Dry mounting digital prints?
2008-09-16 by Rick
2008-09-16 by Rick
I'm coming back to photography after a long break and am going digital. Will digital prints dry mount? I have a full-size press (Seal 210) I used to use for fiber-based darkroom prints. thanks Rick
2008-09-16 by maddoxmb
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Rick" <r_schiller@...> wrote: > > I'm coming back to photography after a long break and am going > digital. Will digital prints dry mount? I have a full-size press > (Seal 210) I used to use for fiber-based darkroom prints. > > thanks > > Rick > Yes. The main thing you have to be careful about is your choice of paper and not leaving the print in the press (heat) for as long as you may have done in the past. Also, there are some new mounting adhesives on the market specifically for digital prints.
2008-09-16 by ben schneider
I believe a more proper way of mounting an inkjet print is the same as one would mount a litho, silkscreen, etching, etc. for art sake.
But for portraits, and commercial matter, I go the same route as I have for years with dry mounting.
Ben
[Non-text portions of this message have been removed]2008-09-16 by Clayton Jones
Hello Ben, >I believe a more proper way of mounting an inkjet print is the same as one would mount a litho, silkscreen, etching, etc. for art sake. >But for portraits, and commercial matter, I go the same route as I have ?for years with dry mounting. Why? Regards, Clayton Info on black and white digital printing at http://www.cjcom.net/digiprnarts.htm I-Trak 2.1 http://www.cjcom.net/itrak.htm
Hello Rick, >I'm coming back to photography after a long break and am going >digital. Will digital prints dry mount? I have a full-size press >(Seal 210) I used to use for fiber-based darkroom prints. Welcome home :) it's a good time to be getting back in. Printer, ink and paper technologies have come a long way over the past few years. Ink prints will dry mount, but IMO there is no longer any need to do it. The main reason for doing it, wrinkled or wavy emulsion papers, is no longer an issue. If you want the floating mount look, it can be emulated by leaving a 1" or greater border around the image and cutting the window mat big enough to leave a "reveal" area around the image. This has the advantage of keeping a signature, title, print #, etc, on the image paper instead of the mount board. As a bonus, mounting/matting time and labor is greatly reduced. It's great. You couldn't pay me enough to go back to dry mounting (well, few could afford to pay me enough <g>). Regards, Clayton Info on black and white digital printing at http://www.cjcom.net/digiprnarts.htm I-Trak 2.1 http://www.cjcom.net/itrak.htm
2008-09-18 by Rick
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Clayton Jones" <cj@...> wrote: > > Hello Rick, > > >I'm coming back to photography after a long break and am going > >digital. Will digital prints dry mount? I have a full-size press > >(Seal 210) I used to use for fiber-based darkroom prints. > > Welcome home :) it's a good time to be getting back in. Printer, ink > and paper technologies have come a long way over the past few years. > > Ink prints will dry mount, but IMO there is no longer any need to do > it. The main reason for doing it, wrinkled or wavy emulsion papers, > is no longer an issue. If you want the floating mount look, it can be > emulated by leaving a 1" or greater border around the image and > cutting the window mat big enough to leave a "reveal" area around the > image. This has the advantage of keeping a signature, title, print #, > etc, on the image paper instead of the mount board. As a bonus, > mounting/matting time and labor is greatly reduced. It's great. You > couldn't pay me enough to go back to dry mounting (well, few could > afford to pay me enough <g>). > > > Regards, > Clayton > > > Info on black and white digital printing at > http://www.cjcom.net/digiprnarts.htm > I-Trak 2.1 http://www.cjcom.net/itrak.htm > OK, thanks for everyone's thoughts on this. There is just something I still miss about a fine BW fiber based darkroom print drymount and sitting on top of the board. But I suppose those days have gone the way of the dinosaur. Best.
2008-09-18 by ben schneider
Portraits, and Commercial prints are mostly framed without a matte. Dry mounting is necessary to keep the print flat, especially when no glass is put into the frame. I normally lacquer all of the prints that do not have glass over them.
I chose to float, or hinge mount prints that are matted, because it is reversible. One can change the matte and backing if necessary. When I print the print, it is on a slightly larger sheet. I sign that sheet, as well as the matte. The extra paper that extends past the image helps to keep the print flat under the matte.
I also think of Ink Jet Prints as being different then Photographs. I have argued this ethical, and aesthetic point many times. I consider Silver/Gelatin prints a whole other class of art, digital ink jet printing another. When I sell digitally produced images, I do not call them photographs. I sell them as Giclee Prints. Adding this title to them, makes people think they are more exclusive.
Personally I consider injet printing more akin to Lithography as a print class. Images made from cyan, magenta, yellow, and black ink dots on paper. It is just the method of applying the ink that is different.
Ben
[Non-text portions of this message have been removed]2008-09-18 by mtparis
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Clayton Jones" <cj@...> wrote: > > Hello Rick, > > >I'm coming back to photography after a long break and am going > >digital. Will digital prints dry mount? I have a full-size press > >(Seal 210) I used to use for fiber-based darkroom prints. > > Welcome home :) it's a good time to be getting back in. Printer, ink > and paper technologies have come a long way over the past few years. > > Ink prints will dry mount, but IMO there is no longer any need to do > it. The main reason for doing it, wrinkled or wavy emulsion papers, > is no longer an issue. If you want the floating mount look, it can be > emulated by leaving a 1" or greater border around the image and > cutting the window mat big enough to leave a "reveal" area around the > image. This has the advantage of keeping a signature, title, print #, > etc, on the image paper instead of the mount board. As a bonus, > mounting/matting time and labor is greatly reduced. It's great. You > couldn't pay me enough to go back to dry mounting (well, few could > afford to pay me enough <g>). > > > Regards, > Clayton > > > Info on black and white digital printing at > http://www.cjcom.net/digiprnarts.htm > I-Trak 2.1 http://www.cjcom.net/itrak.htm > Clayton, How do you fix/position your print to the ?mat board sitting behind the window mat, since it's not dry mounted on a board? Michael
2008-09-19 by Gary Weaver
My working outlook, too. I like to point out to people that the coffee table books seem to have reproductions they don't complain about. It's just a different process. gar *********** REPLY SEPARATOR ***********
On 9/18/2008 at 9:22 AM ben schneider wrote: >Portraits, and Commercial prints are mostly framed without a matte. Dry >mounting is necessary to keep the print flat, especially when no glass is >put into the frame. I normally lacquer all of the prints that do not have >glass over them. > >I chose to float, or hinge mount prints that are matted, because it is >reversible. One can change the matte and backing if necessary. When I >print the print, it is on a slightly larger sheet. I sign that sheet, as >well as the matte. The extra paper that extends past the image helps to >keep the print flat under the matte. > >I also think of Ink Jet Prints as being different then Photographs. I >have argued this ethical, and aesthetic point many times. I consider >Silver/Gelatin prints a whole other class of art, digital ink jet printing >another. When I sell digitally produced images, I do not call them >photographs. I sell them as Giclee Prints. Adding this title to them, >makes people think they are more exclusive. > >Personally I consider injet printing more akin to Lithography as a print >class. Images made from cyan, magenta, yellow, and black ink dots on >paper. It is just the method of applying the ink that is different. > >Ben > > > > > > >[Non-text portions of this message have been removed] > > >------------------------------------ > >Please visit the Group Homepage to check the Files, and other resources as >they are often being updated. > >http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint > >If you wish to receive no emails or just a daily digest, or you wish to >unsubscribe, please edit your Membership preferences by visiting this same >page. > >Please follow these basic guidelines: >- As threads develop, trim off excess portions of earlier messages to keep >them short. >- Good manners are required at all time. No personal attacks or flames. >Hostile, aggressive or argumentative users may be removed from the >membership without notice. >- Keep your posts and threads related to the group topic of digital B&W >printing. Users who persistently make off-topic posts may be removed from >the membership. >- By posting on this forum you agree to abide by the group rules and >guidelines, and to abide by the actions and decisions of the group Owner >and Moderators. See Group Topic, Rules and Guidelines in the Files >section: >http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/ > >BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT >YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE OWNER AND >MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO >YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR >EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF >PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE >OWNER AND MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN >ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE >OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) >UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) >STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT >YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE >PRINT YAHOO GROUP. >Yahoo! Groups Links > > >
