Re: [Digital BW] Clogs from Hell and worse....
2003-03-18 by Julian Thomas
Jerry, this all sounds like air in the nozzles to me. Try priming the system
a couple of times ( as if the inkmonitor is telling you you are out of ink -
lifting the tabs on the cart slots on the 1160 for eg) and then doing a
couple of purge images
Julian
Sent: Tuesday, March 18, 2003 6:46 PM
Subject: [Digital BW] Clogs from Hell and worse....
> To those of you following the worst clog ever,
> I put back the original epson ink cartridges. Now, there's no ink
> whatsoever coming out of any of the chambers.
> 6 blank nozzle checks.
> I'll squirt some ammonia through the nipples, and then go to dinner.
> Maybe I do indeed just have a really bad set of print heads!
> Maybe the eboni ink is NOT compatible with epson inks, but the other 5
> colors MIS VM, should be!!
> Jerry
> Please visit the Group Homepage to check the Files, Bookmarks, Polls and
page.
them short.
&amp;amp;quot;flames.&amp;amp;quot;
resources on the homepage.
2003-03-18 by keith_r_smith2003
FWIW I have seen on other threads that some inks are acid and others
alkiline, so if they mix they form a sludge which will block nozzels.
A cleaning cart was suggested.
keith
2003-03-18 by Robert Morrison
Yep...the chances of loosing all nozzles from an ink clog are very slim.
Complete dropouts are almost always a loss of priming from air in the
system.  You may just have to wait this one out.  I've waiting as much as 4
days before with a CIS.  The key is to be patient and do nothing.  Don't
even run a nozzle check for a couple of days.  The more fussing you do...the
worse it will get.
Robert
> Julian
> From: "Jerry Olson" <jerryolson@...>
>> Jerry
> page.
> them short.
> Please visit the Group Homepage to check the Files, Bookmarks, Polls and other
> page.
> them short.
2003-03-18 by Jerry Olson
I've done this many times Julian. No luck.  I reinstalled the OEM color
inks, and of course got perfect nozzle checks.
It therefore, HAS to be the cartridges, or ink. Do you know how you can
be sure which it is?
Jerry
Keith, the MIS VM inks are definitely compatible with Epson inks, unless
they changed the inks!!! And they told me the Eboni black is compatible
with the VM inkset.
Jerry
> keith
> Please visit the Group Homepage to check the Files, Bookmarks, Polls and other resources as they are often being updated. The page is at:
> - Good manners are required at all time. No personal attacks or &amp;amp;quot;flames.&amp;amp;quot;
> - Before posting a question, search the message archives and the various resources on the homepage.
Robert, I just reinstalled the Original Epson color inks.  Perfect
Nozzle checks. Now what?  It can't be the printer, so it must be the
cartridges or inks.
I'm ready to give up. I'm sitting here with what appears to be a
perfectly loaded CIS system. No air in the tubes, the vacuum appears
perfect. I've sealed up the bottoms with electrical tape, which seems to
be holding for now...
Jerry
> worse it will get.
> Robert
> > Julian
> >> Jerry
> > page.
> > them short.
> > page.
> > them short.
when I've had cis head problems I've pulled ink through the cis heads and
left it stand for a few days before touching it.
Julian
Sent: Tuesday, March 18, 2003 9:02 PM
Subject: Re: [Digital BW] Clogs from Hell and worse....
> Jerry
system
ink -
page.
them short.
Put the CIS back in, run two cleaning cycles and then turn the printer off
and let it sit for at least two days...if not longer.  I'd recommend 4 days.
You probably have microbubbles in the ink in the CIS cart from all of the
cleaning and nozzles checks.  After you wait, then run a nozzle check.  If
you get any nozzles to fire, then run several flush images.  If you don't
get any nozzles then I'd recommend changing the cart again.
Robert
> cartridges or inks.
> Jerry
>> worse it will get.
>> Robert
>>> Julian
>>>> Jerry
>>> page.
>>> them short.
>>> other
>>> page.
>>> them short.
>> page.
>> them short.
> page.
> them short.
2003-03-19 by jim hayes
Forgive me for jumping in the middle of a thread (I've been away
awhile), but you could always suck the ink out the bottom of each cart
chamber of the CIS and return it to the bottle until the ink runs
clear and no foamy bubbles are apparent in the syringe. Use a syringe,
and if possible, a bottom fill adapter from MIS.
Jim H.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Robert Morrison
printer off
4 days.
of the
check.  If
don't
> Robert
> > cartridges or inks.
seems to
> > Jerry
very slim.
much as 4
 Don't
you do...the
> >> worse it will get.
