Emax
Strange Symptoms
Strange Symptoms
2007-04-23 by cheju_99
Hi i´m new in the emax stuff..recently I bought an Emax, serial 1000,
PCb rev 2, Disk Drive working OK. The Symtoms: I push the ON Button,
then it started going up, everything looks goes great "Loading
Operating System" etc Etc...then Loading Bank, and finally showing the
patch on the screen, I began to play a note...a sound....great...then
another sound....great!!!! then suddenly the notes hangs up, and the
system crash, no other button pushed works.....finally nothing works
except the OFF Button. Someone with the same problem???, any idea about
this cause???
Thanks in advance.
Richard
Re: [emax] Strange Symptoms
2007-04-23 by Brooks Mosher
maybe a power supply issue?
actually i have no idea what it could be...  i'm sort of a newbie here.
> this cause???
> Thanks in advance.
> Richard
Re: Strange Symptoms
2007-04-23 by Chip
what is your OS version right now?, do you have HD installed? do you
tried different banks?
about
> this cause???
> Thanks in advance.
> Richard
Re: [emax] Re: Strange Symptoms
2007-04-23 by Mike Wolak
is it possible you have a midi loop? Do you have both
midi in and out connected to another device? If so,
disconnect and see if this problem still occurs.
> installed? do you
> > Hi i\ufffdm new in the emax stuff..recently I bought an
> Emax, serial 1000,
> push the ON Button,
> great "Loading
> finally showing
> the
> hangs up, and the
> about
> > this cause???
> > Thanks in advance.
> > Richard
No... Midi is not present no physical cables also, ´cos i just wanna
turn the emax on....
Thanks for your interest
Richard
> > installed? do you
> > Emax, serial 1000,
> > push the ON Button,
> > great "Loading
> > finally showing
> > the
> > hangs up, and the
> > about
> > > this cause???
> > > Thanks in advance.
> > > Richard
HI!: I have no HD, no idea about my OS, the guy who sold me the
device, just give me a diskette labelled "Frech Horns and sequences"
I tried to format the DIsk with a new OS but i failed. Tonight i will
try to write another one. Otherwise I will disassembly the unit and
sell the pieces....
PD: sorry about my poor english......
Richard
you
1000,
Button,
showing
> the
works
> about
> > this cause???
> > Thanks in advance.
> > Richard
2007-04-23 by Chip
what language do you speak?
don't sell it, it could be a minor bug... try to copy the lastest os
for non hd models with EMXP program.
there is more than 50 banks to download on the web!!!
where are you from?
sequences"
will
> sell the pieces....
> Richard
> you
> 1000,
> Button,
> showing
> > the
and
> the
> works
idea
> > about
> > > this cause???
> > > Thanks in advance.
> > > Richard
2007-04-23 by RICARDO JUAREZ
I speak spanish I am from Chile, i\ufffdll try to load the
latest OS.
Thanks for your help
> copy the lastest os
> web!!!
> where are you from?
> who sold me the
> Horns and
> sequences"
> failed. Tonight i
> will
> > sell the pieces....
> > Richard
> HD installed? do
> > you
> > 1000,
> I push the ON
> > Button,
> goes great "Loading
> and finally
> > showing
> > > the
> note...a
> notes hangs up,
> and
> > the
> > works
> problem???, any
> idea
> > > about
> > > > this cause???
> > > > Thanks in advance.
> > > > Richard
> http://www.silveriafamily.com
Do You Yahoo!?
http://mail.yahoo.com
2007-04-23 by Aquiles Bianchi Salazar
ahh bueno, que tal? soy aquiles de argentina
asi nos entendemos mejor!!!
lo que te decia, es que te bajes el EMXP, y el ultimo OS, formatees un
diskette (preferiblemente nuevo si es HD) y le copies el OS y algun banco,
(ej: zd701 arcostrings) si no sabes como conseguir algo de todo esto te paso
los links
en que parte de chile estas?
yo voy para valparaiso el mes que viene
saludos
aquiles
>From: RICARDO JUAREZ <cheju_99@...>
>Reply-To: emax@yahoogroups.com
>Subject: Re: [emax] Re: Strange Symptoms
>Date: Mon, 23 Apr 2007 13:31:08 -0700 (PDT)
>latest OS.
> > copy the lastest os
> > web!!!
> > where are you from?
> > who sold me the
> > Horns and
> > sequences"
> > failed. Tonight i
> > will
> > > sell the pieces....
> > > Richard
> > HD installed? do
> > > you
> > > 1000,
> > I push the ON
> > > Button,
> > goes great "Loading
> > and finally
> > > showing
> > > > the
> > note...a
> > notes hangs up,
> > and
> > > the
> > > works
> > problem???, any
> > idea
> > > > about
> > > > > this cause???
> > > > > Thanks in advance.
> > > > > Richard
> > Yahoo! Groups Links
>Do You Yahoo!?
>Yahoo! Groups Links
Exercise your brain! Try Flexicon.
http://games.msn.com/en/flexicon/default.htm?icid=flexicon_hmemailtaglineapril07
Re: More Strange Symptoms
2007-04-24 by cheju_99
Hi!:
Finally i can make an bootable image of the OS, but here´s new
symptoms: the diskette is read but at some point, the drive stops
the leds lights of the panel turns on, and then turns off, and again
and again...in a continuous loop. What´s happening maybe the diskette
is wrong, i dont think so, because the old dikette is loaded.
greetings
 Rick
here.
1000,
Button,
showing the
works
about
> > this cause???
> > Thanks in advance.
> > Richard
Re: [emax] Re: More Strange Symptoms
2007-04-24 by Wayne Griffin
You need to have a known good OS disk and known good
EPROM. If you know anyone with a reader, it's time to
pop yours out and verify it. Have you looked at power
supply yet? [w]
--- cheju_99 <cheju_99@...> wrote:
> Hi!:
> here\ufffds new
> the drive stops
> and again...in a continuous loop. What\ufffds happening
> maybe the diskette
> is loaded.
> greetings
>  Rick
> sort of a newbie
> here.
> 1000,
> push the ON
> Button,
> great "Loading
> and finally
> showing the
> notes hangs up, and
> the
> works
> about
> > > this cause???
> > > Thanks in advance.
> > > Richard
> removed]
Do You Yahoo!?
2007-04-24 by Brooks Mosher
Wayne,
Is it normal for the power supply to get quite warm while the Emax is left
on for at least 30 minutes?
Mine does, and I hope that's a normal thing...
> supply yet? [w]
> --- cheju_99 <cheju_99@... <cheju_99%40yahoo.com>> wrote:
> > Hi!:
> > here´s new
> > the drive stops
> > maybe the diskette
> > is loaded.
> > greetings
> > Rick
> > --- In emax@yahoogroups.com <emax%40yahoogroups.com>, "Brooks Mosher"
> > sort of a newbie
> > here.
> > 1000,
> > push the ON
> > Button,
> > great "Loading
> > and finally
> > showing the
> > notes hangs up, and
> > the
> > works
> > about
> > > > this cause???
> > > > Thanks in advance.
> > > > Richard
> > removed]
> Do You Yahoo!?
2007-04-24 by RICARDO JUAREZ
Yep! the problem is i don\ufffdt have any schematics nor
part model for the eprom, even if it\ufffds broken how can
i Reload the data, (i dont know anything about
Eproms)... my last hope of failure is the power
supply..., otherwise my emax is just a piece of
garbage to be sell by pieces..
a dissapointed...
ricki
> to
> power
> supply yet? [w]
> > Hi!:
> but
> > here\ufffds new
> > the drive stops
> > maybe the diskette
> > is loaded.
