Johnny,
You SHOULD get very close results using Epson driver + Curve and
Piezo ICC. The Piezo ICC appears to be nothing more than a linearing
scheme. Different papers behave differently, hence the unique ICC
profiles (or unique curves).
The original Piezography used the following tone order C=dark,
LC=dark, M=medium, LM=medium, Y=light. The FS (and FSN) inks are
designed to work with this order too. Therefore it cannot be used
with the Epson driver. But, if you switch the FS ink order around,
it can be used with the Epson driver. For over 2 years now I have
been using FS inks + Epson driver with C=dark, LC=medium, M=dark,
LM=medium, Y=light. This is SLIGHTELY different from the ICC tone
order.
Hope this helps.
Shilesh
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Johnny Eades"
<jeades1@s...> wrote:
> Hello Paul and Shilesh,
> I just came from Inkjetmall and this link shows the ink densities
> graphically.
> http://www.inkjetmall.com/store/bw/icc-positions.html
> It looks just like the FSN ink densities from MIS. That inkset
worked
> just fine with the Epson driver using curves, and also with the
> PiezographyBW software driver I purchased from Inkjetmall. Frm some
> posts I've read here and elsewhere, I shouln't have gotten the same
> results. Thoughts?
> Your friend in photography,
> Johnny Eades
> P.S> I think I send an empty message to the list. OOOOOPS!!!!!
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Shilesh Jani"
> <shilesh.jani@s...> wrote:
> > Paul,
> > You are right about the new Piezo ICC ink order. I filled one
1280
> > cartridge with FS inks in that order, and was very quickly able
to
> > create a grayscale adjustment curve to linearize a 21 step ramp.
> The
> > wedge was smoth and certainly no dots. So, the new Piezo ICC inks
> > likely can be used very easily with the Epson driver, without
> having
> > to resort to ICC profiles or a partitioned workflow.
> > My understanding of the FS-E inks was that LC=1/3C and LM=1/3M.
It
> > is, therfore a true "hextone" inkset (overkill, IMHO), rather
than
> a
> > quadtone inkset used for hextone printers.
> > Regards.
> > Shilesh
> > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul Roark"
> > <paul.roark@v...> wrote:
> > > Johnny,
> > > >Paul, Thanks for jumping in with your always welcomed input.
> > > >I do have on hand the MIS FSN-Epson driver inkset bulk inks.
> > > The original FSN is being upgraded to a UT-FSN, which is far
more
> > lightfast
> > > and also glossy paper compatible.
> > > > I did receive the cartridges from inkjet mall today.
> > > >I think I'll put them in and see what the Epson driver can do
> with
> > them.
> > > >I still have some curves for the FSN inks, so I may try them.
> > > The MIS FS-E light cyan may be darker than the Piezo/ICC setup.
> > > > I hesitate to do this before getting the ICC profiles
> > > >(currently on backorder).
> > > Sure, don't use up your inks before trying the new system.
> > > In the new Piezo system the ink order is, I believe, as
follows,
> > relative to
> > > the old quad Piezo inks: C = C, LC = M, M = M, LM = Y, Y = Y.
> The
> > main
> > > difference from the FS-E may be that the FS-E used a darker
LC.
> > (The gap
> > > between Piezo C and M is very large.) The bottom line is that
> the
> > old MIS
> > > FS-E curves may not be quite correct for the Piezo/ICC ink
order.
> > > >The whole set of FSN inks cost less than the two cartridges
from
> > > >Inkjetmall, and that adds to my hesitation.
> > > Cost is an issue.
> > > >If you have any ideas on using the Piezotone inks with
> > > >PS and applying curves, I'd appreciate any comments.
> > > The ICC system should work very well.
> > > If I were designing a hextone monotone inkset for the 1280,
> > however, I would
> > > not use so many light inks. The Piezo yellow, for example, was
> > needed to
> > > tame the old 3000. In a 1280 I think it is lighter than
> > necessary. Having
> > > 2 inks of that density is, well, expensive water and a waste of
> the
> > > printer's capabilities. In a 1280, in fact, the M density is
> light
> > enough
> > > to carry the highlights and be very smooth.
> > > (Note that in the UT2 system, the dark midtones are both close
to
> > the Piezo
> > > C density. This is one reason the inkset can print on glossy
> paper
> > with a
> > > good dmax without the need for a Photo black -- a very nice
> feature
> > that
> > > 7600 and 9600 owners are especially going to appreciate.)
> > > At any rate, if I were to write curves for the 1280 and the
> > Piezo/ICC ink
> > > order, I might ignore the yellow-position ink (blue curve) for
> > > highlights and just use it at the very end to turn on the black
> > ink. At
> > > most I might pull it down initially until about 10% and then
turn
> > if off
> > > until the black needed to be used. I'd treat the M ink (green
> > curve) as the
> > > main light ink. Even that one would not be pulled on more than
> > half way
> > > until the very end. I'd probably let it go fairly flat in the
> > middle. The
> > > C ink (red curve) is where the midtone action is. Even this
one
> > could start
> > > at the white point and stay at a low slope until the green
curve
> > started to
> > > level off.
