> Hi Roy,
> Thanks for that. Just so I know I've got the right end of the stick
> here, when you talk about "the other inkset" you mean the Bowhaus
> Config UT7 set, right? It's confusing looking at the MIS website,
> because they talk about both inksets on an equal footing, it's not
> clear that either one of them is a recent development. Looking at the
> traffic here, it seems as if UT7 (in any form) is a new thing.
> Assuming I've understood that correctly, if I wanted to try QTR with
> Paul's UT7 inkset, then it would "just" =) be a matter of generating
> a suitable profile for your RIP. Given what I've just been reading in
> the thread on linearisation, it should be possible for me to get a
> pretty good result there if I have access to a densitometer, at least
> if I don't try to bring the toner inks into the equation. I'm just
> hedging here, really. If I'm going to spend out on a load of ink, it
> would be nice to know I had the option to revert to QTR if it turns
> out I don't like what the Epson driver produces.
> Cheers,
> -= mike =-
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Roy Harrington"
> <roy@h...> wrote:
> > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "mike_nunan"
> > <mike_nunan@h...> wrote:
> > > Hi,
> > > I've got a query for Roy and/or Paul, regarding the differences
> > > between the two variants of the UT7 inkset listed on MIS's
> website.
> > > These are described as the "Bowhaus Configuration", sold for use
> with
> > > QTR and IJC, and "Roark Configuration", sold for use with the
> Epson
> > > driver and Paul's curves. I'm intrigued that there are two
> inksets
> > > that are nearly, but not quite, the same. I know that one of
> Paul's
> > > goals was to create an "Easy B&W" inkset, and presumably that
> meant
> > > that the ink tones have to be made to fit in with the Epson
> driver's
> > > expectations. Is that what created the need for two separate
> sets?
> > > Roy, how hard would it be to use QTR with the "Roark Config" inks?
> > > TIA
> > > -= mike =-
> > Having two ink sets for the same basic idea is complicated.
> > Although I know the general idea of the new UT7 inks, I haven't
> > used or even seen them yet. Certainly the major reason for this
> > new set is to be able to use the ordinary Epson driver and get some
> > variable tone control. The seventh ink, light black, turns out to
> > make the Epson driver and its profiles quite complicated. I think
> that
> > this in turn makes the ink set fairly Epson driver oriented.
> > Whether this is a problem or not I don't know, but it may make the
> > QTR profiles a little more difficult trying to mimic the Epson
> driver.
> > The other inkset is probably a simpler set if you are using QTR,
> > but of course then you must use it -- there's no Easy B&W workflow.
> > Roy
