Apple Logic Pro /LogicExpress Discussion group photo
Index last updated: 2026-04-28 23:06 UTC
Abut all regions on track
2008-08-03 by Gregory Anderson
I have stripped silence from 24 minutes of dialogue, leaving 7
minutes that I want to push all together into one 7-minute audio
file.  If I select in the bin and add all to one track, the regions
do what I want, but every time I make any changes, I have to delete
the regions off the track, reselect in the bin and add back onto the
track.  The "Tie Regions..." commands make them contiguous by
lengthening them.  Is there a command somewhere that makes them
contiguous by moving them?  My current method is cumbersome.
Gregory
Re: [Logic_Cafe] Abut all regions on track
2008-08-03 by Andrew Nixon
I have done this with podcasts before, and found the best method is
splitting with locators, deleting the audio you don't want then shifting it
back together - this method doesn't require reprocessing of the audio
either.
Andrew.
> Thanks,
> Gregory
2008-08-04 by GAmoore@aol.com
Once you have stripped silence, and re-arranged then make a new audio file
out of it - which can be done in various ways. By the way there are at least two
"tie" functions. I think you want to use the other one that puts all the
pieces next to each other without affecting their lengths.
Looking
for a car that's sporty, fun and fits in your budget? Read reviews on AOL Autos.
(http://autos.aol.com/cars-BMW-128-2008/expert-review?ncid=aolaut00050000000017 )
2008-08-04 by Gregory Anderson
> audio file
> at least two
> all the
Aha.  Found it.  I had looked up "Tie Regions" in the manual, and was
presented with only 2 options:
> To tie regions (removing gaps between regions):
> 	Choose Region > Tie Regions by Length Change (or use the
> corresponding key command).
> To tie selected regions between locators...
Being more of a manual reader than "trial and error" kind of guy, I
assumed that those were my only options.  So after going back to the
manual to prove Greg wrong, I on a whim looked at the menu options in
Logic and saw the one not mentioned in this section of the manual -
"Tie Regions by Position Change."  That's exactly what I wanted.
Andrew, I couldn't tell from your email what method you are using to
"shift the audio back together," but if you're not already using this
menu option, it may be the way to go for you as well.
Moral of this story?  Never read the manual
just kdding - Apple's manual is actually exceptionally well-written
and very helpful.  It's very "Apple," however, in that it is very
"biased" towards their pre-conceived notions of how we all use their
products.  This is a prime example.  "Tie Regions" by length an w/in
locators are in a section titled: Moving Regions.  Tie by Position,
however, is mentioned only once, 6 pages later, in a section titled:
Adding or Removing Song Passages.  Emagic's manual, for all its
horrible indexing, awkward phrasing, and complete omissions, always
seems to be aware of the multitude of ways Logic's functions could be
conceived and used.
Thanks for the help,
Gregory
The thing that bothers me about the "ties" is that they are strangely named.
In music, to tie notes is to extend them.   What that tie function does, is to
make a bunch of regions contigous without gaps. What Apple could do is to add
a "comment field" in the key commands to explain this, and then when someone
searched for "move" which is what this function does, then this would come as
an option. But no one would think "I need to move some regions to be
contiguous so I am going to do a search for the word tie" - well maybe now you will
make that connection but its bizarre.
There is also another useful key command to move a bunch of regions from
separate tracks all onto one track. These two together allow you to make a bunch
of cuts with the marquee tool on a raw audio, then arrange them all together on
a single track next to each other, where they can be burned to a CD or
whatever.
The other tie function - to lengthen the regions - i can't imagine what that
would be useful for.
Looking for a car that's sporty, fun and