2008-09-19 by Clayton Jones
Hello Michael, >How do you fix/position your print to the ?mat board sitting behind >the window mat, since it's not dry mounted on a board? >Michael I use two pieces of acid free linen hinge tape at the top of the print, taped to the back of the window mat. Then I hinge the back board (another piece of mat board) to the top of the window mat. So the print is basically hanging by it's top edge while being sandwiched between the boards. Quick, easy, stable, and not permanent. As for positioning the print and mat, I lay the print face up on a table with the top edge (the edge that will be taped) extending over the table edge about two inches. Then lay the window mat over it and carefully position it for even reveal all around the image. When it's in position I place two small pieces of photographers tape over the upper corners of the print (the part extending from the table) to hold it in position against underside of the mat. Then I lift them up for final inspection to ensure the positioning is correct, then lay it face down and apply the hinge tape along the top edge of the print (two pieces, each about 2" long [tape is 1.25" wide]), then remove the photographers tape from the corners. While it's face down, I put the back board next to the mat, top edges touching, and apply two more pieces of hinge tape along that joint. Then fold the back board over the mat, which sandwiches the print, and it's done (print is already signed). If it's not being framed it goes into a sleeve. It's so much quicker than dry mounting, which was always a major factor in print production. It's made a huge difference. I haven't used my dry mount press in over seven years. Regards, Clayton Info on black and white digital printing at http://www.cjcom.net/digiprnarts.htm I-Trak 2.1 http://www.cjcom.net/itrak.htm
2008-09-20 by Frank K
Of course people will see more value in a print that is
called "Giclee" because a lot of people are stupid and think if it
has a french name it is something special. Call it what it is if one
is worried about ethics..sprayed ink...or pigment inks..or dye
inks...
When I sell my prints the print speaks not the process. I have
silver halide, pigment ink, dye ink, both from an inkjet printer,
carbon ink, from inkjet also...I have photos manipulated with
watercolor paints, acrylics etc. I do not give it a fancy name. When
someone asks it is described as..."Mixed media using, dyes, paints,
acrylics, bee pollen, whatever is in it.
I would imagine that the photographers who used
daguerreotypes "felt" that calotypes weren't photographs either. And
the wet plate folks did'nt think the dry plates were "real
photographs" . 8x10 shooters, vs 4x5, Graphlex shooters vs, roll
film users, 2.25 in. vs 35 mm....film vs. digital.. the Is it art?
argument...all of them...useless, silly, wastes of time...what
matters is the final print...period.
Photography is the process where light is captured on a light
sensitive material..it is the capture that dictates whether
something is a photograph or not. Do'nt believe me..check a
dictionary. But, if one believes photographs must be printed on
silver halide, then the years of Life Magazine, Nat Geo, Look, etc
etc did not show photos but showed....???what.
Digital is upon us and will stay. People take photographs with
their digital light capturing sensors and print them either as ink
prints, C Prints, or any other foreign sounding name you can give
them.
And in case anyone needs some sodium thiosulphate for a fix bath
let me know. I wo'nt ever touch that stuff again.
Just my two cents...with gas prices this high, make it a quarter's
worth
Frank in NJ
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, ben schneider
exclusive.
different.> > Ben > > > > > > > [Non-text portions of this message have been removed] >
2008-09-20 by jimcongleton
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Clayton Jones" <cj@...> wrote: > I use two pieces of acid free linen hinge tape at the top of the > print, taped to the back of the window mat. Then I hinge the back > board (another piece of mat board) to the top of the window mat. > > So the print is basically hanging by it's top edge while being > sandwiched between the boards. Quick, easy, stable, and not permanent. > > As for positioning the print and mat, I lay the print face up on a > table with the top edge (the edge that will be taped) extending over > the table edge about two inches. Then lay the window mat over it and > carefully position it for even reveal all around the image. When it's > in position I place two small pieces of photographers tape over the > upper corners of the print (the part extending from the table) to hold > it in position against underside of the mat. Then I lift them up for > final inspection to ensure the positioning is correct, then lay it > face down and apply the hinge tape along the top edge of the print > (two pieces, each about 2" long [tape is 1.25" wide]), then remove the > photographers tape from the corners. Clayton, I've used a method similar to yours (tightly affixing the print to the back of the mat with two short pieces of archival tape) until recently. Then two people returned prints to me for remounting because they had developed waviness, visible along the top edge of the print. I'm using Ilford GSF, so this problem is likely more obvious then it would be with a less reflective mat paper. Now I'm leaving some "play" in the mounting tape (as recommended for mounting art work by Linco & others) by using two 2-inch pieces of tape applied vertically to the back of the print and not stuck to the mat; then two additional, horizontal pieces of tape, spaced 3/4 inch above the print, are used to anchor the vertical pieces of tape to the backing board. So far (but after only 2 months of observation) the new method seems to avoid the waviness problem. Possibly the problem is caused by slight swelling or contraction of the paper related to changes in humidity (the prints cure for, usually, several months before framing). Or possibly the Ilford paper is more susceptible to dimensional changes than rag papers? Best, Jim C
2008-09-20 by djon43
Everybody here knows "Giclee" is a marketing system and bogus label, not a process. And it's a copywrite violation to use the term if one isn't paying to take part in the hustle. "Giclee" is exactly the same conceptually as "Big Mac"...not a burger, a specific brand of burger.. inferior and easily marketed. --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Gary Weaver" <garww@...