> >> Robert
priming the system
out of ink -
doing a
> >>> Julian
> >>> From: "Jerry Olson" <jerryolson@r...>
dinner.
other 5
> >>>> Jerry
Polls and
wish to
this same
> >>> page.
messages to keep
> >>> them short.
subject header.
the various
Polls and
> >>> other
wish to
this same
> >>> page.
messages to keep
> >>> them short.
subject header.
various
Polls and
wish to
this same
> >> page.
messages to keep
> >> them short.
header.
various
Polls and other
wish to
this same
> > page.
to keep
> > them short.
header.
various
2003-03-19 by Jerry Olson
I did that Jim, no luck. Those cartridges and sponges are thoroughly
soaked with ink. Still horrendous clogs.
However, reinstalling the oem epson color inks gave a perfect nozzle
check with only a couple cleanings.  So I'm still baffled. There doesn't
appear to be anything wrong with the printer itself.
Jerry
> Jim H.
> printer off
> 4 days.
> of the
> check.  If
> don't
> > Robert
> > > cartridges or inks.
> seems to
> > > Jerry
> very slim.
> much as 4
>  Don't
> you do...the
> > >> worse it will get.
> > >> Robert
> priming the system
> out of ink -
> doing a
> > >>> Julian
> dinner.
> other 5
> > >>>> Jerry
> Polls and
> wish to
> this same
> > >>> page.
> messages to keep
> > >>> them short.
> subject header.
> the various
> Polls and
> > >>> other
> wish to
> this same
> > >>> page.
> messages to keep
> > >>> them short.
> subject header.
> various
> Polls and
> wish to
> this same
> > >> page.
> messages to keep
> > >> them short.
> header.
> various
> Polls and other
> wish to
> this same
> > > page.
> to keep
> > > them short.
> header.
> various
A toughie, Jerry. As a wild guess, any residue of ink pooled around
the nipples? How do the seals look at the bottom of the CIS carts? How
clean is the parking pad, esp the rubber rim- so it can seal the head?
That's about all I can think of. I guess from what you and others say
the ink is not the problem.
Luck,
Jim H.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Jerry Olson
> Jerry
> > Jim H.
> > printer off
> > 4 days.
> > of the
> > check.  If
> > don't
> > > Robert
be the
> > > > cartridges or inks.
appears
> > seems to
> > > > Jerry
> > very slim.
air in the
> > much as 4
> >  Don't
> > you do...the
> > > >> worse it will get.
> > > >> Robert
> > priming the system
> > out of ink -
> > doing a
> > > >>> Julian
no ink
> > dinner.
> > other 5
> > > >>>> Jerry
> > Polls and
> > wish to
> > this same
> > > >>> page.
> > messages to keep
> > > >>> them short.
> > subject header.
> > the various
> > Polls and
> > > >>> other
> > wish to
> > this same
> > > >>> page.
> > messages to keep
> > > >>> them short.
> > subject header.
> > various
> > Polls and
> > wish to
> > this same
> > > >> page.
> > messages to keep
> > > >> them short.
> > header.
> > various
> > Polls and other
> > wish to
> > this same
> > > > page.
> > to keep
> > > > them short.
> > header.
> > various
to keep them short.
header.
Hi Jim,
Rubber rim around the parking pad? I don't see any rubber rim around the
parking pad.  I can barely see the pad with a flashlight! It does have a
few drops of ammonia and water on it though. I see no pooled ink around
the nipples. And the OEM inks cleared all clog and banding problems with
only 2 cleanings!
Man this is frustrating.  I had a 1280 and CIS system going for 6 months
with NO problems at all, a little while back.
I'm going to try a new set of ink carts and inks, one more time. It will
be the last time. If I can't get it to work this time, I'm just going to
get out of black and white printing. It is not worth the stress, money
and frustration that I have experienced in the last week.
Jerry
> Luck,
> Jim H.
> > Jerry
> > > Jim H.
> > > printer off
> > > 4 days.
> > > of the
> > > check.  If
> > > don't
> > > > Robert
> be the
> > > > > cartridges or inks.
> appears
> > > seems to
> > > > > Jerry
> > > very slim.
> air in the
> > > much as 4
> > >  Don't
> > > you do...the
> > > > >> worse it will get.
> > > > >> Robert
> > > priming the system
> > > out of ink -
> > > doing a
> > > > >>> Julian
> no ink
> > > dinner.
> > > other 5
> > > > >>>> Jerry
> > > Polls and
> > > wish to
> > > this same
> > > > >>> page.
> > > messages to keep
> > > > >>> them short.
> > > subject header.
> > > the various
> > > Polls and
> > > > >>> other
> > > wish to
> > > this same
> > > > >>> page.
> > > messages to keep
> > > > >>> them short.
> > > subject header.
> > > various
> > > Polls and
> > > wish to
> > > this same
> > > > >> page.
> > > messages to keep
> > > > >> them short.
> > > header.
> > > various
> > > Polls and other
> > > wish to
> > > this same
> > > > > page.
> > > to keep
> > > > > them short.
> > > header.