> > greetings
> >  Rick
> > sort of a newbie
> > here.
> > 1000,
> I
> > push the ON
> > Button,
> goes
> > great "Loading
> > and finally
> > showing the
> note...a
> > notes hangs up, and
> > the
> > works
> > about
> > > > this cause???
> > > > Thanks in advance.
> > > > Richard
> > removed]
> Do You Yahoo!?
> protection around
Do You Yahoo!?
cheju_99's Rev 2 (reseat your logic)
This sounds like it could also be heat related.
Emaxen are 20 years old now.
If you know your soft/firmware are okay and your 5V is
somewhat in spec then...
CAREFULLY reseat every chip and every connection on
your motherboard. This includes the big, fat one. This
will take time. Control static electricity as much as
possible, you absolutely don't want to pop your E-Chip
or any of the custom PAL's.
Practice this on something that you don't care about
to get the hang of the way it feels when you slide the
small flatblade screwdriver underneath and patiently
pry them up. Think old 386 motherboards...
It isn't even necessary to completely remove the chips
from the sockets. Just merely move them around some.
Take a sharpie marker and mark the orientation of any
connectors you may remove. In fact, I reseat every
connection on everything that comes through here when
I get something. You are breaking up little oxidations
and the like between the metals.
This is very common on E-mu gear- EIII, EII, SP-12,
SP1200...
[w]
Do You Yahoo!?
Re: cheju_99's Rev 2 (reseat your logic)
2007-04-24 by Chip
sorry about my intromission (and my poor english), but... what does
it mean reseat ?
what you say is to remove chips and put them back again?
how can you be carefully about the static?
I'm not a technician, but sometimes i do  that, and i'm not carefull
at all.
One time, a friend has an E-mu Vintage Keys module, and the unit
stops sounding and differents errors were displayed, so i started to
make shortcircuits in the pin 1 2 and 3, and voila... the problem was
resolved.
was that a static electricity problem?
> SP1200...
> [w]
> Do You Yahoo!?
Re: [emax] Re: cheju_99's Rev 2 (reseat your logic)
try google for answers about ESD and precautions [w]
> but... what does
> it mean reseat ?
> again?
> i'm not carefull
> at all.
> and the unit
> so i started to
> resolved.
> 5V is
> on
> This
> as
> E-Chip
> about
> the
> patiently
> chips
> some.
> any
> when
> oxidations
> SP-12,
> > SP1200...
> > [w]
> > Do You Yahoo!?
> protection around
Do You Yahoo!?
Re: [emax] cheju_99's Rev 2 (reseat your logic)
Ok, Wayne great!, looks fine:
I hope that the power supply will be the cause!!!!,
otherwise i\ufffdll try as you said with the IC\ufffds (the
reseat will be with the power supply ON ? i dont think
so......) , but before I will became rehearsing in an
acient mother board...i need a bit of luck.
Thanks for you unvaluable help,....I except to send
you good news!!!!....
Bye
Rick
> is
> This
> as
> E-Chip
> the
> chips
> any
> when
> oxidations
> SP1200...
> [w]
> Do You Yahoo!?
> protection around
Do You Yahoo!?
2007-04-25 by ted Summers
This is common in any device that has chips and is that old..... try
working on old pinballs / slot machines / videogames sometime ! :-)
I do not recommend shorting pins together.....
So, after removing power from emax,
1) Attach anti-static wrist strap
2) put down anti-static material (packages that computer motherboards
come in have a silvery plastic bag, use this if available)
3)  remove the boards from emax (mark all connectors where they go)
4) Gently pry up chips a little bit on both ends with flat
screwdriver (like Wayne said-  you do not have to completely remove
the chip from the board)
5) Press Chips back down
6) put boards back in emax
TEST!!
Good Luck!
Ted
> otherwise i´ll try as you said with the IC´s (the
> Bye
> Rick
> > is
> > This
> > as
> > E-Chip
> > the
> > chips
> > any
> > when
> > oxidations
> > SP1200...
> > [w]
> > Do You Yahoo!?
> > protection around
> > Yahoo! Groups Links
> Do You Yahoo!?
2007-04-25 by RICARDO JUAREZ
Thanks for you support Ted!!, check my report:
Wayne:
Could you be more specific about the testing of the 5V
digital power ?, because last night i worked on the
machine, I check de purple, orange, etcetera.... +12`s
Volts +10\ufffds ,s volts , the yellow wire marks +4,92
volts,....... but i cannot locate the pin 3 of VR1 and
check +5Volts, there\ufffds a green wire with no power. I
made also some reseating...no success, I found 3 ICs
near the Eprom heated, so i suspect there`s something
wrong in that zone. Is some other thing to do?????
greetings
Ricardo
> that old..... try
> sometime ! :-)
> available)
> where they go)
> with flat
> completely remove
> TEST!!
> Good Luck!
> Ted
> cause!!!!,
> think
> an
> send
> > Bye
> > Rick
> 5V
> > > is
> on
> one.
> > > This
> much
> > > as
> > > E-Chip
> about
> slide
> > > the
> patiently
> > > chips
> some.
> of
> > > any
> every
> > > when
> > > oxidations
> SP-12,
> > > SP1200...
> > > [w]
> > > Do You Yahoo!?
> > > protection around
> > > Yahoo! Groups Links
> > Do You Yahoo!?
> protection around
> removed]
Do You Yahoo!?
2007-04-26 by RICARDO JUAREZ
Hi!:
Here´s what a found: IC 14(NS32008) gets very hot, IC
14 , 9 and IC 17 gets hot, also when you play the
keyboard there´s is sound, not in scale, additionally
as you play, the menu´s system changes going from
everything to everything (master---traspose---change
patches---select, etc)even performs a sequence on the
diskette and blocks the keyboard....tottally a mess.
When you push a button in the panel the system crash
and no sound and changes, hanging the last
note.....despite all this stuff, the patches sounds
very good. Really there´s some processor not doing
well its job, i don´t think i can find one of these
IC´s nowadays, is there any method for reseting this
devices.
Saludos
ricardo
> What are the IC #'s on the chips? What do the chips
> say on them??? Did you also reseat *everything*,
> todos
> on the second board, attached to the motherboard?
> [w]
> --- RICARDO JUAREZ <cheju_99@...> wrote:
> > Wayne:
> > Could you be more specific about the test of the
> 5V
> the
> > machine, I check de purple, orange wire,
> > etcetera....
> > +12`s Volts +10´s ,s volts , the yellow wire marks
> > +4,92 volts,....... but i cannot locate the pin 3
> of
> > VR1 and check +5Volts, there´s a green wire with
> no
> > power. I made also some reseating...no success, I
> > found 3 IC`s near the Eprom heated but still you
> can
> > touch it with your finger not so hot..., so i
> > suspect
> > there`s something wrong in that zone. Is some
> other
> > thing to do?????
> > greetings
> > Ricardo
> > > Where are you located? [w]
> > > > Yep! the problem is i don´t have any
> schematics
> > > nor
> > > > part model for the eprom, even if it´s broken
> > how
> > > > can
> power
> of
> > > > a dissapointed...
> > > > ricki
> > known
> > > > good
> it's
> > > time
> > > > > to
> > at
> > > > > power
> > > > > supply yet? [w]
> > > > > > Hi!:
> the
> > > OS,
> > > > > but
> > > > > > here´s new
> > > > point,
> > > > > > the drive stops
> > > then
> > > > happening
> > > > > > maybe the diskette
> > > > dikette
> > > > > > is loaded.
> > > > > > greetings
> > > > > >  Rick
> Mosher"
> > be...
> > > > i'm
> > > > > > sort of a newbie
> > > > > > here.