> wrote: > > My working outlook, too. > > I like to point out to people that the coffee table books seem to have reproductions they don't complain about. It's just a different process. > > gar > > *********** REPLY SEPARATOR *********** > > On 9/18/2008 at 9:22 AM ben schneider wrote: > > >Portraits, and Commercial prints are mostly framed without a matte. Dry > >mounting is necessary to keep the print flat, especially when no glass is > >put into the frame. I normally lacquer all of the prints that do not have > >glass over them. > > > >I chose to float, or hinge mount prints that are matted, because it is > >reversible. One can change the matte and backing if necessary. When I > >print the print, it is on a slightly larger sheet. I sign that sheet, as > >well as the matte. The extra paper that extends past the image helps to > >keep the print flat under the matte. > > > >I also think of Ink Jet Prints as being different then Photographs. I > >have argued this ethical, and aesthetic point many times. I consider > >Silver/Gelatin prints a whole other class of art, digital ink jet printing > >another. When I sell digitally produced images, I do not call them > >photographs. I sell them as Giclee Prints. Adding this title to them, > >makes people think they are more exclusive. > > > >Personally I consider injet printing more akin to Lithography as a print > >class. Images made from cyan, magenta, yellow, and black ink dots on > >paper. It is just the method of applying the ink that is different. > > > >Ben > > > > > > > > > > > > > >[Non-text portions of this message have been removed] > > > > > >------------------------------------ > > > >Please visit the Group Homepage to check the Files, and other resources as > >they are often being updated. > > > >http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint > > > >If you wish to receive no emails or just a daily digest, or you wish to > >unsubscribe, please edit your Membership preferences by visiting this same > >page. > > > >Please follow these basic guidelines: > >- As threads develop, trim off excess portions of earlier messages to keep > >them short. > >- Good manners are required at all time. No personal attacks or flames. > >Hostile, aggressive or argumentative users may be removed from the > >membership without notice. > >- Keep your posts and threads related to the group topic of digital B&W > >printing. Users who persistently make off-topic posts may be removed from > >the membership. > >- By posting on this forum you agree to abide by the group rules and > >guidelines, and to abide by the actions and decisions of the group Owner > >and Moderators. See "Group Topic, Rules and Guidelines" in the Files > >section: > >http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/ > > > >BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT > >YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND > >"MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO > >YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR > >EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF > >PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE > >"OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN > >ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE > >OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) > >UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii)
> >STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT > >YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE > >PRINT YAHOO GROUP. > >Yahoo! Groups Links > > > > > > >
2008-09-20 by ben schneider
Frank in NJ,
Right on. Magazines are lithographs, not photographs. The original transparency, or piece of film was the photograph. But the reproductions in the magazines are lithographs.
This realization came to me some twenty-five years ago. I had a both at an arts and crafts fair, and it was a requirement that each person exhibiting do some sort of demonstration. I took an Alto's Easy Matte, and my Seal 160M press and demonstrated print finishing. Cutting mattes, and mounting prints on backing board. It was a statement a visitor made in my booth which made me aware of what the was being mounted. His statement to his children was, "See, he is cutting pictures out of magazines, and mounting them to cardboard". Even though they were my original, darkroom made prints, I was made aware that a print is a print to most people.
I was first hurt by his statement; then after thinking about it, if he thought these were magazine reproductions, they must be pretty good to fool him.
Ben
[Non-text portions of this message have been removed]2008-09-20 by Clayton Jones
Hello Jim, >...two people returned prints to me for remounting because they had >developed waviness, visible along the top edge of the print. >I'm using Ilford GSF, so this problem is likely more obvious then it >would be with a less reflective mat paper. Bummer. I've never had that happen (I use matte paper). >Now I'm leaving some "play" in the mounting tape...used to anchor >the vertical pieces of tape to the backing board. Understood, I've seen those kind of hinges. Only problem I have with that is it's back to the old dry mount problem of the time-consuming extreme precision required when attaching to the mount board - it has to be centered in the window. I'm wondering, since the purpose of the hanging hinges is to allow for some minute dimensional changes due to whatever, if it wouldn't work just as well taped to the window mat. Why should it matter to which side of the sandwich it's taped? Why not do as described, only apply hanging hinges instead of the two pieces of tape? Now that I think about it, it would be easy to do. The "tabs" (a 2 or 3 inch piece of tape folded over on itself, leaving just a half inch of sticky exposed) could be pre-attatched to the print, with the tabs extending out from the top edge. Then the usual procedure, and when it's flipped over you just tape down the tabs instead of the print edge. What do you think? >possibly the Ilford paper is more susceptible to dimensional changes >than rag papers? Could be, and maybe size makes a difference. What size prints are you talking about? My biggest are in 16x20 mats, and my best sellers are in 11x14 mats, so I'm not operating in the big print arena. Regards, Clayton Info on black and white digital printing at http://www.cjcom.net/digiprnarts.htm I-Trak 2.1 http://www.cjcom.net/itrak.htm
2008-09-20 by E Neilsen
There is no copyright violation to selling a Giclee. That would be like saying it a copyright violation to sell a photograph. There may be a group of people selling "Giclee" prints but they can not copyright a term that is a term in common use. If this is true, please direct us to ANY post which spells this out. If you don't belong to their group you may not sell a "certified" with their label I suppose, but your statement here leave a lot to be explained. Eric Eric Neilsen Photo 4101 Commerce Street, Suite 9 Dallas, TX 75226 214 827-8301 http://ericneilsenphotography.com SKype ejprinter _____
From: DigitalBlackandWhiteThePrint@yahoogroups.com [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of djon43 Sent: Saturday, September 20, 2008 12:43 PM To: DigitalBlackandWhiteThePrint@yahoogroups.com Subject: [Digital BW] Re:Dry mounting digital prints? Everybody here knows "Giclee" is a marketing system and bogus label, not a process. And it's a copywrite violation to use the term if one isn't paying to take part in the hustle. "Giclee" is exactly the same conceptually as "Big Mac"...not a burger, a specific brand of burger.. inferior and easily marketed. --- In DigitalBlackandWhit <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> eThePrint@yahoogroups.com, "Gary Weaver" <garww@...> wrote: > > My working outlook, too. > > I like to point out to people that the coffee table books seem to have reproductions they don't complain about. It's just a different process. > > gar > > *********** REPLY SEPARATOR *********** > > On 9/18/2008 at 9:22 AM ben schneider wrote: > > >Portraits, and Commercial prints are mostly framed without a matte. Dry > >mounting is necessary to keep the print flat, especially when no glass is > >put into the frame. I normally lacquer all of the prints that do not have > >glass over them. > > > >I chose to float, or hinge mount prints that are matted, because it is > >reversible. One can change the matte and backing if necessary. When I > >print the print, it is on a slightly larger sheet. I sign that sheet, as > >well as the matte. The extra paper that extends past the image helps to > >keep the print flat under the matte. > > > >I also think of Ink Jet Prints as being different then Photographs. I > >have argued this ethical, and aesthetic point many times. I consider > >Silver/Gelatin prints a whole other class of art, digital ink jet printing > >another. When I sell digitally produced images, I do not call them > >photographs. I sell them as Giclee Prints. Adding this title to them, > >makes people think they are more exclusive. > > > >Personally I consider injet printing more akin to Lithography as a print > >class. Images made from cyan, magenta, yellow, and black ink dots on > >paper. It is just the method of applying the ink that is different. > > > >Ben > > > > > > > > > > > > > >[Non-text portions of this message have been removed] > > > > > >------------------------------------ > > > >Please visit the Group Homepage to check the Files, and other resources as > >they are often being updated. > > > >http://groups. <http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint> yahoo.com/group/DigitalBlackandWhiteThePrint > > > >If you wish to receive no emails or just a daily digest, or you wish to > >unsubscribe, please edit your Membership preferences by visiting this same > >page. > > > >Please follow these basic guidelines: > >- As threads develop, trim off excess portions of earlier messages to keep > >them short. > >- Good manners are required at all time. No personal attacks or flames. > >Hostile, aggressive or argumentative users may be removed from the > >membership without notice. > >- Keep your posts and threads related to the group topic of digital B&W > >printing. Users who persistently make off-topic posts may be removed from > >the membership. > >- By posting on this forum you agree to abide by the group rules and > >guidelines, and to abide by the actions and decisions of the group Owner > >and Moderators. See "Group Topic, Rules and Guidelines" in the Files > >section: > >http://groups. <http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/> yahoo.com/group/DigitalBlackandWhiteThePrint/files/ > > > >BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT > >YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND > >"MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO > >YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR > >EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF > >PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE > >"OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN > >ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE > >OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) > >UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) > >STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT > >YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE > >PRINT YAHOO GROUP. > >Yahoo! Groups Links > > > > > > > [Non-text portions of this message have been removed]
