Final info needed on Starter setup - Please Help!!
2005-04-17 by Paul Prowse
Hi all,
I have been searching and searching to try and work out the best way to go
to start quality B&W printing I have made my decision mostly but I need a
little extra help...
My system will be an A3 printer, with to start with MIS Eboni black inks
with the OEM colour inks that come with the printer printing Black Only
until I can afford another A3 Printer to dedicate to colour (Probably an
Epson R1800 if it works out well for colour), then I will turn my origional
printer to a B&W outfit using MIS Ultratone Inks.
Here is my questions, if I put a cartridge of MIS Eboni Black into the
Printer (Epson) will it still work for colour images if I use the OEM inks
and this new black? Can I get a set of UT inks (6 or 7) and swap them over
when I need to print colour (will the carts keep or dry up out of the
printer)?
My final and most important question is which printer to go for, I am
stumped between 2 both Epson's; either the 2200 or the 1280 most people tell
me that there isn't much noticeable difference in the output between the 2,
is this correct? If it is then I will go for the 1280, I know that the dpi
of the 2200 is higher than that of the 1280 but as most of my images are
worked on at between 300 or 600 (onscreen) will I see any difference?
Thanks in advance - I'm almost there!!
Cheers
Re: Final info needed on Starter setup - Please Help!!
2005-04-17 by Shilesh Jani
Paul,
Your plan is well thought out.  I would recommend the 2200 as it will
give you slightly better BO output than the 1280.  Another major
difference is speed.  The 2200 is much, much faster.  The 1280 is one
of the best printer for conversion to b/w inks.  But it is showing
it's age in the speed department.  Additionally, you will be able to
get very good b/w prints using QTR on the 2200 using just the
standard Epson inks.
Good luck.
Shilesh
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Paul Prowse
<paco@e...> wrote:
> Hi all,
way to go
need a
inks
Only
(Probably an
origional
OEM inks
them over
> printer)?
am
people tell
between the 2,
the dpi
images are
difference?
> Cheers
> Paul
2005-04-18 by Clayton Jones
Paul,
Some other important things about the 2200:
1) It has individual carts for each ink.
2) The color inks are pigment.
3) It is made for pigments and there seems to be fewer reports of
clogging problems.
4) It has a rear feeder for thicker papers.
As for using Eboni instead of MK with the UC color inks - a number of
people have mentioned doing it, and I haven't seen anyone say anything
bad about it.
I have one and it has been a very fine printer.  It hardly ever clogs.
I think a 2200 is a good investment.
Clayton
Re: [Digital BW] Re: Final info needed on Starter setup - Please Help!!
2005-04-18 by Paul Prowse
Clayton,
Thanks for your post, I think I¹m sold on the 2200. A couple of questions
arise from your post, forgive a newbie on some of these but my head is
spinning from all of the info I have consumed over the past couple of weeks!
Firstly you refer to Eboni instead of MK, is MK the ink that ships with the
Printer from Epson? And like wise are UC the inks that ship from Epson for
color?
I didn't know about the rear feeder which will mean I can use heavy Rag
Paper which is a bonus - thanks for that!
Could you let me know if I can swap the inks so say I brought a full set of
UT7 from MIS can I swap them around when I need to print color from the
Epson OEM's that ship with the printer and if so can you leave cartridges
out of the printer after you have started using them and they not dry up?
I'm guessing it's best not to do the above but I might (hope) be wrong.
Finally I am interested in experimenting with QTR, do you use it and is it
good for the 2200? Can you tell me what set up(s) you have for your 2200.
Many thanks
On 18/4/05 3:22 am, "Clayton Jones" <cj@...> wrote:
> Paul,
> clogging problems.
> bad about it.
> Regards,
> Clayton
> page.
> them short.
> Hostile, aggressive or argumentative users may be removed from the membership
> without notice.
> printing. Users who persistently make off-topic posts may be removed from the
> membership.
