Lpc2000
Questions on the UART Interface
2004-11-17 by Leighton Rowe
Just for clarification on the UART Block Diagram (see UM)...
1. Do U0TSR & U0RSR actually representthe Tx & Rx FIFO buffers? I
only see U0TSR & U0RSR illustrated here and I can't find any other
documentation for it.
Now concerning U0THR & U0RBR (data registers)...
2. Why do they both share the same memory address? I'd really like
to know the purpose of this.
3. What will happen if the lpc receives a character while I'm
writing to the transmit register?
I ask this because currently, I'm having trouble running the serial
port both ways (with interrupts) while sending replies and receiving
command packets from the PC. Sometimes the protocol I'm using works.
However, while debugging I always notice the lpc losing receiver
bytes whenever communication goes wrong. I only observe this
happening if the lpc's replying to a command packet and another
command packet's coming in the same time.
best regards,
Leighton
Re: [lpc2000] Questions on the UART Interface
2004-11-17 by Robert Adsett
Consider the R/W line an extra address bit if it helps.  They don't share
the same physical memory.  The idea (from the 8250 on) is that since you
never read the transmit register and never write the receive register that
they can be distinguished simply by the state of the read line and save all
that extra address space and decoding logic (also explains why the divisor
latch is a banked register).  These would be from the same school of chip
designers that believe you never actually need to read setup registers.
It's supposed to act just fine.
Are you sure it's not the other way around?  I have seen a similar problem
but I keep losing THRE interrupts.  It appears they 'disappear' if the LPC
receives a byte while the interrupt identification register was being
read.  I have a work-around that appears to at least reduce the problem
(I've not had it reappear) that only reads the IIR once per interrupt.
It behaves similarly to the documented race conditions on the LPC
(particularly the timers) but I've not seen anybody report duplicating it yet.
Needless to say, I'd like to know for sure what's going on with it and you
seem to have come closest to duplicating the conditions I see it under
(both interrupts active, transmit and receive happening simultaneously).
Robert
" 'Freedom' has no meaning of itself.  There are always restrictions,
be they legal, genetic, or physical.  If you don't believe me, try to
chew a radio signal. "
                         Kelvin Throop, III
Re: Questions on the UART Interface
2004-11-17 by Karl Olsen
--- In lpc2000@yahoogroups.com, "Leighton Rowe" <leightonsrowe@y...>
No, they are the actual shift registers.  U0TSR can be checked with
U0LSR bit 6, TEMT.  TEMT=0 => U0TSR is shifting out a byte, TEMT=1 =>
U0TSR is idle.  The 16-byte FIFOs aren't shown in the figure, but
would rather correspond to U0THR and U0RBR.  For better
documentation, Google for 16C550.
Writing to the address means writing to U0THR, and reading from the
address means reading from U0RBR.  They occupy the same address
because Philips chose to be software compatible with the 16C550,
which was designed to be hardware and software compatible with the
8250, which was designed at a time when I/O addresses apparently were
very precious.  For an even worse example of this mindset, see the
Intel 8259 interrupt controller which occupies two(!) I/O addresses.
Nothing special, the receiver and transmitter work independently.
But make sure that you don't miss any of them in your interrupt
handler.
receiving
works.
When you enable more than one interrupt in U0IER (such as both
receive and transmit interrupt), you should in your interrupt handler
check U0IIR to see what caused the interrupt.  More than one
interrupt can occur at a time, and the highest priority one is
indicated in U0IIR.
Pay close attention to the "Interrupt Reset" column in the UART0
Interrupt Handling table.  When you have seen in U0IIR what caused
the interrupt, you should handle it, and then do the action in
the "Interrupt Reset" column to tell the UART that you have handled
it.  For a receive interrupt, the Interrupt Reset action is to
read U0RBR, so it is a quite normal part of handling a receive
interrupt.  For a transmit interrupt, the reset action is simply
reading U0IIR, which you have already done since you know it is a
transmit interrupt.
If you don't do the Interrupt Reset action in your interrupt handler
for a pending interrupt, the UART will immediately interrupt again.
So you can write your interrupt handler in two ways:
a. Check U0IIR, handle the highest-priority pending interrupt,
thereby doing the Interrupt Reset action, and return.  If more than
one interrupt was pending, the UART will immediately interrupt again,
and then present the next-highest priority interrupt in U0IIR, and so
on.  This way is the easiest, and the best one if multiple
simultaneous interrupts are rare.
b. Check U0IIR, handle the highest-priority pending interrupt,
thereby doing the Interrupt Reset action.  Re-check U0IIR, and loop
around if another interrupt is pending.  When no more interrupts are
pending, return.  This way is better if multiple simultaneous
interrupts are so likely that it pays off to save the multiple
interrupt entry/exit code.