Eric, This is a matter for you and your attorney. You won't find a convincing answer unless you pay for it because you believe what you believe...always a mistake. "Giclee" wasn't in "common use" until it was cooked up for marketing purposes, then appropriated by others who didn't want to let their customers know they were doing common inkjets. "Levis" is in common use, but you might not want to use it as a label for Indonesian knockoffs... "Photograph" is a generic term for optical, and perhaps scanned image-making. It commonly includes video and motion picture as well. It doesn't refer to silver film, color slides, digital files or anything technical whatsoever. Commonly we make a distinction between halftone prints (as in magazines, books, and serigraphs) and items that are closer to the camera, but digital technology is blurring that. PT Barnum invented "Giclee." --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "E Neilsen" <e.neilsen2@...> wrote: > > There is no copyright violation to selling a Giclee. That would be like > saying it a copyright violation to sell a photograph. There may be a group > of people selling "Giclee" prints but they can not copyright a term that is > a term in common use. If this is true, please direct us to ANY post which > spells this out. If you don't belong to their group you may not sell a > "certified" with their label I suppose, but your statement here leave a lot > to be explained. > > > > Eric > > > > Eric Neilsen Photo > > 4101 Commerce Street, Suite 9 > > Dallas, TX 75226 > > 214 827-8301 > > > > http://ericneilsenphotography.com > > SKype ejprinter > > > > _____ > > From: DigitalBlackandWhiteThePrint@yahoogroups.com > [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of djon43 > Sent: Saturday, September 20, 2008 12:43 PM > To: DigitalBlackandWhiteThePrint@yahoogroups.com > Subject: [Digital BW] Re:Dry mounting digital prints? > > > > Everybody here knows "Giclee" is a marketing system and bogus label, > not a process. And it's a copywrite violation to use the term if one > isn't paying to take part in the hustle. "Giclee" is exactly the same > conceptually as "Big Mac"...not a burger, a specific brand of burger.. > inferior and easily marketed. > > --- In DigitalBlackandWhit > <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> > eThePrint@yahoogroups.com, "Gary Weaver" > <garww@> wrote: > > > > My working outlook, too. > > > > I like to point out to people that the coffee table books seem to > have reproductions they don't complain about. It's just a different > process. > > > > gar > > > > *********** REPLY SEPARATOR *********** > > > > On 9/18/2008 at 9:22 AM ben schneider wrote: > > > > >Portraits, and Commercial prints are mostly framed without a > matte. Dry > > >mounting is necessary to keep the print flat, especially when no > glass is > > >put into the frame. I normally lacquer all of the prints that do > not have > > >glass over them. > > > > > >I chose to float, or hinge mount prints that are matted, because it is > > >reversible. One can change the matte and backing if necessary. When I > > >print the print, it is on a slightly larger sheet. I sign that > sheet, as > > >well as the matte. The extra paper that extends past the image > helps to > > >keep the print flat under the matte. > > > > > >I also think of Ink Jet Prints as being different then Photographs. I > > >have argued this ethical, and aesthetic point many times. I consider > > >Silver/Gelatin prints a whole other class of art, digital ink jet > printing > > >another. When I sell digitally produced images, I do not call them > > >photographs. I sell them as Giclee Prints. Adding this title to them, > > >makes people think they are more exclusive. > > > > > >Personally I consider injet printing more akin to Lithography as a > print > > >class. Images made from cyan, magenta, yellow, and black ink dots on > > >paper. It is just the method of applying the ink that is different. > > > > > >Ben > > > > > > > > > > > > > > > > > > > > >[Non-text portions of this message have been removed] > > > > > > > > >------------------------------------ > > > > > >Please visit the Group Homepage to check the Files, and other > resources as > > >they are often being updated. > > > > > >http://groups. > <http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint> > yahoo.com/group/DigitalBlackandWhiteThePrint > > > > > >If you wish to receive no emails or just a daily digest, or you wish to > > >unsubscribe, please edit your Membership preferences by visiting > this same > > >page. > > > > > >Please follow these basic guidelines: > > >- As threads develop, trim off excess portions of earlier messages > to keep > > >them short. > > >- Good manners are required at all time. No personal attacks or flames. > > >Hostile, aggressive or argumentative users may be removed from the > > >membership without notice. > > >- Keep your posts and threads related to the group topic of digital B&W > > >printing. Users who persistently make off-topic posts may be > removed from > > >the membership. > > >- By posting on this forum you agree to abide by the group rules and > > >guidelines, and to abide by the actions and decisions of the group > Owner > > >and Moderators. See "Group Topic, Rules and Guidelines" in the Files > > >section: > > >http://groups. > <http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/> > yahoo.com/group/DigitalBlackandWhiteThePrint/files/ > > > > > >BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE > PRINT > > >YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND > > >"MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE > LIABLE TO > > >YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR > > >EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF > > >PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE > > >"OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN
> > >ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) > THE USE > > >OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) > > >UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; > (iii) > > >STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT > > >YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE > > >PRINT YAHOO GROUP. > > >Yahoo! Groups Links > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] >
Copyright issues are fairly straight forward and then again not, but to say that the term giclee is to inkjet as big mac is to burger is so far off to be really sad. One should not confuse the marketing by a group with a readily used term. There has certainly been a movement to stand up and call an inkjet an "inkjet" with pride but there are many out there that are still calling inkjet prints "Giclee" in order to improve the perception of them in the market place. There is NOTHING to impart quality either way; that only comes from the actual piece of paper and ink. If you want to call your coffee table book a collection of giclee prints that is nothing stopping you from doing so. Eric Neilsen Photo 4101 Commerce Street, Suite 9 Dallas, TX 75226 214 827-8301 http://ericneilsenphotography.com SKype ejprinter _____
From: DigitalBlackandWhiteThePrint@yahoogroups.com [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of djon43 Sent: Saturday, September 20, 2008 12:43 PM To: DigitalBlackandWhiteThePrint@yahoogroups.com Subject: [Digital BW] Re:Dry mounting digital prints? Everybody here knows "Giclee" is a marketing system and bogus label, not a process. And it's a copywrite violation to use the term if one isn't paying to take part in the hustle. "Giclee" is exactly the same conceptually as "Big Mac"...not a burger, a specific brand of burger.. inferior and easily marketed. [Non-text portions of this message have been removed]
2008-09-20 by -= Chris =-
"Giclee" is nothing but the French term or word for Inkjet....
