Casio CZ/ VZ/ FZ - Pro Series
Index last updated: 2026-04-28 22:42 UTC
Sysex and USB MIDI
Sysex and USB MIDI
2013-08-30 by Gordon JC Pearce
It looks like an inherent limitation in USB MIDI means that it is impossible to send sysex messages reliably.  This shows up as the inability for most USB interfaces to cope with sending a block of seven bytes like the CZ needs to kick off a sysex transfer.
It's sheer pot luck whether or not your interface will work or not.  Most won't.  There does not appear to be a workaround, because most manufacturers do not implement USB MIDI correctly and miss out the commands needed to send the trailing byte.
Gordonjcp MM0YEQ
RE: Sysex and USB MIDI
2013-08-31 by <domgoold@...>
if so,-which would be absolutelely lamentable on the part of the manufacturers concerned- this is world-shaking news(PC/USB/MIDI world, that is) roland/yamaha/korg/and other professional audio manufs will have considered it, surely? i&#39;ve been surprised by lack of consideration for sysex with some PC sequencers. it&#39;s a bit like teaching kids badly: you&#39;ve got it all now, with VST, so there&#39;s no need for you to know the fundaments. do you realise there&#39;s no &#39;soft&#39; MIDI merge app out there? how are you supposed to merge MIDI input from multiple USB keyboards? also, using that akai arpeggiator mini-kb, the timing is appalling...seems to say that USB MIDI is currently not where it needs to be. i wonder if my old M-Audio Quattro, with USB1.1 does any better? (paid a fortune for it, have hardly ever used it, unsellable, so...) --- In czsynth@yahoogroups.com, &lt;gordon@...&gt; wrote:
Re: [CZsynth] RE: Sysex and USB MIDI
2013-08-31 by jammie
some synths never implemented sysex
gem s2/s3 never had sysex so front panel editing only the alesis fusion no sysex
as for usb interfaces the midi sport range sends sysex correctly as i use them and my opcode parallel interface
i use sounddiver for my cz101 as its a great editor
but for blanket preset dumps in find that change it is the quickest utility
it has a few synths added with editors
but also has a generic conection you add your midi id channel and interface that your cz is attached and add the delay you want and then just open a sysex file and send
http://www.mossgrabers.de/Software/ChangeIt/ChangeIt.html
this is were the program is
never liked midi-ox
  To: CZsynth@yahoogroups.com
  Sent: Saturday, August 31, 2013 9:28 AM
  Subject: [CZsynth] RE: Sysex and USB MIDI
  if so,-which would be absolutelely lamentable on the part of the manufacturers concerned- this is world-shaking news(PC/USB/MIDI world, that is) roland/yamaha/korg/and other professional audio manufs will have considered it, surely? i've been surprised by lack of consideration for sysex with some PC sequencers. it's a bit like teaching kids badly: you've got it all now, with VST, so there's no need for you to know the fundaments. do you realise there's no 'soft' MIDI merge app out there? how are you supposed to merge MIDI input from multiple USB keyboards? also, using that akai arpeggiator mini-kb, the timing is appalling...seems to say that USB MIDI is currently not where it needs to be. i wonder if my old M-Audio Quattro, with USB1.1 does any better? (paid a fortune for it, have hardly ever used it, unsellable, so...) --- In czsynth@yahoogroups.com, <gordon@...> wrote:
  No virus found in this message.
  Checked by AVG - www.avg.com
  Version: 2013.0.3392 / Virus Database: 3222/6625 - Release Date: 08/30/13
2013-08-31 by Daniel Forró
Really? Right now I can't remember even simple one without this
ability...
> fusion no sysex
Manual says there is SysEx control and shows lot of SysEx commands...
> utility
Only Windows....
Daniel Forro
2013-08-31 by analogmonster@...
Casio ht6000 has no Sysex at all, annoyingly
> ability...
> > fusion no sysex
> > utility
> Only Windows....
> Daniel Forro
Re: Sysex and USB MIDI
2013-08-31 by steve_the_composer
Gee whiz. This is really going far beyond observable data.
(1) You cannot say "most" as there is no reliable database showing the results of consistently applied testing.  (If there is, please post the link. The one at MIDIBox is not the result of consistent testing--its more like anecdotal evidence.)
(2) The fact that there are many usb-midi interfaces that work successfully and consistently with sysex disproves your claim. Clearly some manufacturers have hardware, firmware, and/or software that work.  I would not call these workarounds; I'd call them the result of good design.
