Archivability of Epson luster/semi-gloss paper?
2008-11-03 by Roger
This may be a basic question but I recently acquired a pH testing pen
and have been using it on various papers I have.  My main papers,
Harmon FB Al and Innova Smooth Cotton 315 both appear to be
non-acidic.  However the Epson papers I use both look to be quite
acidic.
I am wondering how time will affect these papers.  The tests over at
Aardenburg of pigment inks on Epson Premium Luster do not indicate
much change in the paper as a result of decades-equivalent UV exposure
(loss of UV brighteners but that's about it).
What I'm wondering is how will the acids in the paper ultimately
affect the print?  How concerned should I be with works I've printed
on Epson semi-gloss or Premium Luster and stored in a dark album or
behind glass?
Re: Archivability of Epson luster/semi-gloss paper?
2008-11-03 by pr_roark
>... I recently acquired a pH testing pen
> and have been using it on various papers I have...
>  the Epson papers I use both look to be quite acidic.
Wilhelm rates the Epson Premium Glossy papers as having a long life.
While the surfaces are acidic, tear one open and test the paper
inside.  I think you'll find it is buffered, unlike most of the older
glossy inkjet papers.  Whether this is enough for long term storage is
may be another question.
I wonder also if the plastic in all these papers may be more of a long
term problem than the acidity.
Binder question
2008-11-03 by Peter De Smidt
With traditional pigments, the pigment is suspended in a binder, and
it's this binder which holds the pigment on the substrate.  Change over
time can happen with any element.  I.e. the substrate can deteriorate,
the binder can deteriorate, or the pigment can change.  With current
computerized ink printing, doesn't the coating on the paper act as the
binder?  Are there any issues with these coatings breaking down over time?
Re: [Digital BW] Binder question
2008-11-03 by Ernst Dinkla
There's still PVA in the inkjet binder how little that
binder may be compared to non-inkjet inks.
The paper coating will contain PVA as well but the coating
particles will bind the ink with their structure as well.
As many inkjet papers are waterfast today I think there will
be a some hardening happen in the drying process so plain
PVA it isn't.
Wilhelm doesn't test print's abrasion resistance or folding
strength but test like that are quite common in conventional
print testing. I must have seen some inkjet test results on
that subject too but can not recall it.
Met vriendelijke groeten, Ernst
|  Dinkla Grafische Techniek  |
|     www.pigment-print.com    |
|             ( unvollendet )            |
2008-11-03 by Roger
Thanks.  Another poster replied off-list:
"The paper base deteriorates before the OEM inks change.  The RC paper
bases are not archival.  The plastic coatings will peel from the paper
base with the ink on the coating.
Ben"
So it sounds like the acidity of the surface may be less an issue than
the fundamental construction of the paper.
That leads me to wonder if Harman FB Al or Innova Fibaprint White
Gloss are any more archival than the Epson papers?  They both seem to
have layers that may come apart.
I've seen some cracking with both after immersion in water (I use them
to make contact print cyanotypes- not their intended use but they
perform better than matte papers for tonal range) and the Harman is
curling pretty badly under heat from sitting in my south-facing window
as part of a fade test (it's not really fading).
Any thoughts?
Roger
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "pr_roark"
> Paul
> www.PaulRoark.com
Re: [Digital BW] Re: Archivability of Epson luster/semi-gloss paper?
2008-11-04 by Jim Goshorn
So then the Wilhelm tests only show what happens to the inks and the
coating and reflect very little about the paper itself? If that is
true, then a very important piece of the archival issue is missing
from the reports.
Jim
2008-11-04 by bill storm
Hi All,
In a former life I was co-chair of the ANSI IT9-5 standards committee that
took a look at the life expectancy of optical discs. The committee was
initiated in response to concerns that manufacturer's claims that these disc
and their content, CD's among them, would last at least a 100 years. That
clearly turned out to be a great stretch once objective scientific tests
were conducted.
Based on some of the findings the committee identified it would be fair to
believe any laminated or multi-layered media is likely to have issues over
time. I can't say with certainty but my assumption is that this principal
will likely apply to those types of photo papers as well.
Having said that I must commend this group for the incredible job you have
done influencing manufacturers to strive to provide long-lasting inks and
papers. The CD folks are still at ground zero. You might seriously consider
a regular program of recopying your important images and other data.
Keep up the good work.
Bill
> Ben"
> Any thoughts?
> Roger
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com<DigitalBlackandWhiteThePrint%40yahoogroups.com>,
> "pr_roark"
> > Paul
> > www.PaulRoark.com
2008-11-04 by frankbickelmeyer
Or buying vinyl records ;-)
Greetings,
Frank
> > Ben"
> > Any thoughts?
> > Roger
> > --- In
> > "pr_roark"
storage is
a long
> > > Paul
> > > www.PaulRoark.com
2008-11-04 by pr_roark
Bill Storm" <stormband1@...> wrote:
> ... ANSI IT9-5 standards committee ...
> would be fair to believe any laminated or multi-layered
> media is likely to have issues over time. ...
Even the matte papers have an inkjet receptor coating on them.  Do
you think this type of coating would also be at risk?
I've assumed that at least some would want to avoid even these
coatings.  So, Arches Hot Press water color paper (un-coated) has
usually been one of the papers I test and profile.  For display sizes
the new 1.5 pl printers can do a fairly smooth print on these.  If
there were a 24" 1.5 pl printer, I might actually be tempted to
replace my old 7500 with it.
On a related issue, Wilhelm does give some information on paper
longevity in the "Album/Dark Storage" column of his reports.  See,
for example column 4 in http://www.wilhelm-
research.com/epson/11880.html   At the very least when there is too
much yellowing, that affects the end point of the test.
I've speculated that one reason Wilhelm does not get further into age
testing is that, according to some conservation types I've
communicated with, doing such tests is much more difficult or
uncertain than fade testing.
What procedures did your ANSI IT9-5 standards committee use for
accelerated age testing?
2008-11-04 by sinar001
One of the main problems with papers coated for pigmented inks, is
they tend to be "micro porous". Unless this micro porous coating is
sealed after printing, it is vulnerable to atmospheric degradation.
This includes ozone, which can quickly oxidize dyes and degrade
pigments too!
Of course we are also faced with the various optical brightners used.
Some will actually turn yellow, as they fade.
