Linux/XP File Recognition
2004-04-22 by Tom Husband
I'm in the process of setting up Roy Harrington's QTR on a Redhat 9
partition.  It's a dual boot set up with XP Home in an NTFS
partition.  After a few hiccups I'm able to dual boot perfectly now.
I have all the files in place to install QTR and will probably do it
tonight.  A question though.  I'll be editing the images in Photoshop
CS on the XP partition but am not sure how to transfer them to the
Linux side.  I'm thinking of a separate FAT32 partition and save the
images there but don't know how to get Linux to recognize that
partition.  Anybody doing this sort of thing?  I've looked all over
the place but can't seem to find a definitive answer.
Tom
Re: Linux/XP File Recognition
2004-04-22 by Roy Harrington
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Tom Husband"
> Thanks,
> Tom
The different Linuxes recognize different filesystems, so you should
check their docs.  But FAT32 would be the most likely candidate.
NTFS is very good but I'm not sure Redhat will deal with it.  What
FS are you going to load linux on?  I bet XP will recognize it.
Roy
over
> > Thanks,
> > Tom
> Roy
Roy,
Redhat 9 is in an EXT3 partition.  I didn't think XP would recognize
EXT3 but I haven't tried it.
Tom
RE: [Digital BW] Linux/XP File Recognition
2004-04-22 by Roger L Sopher
Hi Tom,
Rather than having to diddle with the system, another (?easier) way to to
use a USB-2 flash memory drive as the intermediary. You may have to add an
entry to the fstab in Linux but that is pretty straight forward. So the work
flow would be to write the file to the flash memory drive, boot up Linux,
mount the flash memory drive if it didn't automount, and then print away.
The how to for adding a flash memory drive to Linux is:
 http://www.tldp.org/HOWTO/Flash-Memory-HOWTO/index.html
Roger
  Sent: Thursday, April 22, 2004 9:17 AM
  Subject: [Digital BW] Linux/XP File Recognition
  Tom
they are often being updated.
page.
them short.
membership without notice.
the membership.
Moderators. See “Group Topic, Rules and Guidelines” in the Files section:
YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE “OWNER” AND
“MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU
GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  “OWNER” AND
“MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE
  Yahoo! Groups Links
> Roy,
recognize
> Thanks,
> Tom
Another thought.  All I would really need is read only access to the
NTFS or FAT32 partition to print with QTR right?  That might be
easier to set up.
Tom
One caveat is that the Sandisk Cruzer memory sticks will not work with
Linux. The how to I mentioned looks a little old as I went through it but it
is ok. For sure leave the file system as vfat ! This is another howto that
you might want to look at:
http://linuxquestions.org/questions/history/90977
Roger
  Tom
page.
them short.
the membership.
  Yahoo! Groups Links
RE: [Digital BW] Re: Linux/XP File Recognition
XP will see the EXT3 partition but will be unable to read it. The problem
won't be with XP since you can change the format of a partition in your
windows area from NTFD to vfat (after moving any critical data to another
partition). An easier way that comes to mind would be to use partition magic
to add a vfat partition in windows then you wouldn't have to piddle around
with moving data etc.
What I ended up doing in one of my Linux crazes was to set up a vfat
partition in windows, reinstall redhat making sure that I defined the
windows vfat partition with Disk Druid and then went through the rest of
getting updated files etc and then installed QTR.  I am sure there is a
direct way of getting Linux to see the new vfat partition but I am not
enough of a Linux guru to be able to do that at this point.
Roger
  Sent: Thursday, April 22, 2004 1:57 PM
  Subject: [Digital BW] Re: Linux/XP File Recognition
  > Roy,
  recognize
  > Thanks,
  > Tom
  easier to set up.
  Tom
page.
them short.
the membership.
  Yahoo! Groups Links
2004-04-23 by Tom Husband
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Roger L Sopher"
problem
your
another
partition magic
around
rest of
is a
not
> Roger
Thanks Roger!  Good information.  I now have some options.  I'd like
to get Linux to recognize a new vfat partitions which I'll create
with Partition Magic.  Failing that I could go the flash memory
route.  I guess I could also burn a CD in XP and open it in Linux.
I'll have to play around.
Thanks again,
Tom
Re: [Digital BW] Re: Linux/XP File Recognition
2004-04-23 by Glenn Barry
I'm not a guru either, but Linux should be able to recognise most if not all
partition types, you just need to mount the partition and assign it a mount
point. If you've ever come across Knoppix you will know what I mean. I used
it on several NT machines to boot from the CD and it read directly the NTFS
partitions on the drives.
A quick google
gave this
http://linux-ntfs.sourceforge.net/rpm/instructions.html
So apparently it's definitely possible with the addition of the driver from
the above page, I'm not sure if it's read only or read write, but read only
should suffice to get your images into linux to print
Glenn
Sent: Friday, April 23, 2004 10:35 AM
> problem
> your
> another
> partition magic
> around
> the
> rest of
> is a
> not
> > Roger
> Thanks again,
> Tom
page.
them short.
the membership.