(3) The fact that >>some<< manufacturers can't get it right doesn't mean "it is impossible to send sysex messages reliably" via USB MIDI. My tests proved that even with a 1x1 interface (iConnectivity mio) sysex messages can be sent reliably.  My tests with the arduino communicating via usb-midi (1) to a softsynth at a higher serial rates than 31.25 kpbs and (2) to the CZ-5000 via midiox and an e-mu 2x2 interface prove that there is no "inherent limitation in usb midi" as you assert.
If my tests are flawed, please design your own tests and publish the results to support your claims.
Instead of making false, overly broad assertions, let's work together to develop rigorous testing procedures and reporting protocols so we can help people sort out the interfaces and drivers that work from the ones that don't.
Steve
> Gordonjcp MM0YEQ
really daniel forro who always thinks he is right and likes to corect everybody to his perspective
do you own an s2 or a fusion if you did you would know
i create ctrlr and sounddiver adaptions
and you cant make sysex editors for these synths
if you read the manuals you would see that they can record and send sysex from there sequencer but that is for other synths
the fusion cant read sysex for it engine as we tried to make panels and editors for them and even contacted alesis direct for the sysex manual and was told there is not one
as some one tried to make a dx7 syx conversion to fusion fm and its impossible the same as people wanted to use the micron sysex and convert to the fusion va and it cant be done as told by alesis them selfs in there q and a section
so before saying they do find out first
ax80 does not do sysex and there are many others
just because you cant think of any does not mean that they dont exist
  Sent: Saturday, August 31, 2013 11:47 AM
  Subject: Re: [CZsynth] RE: Sysex and USB MIDI
  ability...
  > fusion no sysex
  > utility
  Only Windows....
  Daniel Forro
http://promusicproducts.com/forum/phpBB2/viewtopic.php?f=2&t=1311
here is a debate on it
  Sent: Saturday, August 31, 2013 4:15 PM
  ability...
  > fusion no sysex
  > utility
  Only Windows....
  Daniel Forro
http://www.polynominal.com/site/studio/gear/synth/gem_s2/
and here is info on the gems2 no sysex
  ability...
  > fusion no sysex
  > utility
  Only Windows....
  Daniel Forro
I know a lot but not everything. I don't think I'm always right. And
when I correct somebody's mistake it's based on the obvious facts, not
on my personal opinion. That's a small difference.
I don't own them. But as I don't like when somebody just say
something, I like to check info, not just trust to anybody's saying or
writing. Because my experience is people are often lazy to check
facts, and just repeat mistakes they read somewhere.
So after reading your statement I downloaded manual for GEM S series
and  there's written clearly they have SysEx.
That's exactly what I did.
SysEx commands written in S series manual have GEM ID, so it's their
native data, not just data from other manufacturers recordable and
playable by internal sequencer.
It's possible that GEM didn't publish detailed MIDI implementation
with parameter addresses - I know more such cases (for example Yamaha
PSR9000 Pro, Korg PA80, CX3...). Sometimes it's necessary to ask
manufacturer and they send it, and sometimes they keep it secret from
unknown reason. In such case it's necessary to do reverse engineering
and private research if you need SysEx control. It's quite possible
that a person with deep knowledge and experience with SysEx can find
the format. I'm not bad in cryptology and solving similar rebuses...
That's possible, I don't know this instrument. But if I have it, for
sure I would try to find secret codes by trial and error, and on the
base of other known SysEx data formats from the same manufacturer -
usually they keep the same format for various instruments.
I didn't say they do, read carefully my message. I have written "Right
now I can't remember even simple one without this ability". Slightly
different meaning, isn't it? I'm not ashamed not to know everything or
not to be able to remember. There's a lot of other work in my life, I
haven't enough time and concentration to think about such details
right now or search relevant info.
Yes, that's possible. Thanks for this info, I will check its MIDI
implementation. And write me please which are those "many others".
Such vague statements need clarification. I have published two books
on MIDI (beside more others), such info will help me in writing the
next one.
Of course, that's obvious. And when you read carefully and without
bias my message you can see clearly I didn't say "they don't exist".
Don't add to my message what's not there.
Daniel Forro
>  ----- Original Message -----
>  From: Daniel Forró
>  ability...
>> fusion no sysex
>> utility
>  Only Windows....