When RC substrates became prevalent in B&W and color papers 25-30
years ago, there was concern about how archival the RC coated base
was. Early batches of papers were notorious for  exhibiting a
"cracked" look when exposed to UV. But of course, Kodak in the 70's
didn't think a print needed to last longer than 5-10 years. ;-)
Arches paper, of course uses a gelatin tub sizing, which could be
considered a "coating". But this paper has been around for a long
time, and seems to have accumulated a pretty good track record. The
same can not be said for the majority of the inkjet coated papers out
there. And the coatings and processes seem to change all the time. It
seems the only papers with consistency for the last 10 years come from
Crane and that German company.
It will be interesting how the new baryta papers stack up. I like the
look of the Ilford paper. I just wish they had used a rag paper base,
but I guess the new premium buffered wood pulp papers should be pretty
good for 50-100 years?
John Nollendorfs
> Paul
> www.PaulRoark.com
2008-11-04 by Bruce Watson
> pigments too!
> John Nollendorfs
If I remember correctly, all of the old darkroom papers from Kodak,
Ilford, etc. were alpha cellulose papers. I don't remember any that were
cotton rag. When archivally processed, they did fine. I don't see any
reason why alpha cellulose papers for inkjet wouldn't do at least as
well. Or am I missing something here?
Bruce Watson
I think being mixed into the paper fibers would prevent such things
as separation.
> The same can not be said for the majority of the inkjet coated
> papers ...
That's why I think some would opt for Arches watercolor paper if the
printing was smooth enough and the dmax high enough, and with 1.5 pl
printers, it probably can be good enough for large display.
On the other hand, in my fade testing the best coated papers have
done better than Arches.  But then it's market perception that counts.
>...I guess the new premium buffered wood pulp papers should be
> pretty good for 50-100 years?
Assuming they are 100% alpha cellulose (no lignin) they should be as
good as cotton for our purposes.  The shorter fiber lengths of the
alpha cellulose reduces strength, but that is probably not an issue
for photographers.
2008-11-05 by mantinieri
If you ever visited Italy, you probably noticed that any church older
than 100 years has a room where older documents, often related to a
Saint or to some religious activities, are displayed. No matter how
well those old documents are conserved, usually behind thick glass and
illuminated by controlled artificial light, they show signs of
deterioration, at the very least with yellowing of the paper and
deterioration of the structure of the medium. You can assume that the
substances present in the paper, paper sizing  and the ink are quite
natural, given the status of chemistry at that time and that the
amount of UV seen by those documents is pretty low, given the way they
are conserved. Nonetheless, the old documents deteriorate. The main
culprit is not UV. It is oxidations.
Those of you who visited my site knows that Daniela and me have done
extensive research on the chemicals involved in the manufacture of
inkjet paper and ink. Here is an example of what is in the paper:
http://www.patentstorm.us/patents/6808769/description.html
Commercial papers are a real disaster for fine art applications. The
manufacturer aiming at commercial applications have other worries than
conservation. Most notably: a) quick drying of the image, b) deep
blacks c) quick spray of the ink with low dot gain.
Besides PVA (the commercial White Glue), one of the worst chemicals in
the paper is silica, used for fast drying of the ink. Silica absorbs
any moisture in the environment, including the pollutants and keep the
latter forever.
Inks are even worst. The largest component of MIS Eboni or Ink
Specialist Matte Black, for example, besides water, is Diethylene
Glycol, a refrigerant close brother of Polyethilene Glycole used in
your car radiator. Ever noticed the warning of avoiding dropping
radiator fluid on your car's paint? Other substances in the ink are
dispersant to keep the pigments in suspension (like PVA again) and
surfactant to make the ink flow faster (like the ButylCellosolve
contained in your Simple Green degreaser).
Large Corporations wants to sell their stuff to us. They need the
imprimatur of archivability and advertise the few good stuff like
"Carbon Pigment" or "100% Cotton", but hide all the rest. Ever noticed
that Wilhelm Research only tests for UV? Under encouragement by one
person who contacted my regarding archival testing, I asked them if
they were willing to test the Carbon-Gelatine printing technique. The
did not even replied to me. I dont blame them for that. UV testing is
easy compared to testing  deterioration with time.
If archival for you means keeping your Family Photo Album through your
retirement, look no further. But if you are a fine-art collector
willing to invest hundred of thousand of dollars in a print, would you
put your investment in an inkjet print?
Thanks.
  Mantinieri
www.mantinieri.com
2008-11-05 by djon43
No real photographer or significant collector fantasizes about
hundred-thousand-dollar prints. Scam artists and victims engage in
that fantasy.
It's based on old tales from inflationary times. People who, back in
Ansel-as-investment times, invested in gold have earned less than they
would in a simple savings account.
> Thanks.
>   Mantinieri
> www.mantinieri.com
Re: Archivability of Papers
2008-11-05 by pr_roark
Mantinieri wrote, in part:
> church older than 100 years has a room where older documents,
> often related to a Saint or to some religious activities,
> are displayed. No matter how well those old documents are
On the other hand, there are papers that are more than 500 years old
that look pristine.  Museums like the Getty in L.A. have very old
books with beautiful white pages and vivid images.
What accounts for some papers lasting many centuries and others
deteriorating?
The findings of one study group of experts looking at
the "Composition and Condition of Naturally Aged European Papers,"
noted:
"... there is a belief that certain constituents such as gelatin
content, pH, degree of beating, trace metal content, and fiber type
may play important roles..."
The two factors that seemed to correlate well with good longevity
that this group focused on most were:
"... high pH values (pH = 7.0–9.9)...
"... sheets with high gelatin content (6–12%) all had high pH ..."
See http://aic.stanford.edu/meetings/abstracts/bpg_abstracts.html
(Scroll about 1/3 down the document to get to the "Composition and
Condition of Naturally Aged European Papers" abstract.)
This seems to be consistent with the composition and reputation of,
for example, the Arches Hot Press (un-coated) water color paper.
Re: [Digital BW] Re: Archivability of Papers
2008-11-05 by Mark Savoia
Any chance that all happened long before they even thought of proper
archival storing of them?
Mark
http://www.stillrivereditions.com
2008-11-05 by Bruce Watson
mantinieri wrote:
> But if you are a fine-art collector willing to invest hundred of thousand of dollars in a print, would you put your investment in an inkjet print?
Ah. Fear, uncertainty, and doubt (FUD) as a marketing technique. Quaint.
I reject your premise. Very few photographs of any kind are selling in
the $100,000+ USD range. Those that are, are bought for their unique
qualities, from beauty, to historical importance, to rarity. Prints in
this range don't sell because of the printing techniques. They don't.
Any of the AIPAD dealers (some of whom sell photography in this price
range) will confirm this.