> stuff..recently
> > I
> > > > > > 1000,
> > > > Symtoms:
> > > > > I
> > > > > > push the ON
> > > > > > Button,
> > looks
> > > > > goes
> > > > > > great "Loading
> Loading
> > > > Bank,
> > > > > > and finally
> > > > > > showing the
> > > > > note...a
> suddenly
> > > the
> > > > > > notes hangs up, and
> > > > > > the
> > > > > > works
> the
> > > same
> > > > > > about
> > > > > > > > this cause???
> > > > > > > > Thanks in advance.
> > > > > > > > Richard
> > been
> > > > > > removed]
> > > > > Do You Yahoo!?
> spam
> > > > > protection around
> > > > > Yahoo! Groups Links
> > > > Do You Yahoo!?
> > > > protection around
> > > Do You Yahoo!?
> > > protection around
=== message truncated ===
Do You Yahoo!?
SV: Re: [emax] Re: More Strange Symptoms
2007-04-26 by Brian Ronn
Hi
  Yes, it is normal that the PSU on the Emax gets quite warm.
  Best regards
  Brian
Brooks Mosher <brooksmosher@...> skrev:
          Wayne,
> supply yet? [w]
> > Hi!:
> > here´s new
> > the drive stops
> > maybe the diskette
> > is loaded.
> > greetings
> > Rick
> > sort of a newbie
> > here.
> > 1000,
> > push the ON
> > Button,
> > great "Loading
> > and finally
> > showing the
> > notes hangs up, and
> > the
> > works
> > about
> > > > this cause???
> > > > Thanks in advance.
> > > > Richard
> > removed]
> Do You Yahoo!?
Alt i én. Få Yahoo! Mail med adressekartotek, kalender og notesblok.
2007-04-27 by ted Summers
That IC is still available (just google it- someone will sell you a
single one- may have to do a bit of email to get it) and one bad IC
can cause others ICs to heat up as well....
But I would still verify the Power Supply first.....
Thx,
Ted
On Apr 26, 2007, at 6:28 AM, RICARDO JUAREZ wrote:
> Hi!:
> devices.
> Saludos
> ricardo
> > todos
> > [w]
> > > Wayne:
> > 5V
> > the
> > > etcetera....
> > of
> > no
> > can
> > > suspect
> > other
> > > thing to do?????
> > > greetings
> > > Ricardo
> > schematics
> > > > nor
> > > how
> > > > > can
> > power
> > of
> > > > > a dissapointed...
> > > > > ricki
> > > known
> > > > > good
> > it's
> > > > time
> > > > > > to
> > > at
> > > > > > power
> > > > > > supply yet? [w]
> > > > > > > Hi!:
> > the
> > > > OS,
> > > > > > but
> > > > > > > here´s new
> > > > > point,
> > > > > > > the drive stops
> > > > then
> > > > > happening
> > > > > > > maybe the diskette
> > > > > dikette
> > > > > > > is loaded.
> > > > > > > greetings
> > > > > > > Rick
> > Mosher"
> > > be...
> > > > > i'm
> > > > > > > sort of a newbie
> > > > > > > here.
> > stuff..recently
> > > I
> > > > > > > 1000,
> > > > > Symtoms:
> > > > > > I
> > > > > > > push the ON
> > > > > > > Button,
> > > looks
> > > > > > goes
> > > > > > > great "Loading
> > Loading
> > > > > Bank,
> > > > > > > and finally
> > > > > > > showing the
> > > > > > note...a
> > suddenly
> > > > the
> > > > > > > notes hangs up, and
> > > > > > > the
> > > > > > > works
> > the
> > > > same
> > > > > > > about
> > > > > > > > > this cause???
> > > > > > > > > Thanks in advance.
> > > > > > > > > Richard
> > > been
> > > > > > > removed]
> > > > > > Do You Yahoo!?
> > spam
> > > > > > protection around
> > > > > > Yahoo! Groups Links
> > > > > Do You Yahoo!?
> > > > > protection around
> > > > Do You Yahoo!?
> > > > protection around
> Do You Yahoo!?
2007-04-27 by RICARDO JUAREZ
Yep!,I still need a method for verify the 5v of the
digital, Why we need to measure VR1?????, and how you
do that????
M\ufffds Saludos
Ricardo
> will sell you a
> and one bad IC
> Thx,
> Ted
> > Hi!:
> > Here\ufffds what a found: IC 14(NS32008) gets very hot,
> IC
> > keyboard there\ufffds is sound, not in scale,
> additionally
> > as you play, the menu\ufffds system changes going from
> the
> mess.
> crash
> sounds
> > very good. Really there\ufffds some processor not doing
> > well its job, i don\ufffdt think i can find one of
> these
> > IC\ufffds nowadays, is there any method for reseting
> this
> > devices.
> > Saludos
> > ricardo
> chips
> > > todos
> motherboard?
> > > [w]
> > > > Wayne:
> the
> > > 5V
> on
> > > the
> > > > etcetera....
> > > > +12`s Volts +10\ufffds ,s volts , the yellow wire
> marks
> pin 3
> > > of
> > > > VR1 and check +5Volts, there\ufffds a green wire
> with
> > > no
> success, I
> you
> > > can
> > > > suspect
> > > other
> > > > thing to do?????
> > > > greetings
> > > > Ricardo
> > > schematics
> > > > > nor
> broken
> > > > how
> > > > > > can
> about
> > > power
> piece
> > > of
> > > > > > a dissapointed...
> > > > > > ricki
> and
> > > > known
> > > > > > good
> > > it's
> > > > > time
> > > > > > > to
> looked
> > > > at
> > > > > > > power
> > > > > > > supply yet? [w]
> > > > > > > > Hi!:
> of
> > > the
> > > > > OS,
> > > > > > > but
> > > > > > > > here\ufffds new
> some
> > > > > > point,
> > > > > > > > the drive stops
> and
> > > > > then
> What\ufffds
> > > > > > happening
> > > > > > > > maybe the diskette
> old
> > > > > > dikette
> > > > > > > > is loaded.
> > > > > > > > greetings
> > > > > > > > Rick
> > > Mosher"
> could
> > > > be...
> > > > > > i'm
> > > > > > > > sort of a newbie
> > > > > > > > here.
> > > stuff..recently
> > > > I
> > > > > > > > 1000,
> The
> > > > > > Symtoms:
> > > > > > > I
> > > > > > > > push the ON
> > > > > > > > Button,
> everything
> > > > looks
> > > > > > > goes
> > > > > > > > great "Loading
> > > Loading
> > > > > > Bank,
> > > > > > > > and finally
> > > > > > > > showing the
> play a
> > > > > > > note...a
Do You Yahoo!?
Well, my opinion is that there is an issue with the power supply.
The 4.92 volt is SUPPOSED to be at 5V. A little variance is ok, and
higher (5.05V) especially in an older unit would feed better as it
went across the board. 4.92 is a bit low. Most chips like 4.95 at
least. And remember the farther you measure across a board, the more
the volts will drop lower. In fact, if you knew the correct pin to
test for on the farthest chip physically across the board from the
power supply, and measure the volt reading on the 5 volt pin, it
wouldn't surprise me if it is actually much lower than the 4.92. This
can cause very strange behaviour in logic systems.
It is possible to attach a PC power supply and test, without making
it "permanent". Not an ATX, but an older AT style power supply.... I
would have to see schematics, but am not sure why there would be a 10
volt, it seems that should be twelve. If the power supply is putting
out 10v on a 12v line, then that would be another issue.
