Lpc2000
explanation
explanation
2004-10-26 by domingos_bento
Hello,
I'm to use the Tinyarm DIP50 that has the lpc2129 and in the user
manual says that it is tolerant to 5V in ports I/O, but in many of the
emails the group I see pullup to 3.3V.
if I want to put an input high I can make a direct pullup to 5V??
       Domingos
Ethernet controller for LPC2106
2004-10-27 by Mark Butcher
Hi All
I would like to make a LAN connection to an LPC2106 design. It seems
best to use the SPI interface but I don't know much about SPI
Ethernet controller support.
After checking around I found the Microchip MCP22S80, a 10M device
with SPI connection. But, apart from a simple overview data sheet no
more information.
Question: Has anyone a good suggestion for a device (I would really
like 10/100 if possible but 10M will do for starters). Has any one
used the MCP22S80 and would they recommend it?
Thanks in advance.
Cheers
Mark Butcher
RE: [lpc2000] Ethernet controller for LPC2106
2004-10-27 by Paul Curtis
Mark,
Bit of a tangent, but I got uIP working on the Olimex LPC-E2124 board so
it would be possible to get it working on the 2106 too--it's just bit
bashing.  The E2124 has a 10M CS8900A on it (popular, low-power, easy to
drive).
As for SPI & Ethernet, I don't have any direct experience.
Paul Curtis, Rowley Associates Ltd  http://www.rowley.co.uk
CrossWorks for MSP430, ARM, and (soon) Atmel AVR processors
> From: Mark Butcher [mailto:mjbcswitzerland@...]
> Sent: 27 October 2004 22:19
> To: lpc2000@yahoogroups.com
> Subject: [lpc2000] Ethernet controller for LPC2106
> Hi All
> It seems best to use the SPI interface but I don't know much
> about SPI Ethernet controller support.
> device with SPI connection. But, apart from a simple overview
> data sheet no more information.
> really like 10/100 if possible but 10M will do for starters).
> Has any one used the MCP22S80 and would they recommend it?
> Thanks in advance.
> Cheers
> Mark Butcher
> $9.95 domain names from Yahoo!. Register anything.
> http://us.click.yahoo.com/J8kdrA/y20IAA/yQLSAA/dN_tlB/TM
Re: Ethernet controller for LPC2106
--- In lpc2000@yahoogroups.com, "Paul Curtis" <plc@r...> wrote:
> Mark,
board so
bit
easy to
> drive).
Hi Paul
Problem I have is that the other ports on the LPC2106 are all used
up... SPI is still free and is probably faster that bit banging.
Cheers
Mark
2004-10-28 by Joe Hlebasko
Mark,
I have not used this chip. I STRONGLY recommend to get the errata sheet and
request the unpublished errata from Microchip for this chip.  I had a very
bad experience with microchip's CAN controller having problems and trying to
get Microchip to admit the problems.
Joe
> Sent: Wednesday, October 27, 2004 5:19 PM
> Hi All
> Thanks in advance.
> Cheers
> Mark Butcher
Re: [lpc2000] Ethernet controller for LPC2106
2004-10-28 by Alex Gibson
Joe Hlebasko wrote:
> Mark,
> sheet and
> trying to
> Joe
Which microchip can controller ?
2004-10-29 by Viron Papadopoulos
Hi Mark,
I do not know of any ethernet controller that supports
SPI interface.
An alternative would be to use the Xport from
lantronix.
It gives you ethernet  connectivity through a serial
port. You can use the maxim MAX3100 or MAX3111 to
interface the SPI to UART.
Viron.
--- Mark Butcher <mjbcswitzerland@...> wrote:
> Hi All
> design. It seems
> about SPI
> more information.
> (I would really
> Thanks in advance.
> Cheers
> Mark Butcher
Do you Yahoo!?
Yahoo! Mail - Helps protect you from nasty viruses.
http://promotions.yahoo.com/new_mail
2004-10-29 by acetoel
Hello... I visited Microchip's Web Site, and that SPI to Ethernet
device doesn't have even a datasheet... But seems to be an
interesting device.
