Re: [Digital BW] Scanning Black and White With Vuescan
2007-07-15 by Brian Ellis
I always scanned my b&w negatives as b&w in Vuescan. When I tried scanning
them as color I noticed no difference except the much larger file. OTOH, if
you go to www.butzi.net and click on the "Articles" section you'll see the
results of a test done by Paul Butzi. He maintains that it's better to scan
in RGB, then use Channel Mixer to look at the red, blue, and green channels
to find the one that looks best and discard the other two. I don't know, the
differences he sees between the three looked pretty tiny to me even at his
magnifications. But you can easily try it both ways and see for yourself.
Sent: Sunday, July 15, 2007 11:28 AM
Subject: [Digital BW] Scanning Black and White With Vuescan
I am just starting to try my hand at black and white digital imaging
and am actually starting with a Holga and a pinhole camera using Kodak
Tri-X.  I recently purchased an Epson V700 scanner and Vuescan
software.  Looking around the internet, the general advice seemed to
be to scan black and white negatives as if they were color images and
then convert to grayscale afterwards.  I do notice that Vuescan has a
scan black and white negative as an option.  Since this is Vuescan and
not some prepackaged scanning software I was wondering how folks here
recommend doing this with Vuescan (I realize this isn't a Vuescan
forum but figure there are lots of people here using it with a lot of
experience)....is it best to scan as a color slide or a color negative
and convert to grayscale or will the Vuescan scan as black and white
negative give the best results (ie, has Vuescan taken all this into
account and will setting the source as black and white negative give
me the best results)?
Thanks.
Howard
they are often being updated.
page.
them short.
membership without notice.
the membership.
Yahoo! Groups Links
2007-07-15 by howg2211
Thanks.
Howard
2007-07-15 by Bruce Watson
> Thanks.
> Howard
Why guess when you can know? Scan the same negative in different ways
and compare. What works for someone else won't necessarily work for you.
And scanning isn't automatic. The only way to get good at it is to scan,
and scan, and scan. So you can kill two birds with one stone as it were.
Scan and scan and scan. It's the only way to learn what the different
settings mean, and what they do, for your film. I'm serious.
Bruce Watson
2007-07-15 by Peter De Smidt
> experience).
> Thanks.
> Howard
Howard,
Really the only way to know is to try each way and compare results.  I
scan with "make gray from green channel" because it gives the best
results with my scanner.  You don't want to use a "color negative"
setting, as this changes things to get rid of the orange mask of a color
film, which regular bw films don't have.  I usually set the "color"
settings to manual, and set the black and white clipping settings at
"0".  Basically, you want a low contrast scan that includes as much info
as possible.  Make sure that you set up viewscan show that clipped
shadows and highlights get represented by colors (usually blue and
green)  on the scan screen.
-Peter
2007-07-15 by djon43
Silver B&W scans perfectly with the B&W setting but maybe C41 B&W is
different?
Importantly C41 B&W allows use of Infared...maybe that wants RGB?
Don't know about that.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Brian Ellis
channels to find the one that looks best and discard the other two.
Butzi's advocating an outright silly workflow IMO. He's paying
attention to the "look" of the scan on his monitor rather than his
post-processed file (or soft proof) in Photoshop, his print, or
Internet image. Bassakward.
2007-07-15 by Jules
There is no advantage to scanning a b&w neg in RGB as the three
channels (and hence the three times larger file) will be identical.
However, my printer tells me that i should supply him with RGB files
of my b&w work as they contain more information. I have never quite
understood this but I do it.
 If you convert to monochrome in the channel mixer the three different
channels WILL look different. Very different in some cases. Yes it's
true that you can select the one that you like but there is an optimum
percentage mix that I have seen recommended. I don't know if you used
to shoot with different b&w films years ago but if you compared the
same shot of a colourful subjecttaken with Tri-X and say Plus X they
were very different as the films reacted to different colours differently.
I personally don't use the Mixer method to convert to B&W but use the
Lab method and prefer those results. The method is explained on the
web if you do a search. Try it and see what you think. It is good and
much better than Desaturate.
Jules
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Bruce Watson
> > Thanks.
> > Howard
you.
scan,
were.