> > > various
> to keep them short.
> header.
> Hi Jim,
No it's there, just not very wide. It's the perimeter of the pad that
surrounds the cloth-looking part. I was told once that it helps to
keep it wiped off with a swab. Not hard to do, I use a foam swab with
40% ethanol to distilled water and wipe around the rim once in a great
while. Ink builds up on it over time. I should mention that it's a
shot in the dark- and since Epson carts work good in your 1280 I
wouldn't suspect it as the problem.
 It does have a
> only 2 cleanings!
And the exit port seals on the CIS carts? The only other thing I can
think of...
Jerry I have reached that point myself in the past. It is a bad place
to get, but giving up image making should not have to be an option.
This is why I went with 2200/IP5 (soon to be 5.5), even at the upfront
expense.
I live with the dots in highlights. I know they are there, I have
compared them with VM output, etc. For me, in real life, when my
prints are on a wall, no one has yet bothered me about dots in
highlights. In comparisons you can see the problem, but if it's a
choice between not being able to do prints from a practical viewpoint
at all (which it is for me) I'll take the dots any day.
You really have to stare at the highlights close up to see them. So
whether it is acceptable is an individual choice I think. They are
close enough to blending into mat paper that it may be a toss up for some.
The perfectionist will not accept them maybe. But Jerry, I look at it
as I do cameras...I can get great shots with an p&s Olympus XA or a
Canon/ Nikon SLR, a MF Mamiya.....or I can buy Leica glass. If I'm a
good enough photog, I can make negs with a milk carton.
Those dots may put it out of the realm of Leica or MF comparison. But
the prints may be equivilant to Canon glass. Is this really so awfull,
if the alternative is abandoning image making? Interesting question...
Philosopy 101,
Jim H.
> Jerry
> > Luck,
> > Jim H.
doesn't
> > > Jerry
each cart
syringe,
> > > > Jim H.
Morrison
> > > > printer off
recommend
> > > > 4 days.
from all
> > > > of the
> > > > check.  If
 If you
> > > > don't
> > > > > Robert
 Perfect
> > be the
> > > > > > cartridges or inks.
to be a
> > appears
which
> > > > seems to
> > > > > > Jerry
> > > > very slim.
> > air in the
waiting as
> > > > much as 4
nothing.
> > > >  Don't
fussing
> > > > you do...the
> > > > > >> worse it will get.
> > > > > >> Robert
> > > > priming the system
you are
> > > > out of ink -
and then
> > > > doing a
> > > > > >>> Julian
> > no ink
go to
> > > > dinner.
heads!
but the
> > > > other 5
> > > > > >>>> Jerry
Bookmarks,
> > > > Polls and
page is at:
digest, or you
> > > > wish to
visiting
> > > > this same
> > > > > >>> page.
> > > > messages to keep
> > > > > >>> them short.
> > > > subject header.
attacks or
archives and
> > > > the various
Bookmarks,
> > > > Polls and
> > > > > >>> other
or you
> > > > wish to
visiting
> > > > this same
> > > > > >>> page.
> > > > messages to keep
> > > > > >>> them short.
> > > > subject header.
attacks or
and the
> > > > various
Bookmarks,
> > > > Polls and
is at:
or you
> > > > wish to
visiting
> > > > this same
> > > > > >> page.
> > > > messages to keep
> > > > > >> them short.
subject
> > > > header.
attacks or
and the
> > > > various
> > > > Polls and other
or you
> > > > wish to
visiting
> > > > this same
> > > > > > page.
messages
> > > > to keep
> > > > > > them short.
subject
> > > > header.
attacks or
and the
> > > > various
page is at:
> > to keep them short.
> > header.
to keep them short.
header.
Jim, I can't see any dots in the highlights of my prints when things are
all working as they should. Especially with Paul's curves (Cool, and
Neutral). At 1440 DPI on the 1280. Maybe my eyes aren't that great, but
I have 15/20 vision at only one spot in my entire vision. Without
glasses at 3 inches. At 3.5 inches it is out of focus. But where I CAN
focus, it is VERY sharp. I certainly noticed the dots in the 1160, but
haven't seen them yet in a 1280. Maybe Paul's curves took care of it, or
maybe my prints just don't show them.
I'd even be happy if all these problems could actually be traced to a
single source, like bad inks, or bad cartridges. WHY are they bad? What
happened that made them clog? Inks too thick? Too much difference
between batches?
If it's the cartridges, WHAT is making third party carts clog so bad?
Epson Original inks practically never have clogging problems!
I would love to try the 2200 printer, but frankly with my luck, I know
I'd have clogs when using third party inks an cartridges. It wasn't
always that way. In the past 6 years, I've had several spaces of 4-6
months with no problems whatsoever. So that is why it's so frustrating now.
Imageprint is just to expensive for me, and I doubt if I could
understand how to use it anyway.
Jerry
