refill-friendly carts?
2004-11-16 by Richard Wolfson_
hi Paul -
Could you describe what makes certain cartridges "refill-friendly?" Is
this related to "poppets" you mentioned in another post? (And what are
they?)
thanks,
Richard Wolfson
Fine Art Photographer
Digital Imaging Consultant
Harvard Massachusetts USA
rw at RichardWolfson.com
> From: Paul Roark [mailto:paul.roark@...]
> Subject: comparison hue of piezotone selen - UT-FSN
[big snip]
> The per-print ink costs when refilling the "refill-friendly"
> carts with MIS UT ink is extremely low.  I do not recommend
> bottom filling/re-filling of older desktop carts, but I find
> my 7500 carts and the newest C86 and 2200 carts to be
> extremely easy to refill.
RE: [Digital BW] refill-friendly carts?
2004-11-16 by Paul Roark
Richard,
>Is this related to "poppets" you mentioned in another post?
>(And what are they?)
Take a look at
http://www.inksupply.com/index.cfm?source=html/c82refill.html and
http://www.inksupply.com/index.cfm?source=html/c84refill.html.
(Where the C86 picture says to drill a hole, they are now pre-drilled, and
there are little rubber "corks" that plug the hole until re-fill time.)
To fill or re-fill these carts, all one does is pull the cork, squirt 13 cc
of ink into the sponge-free reservoir, stick the cork back in, and re-set
the chip.  This is really easy and cheap.  So far it is working extremely
well with the C86 I'm using.  I don't know how long the carts will last, but
the system is essentially a CFS without the tubes.  The carts might last a
year or more.
(The latest version of Re-setter SK168 -- that turns from red to green -- is
the recommended resetter.  It has a plastic guide that needs slight
modification at least for the C86 carts -- 1 mm cardboard on the base to
raise the cart, 5 mm sawed off the side of the guide to allow for a bulge
the new carts have.  I've sent my recommendations to MIS.  With those
modifications, it has successfully reset 100% of the time with the C86.)
The poppet valve is similar to what Epson has had for some time, but the
third party carts have lacked the better outlet valve.  It's a spring valve
as opposed to the older simple rubber gasket.  It allows me to, for example,
switch between Eboni matte K and PK at will, with perfect nozzle checks
right off the bat.  Interchanging carts now becomes practical, it appears.
I just tape the outlet of the cart that has been removed.
So, these 2 advances, which affect the C86 carts (C84 included) and 2200
carts (C82 included), make life for these desktop units much easier and
cheaper.  I never liked the old re-filling, and I do not recommend bottom
filling because it puts any junk in the ink on the wrong side of the
sponge/filter.  With these new carts the built-in filters will always be
able to do their job, which might allow our desktop units to live longer.
[big snip]
2004-11-16 by Jake Hellbach
Hi Richard,
I'm not sure what makes the cart refill-friendly but I did buy some of the carts and ink from MIS for my
2200.
I would say they are "fill-friendly" as they are easy to fill using the bottom fill method. The problem is
when its time to re-fill they are full of ink foam and I still can't get all the foam out of one of mine
so I had to buy a Epson cartridge to finish a print order I had.
I'm guessing its something I'm not doing right. One other thing is when you fill them, do yourself a favor
and wear rubber gloves and do it outside as it can get very messy.
Jake
Fine Art Photography
www.jakehellbachphoto.com
  Sent: Tuesday, November 16, 2004 11:09 AM
  Subject: [Digital BW] refill-friendly carts?
  hi Paul -
  they?)
  thanks,
  Richard Wolfson
  [big snip]
  If you wish to receive no emails or just a daily digest, or you wish to unsubscribe, please edit your
Membership preferences by visiting this same page.
  - Good manners are required at all time. No personal attacks or flames. Hostile, aggressive or
argumentative users may be removed from the membership without notice.
  - Keep your posts and threads related to the group topic of digital B&W printing. Users who persistently
make off-topic posts may be removed from the membership.