>  Daniel Forro
ok daneil i await your sysex editor for both and myself and others will praise you to the ends of the earth if you can do such a thing as alesis has clearly said no sysex implementation
and i have not managed to get a clrtr panel working for either or an adaption would love to be proved wrong
as would many others as an editor would make patch creation qucker than diving through menus
  Sent: Saturday, August 31, 2013 5:08 PM
  next one.
  Daniel Forro
  > From: Daniel Forró
  > ability...
  >> fusion no sysex
  >> utility
  > Only Windows....
  > Daniel Forro
Re: [CZsynth] Re: Sysex and USB MIDI
2013-08-31 by Gordon JC Pearce
There's no need to devise tests.  As the protocol stands, there is no way to send arbitrary length data without a terminating 0xf7.  This means that you cannot use USB MIDI for reliable sysex dumps with anything that expects bidirectional traffic.
Gordonjcp MM0YEQ
i would recomend the fusion it is a very good synth/sampler
has a nice va which is different to the ion/micron/miniak
it has a good fm synth which can be routed like a dx7 but you can route it how you like
and has some realtime controls
the sampler engine is good with multivelocity keymaps and a big sample ram
the physical modelling synth is great to
i like to do sample libraries on cf cards which you can access from the cf slot
its a great machine and they are cheap second hand
  Sent: Saturday, August 31, 2013 5:16 PM
  next one.
  Daniel Forro
  > From: Daniel Forró
  > ability...
  >> fusion no sysex
  >> utility
  > Only Windows....
  > Daniel Forro
Right now I have downloaded manual for Fusion, and in almost 300 pages
reference manual there's only simple MIDI Implementation Table,
slightly disappointing. BUT: it says clearly that synthesizer section
transmits and receives SysEx. So where's truth?
I can't believe that such instrument hasn't detailed MIDI SysEx spec.
Just impossible. Despite the fact that whole manual doesn't mention
anything like parameter control or even memory bulk dump.
Don't expect such editor from my side, I don't have this instrument,
and prefer making music, not programming editors. But just as a
challenge, if I can have this instrument in my studio for some time,
for sure I would attempt to find data format.
Daniel Forro
Yes, I agree, I didn't know it, and I'm pleasantly surprised after
quick going through the reference manual now. Virtual analog, freely
programmable six oscillator FM, and even two physical models of wind
instruments, plus much more - that looks pretty good.
I would just be afraid about the reliability - unfortunately Alesis
products haven't so good fame concerning this...
Daniel Forro
> sample ram
> the cf slot
yes we were very disapointed when we found out that we could not control via an editor
it does mention sysex control but no details
i think it would of been implemented but poor sales stopped production of this great instrument
as it is the ion/micron/miniak have more filter options for the va
it amazed me that the alesis other va synths are not compatible program wise
and having a usb interface which could have been used for control with say a bcr2000
but its fixed for hd control only
and yes the manual is misleading when it says the synthesizer section transmits and recieves sysex when in truth it does not
i think because it has a massive hd that it though dumping of data was not needed i have a 80gb drive on mine and both synth engine a and b have 192mb ram
you can get some great sounds as in mix mode you can layer lots of patches together as 1 preset
i also love the s2 i have 2 1 with turbo and 1 without and it has a very nice polyat keyboard and is great for adding single cycle multisamples
it also has a nice featurew for the drums as you can sink an lfo with the drum hits and it makes them thud great for bass drum hits and 808 sin sustain drum sounds
  Sent: Saturday, August 31, 2013 5:43 PM
  Daniel Forro
HUH?
"you cannot use USB MIDI for reliable sysex dumps with anything that expects bidirectional traffic."
This actually proves that bi-directional communication using usb-midi is more reliable than bi-directional human communication.
As I understand the phrase "reliable sysex dumps with anything that expects bidirectional traffic," your statement that "you cannot use usb midi for reliable sysex dumps with anything that expects bidirectional traffic" is a totally false statement.
However, as you understand that phrase, clearly you believe it is 100% true.
Ergo, there is no way we can communicate.
To each of us the other is wrong. Fortunately, the testing I did proves that using usb midi, I did reliable sysex dumps with the CZ which definitely expects some handshaking (bidirectional communication). I am comfortable with that.
Again, if you can produce any testing to verify your broad sweeping claims, I am willing to listen.
Steve
Okay, so how are you sending the initial seven bytes?
Gordonjcp MM0YEQ
See comments below.
