Emax
EIII harddisk boot problem
2003-02-13 by brian_ronn <brian_ronn@...>
I have the OS2.42 boot disc (the latest OS) for the EIII. I've set
the scsi id this way: floppy id=0, hd=1 and EIII=6 but the EIII
won't boot from the ST51080N hd. I have also formattet the hd and
copyed the software from diskette to hd, but the EIII won't boot
from the hd only from floppy. I can access banks on the hd and
access any module via the frontpanel but just won't boot.
Do you know the jumper settings on the Seagate ST51080N hd?
I'm thinking about putting the hd to an external hd-case and I would
want to disconnect the power of the center ventilator which cools
the hd (because of the noise), would you advise me not to disconnet
the ventilator maybe because of the heat level on the pcb boards?
Thanx
Brian
Re: [emax] EIII harddisk boot problem
2003-02-14 by Colin Ross
Hi There
do not put the disk in the floppy drive so it will search for the one on the HD.
Cheers
Colin
  To: emax@yahoogroups.com
  Sent: Thursday, February 13, 2003 11:05 PM
  Subject: [emax] EIII harddisk boot problem
  Thanx
  Brian
  http://www.silveriafamily.com
2003-02-15 by Pedro H
Is it Emu III or Emu III XP?
  Sent: Friday, February 14, 2003 12:14 PM
  Subject: Re: [emax] EIII harddisk boot problem
  Hi There
  Cheers
  Colin
    Thanx
    Brian
Re: EIII harddisk boot problem
2003-02-17 by brian_ronn <brian_ronn@...>
It is the EIII (keyboard version). I've tried to boot up without the
floppydisk in drive but the EIII just keeps scanning the scsi ID's
from 0 to 7. The hd is formattet with OS2.42 and I've copied the
software from floppy to the hd. I can access any module on the front
panel which loads a bit of the OS software from the hd and I can also
load entire banks from the hd. It just wont boot. Any suggestions?
>   ----- Original Message -----
>   From: Colin Ross
>   Hi There
one on the HD.
>   Cheers
>   Colin
>     From: brian_ronn <brian_ronn@y...>
set
and
boot
would
cools
disconnet
boards?
>     Thanx
>     Brian
Service.
Service.
RE: [emax] Re: EIII harddisk boot problem
2003-02-17 by Hermann Seib
EPROM version?
From: brian_ronn <brian_ronn@...> [mailto:brian_ronn@...]
Sent: Monday, February 17, 2003 12:54 PM
Subject: [emax] Re: EIII harddisk boot problem
>   From: Colin Ross
>   Hi There
one on the HD.
>   Cheers
>   Colin
set
and
boot
would
cools
disconnet
boards?
>     Thanx
>     Brian
Service.
Service.
http://docs.yahoo.com/info/terms/
The bootrom version on my EIII is 1.0. Can that be the problem?
--- In emax@yahoogroups.com, "Hermann Seib" <shadowcast@e...> wrote:
> EPROM version?
> From: brian_ronn <brian_ronn@y...> [mailto:brian_ronn@y...]
front
also
> >   From: Colin Ross
> >   Hi There
> one on the HD.
> >   Cheers
> >   Colin
> set
EIII
> and
> boot
and
> would
> cools
> disconnet
> boards?
> >     Thanx
> >     Brian
> Service.
> Service.
Re: [emax] Re: EIII harddisk boot problem
2003-02-17 by John Silveria
I think this can be the same problem the Emax II has with slow SCSI devices. There is a
chance at power up the drive is not up and spinning yet by the time the EIII looks to it for
the OS. On the Emax II this can be solved by assigning it to boot from a different SCSI
ID then waiting for it to cycle around back to the ID of the HD. EG: if the internal hard
drive is SCSI #1 tell it to boot from SCSI #3 and when that fails it will look through the
SCSI chain for another device to boot from and when it gets to SCSI #1 the hard drive
will be ready to go. This seemed to be a common problem with older Maxtor hard drives.
On 17 Feb 2003 at 11:53, brian_ronn brian_ronn@yahoo.d spoke unto me:
> --- In emax@yahoogroups.com, "Pedro H" <sotavento1999@h...> wrote: >
> Is it Emu III or Emu III XP? > >   ----- Original Message ----- >
> From: Colin Ross >   To: emax@yahoogroups.com >   Sent: Friday,
> February 14, 2003 12:14 PM >   Subject: Re: [emax] EIII harddisk boot
> problem > > >   Hi There >   do not put the disk in the floppy drive
> so it will search for the one on the HD. >   Cheers > >   Colin >
> ----- Original Message ----- >     From: brian_ronn <brian_ronn@y...>
> >     To: emax@yahoogroups.com >     Sent: Thursday, February 13, 2003
> 11:05 PM >     Subject: [emax] EIII harddisk boot problem > > >     I
> have the OS2.42 boot disc (the latest OS) for the EIII. I've set >
> the scsi id this way: floppy id=0, hd=1 and EIII=6 but the EIII >
> won't boot from the ST51080N hd. I have also formattet the hd and >
>  copyed the software from diskette to hd, but the EIII won't boot >
>  from the hd only from floppy. I can access banks on the hd and >
> access any module via the frontpanel but just won't boot. > >     Do
> you know the jumper settings on the Seagate ST51080N hd? > >     I'm
> thinking about putting the hd to an external hd-case and I would >
> want to disconnect the power of the center ventilator which cools >
>  the hd (because of the noise), would you advise me not to disconnet >
> > >     Thanx > >     Brian > > > > >     Emax and Emax II User's
> Group Website > >     http://www.silveriafamily.com > >     Your use
> of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > >
> [Non-text portions of this message have been removed] > > >   Emax and
> Emax II User's Group Website > >   http://www.silveriafamily.com > >
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. >
**************************John Silveria II****************************
                        MSN: emaxjs@...