> > > I don't see me doing any curves for this inkset because it's
not
> > the way I
> > > would do things to start with. I think the inkset has too much
> > light ink in
> > > it and is too limited in its flexibility -- non-variable tones
> and
> > not
> > > glossy compatible. Frankly, I've been curious what an ICC
> approach
> > could do
> > > with the UT2 inkset.
> > > Paul
> > > www.PaulRoark.com
> > > For UT2 information, curves, and settings see:
> > > http://home1.gte.net/res09aij/
> > > __________________________________
Roark"
> > > > >The ICC profiles are specific to the piezotone ink sets and
> > > therefore it is
> > > > >quite unlikely that they will suit other manufacturers inks.
> > > > MIS FS inks are the same densities. So I suspect the MIS FS
> > series
> > > inks
> > > > would work fine as long as one makes sure the inks are in the
> > > correct
> > > > positions. The new Cone ink position is similar to (but
maybe
> > not
> > > exactly
> > > > the same as) what MIS marketed a few years ago as the FS-E
> > > inksets. The
> > > > original Piezo hextone arrangement was not consistent with
> > > Epson driver
> > > > because it used the same density inks in the light and dark
> > > positions of the
> > > > M & C spots. With both the MIS FS-E and new Piezo ICC
> > arrangement,
> > > the idea
> > > > is to allow the Epson driver crossovers to work -- because
> Epson
> > > does an
> > > > excellent job of it.
> > > > Paul
> > > > www.PaulRoark.com
> > > > -----Original Message-----
> > > > From: Johnny Eades [mailto:jeades1@s...]
> > > > Sent: 24 February 2004 02:40
> > > > To: DigitalBlackandWhiteThePrint@yahoogroups.com
> > > > Subject: [Digital BW] Curves for Epson 1280 and Piezotone inks
> > > > I currently use BO printing after ordering the PiezographyBW
> > > software
> > > > and the MIS Full Spectrum Neutral inkset. I am receiving the
> > > upgrade
> > > > to PiezoICC profiles and have ordered the matching Piezotone
> > > inkset.
> > > > [This E-mail has been scanned for viruses but it is your
> > > responsibility
> > > > to maintain up to date anti virus software on the device that
> you
> > > are
> > > > currently using to read this email. ]
> > > > Please visit the Group Homepage to check the Files, and other
> > > resources as
> > > > they are often being updated.
> > > > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint
> > > > If you wish to receive no emails or just a daily digest, or
you
> > > wish to
> > > > unsubscribe, please edit your Membership preferences by
> visiting
> > > this same
> > > > page.
> > > > Please follow these basic guidelines:
> > > > - As threads develop, trim off excess portions of earlier
> > messages
> > > to keep
> > > > them short.
> > > > - Good manners are required at all time. No personal attacks
or
> > > flames.
> > > > Hostile, aggressive or argumentative users may be removed
from
> the
> > > > membership without notice.
> > > > - Keep your posts and threads related to the group topic of
> > digital
> > > B&W
> > > > printing. Users who persistently make off-topic posts may be
> > > removed from
> > > > the membership.
> > > > - By posting on this forum you agree to abide by the group
> rules
> > and
> > > > guidelines, and to abide by the actions and decisions of the
> > group
> > > Owner and
> > > > Moderators. See Group Topic, Rules and Guidelines in the
> Files
> > > section:
> > > > BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL
BW,
> > THE
> > > PRINT
> > > > YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE
> OWNER
> > AND
> > > > MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT
BE
> > > LIABLE TO YOU
> > > > FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL
OR
> > > EXEMPLARY
> > > > DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF
> > PROFITS,
> > > > GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE
> > > OWNER AND
> > > > MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN
> > ADVISED
> > > OF THE
> > > > POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR
> THE
> > > INABILITY
> > > > TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii)
UNAUTHORIZED
> > > ACCESS TO OR
> > > > ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR
> > > CONDUCT OF ANY
> > > > THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv)
> ANY
> > > OTHER
> > > > MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
> > > > Yahoo! Groups Links
> > resources as
> > > If you wish to receive no emails or just a daily digest, or you
> > wish to
visiting
> > this same
> > > page.
> messages
> > to keep
> > > them short.
> > > - Good manners are required at all time. No personal attacks or
> > flames.
> > > Hostile, aggressive or argumentative users may be removed from
> digital
> > B&W
> > removed from
> > > the membership.
rules
> and
> group
> > Owner and
> > > Moderators. See "Group Topic, Rules and Guidelines" in the
Files
> > section:
> > > BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW,
> THE
> > PRINT
THE "OWNER"
> AND
> > > "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE
> > LIABLE TO YOU
> > > FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR
> > EXEMPLARY
> PROFITS,
> > THE "OWNER" AND
> > > "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN
> ADVISED
> > OF THE
THE
> > INABILITY
> > > TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED
> > ACCESS TO OR
> > CONDUCT OF ANY
ANY
> > OTHER
> > > Yahoo! Groups Links