Be aware that power supplies have what are called 'rails'. Each rail
is a separate voltage. So the power supply may have:
1 x 5 Volt rail
2 x  12 volt rail
for an example. One 12Volt rail could be ok, and the other bad, then
the bad side can pull down the power on the good one.
  I looked at the power supply in my emax when I first got it. They
used diodes to "crowbar" the voltage regulation circuit. Not an
uncommon practice back then, but not done often now (there are better
ways to do this). What I did on my power supply when I first got the
emax was remove it, and resoldered all the connections to the parts
on the power supply. There were a couple of "cold solders" which are
solders that have small cracks in them (sometimes require a
magnifying glass to see them). They will arc and connect part of the
time, then lose connection momentarily at which point the circuit is
broken and no longer works properly. This could cause the lower power
output as well as the strange behaviour. You can resolder all the
parts on the power supply, then if that doesn't seem to help, get the
PC power supply and hook in place of the original supply to do a test...
Just a couple of thoughts.
But what do I know. Having worked as a repair tech for 17 years on
electronic equipment.... I don't know anything ;-)
Ted
> do that????
> Más Saludos
> Ricardo
> > will sell you a
> > and one bad IC
> > Thx,
> > Ted
> > > Hi!:
> > IC
> > additionally
> > the
> > mess.
> > crash
> > sounds
> > these
> > this
> > > devices.
> > > Saludos
> > > ricardo
> > chips
> > > > todos
> > motherboard?
> > > > [w]
> > > > > Wayne:
> > the
> > > > 5V
> > on
> > > > the
> > > > > etcetera....
> > marks
> > pin 3
> > > > of
> > with
> > > > no
> > success, I
> > you
> > > > can
> > > > > suspect
> > > > other
> > > > > thing to do?????
> > > > > greetings
> > > > > Ricardo
> > > > schematics
> > > > > > nor
> > broken
> > > > > how
> > > > > > > can
> > about
> > > > power
> > piece
> > > > of
> > > > > > > a dissapointed...
> > > > > > > ricki
> > and
> > > > > known
> > > > > > > good
> > > > it's
> > > > > > time
> > > > > > > > to
> > looked
> > > > > at
> > > > > > > > power
> > > > > > > > supply yet? [w]
> > > > > > > > --- cheju_99 <cheju_99@yahoo.com> wrote:
> > > > > > > > > Hi!:
> > of
> > > > the
> > > > > > OS,
> > > > > > > > but
> > > > > > > > > here´s new
> > some
> > > > > > > point,
> > > > > > > > > the drive stops
> > and
> > > > > > then
> > What´s
> > > > > > > happening
> > > > > > > > > maybe the diskette
> > old
> > > > > > > dikette
> > > > > > > > > is loaded.
> > > > > > > > > greetings
> > > > > > > > > Rick
> > > > Mosher"
> > could
> > > > > be...
> > > > > > > i'm
> > > > > > > > > sort of a newbie
> > > > > > > > > here.
> > > > stuff..recently
> > > > > I
> > > > > > > > > 1000,
> > The
> > > > > > > Symtoms:
> > > > > > > > I
> > > > > > > > > push the ON
> > > > > > > > > Button,
> > everything
> > > > > looks
> > > > > > > > goes
> > > > > > > > > great "Loading
> > > > Loading
> > > > > > > Bank,
> > > > > > > > > and finally
> > > > > > > > > showing the
> > play a
> > > > > > > > note...a
> Do You Yahoo!?
Emax power supply
2007-04-27 by Wayne Griffin
I agree about the 5.05V and the idea of a voltage drop
across the digital board.
orange = +12V
yellow = +5V (5.05V)
purple = -12V
The +10V on pin 3 of Q2 is also fine because that's
either to drive the DC/DC converter for the LCD
backlight or maybe something pertaining to the EPROM.
[w]
> power supply.
> variance is ok, and
> feed better as it
> like 4.95 at
> board, the more
> correct pin to
> board from the
> volt pin, it
> than the 4.92. This
> without making
> power supply.... I
> there would be a 10
> supply is putting
> issue.
> 'rails'. Each rail
> 1 x 5 Volt rail
> 2 x  12 volt rail
> other bad, then
> one.
> first got it. They
> circuit. Not an
> (there are better
> I first got the
> solders" which are
> require a
> connect part of the
> resolder all the
> to help, get the
> for 17 years on
> Thanks,
> Ted
> the
> you
> > do that????
> > M\ufffds Saludos
> > Ricardo
> someone
> > > will sell you a
> it)
> > > and one bad IC
> first.....
> > > Thx,
> > > Ted
> wrote:
> > > > Hi!:
> hot,
> > > IC
> the
> > > additionally
> from
> on
> > > the
> > > mess.
> > > crash
> > > sounds
> doing
> > > these
> reseting
> > > this
> > > > devices.
> > > > Saludos
> > > > ricardo
> the
> > > chips
> *everything*,
> > > > > todos
> > > motherboard?
> > > > > [w]
> wrote:
> > > > > > Wayne:
> of
> > > the
> > > > > 5V
> worked
> > > on
> > > > > the
> > > > > > etcetera....
> wire
> > > marks
> the
> > > pin 3
> > > > > of
> wire
> > > with
> > > > > no
> > > success, I
> still
> > > you
> > > > > can
> so i
> > > > > > suspect
> some
> > > > > other
> > > > > > thing to do?????
> > > > > > greetings
> > > > > > Ricardo
Do You Yahoo!?
Re: [emax] Emax power supply
I suppose i could check the entire board this weekend,
that includes the keyboard, the buttons command,
according to my multimeter the voltage is doing well,
but as you said, is esential recheck the entire AC/DC
System, i hope to resolve this thing soon....
salu2
Ricardo
> drop
> orange = +12V
> purple = -12V
> EPROM.
> [w]
> the
> > power supply.
> > variance is ok, and
> > feed better as it
> chips
> > like 4.95 at
> a
> > board, the more
> the
> > correct pin to
> the
> > board from the
> 5
> > volt pin, it
> > than the 4.92. This
> test,
> > without making
> > power supply.... I
> > there would be a 10
> > supply is putting
> > issue.
> > 'rails'. Each rail
> have:
> > 1 x 5 Volt rail
> > 2 x  12 volt rail
> the
> > other bad, then
> > one.
> > first got it. They
> > circuit. Not an
> now
> > (there are better
> when
> > I first got the
> > solders" which are
> > require a
> > connect part of the
> > resolder all the
> seem
> > to help, get the
> > for 17 years on
> > Thanks,
> > Ted
> > the
> how
> > you
> > > do that????
> > > M\ufffds Saludos
> > > Ricardo
> > someone
> > > > will sell you a
> get
> > it)
> > > > and one bad IC
> > first.....
> > > > Thx,
> > > > Ted
> > wrote:
> > > > > Hi!:
> very
> > hot,
> > > > IC
> play
> > the
> > > > additionally
> > from
> sequence
> > on
> > > > the
> a
> > > > mess.
> system
> > > > crash
> > > > sounds
> > doing
> of
> > > > these
> > reseting
> > > > this
> > > > > devices.
> > > > > Saludos
> > > > > ricardo
> > the
> > > > chips
> > *everything*,
> > > > > > todos
> > > > motherboard?
> > > > > > [w]
> > wrote:
> > > > > > > Wayne:
> test
> > of
Do You Yahoo!?
2007-04-29 by RICARDO JUAREZ
Well...
I clean all the unit,everything was removed, and found
nothing special, nothing but a few problems with some
"Light leds" in the push buttons, there was one with a
"cold soldering", and some contacts with several
wearing, I repair it with some glue and new metalics
contacts, ONe Question: There\ufffds a pair of "sort of
jacks" (white and light-Blue) in the back of the
keyboard plaque, in one side and the other side, is
there any cable attached to they??? because my unit
has no one........I will check the soldering in the
PSU...