Personally, I've bought a number of prints, from silver gelatin to dye
transfer to inkjet. One of my favorites is a beautiful IRIS print that I
bought for $225 CA. I was this Toronto artist's first ever print sale.
This was at least 15 years ago and the print still looks like it was
printed yesterday. Everything I've read about the early IRIS dye prints
indicates that the print should have faded into oblivion years ago. It
would have been a bargain at twice the price even if it had.
At my level people don't "invest" in art. They buy art because it brings
them pleasure. Sometimes just the pleasure of creating a collection.
Mostly just to enjoy art on their walls. Even at this level people
rarely ask about the printing technique.
People buy art for all kinds of reasons. But FUD isn't one of them.
Bruce Watson
2008-11-05 by wparsons
With regard to archival qualities, I recently took advantage of an Epson
offer and an InkJetMall offer to acquire an Epson 1400 and a Piezography
CIS kit.
Regarding archival qualities, view this page on the InkJetMall site:
http://shopping.netsuite.com/s.nl/c.362672/it.I/id.38/.f?sc=15&category=242
Bill Parsons
----- Original Message Follows -----
> deteriorating?
> noted:
> Paul
> www.PaulRoark.com
Very interesting paper. Thanks for pointing it out. I will refer to it
in my web pages. Almost all fine art papers have sizing to different
levels. Some of then are "internally sized" (I never fully understood
what that means). Usually watercolor paper have more sizing than
printmaking or etching papers (that I use) because they need to
receive more liquid. Infact that helps to increase the D-max as well.
Arches Watercolor was the uncoated paper we were able to obtain the
maximum D-max with (although with a special trick). Even higher than
the Magnani Pescia we use now. Sizing in fine art is almost
universally done with gelatine.
However, sizing is one think, paper coating is a totally different one.
   Mantinieri
www.mantinieri.com
2008-11-05 by Clayton Price
Until not so long ago, all the Epson papers were acidic. Complaints
by many about the longevity of Epson Archival Matte paper, rather
than correct the problem, resulted in them changing the name to
Enhanced Matte. The pH remained the same - definitely in the acidic
range - around  5.5, as I recall.  So much for Epson - who as
Mantinieri pointed out, is a large corporation who makes their money
from paper and inks, especially, which is the reason one can buy a
variety of quite good printers for  very reasonable prices.
That said, there are some errors in Mantinieri's logic -
																		First is Silica - one of the more stable compounds
around - Silicon Dioxide (basically sand, and the major ingredient of
glass).  It's formula, SiO2 already has the maximum number of Oxygen
atoms possible, and really doesn't react with the paper. Documents
over 100 years old in Italy or anywhere else could have a variety of
chemicals and UV causing degradation - Why?  Because papers had all
kinds of impurities and very likely were most any pH, since for the
most part there was no science to help them with the manufacturing
process. And I'm curious how he could know they weren't exposed to a
high UV content? After all, putting them behind glass, is a
relatively recent museum occurrence when looked at within the time
frame of history!
Back to the present, both the current Epson inks (Ultra Chrome K3,
and Jon Cone's Piezo inks both use some variation of Ethylene Glycol
as the major carrier to hold the dispersed pigments. Perhaps there's
some chemical reactions, but if the inks are truly pigments, the
chances are they remain mostly archival and stable. There could very
well be some reactions with certain papers, which could cause
staining, yellowing, etc. Am I wrong that Wilhelm only tests the
inks, but not the papers?
For whatever it's worth. real world testing of ink/paper
combinations, IMO, work best in a window, with a lot of sun. My
experience with Cone's inks has been that they hold up extremely
well, even after six consecutive months in a south facing  window.
I've not done this with the Epson Inks yet - I'm tending to assume
the testing I've read is mostly accurate.  I print almost everything
on Photo Rag paper, which I know is pH neutral.
If that doesn't impress you, consider - that putting a watercolor
painting in the window will give you perhaps 3 or 3 days before
noticeable fading starts to occur. (And that is primarily from UV &
oxidation). However if you take a look at 16th and 17th century
paintings, you'll almost never see color degradation, other than dirt
and varnishes darkening with time. When those paintings are cleaned
up, the experts tell us that they are almost exactly like they were
when created.  Why is this? It's because high quality pigments hardly
ever oxidize or fade from UV.
That said, who in their right mind would put a priceless painting
into a UV or bright sun situation? Ditto for watercolors, both
contemporary and historic, as well as old and new photographs -- no
matter what process they were crafted from?
Finally, I'd ask Mantinieri what process you would use and/or suggest
to others, for creating our own contemporary photographic prints that
will last? Certainly "C" Prints both conventional and digital (both
of which use the same chemistry) are no more archival than some other
processes, no matter what the hype about them is, and my guess is
that they would be less archival than carbon pigment prints on cotton
pH neutral papers.
Clayton Price
Mantinieri wrote:																											.... You can assume that
the substances present in the paper, paper sizing and the ink are
quite natural, given the status of chemistry at that time and that
the amount of UV seen by those documents is pretty low, given the way
theyare conserved. Nonetheless, the old documents deteriorate. The
main culprit is not UV. It is oxidations....
Dear Clayton,
  thanks for being interested in my opinions.
Most of the aging processes you mentioned and the tests you also
mentioned (south window test, Wilhelm Research tests, Inkjet Mall
tests, etc.) are based on effect of UV rays on the materials of the
print. The UV do not make chemical reactions (they are photons), but
rather, physical reaction: they break some molecules and create free
radicals which are very reactive and cause the actual degradation,
mostly trough oxidation. But the molecule to be broken must be there
in the first place. Therefore UV's only accelerate the process of aging.
Aging is almost always a consequence of oxidation. The documents in
the churches or monastery hardly received any UV because sacred
documents were never exposed to publics. They were, instead, conserved
accurately by religious peoples (like the monks in the monastery).
Some of them deteriorated any way and some others, as Paul observed,
are still intact. Isn't the reason that obvious?
It depends on the substances contained in the paper and the ink.
You are certainly right. Impurities are among the culprit. They are
mostly heavy metals, oxidizing very quickly. The purest pigments dont
fade (remember, though, that paintings are coated with linseed oil,
which protects them from pollutants not from UV). Not the only
culprit: whatever is in the paper (including sizing) and the inks
makes a large contribution.
My suggestion for making fine art print is: shop in a fine art store,
not in computer store. We are lazy and pretend to make fine art prints
by clicking the mouse on the print button of your computer program.
