QTR-Quadtone RIP
Installing Problems for Epson 2880
2008-11-26 by rabanito
Hallo :-)
I have installed QuadtoneRIP for Windows (XP). Things aren't really as
described in the user's guide but at first i didn't care, everything
went automatically and was OK.
Now: It doesn't look like it is installed properly.
On PS CS2 I expected to see a printer profile starting with "Q" but
nothing has changed.
Then I tried to print something directly w the GUI. I selected a .tif
file, my printer's name (2880) and different printing models, just
because nothing happened. The task stayed in the printer's queue as
"printing" but my printer expelled all sheets without doing any printing.
I'm surely missing something, probably elementary :-(, but i cannot
find what I am doing wrong.
Could anybody give me a hand?
Thanks
Re: Installing Problems for Epson 2880
2008-11-27 by grayscale2008
1.) Your tifs 8 bit tifs?
2.) How did you name the printer in QTR gui?
CU
Peter
--- In QuadtoneRIP@yahoogroups.com, "rabanito" <rabsanito@...> wrote:
> Hallo :-)
printing.
> Thanks
2008-11-27 by rabanito
Hallo Peter
1. Yes, 8bit uncompressed
2. Actually I didn't get any chance to name the printer.  It appeared
already in the drop-down "printer name", where name and printer model
are. While installing (QTR_Setup_2.6.1.EXE) there were no other
instructions other than "close all other programs", and this I did :-)
The printer does get some command, but I understand too little of what
is happening. The sheet of paper comes out without being printed at
all and the task remains in the queue with the document as "being
printed". I have to delete it manually.
Printing for example with Photoshop, without QTR happens normally. I
mean the printer is OK.
(I got the version 2.6.1.0).
Thanks for you attention :-)
Jorge
> CU
> Peter
2008-11-28 by grayscale2008
Hi Jorge!
Mmmmh...
I am using the same version but no problem with that.
Perhaps you uninstall qtr completly and you install it again?
Perhaps that might help?
Can you print the 21step.tif that came with qtr?
CU
Peter
> Hallo Peter
> Jorge
> > CU
> > Peter
2008-11-28 by rabanito
Hallo Peter
thank you for the hints. I got something else, perhaps this could help
to understand what's happening.
First I uninstalled and installed again. I even tried a former version
but the result is the same.
NOW:
- I used 21step.tif as you proposed.
- I fed enough sheets (A4)just to see what happens.
- The first sheet got printed a horizontal line (or wedge)about 1mm
thickness
- the next 3 or 4 sheets got nothing
- The 5th sheet got gibberish like ..@A@L@@DA@D@AADD@@DD@@@....etc
Looks like QTR and my printer are not speaking the same language, but
I am a novice in these matters... I presume there is something to be
done that I missed...
Thanks again
Jorge
> Hi Jorge!
> Mmmmh...
> CU
> Peter
> --- In QuadtoneRIP@...m, "rabanito" <rabsanito@> wrote:
> > Hallo Peter
> > Jorge
> > > CU
> > > Peter
Re: [QuadtoneRIP] Re: Installing Problems for Epson 2880
2008-11-28 by mark sloane
I've got a curious issue that maybe you folks can help me with.
I'm using a CIS I bought from Joe on an Epson 1400.  I've been working through a number of issues and have them all solved except for one:  I get some type of banding the first 1/2 inch of the print.  It's odd because it goes away after the first half of an inch and then starts all over again for the next print.  If it was continuous it would almost make more sense to me but every print has the first half inch of banding.  The banding looks to me as no ink vs. the wrong ink.
Also, I have cycled through nozzel checks, head cleanings and print head alignments before each print, after each print all to no avail.
Anybody have any experience with this?  I'm lost and don't know where to go next.
Mark Sloane
925 820 4112 Home
925 997 0281 Cell
RE: [QuadtoneRIP] Re: Installing Problems for Epson 2880
2008-11-28 by Paul Roark
The 1400, as well as the 1800 and probably other 1.5 pl printers, seem to be
sensitive to paper feed issues.  They are best when both rollers are
engaged.  At a practical matter, you need wide top and bottom margins to
avoid banding.