Steve: I thought it was me that is always right and likes to correct [not corect] people to understand and and agree with my pespective.  :P
Steve: Do you program using Lua? Also, what name do you use in the ctrlr forum?
Steve
Can you be specific--what 7 bytes?
Did I use those 7 bytes in the tests I previously reported?
If not, why do you want to send the CZ random 7 bytes?
You can send any synth any bytes you want, but depending on the firmware, the synth may or may not respond.  For example:
Colorless green gas flies furiously.
That might mean something to one person and be total nonsense to someone else.  By the same token, 7 random bytes might mean something to one synth and it might mean absolutely nothing to 1,000 other synths.
Steve
> Gordonjcp MM0YEQ
jhulk i use in the ctrlr forum
and i built a generic 14bit cc panel for the bc modular for the scope system
it sends out all the available 14bit cc messages for very smooth control
https://www.dropbox.com/s/d22zbjjdbidv1x3/ctrlr%20panels.zip
these are the exe and the bpanels for use in .dll
you can use this with bcmodular or you can use it with any synth that responds to 14bitcc as its a generic device
you can label the modules to the actual control
theres the bcmodular version
these are also tied to the bcr2000 so that you can use it as a external controller
and theres a version thats very bright for dark places
i have a friend who plays live in vegas and he uses this for modular fx for his live gigs so that he can control his fx with very fine precission
  Sent: Saturday, August 31, 2013 8:37 PM
  Subject: [CZsynth] Re: Sysex and USB MIDI
  See comments below.
  Steve
  Version: 2013.0.3392 / Virus Database: 3222/6626 - Release Date: 08/31/13
and yes im lazy with my spelling and if i make mistakes i cant be arse to check
as it does not bother me like some people but hey lifes to short
  Sent: Saturday, August 31, 2013 8:44 PM
  Subject: Re: [CZsynth] Re: Sysex and USB MIDI
  See comments below.
  Steve
"the Fusion doesn't have sysex implementation that would allow it to work with commands for a remote MIDI editor."
But is the Fusion capable of doing bulk data dumps one patch at a time or even as a bank of patches? If so, you can create an editor that assembles the patch (or bank of patches) and then sends it to the Fusion.
If the Fusion has absolutely no sysex implementation at all, then you would be right. As for using ctrlr, I do not do lua programming so I cannot comment on whether or not you can assemble a preset byte at a time and then transmit it. From what little I have read, I am inclined tho think you can since I believe you can label and reference each item within a sysex dump. Again, my knowledge of ctrlr is very limited. Ask atom.
Steve
>   From: jammie
>   From: Daniel Forró
>   ability...
>   > fusion no sysex
>   > utility
>   Only Windows....
>   Daniel Forro
Thanks for the background.  I have not done anything with ctrlr in weeks and am not sure when I will get back to it.  The only thing I have done so far is a little panel to turn 16 arps on and off in the E-Mu Proteus line with sliders to control relative volume with CC11. Its just one way--midi data out. It was just a way to teach myself how ctrlr worked. When I go there, I will check out your panels--not that I could use them, but I am always interested in learning new stuff.
Steve
>   From: steve_the_composer
>   See comments below.
>   Steve
no it saves data to hard drive or usb external or cf card
in the manual it states that it sends and recieves sysex but when changing params do sysex data is sent to the midi outputs so you can not record the strings
other wise i would have done it by trial and error but because it sends no data at all then you fcukde
it does recieve midi messages so you can set the internal settings to do real time control but for editing at the highest level to simplify the patch process so you dont have to keep change menu and to do it on a screen like in adaption or a ctrlr panel is much easier having all data in front of you
it makes my life very easy when programming my sy99 t1 01w d550 and many others which are just a pain todo from the front screen
and its easy for copy and pasting params saves a lot of time
the ctrlr is great for real time control in a vsti enviroment visually being able to see all control elements and real time controls is great and really brings out synths that are just impossible to do with tiny lcd screens
the kawai k3 is a great example there not a lot of real time control knobs like on the old analogs as they went to parameter and switches and only being able to do 1 realtime control as it only does 1 param at a time
but having a ctrlr panel so that you can change many params at a time via a control box mine is the korg pad control and the bcr2000
and with these i can control parts of my synths that i cannot usually use
like for instance on the ensoniqs vfx and samplers and the ts range you can do vector synthesis but because there is only 1 external control you cant use a joystick from a wavestation or prophet vs
but with a ctrlr panel you can as you set the external controls to control the panel but the outputs can then be sent to the synth to what you can program them to so the vector synthesis xy joystic 16/17cc i can still use one of the cc 16 or 17 but for the x or the y i need to use a controller that the ensoniqs will respond to internally and externally so
i reroute either 16 or 17 to data which is midi cc6 i can then progam the synths internally to crossfade to these controllers and use any synth with a x/y control to control vector synthesis on the ensoniqs via the ctrlr panel
  Sent: Saturday, August 31, 2013 8:54 PM
  Steve
  > From: jammie
  > From: Daniel Forró
  > ability...
