From the Philips Datasheet
Price : 0,08 / 100 pcs @ Digikey
240mV @ 0,1mA (that's far more than the RTC uses)
With do you need this resistor ? And even if you need it, let's see:
Using a 1K resistor, and a RTC current of 20uA gives you a dropout of
20mV ....
I use this a lot and I'm sure it works very well.
But I can't see how do you want to use a fet in this application.
Mauricio
Sean wrote:
> The BAT54C's that I see ($0.12 qty 100) all have horrible forward voltage
> drops (some are as bad as 1V at 50mA current!) and I'll still need to
> drop
> the voltage further with a resistor, which drops the efficiency even
> further. This device can also run off of a battery for main power, and
> this circuit needs to power SRAM, so the peak will be around 50mA.
> Do you know of any BAT54C's that have a much lower voltage drop? I see
> Philips has BAT54CW which is 420mV at 50mA current, that's the best I can
> find (yes, these are schottky).
> The FET is the same price but will give me 0.2V drop without needing the
> extra resistor, and because this disconnects the lithium there is no drop
> at all when on main power. Is there any reason this wouldn't work?
> -- Sean
> At 00:17 1/31/2006, you wrote:
> >Use a BAT54C. Inside this component you have the 2 diodes (schotky ones
> >that have only 0,3V dropout) with their cathodes connected.
> >Sean wrote:
> > > Tom:
> > > Thanks for the code!
> > > Is it *necessary* to have the switching in place (as opposed to use
> > > leaving
> > > the lithium to power the RTC all the time)? Just curious.
> > > Instead of using the batt->res->diode what if I used a FET instead to
> > > provide switching between Vcc and Vbat? This would also extend the
> > > battery
> > > life (since it's also powering external SRAM as well). From Digikey a
> > > FET
> > > is the same price as a single diode, so that would actually be
> cheaper (?)
> > > -- Sean
> > > At 22:24 1/30/2006, you wrote:
> > > >Sean wrote:
> > > > >Hello everyone,
> > > > >I've got a bit of a strange problem with the RTC in my setup.
> I have a
> > > > >dedicated lithium battery going to the Vbat pin to power the RTC,
> > > and it
> > > > >usually works fine, however periodically the clock changes to an
> > > invalid
> > > > >value and stops running. Usually this value is something like
> > > "Year:129
> > > > >Month:00 Day:16 Hour:02 Min:09 Sec:08", and unless I reset the
> RTC to a
> > > > >valid value it stops running. This will usually happen after
> > > several hours
> > > > >of Vcc absent (i.e. device powered off) or after a day or two
> running
> > > > >constantly. Nothing else is disrupted. I have a 3.6V lithium
> running
> > > > >through a diode which drops the voltage at the pin down to 3.165V
> > > when Vcc
> > > > >present and to 3.232V when Vcc absent (implying that more current
> > > is drawn
> > > > >when the micro is powered on??)
> > > >Diode switching is needed to maintain the Vbat when Vdd (3.3v
> main) is
> > > >absent and to switch over to the battery when Vdd disappears. It
> sounds
> > > >like you have that working? It will take two diodes (1N4148A) and a
> > > >resistor (560ohm) to do this properly. Cathodes of both diodes go to
> > > >Vbat line, anode of one diode goes to Vdd, anode of other diode is
> > > >series with 560ohm to positive terminal of Lithium cell.
> > > >This is half the solution, the hardware half. I found that my clock
> > > >would also "explode" on occasion and seemingly at random. The
> solution
> > > >I took was a bit more aggressive in the software. Study my clock
> > > >routines, especially awakenClock() and sleepClock().
> Essentially, when
> > > >the clock registers are not needed, they are "disconnected".
> SPONSORED LINKS
> Microcontrollers
> <http://groups.yahoo.com/gads?t=ms&k=Microcontrollers&w1=Microcontrollers&w2=Microprocessor&w3=Intel+microprocessors&w4=Pic+microcontrollers&c=4&s=95&.sig=mfaAujKZXA2Z_vxre9sGnQ>
> Microprocessor
> <http://groups.yahoo.com/gads?t=ms&k=Microprocessor&w1=Microcontrollers&w2=Microprocessor&w3=Intel+microprocessors&w4=Pic+microcontrollers&c=4&s=95&.sig=9jjd2D3GOLIESVQssLmLsA>
> Intel microprocessors
> <http://groups.yahoo.com/gads?t=ms&k=Intel+microprocessors&w1=Microcontrollers&w2=Microprocessor&w3=Intel+microprocessors&w4=Pic+microcontrollers&c=4&s=95&.sig=OMnZuqMZX95mgutt4B-tDw>
> Pic microcontrollers
> <http://groups.yahoo.com/gads?t=ms&k=Pic+microcontrollers&w1=Microcontrollers&w2=Microprocessor&w3=Intel+microprocessors&w4=Pic+microcontrollers&c=4&s=95&.sig=Malspbd0T4Rq3M4Q0nHrfw>
> YAHOO! GROUPS LINKS
> * Visit your group "lpc2000
> <http://groups.yahoo.com/group/lpc2000>" on the web.
> * To unsubscribe from this group, send an email to:
> lpc2000-unsubscribe@yahoogroups.com
> <mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
> * Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> Service <http://docs.yahoo.com/info/terms/>.
