Hart dropouts
Hart dropouts
2004-12-12 by vl2000_us
Well, I had previously posted here that after much experimentation
with various rejection settings, etc. I had just about decided that
tightening the Hart mesh heads a bit tighter solved the occasional
dropped hit.
I'm no longer positive thats the final word.
We had a focused rehearsal yesterday that i set my volume waaay down
for so two of the string players could work out some parts.
At one point i got a little 'into it' and struck the snare pretty
hard and I'm pretty sure it dropped out.  I couldn't reproduce it
however, so I'm a bit unsure.
To that point, I was pretty sure the 'over tightened heads' had
solved the problem, but not 100% sure now.
We have rehearsal again today, so I'll get another opportunity.
Has anyone else experienced this issue and found the holy grail
solution?  I think I'm close, but thats just not 'good enough' for
me :-)
vlus
Re: Hart dropouts
2004-12-12 by peterpan
Thanks for the update, I'm considering going with the DTXtreme II
brain for my Hart kit & would really like to see how you get on. You
should also try posting in the Yahoo HartDrums group, maybe some of
those members might use the DTXtreme II with their kits.
Good luck  :)
> dropped hit.
down
> me :-)
> vlus
Re: Hart dropouts
2004-12-13 by drumsonly2002
I have had the dreaded drop out problem with my DTXTreme-2. I am a
hard hitter and my snare was dropping notes.  With the xtreme rubber
pads there is an adjustment for the pad, a small black dial on the
back. I had it turned up, thus making the peizo hot. It was
recommended to have it turned down. After turning it down no
problems what so ever. My theory is the Hart pads are too hot, and
somehow the note gets dropped when playing hard. If the pizeo could
be "turned down" somehow, and lessen it's strength, I think that
will cure the snare dropping out problem. Believe me when I say
initially that problem was very annoying esepically live. Turning my
adjustable pad down cured it. I hope this helps. As far as
triggering goes with the dial turned down, every single note light
or hard gets played. Amazing dynamics. I had my kit running through
2 x 400 watt powered speakers and a sub and no problems with
dropping notes.
Re: Hart dropouts
2004-12-13 by copeg100
I am having the same problem with my DTXpress III. I only use the
snare pad TP56S when playing live, but i'm not a hard hitter, it
just cuts out the odd hit during a song. The pad does get set off by
vibration and I wondered if there is a setting or something I can
adjust? I pretty new to it all...but I'm guessing perhaps the
triggering through vibration is occuring at the same time that I am
striking the pad?? I'm just a little confused with these 'rejection'
settings. Do i need to be adjusting these maybe or the gain levels?
Can anyone help?
Grahame
rubber
could
my
through
> dropping notes.
Re: Hart dropouts
2004-12-13 by vl2000_us
What is the group name for Hart?  I post here because the core of my
kit is the DTXtreme brain w/5 yam pads.  The Harts were add ons.  We
had a reheasal yesterday.  My volume was a little lower than usual,
and I had one drop out hitting the beginning snare crack for Breaking
the Law.  It seems the drop outs only occur during what might be
considered an extra hard hit.  Today I plan to tension the snare head
just a little more.  I am also interested in hearing from anyone else
having similar problem with Hart or Roland mesh heads.
For the record, if I turn my volume up and play less aggressively I
NEVER experience a problem, but its just a little too loud then for
stage volume.  This may just be a matter of continueing to experiment
with volumes, gains and velocities, etc.
vlus
Get fast, affordable hosting for your band or business for pennies a
day at http://www.Web-Hostess.com!
You
> Good luck  :)
experimentation
that
occasional
> > dropped hit.
> down
for
> > me :-)
> > vlus
Re: Hart dropouts
copeg....
It sounds like the problem you are experiencing might be more related
to rejection settings and therefore more easily solved.
A couple steps you should take are:
a) locate the source of the vibration and fix if possible (ex: two
drums touching, cymbal stand touch drum, etc
b) it might also be one of the othe e-drums triggering the snare.
Hit the trigger button on your brain and strike the snare to bring
the pad number to the snare channel.  Now, make a single hard strike
on each tom pad and watch the brain.  If you hear the snare trigger
after a tom strike, the offending tom pad number will now appear in
your brain.  Go back to the snare settings and turn up the 'specific
rejection setting' against that tom channel
c) general vibrations triggering set with the middle rejection
setting, although your best bet is to find the source and fix.
d) as a last resort tweak the self rejection.
Hope that helps, now off to RE-read the post before yours... someone
has my curiousity up regarding maybe a gain setting...
vlus
http://www.MonstersOfRock.info
Get full featured, cPanel web hosting from $1.99/month from www.Web-
Hostess.com!
by
these 'rejection'
> Can anyone help?
> Grahame
a
> rubber
and
> could
> my
light
> through
> > dropping notes.
Re: Hart dropouts
Drumsonly....
Interesting... sounds like 'gain' setting.  I have experimented
somewhat with the gain, but was more focused on rejection, head
tension, etc.
I will try some experiments over the next day or two with gain
settings and will post back to the list.  I DO have my gains set
pretty 'hot' on the Hart pads, so you may be on to something.  With
another practice Tuesday night, I should have results by Wednesday.
Thank you for sharing your experience!
vlus
Get your own website hosted for as low as $1.99/month at
rubber
my
> dropping notes.
Re: Hart dropouts
2004-12-13 by peterpan
I think it may definitely be something gain orientated, I remember
reading somwhere else (can't remember where) that the pads shouldn't
be too hot with the xtreme II.  Good luck with it all, hopefully
you'll have some good news on Tuesday.
The Hart group:
http://launch.groups.yahoo.com/group/Hartdrums/
I asked a couple of days back if anyone is using the xtreme II, no
joy as yet - you are the only person I've come across with this
combination so far - keep us posted!!
my
We
Breaking
head
else
experiment
> vlus
a
> You
of
> > Good luck  :)
> experimentation
> that
> occasional
> > > dropped hit.
> > down
pretty
it
> for
> > > me :-)
> > > vlus
Re: Hart dropouts
2004-12-16 by vl2000_us
OK, here is where things stand with the drop out issue.  I pulled the
gains down pretty substantially on all the Hart drums.  Right now
most of my programmed kits have gain set as follows:
Yamaha toms 1 thru 4: all set at 32
Yamaha Snare: mostly set at 45, some kits its higher because I use
that snare mostly for special snare voices, special F/X, etc
Hart toms: 7 of them (8 thru 12 inch) set at 35 with very tight heads
and one of the 8 inch toms is set to 48 because it just seems less
sensitive than the others
Hart Snare:  this is my main snare and is now set at 45
I've not changed any of my rejection settings at this time and still
have all heads very tight.
Output volume from the DTXrememe IIs brain has been raised to
compensate for the lower gain settings.
Tuesday nite practice no dropouts, but we were at a lower volume
overall.  Sunday we have practice with our male frontperson, and we
are usually louder cuz he's half friggin deaf :-)
Any remaining dropouts should surface sunday.  Will report back
then.  I do think this gain may have been an important part of the
solution, along with rejection settings, head tension, etc.
Good luck everyone...
vlus
Host your band or business for less ...guaranteed!  30 day FREE
Trial!  See http://www.Web-Hostess.com for details or ask vlus!
shouldn't
> The Hart group:
Re: Hart dropouts
2004-12-16 by peterpan
Thanks for the update, hopfully this will have solved the problem..
Good luck for Sunday!
heads
still
> vlus
remember
> shouldn't
> > The Hart group:
no
