Doepfer
reverb sheild
reverb sheild
2005-03-28 by thomasborax
hi ladies (hopefully there's 1 or 2) and gentlemen-
i was talking to shawn at analogue haven, who recommended against my
putting a spring reverb in a suitcase.  i wondered if anyone tried
this using the new PSU, which supposedly causes less noise due to ring
core transformer?
also, i'm curious if anyone has attempted to sheild the reverb unit?
perhaps covering it in tin foil, and attaching a ground from the
transformer or bus board to the foil?
i could drill holes of course, but i'd like to have the tank nice and
snug in the case so i don't have to futz with it when traveling.
thx-
tom
Re: [Doepfer_a100] reverb sheild
2005-03-28 by jkn@johei.com
I'm very interested in the answer to this one also... I was planning to
put one into my (future) suitcase.    The manual to it mentioned placing
it away from sound sources - is that easier to do in a rack rather than a
suitcase?   Note - I don't own any Doepfer gear yet - I'm in the
researched and read just about everything, but haven't actually bought
anything yet category...
jkn
> core transformer?
> thx-
> tom
AW: [Doepfer_a100] reverb sheild
2005-03-29 by Dieter Doepfer
We have built a shield (before the PSUII) made of 1 mm steel that covered
the spring system completely but it did not help very much. The problem is
the magnetic shielding not the electrical shielding. A simple foil will not
help from our experience. The only material I know that can be used for
magnetic shielding is u-metal (the greek u). I don't know if the same term
is used in English language. But this material is very expensive and hard to
find.
We show the A-199 in a suitcase with PSUII in Frankfurt. I will tell you the
results after the fair.
Best wishes
Dieter Doepfer
2005-03-29 by Josue Arias
Hi Dieter and group
In English is know as mu-metal, and very expensive, you can get some
of them here:
http://www.lessemf.com/
Best Regards,
Josue.
On Tue, 29 Mar 2005 13:09:01 +0200, Dieter Doepfer <hardware@doepfer.de> wrote:
> find.
> Best wishes
> Dieter Doepfer
Re: reverb sheild
2005-03-30 by thomasborax
hello-
great link.  thx!  expensive yes, though the amount needed is
small...who can put a value on a wild reverb sound?
--t
> Hi Dieter and group
> of them here:
> Best Regards,
> Josue.
> On Tue, 29 Mar 2005 13:09:01 +0200, Dieter Doepfer <hardware@d...>
unit?
covered
problem is
foil will not
used for
same term
and hard to
> > find.
tell you the
> > Best wishes
> > Dieter Doepfer
> > Yahoo! Groups Links
Re: reverb sheild
2005-10-13 by Ernst Karel
Can anyone report on having tried this mu-metal in a suitcase with the old power supply?
Does it completely eliminate the hum?
thanks,
Ernst
--- In Doepfer_a100@yahoogroups.com, "thomasborax" <thomasborax@y...> wrote:
> hello-
> --t
> > Hi Dieter and group
> > of them here:
> > Best Regards,
> > Josue.
Re: reverb sheild
2005-10-15 by thomasborax
ernst-
as it happened, i never tried the mu metal.  i didn't find the price
prohibitive, since it only required 20$ to do the job, and i did find
that goofy sheilding company kinda charming, but i did something else
which turned out pretty easy.
i drilled a hole through the wood strip across the bottom of the
front panel, cut the rca cable coming from the pc board halfway
between the board and the jacks, threaded the remaining lenth of
cable through the hole, screwed the module in, and soldered the jack-
end of the cable back onto the rest of the cable.  whenever i pack up
the suitcase for a gig, i just unplug the tank (which sits wherever
away from the psu) and tuck the cable in along with my patch mess and
close the door.
doesn't answer your question, but if i recall correctly you already
drilled mults in your wood strip, so you probably wouldn't find
another hole sacrelige.
ok-tom
--- In Doepfer_a100@yahoogroups.com, "Ernst Karel" <eklkrl@g...>
> thanks,
> Ernst
> > hello-
> > --t
> > > Hi Dieter and group
some
> > > of them here:
> > > Best Regards,
> > > Josue.
Re: reverb sheild
2008-08-19 by swordsect
My A-199 has an awful buzz, i've tried moving it as far away from
the PSU as possible, there's still a buzz, its pretty much useless
at this point because its so bad.  So for the Mu-Metal Foil, if you
were to get some of this, where would you put it on the module?
would you just wrap the RCA cord in it?  Thanks! Jon
--- In Doepfer_a100@yahoogroups.com, "thomasborax" <thomasborax@...>
wrote:
> ernst-
> close the door.
> ok-tom
> > thanks,
> > Ernst
> > > hello-
> > > --t
> > > > Hi Dieter and group
> some
> > > > of them here:
> > > > Best Regards,
> > > > Josue.
Re: reverb sheild
Oh and I should also say that i'm using an Accutronics
Spring, and its mounted outside my case......tried
testing the module with the doepfer spring and it
still does the same thing......so I guess I should
also ask as far as the MU-METAL goes, do you wrap
the Spring Tank in it?
> --- In Doepfer_a100@yahoogroups.com, "thomasborax" <thomasborax@>
> wrote:
> > ernst-
> > close the door.
> > ok-tom
> > > thanks,
> > > Ernst
> > > > hello-
> > > > --t
> > > > > Hi Dieter and group
> > some
> > > > > of them here:
> > > > > Best Regards,
> > > > > Josue.