  > > fusion no sysex
  > > utility
  > Only Windows....
  > Daniel Forro
my panels are not up on the ctrlr site as there was a problem uploading panels apparently thats sorted now but ctrlr is all trial and error as there is no proper manual they have recently done some guides
but you need to understand midi hex and sysex strings and be able to read sysex string and add the correct data for set params
it gets even more complicated when doing 14bitcc as there are a few different manufacturers standards
and you have to send 2 7bit strings
i did in in sounddiver to butr in ctrlr you can create your own knobs and panels where in the sounddiver the objects are just plain
  Sent: Saturday, August 31, 2013 9:00 PM
  Steve
  > See comments below.
  > Steve
It's in the protocol.  You start a transfer with:
F0 44 00 00 7x yy pp
where x is the MIDI channel, yy is the command byte and pp is the patch number.
The CZ will respond with:
F0 44 00 00 7x 30
and you respond with:
7x 31
Now, if you send f0 44 00 00 7x yy pp 7x 31 all in one go, USB can handle that because it is (purely by coincidence) a multiple of three bytes - but it crashes the CZ.  Sometimes you get valid patch data, sometimes you get garbage, sometimes you get to do a full reset and clear the RAM.
This doesn't happen if you wait for the request from the CZ.
Gordonjcp MM0YEQ
I always make typos myself, so I understand when others make them, too. Its the broad, sweeping, unsupported, and untrue generalizations that people post which I feel should be corrected, lest someone read them and accept them as true, and maybe make decisions based on them.
I maintain an active presence in a couple of gear-specific forums and when people have trouble doing things, I like to see if I can figure them out. Some people like doing crossword puzzles, sudoku, etc. Well, I like solving challenges related to gear I am familiar with.  That's why I spent the time trying to solve the CZ sysex/1x1 usb-midi interface issue.
Clearly, not everyone enjoys the challenge of systematic exploration of issues. I get that.
I am usually rather probative, saying things like, "as I understand it . . . ," "I could be wrong . . .," "here's what worked for me," "have you tried . . . ," "one thing I have found, is . . . " etc.
However, when I go so far as to design a test, spell out the steps I took, and report my results and conclusion, I usually do it without using the probative wording and caveats.
Apologies if I seem to expect the same standards from others that I expect of myself.
Steve
I will have to compare what you wrote with what I did. I am inclined to say, that's what I did and it worked and it has worked every time with every interface I used.
But maybe there is some difference in what you are saying and what I did.  I will get back after a comparison.
Steve
> F0 44 00 00 7x 30
> 7x 31
> Gordonjcp MM0YEQ
thats why many minds are better than one as some will perceive one way and others another and some just cant get it
but by lots of people adding support a bigger general picture can be seen and then
a more accurate visualization hopefully then will make things easy for others
im great at sampling and make many libraries with good loops while others strugle
same as patch creation lots of people struggle and why in the 80,s 90,s there were programmers of presets as the players who are very good musicians where just not good at programming
and all they wanted todo was perform
  Sent: Saturday, August 31, 2013 9:37 PM
  Steve
Thanks for the clarification. In fact, I downloaded your panels from the dropbox immediately after replying before. (I have not unzipped them yet; looking forward to it).
I think atom has done a great job with ctrlr, but I think he needs someone who can write manuals for users, not programmers. I have done some programming and understand midi quite a bit (including sysex), but I have found that I have to struggle to try to think how he is doing things. He is great though at writing up examples to help people with their tasks. They just need to know how to reverse engineer what he has done.
Unfortunately, I don't know lua and I don't have the ability any more to learn a new language (or programming environment). To do anything deep with ctrlr, you need to get into lua from what I can tell. That's why I was asking if you knew lua.