Karl Olsen
Re: [lpc2000] Re: Questions on the UART Interface
2004-11-18 by Robert Adsett
That's certainly the way it's supposed to work (and the way I have done it
on 'real' 16550s) but when I do this on an LPC2106 with both transmit and
receive interrupts I occasionally miss THRE interrupts (they just never
occur).  This only happens when receive is occurring at the same time as
transmit (I used a simple echo test) and it only occurs infrequently
(several 100K up to a megabyte or more of transmitted bytes before it would
halt).  The only explanation I have is an undocumented race condition in
updating the IIR as it is being read but as I said in an earlier post I
haven't seen any duplication.  Changing to the less conventional one IIR
read per interrupt seems to eliminate the problem but maybe all it does is
reduce the probability.
Leighton's symptoms appear to be similar to (but not the same as) what I've
seen so I'm wondering if he hasn't run across the same underlying problem I
have.
The THRE interrupts are the only serial interrupts that do not re-assert if
they are not serviced so they are particularly vulnerable.
Robert
                         Kelvin Throop, III
2004-11-18 by Leighton Rowe
Sorry for the delay guys,
Point taken for the answers to 1,2, and 3. Thanks Karl & Robert.
what I've
problem I
> have.
assert if
Robert, I haven't yet seen the problem you described that's
interestingly the opposite to what I'm getting. Debugging through
the JTAG and using a serial port data logger I see all the receiver
bytes coming in from the PC. I usually send up to 16 bytes per THRE
& for the most part the lpc sends the reply packet correctly. But
only in that special case I see the lpc not respond to the last
command packet. It came across the receive line ok (logger) so the
PC's ok. However on the lpc side I debug and see the packet looking
truncated. Like some bytes got lost while receiving, which looks
kinda wierd. I haven't yet seen the opposite happen b4.
than
again,
so
loop
are
Interesting stuff Karl. I wasn't really paying attention to the IIR
table. So, I'll have to review my code just incase I did a bit too
much for RDA & THRE. Basically, the code I'm using is following Plan
B. Bill Knight's code follows the same concept too. I'll give Plan A
a try though, since my PC <-> lpc communication is on a small scale,
and Robert's having more success with it.
>what I've
>problem I
> > have.
>assert if
I had a thought.  If my speculation about a race condition in IIR is
correct it may well explain both our problems.  In my case I lose the THRE
interrupt and thus stop transmitting.  In your case you lose a receive
interrupt and drop a character.  My test wouldn't catch a dropped character
since I wasn't running any sort of check or comparison so all I would see
is if the echo stopped cold (if a receive interrupt was missed it would
just pick up the next one).
Do you know (and can you tell) if the packet is truncated or maybe just
missing characters from its body?  If it always just characters at the end
I'm less optimistic about the race condition.
If it is a race in the IIR then a single read per interrupt might help (or
it might not) depending on the details of the race and the timing (ICK).
In any case let us know how changing to a single IIR read per interrupt
affects the problem.
Robert
                         Kelvin Throop, III
just
the end
Well after double checking & changing my code to the single IIR read
concept, things remained the same. The affected packet I receive
always get's somewhat truncated in the middle, with the last bytes
showing up a few bytes earlier than expected.
I however notice LSR interrupt occuring at the point where the
problem occurs but I don't see any signs of any LSR errors.
Just a crazy question though...can the UART ISR interrupt itself?
(eg. while processing a THRE an RDA interrupt comes in)
Should I enable the FIFOs (write 1 to U0FCR) before running the
interrupts? I seem to be getting by without this up until this point.
Thanks again,
Leighton
>just
>the end
Well that fits with the speculation of an IIR race condition.  Doesn't
prove it but it does fit.  You may have duplicated what I've been seeing.
Hmmm... Doesn't make much sense to me either.  Maybe instead of a simple
race the source is being miss-classified?  My own test would not have seen
a difference between that and the interrupt simply dissappearing.
At the very least that would require that you re-enable the associated
interrupt (IRQ or FIQ) and if vectored through the VIC you would also have
to acknowledge the vectored interrupt with the appropriate write to the VIC
first as well.   If you've done that, try it again w/o re-enabling the
interrupts.
I don't see why that would eliminate the problem.  Worse it might hide it
so that it showed up later under less benign conditions.
Curiouser and curiouser
Robert
                         Kelvin Throop, III
point.
hide it
Good news...I got communication running alot better after enabling
FIFOs (U0FCR = 1) at startup. So far, no Rx & Tx glitches yet. Try
doing the same to see what happens.
For now the LSR mystery is worth forgetting.
Leighton
>point.
>hide it
That rather worries me.  I will give it try and see what it does on my code
though (I've got a few other items to take care of first).  I place it in
the same category as my read-IIR-only-once-per-interrupt 'fix' though.  I
strongly suspect it's only masking temporarily whatever the underlying
cause is.
I suspect there is something similar going on here as happens with the SPI
and the timers.  We've now got two independent reports of missing
interrupts on the UART with no clear source of the problem.
Robert
                         Kelvin Throop, III
2004-11-18 by g2100g
You MUST enable the FIFO (by setting U0FCR:0) - See Description of
that bit in Table 66 of LPC2106 User Manual.