Corporations know that and sell us their quick solutions with the
illusion of turning a newbie into an artist overnight.
Fine art is never quick. How many hours did you spend in your darkroom
washing and toning your fiber based silver prints? Those who did it
know the answer.
Another suggestion I would give is: do not trust the hype from large
corporations. Fifteen years ago I was making Cibachrome in my
darkrooms and sold them as 100 years archival, as was the hype of the
time. I process them myself: fresh chemicals and long wash in running
water. The ones I have today (stored in a dark place), all have
shifted colors!!!
Today, I would recommend two processes for fine-art printing:
1) Silver-gelatine printing on fiber based paper, with appropriate
washing and toning. If the chemicals are washed away, what remains are
just the paper, the gelatine and the toned silver. All very long lived.
2) Inkjet printing with appropriate paper, ink and methodology. By
appropriate I mean the following:
a) Papers. Please, stop at Blick or any other large fine art store and
just touch a fine art (uncoated) paper made with 100% cotton. Can you
tell the difference from a coated inkjet paper? They are made to last
centuries
b) learn to print on that paper. It is not easy. You need to
experiment as any artist does. Understand that those papers reacts in
a different way than inkjet paper, and also from one another. Paul
Roark and Clayton Jones are the people to learn from.
c) Forget about that bloody d-max. It has nothing to do with the
beauty of your artwork. If you print with ink, you must compare your
print with similar techniques like lithography, etching or
"acquaforte" (I dont know the English translation for it), not with
photographs. If you want to make fine art with high d-max, go back to
your darkroom
d) ink. This is the difficult part. Fine art artists prepare their own
oil paints or inks starting from pure pigments. The only premade ink
that I know to be suited in fine art is India ink (in Italy, China
ink). We tested it in an inkjet and it is a nightmare, because you
need to keep the printing head wet all the time (as with Rapidograph
pens). Preparing your own inkjet fine art ink is very easy because you
can do that with natural ingredients. What makes it impossible today
is that you will not find over the shelves the pigments with the
correct diameter (much smaller than what available at fine art stores
for oil paints). I have tried to purchase them in small quantities and
had no success. Therefore, we need to use what is available
commercially and trust the seller. OEM ink usually has dyes and
pigments (for better d-max and colder tones). Personally, I stay clear
of it. Brands I am comfortably with are: MIS Eboni, IS Matte Black and
Cone's.
e) dilute them with your own base made with natural substances (as all
fine art dilutives - also India ink contain all natural ingredients).
You know what you put in. It will probably not hold in suspension the
pigments for long time. Then, shake them often and prepare them as
freshly as you can (as you would do with the chemicals in your darkroom).
f) wash you final print in running water. It takes away the chemicals
that were in the pre-made ink.
  Mantinieri
www.mantinieri.com
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Clayton Price
> frame of history!
> pH neutral papers.
> Clayton Price
RE: [Digital BW] Re: Archivability of Epson luster/semi-gloss paper?
2008-11-05 by David Whistance
Dear Mantinieri
Thank you for this and your other interesting postings.  I agree with much
of what you have said, however I think you need to add another process to
your list - Platinum/Palladium.  It meets all of your requirements and is as
archival as your other examples.
David Whistance
PS - I am afraid that by your standards I have "sold out" and use the Cone
K7 inks for my proper B&W prints.
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com]On Behalf Of mantinieri
  Sent: 05 November 2008 23:02
  Subject: [Digital BW] Re: Archivability of Epson luster/semi-gloss paper?
  Dear Clayton,
  know the answer.
  shifted colors!!!
  centuries
  your darkroom
  Cone's.
  Mantinieri
  www.mantinieri.com
  > frame of history!
  > pH neutral papers.
  > Clayton Price
2008-11-06 by dlruckus
Hi Clayton.
I took what he said to mean that the silica absorbed pollutants from
it's environment and held them, much as something like activated
carbon would do, thereby keeping them in contact with the inks for
extended periods and causing ongoing damage.
> Perhaps there's
I think the literature refers to current pigments used in inkjet inks
as dye stacks in the technical sense. ie:more stable forms but of the
same or similar chemical compositions as the soluble dye forms. They
are not at all the same as mineral pigments used in centuries old
paints. The pure carbons would be the exceptions of course.
Duane
2008-11-06 by mantinieri
with much
process to
and is as
Yes! Absolutely.
  Mantinieri
www.mantinieri.com
2008-11-06 by Seth Rossman
*Because they used acid when making papers back then.*
2008-11-06 by pr_roark
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Seth Rossman
This comment was from Mantinieri, I believe.  Unfortunately, I have
not yet had the opportunity to tour the old Italian churches.
However, many of the really old papers are better than those made
more recently.  They didn't start to grind up trees for paper until
the last century.  As I understand it, that is when the average paper
quality went south.
2008-11-06 by djon43
Acid doesn't seem to have been used for paper making until some time
in the 19th century...Googling appears to support that. If you can
cite a link to the contrary, please do. Older paper has deteriorated
for a host of other reasons.
Use of wood pulp was relatively recent.. it required acid from 19th
sometime until the late 20th..it's been eliminated in some "green"
papers to reduce environmental damage.
2008-11-08 by Mark MacKenzie
This is basically correct.  Until ca. 1840's most and the best papers were made of cotton.  Cotton was expensive to make paper from and so came the profession of the "rag picker" collecting used cotton clothing to be made into cotton  based paper.
The Kraft sulfite paper making process was invented in the 1840's (remembrance from graduate school as to actual date) allowing the commercial manufacture of paper from soft wood pulp.  This meant that great amounts of lignin were now included in the resulting paper.  The acid residues from the manufacturing process plus the deterioration prone lignin (which produces more acids itself) and even more complicated chemistry are the basis of the modern self destructing paper.
Through this time most fine art papers had either a high cotton fibre content or were 100% cotton so they usually did not suffer from the same problems.  Thus the sad situation where paper, books, etc. made before 1840 almost certainly look better now than 20 year old newspapers and pocket books which usually were made from the absolutely cheapest wood pulp paper with the least processing for life.
Those who have had the privilege of viewing very old works of art on paper or books should know that the modern concept of "white" paper is just that a modern concept involving bleaching with very nasty materials.  You will also have noticed that when you are viewing old books the color change deepens as you get to the edge of the paper.  This comes from handling and from deteriorating agents creeping in from the outside environment from the edge of the page when the book is closed.  This could be smoke, oils, perspiration, etc.