> Bruce Watson
2007-07-15 by Dana H. Myers
> different?
I haven't been using Vuescan - I use the Nikon scanning S/W
with my LS-9000.  I scan B&W negs as 16-bit monochrome.
C41 B&W, I usually scan as monochrome, but I haven't scanned much of
it in a while.  The Nikon S/W lets me enable Digital ICE even when
scanning as monochrome, though I haven't really experimented with it
much because, as I mention above, I haven't scanned much C41 B&W.
Dana
> <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com>, Brian Ellis
No actually, they won't be identical. Even B&W negatives have some level
of color, usually depending on developer. HC-110 leaves Tri-X somewhat
purple, while XTOL leaves Tri-X somewhat brown, for example.
The question is, is capturing this slight color cast worth anything? I
personally don't think so, but clearly this going to vary depending on
what the individual wants.
Now if you are working with one of the staining developers like
Procat-HD, the stain contains image data and you should really think
about scanning in RGB to capture this data. But I'm assuming a "normal"
developer here.
Theoretically this is true. A single scanner channel has less dynamic
range than the three channels taken together. There is a similar effect
with thermal noise in that more channels helps dampen scanner induced
noise. But from a practical standpoint, especially with B&W negatives, I
doubt the need for this. IOW, I believe that the three channels together
contain more data, but not necessarily more information which is a
different concept.
Bruce Watson
If you scan B&W as B&W channel mixer is irrelevant.
differently.
Not in my experience or for practical purposes, but it'd be
interesting to confirm. I shoot silver film now, as I have since 1951
(I was 8). All but Verichrome Pan and Kodalith are "panchromatic."
the Lab method and prefer those results. The method is explained on
theweb if you do a search. Try it and see what you think. It is good
and much better than Desaturate.
> Jules
Channel mixer and Desaturate are both irrelevant as Bruce Watson is
scanning Tri X.
Kodak
> > > Tri-X.  I
2007-07-15 by Tyler Boley
this is exactly the point of doing some b&w negs scan tests in RGB- to investigate the
possibility of a superior channel, or channel combination as you describe. Once
determined, if you have the channel option for mono as you describe (Silverfast also has it,
I've seen it elsewhere as well) there is no reason to make the larger RGB scans from B&W in
the future.
If you have a clearly desirable channel, and no such option in the software, there is no
choice but to scan in RGB then toss out the other channels once in Photoshop.
It is quite possible some scanners perform well in all channels, and a more typical RGB to
Gray conversion in the scanner software or elsewhere will be fine, or desaturate, or LAB, or
whatever your prefer.
Another reason to investigate individual channels to optimize workflow is for staining
developer users.
Some software has problematic LUTs for B&W negs, that never give you access to all the
info on some or all negs. This would be another reason to use an alternative procedure-
scan as a transperency to open up the capture range, and invert in PS later. Or, with
Vuescan use the raw file, or Silverfast's HDR.
Tyler
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Peter De Smidt <pdesmidt@...>
> Vuescan allows you to make a greyscale file from any of the color
> channels.  I tried the default way, and then each of the various color
> channels.  The green channel with my Canon 9950F gave the most detail
> with the least noise for scanning BW silver negatives.  As such, I set
> Vuescan to make the grey 16 bit image from the green channel. This does
> not require having an RGB image, with the resultant huge file size. It's
> easy to test these things. Try each way. Make sure to label the file
> with an appropriate name.  Open them in Photoshop and compare.
Re: Scanning Black and White With Vuescan
2007-07-15 by david627890
I agree with Jules, different B&W films have different responses to
colour, despite all being labelled as "panchromatic".  If you try a
search you should be able to find someone who has shot a colour test
chart with different films and published the results - its surprising
how much variation there is in the mid tones!
David
channel mixer isn't involved if one is scanning silver B&W...
differently.
Not in my experience or for practical purposes (that's what B&W
filters are for), but it'd be interesting to confirm. It's technically
true that different panchromatic B&W films have different spectral
responses but I don't think it's relevant for practical purposes.
I shoot silver film now, have since 1951 (I was 8). All readily
available films but Verichrome Pan and Kodalith, and perhaps some
technical films, have been fully "panchromatic."