2008-09-20 by Tyler Boley
http://www.dpandi.com/giclee/giclee.html Tyler http://www.custom-digital.com/
2008-09-20 by jim kitchen
Dear Chris, On 9/20/08 4:11 PM, "-= Chris =-" <baudec@...> wrote: > "Giclee" is nothing but the French term or word for Inkjet.... > > The French language definition means something completely different... :) This is an anglicized version of the French definition... jim k [Non-text portions of this message have been removed]
I have my belief and you have your, but while Levis is a brand name, who made and sold the copyrighted print known as the Giclee. These are not Fresson prints, which are a unique type of print. I asked for reference if you have it; Not more hearsay. Doing a Google check, a search on the US copyright site, I find nothing on the term being anything other than a term; not a copyrighted process. Giclee is a generic term for iris, and inkjet prints. If the owners of the process known as a Giclee were out there, I think someone on this list, the Epson Wide Format Group, or one of the many other groups I subscribe would have run across an issue using that term. Is it possible that it is a copyright term? Loooking, looking, looking ahh According to Wikipedia, True Story of Giclée''" By Harald Johnson is quoted as attibuting the creation of it to Jack Duganne. What is a "Giclee" Art Reproduction print (pronounced gee-clay)? Giclee is French for "sprayed paint" and is traditionally used to describe fine art reproductions (copies) of original works of art, generally in larger sizes. Giclee reproductions are created on high quality archival ink-jet printing systems using pigment inks that are designed for color accuracy, longevity, and fade resistance. From San Diego Pictures,858-274-0665 web site I have email Jack and Harald for their input on this issue. I will post what I feel I can, if not all of their response. ( after check with them). I also see over 30 places selling Giclee prints that ARE inkjets; not Iris prints. Eric Eric Neilsen Photo 4101 Commerce Street, Suite 9 Dallas, TX 75226 214 827-8301 <http://ericneilsenphotography.com> http://ericneilsenphotography.com SKype ejprinter _____
From: DigitalBlackandWhiteThePrint@yahoogroups.com [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of djon43 Sent: Saturday, September 20, 2008 5:08 PM To: DigitalBlackandWhiteThePrint@yahoogroups.com Subject: [Digital BW] Re:Dry mounting digital prints? Eric, This is a matter for you and your attorney. You won't find a convincing answer unless you pay for it because you believe what you believe...always a mistake. "Giclee" wasn't in "common use" until it was cooked up for marketing purposes, then appropriated by others who didn't want to let their customers know they were doing common inkjets. "Levis" is in common use, but you might not want to use it as a label for Indonesian knockoffs... "Photograph" is a generic term for optical, and perhaps scanned image-making. It commonly includes video and motion picture as well. It doesn't refer to silver film, color slides, digital files or anything technical whatsoever. Commonly we make a distinction between halftone prints (as in magazines, books, and serigraphs) and items that are closer to the camera, but digital technology is blurring that. PT Barnum invented "Giclee." --- In DigitalBlackandWhit <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> eThePrint@yahoogroups.com, "E Neilsen" <e.neilsen2@...> wrote: > > There is no copyright violation to selling a Giclee. That would be like > saying it a copyright violation to sell a photograph. There may be a group > of people selling "Giclee" prints but they can not copyright a term that is > a term in common use. If this is true, please direct us to ANY post which > spells this out. If you don't belong to their group you may not sell a > "certified" with their label I suppose, but your statement here leave a lot > to be explained. > > > > Eric > > > > Eric Neilsen Photo > > 4101 Commerce Street, Suite 9 > > Dallas, TX 75226 > > 214 827-8301 > > > > http://ericneilsenp <http://ericneilsenphotography.com> hotography.com > > SKype ejprinter > > > > _____ > > From: DigitalBlackandWhit <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> eThePrint@yahoogroups.com > [mailto:DigitalBlackandWhit <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> eThePrint@yahoogroups.com] On Behalf Of djon43 > Sent: Saturday, September 20, 2008 12:43 PM > To: DigitalBlackandWhit <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> eThePrint@yahoogroups.com > Subject: [Digital BW] Re:Dry mounting digital prints? > > > > Everybody here knows "Giclee" is a marketing system and bogus label, > not a process. And it's a copywrite violation to use the term if one > isn't paying to take part in the hustle. "Giclee" is exactly the same > conceptually as "Big Mac"...not a burger, a specific brand of burger.. > inferior and easily marketed. > > --- In DigitalBlackandWhit > <mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> > eThePrint@yahoogrou <mailto:eThePrint%40yahoogroups.com> ps.com, "Gary Weaver" > <garww@> wrote: > > > > My working outlook, too. > > > > I like to point out to people that the coffee table books seem to > have reproductions they don't complain about. It's just a different > process. > > > > gar > > > > *********** REPLY SEPARATOR *********** > > > > On 9/18/2008 at 9:22 AM ben schneider wrote: > > > > >Portraits, and Commercial prints are mostly framed without a > matte. Dry > > >mounting is necessary to keep the print flat, especially when no > glass is > > >put into the frame. I normally lacquer all of the prints that do > not have > > >glass over them. > > > > > >I chose to float, or hinge mount prints that are matted, because it is > > >reversible. One can change the matte and backing if necessary. When I > > >print the print, it is on a slightly larger sheet. I sign that > sheet, as > > >well as the matte. The extra paper that extends past the image > helps to > > >keep the print flat under the matte. > > > > > >I also think of Ink Jet Prints as being different then Photographs. I > > >have argued this ethical, and aesthetic point many times. I consider > > >Silver/Gelatin prints a whole other class of art, digital ink jet > printing > > >another. When I sell digitally produced images, I do not call them > > >photographs. I sell them as Giclee Prints. Adding this title