2004-04-23 by Roger L Sopher
  Thanks again,
  Tom
   Tom,
  I've gone all of these routes. If you are going to work from a dual boot
system I would seriously consider setting up the fat32 partition in XP and
then reloading Linux and including that partition as a vfat partition called
something like /photo. In the long run it will be the simplest way around
the editing/printing problem with QTR. I have a separate linux box as well
as an old beige mac (bought on ebay for $100.00) that I use for printing
with QTR. I use both the USB flash memory route as well as a shared
partition. Eventually I am going to bag the PC and get a more capable mac,
get a platform transfer of photoshop from adobe and quit fighting this.
  My Linux box runs circles around the mac in speed but it is an idiot
savant printing system lacking much of the software I routinely use. On the
other hand it is a superb print engine.
  No perfect answer yet but I think you will like what you can do with Linux
and QTR even if the workflow is a bit cumbersome.
  Roger
>    Tom,
dual boot
XP and
partition called
around
as well
capable mac,
On the
with Linux
>   Roger
Thanks again, Roger.  Will have to give this some thought as I'm new
to Linux and reloading everything is a little daunting at the moment.
Tom
New member Re: Linux/XP File Recognition
2004-04-23 by Ramin
  I just became a memeber of this group as i am planning to purchase
a printer mainly for b&w printing.
  Regarding your enquiries:
1- You will not have any problem reading access to NTFS from linux.
If you only need to read files from there (copying files from NTFS
to a linux partition), it will be perfectly fine.
2- However if you want write access to windows file system from
linux, NTFS is risky. You very likely risk file corruption.
F32 is perfectly fine. I am having F32 partions on my machine which
i use to store the files i want to use from both windows and linux.
3- Windows does not recognize any linux file system. It only sees
them as unkonwn file systems.
I am having my own questions that i will soon post here.
Best regards, Ramin
9
now.
it
Photoshop
over
> Thanks,
> Tom
2004-04-23 by Ramin
As i mentioned in my previous reply, if you only need read access,
NTFS is fine. I am using Mandrake 9.2 and i don´t have any problem
reading access to Windows NTFS (assuming you have mounted the NTFS
partition in the linux system). Redhat 9 is quite a recent version
of Linux so shouldn´t have any problem reading from NTFS.
> > Roy,
> recognize
> > Thanks,
> > Tom
> easier to set up.
> Tom
2004-04-23 by Ramin
recognize
> Thanks,
> Tom
Windows can not recognize any linux file system: It only sees them
as unkonwn file system. You can verify this by having a look at disk
management utility under windows xp.
Best regards, Ramin
2004-04-23 by Ramin
9
now.
it
Photoshop
over
> Thanks,
> Tom
  Sorry i did not see the second part of your question on how to
have linux recognize a newly made partition. I am not a redhat user,
but i bet it has a graphical user interface for this purpose as
Mandrake and Suse (that i have been using) have such tool.
  Even without such a graphical tool, it should be equally easy to
do so. You only need to add a line to you fstab file (/etc/fstab)
defining the new partition. I have four F32 partitions in my system.
The coresponding lines in my fstab file are as follows:
/dev/sdc5 /mnt/wind vfat
iocharset=iso8859-1,uid=501,gid=500,codepage=850 0 0
/dev/sdc6 /mnt/wine vfat iocharset=iso8859-1,umask=0,codepage=850 0
0
/dev/sdc7 /mnt/winf vfat iocharset=iso8859-1,umask=0,codepage=850 0
0
/dev/sdc8 /mnt/wing vfat iocharset=iso8859-1,umask=0,codepage=850 0
0
Note that /mnt/wind and the others are directories that i have
already defined. That means i run the command > mkdir /mnt/wind.
/mnt is where Mandrake usually puts non-linux file systems,
DVD/CD-ROMs, floppies, any USB or other storage device. You can
easily find where redhat put these filesystems by surfing the root
file system of redhat.
  You probably need to change sdc5 to something like hda2 or so. You
can get this information by having look as KDE control center >
information > storage devices or similar utilities.
  After adding similar lines, all you need to do is to reboot or
just simply enter the command mount -a in a terminal. This will
mount any partition and filesystem including the new ones.
  The options uid=501,gid=500 are not necessary. They specify that
only a particular user or a group of users in your linux box have
read/write permission on the partition.
Note that all these should be done as root. If you are logged in as
a user, open a terminal type su (logging in as root) and enter your
root password.
 I hope these will be useful. You can also find these information by
checking Linux forums and mailing lists or abundant linux resources
on the internet.
Best regards, Ramin
(snip)
You
> root password.
by
> on the internet.
> Best regards, Ramin
Thanks Ramin!  I really appreciate the information.  I'll try to set
it all up this weekend.
Welcome to the group by the way.  You'll find lots of helpful folks
here.
Tom
