Used DTX1 module wanted
2003-03-19 by brown8700
Hey guys:
Well after much consideration, I've decided to go the route of adding
another DTX I module rather than a MIDI device to get more triggers.
I've searched the normal (ebay, Drumbalaya, Drummer's Web, etc.)
places for a used DTX but can't seem to find one.
Anyone have any other sources I might try?
Thanks for any suggestions,
Stephen
p.s. The Music store next door does have a DM5 I'm considering
grabbing if I can't find the DTX.
Re: Used DTX1 module wanted
2003-03-19 by liberatusvirus
Good morning, Stephen,
Is it a used DM5? Then it should cost around the ballpark of a used
DTXPU. Even the new ones are only $300 bucks or so. It doesn't have
all the amenities of the Yamaha (though thankfully some of its
programmed sounds come with effects), but you've already got those.
It does have some nice features of its own, though, like 18 bit
processing and voices recorded in true stereo. Why not grab it?
Also, just for the record, Jade's midikiti is available, not because
it's too difficult to use (the tip from Yamaha solved that problem)
but because unforeseen expenses have cropped up.
Ed
--- In DTXpress@yahoogroups.com, "brown8700" <brown8700@a...> wrote:
> Hey guys:
adding
triggers.
> Stephen
Mornin' Ed:
Yes, the DM5 is used but in good shape with the asking price of $229
with adapter and manual. I've seen them new at MF for $349.
I considered the MIDI approach but fear my learning curve may be too
great. I barely find enough time to play, much less program. If it
comes to that, do you know what the asking price for Jade's KITI is,
if it's still available?
Stephen
Jade's "midi kiti" is currently on ebay:
http://cgi.ebay.com/ws/eBayISAPI.dll?
ViewItem&category=10175&item=2515561560&rd=1
But I know that Jade will entertain outside offers, especially if
the auction doesn't pick up steam in the next five hours or so when
it ends. I also know that someone else out there has contacted Jade
and is waiting to see how the auction goes before pouncing to make a
deal.
> Mornin' Ed:
$229
too
is,
> Stephen
Re: [DTXpress] Used DTX1 module wanted
2003-03-19 by Jade
I have a Midi Kiti for sale...it works great(once you
factory re-set the DTXII module)...I just got another
DTXII module...if you are interested-let me know
Jade
--- brown8700 <brown8700@...> wrote:
> Hey guys:
> the route of adding
> get more triggers.
> Stephen
> considering
Do you Yahoo!?
Yahoo! Platinum - Watch CBS' NCAA March Madness, live on your desktop!
http://platinum.yahoo.com
2003-03-25 by brown8700
Well, I haven't been able to find a used DTX, but I did run across a
used DM5 that will be purchasing this evening. I'm kind of excited
about the range of new sounds the DM5 offers.
I'll now be able to use the extra pads and cymbals I have, as well as
run (hopefully) 4 separate audio outs to the PA.
I'll post later to let you all know how I like this configuration.
Stephen
2003-03-27 by brown8700
I just picked up a used DM5 to augment my DTX, and I have a question
or two for anyone familiar with the DM5.
Are any of the trigger inputs of the DM5 stereo, so that they could
accept both signal from a Pintech dual zone Zenbal?
How does the HH foot pedal function with the module (which trigger
input)?
Can you layer sounds, and set velocity parameters on the second sound
as you can on the DTX?
My original thought was to run cymbals and percussion through the DM5
and the true drums sounds through the DTX. However, I didn't have
much luck last evening setting things up as I had hoped.
Any help, hints, tips or advice is appreciated.
Stephen
2003-03-27 by hairytrigger
Stephen
I sold my DM5 two years ago, but Here is what I remember.
The inputs are all mono.
There is a dedicated HH footswitch input.It is just a momentary
switch; open and closed. no in-between.
You can't layer sounds.
I used mine for triggering from acoustic drums, and a couple added
pads. For that it was excellent.What I did like was four outputs(two
stereo pairs.) I had snare on one, kick on one, toms on one and
accessories on one.
Scott
> input)?
sound
DM5
> Stephen
Re: [DTXpress] Re: Used DTX1 module wanted
2003-03-27 by MrPhoney@aol.com
There are no stereo hookups on the DM5. You would need to use a stereo adapter for the cymbal to two triggers on the DM5. The HH foot pedal gets hooked up to the FOOTSWITCH input on the very left hand side. Make sure that you have the Footswitch trigger set correctly, not as a switch.
You can download the manual for free here. You owe me one!
http://www.alesis.com/downloads/manuals/index.html
Claudio Ortiz
Claudio:
Consider yourself 'owed'. I'll play a solo tonight in your honor.
After considering all this, I think I'll run my two Zenbals through
the DM5 (using two inputs) as well as my Bar Pad (two more inputs).
I'll have to try out the HH, but it doesn't sound like I'll like the
downgrade from the DTX.
Actually, unless I am mistaken The Zenbal is a Stereo pad. It WILL NOT
work with a splitter.
stereo
gets
sure that
> <A
HREF="http://www.alesis.com/downloads/manuals/index.html">http://www.a
lesis.com/downloads/manuals/index.html</A>
> Claudio Ortiz
2003-03-27 by liberatusvirus
Scott,
You're not mistaken. The Zenbal stereo cymbal will not work with a
splitter. Shame on you, Stephen.