Steve
PS: I am so glad you call them sysex strings. For the longest time I could not figure out why he calls them formulas. I have never seen sysex strings or sysex commands called formulas before. Have you seen them called formulas anywhere else?
>   Steve
>   > See comments below.
>   > Steve
no its a language thing i suppose
and why people get confused if it was called formulas from the bigging then it would not be a problem
but it is confusing when manufacturers use the sysex string terminology
and thats what it says in  the manual a sysex string
  Sent: Saturday, August 31, 2013 10:05 PM
  Steve
  > Steve
  > > See comments below.
  > > Steve
OK. I did the comparison. I used these posts:
GORDON = http://launch.groups.yahoo.com/group/CZsynth/message/5928
STEVE = http://launch.groups.yahoo.com/group/CZsynth/message/5876
I have written some observations about the comparison.
Executive Summary:
1. I did exactly what you said needs to be done.
2. I successfully achieved what you said couldn't be done.
GORDON: It's in the protocol.  You start a transfer with:
> F0 44 00 00 7x 30
> 7x 31
STEVE:
F0 44 00 00 70 10 60 70 31 F7
The 6th byte [10] is the code to request the CZ send a patch. The 7th byte [60] tells the CZ to send the data from the Sound Area. The 8th and 9th bytes [70 31] are an acknowledgement from the PC to the CZ to continue after after the CZ sends a dump header:
F0 44 00 00 70 30
Once the CZ receives the 70 31 from the PC the patch (aka tone data) is sent with a final F7 byte.
Notice the 6th byte is now 30.
In order to send that data back to the CZ, you need to change that 30 to a 20 and then >>INSERT<< a byte to tell the CZ the destination.
GORDON:
STEVE'S OBSERVATIONS:
In my previous posts (including the one cited above) I used the required sysex header to request data. I did in fact use the sysex string "all in one go," the usb-midi interfaces I used handled it, and the CZ did not crash.
Perhaps the only thing I did not test is sending patch data back to the CZ.
So, to test this I will play the midi files with patch data that goes to the sound area ( http://launch.groups.yahoo.com/group/CZsynth/files/CZ%20-%20Sounds.../Dr.%20Steve%27s%20%20Patch%20Test%20Files/ ).
If the sysex data gets corrupted on the way out from the computer through the usb-midi interface to the CZ, I will admit that you are right. If I have no issues, are you willing to test all of your usb-midi interfaces?
Then perhaps we can start compiling a table of interfaces that work with the CZ and those that don't work with the CZ? Maybe others will test theirs and share their results.
Steve
> Steve
> > F0 44 00 00 7x 30
> > 7x 31
> > Gordonjcp MM0YEQ
2013-09-01 by Gordon JC Pearce
> Executive Summary:
I can't read either of those messages, because the Yahoo! Groups site appears to be pretty badly broken right now.
What exactly did you do?  I find that if I send everything in one go, the CZ-1000 crashes every time.
Gordonjcp MM0YEQ
2013-09-01 by steve_the_composer
GORDON: > I can't read either of those messages, because the Yahoo! Groups site appears to be pretty badly broken right now.
STEVE: As for not being able to read messages, perhaps there is a problem with your computer. I recommend getting messages as a digest. That way you can re-read posts.
For your convenience, I have copied the referenced STEVE post in its entirety below. (The part which you deleted in your reply was only a part of that.)
GORDON: > What exactly did you do?  I find that if I send everything in one go, the CZ-1000 crashes every time.
STEVE: Once you figure out the problem you are having with the website take a look in the files section for the folder named "Using Midi-Ox with your Casio CZ." Those are the screenshots that go with http://launch.groups.yahoo.com/group/CZsynth/message/5876.
Out of curiosity, which interface(s) are you using (and what computer/OS/SP)? If you are using one of those really bad 1x1 usb-midi cable interfaces, that might be your problem.
Also, if you are simply capturing a patch dump and trying to send it to the CZ unchanged, that will not work.
If you want me to test some short sysex strings on my CZ-5000, I can give it a try.  If you have some patch dumps, load them to a temporary folder and I can give those a try.
Steve
http://launch.groups.yahoo.com/group/CZsynth/message/5876 follows:
> Even if its a moot point, I decided to test a usb-midi interface cable. I opted for the iConnectivity mio. [It probably stands for midi in/out.]
> The test was on an HP 64-bit Win7 SP1 laptop with an AMD Phenom II P650 Dual-Core Processor 2.60 GHz. (Not as fast as this year's models, but light years ahead of what was common in the 1980s.) I used midi-ox with default settings, with no delays added between bits or bytes.
