mp-7 is acting weird is it time for an initialization?
2006-09-04 by malik
hi,
the mp-7 is acting nutz!
1. when i press the E key on the first octave it will just start
plaingit every two bars in whatever channel i pressed it. wether the
sequencer is playing or not. no midi signals are being sent in or out. -
switching tracks stops this.
2. the data wheel jumps big time when i turn it to the right when
first touching it. when i turn left then turn right again, it usualy
goes back to normal.
3. she just froze on me! i drew the line.
is a system initialization in order? i did all the diagnostics tests i
think, they all passed. i couldnt compare the crc checks with anything...
is there anything else i should try before initializing?
if i do initialize should i back up my patterns presets and multi's?
Re: [xl7] mp-7 is acting weird is it time for an initialization?
2006-09-04 by heyrag@comcast.net
I would bet initializing is in order BUT having recently done this myself, better think through the whole back-up bit very carefully, back up beyond what you might think, seq, user setups...and the part I forgot....any special user created sounds or wave them all good bye....
Re: mp-7 is acting weird is it time for an initialization?
2006-09-04 by steve_the_composer
> wether the sequencer is playing or not. no midi signals are being
> sent in or out. -  switching tracks stops this.
Could be mechanical problem, OS problem, or user error. Try ruling out
simple stuff before reinitializing.
--Is there a trigger set up for that note?
--Try resetting to factory multisetup before reinitializing entire
machine.
> usualy goes back to normal.
Search archives for discussions on the "encoder."
2006-09-04 by malik
--- In xl7@yahoogroups.com, "steve_the_composer" <smw-mail@...>
out
> machine.
Dont think so. i know i didnt do it, probably. but the baby might
have gotten to it. will have to check that out. dont have my mnual
here.
do you know wich part of the menu i should look in?
i remember this being a famous problem. the last thing i remember is
aaron suggestiong connector cleaner... will do a search for it.
Re: [xl7] Re: mp-7 is acting weird is it time for an initialization?
2006-09-04 by Bob S.
Data wheel jump is usually an independent problem......they get dirty and need to be cleaned since they are not sealed.  Just use a good contact cleaner, I used Radio Shack 64-4315 Tuner Control Cleaner/Lubricant, sprayed into/down the top shaft after the knob was pulled off.  Also told a product called De-Ox works well.  I just cleaned 12 encoders yesterday on a Yamaha SU700 I just got....they were tight and erratic....now they feel & work like new....no skips....
Bob
El Segundo, CA
  To: xl7@yahoogroups.com
  Sent: Monday, September 04, 2006 7:16 AM
  Subject: [xl7] Re: mp-7 is acting weird is it time for an initialization?
  machine.
Silly, of course you can back all of it up via MIDI sysex.......
Bob
El Segundo, CA
  Sent: Monday, September 04, 2006 8:57 AM
  so there's no way for me to back up my user rom preset settings?
2006-09-04 by malik
cool will have to check that out
new....no skips....
> Bob
> El Segundo, CA
>   ----- Original Message -----
>   From: steve_the_composer
initialization?
start
being
ruling out
entire
>   machine.
when
2006-09-04 by Aaron Eppolito
#1 - you probably have an arpeggiator set up on that note.  either try to find it and turn it off, or just reset the factory multisetup at the end of the global menu.
#2 - yeah, the encoders suck.  all of mine jump like crazy.  like somebody said, contact cleaner is probably your best bet.  I still haven't fixed mine though.
#3 - froze how?  was it still playing stuff?  did you perhaps have a midi loop?  or perhaps jumping through list edit while recording or something (known bug)?  anyway, reinitializing won't help.
-Aaron
malik <malik_martin@...> wrote: hi,
Get your own web address for just $1.99/1st yr. We'll help. Yahoo! Small Business.
Initialization Summary
So, I just went back and took a look at the code (it's been years) and here's a rundown of what the three init methods do.
Restore Multisetup:
    reset all master parameters
        every setting in the Global menu (except tuning tables)
        every setting in the Controllers menu
         every setting in the Arp menu (except user arp patterns)
         every setting in the MIDI menu (except prog change to preset map)
     reset all channel parameters
        vol, pan, preset, arp status for all 32 channels
Init User Data except Seq:
    all of restore multisetup, plus
    overwrite all user presets with factory presets!
     erase all user arp patterns
    reset all tuning tables
    reset the program change to preset map
Init User Data:
    all of Init User Data except Seq, plus
    erase (not reset!) all patterns and songs (leaves them blank!)
As you can see, the diagnostic init methods don't do much more than restore multisetup, except that they get rid of user data like user presets, user arps, and all sequences.  They're really not meant to fix problems, they're meant to provide a way to erase all the previous owner's stuff.  Really, they're there only to provide a way to initialize the unit on the factory floor.  For all but reseting the user data, restore Factory Multisetup will do what you want (there's a reason it's called factory!)
-Aaron
Do you Yahoo!?
 Get on board. You're invited to try the new Yahoo! Mail.
Actually, you're probably in beats mode.  Check the 8th screen in the Arp menu (on the PX-7 it's labeled Arp/Beats) which is the BEATS MODE screen.  Set mode to "off" if you never intend to use the feature.  By default, it's in preset mode "P" which means if the preset you're on has an enhanced beats riff (prefixed with BTS) it will do the beating thing, otherwise it won't.  You can also define what keys do what in the next screen.
-Aaron
Aaron Eppolito <synthesis77@...> wrote: #1 - you probably have an arpeggiator set up on that note.  either try to find it and turn it off, or just reset the factory multisetup at the end of the global menu.
 All-new Yahoo! Mail - Fire up a more powerful email and get things done faster.
Thanks Aaron for the last few emails with a wealth of information.....after years I still am learning......
Bob
El Segundo, CA
  Sent: Monday, September 04, 2006 10:36 AM
  Subject: Re: [xl7] mp-7 is acting weird is it time for an initialization?
  -Aaron
2006-09-04 by malik
ditto thanks a lot. that cleared some stuff up. when i get a chance
to see if i've found a solution i'll let you know:)
> Bob
> El Segundo, CA
>   From: Aaron Eppolito
initialization?
>   -Aaron
global menu.
or out. -
things done faster.
2006-09-06 by malik
thanks.
wow such a complicated machine...
> -Aaron
menu.
out. -
things done faster.
side panels wanted
2008-06-06 by Greg Waltzer
If anyone has a pair of the side panels for sale, please contact me.
Thanks!