Ed
NOT
> stereo
pedal
> gets
Make
> sure that
> > <A
a
> > Claudio Ortiz
2003-03-28 by brown8700
"The Zenbal stereo cymbal will not work with a splitter." - Ed
And how well I know know it! Also, the DM5 doesn't have a Windchime
sound. I'm 97.5% certain thias thing is going back. The store I
bought it from had a pretty well used DTXpress set for sale. It had a
variety of pads. I originally asked the store owner (whom I know
quite well) if he would consider breaking up the set and put the DM5
on it and sell me the DTX module. He didn't go for it though.
However, when he sees me bringing back the DM5 for a cash refund, he
might reconsider.
Oh, and you ought to see the module mount (actually it's a module
mounting system, or MMS) to hold the two brains. I'll have to take a
picture of it. It added 50% weight by volume to my kit!!!!
Aha, another reason to return the DM5.
Ed, if I take the DM5 back, will I be allowed once again into the
brotherhood of DTX owners?
Stephen
2003-03-28 by Jade
I still have a Midi Kiti for sale...it will do what
you want.
Jade
> splitter." - Ed
> have a Windchime
> The store I
> for sale. It had a
> (whom I know
> and put the DM5
> it though.
> cash refund, he
> might reconsider.
> it's a module
> I'll have to take a
> kit!!!!
> again into the
> Stephen
Do you Yahoo!?
2003-03-28 by liberatusvirus
Stephen,
Yes, you can come back. You hate the DM5 as a second unit, huh?
Well, I guess if you wanted it to pull equal weight alongside the
DTXPU, I can understand it. I'd use it the way I use the midikiti--
to house percussion sounds that have a permanent, though secondary,
use in all of my kits--not to take up all the cymbals or all the
pads, first because it's all mono and second because it isn't as
versatile to program. Can't you use it as a midi device
parasitically through to the DTXPU? That is, with midi out bypassing
its own sounds, can it tap into the sounds of the DTX via channel
and note number? This is an honest question; I simply don't know if
the DM5 will work that way. Maybe someone else does.
Ed
Windchime
had a
DM5
he
> might reconsider.
a
> Stephen
2003-04-02 by brown8700
And now, the rest of the story.........
OK, so I got the DM5 set up on Thursday (4+ hours) and it sounded
great. Go to fire up the kit on Friday....no stored kits. Darn, it
must be the battery. Take the unit back to the stor to have the
battery replaced at no charge. Pick it up yesterday. Take it home and
modify one kit. Changes won't; the unit keeps resetting to factory
defaults. Take the unit back to the store this evening. The shop
owner breaks up a used DTXpress he has on the floor and swaps me even.
WooHoo!
Not only do I have the second DTX like I originally wanted, but I got
it for $125 (and 3 PCY pads). Plus, I get to stick around here.
I've got tomorrow off, so I think I'll be doing a bit of programming
before a mini-recording session tomorrow evening
2003-04-02 by liberatusvirus
Stephen,
We're all going to line up for a chance to touch the hem of your
garment and get some of your luck. Nice work.
Ed
and
even.
> WooHoo!
got
programming
2003-04-03 by Walt
Some people have all the luck!
Me, I'm stuck with stunning good looks.
Walt
> WooHoo!
2003-04-03 by brown8700
Walt, Ed:
Yes, I did get lucky on this deal. I've done business with this shop
for years, and apparently the owner knows it's better to lose a few
bucks on a deal than to lose a good customer.
When I got home last night, I had a delivery from Musician's Friend.
It was my Behringer MX602 mixer (thanks for the idea, Ratzo). Using
this, I should be able to send four seprate line to the mixing board
(1-bass, 2-snare, 3-toms, 4-cymbals/percussion). I set the two DTXs
up with those four groups panned to either the left or right side.
I'll find out tonight if that worked. It better; it's a live
situation!
My wife says I now have everything I need.
2003-04-03 by Ratzo
No problem ;-)
>situation!
I do the same with the panning bit.  Works great.
So dose mine, but I still manage to prove her wrong from time to time.
Jim
2003-04-04 by brown8700
Ratzo:
Used the MX602 last night and it worked like a charm. What I really
like about (and didn't realize beforehand), is that I can drastically
change the sound of the drums, particularly the snare.
This will come in helpful in going from a deep coliseum snare sound
to piccolo without having to change kits or voices.
Cool!
2003-04-04 by Ratzo
On Fri, 04 Apr 2003 21:12:55 -0000, you wrote:
>Ratzo:
>Cool!
Yep, it's a cool little gizmo.  I'd like to have a second one for my
PC.  I read a review from a guy who was using it to mix his inputs and
headphone/speaker outputs of his sound card.  Sounds like just the
ticket, having volume and mix controls right there next to your mouse.
Jim
RE: [DTXpress] Re: Used DTX1 module wanted
2003-04-05 by Erik@Dobbelsteijn
> for my PC.  I read a review from a guy who was using it to
> mix his inputs and headphone/speaker outputs of his sound
> card.  Sounds like just the ticket, having volume and mix
I've got it exactly there, and a step away from my kit :)
I used my PC instead of a taperecorder the tape loop of the mx, so I can
play along with an MP3, and record my humble rumble (without the MP3 :)
Grz Erik