> I did three tests:
> (1) Receive and then send Glide sysex
> (2) Request Sequencer Dump
> (3) Request Sound Area Dump and then sent it back to the CZ.
> I have screen shots, which I will post when I am not so tired. I need to draw a few things on at least two of the shots and write up some explanations.
> Two important points for the moment:
> (1) With the dump requests, I changed the keyboard to MIDI = 8. However, I set the sysex request using 70 [channel 1]. It worked.
> (2) The patch dump needs to tweaked before it is sent back to the CZ.
> It will probably be easier to see when I post the screen shots, but basically here's a description. Consider this send request where the computer requests the CZ to send the patch data from the Sound Area:
> The 6th byte [10] is the code to request the CZ send a patch. The 7th byte [60] tells the CZ to send the data from the Sound Area. The 8th and 9th bytes [70 31] are an acknowledge ment from the PC to the CZ to continue after after the CZ sends a dump header:
> F0 44 00 00 70 30
> In my case, I changed the header in the dump I received as follows:
> F0 44 00 00 70 20 60 .
> The 20 in the 6th place of the sysex command tells the CZ that data is coming. the 60 in the 7th place tells the CZ to put the data in the Sound Area.
> You cannot just send the data that was received from the CZ back to the CZ.  Without the 20 and the destination, the CZ will not know what to do with the data.
> I am not sure if that provides the missing link to solve the original problem. The resending of the Glide mode change does not need to be changed like this. Not sure why it didn't work with the Hosa usb-midi interface cable.
> In sum, on my modern laptop, the iConnectivity mio successfully received and transferred a short sysex command and a single patch dump using midi-ox without inserting delays.  Needless to say if I were writing a midi patch librarian program to receive and send 32 or 64 patches I would have a delay between each dump send.
> Also, if I were making a midi file of 16 or 32 or 64 sysex dumps to send to a CZ, I'd space them a bit in the file so there is some separation between them.
> By the way, when I requested the sequencer dump, I inserted 7 sets of 70 31 acknowledgement byte pairs even though for the sequence I had in the CZ two would have been sufficient.  There was no ill-effect from sending the CZ too many "go ahead" commands. Once the CZ sent the F7 to say the sequencer dump was done, it seemed to ignore those bytes.
> However, I was not doing the dump and performing at the same time. If someone else wants to see what happens when they do data transfers at the same time as sending copious amounts of performance data, be my guest. I think Casio's infamous F7 screw-up might produced unpredictable results. I don't do bulk data dumps while performing and its not a cutting edge technique I want to explore.
> (On the other hand, I have explored putting in data that is outside the range of acceptable parameters. But that's a different can of worms.)
> Hope these tests and explanations helps someone, sometime.
> Steve
> I did three tests:
> F0 44 00 00 70 30
> Steve
> --- In CZsynth@yahoogroups.com, "steve_the_composer" <smw-mail@> wrote:
> > With all of the side issues, I am wondering if you are still stuck with the CZ not responding to sysex.
> > I called my local Guitar Center and found I can buy a usb-midi "cable" and return it for full refund withing 30 days.  They have one that is open, so I won't feel bad about returning it.
> > If you are still trying to get the bulk data transfers to work, I can stop by Guitar Center and run the same tests I described. Let me know.
> > Executive Summary:
> Gordonjcp MM0YEQ
Steve
> I did three tests:
> F0 44 00 00 70 30
> Steve
> I did three tests:
> F0 44 00 00 70 30
> Steve
> > Executive Summary:
> Gordonjcp MM0YEQ
I get individual mails.  I can't get on the Yahoo groups website at all at the moment.
Well one of the "problematic" ones is an E-Mu 1X1, but for the most part it works better than all the others.
Is there one in particular you recommend?
Maybe a CZ5000 is different.  With my CZ1000, sending:
F0 44 00 00 70 20 00 70 31
sends it off into la-la land instantly, most times.  This happens with all the interfaces, including a "real" MPU401 type (which *does* deal with sending individual random bytes).
Gordonjcp MM0YEQ
Let me ask: Are you saying this is the sysex header for the pach data the CZ1000 sends to the computer?  Or are you saying this is the header you use to send the patch data from the computer to the CZ?