Cotton  itself will deteriorate but at a very much lower and slower rate.  Its degradative products are yellow brown in nature BUT are water soluble.  Thus old works of art and books made from cotton and which are badly yellowed can often be totally refreshed by selective washing techniques as long as the ink, pigments, etc. allow this.  Lignin containing paper is very hard to do this to and obtain the same clock resetting results.
I have been watching this thread with great interest and some trepidation.
The more that we digital printers and artists producing "born digital" art come to think in terms of permanence of the image and the image substrate and their components the more you tread the journey of the master artists of the classical and Renaissance periods.
You are going to have to examine absolutely every component of your art.  The least permanent and most prone to change aspect of it determines the "archivalness" of the entire work.  This extends to the use of "glop" as a final coating for the ink image and on through the protective coatings you employ to finish your work.
I suggest strongly that you look at the model developed over the centuries, rethink it in terms of your modern materials but follow the model.
The time was that a painting or print purchaser demanded their money back when the painting or print obviously deteriorated and got it too.
The evolution of the digital art work will get there to.
Mark MacKenzie
Art Conservator & Wet Plate Photographer
Alcalde, New Mexico
2008-11-08 by Jim Goshorn
On this subject, I looded at archival data from Wilhelm's site one
for prints made on the 9800:
http://www.wilhelm-research.com/epson/9800.html
and the other for Hahnemuhle papers printed on the 7800 (data should
comparable):
http://www.wilhelm-research.com/WIR%20Hahnemuhle_2008_10_20%20/
Hahnemuhle%20Inkjet%20Papers.html
and found something very interesting:
Premium Luster 250 (OBA's and RC) rated 71 years under glass, 165
under UV, 48 with bare bulb and >200 in dark storage.
Photo Rag Pearl (no OBA and Rag) rated 64 years under glass, 126
under UV, 35 with bare bulb and >200 in dark storage.
With the recent discussions on OBAs and paper bases, how is it
possible for Premium Luster to last longer? Not only that but:
Fine Art Pearl (OBA's and Rag) rated 82 years under glass, 148 under
UV, 46 with bare bulb and >200 in dark storage.
So of the two Hahnemuhle papers, the one with OBAs outlasts the
"purer" paper.
Am I misunderstanding something?
Thanks!
Jim
2008-11-08 by pr_roark
Mark,
Thanks for taking the time to contribute to this thread.
Is there a specific model you're referring to or just saying that, in
general, studying the history of what has been found to be most
stable?  Do you have recommendations in terms of sources of information
along these lines?
2008-11-08 by Roger
> "purer" paper.
I don't think the OBAs is the significant difference between the
papers.  I've had Harman FB Al in a south facing window since last
summer and the paper base has moved from cool to neutral but doesn't
seem to have other negative effects.
You can see this site (blue files are downloadable for free):
http://aardenburg-imaging.com/cgi-bin/mrk/_4102c2hvd19kb2NfbGlzdC80
Any look at the paper white patches as they get bombarded under UV light.
There is also a free 1 hour discussion of image permanence with
Wilhelm here: http://www.luminous-landscape.com/videos/wilhelm-audio.shtml
I'm listening to it now.
2008-11-08 by Seth Rossman
Well, yes and no.
With the topic being "archival" note that the dark storage for all is
 >200.  This should assume the same temp and humidity for each also.
Since archival IS a dark storage condition in a controlled environment,
anything to do with differences in display condition is pretty irrelevant.
Really, Wilhelm should differentiate.  However, mass marketing uses the
term archival outside its true meaning/conditions.
What you are seeing differences in as display characteristics (or
longevity).
Seth
Posted by: "Jim Goshorn" jgoshorn@...
<mailto:jgoshorn@...?Subject=%20Re%3A%20Archivability%20of%20%20Papers>
  jim_goshorn <http://profiles.yahoo.com/jim_goshorn>
            Sat Nov 8, 2008 7:46 am (PST)
    <http://www.wilhelm-research.com/epson/9800.html>
    comparable):
    <http://www.wilhelm-research.com/WIR%20Hahnemuhle_2008_10_20%20/>
    and found something very interesting:...
> longevity).
OK, but shouldn't the longevity also be better for the papers with no
OBAs and no resin coating?
Jim
2008-11-08 by Michael King
On this topic you might be interested in a video interview with Wilhelm just
released here;
http://luminous-landscape.com/whatsnew/
Mike
2008/11/8 Jim Goshorn <jgoshorn@...>
> > longevity).
> Jim
2008-11-09 by Clayton Jones
>>"purer" paper.
In addition, there are different types of OBAs.  We use the term
broadly, but when I did some research on the subject for an article
(#5 at the link below) it was pointed out to me that OBA technology is
improving along with everything else and newer ones are much better.
There is no way for us to know what or how many types are used in any
given paper, in what combination, whether they are in the paper, the
coating, or both, and in what quantities - paper makers keep their
formulas secret.  Just saying a paper has or doesn't have OBAs doesn't
give us enough information.
Not only that, but we can't always believe what the paper makers say.
During my research it turned up that a popular paper by a major maker,
advertised as having no OBAs, actually had "small" amounts in the
paper "to ensure uniformity of color" across production batches, but
"not enough to affect print longevity".  As a result of this discovery
a major vendor who was selling a repackaged version of the paper
changed the wording on their web site (they later discontinued the
paper, although I don't know if the OBA issue had anything to do with
that).
I know this probably muddies the waters for us, but there it is.  We
should beware of over-simplifying the subject.  If we accept W's tests
as valid then perhaps they should be the basis of choosing our papers.
For example, I use VFA a lot with K3/ABW.  According to W, VFA has
"some" OBAs (I suppose that means a small amount, other papers are
listed as "yes" or "no").  Here are his results for this combination:
Unprotected > 112
Glass > 115
UV Glass > 125
Dark > 200
...and with the new K3-Vivid Magenta/ABW
UV Glass > 400
That's good enough for me.  I've been doing a direct sunlight torture
test on a VFA print for several months and hope to report some results
soon.  Might be interesting...
Clayton
I-Trak 2.1   http://www.cjcom.net/itrak.htm
2008-11-09 by mantinieri
Dear Mark,
  thank you very much for your opinions. I am happy as I know now that
I am not alone in pursuing fine-art conservation grade in Black and
White Digital printing. Your trepidation is exactly what was behind
the two years effort that concluded with the Carbon-Gelatine technique.