Saludos
Ricardo
> drop
> orange = +12V
> purple = -12V
> EPROM.
> [w]
> the
> > power supply.
> > variance is ok, and
> > feed better as it
> chips
> > like 4.95 at
> a
> > board, the more
> the
> > correct pin to
> the
> > board from the
> 5
> > volt pin, it
> > than the 4.92. This
> test,
> > without making
> > power supply.... I
> > there would be a 10
> > supply is putting
> > issue.
> > 'rails'. Each rail
> have:
> > 1 x 5 Volt rail
> > 2 x  12 volt rail
> the
> > other bad, then
> > one.
> > first got it. They
> > circuit. Not an
> now
> > (there are better
> when
> > I first got the
> > solders" which are
> > require a
> > connect part of the
> > resolder all the
> seem
> > to help, get the
> > for 17 years on
> > Thanks,
> > Ted
> > the
> how
> > you
> > > do that????
> > > M\ufffds Saludos
> > > Ricardo
> > someone
> > > > will sell you a
> get
> > it)
> > > > and one bad IC
> > first.....
> > > > Thx,
> > > > Ted
> > wrote:
> > > > > Hi!:
> very
> > hot,
> > > > IC
> play
> > the
> > > > additionally
> > from
> sequence
> > on
> > > > the
> a
> > > > mess.
> system
> > > > crash
> > > > sounds
> > doing
> of
> > > > these
> > reseting
> > > > this
> > > > > devices.
> > > > > Saludos
> > > > > ricardo
> > the
> > > > chips
> > *everything*,
> > > > > > todos
> > > > motherboard?
> > > > > > [w]
> > wrote:
> > > > > > > Wayne:
> test
> > of
Do You Yahoo!?
2007-04-29 by ted Summers
I need more description (do the connectors have labels next to them
like CN14 or J1), to tell you what the connectors are for. Picture
Files do not show on the group email, but you could post them to the
files and then we could see what you are talking about, also.
Ted
On Apr 29, 2007, at 1:18 AM, RICARDO JUAREZ wrote:
> Well...
> contacts, ONe Question: There´s a pair of "sort of
> PSU...
> Saludos
> Ricardo
> > drop
> > orange = +12V
> > purple = -12V
> > EPROM.
> > [w]
> > the
> > > power supply.
> > > variance is ok, and
> > > feed better as it
> > chips
> > > like 4.95 at
> > a
> > > board, the more
> > the
> > > correct pin to
> > the
> > > board from the
> > 5
> > > volt pin, it
> > > than the 4.92. This
> > test,
> > > without making
> > > power supply.... I
> > > there would be a 10
> > > supply is putting
> > > issue.
> > > 'rails'. Each rail
> > have:
> > > 1 x 5 Volt rail
> > > 2 x 12 volt rail
> > the
> > > other bad, then
> > > one.
> > > first got it. They
> > > circuit. Not an
> > now
> > > (there are better
> > when
> > > I first got the
> > > solders" which are
> > > require a
> > > connect part of the
> > > resolder all the
> > seem
> > > to help, get the
> > > for 17 years on
> > > Thanks,
> > > Ted
> > > the
> > how
> > > you
> > > > do that????
> > > > Más Saludos
> > > > Ricardo
> > > someone
> > > > > will sell you a
> > get
> > > it)
> > > > > and one bad IC
> > > first.....
> > > > > Thx,
> > > > > Ted
> > > wrote:
> > > > > > Hi!:
> > very
> > > hot,
> > > > > IC
> > play
> > > the
> > > > > additionally
> > > from
> > sequence
> > > on
> > > > > the
> > a
> > > > > mess.
> > system
> > > > > crash
> > > > > sounds
> > > doing
> > of
> > > > > these
> > > reseting
> > > > > this
> > > > > > devices.
> > > > > > Saludos
> > > > > > ricardo
> > > the
> > > > > chips
> > > *everything*,
> > > > > > > todos
> > > > > motherboard?
> > > > > > > [w]
> > > wrote:
> > > > > > > > Wayne:
> > test
> > > of
> Do You Yahoo!?
OS 2.14 for EMAX II
2007-04-29 by Tomas Komorowski
Hallo,
Can you sand me somebody OS 2.14 for My EMAX II, please?
Thanks a lot
Tomas-Prague, Czech Republic
Re: [emax] OS 2.14 for EMAX II
2007-04-29 by mishon66@...
You can pucrahse them from www.Route66studios.com
Sent: Sun, 29 Apr 2007 2:34 PM
Subject: [emax] OS 2.14 for EMAX II
Hallo,
Thanks a lot
________________________________________________________________________
AOL now offers free email to everyone.  Find out more about what's free from AOL at AOL.com.
2007-04-30 by RICARDO JUAREZ
Ok, i\ufffdll put it soon,
thanks
saludos
> labels next to them
> are for. Picture
> post them to the
> about, also.
> Thanks,
> Ted
> > Well...
> found
> some
> with a
> metalics
> is
> unit
> the
> > PSU...
> > Saludos
> > Ricardo
> voltage
> > > drop
> > > orange = +12V
> > > purple = -12V
> that's
> > > EPROM.
> > > [w]
> with
> > > the
> > > > power supply.
> little
> > > > variance is ok, and
> would
> > > > feed better as it
> > > chips
> > > > like 4.95 at
> across
> > > a
> > > > board, the more
> knew
> > > the
> > > > correct pin to
> across
> > > the
> > > > board from the
> the
> > > 5
> > > > volt pin, it
> lower
> > > > than the 4.92. This
> systems.
> > > test,
> > > > without making
> style
> > > > power supply.... I
> why
> > > > there would be a 10
> power
> > > > supply is putting
> another
> > > > issue.
> called
> > > > 'rails'. Each rail
> > > have:
> > > > 1 x 5 Volt rail
> > > > 2 x 12 volt rail
> and
> > > the
> > > > other bad, then
> good
> > > > one.
> > > > first got it. They
> regulation
> > > > circuit. Not an
> often
> > > now
> > > > (there are better
> supply
> > > when
> > > > I first got the
> "cold
> > > > solders" which are
> (sometimes
> > > > require a
> and
> > > > connect part of the
> which
> could
> can
> > > > resolder all the
> doesn't
> > > seem
> > > > to help, get the
> original
> tech
> > > > for 17 years on
> > > > Thanks,
> > > > Ted
> of
> > > > the
> and
> > > how
> > > > you
> > > > > do that????
> > > > > M\ufffds Saludos
> > > > > Ricardo
> it-
> > > > someone
> > > > > > will sell you a
> to
Do You Yahoo!?
Re: Emax power supply
2007-04-30 by cheju_99
Hi Ted:
Unfortunatelly there´s no photo of the conectors , but as you said
there´s no label on the board, i expect to put some new photos soon..
Some electrical readings about components, that I found some strange:
VR1: Pin 3: 4,91 volts, pin 1: 117 Volts
Diodes
D3: 0.650 --0.834 v
D8: 1.538 ---0.617 v
D2: 0.618 --- 1.60 v
I don´t know if this is OK....or not????
Besides the above i found nothing more peculiar on my sick Emax....
them
> Thanks,
> Ted
> > Well...
> > PSU...
> > Saludos
> > Ricardo
> > > drop
> > > orange = +12V
> > > purple = -12V
> > > EPROM.
> > > [w]
> > > the
> > > > power supply.
