its possible get nice prints from it... if it does what you want. I believe users are printing a file from Photoshop, and the same file In Lightroom, and complaining that the two prints aren't identical, rather than editing in Lightroom, and complaining about the screen to print match. These are two different issues. C. David Tobie Product Technology Manager ColorVision Business Unit Datacolor Inc. CDTobie@... www.colorvision.com ************************************** See what's free at http://www.aol.com. [Non-text portions of this message have been removed]
I did not do side by side comparisons through LR and PS or the same image, but the image printed like it looked on the screen ( not the PFP image as that was a colorized profile) but not too dark which was the complaint. I don't have a 2400 and don't have the screen that shows, Best Photo, is that allowing you to turn off ALL color management? Select custom and turn all the others OFF. Choose your paper type and print. Pierre, What OS/platform are you using? You can do a screen capture and send it too me, or post it to the group. Eric Neilsen Photography 4101 Commerce Street, Suite 9 Dallas, TX 75226 214-827-8301 http://ericneilsenphotography.com Skype : ejprinter _____
From: DigitalBlackandWhiteThePrint@yahoogroups.com [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of CDTobie@... Sent: Monday, April 23, 2007 9:32 AM To: DigitalBlackandWhiteThePrint@yahoogroups.com Subject: Re: [Digital BW] Importing 8 bit duotone images into Lightroom w/ PSCS2 compatibility enabled In a message dated 4/23/07 10:24:10 AM, e.neilsen2@worldnet <mailto:e.neilsen2%40worldnet.att.net> .att.net writes: > Speaking of which, I output some files yesterday with LR and some PFP > colorized profiles and they printed as expected; not too dark. > Pleased to hear you are working with PFP. As for Lightroom, its a strange situation; there's no way to turn off the "flavoring" to print a profiling target, but whether custom profiles (built from targets printed from Photoshop or PFP, NOT from Lightroom) print properly from an image in that "flavored" workflow is an open question... it depends on a number of factors, certainly the settings you use (some settings simply aren't available in Lightroom) and I suspect there may be a factor or two that haven't been disclosed yet. But yes, its possible get nice prints from it... if it does what you want. I believe users are printing a file from Photoshop, and the same file In Lightroom, and complaining that the two prints aren't identical, rather than editing in Lightroom, and complaining about the screen to print match. These are two different issues. C. David Tobie Product Technology Manager ColorVision Business Unit Datacolor Inc. CDTobie@colorvision <mailto:CDTobie%40colorvision.com> .com www.colorvision.com ************************************** See what's free at http://www.aol. <http://www.aol.com.> com. [Non-text portions of this message have been removed] [Non-text portions of this message have been removed]
2007-04-24 by Pierre
I agree with you that there are a few issues to contend with. I use a Dell laptop right now but am considering getting a Mac next year. I believe that future versions will improve on many fronts but in the mean time I'm hoping that Lighroom and Aperture will compete against each other and that the result will benefit both applications and everyone. In my case I only had about 4 files setup that way so I managed to find them along with a few others that I had the compatibility mode turned off and managed to get them fixed. I did print the dialog so I didn't have to manually copy the file paths but they should give you more options to handle such situations. I also wish they had a better way of handling metadata across the various Adobe applications. You get extra features by using the database but when you export to sidecars you loose some of the hierarchy you can develop for things such as keywords. Maybe CD Toby has some suggestions for searching out such files. Thanks for the input. :o) Pierre
-----Original Message----- From: DigitalBlackandWhiteThePrint@yahoogroups.com [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Eric Neilsen Photo Sent: April 23, 2007 10:21 To: DigitalBlackandWhiteThePrint@yahoogroups.com Subject: RE: [Digital BW] Importing 8 bit duotone images into Lightroom w/ PSCS2 compatibility enabled Pierre, The folks at Adobe really pissed me off with their lack of compatibility with LR and their other image products. I suppose it can't be all things to all people but there are many aspects of LR image management that really stink. NON maximized PSD files will not import into LR either. I also ran across some 325mb Tif files that were report to be too large. I don't know of a search that you can do to identify Duotone, Tritone or Quadtone files. LR will tell you when a file will not be imported but will not allow you to copy or export that list so that you can trouble shoot the list. Sure you could manually write them down and if there were only a few that is work around but with thousands of image files and possibly hundreds that don't flow into LR, you are left with the task of some other tracking system. All Duotone, Tritone or Quadtone files need to be converted to RGB in PS. The conversion will keep the color properties that you assigned them and then can be read by RGB programs. Eric Eric Neilsen Photography 4101 Commerce Street, Suite 9 Dallas, TX 75226 214-827-8301 http://ericneilsenphotography.com Skype : ejprinter _____ From: DigitalBlackandWhiteThePrint@yahoogroups.com [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Pierre Archambault Sent: Monday, April 23, 2007 8:44 AM To: DigitalBlackandWhiteThePrint@yahoogroups.com Subject: RE: [Digital BW] Importing 8 bit duotone images into Lightroom w/ PSCS2 compatibility enabled Good morning Eric, I recently purchased Lightroom and wanted to use it to allow me to navigate my library of images. This file in particular was process 2 years ago so I wasn't starting fresh from a raw file. As far as my use of the PS duotone mode, it was based on what little experience I had at the time. I usually keep everything in 16 bit throughout my workflow but in this case I noticed that I couldn't use the PS feature unless I when down to 8 bits and at the time I didn't know a better way to achieve this look. Please feel free to suggest some work around that would enable me to see thes few files I have under Lightroom. Thanks, Pierre
Eric, I use Windows XP w/ Lightroom + PSCS2 + QImage Studio to print on an Epson 2200. I haven't used Lightroom to print yet. I do mostly color but am getting back into B&W from wet darkroom techniques from eons ago when I was in high school. I would like to help you by doing a screen capture but I am unclear what you whish me to capture. Are you asking me to capture side by side views of the same image one in Lightroom and one in PSCS2? Please clarify what you described in your message. Pierre
-----Original Message----- From: DigitalBlackandWhiteThePrint@yahoogroups.com [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Eric Neilsen Photo Sent: April 23, 2007 11:32 To: DigitalBlackandWhiteThePrint@yahoogroups.com Subject: RE: [Digital BW] Importing 8 bit duotone images into Lightroom w/ PSCS2 compatibility enabled I did not do side by side comparisons through LR and PS or the same image, but the image printed like it looked on the screen ( not the PFP image as that was a colorized profile) but not too dark which was the complaint. I don't have a 2400 and don't have the screen that shows, Best Photo, is that allowing you to turn off ALL color management? Select custom and turn all the others OFF. Choose your paper type and print. Pierre, What OS/platform are you using? You can do a screen capture and send it too me, or post it to the group. Eric Neilsen Photography 4101 Commerce Street, Suite 9 Dallas, TX 75226 214-827-8301 http://ericneilsenphotography.com Skype : ejprinter _____ From: DigitalBlackandWhiteThePrint@yahoogroups.com [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of CDTobie@... Sent: Monday, April 23, 2007 9:32 AM To: DigitalBlackandWhiteThePrint@yahoogroups.com Subject: Re: [Digital BW] Importing 8 bit duotone images into Lightroom w/ PSCS2 compatibility enabled In a message dated 4/23/07 10:24:10 AM, e.neilsen2@worldnet <mailto:e.neilsen2%40worldnet.att.net> .att.net writes: > Speaking of which, I output some files yesterday with LR and some PFP > colorized profiles and they printed as expected; not too dark. > Pleased to hear you are working with PFP. As for Lightroom, its a strange situation; there's no way to turn off the "flavoring" to print a profiling target, but whether custom profiles (built from targets printed from Photoshop or PFP, NOT from Lightroom) print properly from an image in that "flavored" workflow is an open question... it depends on a number of factors, certainly the settings you use (some settings simply aren't available in Lightroom) and I suspect there may be a factor or two that haven't been disclosed yet. But yes, its possible get nice prints from it... if it does what you want. I believe users are printing a file from Photoshop, and the same file In Lightroom, and complaining that the two prints aren't identical, rather than editing in Lightroom, and complaining about the screen to print match. These are two different issues. C. David Tobie Product Technology Manager ColorVision Business Unit Datacolor Inc. CDTobie@colorvision <mailto:CDTobie%40colorvision.com> .com www.colorvision.com ************************************** See what's free at http://www.aol. <http://www.aol.com.> com. [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] Please visit the Group Homepage to check the Files, and other resources as they are often being updated. http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint If you wish to receive no emails or just a daily digest, or you wish to unsubscribe, please edit your Membership preferences by visiting this same page. Please follow these basic guidelines: - As threads develop, trim off excess portions of earlier messages to keep them short. - Good manners are required at all time. No personal attacks or flames. Hostile, aggressive or argumentative users may be removed from the membership without notice. - Keep your posts and threads related to the group topic of digital B&W printing. Users who persistently make off-topic posts may be removed from the membership. - By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See Group Topic, Rules and Guidelines in the Files section: http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/ BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE OWNER AND MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE OWNER AND MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP. Yahoo! Groups Links
2007-04-24 by Eric Neilsen
Pierre, If you can do a screen capture of the Epson printer screen where it says "best photo" then I might be able to make another suggestion. (Or anybody else) I too use a Dell laptop with XP SP2 and Qimage, but until DHL can figure out how to make a simple delivery, I am still waiting to up grade my CS suite to CS3 Design + . I have printed with LR just to try it and see if I was having problems like some were talking about. Eric Neilsen Photography 4101 Commerce Street Suite 9 Dallas, TX 75226 http://e.neilsen.home.att.net http://ericneilsenphotography.com Skype ejprinter _____