Unfortunately, the results of the tests by Wilhelm Research and by
others are  playing a negative role in the effort of pursuing fine art
archivability. Their conclusions are used by us to validate current
inject techniques in a lazy approach, rather than encouraging us to
purse new techniques. The fact is that, although the results of their
test are  very important on they own, they are misused by the vast
majority. In other word, it is just another excuse for us to keep
using commercial solutions. Look at how many time they are advocated
in this tread alone. I think I will take the link to Wilhelm Research
out of my web site.
I especially appreciated this comment of yours:
art.
Although the medium, the ink base and the gelatine coating in the
Carbon-Gelatine approach are fine in archival terms, the undiluted ink
is not, being the weakest ring of the chain. If <100 nm carbon
pigments were available, making that ink  would be pretty easy.
However, fin art carbon pigments are much coarser than that. To grind
them to the correct size will require a ball mill and <100nm filters.
 I am not sure how easy would that be. However, in order to make the
undiluted ink, you still need to disperse the pigments into a
dispersant. The dispersants used in commercial ink are not fine art
grade. Those used in fine-art are colloidal and will easily clog
permanently the printer. Do you have a suggestion for an archival
grade dispersant?
Thank you very much.
  Mantinieri
www.mantinieri.com
2008-11-10 by Mark MacKenzie
> >>"purer" paper.
In general, if you are chasing permanence then stay away from using any
paper using OBA's.  They are not permanent, as they change so will the
presentation of your print.
OBA's are introduced into some papers at various stages.  Those that
are in the paper pulp tend not to move around much but will still fade
and degrade and change ? into other chemicals which may or may not
further degrade the image base.
Other OBA's are added in the ink receptor coating.
We have found that some of the textile products we use for attaching to
textile artifacts for identification purposes have OBA's of the latter
type.  These can not only rub off onto the artifact but also transfer
in solution form if there is an accidental wetting.
We have put a call back through out our museum system prohibiting the
use of these textiles.  When contacted, some of the manufacturers or at
least the wholesalers did not know anything about the addition of OBA's
to their product.
For us, simply looking at a suspect material under UV light shows
immediately whether OBA's are present.  I will try some of our
photodocumentation inkjet paper (Lyson) at the museum and see.  But
almost any UV source (forensic type LED flash light) should work.
Mark
> >>"purer" paper.
to their product.
Mark
2008-11-10 by Ernst Dinkla
>>>> "purer" paper.
Henry Wilhelm recommends not to use paper with OBAs in view
of the changing paper color in time.
On the other hand he says that he has no evidence that it
will influence other aspects of permanency later on.
It's usually a dye as far as I know and I wonder what it
could become to do harm to good fibers.
|             ( unvollendet )            |
> released here;
Listened to the audio files and it is a nice summary of the
issues.
The RC papers could have been discussed a bit more
thoroughly in my view, there are still questions to be
answered there. I heard no real condemnation of digital RC
papers
in that interview.
I have seen an estimation that RC papers structurally should
last
about 75 years so one shouldn't write them off too easily.
Henry Wilhelm likes to refer to Fiber papers and isn't happy
with the term barite for some of the papers. It isn't
explained but my best guess is that the actual barite
content varies a lot within the category. The main thing
is that the Fiber papers try to give the air dried analogue
photopaper look but they are not that related in their
composition.
I see on Wilhelm's pages that he tested both Harman Fiber
qualities and Epson Exhibition Fiber Paper and the results
are good. The HP Vivera pigment inks perform much better on
the Harman qualities than the Canon and Epson pigment inks.
A quick estimation says 2x the lifetime.
Good to see that Hahnem\ufffdhle and Harman as third party paper
manufacturers have independent testing done (again).
|             ( unvollendet )            |
2008-11-11 by Mark MacKenzie
Wilhelm's tests are still accelerated aging tests.  Who knows what in  time will develop.  You are right in that it may never be harmful.
Mark MacKenzie
Alcalde, New Mexico
grade dispersant?
Mantinieri
www.mantinieri.com
I am sorry Mantinieri but at this time (and perhaps never) I don't have any advice on this issue.
Mark MacKenzie
Alcalde, New Mexico
2008-11-11 by sinar001
Inkjet dispersants, need to keep the pigments in better suspension
than "fine art grade" colors. But Wilhelm says that HP inks are pretty
darn near indistructable, giving them over a 200 year fade resistant
rating.
Some of the most high-tech developments in archival, large gamma
colors have come because of the ink jet industry in the last 10 years.
It's hard to predict exactly how "archival" our products really will
be. I guess we'll find out in another 100 years or so. Amazing, how
well some of the pigments from early art have stood up to the ravages
of time and light.
John Nollendorfs
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Mark MacKenzie"
> grade dispersant?
> Mantinieri
> www.mantinieri.com
> Mark MacKenzie
> Alcalde, New Mexico
2008-12-08 by Roger
Just to return to this thread, I know that it looks like the acid
contents of papers is far from the most important attribute, but I
thought I'd report what I found.
I think it was Paul who mentioned that there may be differences
between surface acidity and the acid levels found in the paper.
I'm awash in discarded test prints here so I used my pH pen on a few
and tore them open to expose the paper inside.
It's not precise but yellow-green is acidic and blue is basic.  I use
the term "base" to refer to the exposed paper fibers within glossy and
matte papers
Here's what I found:
Epson Premium Semi-gloss: acidic surface, neutral-basic base
Pictorico Premium Photo Glossy: acidic-neutral surface, basic base
Epson Premium Semi-matte: neutral-basic surface, basic base
Epson Premium Luster: acidic surface, basic base
Innova SW Cotton 315: basic surface, basic base
Fuji Crystal Archive glossy (thin version): basic surface, basic base
Epson Ultra Premium glossy: basic surface, basic base
Museo Crane Silver rag: acidic surface, basic base
Harman FB Al Baryta Glossy: basic surface, basic base
>   -----Original Message-----
>   From: DigitalBlackandWhiteThePrint@yahoogroups.com
mantinieri
paper?
>   Dear Clayton,
aging.
>   know the answer.
>   shifted colors!!!
lived.
>   centuries
>   your darkroom
>   Cone's.
darkroom).
>   Mantinieri
>   www.mantinieri.com
ingredient of
>   > frame of history!
dirt
suggest
that
other
cotton
>   > pH neutral papers.
>   > Clayton Price
the way
2008-12-08 by pr_roark
Take a look at the B&W ratings Wilhelm gives Epson Premium Luster in
his latest tests, for example
http://www.wilhelm-research.com/epson/11880.html
The B&W display for Premium Luster -- bare bulb (no glass) -- is >315
years.  Nothing else is close for that bare bulb category.  (Color is
45 years for that paper bare bulb.)
