Re: change default controller mappings?
2003-08-14 by teddybut
> On a fine day, 13-08-2003, teddybut wrote: > >> can you change the default controller mappings in the EXS? I have a >> controller keyboard and I want my default mappings to save the setup for my >> particular keyboard. It's a lot to setup everytime you open a new >> instrument. >> >> or is there a way to copy and paste controller mappings from instrument to >> instrument? > > I suppose you're talking about the modulation matrix... yes sir... > As a workaround I guess you could always create a small automation > sequence that sets up the mod-matrix like you want it. Then when > creating a new EXS track, just put this sequence on it, play it back, > and you're done. > > -- > Hendrik Jan Veenstra h @ k n o w a r e . n l that sounds like an interesting thing but wouldn't the instrument be included in that setting? it is here in 6.1.1. My workaround was to 1) setup the matrix how I want it and "save setting to instrument" in the options menu, then go to the next instrument, delete it's setting in the options menu (if it has any, if it doesn't, the matrix settings get carried over and you can just save them to the that instrument), 2) go back to the instrument with the right matrix setup, 3) go back to the instrument that I just deleted the settings in. then the matrix gets carried over since there's no saved setting. 4) save the matrix settings in the that instrument. Kind of a pain in the butt to do to 30,000 sampler instruments, but last night I did about 300 of them in about an hour. the easiest way was to go through and just delete many settings first, go back to the one with the right setup, then keep hitting next, they carry over and you save the settings to each instrument. no key command for saving or deleting though. my hand gets tired from the mouse in the options menu. the project manager should handle this in bulk, or there should just be a way to save your own default settings. wouldn't it be nice? teddybut