> Jules
Neither Channel mixer nor Desaturate are relevant as Bruce Watson is
scanning Tri X. They would be relevant if he was shooting color film
for B&W.
Kodak
> > > Tri-X.  I
2007-07-15 by scott_now_coming
Howard,
Try both and see what works best for you.
For me, scanning in 16-bit grayscale works the best
Scott
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "howg2211"
Kodak
and
a
and
here
of
negative
> Thanks.
> Howard
Thanks for the thoughtful and many responses.  I was hoping not to try
to reinvent the wheel, but it looks like I may have some testing to
do.  Right now I am learning the developing in the basement
routine....and having fun at it.  A nice diversion from pure digital.
Anyway, once I get past that stage and have an assortment of negs to
work with I will start scanning in earnest.  Once I see what the
options are I will probably come back with a few more questions.  In
the meantime, I will be reading the great advice you guys are putting
forth in the forum here.
Thanks.
Howard
"There is no advantage to scanning a b&w neg in RGB as the three
channels (and hence the three times larger file) will be identical."
The test done by Paul Butzi that I mentioned in my earlier post shows that
the three are different, at least with the film and scanner he was using.
Sent: Sunday, July 15, 2007 3:14 PM
Subject: Re: [Digital BW] Scanning Black and White With Vuescan
Jules
> > Thanks.
> > Howard
you.
scan,
were.
> Bruce Watson
page.
them short.
the membership.
Yahoo! Groups Links
> is for staining
> developer users.
Tyler,
That's a very good point. I used Xtol for years, but recently I switched
to Pyrocat-HD, a staining developer.  Looks like it's time to run
another test. Sigh. I hate tests.
-Peter
2007-07-16 by djon43
First,  even stains in negatives usually prove inadequately removed
antihalation dye...insufficient fix/wash. It's equivalent to fog when
printing or scanning..it reduces contrast evenly but may suggest the
negative wasn't adequately fixed/washed.
Second, very few people use staining developers, probably nobody with
 TriX/Holga. Staining developer ideas simply confuse things here.
COMPLETELY OFF TOPIC>>>It happens that I've inquired of folks who DO
use staining developers and scan...they've told me scanners treat the
stain identically to silver..it's considered colorless density by the
scanner when in B&W mode, just as it is when using an
enlarger...that's the whole point of a staining developer! (some say
the stain color is faintly noticed by polycontrast paper but not
significantly.
Just to make the point about file size, a B&W neg that I just scanned
as as if it was a chrome is 120.3MB...(can be inverted in Photoshop to
look like a positive...not necessary with Vuescan, best practice with
Nikonscan). The same neg scanned as a B&W neg produces 40.1MB and
won't have to be inverted.
John
RE: [Digital BW] Scanning Black and White With Vuescan
2007-07-16 by Paul Grant
I for one can tell you that it does make a difference in Staining developers
to scan in RGB mode. There is a visiable difference and it can be easily
seen when printing in the darkroom.  That is the point of using a staining
developer.  Separately it is my understanding the the majority of scanners
all scan in RGB and the scanner software whether it is Vuesan,Epson or
Silverfast just convert the RGB image to greyscale in software.   Frankly I
would rather take charge of that conversion myself and do it in Photoshop
with whatever method I chose.
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of djon43
Sent: Sunday, July 15, 2007 7:31 PM
significantly.
John
2007-07-16 by Ernst Dinkla
Two scanners I have the Nikon LS8000 and the Epson V700 can
only scan in RGB hardware wise whether the software is set
on greyscale or color.  Vuescan will emphasise the green
channel but still pick up part of the other channels in the
conversion to greyscale if I recall some messages by Ed.
My old Agfa  Horizon Plus A3 has a monochrome sensor that
needs 3 passes for color and isn't very good for that work
anymore but it has a one pass Greyscale setting where the
color filter is replaced by a ND filter that works very
good, 1200 PPI only but up to A3 if needed. I use it mainly
for old graphic films.
Related to that, we see all kinds of B&W conversions of
color devices: printers that are changed to quad inksets,
cameras that are stripped of their Bayer filters, but no
scanners that have their sensor filters removed for B&W
scanning. Could be impossible if the filter is within the
glass of the linear sensor strips. But if possible one could
even partition the 3 sensors with 2 grades of ND filters and
one without to increase the dynamic range. RGB filters have
different density levels but not as ideal as it could be.