  _____
From: QuadtoneRIP@yahoogroups.com [mailto:QuadtoneRIP@yahoogroups.com] On
Behalf Of mark sloane
Sent: Friday, November 28, 2008 10:25 AM
To: QuadtoneRIP@yahoogroups.com
Subject: Re: [QuadtoneRIP] Re: Installing Problems for Epson 2880
next.
Mark Sloane
925 820 4112 Home
925 997 0281 Cell
Paul,
Your recommendation solved the problem.   Thank you very, very much.....Mark
Mark Sloane
925 820 4112 Home
925 997 0281 Cell
--- On Fri, 11/28/08, Paul Roark <paul.roark@...> wrote:
Subject: RE: [QuadtoneRIP] Re: Installing Problems for Epson 2880
Date: Friday, November 28, 2008, 11:23 AM
avoid banding.
  _____
to go
next.
Mark Sloane
925 820 4112 Home
925 997 0281 Cell
Yahoo! Groups Links
2008-11-28 by Roy Harrington
The gibberish comes from selecting a printer model driver that is
incompatible with the
printer you are using.  I assume when you said "2880 printer name" you have
a new Epson R2880 printer.  If so, this printer is not yet supported
so you can't
have picked a matching printer driver.   However as it turns out the R2880
printer is very compatible with the R2400 printer that it replaces.  So you
might try use printer model QuadR2400.   The profiles ought to be a
bit different
since there are new inks but with the blending you make find decent results.
Roy
On Fri, Nov 28, 2008 at 12:53 AM, rabanito <rabsanito@...> wrote:
> Hallo Peter
> NOW:
> thickness
> Thanks again
> Jorge
>> Hi Jorge!
>> Mmmmh...
>> CU
>> Peter
>> --- In QuadtoneRIP@yahoogroups.com, "rabanito" <rabsanito@> wrote:
>> > Hallo Peter
>> > Jorge
>> > > CU
>> > > Peter
Yes it worked! Thank you Roy and everybody who cared :-)
I assume I'll be coming back later with other questions, but at least
I see the images printed...
Jorge
you have
> so you can't
R2880
 So you
> bit different
results.
> Roy
2008-11-28 by Stephane Bourriaux
I had the problem in september and I picked the R2400 driver As Roy
recommend it. It works fine but I have a problem of microbanding on the
top and bottom (about one inch) of my prints with the UCMk3 inks. I hope
that the new driver set for the R2880 could solve that .
Stephane
Roy Harrington a \ufffdcrit :
> so you can't
> bit different
> results.
> Roy
> <mailto:rabsanito%40yahoo.com>> wrote:
> > Hallo Peter
> > NOW:
> > thickness
> > Thanks again
> > Jorge
> <mailto:QuadtoneRIP%40yahoogroups.com>, "grayscale2008" <pm2003@...>
> wrote:
> >> Hi Jorge!
> >> Mmmmh...
> >> CU
> >> Peter
> <mailto:QuadtoneRIP%40yahoogroups.com>, "rabanito" <rabsanito@> wrote:
> >> > Hallo Peter
> did :-)
> what
> >> > Jorge
> >> > > CU
> >> > > Peter
> > Yahoo! Groups Links
2008-11-28 by Tom Moore
Jorge
It sounds like you are not using the correct Printer Model. My version of
QTRgui does not have a model for the R2880. If Peter had not said that the
printer is working for him (presumably with QTR) I would have guessed that
QTR doesn't support this model yet.
Since Peter says that it is working for him, make sure you are using the
same printer model he is. The Printer Model tells QTR what low level command
set to use for the printer.
Tom Moore
> Behalf Of rabanito
> NOW:
> thickness
> Thanks again
> Jorge
2008-11-30 by grayscale2008
Hi Tom!
Ahhhh, sometimes the solution is so near...
I didn´t read quite wll the title of the thread. And of course if
somthings comes out like '#+´??888' it must be something with the
printer driver...
Next time I will read the content with a little bit more attention!
CU
Peter
--- In QuadtoneRIP@yahoogroups.com, "Tom Moore" <rtmlists8888@...> wrote:
> Jorge
version of
that the
guessed that
command
> Tom Moore
> > Behalf Of rabanito
> > NOW:
> > thickness
> > Thanks again
> > Jorge
