John Samperi wrote:
> At 01:35 AM 26/06/2007, you wrote:
> > I don't know for certain. I was running it as the shipped sample
> >device with the shipped sample program (LEDs & Switches). I was
> >unable to read many of the registers on the device without receiving
> >error messages from AVRStudio, suggesting themy ISP vs STK frequencies
> >were incorrect, but so far as I coudl tell they were not.
> Can you got to Tools>Program Avr>Connect and then select the STK500.
> Have you ever gone this far with the STK??
Yep, been there, done that.
> If you can then first select the chip you are using from the drop down
> menu and also select ISP mode for programming.
> Then go to the Board tab, you should now see the VTG, AREF etc.
> Also the ISP frequency should be there, set it at 250KHz (or close)
> and then WRITE it. If all is well you should then be able to go to
> the Advanced tab and read the signature byte.
Likewise, been there, done that.
> Let's start with that for now.
I swapped out the 8515 for thr ATmega16L that shipped with the
STK-500. I plugged it into socket 3100A3, per the User Guide. I try
to program it with the switches&leds code, but I am still getting that
damnable box xomplaining about possible clock speed problems. It also
recommends reading help, but I don't seem to HAVE help. )-: I am
re-downloading AVRStuio 4.12, going to reinstall it and see if that
helps some
tom
