--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Eric Neilsen"
<e.neilsen2@...> wrote:
> Joost, Not all papers are ; the same thickness, take the same
amount of time
> to absorb/dry ink, etc. The printers are pretty amazing but they
really are
> stupid. They don't know what paper is being put into them, so you
might need
> to make adjustments to paper feed, dry time, thickness, etc to get
the best
> out of each paper.
Yes, I know all this. But in this particular case we're talking about
the combination of HPR and EEM. EEM is often advocated as a good
draft paper for HPR.
And indeed, the print shades I get on both papers are very much
alike, good enough for me.
Furthermore, the QTR curve I'm using is a curve calibrated for HPR,
not EEM. So if a paper would be priviliged, it would would be EEM
over HPR.
> That being said, flatter smoother papers will show more detail that
rougher
> papers. EEM is a smoother paper than HPR 308. is that 188 you are
using?
I'm using HPR 308, which is indeed somewhat rougher than EEM. But I'm
surprised if this could explain the difference??
Can I expect a different result on HPR 188??
> Eric
> Eric Neilsen Photography
> 4101 Commerce Street
> Suite 9
> Dallas, TX 75226
> http://e.neilsen.home.att.net
> http://ericneilsenphotography.com
> Skype ejprinter
> _____
> [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of
Joost
> Horsten
> Sent: Sunday, April 13, 2008 11:30 AM
> Subject: [Digital BW] more detail with EEM than with PhotoRag(?)
> Hi all,
> Normally, PhotoRag is my paper of choice and I use Epson Enhanced
> Matte as draft paper. My default print size is A4.
> Lately I'm making some smaller prints (A5-A6) with quite some
detail.
> And I notice that my EEM prints show clearly more detail than the
> ones on PhotoRag. The paper is the only thing that changes. All
> prints are made on an Epson 2100, UT3D inks, QTR. In both cases I
use
> the very same QTR curves (made with an Eye-One). No, I don't print
on
> the back side of PhotoRag - once in a while I do by mistake, and
then
> the difference is MUCH bigger :O).
> I think I observed the same phenomenon earlier, but can not recall
it
> was that clear. Perhaps I notice better because of the smaller
print
> size? Or I got a different batch (of both PhotoRag and EEM) with
some
> more difference.
> Have you seen the same thing?
> Joost