Since other sections of the manual imply that you can run without
this bit set, I asked Philips about it.  One of the apps engineers
told me it was OK to run without the FIFO enabled.  Hwever, another
apps engineer told me that the original intention was to allow
operation without the FIFO, but they discovered some bugs operating
in that mode, so they redefined the product to not allow that mode of
operation.
So, as far as I know, if the FIFO is not enabled - all bets are off.
Robert: Are you also operating without the FIFO when you have your
problems?
As to whether the problem operating without the FIFO (which Philips
has long been aware of) might be caused by a similar race condition
as the timer interrupt problem - interesting question.  When I
discussed the FIFO issue with them, the timer problem had not yet
been discovered.  Now that Philips has an understanding of the timer
interrupt problem (and has reportedly implemented a fix on some new
chips in development), their circuit designers should be able to
easily determine if a similar problem exists here.
In fact, there are a number of other registers which also get written
to by both the core and peripheral hardware.  Has Philips analyzed
which of these are subject to the same problem with simultaneoues
access?
Philips: How about letting us know what's going on!
> point.
> hide it
> Leighton
Thanks for passing this along.  It may be the root of a problem that's been
bothering me for some time.  There are times when I start to think Philips
is actually trying to kill this microcontroller.
Good heavens, that's well hidden.  I don't think very many others noticed
that.  Most of the example uart code doesn't use the FIFOs.  It's certainly
contradictory to any other 16550 implementation.
I'll have to go back to my paper copy and see if that was in earlier revs
of the UM.  Sheesh!
>operation.
>problems?
Nope, the program I've got that ran into the problem has the FIFO
enabled.  Hmm that went through a set of changes I may have added the FIFO
after changing the IIR read. I'll have to go back and recheck to see if it
works properly with the FIFO enabled now.
Well, one race condition is an oversight.  Two make me wonder if it was
something they didn't check for properly.  And since both the SPI and timer
have documented race conditions (and given the apparent long lead time
between the discovery of an issue and letting us know about it) ....
>access?
Very good question.  Having errata come out in dribs and drabs is very
frustrating.
I'll get to this shortly, I hope,  and I will report back (after restoring
IIR multiple read with FIFO's enabled and performing a test).
Robert
                         Kelvin Throop, III
2004-11-19 by lp2000c
It seems to me that given the problem with the UART interrupt
register, it is more likely than not that the same problem exists
with other registers.  Rather than "one race condition is an
oversight," I would assume similar circuit design would be used in
all parts of the chip.
In any event, this is something which should be very easy for
Philips' circuit designers to answer.
As engineers, we can all appreciate that bugs sometimes get through.
It's the lack of information, once the bug is discovered, that's
frustrating.
--- In lpc2000@yahoogroups.com, Robert Adsett <subscriptions@a...>
was
and timer
time
written
> >access?
very
> frustrating.
CAN messages delayed by one?
2004-11-20 by Robert Wood
Hi folks,
First off, I'm using the LPC2294.
I am finding my CAN messages seemingly delayed by one message. In my main loop
I have:
if ((CAN1GSR  & 0x01) == 0x01)
		QueueCAN1Out();		// Queue up the received  message to send out of the UART.
		CAN1CMR |= 0x04;		// Clear the had frame bit
The call to QueueCAN1Out is triggered when I send out a CAN message from an
external CAN node into the LPC. However, the first message I look at reads
all its registers as being filled with zeros. If I then send another CAN
message from the external CAN node, the data and the identifier are what was
send out by the remote node on the first transmission. The third message
reads the second message's data and identifier and so on.
If I insert the line:
	temp = CAN1RID;
into the routine above, just to prove it's not a different part of my code
that's at fault, the value in temp is always the identifier from the previous
CAN mesaage.
Has anyone ever come across this before? I've read through the datasheet and
nothing seems to indicate why this would happen and I don't see anything in
the errata sheet either. I have checked with a little CAN analyser and the
messages being sent out from the external node seem correct.
I've even tried reading the first message twice to see if I could flush out
the phantom zeros, but I just read zeros again. It's only when I receive the
second CAN message that the first message is flushed out.
Anyone seen anything like this before? And if so, do you know what I'm doing
wrong?!
Many thanks.
Rob.
Re: CAN messages delayed by one?
2004-11-21 by mahlerweb
Hi Robert,
are you sure, that not another nodes sends any ID before your
external node ?
The CAN-Core contains a internal Buffer with about 64 Bytes
(descriped at  SJA1000, should be the same at LPC ). So if your
Buffer contains any other data  which were received from a previous
message, you will get this one.
In normal case you should receive messages like this :
while((CAN1GSR  & 0x01) == 0x01) {
     QueueCAN1Out();
     CAN1CMR |= 0x04;
hope it helps,
Peter
--- In lpc2000@yahoogroups.com, Robert Wood <robert.wood@a...> wrote:
> Hi folks,
my main loop
> I have:
frame bit
from an
at reads
another CAN
what was
message
> 	temp = CAN1RID;
my code
the previous
> CAN mesaage.
datasheet and
anything in
and the
flush out
receive the
I'm doing
> wrong?!
> Many thanks.
> Rob.