to them, > > >makes people think they are more exclusive. > > > > > >Personally I consider injet printing more akin to Lithography as a > print > > >class. Images made from cyan, magenta, yellow, and black ink dots on > > >paper. It is just the method of applying the ink that is different. > > > > > >Ben > > > > > > > > > > > > > > > > > > > > >[Non-text portions of this message have been removed] > > > > > > > > >------------------------------------ > > > > > >Please visit the Group Homepage to check the Files, and other > resources as > > >they are often being updated. > > > > > >http://groups. > <http://groups. <http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint> yahoo.com/group/DigitalBlackandWhiteThePrint> > yahoo.com/group/DigitalBlackandWhiteThePrint > > > > > >If you wish to receive no emails or just a daily digest, or you wish to > > >unsubscribe, please edit your Membership preferences by visiting > this same > > >page. > > > > > >Please follow these basic guidelines: > > >- As threads develop, trim off excess portions of earlier messages > to keep > > >them short. > > >- Good manners are required at all time. No personal attacks or flames. > > >Hostile, aggressive or argumentative users may be removed from the > > >membership without notice. > > >- Keep your posts and threads related to the group topic of digital B&W > > >printing. Users who persistently make off-topic posts may be > removed from > > >the membership. > > >- By posting on this forum you agree to abide by the group rules and > > >guidelines, and to abide by the actions and decisions of the group > Owner > > >and Moderators. See "Group Topic, Rules and Guidelines" in the Files > > >section: > > >http://groups. > <http://groups. <http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/> yahoo.com/group/DigitalBlackandWhiteThePrint/files/> > yahoo.com/group/DigitalBlackandWhiteThePrint/files/ > > > > > >BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE > PRINT > > >YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND > > >"MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE > LIABLE TO > > >YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR > > >EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF > > >PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE > > >"OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN > > >ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) > THE USE > > >OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) > > >UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; > (iii) > > >STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT > > >YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE > > >PRINT YAHOO GROUP. > > >Yahoo! Groups Links > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > [Non-text portions of this message have been removed]
2008-09-20 by Gary Weaver
I still associate the word with the IRIS and the APLS 4000 era. Not at all with inkjet. gar *********** REPLY SEPARATOR ***********
On 9/20/2008 at 5:02 PM jim kitchen wrote: >Dear Chris, > >On 9/20/08 4:11 PM, "-= Chris =-" <baudec@...> wrote: > >> "Giclee" is nothing but the French term or word for Inkjet.... >> >> >The French language definition means something completely different... :) > >This is an anglicized version of the French definition... > >jim k >
2008-09-21 by David Logan-Morrow
Couldn't have been said simpler. --- On Sat, 9/20/08, -= Chris =- <baudec@...> wrote:
> From: -= Chris =- <baudec@...> > Subject: Re: Copyright enough misinformation RE: [Digital BW] Re:Dry mounting digital prints? > To: DigitalBlackandWhiteThePrint@yahoogroups.com > Date: Saturday, September 20, 2008, 6:11 PM > "Giclee" is nothing but the French term or word > for Inkjet....
Just heard that someone, somewhere in a back room in Rochester, NY, is developing a camera that not only shoots digital but also film. Anyone else hear this?
2008-09-21 by jimcongleton
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Clayton Jones" <cj@...> wrote: > > I'm wondering, since the purpose of the hanging hinges is to allow for > some minute dimensional changes due to whatever, if it wouldn't work > just as well taped to the window mat. Why should it matter to which > side of the sandwich it's taped? Why not do as described, only apply > hanging hinges instead of the two pieces of tape? > > Now that I think about it, it would be easy to do. The "tabs" (a 2 or > 3 inch piece of tape folded over on itself, leaving just a half inch > of sticky exposed) could be pre-attatched to the print, with the tabs > extending out from the top edge. Then the usual procedure, and when > it's flipped over you just tape down the tabs instead of the print > edge. What do you think? I think that's a great idea: it certainly would speed up the process. It is difficult to center a print in the mat window when the print is fastened to the backing board. Probably not even necessary to fold over the hinge (might make the tabs too rigid?), if only the end that is fastened to the back of the print is moistened. I'll try it. > > What size prints are you talking about? My biggest are in 16x20 mats, and my best sellers are in 11x14 mats, so I'm not operating in the big print arena. My prints are in the same size range (18X23 mats). thanks for the suggestion, Jim C
2008-09-21 by -= Chris =-
----- jim kitchen <jim.kitchen@...> wrote: > > "Giclee" is nothing but the French term or word for Inkjet.... > > The French language definition means something completely different... :) http://fr.wikipedia.org/wiki/Gicl%C3%A9e http://www.nakedtranslations.com/fr/2004/05/000157.php En 1991, Duganne a dû créer un mot pour désigner un type d'impression mentionné dans un dépliant annonçant l'exposition de Diane Bartz, une artiste californienne. Il voulait éviter des mots tels que "ordinateur" ou "numérique" à cause des connotations négatives attachées à cette nouvelle technique dans le monde artistique. S'inspirant du mot français jet d'encre, Duganne a cherché dans son Larousse de poche un mot recouvrant la plupart des technologies jet d'encre de l'époque et, avec un peu de chance, du futur. Il est tombé sur le mot gicleur, la pièce qui diffuse l'encre sur le papier présente dans la plupart des imprimantes. La forme nominale de gicleur est giclée. Duganne avait trouvé ce qu'il recherchait. I guess, artistic license <g>, it also does have a slang connotation.
