refilling UT-2 in my 1280 air problems
2004-02-03 by Mike Sommers
This weekend I tried refilling my UT-2 cartridges for the first time
(they came already filled, I subsequently bought the 4 oz bottles and
the syringes).
My first comment is that I made a big mess. I underestimated how far the
ink would squirt out of the top vent if I overfilled (which I did on 4
out of 5 tries). Both of my hands were covered in black ink when it was
all said and done, but it washed off with soap and water.
It took me 2 sets of cleaning cycles of 3 cleanings each to get clean
nozzle checks.  I'm still having trouble getting a good nozzle check out
of the "light magenta" position (after 36 hours of "rest"). I'm pretty
sure it's caused by air in the ink chamber.
If I wait long enough, will this problem go away (ie, will the air work
its way out)? or should I just pop out the cartridge and try refilling
again (after extracting the ink and foam out of the cartridge first).
Mike
Re: [Digital BW] refilling UT-2 in my 1280 air problems
2004-02-04 by Mike Sommers
In case someone in the future has the same problem and comes here
seeking a solution...
I'll answer my own question.
Yes. If you wait a couple days, air in the sponge or the ink chamber
will "work itself out."
At least, it did for me. I waited 2 more days before trying a nozzle
check again.. and voila.. it worked.
m
> the syringes).
> Thanks,
> Mike
> If you wish to receive no emails or just a daily digest, or you wish
> this same page.
> - As threads develop, trim off excess portions of earlier messages to
> keep them short.
> flames. Hostile, aggressive or argumentative users may be removed from
> the membership without notice.
> - Keep your posts and threads related to the group topic of digital
> B&W printing. Users who persistently make off-topic posts may be
> removed from the membership.
> guidelines, and to abide by the actions and decisions of the group
> Owner and Moderators. See "Group Topic, Rules and Guidelines" in the
> Files section:
> BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE
> PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER"
> AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE
> LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
> CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO,
> DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE
> LOSSES (EVEN IF THE  "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT
> YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES),
> RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW,
> THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF
> YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD
> PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER
> MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
>     * To visit your group on the web, go to:
>     * To unsubscribe from this group, send an email to:
>       DigitalBlackandWhiteThePrint-unsubscribe@yahoogroups.com
>       <mailto:DigitalBlackandWhiteThePrint-unsubscribe@yahoogroups.com?subject=Unsubscribe>
>     * Your use of Yahoo! Groups is subject to the Yahoo! Terms of
>       Service <http://docs.yahoo.com/info/terms/>.
Microbands & Green Cast with 1280 & UT
2004-06-15 by Keith Hollister
I have recently developed a couple of problems with my 1280 loaded with
MIS UT carts. The first issue is a very noticeable green cast. I have
triple checked my workflow as well as nozzle checks to no avail. I
decied to try a black-only to see if the Eboni ink looked right - the
color was OK (warm but free of other colors), but I have microbands
except in the first 1/2 inch of the print. After the first 1/2 inch is
printed the banding starts. This is not visible in a color (greys)
print. I have tried alignment and cleaning, but no luck.
Ideas?
Keith Hollister
Re: Microbands & Green Cast with 1280 & UT
2004-06-15 by Bob Michaels
Keith, have you tried swapping carts to either Epson OEM or the MIS $5
dye carts? That will isolate your problem to output/driver/printer or
carts/ink. If carts/ink just ask MIS to swap them out. If
output/driver/printer then try a standard, no adjustment needed, file
to narrow it down to output/driver/printer.
Just follow a simplistic diagnostic process to isolate the problem. I
bet the solution will be obvious once you know the true problem.
Also look on the tech support section of the MIS website. The answer
to almost every question is there. It's just time consuming to find it.
Bob Michaels
  --- In DigitalBlackandWhiteThePrint@yahoogroups.com, Keith Hollister
> Ideas?
> Keith Hollister
RE: [Digital BW] Microbands & Green Cast with 1280 & UT
2004-06-16 by Paul Roark
Keith,
Was your printer sitting unused for a while?
______________________
Sent: Tuesday, June 15, 2004 2:56 PM
Subject: [Digital BW] Microbands & Green Cast with 1280 & UT
Ideas?
Keith Hollister
page.
them short.
the membership.
Moderators. See Group Topic, Rules and Guidelines in the Files section:
YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE OWNER AND
MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU
GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  OWNER AND
MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE
Yahoo! Groups Links
Re: [Digital BW] Microbands & Green Cast with 1280 & UT
2004-06-16 by Keith Hollister
Not really - I haven't printed for a couple months, but I ran nozzle
checks every few days.
On Jun 15, 2004, at 8:13 PM, Paul Roark wrote:
> Keith,
> Paul
> www.PaulRoark.com
> From: Keith Hollister [mailto:khollist@...]
> Ideas?
> Keith Hollister
> resources as
> same
> page.
> keep
> them short.
> from
> the membership.
> Owner and
> section:
> PRINT
> TO YOU
> EXEMPLARY
> AND
> THE
> INABILITY
> TO OR
> OF ANY
> this same page.
> keep them short.
> Owner and Moderators. See “Group Topic, Rules and Guidelines” in the
> Files section:
> PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE “OWNER”
> AND “MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE
> LOSSES (EVEN IF THE  “OWNER” AND “MODERATORS” OF DIGITAL BW, THE PRINT
2004-06-16 by nick_h_nugent
Hi Keith,
I think Paul may be correct in asking you if you haven't printed
anything for a while. You most likely have to run one or two cleaning
cycles even if you got good nozzle checks the first time, then print
a half or full page of a purge pattern, then print the nozzle check
again, and maybe one more clean cycle.
I always print a pattern to make sure all nozzles are firing before
starting my print jobs.
-nick
> nozzle checks every few days.