[snip]
[snip]
2013-09-01 by charlie midi gfa
try this one
F0 44 00 00 70 10 00 70 31
charlie
To: <CZsynth@yahoogroups.com>
Sent: Sunday, September 01, 2013 5:55 PM
> [snip]
> [snip]
2013-09-02 by Gordon JC Pearce
Command 0x20 tells the CZ to start receiving patch data.  Commands 0x10 and 0x19 tell the CZ to send data.
If I send command 0x20 to the CZ it does actually dump data that appears to be correct, but if I send 0x10 or 0x19 it crashes.  In my previous email I'd pasted in the string for getting it to send data, which was incorrect.
Gordonjcp MM0YEQ
2013-09-02 by steve_the_composer
The CZ-5000 doesn't have the same Send Request 2 (command = 0x19). It has a Send Request 2 to get sequencer data (command = 0x14, memory location = 0x61). I am not sure if I tested the 0x14 command with the midi-us, but I did with WinXP SP3. (It worked.)
Do you send F0 44 00 00 70 19 00 70 31 F7 when it crashes? I know the MIDI Guide book says the dummy data (7th byte) should be within 00 ~ F7, but that has to be a typo.  At most it should be 00 ~ 7F.
When I do a sequencer data request I can chain at least six 70 31 acknowledgement pairs in the request without any ill effects. Perhaps the CZ-101/1000 can't handle the 70 31 F7 before it send out the data. Since I don't have the 101/1000, unfortunately I cannot test that command with the midi-usb interfaces I have.
Since the 0x19 command is just for getting programmer data (the patch selected) and effect data (vibrato and portamento on/off states). I don't think its a big loss if it doesn't work, though it might be handy for you to have.
The bigger problem is the 0x10 command. If that doesn't work, you cannot request and receive dumps from the CZ. Are you sending F0 44 00 00 70 10 60 70 31 F7 and getting a crash instead of receiving the data dump?  If so, perhaps it is that the 101/1000 cannot make use of the 70 31 F7 being sent with the first part of Send Request 1.  I believe I read that it is supposed to work with the CZ-101/1000, but maybe not.
It occurs to me that maybe the 1x1 (and its driver) are not really full duplex. It might be that the driver (or firmware if it has any) gives control to one channel (in or out) when a F0 is transmitted and that channel keeps control until a corresponding F7 is received.
I have no way to test that.
With the receive request (command = 0x20 + memory location), it wouldn't matter that the interface doesn't send the F0 44 00 70 30 to the computer, EXCEPT if its presence somehow presence prevents the CZ-101/1000 from receiving all of the Tone Data from the computer. If that were the case, I'd expect a lock up or corrupt data. However, you said you have been able to send tone data to the CZ successfully with the 0x20 command.
With my sequencer (Cakewalk) it wouldn't be possible send the different parts of the handshaking requests (header, ack, F7) individually since each bank (what Cakewalk calls a stored sysex command) requires an F0 F7 pair. I am not sure they can be sent out individually with midi-ox or any other utility.
In sum, it might be a problem with the specific 1x1 usb-midi interface cable, or it might be something unique to the CZ-101/1000, or perhaps as I suggested in an earlier post, perhaps over time components in the CZ age and their abilities start to fail.
While I hope this helps, I am thinking the best way to try to solve the anomaly it is to try other interfaces. I don't know anyone with a CZ-101/1000, otherwise I'd be very interested to test it.
Steve
> Gordonjcp MM0YEQ
This confirms that there must have been issues with the Yahoo! server. This message is a duplicate of one I had to send a second time because the first time it did did not show up in the message list. This one must have gotten gobbled up in cyber space and was regurgitated roughly 12 hours later!!
Steve
> Steve
> > I did three tests:
> > F0 44 00 00 70 30
> > Steve
> > I did three tests:
> > F0 44 00 00 70 30
> > Steve
> > > Executive Summary:
> > Gordonjcp MM0YEQ
Message 5947 [the first time I sent it]
sent Sun Sep 1, 2013 4:23 pm
posted Sun Sep 2, 2013 4:49 am
[posted over 12 hours later]
Message 5942 [the second time I sent it]
sent Sun Sep 1, 2013 4:31 pm
posted Sun Sep 1, 2013 4:31 pm
On reflection, I suppose it might not have been caused by Yahoo servers. It could have been a major internet traffic/routing issue independent of Yahoo. I am not enough of a conspiracy theorist to believe the delay was caused by internet cyberwars. :P
> Steve
> Steve