> > > > variance is ok, and
> > > > feed better as it
> > > chips
> > > > like 4.95 at
> > > a
> > > > board, the more
> > > the
> > > > correct pin to
> > > the
> > > > board from the
> > > 5
> > > > volt pin, it
> > > > than the 4.92. This
> > > test,
> > > > without making
> > > > power supply.... I
> > > > there would be a 10
> > > > supply is putting
> > > > issue.
> > > > 'rails'. Each rail
> > > have:
> > > > 1 x 5 Volt rail
> > > > 2 x 12 volt rail
> > > the
> > > > other bad, then
> > > > one.
> > > > first got it. They
> > > > circuit. Not an
> > > now
> > > > (there are better
> > > when
> > > > I first got the
> > > > solders" which are
> > > > require a
> > > > connect part of the
> > > > resolder all the
> > > seem
> > > > to help, get the
> > > > for 17 years on
> > > > Thanks,
> > > > Ted
> > > > the
> > > how
> > > > you
> > > > > do that????
> > > > > Más Saludos
> > > > > Ricardo
> > > > someone
> > > > > > will sell you a
> > > get
> > > > it)
> > > > > > and one bad IC
> > > > first.....
> > > > > > Thx,
> > > > > > Ted
> > > > wrote:
> > > > > > > Hi!:
> > > very
> > > > hot,
> > > > > > IC
> > > play
> > > > the
> > > > > > additionally
> > > > from
> > > sequence
> > > > on
> > > > > > the
> > > a
> > > > > > mess.
> > > system
> > > > > > crash
> > > > > > sounds
> > > > doing
> > > of
> > > > > > these
> > > > reseting
> > > > > > this
> > > > > > > devices.
> > > > > > > Saludos
> > > > > > > ricardo
> > > > the
> > > > > > chips
> > > > *everything*,
> > > > > > > > todos
> > > > > > motherboard?
> > > > > > > > [w]
> > > > wrote:
> > > > > > > > > Wayne:
> > > test
> > > > of
> > Do You Yahoo!?
Re: [emax] Re: Emax power supply
2007-05-01 by ted Summers
The voltage readings you got are the drops across the diodes, not the
actual output of that circuit..... those are typical numbers for that...
Ted
On Apr 30, 2007, at 5:37 AM, cheju_99 wrote:
> Hi Ted:
> Diodes
> D3: 0.650 --0.834 v
> them
> the
> > Thanks,
> > Ted
> > > Well...
> > > PSU...
> > > Saludos
> > > Ricardo
> > > > drop
> > > > orange = +12V
> > > > purple = -12V
> > > > EPROM.
> > > > [w]
> > > > the
> > > > > power supply.
> > > > > variance is ok, and
> > > > > feed better as it
> > > > chips
> > > > > like 4.95 at
> > > > a
> > > > > board, the more
> > > > the
> > > > > correct pin to
> > > > the
> > > > > board from the
> > > > 5
> > > > > volt pin, it
> > > > > than the 4.92. This
> > > > test,
> > > > > without making
> > > > > power supply.... I
> > > > > there would be a 10
> > > > > supply is putting
> > > > > issue.
> > > > > 'rails'. Each rail
> > > > have:
> > > > > 1 x 5 Volt rail
> > > > > 2 x 12 volt rail
> > > > the
> > > > > other bad, then
> > > > > one.
> > > > > first got it. They
> > > > > circuit. Not an
> > > > now
> > > > > (there are better
> > > > when
> > > > > I first got the
> > > > > solders" which are
> > > > > require a
> > > > > connect part of the
> > > > > resolder all the
> > > > seem
> > > > > to help, get the
> > > > > for 17 years on
> > > > > Thanks,
> > > > > Ted
> > > > > the
> > > > how
> > > > > you
> > > > > > do that????
> > > > > > Más Saludos
> > > > > > Ricardo
> > > > > someone
> > > > > > > will sell you a
> > > > get
> > > > > it)
> > > > > > > and one bad IC
> > > > > first.....
> > > > > > > Thx,
> > > > > > > Ted
> > > > > wrote:
> > > > > > > > Hi!:
> > > > very
> > > > > hot,
> > > > > > > IC
> > > > play
> > > > > the
> > > > > > > additionally
> > > > > from
> > > > sequence
> > > > > on
> > > > > > > the
> > > > a
> > > > > > > mess.
> > > > system
> > > > > > > crash
> > > > > > > sounds
> > > > > doing
> > > > of
> > > > > > > these
> > > > > reseting
> > > > > > > this
> > > > > > > > devices.
> > > > > > > > Saludos
> > > > > > > > ricardo
> > > > > the
> > > > > > > chips
> > > > > *everything*,
> > > > > > > > > todos
> > > > > > > motherboard?
> > > > > > > > > [w]
> > > > > wrote:
> > > > > > > > > > Wayne:
> > > > test
> > > > > of
> > > Do You Yahoo!?
2007-05-01 by RICARDO JUAREZ
Hi:
As you said... i put my multimeter on some pins on the
microprocessor i read 4,92 4,94, some 4,91, and then
i make a short circuit and the displays goes out, but
pressing On again i can reset. My questions is: the
potentiometer located in the Power supply  can make
some adjustment in the digital power out??????,
because i found another swithching Power supply from
another device.... who got this pot and you can make
some adjustment....
Thanks for your support
Saludos de Chile
Ricardo
> the diodes, not the
> numbers for that...
> Ted
> > Hi Ted:
> > Unfortunatelly there\ufffds no photo of the conectors ,
> but as you said
> > there\ufffds no label on the board, i expect to put
> found some strange:
> > Diodes
> > D3: 0.650 --0.834 v
> > I don\ufffdt know if this is OK....or not????
> my sick Emax....
> labels next to
> > them
> could post them to
> > the
> about, also.
> > > Thanks,
> > > Ted
> wrote:
> > > > Well...
> and found
> with some
> one with a
> several
> metalics
> "sort of
> the
> side, is
> unit
> in the
> > > > PSU...
> > > > Saludos
> > > > Ricardo
> voltage
> > > > > drop
> > > > > orange = +12V
> > > > > purple = -12V
> that's
> LCD
> the
> > > > > EPROM.
> > > > > [w]
> with
> > > > > the
> > > > > > power supply.
> little
> > > > > > variance is ok, and
> would
> > > > > > feed better as it
> Most
> > > > > chips
> > > > > > like 4.95 at
> measure across
> > > > > a
> > > > > > board, the more
> knew
> > > > > the
> > > > > > correct pin to
> across
> > > > > the
> > > > > > board from the
> on the
> > > > > 5
> > > > > > volt pin, it
> much lower
> > > > > > than the 4.92. This
> systems.
> and
> > > > > test,
> > > > > > without making
> AT style
> > > > > > power supply.... I
> sure why
> > > > > > there would be a 10
> the power
> > > > > > supply is putting
> another
> > > > > > issue.
> called
> > > > > > 'rails'. Each rail
> may
> > > > > have:
> > > > > > 1 x 5 Volt rail
> > > > > > 2 x 12 volt rail
> ok, and
> > > > > the
> > > > > > other bad, then
> the good
> > > > > > one.
> when I
> > > > > > first got it. They
> regulation
> > > > > > circuit. Not an
> often
> > > > > now
> > > > > > (there are better
> supply
> > > > > when
> > > > > > I first got the
> of "cold
> > > > > > solders" which are
> (sometimes
> > > > > > require a
> arc and
> > > > > > connect part of the
> which
> could
> You can
> > > > > > resolder all the
> doesn't
Do You Yahoo!?
Re: Emax 1 Alchemy - Sound Designer cable & software offer
2007-05-01 by mencoripieno
Hi Wayne,
I am interested in the Sound Designer for Emax + cable.
