Doepfer
rack compatibilty
rack compatibilty
2007-09-04 by funkycholrton
Hi
I have a s6U ystem which is about half doepfer and the rest is
analogue systems and analogue solutions. at the moment I have it in a
homebrew wooden case with wooden rails.
If I moved the whole thing into a doepfer suitcase would I have
trouble combining the other modules with Doepfer in the same row? It
seems the hole spacing might be different??
I am wondering how people get around this?
Richard
Re: [Doepfer_a100] rack compatibilty
2007-09-05 by James Husted
I have both Doepfer and AS in my 2 portable rack cabinets (which are
VERY nice units BTW) and there is a spacing difference in the two
manufacturers - it is equal to half the space between two screw holes
in the rails. All this will result in is a gap between the set of AS
modules and the Doepfer ones of half the space between two rail holes
- not very much. I have to admit that I went to the effort of
drilling new holes on my AS modules to compensate (I'm sorta anal
about it though). As long as you keep the AS modules together there
will only be the gap between them and the Doepfer modules (not
between the AS modules themselves)
-James
On Sep 4, 2007, at 2:41 PM, funkycholrton wrote:
> Hi
> Richard
AW: [Doepfer_a100] rack compatibilty
2007-09-05 by hardware@doepfer.de
> -James
If you send me a dimensional drawing I could ask our front panel
manufacturer to produce a blind panel ( "1.5 TE" or so) to compensate the
gap. It would be cheap (~ Euro 2...3) provided that we obtain sufficient
pre-orders (min. 50, otherwise the price will increase because of the
non-recurring machine programming charges).
Best wishes
Dieter Doepfer
Bakis - how about a poll (including the option "would you buy such a
compensation panel if it's in the Euro 2...3 range)
2007-09-05 by Silas Johansen
When mounting a Doepfer bus board in a "generic" eurorack case I came upon
a  similar problem (I think Doepfer uses individual nuts for mounting bus
boards whereas this case came with a rail). I snapped the rail in halves,
then removed a hole or two more and now it all fits. Whether you would do
that with rails for module mounting is a different matter, though, as you
may want to have some flexibility in rearranging your modules and breaking
the rails in halves may result in some trouble when reorganizing later.
/Silas
> -James
> > Hi
> > Richard
> > Yahoo! Groups Links
Re: rack compatibilty
2007-09-05 by helitr0n
For my DIY rack I used something that is called "Gleitmuttern" in
german."slide nuts" would be the english translation, but i am not
sure. I got them from Proma in germany - the same company that
produces the doepfer euro-racks. www.proma-systro.de
with those i dont have any compatibility problems between modules.
hel
came upon
mounting bus
halves,
would do
as you
breaking
> /Silas
> > -James
> > > Hi
in a
> > > Richard
> > > Yahoo! Groups Links
Re: AW: [Doepfer_a100] rack compatibilty
2007-09-05 by Bakis Sirros
ok, Poll is ready!
please vote!
it will last for 3 weeks from now.
best regards,
Bakis.
> cabinets (which are
> the effort of
> (I'm sorta anal
> modules (not
> > -James
> front panel
> Best wishes
> Dieter Doepfer
[Doepfer_a100] group owner
http://www.myspace.com/interconnectedmusic
http://www.myspace.com/memorygeist
http://www.DiN.org.uk
http://www.shimarecords.co.uk
http://www.rubber.gr
Athens-Greece
Yahoo! oneSearch: Finally, mobile search
that gives answers, not web links.
http://mobile.yahoo.com/mobileweb/onesearch?refer=1ONXIC
2007-09-08 by James Husted
I would imagine that 1.5TE (around 7.5MM) wide module would work
fine. Just add 2.5mm to one side of the standard 2hp blank module. It
would be nice to offer them in pairs since most often they would be
used that way (on both sides of a single or group of AS modules). The
AS modules are all multiples of 6HP wide which is not a problem but
the main difference is the all have their mounting holes 5 mm from
the panel edges where the Doepfer ones are 7.5 mm from the edges.
This difference leaves the 2.5 mm gap between modules. A panel that
is 7.5 mm wide would fill this gap. to some this may be too big of a
blank panel to use. Another option may be to just offer a cheap
utility module, like a multiples module, in a version that is 2.5 mm
wider. of course since using a AS module in a Doepfer system would
leave a gap on both sides it would cost more to plug that gap with
two multiple modules instead of two blanks.
-James
>> -James
> compensate the
> sufficient
> Best wishes
> Dieter Doepfer