What about using an ISA Card?
Ezequiel
--- In lpc2000@yahoogroups.com, Viron Papadopoulos <v1r0n@y...>
wrote:
> Hi Mark,
> SPI interface.
> lantronix.
> Regards,
> Viron.
> --- Mark Butcher <mjbcswitzerland@y...> wrote:
> > Hi All
> > design. It seems
> > about SPI
> > more information.
> > (I would really
> > Thanks in advance.
> > Cheers
> > Mark Butcher
> Do you Yahoo!?
2004-10-29 by Mark Butcher
> interesting device.
> Regards,
> Ezequiel
Have just had contact with a local distributor who informed me that
this device (Microchip MCP22S80) is not yet available - it is
planned for Feb. 2005. It also seems as though it will get (or
already has) a new name - the ENC28J60.
Still haven't found any alternative which is a shame since it a
handy way to expand a design without having to add a bus.
Mark Butcher
2004-10-29 by gcarter68@comcast.net
--- In lpc2000@yahoogroups.com, "Mark Butcher" <mjbcswitzerland@y...>
> > interesting device.
> > Regards,
> > Ezequiel
> Regards
> Mark Butcher
Mark,
If you could use a two chip solution, both Phytec and ARM Patch have
boards that you could use with the LPC2200's and the SMSC Ethernet
MAC/PHY.  I think the total cost of the solution would be around
$10.  Check out these links:
http://www.thearmpatch.com/lpc-sbc2.html
http://www.phytec.com/sbc/32bit/pclpc229x.htm
2004-10-29 by Anton Erasmus
On 27 Oct 2004 at 22:18, Mark Butcher wrote:
> Hi All
> best to use the SPI interface but I don't know much about SPI Ethernet
> controller support.
> more information.
You can try the Wiznet W3100 device. This device runs a TCP/IP stack
in hardware for up to 4 simultaneous connections. It can be used as an 8 bit
peripheral or through an I2C channel. It can do 10/100.
   Anton Erasmus--
A J Erasmus
2004-10-30 by FabioDB
Il giorno mer, 27-10-2004 alle 22:18 +0000, Mark Butcher ha scritto:
> Hi All
Look at:
http://www.digi.com/products/embeddeddeviceservers/index.jsp
It isn't SPI but serial TTL signal levels.
FabioDB <fabiodib@...>
Altraqua
2004-10-30 by Joe Hlebasko
It was the MCP2510 and then the MCP2515.  I regret the day we decided to use
this chip.
Joe
> From: Alex Gibson [mailto:alxx@...]
> Sent: Thursday, October 28, 2004 6:05 AM
> Subject: Re: [lpc2000] Ethernet controller for LPC2106
> Joe Hlebasko wrote:
> > Mark,
> > sheet and request the unpublished errata from Microchip for
> this chip.
> > I had a very bad experience with microchip's CAN controller having
> > problems and trying to get Microchip to admit the problems.
> > Joe
> --------------------~--> Make a clean sweep of pop-up ads.
> Yahoo! Companion Toolbar.
> Now with Pop-Up Blocker. Get it for free!
> http://us.click.yahoo.com/L5YrjA/eSIIAA/yQLSAA/dN_tlB/TM
2004-10-30 by tsvetanusunov
--- In lpc2000@yahoogroups.com, "Joe Hlebasko" <jhlebasko@i...>
decided to use
> this chip.
can you be more specific?
we use MCP2515 without any problems so far
Best regards
Tsvetan
2004-10-31 by Dan Beadle
DPAC Technologies makes a SPI to WiFi adapter.
http://www.dpactech.com/index.asp
  _____
Sent: Saturday, October 30, 2004 3:27 PM
> Hi All
Look at:
Altraqua
ADVERTISEMENT
<http://us.ard.yahoo.com/SIG=129g0n6d1/M=315388.5543472.6613714.3001176/D=gr
oups/S=1706554205:HM/EXP=1099207607/A=2372354/R=0/SIG=12id813k2/*https:/www.