From: DigitalBlackandWhiteThePrint@yahoogroups.com [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Pierre Sent: Monday, April 23, 2007 7:34 PM To: DigitalBlackandWhiteThePrint@yahoogroups.com Subject: RE: [Digital BW] Importing 8 bit duotone images into Lightroom w/ PSCS2 compatibility enabled Eric, I use Windows XP w/ Lightroom + PSCS2 + QImage Studio to print on an Epson 2200. I haven't used Lightroom to print yet. I do mostly color but am getting back into B&W from wet darkroom techniques from eons ago when I was in high school. I would like to help you by doing a screen capture but I am unclear what you whish me to capture. Are you asking me to capture side by side views of the same image one in Lightroom and one in PSCS2? Please clarify what you described in your message. Pierre -----Original Message----- From: DigitalBlackandWhit <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> eThePrint@yahoogroups.com [mailto:DigitalBlackandWhit <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> eThePrint@yahoogroups.com] On Behalf Of Eric Neilsen Photo Sent: April 23, 2007 11:32 To: DigitalBlackandWhit <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> eThePrint@yahoogroups.com Subject: RE: [Digital BW] Importing 8 bit duotone images into Lightroom w/ PSCS2 compatibility enabled I did not do side by side comparisons through LR and PS or the same image, but the image printed like it looked on the screen ( not the PFP image as that was a colorized profile) but not too dark which was the complaint. I don't have a 2400 and don't have the screen that shows, Best Photo, is that allowing you to turn off ALL color management? Select custom and turn all the others OFF. Choose your paper type and print. Pierre, What OS/platform are you using? You can do a screen capture and send it too me, or post it to the group. Eric Neilsen Photography 4101 Commerce Street, Suite 9 Dallas, TX 75226 214-827-8301 http://ericneilsenp <http://ericneilsenphotography.com> hotography.com Skype : ejprinter _____ From: DigitalBlackandWhit <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> eThePrint@yahoogroups.com [mailto:DigitalBlackandWhit <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> eThePrint@yahoogroups.com] On Behalf Of CDTobie@aol. <mailto:CDTobie%40aol.com> com Sent: Monday, April 23, 2007 9:32 AM To: DigitalBlackandWhit <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> eThePrint@yahoogroups.com Subject: Re: [Digital BW] Importing 8 bit duotone images into Lightroom w/ PSCS2 compatibility enabled In a message dated 4/23/07 10:24:10 AM, e.neilsen2@worldnet <mailto:e.neilsen2%40worldnet.att.net> .att.net writes: > Speaking of which, I output some files yesterday with LR and some PFP > colorized profiles and they printed as expected; not too dark. > Pleased to hear you are working with PFP. As for Lightroom, its a strange situation; there's no way to turn off the "flavoring" to print a profiling target, but whether custom profiles (built from targets printed from Photoshop or PFP, NOT from Lightroom) print properly from an image in that "flavored" workflow is an open question... it depends on a number of factors, certainly the settings you use (some settings simply aren't available in Lightroom) and I suspect there may be a factor or two that haven't been disclosed yet. But yes, its possible get nice prints from it... if it does what you want. I believe users are printing a file from Photoshop, and the same file In Lightroom, and complaining that the two prints aren't identical, rather than editing in Lightroom, and complaining about the screen to print match. These are two different issues. C. David Tobie Product Technology Manager ColorVision Business Unit Datacolor Inc. CDTobie@colorvision <mailto:CDTobie%40colorvision.com> .com www.colorvision.com ************************************** See what's free at http://www.aol. <http://www.aol. <http://www.aol.com.> com.> com. [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] Please visit the Group Homepage to check the Files, and other resources as they are often being updated. http://groups. <http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint> yahoo.com/group/DigitalBlackandWhiteThePrint If you wish to receive no emails or just a daily digest, or you wish to unsubscribe, please edit your Membership preferences by visiting this same page. Please follow these basic guidelines: - As threads develop, trim off excess portions of earlier messages to keep them short. - Good manners are required at all time. No personal attacks or flames. Hostile, aggressive or argumentative users may be removed from the membership without notice. - Keep your posts and threads related to the group topic of digital B&W printing. Users who persistently make off-topic posts may be removed from the membership. - By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See Group Topic, Rules and Guidelines in the Files section: http://groups. <http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/> yahoo.com/group/DigitalBlackandWhiteThePrint/files/ BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE OWNER AND MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE OWNER AND MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP. Yahoo! Groups Links [Non-text portions of this message have been removed]