But I am in Italy, is it a problem for you?
In case you can, how much to ship? My zip code is 52037, city is
Sansepolcro, Italy.
Thank you in advance.
Patrizio
> I am making up some EMAX SD / Alchemy cables and I
> wanted to know if anyone in the US or Canada needs one
> on this batch.
> It's just as much trouble to build and test 5 as it is
> 1 so I thought I would offer this to the group.
> Each order can specify a desired length- I've been
> using 8 ft. Localtalk driver levels have allowed me to
> experiment with as much as 15ft. I'll use top
> materials and my soldering is pro.
> The price for the cable and shipping is $20.
> If you ever wanted to edit your Emax via Mac GUI as
> opposed to TEDIOUS LCD time (straining neck, slider
> values jumping around) I can also provide the
> previously hella-unobtainable
> Sound Designer for EMAX 1
> It runs well on any of the 68030's.
> If you want the cable and
> the bootable Zip100 (or supplied SCSI HD) with
> SoundDesigner / Alchemy / all the other little Emax
> toolz that'll be $40
> I have made custom Mac / PC editing rigs for all kinds
> of samplers.
> For references, check the Emulator II yahoo group.
> NO self-respecting cognoscenti of the Emax is without
> a working installation of Alchemy & Sound Designer.
> This offer stands for two weeks from to-day, 07.05.01
> ad fontes, [w]
> (BTW, I know Alchemy is passed around but SD isn't)
> Do You Yahoo!?
Re: [emax] Re: Emax 1 Alchemy - Sound Designer cable & software offer
2007-05-01 by Patrizio
Hi Wayne, thank you for your fast reply.
Yes I do, I have a scsi zip (I use with my Emax SE scsi).
Now I have a beige G3 for use with alchemy via midi, I don't know if
it's ok with SD but if necessary I will get an older 68030 as you indicated.
In case I have to get a 68030 or similar, wich model do you suggest?
$80 includes also the mac cable?
If for you it's all ok tomorrow I will send you $80 to the paypal
address you indicated.
Thank you again for your kindness.
Patrizio
Wayne Griffin wrote:
> What model Macintosh are you going to use?
> Do you have a SCSI Zip?
> my paypal address is
> waynegriffin@... <mailto:waynegriffin%40comcast.net>
> I did say North America but I will make an exception
> for you.
> I think I will need $80 in your case because of
> international shipping (Global International Express
> shipping from United States Postal Service).
> [w]
> --- mencoripieno <mencoripieno@...
> <mailto:mencoripieno%40yahoo.it>> wrote:
> > Hi Wayne,
> > cable.
> > 52037, city is
> > Sansepolcro, Italy.
> > Patrizio
> > --- In emax@yahoogroups.com <mailto:emax%40yahoogroups.com>, Wayne
> Griffin
> > one
> > > on this batch.
> > it is
> > me to
> > as
> > slider
> > Emax
> > kinds
> > > of samplers.
> > without
> > Designer.
> > 07.05.01
> > > ad fontes, [w]
> > isn't)
> > > Do You Yahoo!?
> > protection around
> > > http://mail.yahoo.com <http://mail.yahoo.com>
> Do You Yahoo!?
indicated.
Patrizio
> waynegriffin@...
> for you.
> [w]
> --- mencoripieno <mencoripieno@...> wrote:
> > Hi Wayne,
> > cable.
> > 52037, city is
> > Sansepolcro, Italy.
> > Patrizio
> > one
> > > on this batch.
> > it is
> > me to
> > as
> > slider
> > Emax
> > kinds
> > > of samplers.
> > without
> > Designer.
> > 07.05.01
> > > ad fontes, [w]
> > isn't)
> > > Do You Yahoo!?
> > protection around
> Do You Yahoo!?
2007-05-01 by cheju_99
You can adjust the digital volts by turning the pot in the PSU, i do
so until 5,30 volts....but no change in the machine, finally there´s
a problem on some IC, who knows what are the SSM´s chips??? and the
PAL, or the scanner MPU???? i can´t locate in the mobo....
them
> Thanks,
> Ted
> > Well...
> > PSU...
> > Saludos
> > Ricardo
> > > drop
> > > orange = +12V
> > > purple = -12V
> > > EPROM.
> > > [w]
> > > the
> > > > power supply.
> > > > variance is ok, and
> > > > feed better as it
> > > chips
> > > > like 4.95 at
> > > a
> > > > board, the more
> > > the
> > > > correct pin to
> > > the
> > > > board from the
> > > 5
> > > > volt pin, it
> > > > than the 4.92. This
> > > test,
> > > > without making
> > > > power supply.... I
> > > > there would be a 10
> > > > supply is putting
> > > > issue.
> > > > 'rails'. Each rail
> > > have:
> > > > 1 x 5 Volt rail
> > > > 2 x 12 volt rail
> > > the
> > > > other bad, then
> > > > one.
> > > > first got it. They
> > > > circuit. Not an
> > > now
> > > > (there are better
> > > when
> > > > I first got the
> > > > solders" which are
> > > > require a
> > > > connect part of the
> > > > resolder all the
> > > seem
> > > > to help, get the
> > > > for 17 years on
> > > > Thanks,
> > > > Ted
> > > > the
> > > how
> > > > you
> > > > > do that????
> > > > > Más Saludos
> > > > > Ricardo
> > > > someone
> > > > > > will sell you a
> > > get
> > > > it)
> > > > > > and one bad IC
> > > > first.....
> > > > > > Thx,
> > > > > > Ted
> > > > wrote:
> > > > > > > Hi!:
> > > very
> > > > hot,
> > > > > > IC
> > > play
> > > > the
> > > > > > additionally
> > > > from
> > > sequence
> > > > on
> > > > > > the
> > > a
> > > > > > mess.
> > > system
> > > > > > crash
> > > > > > sounds
> > > > doing
> > > of
> > > > > > these
> > > > reseting
> > > > > > this
> > > > > > > devices.
> > > > > > > Saludos
> > > > > > > ricardo
> > > > the
> > > > > > chips
> > > > *everything*,
> > > > > > > > todos
> > > > > > motherboard?
> > > > > > > > [w]
> > > > wrote:
> > > > > > > > > Wayne:
> > > test
> > > > of
> > Do You Yahoo!?
2007-05-01 by jesse misemer
I am using my EMAX HD SE PLUS keyboard with an apple power mac 8600 ( 604e ) with Alchemy . I have a drive in the mac I boot in 7.5  os.  WITH NO PROBLEMS!
jesse
Ahhh...imagining that irresistible "new car" smell?
 Check outnew cars at Yahoo! Autos.
RE: [emax] Re: Emax power supply
2007-05-01 by Tomas Komorowski
Hallo,
Can You recommend me how to determine an O.S. version in my EMAX II? I have
KBD version.
Thanks a lot
Tomas
2007-05-02 by RICARDO JUAREZ
put your diskette on EMXP and check version
--- Tomas Komorowski <komorowski@...>
wrote:
> Hallo,
> KBD version.
> Thanks a lot
> Tomas
> removed]
Do You Yahoo!?
2007-05-02 by cheju_99
Check the photo section, there´s one with the back of the keyboard
and you can see the jacks(white-blue)...
them
> Thanks,
> Ted
> > Well...
> > PSU...
> > Saludos
> > Ricardo
> > > drop
> > > orange = +12V
> > > purple = -12V
> > > EPROM.
> > > [w]
> > > the
> > > > power supply.
