Re: [Digital BW] Re: Epson 1280 Thin Black Lines on Printout
2004-11-28 by B. Campbell
> I recently installed the UT2 inks for my Epson 1280. After about 5-7 > prints, I started getting thin black lines on the prints. Sometimes > it's one long line, other times it's several thin lines in a > grouping. Has anyone experienced this type of problem before and if > so, what did you do to resolve it? I have the same printer and inks and the same problem. In my case there are two types of lines. One is a single distinct line that looks like someone used a ruler and a #2 pencil and drew a straight line from the top to the bottom of the image. This line is most obvious in areas like skies but it's always there and always in the same place on the image. The other type of line isn't as distinct, isn't of uniform width or intensity, and tends to appear in groups. I haven't found a fix for the first kind and I suspect it's a mechanical problem with my scanner (you don't say whether you use a flatbed scanner or not, if you do and if the lines appear on your monitor screen as well as the print then it may just be a matter of keeping the scanner clean, even small amounts of dust can create lines in the image). The second type of line or groups of lines has been fixed by properly aligning the heads (I put the paper on a light box and use an 8X loupe).
----- Original Message ----- From: "Bob Michaels" <bob@...> To: <DigitalBlackandWhiteThePrint@yahoogroups.com> Sent: Sunday, November 28, 2004 9:03 AM Subject: [Digital BW] Re: Epson 1280 Thin Black Lines on Printout Do your lines look like they could be smears or one nozzle that fires continously? If it looks like one nozzle firing, do they extend outside the print area on one side? In either case it probably has nothing to do with the ink but I'd try putting color dye carts back in to be sure. If it's a smear, you need to clean the bottom of the heads with a windex soaked paper towel. If it's a nozzle firing, you're really out of luck as it's an electrical connection problem between the printer and the heads and is unrepairable. I had this and got Epson to do a warranty replacement. This problem was discussed quite a bit recently over on the Epson priter Yahoo group. Bob Michaels --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "jturner4210626" <JTurner421@a...> wrote: > > I recently installed the UT2 inks for my Epson 1280. After about 5-7 > prints, I started getting thin black lines on the prints. Sometimes > it's one long line, other times it's several thin lines in a > grouping. Has anyone experienced this type of problem before and if > so, what did you do to resolve it? > > --Joel Turner Please visit the Group Homepage to check the Files, and other resources as they are often being updated. http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint If you wish to receive no emails or just a daily digest, or you wish to unsubscribe, please edit your Membership preferences by visiting this same page. Please follow these basic guidelines: - As threads develop, trim off excess portions of earlier messages to keep them short. - Good manners are required at all time. No personal attacks or flames. Hostile, aggressive or argumentative users may be removed from the membership without notice. - Keep your posts and threads related to the group topic of digital B&W printing. Users who persistently make off-topic posts may be removed from the membership. - By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See "Group Topic, Rules and Guidelines" in the Files section: http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/ BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP. Yahoo! Groups Links