orchardbank.com/hcs/hcsapplication?pf=PLApply&media=EMYHNL40F21004SS> click
here
<http://us.adserver.yahoo.com/l?M=315388.5543472.6613714.3001176/D=groups/S=
:HM/A=2372354/rand=826428489>
  _____
Yahoo! Groups Links
*	To visit your group on the web, go to:
http://groups.yahoo.com/group/lpc2000/
*	To unsubscribe from this group, send an email to:
<mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
*	Your use of Yahoo! Groups is subject to the Yahoo!
<http://docs.yahoo.com/info/terms/>  Terms of Service.
2004-10-31 by ggindele
Speaking of Wi-Fi, an SDIO Wi-Fi card could be a low cost solution
(SDIO is SPI in simple terms). Sandisk and Socket makes such a SDIO
Wi-Fi cards. The major issue here is rather the manufactureres don't
give out the specification of the card.
Gabe
Re: [lpc2000] Re: Ethernet controller for LPC2106
2004-10-31 by capiman@t-online.de
Someone else working on this (SDIO) topic ?
        Martin
To: <lpc2000@yahoogroups.com>
Sent: Sunday, October 31, 2004 5:09 PM
Subject: [lpc2000] Re: Ethernet controller for LPC2106
> Gabe
A couple of basic questions.
2004-10-31 by Robert Wood
Hi folks,
My first question is me being a little lazy really!
Regarding startup code:
I'm writing some code for the LPC2294: does anyone know if it's possible to
use the startup code such as LPC210X_Startup.s and crt0.s that comes with
Crossworks with the 2294?
Regarding modes:
I'm writing some straight forward run-til-complete non operating system code,
should I just put the processor into supervisor mode and leave it there? If
not, what is the best mode to put it in?
Many thanks,
Rob.
Re: [lpc2000] A couple of basic questions.
2004-10-31 by Robert Adsett
At 07:02 PM 10/31/04 +0000, you wrote:
>Regarding modes:
Leave it in system mode.  There is no need to switch to supervisor mode.
Robert
" 'Freedom' has no meaning of itself.  There are always restrictions,
be they legal, genetic, or physical.  If you don't believe me, try to
chew a radio signal. "
                         Kelvin Throop, III
Re: A couple of basic questions.
2004-10-31 by embeddedjanitor
--- In lpc2000@yahoogroups.com, Robert Wood <robert.wood@a...> wrote:
> Hi folks,
possible to
comes with
The startup for these is pretty similar.  You should be able to use
the same startup for most basic tasks.
> Regarding modes:
system code,
there? If
It is best to use system mode for these sorts of task. You can then
use supervisor mode for software interrupts (SWI) if you ever need
this.
Cross Studio Target
2004-11-01 by Robert Wood
Hi folks,
I'm trying to connect my (very first) LPC2294 target to my board using Cross
Studio and an Olimex 20 pin parallel port JTAG interface. Crossworks only
lists Macraigor 14 and 20 pin targets and this gives an error message saying
it [Crossworks] can't identify the target. Should this driver work with the
Olimex interface?
I do have both voltages on the processor and AFAIK I have all the JTAG
connectors correct. If it's of any relevance at all, I'm running under Linux.
Also, I have the Olimex interface on the end of a screened parallel lead (how
short is that ribbon cable? ;-)
Many thanks,
Rob
RE: [lpc2000] Cross Studio Target
2004-11-01 by Paul Curtis
Robert,
> board using Cross Studio and an Olimex 20 pin parallel port
> JTAG interface. Crossworks only lists Macraigor 14 and 20 pin
> targets and this gives an error message saying it
> work with the Olimex interface?
> the JTAG connectors correct. If it's of any relevance at all,
> parallel lead (how short is that ribbon cable? ;-)
Have you successfully connected to another target (e.g. 2106) using the
Olimex JTAG adapter?