2008-09-21 by Clayton Jones
Hello Tyler, > http://www.dpandi.com/giclee/giclee.html Thanks for the good link. Here is the essence of the dictionary definition at the bottom: "...exact copy of an original work of art that was created by conventional means (painting, drawing, etc.) and then reproduced digitally, typically via inkjet printing." I don't know if the author(s) of this meant to include photographs in the "etc" part of "conventional means", but no matter. If a giclee is a copy of an original work of art, then it's not a good term for my ink prints because my prints are original works of art. If anyone wants to call their prints giclees that's fine, but they are relegating their efforts to the realm of copies. Regards, Clayton Info on black and white digital printing at http://www.cjcom.net/digiprnarts.htm I-Trak 2.1 http://www.cjcom.net/itrak.htm
2008-09-21 by jim kitchen
Dear Chris, On 9/20/08 6:42 PM, "-= Chris =-" <baudec@...> wrote: I guess, artistic license <g>, it also does have a slang connotation. It can... :) jim k [Non-text portions of this message have been removed]
2008-09-21 by Tyler Boley
unlike "toned silver gelatin", "Platinum", "Kallitype", on and on, including all of the intaglio, silkscreen, stone lithography, etc etc.. .. it's not a very helpful term, as it does not inform about the materials at all, or really the process. It could be Iris, Epson, dye or pigment, whatever. Certainly people can call their prints whatever they want. I prefer to call them something helpful and descriptive, and like yours, mine are originals, not "reproductions" of some other original. Tyler --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Clayton Jones" <cj@...> wrote:
> > Hello Tyler, > > > http://www.dpandi.com/giclee/giclee.html > > Thanks for the good link. Here is the essence of the dictionary > definition at the bottom: > > "...exact copy of an original work of art that was created by > conventional means (painting, drawing, etc.) and then reproduced > digitally, typically via inkjet printing." > > I don't know if the author(s) of this meant to include photographs in > the "etc" part of "conventional means", but no matter. If a giclee is > a copy of an original work of art, then it's not a good term for my > ink prints because my prints are original works of art. > > If anyone wants to call their prints giclees that's fine, but they are > relegating their efforts to the realm of copies. > > Regards, > Clayton > > > Info on black and white digital printing at > http://www.cjcom.net/digiprnarts.htm > I-Trak 2.1 http://www.cjcom.net/itrak.htm >
2008-09-21 by Frank K
That waviness can happen because of different reasons. 1. The thickness of the paper. 2. The tightness of the frame's backing which, if too loose, will not keep the mat's backing tight to the mat itself. 3. Humidity as someone else mentioned. I have found I never get waviness with 8x10 but it begins with 11x14 and above. A co-worker who mats and frames photos for other people mentioned the same thing. When I use a metal frame, and tightly set the backing boards I rarely get waves...seems to happen more with thin wooden frames. Also, printing on a paper the same size as the mat backing board almost completely eliminates it with 11x14 and larger. Frank in NJ --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "jimcongleton" <jconglet@...> wrote: > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Clayton Jones" <cj@> wrote: > > > I use two pieces of acid free linen hinge tape at the top of the > > print, taped to the back of the window mat. Then I hinge the back > > board (another piece of mat board) to the top of the window mat. > > > > So the print is basically hanging by it's top edge while being > > sandwiched between the boards. Quick, easy, stable, and not permanent. > > > > As for positioning the print and mat, I lay the print face up on a > > table with the top edge (the edge that will be taped) extending over > > the table edge about two inches. Then lay the window mat over it and > > carefully position it for even reveal all around the image. When it's > > in position I place two small pieces of photographers tape over the > > upper corners of the print (the part extending from the table) to hold > > it in position against underside of the mat. Then I lift them up for > > final inspection to ensure the positioning is correct, then lay it > > face down and apply the hinge tape along the top edge of the print > > (two pieces, each about 2" long [tape is 1.25" wide]), then remove the > > photographers tape from the corners. > > Clayton, > I've used a method similar to yours (tightly affixing the print to the back of the mat with > two short pieces of archival tape) until recently. Then two people returned prints to me for > remounting because they had developed waviness, visible along the top edge of the print. > I'm using Ilford GSF, so this problem is likely more obvious then it would be with a less > reflective mat paper. > > Now I'm leaving some "play" in the mounting tape (as recommended for mounting art > work by Linco & others) by using two 2-inch pieces of tape applied vertically to the back > of the print and not stuck to the mat; then two additional, horizontal pieces of tape, > spaced 3/4 inch above the print, are used to anchor the vertical pieces of tape to the > backing board. So far (but after only 2 months of observation) the new method seems to > avoid the waviness problem. > > Possibly the problem is caused by slight swelling or contraction of the paper related to > changes in humidity (the prints cure for, usually, several months before framing). Or > possibly the Ilford paper is more susceptible to dimensional changes than rag papers?
> Best, > Jim C >
2008-09-21 by the_des_bois
I agree. So not descriptive of anything. Might have been needed at the beginning... but today? Me not think so. Hey I just loaded my water gun with some dye blue ink and unloaded it on a piece of HPR. An original giclée... :-) Denis --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Tyler Boley" <tyler@...> wrote:
> > unlike "toned silver gelatin", "Platinum", "Kallitype", on and on, > including all of the intaglio, silkscreen, stone lithography, etc etc.. > > .. it's not a very helpful term, as it does not inform about the > materials at all, or really the process. > It could be Iris, Epson, dye or pigment, whatever. > Certainly people can call their prints whatever they want. > I prefer to call them something helpful and descriptive, and like > yours, mine are originals, not "reproductions" of some other original. > > Tyler > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Clayton Jones" > <cj@> wrote: > > > > Hello Tyler, > > > > > http://www.dpandi.com/giclee/giclee.html > > > > Thanks for the good link. Here is the essence of the dictionary > > definition at the bottom: > > > > "...exact copy of an original work of art that was created by > > conventional means (painting, drawing, etc.) and then reproduced > > digitally, typically via inkjet printing." > > > > I don't know if the author(s) of this meant to include photographs in > > the "etc" part of "conventional means", but no matter. If a giclee is > > a copy of an original work of art, then it's not a good term for my > > ink prints because my prints are original works of art. > > > > If anyone wants to call their prints giclees that's fine, but they are > > relegating their efforts to the realm of copies. > > > > Regards, > > Clayton > > > > > > Info on black and white digital printing at > > http://www.cjcom.net/digiprnarts.htm > > I-Trak 2.1 http://www.cjcom.net/itrak.htm > > >
2008-09-21 by Bob Frost
>There has certainly been a movement to stand up and call an inkjet an "inkjet" with pride but there are many out there that are still calling inkjet prints "Giclee" in order to improve the perception of them in the market place. I cannot see how using a rude French word for ejaculate improves the perception of a print as a serious piece of work. I just makes me (and others) laugh at the stupidity of it. bob Frost. ----- Original Message ----- From: "E Neilsen" <e.neilsen2@...>
I think Harald Johnson describes the origins and use of the word well http://www.dpandi.com/giclee/giclee.html Bob Frost. ----- Original Message ----- From: "E Neilsen" <e.neilsen2@...>
2008-09-21 by handyman856
Incorrecto-mundo my friend! It is the French word for "Spurt" (or similar) and was brought about around 2000 to make the process sound more arty - a more clever, less techy name for ink-JET. The French have shunned the word as it is also close to ejaculation in it's French meaning and therefore considered crude and offensive. Also: I think it is/was used more for traditional artworks (paintings, water colors, etc) that were drum-scanned and reproduced via (originally) an Iris printer. The reproduction quality was so stunning (for the day - 2000ish) - nearly indistinguishable from the original - that gallery owners were in fear of a flood of counterfeit Mona Lisa's. Now that quality is available on the desktop! I've seen "Pigment ink" used as reference to an ink-jet produced image, just as "silver gelatin" is being used as a reference to traditional wet-process photographic prints. That seems like a reasonable term. =Alan R. --- In DigitalBlackandWhiteThePrint@yahoogroups.com, -= Chris =- <baudec@...> wrote:
2008-09-21 by E Neilsen
Bob, I too find it an odd behavior, but it is out there none the less. And again, I don't think that they were going for that context but the one set in motion by those following Jack Duganne and his followers. Perhaps the slang you refer to is really a statement about all the piss poor quality prints that flows over the art market. It felt good when they were making them, but looking back not much to remember. Eric Eric Neilsen Photo 4101 Commerce Street, Suite 9 Dallas, TX 75226 214 827-8301 http://ericneilsenphotography.com SKype ejprinter _____
From: DigitalBlackandWhiteThePrint@yahoogroups.com [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Bob Frost Sent: Sunday, September 21, 2008 3:12 AM To: DigitalBlackandWhiteThePrint@yahoogroups.com Subject: Re: Copyright enough misinformation RE: [Digital BW] Re:Dry mounting digital prints? >There has certainly been a movement to stand up and call an inkjet an "inkjet" with pride but there are many out there that are still calling inkjet prints "Giclee" in order to improve the perception of them in the market place. I cannot see how using a rude French word for ejaculate improves the perception of a print as a serious piece of work. I just makes me (and others) laugh at the stupidity of it. bob Frost. ----- Original Message ----- From: "E Neilsen" <e.neilsen2@worldnet <mailto:e.neilsen2%40worldnet.att.net> .att.net> [Non-text portions of this message have been removed]
2008-09-21 by ben schneider
Since I am the bastard that started this "Photograph" thing, I thought I would add the following Wikipedia definition:
A photograph (often shortened to photo) is an image created by light falling on a light-sensitive surface, usually photographic film or an electronic imager such as a CCD or a w-redirect">CMOS chip. Most photographs are created using a camera, which uses a lens
to focus the scene's visible wavelengths of light into a reproduction
of what the human eye would see. The process of creating photographs is
called photography. The word "photograph" coined 1839 by Sir John Herschel and is based on the Greek φώς (phos), "light" + γραφίς (graphis), "stylus", "paintbrush" or γραφή (graphê), "representation by means of lines" or "drawing", together meaning "drawing with light".[1]
I think the word "photograph" invented by Sr. John Herschel says it all! This is the definition I was taught in college some 40 years ago, and the definition I used when I taught photography in college more recently. Drawing with light.
