Re: [EXS] SoundsOnline Xmas sale
2003-12-14 by topfloormix@aol.com
I have tried the "XMAS" code, but no-luck/no-35% off! I wanted to order the full "SAM" set (Horns/Trombones/Trumpets), as well as Quantum Leap Brass EMU. LG [Non-text portions of this message have been removed]
2003-12-14 by Fernstudio
Hi, On Dec 13, 2003, at 5:57 PM, topfloormix@... wrote: > I have tried the "XMAS" code, but no-luck/no-35% off! > > I wanted to order the full "SAM" set (Horns/Trombones/Trumpets), as > well as > Quantum Leap Brass EMU. > I just tried. For the SAM Set, I couldn't get it to work either. However, there are other titles which I could apply it to. Perhaps you should give them a call or email. The QL Brass EMU format is on sale currently as part of their December sale. You won't be gettng an additional 35% off on it but it is currently at a phenomenal price ($99 US). I ordered it a few days ago myself since it is such an awesome deal. Fernstudio [Non-text portions of this message have been removed]
2003-12-14 by Ned Bouhalassa
It should work. I've never had trouble with Soundsonline's specials.
Have you tried contacting them directly? AFAIK, the only things that
are not on special are the EWQL libraries...
Ned
> well as
> LG
> Yahoo! Groups Sponsor
> ADVERTISEMENT
> <image.tiff>
> <image.tiff>
> ____________________________________________________________________
> EXS* Users Group
> - To UNSUBSCRIBE: email exs-users-unsubscribe@yahoogroups.com
> - EXS/Logic FAQ:http://logicfaq.omega-art.com/
> - Free legal samples:http://groups.yahoo.com/group/exs-users/links/
> - To contact list admins, email exs-users-owner@yahoogroups.com
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
http://www.nedfx.com
Ned Bouhalassa
n e d @ n e d f x . c o m
[Non-text portions of this message have been removed]2003-12-14 by Mark
If you go to http://www.bigfishaudio.com and enter the coupon code "claus" you get $25 off. Just and FYI! :) --- In exs-users@yahoogroups.com, Ned Bouhalassa <ned@n...> wrote: > It should work. I've never had trouble with Soundsonline's specials. > Have you tried contacting them directly? AFAIK, the only things that
> are not on special are the EWQL libraries... > > Ned >
I have experienced unpredictable result when converting from Emu or Akai to EXS24, either using CDXtract or the EXS24 itself. It depends on the material/CDs, not everything gets converted properly, sometimes you get missing instruments/samples from the original. Thus, Quantum Leap Brass comes in different flavour (Akai, Giga, Emu...), and I am not to sure which of these format would be the "safest" to go for, to get best result. Advice appreciated, LG [Non-text portions of this message have been removed]
Cheers Garth, is there a demo available for Chick/Sys? I would like to do an A/B comparison with CDXtract on the same CD. LG [Non-text portions of this message have been removed]
2003-12-14 by Garth Hjelte
At 12:13 PM 12/14/03 -0500, you wrote: >I have experienced unpredictable result when converting from Emu or Akai to >EXS24, either using CDXtract or the EXS24 itself. It depends on the >material/CDs, not everything gets converted properly, sometimes you get >missing >instruments/samples from the original. Thus, Quantum Leap Brass comes in >different >flavour (Akai, Giga, Emu...), and I am not to sure which of these format >would be >the "safest" to go for, to get best result. I would go for the Giga version, as it has keyswitching which the EXS-24 supports, and also doesn't impose memory restrictions, which is not compelling for the EXS either. Akai will restrict memory, which you don't want. The Emu likely will impose real-time programming which the EXS probably can't handle. However, Giga won't "go to town" on the programming, will give you large samples, adn supply keyswitching which you can handle as well. As far as conversion goes, Translator www.chickensys.com never drops any instruments/samples from any Emu or Akai setup, unless the Bank or Program/Volume is corrupted in the first place. However, if ever it does or seems like it does, you are free to submit it to one our 257 holiday support staffers (okay, I'm kidding) and we'll check it out and send you a holiday chocolate gift bag as a friendly thank you. Garth Hjelte Sampler User
2003-12-14 by dfusion2000
I agree with Garth. I think getting CDs in Giga provides the best results and give the most flexibility. I drop the Giga files into my "Sampler Instruments" directory and they automatically show up in the EXS24. Of course the first time you select a sample the EXS24 converts it, but it does this so well I don't see the need to use another application. Just make sure after everything is converted you delete the old Giga file otherwise you're using up double the disk space. Regards, Mark --- In exs-users@yahoogroups.com, topfloormix@a... wrote: > > > I have experienced unpredictable result when converting from Emu or Akai to > EXS24, either using CDXtract or the EXS24 itself. It depends on the > material/CDs, not everything gets converted properly, sometimes you get missing > instruments/samples from the original. Thus, Quantum Leap Brass comes in different > flavour (Akai, Giga, Emu...), and I am not to sure which of these format would be
> the "safest" to go for, to get best result. > > Advice appreciated,
2003-12-15 by topfloormix@aol.com
Thanx Mark, this is very valuable advice from you too. LG [Non-text portions of this message have been removed]
2003-12-15 by Fernstudio
Hi, On Dec 14, 2003, at 3:55 PM, dfusion2000 wrote: > I agree with Garth. I think getting CDs in Giga provides the best > results and give the most flexibility. I drop the Giga files into > my "Sampler Instruments" directory and they automatically show up in > the EXS24. Of course the first time you select a sample the EXS24 > converts it, but it does this so well I don't see the need to use > another application. Just make sure after everything is converted > you delete the old Giga file otherwise you're using up double the > disk space. > The GIGA version is on sale as well but not discounted as much as the E-mu version ($199 vs $99). It all depends on whether or not you want to pay the extra for the easier conversion since the GIGA version is programmed to include various velocity levels and articulations in the same program whereas I believe that the E-mu version does not (in order to save memory). You're not getting any more samples on the GIGA version than on the E-mu version - just the combined programs. Myself, I went for the E-mu version and took the extra price break. I tend to program my own patches anyway and rarely use the programs as they come directly off of the sample CD. HTH, Fernstudio [Non-text portions of this message have been removed]
BTW, I managed to get the 35% off (thanks to you again) For the "Sam-set" (Tromb/Horn/Trump), you simply have to "add to cart" one by one without using the option where they offer 10 or 20% if you buy two or three CDs... Quantum Leap Brass Giga did qualify for the 35% off as well. So in total I ordered four different titles, three "Sams" and one "Quantum". For some reason, choosing the Emu version over the Giga, only saved $30/£20! Well, I really look forward to get my hands on those Roms and hopefully, getting those horns to "Funk-up" the hell out of my grooves. The great thing about all that, is that was just looking around for some good horns at a sensible price lately, you made my day (well, my Christmas... ;-) A big thank to Ned as well, cause with the "free samples" link he gave use, I was able to check out the Sam stuff, which I wasn't aware of those horns library. Thousand thanx again for the Xmas tips, and for the one who belive, let's praise the Lord. Peace LG [Non-text portions of this message have been removed]
