Is MIS's Eboni Black the same as R1800 MK?
2008-05-10 by Bob Marsolais
I was told by a vendor of Image Specialist inks that the Eboni Black
ink sold by MIS is the same ink as the matte black used in the IS bulk
inks for the R800/R1800.  Can anyone confirm or deny this.  Has anyone
compared output from the two inks on the same media?
Thanks all!
Re: Is MIS's Eboni Black the same as R1800 MK?
2008-05-10 by ferdinand_paris
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Bob Marsolais"
> Thanks all!
I've asked this question before, and got a definite "maybe".  Even
people who are in the know and who know other people in the know can't
be sure.
F_p
2008-05-11 by Greg
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "ferdinand_paris"
> > Thanks all!
> be sure.
> F_p
I would suggest that you simply buy by the Image Specialists part
number http://www.inksupply.com/imagespec.cfm The only problem for
some people is that you need to buy them in ~500ml bottles. I would
suggest the WJ1082 matte black ink. Cross reference to these ink (or
others) on the Image Specialists web site
http://www.image-specialists.com/catalog_pigment_ultra.aspx
Epson R1800 3MK + 5 dye color inks?
2008-06-21 by Panmedia
To print B&W on matte and color on glossy papers, is it possible to use
3MK on R1800 with 5 dye color inks instead of Epson's original
UltraChrome color inks?
R1800 has 5 UltraChrome color inks: cyan, magenta, yellow, plus red and
blue. They are more for matte paper without gloss optimizer. How if I
use five compatible dye inks: cyan, magenta, yellow, light cyan, light
magenta?
Or, if dye black is required to print color photos, is it possible to
make it:
    MK+MK+PK+C+M+Y+LC+LM
- philip
Re: Epson R1800 3MK + 5 dye color inks?
2008-06-21 by pr_roark
With a rip that can handle color, the 1800 has lots of
possibilities.  However, the Epson drive requires the expected colors
to be in their expected places, and QTR does not pass the color
information through the rip.  It converts to grayscale.  (I'd like to
see a versionn of Create ICC-RGB that does pass the color information
through.)
Don't use dyes; Eboni is not compatible with them.
I'd recommend you use MIS (or Epson) color pigments that are designed
for the 1800 plus the 3-MK.  To print glossy, just swap out the MK in
the PK spot and do not check "gloss" in the driver.  Then the Epson
driver will print color as usual, using the PK when a glossy paper
type is used.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Panmedia
use
and
I
light
> magenta?
to
> make it:
> Thanks,
> - philip
Re: [Digital BW] Re: Epson R1800 3MK + 5 dye color inks?
2008-06-26 by Panmedia
Thanks Paul. After reading your email I dropped my plan to use dye inks
in R1800 together with 3MKs. Instead, I have some UT7 inks available and
it was originally for an Epson 2200 printer. Is it possible to use the
ink on the same R1800 with 3MK together to make it multiple choices
where I can choose to print 3MKs, or MKs with gray or toned inks??
For R1800, the rest of 5 unused ink positions are: Cyan, Magenda,
Yellow, Red, Blue
Other than MK/PK, UT7 has 6 inks: light black, dark gray, light gray,
cool tone, sepia tone, light cool tone
I would like to use light black, dark gray, light gray, cool tone, sepia
tone in R1800's 5 positions. Any suggestion to set this up?
BTW I printed a few pictures using 3MKs onto different sized Moab
Entrada natural paper. Looking at the results I feel 3MK method is very
excellent on 11x17 or larger paper. But for letter size some light
black/gray/light gray inks may help to smooth the transition especially
on light human skin tone.
- philip
> through.)
> type is used.
> Paul
> www.PaulRoark.com
> <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com>, Panmedia
> use
> and
> I
> light
> > magenta?
> to
> > make it:
> > Thanks,
> > - philip
2008-06-27 by pr_roark
>... I have some UT7 inks available and
The UT7 inks are physically compatible with the 1800.  If you're
proficient with QTR you could certainly come up with some combination
that would make the 1800 a variable tone printer.
> Yellow, Red, Blue
> light gray, cool tone, sepia tone, light cool tone
The UT7 was made so that it could run on a k2 printer using the Epson
driver.  That won't work with the 1800.  The LK, in particular, is
going to be redundant and not needed.  It was a compromise due to the
Epson driver and the inability to stop the LK from being used.  It is
a blended ink -- just a little blue in it.
As noted above, I'd avoid the UT7 LK. It simply will not add much.
The UT7 light and dark grays -- in addition to an MK or PK -- should
be all you'll need for your carbon channel.  Use broad skirts -- lots
of overlap -- on the curves to suppress microbanding.
> cool tone, sepia tone in R1800's 5 positions.
If you dump the LK, you could ad a PK and have glossy compatibility.
Good luck with the system.