> > > > variance is ok, and
> > > > feed better as it
> > > chips
> > > > like 4.95 at
> > > a
> > > > board, the more
> > > the
> > > > correct pin to
> > > the
> > > > board from the
> > > 5
> > > > volt pin, it
> > > > than the 4.92. This
> > > test,
> > > > without making
> > > > power supply.... I
> > > > there would be a 10
> > > > supply is putting
> > > > issue.
> > > > 'rails'. Each rail
> > > have:
> > > > 1 x 5 Volt rail
> > > > 2 x 12 volt rail
> > > the
> > > > other bad, then
> > > > one.
> > > > first got it. They
> > > > circuit. Not an
> > > now
> > > > (there are better
> > > when
> > > > I first got the
> > > > solders" which are
> > > > require a
> > > > connect part of the
> > > > resolder all the
> > > seem
> > > > to help, get the
> > > > for 17 years on
> > > > Thanks,
> > > > Ted
> > > > the
> > > how
> > > > you
> > > > > do that????
> > > > > Más Saludos
> > > > > Ricardo
> > > > someone
> > > > > > will sell you a
> > > get
> > > > it)
> > > > > > and one bad IC
> > > > first.....
> > > > > > Thx,
> > > > > > Ted
> > > > wrote:
> > > > > > > Hi!:
> > > very
> > > > hot,
> > > > > > IC
> > > play
> > > > the
> > > > > > additionally
> > > > from
> > > sequence
> > > > on
> > > > > > the
> > > a
> > > > > > mess.
> > > system
> > > > > > crash
> > > > > > sounds
> > > > doing
> > > of
> > > > > > these
> > > > reseting
> > > > > > this
> > > > > > > devices.
> > > > > > > Saludos
> > > > > > > ricardo
> > > > the
> > > > > > chips
> > > > *everything*,
> > > > > > > > todos
> > > > > > motherboard?
> > > > > > > > [w]
> > > > wrote:
> > > > > > > > > Wayne:
> > > test
> > > > of
> > Do You Yahoo!?
Check the photo section with my emax on the surgery table.....there´s a
blue jack on the back of the keyboard..For what it is????
about
> this cause???
> Thanks in advance.
> Richard
2007-05-03 by ted Summers
I don't know about that one....
Ted
> ´s a
> 1000,
> the
> about
> > this cause???
> > Thanks in advance.
> > Richard
2007-05-03 by RICARDO JUAREZ
I found something strange: i found sort of
modification for HD in my Mother board, actually i
found a cut trace between IC54 and IC2, there\ufffds no HD
in my Emax, so maybe someone try to install an HD and
fail, but he forgot to restore the cuts and loops, may
be this is the problem with my machine???????? There\ufffds
no cuts in the circuit on a rev 2.0 PCB machine?????
> Ted
> > \ufffds a
> is????
> an Emax, serial
> > 1000,
> push the ON Button,
> great "Loading
> and finally showing
> > the
> > about
> > > this cause???
> > > Thanks in advance.
> > > Richard
> removed]
Do You Yahoo!?
2007-05-04 by ted Summers
I do not know- you could find out by going to
www.emulatorarchive.com. There is a howto to add a hard drive there
that talks about the procedure in detail. You would be able to know
from that..... Of course, you might have it enabled and not know that
you could put a hard drive in.... I bought a broken emax rack off
ebay for $40 and it had stuff in it to make my keyboard an HD model....
Ted
> found a cut trace between IC54 and IC2, there´s no HD
> be this is the problem with my machine???????? There´s
> > Ted
> > > ´s a
> > is????
> > an Emax, serial
> > > 1000,
> > push the ON Button,
> > great "Loading
> > and finally showing
> > > the
> > > about
> > > > this cause???
> > > > Thanks in advance.
> > > > Richard
> > removed]
> > Yahoo! Groups Links
> Do You Yahoo!?
Re: [emax] Emax 1 Alchemy - Sound Designer Last 3 kits
2007-05-08 by sam goose
Hi.  Can i use a mac SE with my emax.  Will it run the programs?  and how do
i connect it?
>From: Wayne Griffin <ingsoc_1979@...>
>Subject: Re: [emax] Emax 1 Alchemy - Sound Designer Last 3 kits
>Date: Tue, 8 May 2007 12:23:47 -0700 (PDT)
>If there's anyone left that hasn't placed an order you
>should do so now. I only have enough supplies left to
>make 3 more Sound Designer kits. Then I put them on
>ebay? cheers, [w]
> > one
> > on this batch.
> > is
> > to
> > kinds
> > of samplers.
> > without
> > 07.05.01
> > ad fontes, [w]
> > Do You Yahoo!?
> > protection around
>Do You Yahoo!?
FREE pop-up blocking with the new MSN Toolbar - get it now!
http://toolbar.msn.click-url.com/go/onm00200415ave/direct/01/
RE: [emax] Mac SE is perfect for Emax SD
Hi.  I looked at my mac and found out its, only got 1 Mb.
Will that work?
Also would you post cables software to uk, and do you accept paypal?
>Subject: [emax] Mac SE is perfect for Emax SD
>Date: Tue, 8 May 2007 14:13:23 -0700 (PDT)
>Absolutely. The Mac SE is actually one of the very
>best Macs to use with this software with since it was
>designed for that series.
>To connect it, just attach the supplied cable to
>either your modem or printer ports. After that, you'll
>need to tell Sound Designer what port you attached it
>to. After that, you're on your way.
>I am enclosing some screenshots that I did on a Mac
>Classic which is quite similar to the SE. [w]
> > i connect it?
> > Last 3 kits
> > you
> > to
> > >ebay? cheers, [w]
> > I
> > needs
> > > > one
> > > > on this batch.
> > it
> > > > is
> > been
> > me
> > > > to
> > as
> > slider
> > Emax
> > > > kinds
> > > > of samplers.
> > group.
> > > > without
> > Designer.
> > > > 07.05.01
> > > > ad fontes, [w]
> > isn't)
> > > > Do You Yahoo!?
> > > > protection around
> > >Do You Yahoo!?
> > protection around
> > it now!
>____________________________________________________________________________________
>Expecting? Get great news right away with email Auto-Check.
>Try the Yahoo! Mail Beta.
>http://advision.webevents.yahoo.com/mailbeta/newmail_tools.html
Express yourself instantly with MSN Messenger! Download today it's FREE!
http://messenger.msn.click-url.com/go/onm00200471ave/direct/01/
2009-05-08 by one23fofif
Are you still offering the cable and software?  I'm very interested for sure!  Have you or anyone you konw tried running the software on a windows PC with a classic Mac emulator?  Either way put me in for an order if you're still making the cables.  I can pay via Paypal if that's acceptable.
THanks!
> on this batch.
> of samplers.
> ad fontes, [w]
> Do You Yahoo!?
2009-05-22 by Jason Mc
Hello,
I am also looking for a EMAX SD / Alchemy cables/software. Do you know who i
can get in touch with to get placed on this order?
Jason, new emaxer (love the 12bit)
> THanks!
> -- In emax@yahoogroups.com <emax%40yahoogroups.com>, Wayne Griffin
> > on this batch.
> > of samplers.
> > ad fontes, [w]
> > Do You Yahoo!?
2009-05-22 by esynthesist
As far as I know Wayne is still taking orders.
Just e-mail him on his Yahoo account (ingsoc_1979 at yahoo dot com).
Except for the guys (and girls :-) who received SD for Emax from Wayne, I don't think there's any one else out there who owns this software package...
///E-Synthesist
--- In emax@yahoogroups.com, Jason Mc <jasonmcdougal@...> wrote:
> Hello,
> > THanks!
> > > on this batch.
> > > of samplers.
> > > ad fontes, [w]
> > > Do You Yahoo!?