2008-12-08 by Roger
Thanks.  It's odd that luster does so much better than Epson semi-matte.
It's too bad, too- I don't really like the luster surface- to me it
looks "wet" with the K3 inks.  I much prefer Epson premium semi-matte,
Harman FB Al, Innova white semi-matte 300, etc.
Roger
> Paul
> www.PaulRoark.com
2008-12-09 by Jon Cone
Roger,
You may be misunderstanding.
Wilhelm only is making predictions of light stability - not paper
archival qualities. This particular paper should never be used for
anything which you wish to be archival or last a very long time. The
presence of Acid is the most defeating issue in regards to this
subject (Archival). These are commercial grade papers, not fine art grade.
Paul was just pointing out the prediction of ink fade on them to you.
Unfortunately, Wilhelm is not equipped to nor does he make predictions
on how long the actual media might last. Fortunately, there is
centuries of data available and there is no doubt that papers with
acidic content will yellow and deteriorate in time - sometimes as soon
as 3 years.
Also there is a very sobering read for those using color inks or color
inks which also include multi-level blacks to print black&white - that
read is about the failure of the current Wilhelm ratings to pick up
fade in near neutrals etc... The article is actually by Wilhelm himself:
www.wilhelm-research.com/istar/WIR_IST_2007_09_HW_DS.pdf
Fortunately he has proposed a new standard which is now open to the
public. New fade prediction facilities which can handle the larger
targets (more than 300 patches should be tested rather than less than
12) are beginning to surface! I bought an Atlas and am now testing
these materials with the new i*metric to see how close or how far they
are from the original Wilhelm predictions. I am also using a more
realistic light source (sunlight filtered through glass instead of
fluorescent.)
But try not to confuse "Archival" and "Light Stability" as they are
two different subjects all together. Think of a sheet cake. You can
print on one actually with Epson K3 inks. (don't ask, but you actually
can...)  You could test to see how long before that ink might fade...
 But certainly you know the cake will eventually rot - and these two
life ratings are mutually exclusive of each other. The cake is
obvious, but unfortunately acid paper is not when respected
institutions make ink light stability predictions on them. Its like
turning back all the archival education done in the 1970s...
Paper with an acidic content should never be used for fine art or for
photography which is intended to have a long life. While it is
possible to limit the exposure of light to a work of art made with
fugitive inks and preserve it well into the future, you can not
prevent a paper that is self-destructing from self-destructing. Sheets
with acidic surfaces or bases will eventually yellow and then  their
structures will begin to decay.
There is no use printing with pigment inks on such an inferior support
base! Spend your money on acid-free papers, and use these commercial
grades for just proofing.
regards,
Jon Cone
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Roger"
semi-matte.
> Roger
> > Paul
> > www.PaulRoark.com
2008-12-09 by sinar001
In regards to paper bases, I would like to point out that  contrary to
what Jon may have lead you to believe, most modern paper bases are
"acid free". Only the cheapest wood paper products such as newsprint
are not sufficiently buffered to prevent yellowing.
See http://en.wikipedia.org/wiki/Acid-free_paper
Yellowing can still occur, mostly due to UV whitening agents fading,
or from atmospheric pollution. Pigmented ink jet papers are especially
prone to atmospheric conditions, since most use a micro porous ink
receptor layer that is quite susceptible. This is one reason why you
should seal any pigmented ink jet paper with proper archival spray or
have it sealed under glass in a frame. Remember the orange fade of the
first Epson 1280 dye prints? This was traced to ozone attacking the
dye in the microporous Epson paper.
RC papers, are another story though! This has been a source of
controversy since they were introduced back in the 70's. The early RC
papers were susceptible to "crazing" or cracking condition of the
polyethylene layers, especially when exposed to UV. The products today
should be much more stable. Estimates of life are in the 50 year
range. This is one reason why the baryta papers are coming into
vogue--a more stable paper base. But I have not seen any data on the
life of these papers.
John Nollendorfs
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Jon Cone"
<jon@...> wrote:
> Roger,
grade.
> as 3 years.
> fluorescent.)
> regards,
> Jon Cone
> semi-matte.
> > Roger
Luster in
>315
(Color is
> > > Paul
> > > www.PaulRoark.com
John,
I am only "leading" people to believe that if an inkjet paper has an
acid base or coating, then it has an acid base or coating.
That is pretty simple. It's not like putting lipstick on a pig or
anything.
Jon
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "sinar001"
> John Nollendorfs
> <jon@> wrote:
> > Roger,
> grade.
> > as 3 years.
himself:
> > fluorescent.)
> > regards,
> > Jon Cone
> > semi-matte.
semi-matte,
> > > Roger
> Luster in
> >315
> (Color is
> > > > Paul
> > > > www.PaulRoark.com
2008-12-10 by pr_roark
> archival qualities.
While I'm a skeptic about all these RC type papers, I think Wilhelm is
doing some accelerated age testing.  This is what gets reported in
the "Album/Dark storage" category, and he rate Premium Luster as ">300
years."  Personally, I'd stick with buffered cotton for longevity.
Accelerated age testing is not that good at its best.
2008-12-10 by Jon Cone
Paul,
Agreed!
If one takes that rating on face value, it would be the first
non-archival paper in history to last three centuries...and it would
not even have to be held in dark storage in one of the vaults under
the Brooklyn Bridge.
In general, pigments and the new altered-molecule approaches to dye
ink are making colorants that are very good and very fade-resistant.
The big ugly gorilla in the corner which everyone has been ignoring
has always been the inkjet-coated-paper.
Got bananas?
Jon Cone
> > archival qualities.
> Paul
> www.PaulRoark.com
Jon,
> ignoring has always been the inkjet-coated-paper.
I agree.  I've always kept some Arches Hot Press (un-coated) watercolor
paper around to test, and I must say the 1.5 pl printers are capable of
making some reasonable images on it now -- good enough, I believe, for
large display.  The 3-MK 1800 can, for example, hit 1.6 dmax with Eboni
firing from the 3 channels.  (True, the last 5% gets a bit blotchy.)
For ultimate smoothness Arches HP can't touch the coated papers, but I
think there are artists and purists who will go the un-coated route,
particularly if there were a 1.5 pl 24" printer.  So, that is what I'm
waiting for.
2008-12-11 by Roger
I think this discussion has now completed a full circle.