> guidelines, and to abide by the actions and decisions of the group Owner and
> Moderators. See “Group Topic, Rules and Guidelines” in the Files section:
> YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE “OWNER” AND
> “MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU
> FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY
> DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL,
> USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  “OWNER” AND “MODERATORS” OF
> DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH
> DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW,
> THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR
> TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE
> DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE
> DIGITAL BW, THE PRINT YAHOO GROUP.
> * To visit your group on the web, go to:
> * http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/
> * To unsubscribe from this group, send an email to:
> * DigitalBlackandWhiteThePrint-unsubscribe@yahoogroups.com
> <mailto:DigitalBlackandWhiteThePrint-unsubscribe@yahoogroups.com?subject=Unsub
> scribe>
> * Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
> <http://docs.yahoo.com/info/terms/> .
2005-04-18 by Shilesh Jani
Paul,
MK (matte black) is the Epson ink for use with matte papers,  It does
not ship with the printer.  The black that ships with the printer is
PK (photo black) to be used with resin coated (RC) papers.  UC inks
are the Epson "Ultra Chrome" PIGMENT inks which are standard with the
2200.
Epson MK is a warm black, and so is the Epson light black.  So BO
prints with MK will be warm (but very nice).  The Ebony ink from MIS
is a cool overall, and can appear warm depending on the paper (see
Clayton's web site for details).
I would suggest initially to load all Epson inks.  Try the warm BO
method and the share-ware QTR for a number of tones.  If you are
dissatisfied with them for any reason, then you can try other inks
like UT7.  I will tell you from experience that IF QTR does not work
for you overall (i.e., contrast, punch, the inkjet b/w "look"), no
amount of ink swapping will work any better.  The differences in the
print between QTR+UC and UT7 is relatively minor.  So when you get a
new 2200 printer, the default advice is to go with the Epson inks,
play around with BO, QTR, and ask yourself if it is worth going the
more complicated route.  If you find BO is your preferred method, by
all means go with MIS Ebony for a more neutral print.  But if you
find QTR prints (cool, cool-selenium, warm, sepia, and many
combinations of two of the aforementioned) acceptable then you are
better off staying with Epson inks.
When you are playing around initially, use Epson Enhanced Matte paper
exclusively.  It is readily available and inexpesive to boot.
Good luck.
Shilesh
<paco@e...> wrote:
> Clayton,
questions
is
of weeks!
with the
Epson for
> color?
Rag
full set of
cartridges
dry up?
wrong.
and is it
2200.
> Many thanks
> Paul
> On 18/4/05 3:22 am, "Clayton Jones" <cj@c...> wrote:
> > Paul,
> > clogging problems.
number of
anything
> > bad about it.
clogs.
> > Regards,
> > Clayton
resources as
wish to
this same
> > page.
messages to keep
> > them short.
flames.
the membership
> > without notice.
digital B&W
removed from the
> > membership.
and
group Owner and
> > Moderators. See "Group Topic, Rules and Guidelines" in the Files
section:
THE PRINT
> > YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER"
AND
> > "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE
LIABLE TO YOU
EXEMPLARY
PROFITS, GOODWILL,
> > USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  "OWNER"
AND "MODERATORS" OF
POSSIBILITY OF SUCH
DIGITAL BW,
OF YOUR
PARTY ON THE
RELATING TO THE
> > Yahoo! Groups Links
> > * DigitalBlackandWhiteThePrint-unsubscribe@...m
subject=Unsub
> > scribe>
Service
2005-04-20 by Paul Prowse
Thanks for all your comments - the 2200 (Well 2100 here in the UK) is being
dispatched today, I can't wait to get printing - cheers again.
PS Look out for my .... I'm confused about this?? Post that will crop up ohh
probably tomorrow night, I really enjoy this forum!!
On 18/4/05 8:42 pm, "Shilesh Jani" <shilesh.jani@...> wrote:
> Paul,
> 2200.
> Good luck.
> Shilesh