It is the process that names the image we see. So, if the final image, the one placed on display, is not made by using light, it is not a photograph. The signal formed by the camera sensor could be a photograph though.
Electra magnetic ink splatterings?????? Call it what you want.
Doing a image with a squirt gun loaded with ink could be a new art form, needing a great amount of skill. One could develop a whole line of precision squirt guns. Make tons of money selling them. Especially in selling the inks and papers needed to use them properly. Would we call that sort of image a Giclee too!
I wonder if Jackson Pollock ever tried it?
Ben
[Non-text portions of this message have been removed]2008-09-21 by handyman856
YES! I think the clueless noobs who invented the word had no idea of the 'other' connotations of it. And it is, AFAIK, why it as fallen into such disfavor. "Pigment Ink" rules! --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Bob Frost" <bob@...> wrote: > > >There has certainly been a movement to stand up and call > an inkjet an "inkjet" with pride but there are many out there that are still > calling inkjet prints "Giclee" in order to improve the perception of them in
> the market place. > > I cannot see how using a rude French word for ejaculate improves the > perception of a print as a serious piece of work. I just makes me (and > others) laugh at the stupidity of it. > > bob Frost. > > ----- Original Message ----- > From: "E Neilsen" <e.neilsen2@...> >
> Doing a image with a squirt gun loaded with ink could be a new art form, needing a great amount of skill. One could develop a whole line of precision squirt guns. Make tons of money selling them. Especially in selling the inks and papers needed to use them properly. Would we call that sort of image a Giclee too! > > I wonder if Jackson Pollock ever tried it? > > ; >) > > Ben I think these precision squirt guns already exist and are called airbrush, An artform in itself indeed. ;-) I tried while studying industrial design and failed miserably at using them... Denis
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "E Neilsen" <e.neilsen2@...> wrote: > > ....Perhaps the > slang you refer to is really a statement about all the piss poor quality > prints that flows over the art market.... I can't resist passing this on, Bruce Watson sent me the link. YOu have to watch to the end. I gotta get me one of these! http://www.youtube.com/watch?v=fKK933KK6Gg Tyler http://www.custom-digital.com/
2008-09-21 by Jules
What's this got to do with Dry Mounting Digital Prints? Jules --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "the_des_bois" <thedesbois@...> wrote:
> > > > Doing a image with a squirt gun loaded with ink could be a new art > form, needing a great amount of skill. One could develop a whole > line of precision squirt guns. Make tons of money selling them. > Especially in selling the inks and papers needed to use them > properly. Would we call that sort of image a Giclee too! > > > > I wonder if Jackson Pollock ever tried it? > > > > ; >) > > > > Ben > > I think these precision squirt guns already exist and are called > airbrush, An artform in itself indeed. ;-) I tried while studying > industrial design and failed miserably at using them... > > Denis >
2008-09-22 by Bill Morse
Ouch! [BG] I try to educate my customers (both artists buying limited editions, and end-user print buyers) to not call them Giclee, but if they insist, that's what I make. But I'm not going to jump into the "what's a photo" argument. Bill On Sun, Sep 21, 2008 at 10:13 AM, E Neilsen <e.neilsen2@...>wrote: > It felt good when they were making > them, but looking back not much to remember. > > Eric > > [Non-text portions of this message have been removed]
I can see a whole new industry! (just not sure what is it good, for; UHH!) Bill On Sun, Sep 21, 2008 at 2:32 PM, Tyler Boley <tyler@...> wrote: > --- In DigitalBlackandWhiteThePrint@yahoogroups.com<DigitalBlackandWhiteThePrint%40yahoogroups.com>, > "E Neilsen" > <e.neilsen2@...> wrote: > > > > ....Perhaps the > > slang you refer to is really a statement about all the piss poor quality > > prints that flows over the art market.... > > I can't resist passing this on, Bruce Watson sent me the link. YOu > have to watch to the end. I gotta get me one of these! > > http://www.youtube.com/watch?v=fKK933KK6Gg > > Tyler > http://www.custom-digital.com/ > > > -- Regards, Bill Morse Wm. Morse Editions http://www.MorseEditions.com/ [Non-text portions of this message have been removed]
2008-09-22 by Ernst Dinkla
Tyler Boley wrote: > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "E Neilsen" > <e.neilsen2@...> wrote: >> ....Perhaps the >> slang you refer to is really a statement about all the piss poor quality >> prints that flows over the art market.... > > > I can't resist passing this on, Bruce Watson sent me the link. YOu > have to watch to the end. I gotta get me one of these! > > http://www.youtube.com/watch?v=fKK933KK6Gg > > Tyler > http://www.custom-digital.com/ That's what the print side of Photoshop CS4 will look like then :-) A paint ball is in a way an encapsulated pigment particle. -- Met vriendelijke groeten,Ernst | Dinkla Grafische Techniek | | www.pigment-print.com | | ( unvollendet ) |