I'm not an Arm expert, but Jon or Michael should be able to help.
> From: Robert Wood [mailto:robert.wood@...]
> Sent: 01 November 2004 22:24
> Subject: Re: [lpc2000] Cross Studio Target
> Hi Paul,
> 2106) using
> >> the
> Olimex JTAG adapter? <<
> No, this is the first time I've tried connecting to anything;
> I didn't buy a development board from anyone.
> Rob.
Hi Paul,
No, this is the first time I've tried connecting to anything; I didn't buy a
Rob.
Re: Cross Studio Target
2004-11-01 by leon_heller
> Hi Paul,
using the
didn't buy a
Check your JTAG connections against my Wiggler '210x interface:
http://www.geocities.com/leon_heller/lpc2104.html
and make sure that you have the equivalent pins on your target board
connected appropriately.
You might need to reduce the connection speed for the JTAG interface
(Wiggler Properties). Also, ensure that you are using the correct
port on the PC.
Leon
Re: [lpc2000] Re: Cross Studio Target
Hi Leon,
>> Check your JTAG connections against my Wiggler '210x interface: <<
Yeah, they look essentially the same (I have RTCLK connected as well). I must
say, I can't find the DBGSEL pin at all though. There's a mention of it in
the manual, but it doesn't seem to indicate which pin it is.
(Wiggler Properties). <<
Yep, tried that one too.
I take it that you have used the Olimex interface with the Macgraigor driver
then?!
Rob
2004-11-02 by Leon Heller
>From: Robert Wood <robert.wood@...>
>Reply-To: lpc2000@yahoogroups.com
>Subject: Re: [lpc2000] Re: Cross Studio Target
>Date: Mon, 1 Nov 2004 23:04:16 +0000
>Hi Leon,
>must
>driver
>then?!
No, I've used my own interface as well as a genuine Macraigor Wiggler.
I couldn't find DBGSEL either, perhaps the '2119 doesn't have one.
Leon
2004-11-02 by leon_heller
--- In lpc2000@yahoogroups.com, "Leon Heller" <leon_heller@h...>
wrote:
> >From: Robert Wood <robert.wood@a...>
> >Hi Leon,
interface: <<
well). I
> >must
of it in
interface
Macgraigor
> >driver
> >then?!
Wiggler.
I just checked the data sheet, and saw that P1.26 must be low whilst
RESET is low, to enable debug. Have you done that?
Leon
2004-11-02 by Robert Wood
Hi Leon,
RESET is low, to enable debug. Have you done that? <<
Yes, that I had done(it looks like the equivalent to the DBGSEL to me), but it
did point me in the direction of what *was* wrong! The reset line was
flapping about, looks like for some reason my reset chip was broken. Seems to
connect, upload code and step through now. :-)
All I have to do is find out why it's dissappearing up its own @rse now! ;-)
Many thanks for your help.
Rob.
RE: [lpc2000] Re: Ethernet controller for LPC2106
2004-11-06 by Joe Hlebasko
Tsvetan,
Check out the errata sheet for the MCP2515.  The defect that caught our
attension was the one where can not use transmit object 2 or 3 with out
possible loss of data.
Joe
> From: tsvetanusunov [mailto:tusunov@...]
> Sent: Saturday, October 30, 2004 3:51 PM
> decided to use
> > this chip.
> Best regards
> Tsvetan
2004-11-06 by Micron Engineering
Joe Hlebasko wrote:
>Tsvetan,
>Joe
>>-----Original Message-----
>>decided to use
>>>this chip.
>>Best regards
>>Tsvetan
>>Yahoo! Groups Links
>Yahoo! Groups Links
It is better to use an LPC2214 or LPC2294 having the external bus but in
the past I made micro web server using a PIC 18F258 interfaced via i/o
pins to a CS8900 (that has a parallel interface) and it worked. You have
to write a function that read/write data to an i/o port emulating a data
bus. Of course you will not have maximum possible performance but always
better then using a serial accessible ethernet controller.