It originally started with a discussion of acidity as a limiting
factor for print life then evolved to a discussion of all the other
weaknesses of modern inkjet inks and papers (acids, OBAs, surface
separation, binders in ink, oxidation, etc)
Then I posted this reply with my own results about acid levels in a
few paper coatings and papers using a pH pen:
http://tech.groups.yahoo.com/group/DigitalBlackandWhiteThePrint/message/94308
At this point I'm not sure of the relative importance of the factors
that have been raised and skeptical of how long any of these prints
will last.  As long as it's longer than my Fuji Frontier prints I'm
happy as that's my alternative.
Will Epson luster, despite its RC composition, OBAs and surface
acidity really outperform cotton papers like Somerset Velvet?  In
Wilhelm years, yes, apparently, but in reality?  See here for the
9880: http://www.wilhelm-research.com/epson/9880.html
Also, John, the Harman FB Al Baryta doesn't do all that well relative
to standard Epson papers in the Wilhelm tests- except when used with
HP pigment printers.
http://www.wilhelm-research.com/WIR%20Harman%202008_10_22/Harman%20Inkjet%20Papers.html
<jon@...> wrote:
> John,
> anything.
> Jon
2008-12-11 by mccormick.mark59
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Roger" <rsmith02@...> wrote:
> acidic.
> behind glass?
Sorry I'm late to the party. This thread has many interesting comments, and I would like to
jump in at many points. Yahoo's rather non-intuitive threading of comments makes it
hard for me to know how the conversation has progressed, so let me just tap in here to
make a few observations.
Accelerated light fade tests are relatively straight forward. While we can argue over
spectral properties of the light source, reciprocity failure of high intensity short-time
duration testing, etc., different approaches can give us at least some reasonable insight
into the sensitivity of various color forming systems to light.  That said, the RC papers like
Epson Premium Luster have a convoluted problem that is very hard to mimic in
accelerated tests. The TiO2 whitening layer converts low level light energy to form free
radicals which do two things. The free radicals oxidize the silver particles in traditional
silver halide B&W prints, and they embrittle the polyethylene coatings that encapsulate the
paper core in any RC type print paper. Anti-oxidants have been added which can be
shown to improve the product significantly, but a sensitive longevity test for these
materials has still proven to be very illusive.  Traditional thermal aging tests (WIR does run
these to predict dark stability) can do a pretty good job at predicting thermally induced
yellowing, staining, and even loss of certain physical properties (which leads to cracking
and delamination). However,  the light-induced free radical issue in RC papers greatly
complicates matters, and no good test that could replicate real world anecdotal
observations about RC paper was ever developed. Thus, RC papers represent a wild card
in image permanence predictions even to this day. We can test to see that they don't
discolor and even predict that heat alone won't embrittle them for X number of years, but
none of this predicts true performance on display where both heat and light interact.
My conclusion: if you want to raise your chances of working with a 300 plus year stable
substrate, stick with tried and true materials. But that's easier said than done with inkjet
technology. As others in this thread have noted, this philosophy will constrain us to
papers that use natural sizings only and have no special image binder layers. Even
"archival" processed selenium toned silver gelatin prints have a gelatin binder that is
susceptible to environmental humidity cycling. Photo conservators have already been
called upon to treat some archivally processed Ansel Adams prints that have cracked
because they were displayed and stored in seasonally cycled northern winter climates that
stress the hell out of the gelatin coating (i.e,  by cycling from <20%RH winter to >70% RH
summer conditions). Gelatin is an amazing polymer. It can tolerate several thousand
pounds per sq inch of tensile stress (higher than some epoxy glues), but humidity cycling
can induce these levels, and ultimately after many cycles, microcracks and voids appear,
then finally large, ugly, highly noticeable cracks.
The whole acid-free issue in photo conservation is another can of worms. Both technicolor
motion picture film and Kodak Dye transfer prints have proven over time to be much more
stable than other color imaging systems. Yet both employed approximately 1% acetic acid
final rinses, so the image layer is without question acidic. Also, consider ordinary news
paper that has such a bad reputation. Yes, it discolors significantly within days due to the
light reactive lignin-containing wood pulp, and yes it is an acidic "low stability" paper. Yet
100 year old examples abound. They are more brittle and they are more discolored
compared to other papers, but their
intended function (ie., reading the printed type by holding the paper up to your face) is
still working just fine.  Had they been stored in more benign environmental conditions,
they'd be
even more flexible and less discolored. My point is simply this: Paper pH alone does not
dictate short-lived paper performance.
No media can circumvent the laws of thermodynamics. A cynic would say that all art is
"performance art". We can take steps to make it more stable and less environmentally
sensitive so that, all other things being equal, it will withstand typical human
handling,viewing, and storage conditions much better.  Like many of you on this list, I
work hard in my own personal printmaking to do just that. Also, some artwork ages
"sympathetically" over time better than others. When the patina of age is not
objectionable, we often accept it, and even admire it.
Note the debate which occurred when the Sistine Chapel was restored not too long ago.
Some experts of antiquity were outraged and felt that the restoration went too far. B&W
prints often age more sympathetically than color prints. Color prints for the most
part just get ugly when they fade, but yellowed 19th century albumen prints
merely enhance our sentimentality about the Victorian Era.
A good steward of an important work of art on paper is also going to take serious
steps to manage time on display and to create greatly superior storage conditions. Drop
the storage temperature about 5 degrees centigrade and most works of art on paper will
degrade at
about half their rate compared to the 5C higher temperature environment. Store in cold
storage, and you will have thousands of years of pristine condition. Cold storage is why
scientists are discovering nearly fully intact 20,000 year old Woolly mamoth carcasses.
How long wood the flesh have taken to fully decompose at normal room temperatures? A
couple of years at best.
I can see that my post is beginning to sound like a rant, but I hope my comments have
been constructive and will help others to better gage their concerns about acidity, RC
papers, and the role of environment in image permanence. Despite the more than quarter
century that I've been involved in image permanence research, I don't consider myself a
zealot who demands that artists use only the most stable processes. However, I do believe
that an informed artist is better prepared to make materials and process choices that meet
his or her needs, and this belief keeps guiding my research.
Best regards,
Mark McCormick
http://www.aardenburg-imaging.com
2008-12-11 by Jim Goshorn
So if I have the general gist of the conversation, you can use a
luster paper like Hahnemuhle Photo Rag Baryta or a matte paper like
Epson UltraSmooth which are both fairly pure (no OBAs, cotton rag)
and after that you just keep your fingers crossed that they will
prove to be as archival as the preliminary tests anticipate?
Jim