> > Keith,
> > Paul
> > www.PaulRoark.com
2004-06-17 by Keith Hollister
After a few iterations of the nozzle cleaning dance, I have what appear
(even under 2X magnification) to be perfect check patterns, However, I
still get microbands in BO printing. What's really odd is that the
first 3-5% of the image is perfect, then the banding starts. Moreover,
the good part of the image is a fixed percentage of the total image
size, NOT a fixed number of pixels or inches (on a 5x7 it is about
1/2", on a 3x5 it's about half that). In a full color print there is no
banding apparent to the naked eye, but it is faint;y visible under 2x
mag. I've tried OEM carts also. Now for the even stranger part - there
is no banding visible in the black stripe when I print the MIS purge
pattern, even on EEM with 1440 DPI!
I believe the green cast is a bad cart because the light blue toner ink
is more cyan than I remember when I print the purge pattern.
Any ideas? It almost seems like a driver problem, but the only thing
different is a newer version of OS X (10.3.4 versus 10.3.2? when I last
printed with this printer).
Keith
On Jun 16, 2004, at 6:28 PM, nick_h_nugent wrote:
> Hi Keith,
> -nick
2004-06-19 by Paul Roark
Keith,
Did you go back to MIS for a new cartridge?  The green shift is a problem
that has shown up on my 7500 when it is not used for more than a month, but
yours is the first case I've heard of with a desktop printer.  It's non-use
of the printer that seems to cause this.  I just loaded a new beta UT1 toner
in my 7500 and hope that it'll take care of the problem.
At any rate, go to MIS and get a new cartridge.  Using the printer at least
every few days should avoid the problem.
_________________
Sent: Wednesday, June 16, 2004 4:30 PM
Subject: Re: [Digital BW] Microbands & Green Cast with 1280 & UT
Keith
> Hi Keith,
> -nick
page.
them short.
the membership.
Yahoo! Groups Links
2004-06-20 by Keith Hollister
I had another new, sealed cartridge which I put in - now I have a faint
magenta cast. It would appear that these inks do not have much of a
shelf life. I'll call MIS next week and see what they want to do. I
guess I'll try the UT2 stuff this time. Any advantage to using QuadTone
RIP over the Epson driver with UT2?
On Jun 19, 2004, at 4:15 PM, Paul Roark wrote:
> Keith,
> problem
> month, but
> non-use
> toner
> least
2004-06-25 by Ernst Dinkla
Paul Roark wrote:
> Keith,
> Paul
Paul,
On one hand I'm happy that I'm not the only one but it looks like
it happens much faster and less predictable.
Wednesday I got that green shift of the light toner for the first
time in my 9000 but it has been idle for longer periods before
and this time it was less than 4 days.
Is this pigment settling ?  I'm not so sure, looks more like they
used two pigment hues and the magenta degrades in the mix.  One
would expect a single hue pigment for a toner that has to last.
Ernst
2004-06-25 by Andre
problem
month, but
> yours is the first case I've heard of with a desktop printer.  >
> Paul
Paul,
I had this problem for a while earlier this spring with the UT inkset
on an Epson 1160. In desperation, I kinda shook all the bottles of
the inkset and the problem went away.
Andre
RE: [Digital BW] Re: Microbands & Green Cast with 1280 & UT
2004-06-25 by Paul Roark
Andre,
>>... The green shift ...
Exactly.  I agitate bottles regularly.  When I used a CIS with an 1160 and
Piezo inks, I agitated the bottles occasionally.  With a 4000 on a table
next to my desk, I may go with a CFS in part to be able to agitate easily
and at will.
Ernst,
>Paul Roark wrote:
>>...The green shift is a problem
>>more than a month...
>>It's non-use of the printer that seems to cause this.
>>I just loaded a new beta UT1 toner in my 7500 and hope that
>>it'll take care of the problem...
>>Using the printer at least every few days should avoid the problem.
>... it looks like it happens much faster and less predictable.
Is it possible that the inks separated in the carts when idle for the longer
period and you had been using ink in the lines that was not separated for a
period?
>Is this pigment settling?  I'm not so sure, looks more like they
When the ink is agitated, it returns to its former hue, from what I can
tell.  So, this seems to indicate to me that it is probably a settling
problem.
In desktop units, the head agitates the mix regularly.  So, the problem does
not seen to exist for most users.  The sponges may also be a factor.  My
7500 seems to agitate the pigments enough due to the stand rocking slightly.
(You'd once mentioned this, I thought at least in part as a joke.  However,
I think you were right on, as usual.)
The beta toner I'm testing in my 7500 uses the R800 clone "blue" pigment.
This is part of the Ultra Tone family of inks.  While it is on the magenta
side of my target, it allows me to move considerably closer to a
single-color toner.  I have to use a bit of cyan, but cyan has always been
rock solid.  The pigments seem to be well matched in their physical
characteristics.  So, I'm waiting for the end of the month to see how the
fade test looks.  Also, of course, the ink is sitting in the 7500, and I'll
let it sit idle for long while.
Note that pigments are often mixed.  I don't think the mixing is necessarily
a negative, as long as the characteristics of the pigments are appropriately
matched.
Paul Roark wrote:
> Ernst,
> period?
I'm using my own CIS system that has 500 ml bottles with a direct
connection to the internal inklines. The total length of the
lines isn't more than with carts. But when I observed it I
checked the bottle to see whether settling had occured and
couldn't see it. Neither with the 1.5 pint content in two bottles
for filling.  I will pull the ink out the line and see whether it
gets back to normal. Normally (with Generations yellow for
example) you can see the pigment settling at the bottom of the
bottle.
I will take more care to keep them suspended. I had the
impression that the Ultratone / Ultrachrome inks suffer less of
that problem.
Ernst
