On Mar 7, 2005, at 10:38 AM, Bob Boilen wrote:
Bob,
I'm assuming you are running LP 7, right?
> I just reinstalled Logic Pro on my Quicksilver Mac.
> I run 10.3.8
> It put my EXS files in the system library in application support for
> Logic.
> This folder is owned by the system and doesn't allow me write access.
> Now I can change the access to the folder (in fact I did )
> but this doesn't seem right.
A better place is the same folder in your user directory.
( yourname/Application Support/Logic/Sampler Instruments)
You may have to create the a folder called "Sampler Instruments".
> Where do your EXS Samples and Sampler Instruments belong?
See above. Your samples can be anywhere though. I keep all my samples
on a separate drive. Easier for me to stay organized, easy backup etc.
If you only have one drive, you may want to just create a folder for
your samples,
but it's just a matter of preference.
> Each time I want a new sample, it takes a while for it to load.
> I thought i set up the project manager to scan all of this so it would
> know where to look and cut down on load time..
Open project manager, navigate to your "sample instruments" folder.
Functions > "Find unresolved file references for selected items".
This is in the manual, by the way. :)
> What am i missing?
> tinydesk
Chris Hellstrom
Guitarist - Programmer - Engineer
http://www.chrishellstrom.com