------------------ http://www.silveriafamily.com ----------------------
2003-02-18 by Colin Ross
Hi again,
Try a new install and set the HD to ID 01. Tell the EIII to look ID 01 on bootup.
Hope this helps.
Colin
  Sent: Monday, February 17, 2003 11:53 AM
  >   From: Colin Ross
  >   Hi There
  one on the HD.
  >   Cheers
  >   Colin
  set
  and
  boot
  would
  cools
  disconnet
  boards?
  >     Thanx
  >     Brian
  Service.
  Service.
        Yahoo! Groups Sponsor
              ADVERTISEMENT
2003-02-18 by brian_ronn <brian_ronn@...>
I've tried to set the HD to ID 1 and 4 without any boot success. When
I set the ID to 1 or 4 the EIII waits 3 or 4 times longer before it
proceds scanning the scsi chain. I've tried with 2 different Seagate
ST51080N hd's which should work with the keyboard, but not in my
case. I then tried to install one of the ST51080N disks in a EIIIx
(modul) with success. In the EIIIx the hd boots as it should.
When I insert the original 43 Mb hd in the EIII the EIII will boot.
I can't figure this out.....
Thanx for helping out
Brian
--- In emax@yahoogroups.com, "Colin Ross" <colin.a.ross@b...> wrote:
> Hi again,
01 on bootup.
> Hope this helps.
> Regards,
> Colin
ID's
front
also
>   >   From: Colin Ross
>   >   Hi There
>   one on the HD.
>   >   Cheers
>   >   Colin
I've
>   set
EIII
hd
>   and
>   boot
and
and I
>   would
>   cools
>   disconnet
>   boards?
>   >     Thanx
>   >     Brian
>   Service.
>   Service.
>               ADVERTISEMENT
Service.
Hi Brian
Did you change the jumper settings?. I will have to check if there's a auto detect on the EIII and get back to you. Have you tried contacting Rob on the Emu Archive  site? He's the man who can really guide you.
Colin
  Sent: Tuesday, February 18, 2003 12:33 PM
  Brian
  > Hi again,
  01 on bootup.
  > Hope this helps.
  > Regards,
  > Colin
  ID's
  front
  also
  >   >   From: Colin Ross
  >   >   Hi There
  >   one on the HD.
  >   >   Cheers
  >   >   Colin
  I've
  >   set
  EIII
  hd
  >   and
  >   boot
  and
  and I
  >   would
  >   cools
  >   disconnet
  >   boards?
  >   >     Thanx
  >   >     Brian
  >   Service.
  >   Service.
  >               ADVERTISEMENT
  Service.
              ADVERTISEMENT
2003-02-21 by brian_ronn <brian_ronn@...>
Hi Colin
Thanks to you and everybody else who is trying to help me out here.
Yes, I've changed the jumpersettings on the hd so that the EIII can
see that the scsi id on the drive has changed. I can also see when
the EIII scans through from 0 to 7 and that the id on the hd has
changed.
I've been e-mail corresponding with the very helpfull and skilled
guy Rob from emulatorarchive along with you in this group. we
haven't come up with anything concrete yet but we are now focusing
on the boot rom version 1.0. Maybe a boot rom version 2.0 will help
but that mean that 2 new proms are going to be programed. That's for
the moment too hardcore for me.
I've been ill for a couple of days, that's why I haven't been
replying. But now I'm fit for fight again :)
Best regards
Brian
> Hi Brian
really guide you.
> Cheers,
> Colin
When
it
Seagate
EIIIx
boot.
>   Brian
wrote:
>   > Hi again,
look ID
>   01 on bootup.
>   > Hope this helps.
>   > Regards,
>   > Colin
without
>   the
scsi
>   ID's
>   front
can
>   also
suggestions?
>   >   >   From: Colin Ross
>   >   >   Hi There
search for
>   the
>   >   one on the HD.
>   >   >   Cheers
>   >   >   Colin
EIII.
>   I've
>   >   set
>   EIII
>   hd
>   >   and
won't
>   >   boot
the hd
>   and
boot.
ST51080N hd?
case
>   and I
>   >   would
which
>   >   cools
to
>   >   disconnet
pcb
>   >   boards?
>   >   >     Thanx
>   >   >     Brian
Terms of
>   >   Service.
of
>   >   Service.
>   >               ADVERTISEMENT
>   Service.
>               ADVERTISEMENT
Service.