Met vriendelijke groeten,  Ernst
|  Dinkla Grafische Techniek  |
|     www.pigment-print.com    |
|             ( unvollendet )            |
Re: [Digital BW] Scanning STAINED negs ( Holga?)
Howard's original question had nothing to do with staining developers.
**I've sent a note to Sandy King, asking his thoughts.
Howard, Want to make your own developers? I'd thought your question
was more photographically oriented than boy-chemist oriented :-)
http://unblinkingeye.com/Articles/PCat/pcat.html
http://www.freestylephoto.biz/sc_prod.php?cat_id=&pid=1000000387
"I am just starting to try my hand at black and white digital imaging
me the best results)? "
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Ernst Dinkla
<E.Dinkla@...> wrote:
developers
easily
staining
scanners
Frankly I
Photoshop
> |             ( unvollendet )            |
2007-07-16 by Jules
Thanks for clarifying my post Djon. I thought I was clear that the
channels were relevent to scanning, or importing colour. Using
different b&w fims did hive different results as the different
processes in manufacturing them reacted differently to different colours.
Jules
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "djon43"
> differently.
> > Jules
> scanning Tri X.
> > <bwyg@> wrote:
imaging
> Kodak
> > > > Tri-X.  I
2007-07-16 by Jules
What is the meaning of the word 'staining' used here and previously.
I have no idea of it's meaning unless it is some reference to 'toning'
as used to be done to B&W prints. Please explain.
Jules
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Tyler Boley"
to investigate the
describe. Once
> the future.
Photoshop.
> developer users.
access to all the
PS later. Or, with
> Tyler
<pdesmidt@>
color
set
does
size. It's
Jules, Some developers stain emulsion selectively, which does with
certain images sometimes increase shadow detail. As well, stain tends
to conceal grain without dissolving it. Almost exclusively  relevant
to "scenic" photography (not commonly of interest to people who use
fast film), it has less to do with "image" and more to do with
"print." Practitioners commonly develop sheet film, one at a time in
trays, though it can certainly be done with 35mm in tanks.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Jules"
STAINED B&W Vs conventional B&W negs
Sandy King's response to my query:
I am suggesting scanning B&W negatives in RGB, but only if they were
developed in a pyro staining developer. Negatives developed in
non-staining developers should be scanned in grayscale as there is no
advantage to scanning in RGB.
And yes, if memory and file size is not an issue I would recommend
scanning stained negatives in RGB and then looking at the channels to
see which one (s) give the best tonal range. In most cases there is
no advantage over scanning grayscale, but sometimes there is.
Sandy
At 7:43 AM -0700 7/16/07, john kelly wrote:
>Sandy, thanks..
>I may be missing something here...
>Are you suggesting scan of stained B&W negs as color
>neg or transparency, then reviewing channels?
>Do you think this is better than scanning as B&W?
>I understand the file size issue, but if memory wasn't
>an issue, would you scan B&W stained negs as B&W or as
>color?
>Is there any argument for scanning non-stained B&W
>negs as color?
2007-07-16 by Jules
Well, I'm 57 and started my photography and developing my own in
about1965 and then studied photography full time for three years in
the seventies and I never heard of satining before. I guess we learn
something new every day.
Jules
2007-07-16 by olaf ringdahl
Howard,
With my scanner, the Canon 4000, there is a huge difference between the RGB
Color Negative 42 bit setting and any of the monochrome settings. Each
monochrome setting gives me a single channel to work with, take it or leave
it. The Color Negative setting gives me three very different channels with
the option of working with any one, two or all three of them. On my
particular scanner the red channel is always the lightest, the blue channel
is always the darkest and the green channel is always in between. I usually
work from the green but when I have a problem with nearly blown out
highlights and weak shadow detail in the same photograph I will sometimes
use two channels, painting from one to the other.
Maybe there should be no difference between channels but with my scanner
there is and I find the difference very useful.
My suggestion: Listen to all of your friends on this forum and then try
everything with your particular scanner and see what works best for you.
Olaf