  - By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the
actions and decisions of the group Owner and Moderators. See Group Topic, Rules and Guidelines in the
Files section:
  BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY
UNDERSTAND AND AGREE THAT THE OWNER AND MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE
LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING
BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF
THE  OWNER AND MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF
SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP;
(ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF
ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL
BW, THE PRINT YAHOO GROUP.
        Yahoo! Groups Sponsor
              ADVERTISEMENT
  Yahoo! Groups Links
Paul,
Did MIS change the design on their carts?
I bought mine about a month ago and they are not clear as in the link below. They do have a larger hole
where in the instructions for the c82refill they mention filling it there and then plug the hole. I've
asked this question from MIS but haven't gotten a answer. If I can fill my carts this same way maybe this
is my problem with the foam buildup.
Jake
  Richard,
  Take a look at
  year or more.
Jake,
Frankly, they are at the mercy of their suppliers.  A large part of MIS's
job is to search the world for the best supplies, including the carts.  From
what I can tell these latest, poppet-valve, easy refill types are brand new.
>...If I can fill my carts this same way maybe this
I'm hopeful that these new carts will not have the foam problem.  I've
refilled a number of the new C86 carts and, so far, no problems.
_________________
  Richard,
  Take a look at
cc
but
  year or more.
is
valve
example,
page.
them short.
the membership.
Moderators. See Group Topic, Rules and Guidelines in the Files section:
YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE OWNER AND
MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU
GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  OWNER AND
Yahoo! Groups Links
Re: [Digital BW] refill-friendly carts?
2004-11-17 by David Wroblewski
Hi Paul, thanks for the update on these carts. Glad to hear you
like them.
I'm in the middle of running my first set, and wondering how
I'm going to pull that little plug out of its tiny little hole
when the time comes. It's very snug. Do you use a pin? Or is
there another trick?
By the way, when I first filled mine I didn't do that primer
draw from the bottom, and the results were nerve-racking.
Took *forever* to get a good nozzle check, but now they are
perfect every time. I assume I don't need to do that on
subsequent fills, correct?
-david
2004-11-17 by Paul Roark
David,
>I'm going to pull that little plug out ...
I now make sure they are not pushed all the way in.  They are in the shape
of a little cork.  So, I make sure the wide end is enough outside the cart
that I can pull it out with a finger nail.  Today I had one that I'd pushed
in too far, but I was able to extract it with the point of a razor knife
blade.
No, once it starts, it's good.
But, as you've also discovered, it's important to prime the carts by pulling
a bit of ink out.  I use an MIS bottom fill adapter on a syringe.  I've
modified the bottom fill adapter by shortening the end to 7 mm.  (I first
did this to be able to pull ink from 7600 carts, but it seems to work for
these poppet valves also.)  The idea was to get the snout long enough to
open the valve, but short enough that the wider part of the bottom fill
adapter could be pushed tight against the bottom of the valve to seal the
connection.  I turn the cart upside down when I do this so that the bubble
that is there will be pulled out first.  As soon as I get ink I stop.  I'm
thinking it might also make sense to tip the cart just enough so that the
ink in the reservoir is up against the opening between the 2 chambers.  This
would stop air from being pulled in through that opening.
Anyway, I refilled 3 carts today and had perfect nozzle checks with each one
immediately without doing any more than squirting about 10 cc of ink into
the reservoir and re-setting the chip.
2004-11-17 by Steve Kale
Do you know whether the resetter requires modification for the 2200 carts?
Thanks
Steve
> From: Paul Roark <paul.roark@...>
> Date: Tue, 16 Nov 2004 09:59:58 -0800
> Subject: RE: [Digital BW] refill-friendly carts?
> Richard,
> Take a look at
> year or more.
> Paul
> www.PaulRoark.com
> carts by pulling a bit of ink out.  I use an MIS bottom fill
> adapter on a syringe.  I've modified the bottom fill adapter
...and the other thing I learned, the hard way, was to be sure to
order needle tips for the syringes you've has been using to do
bottom filling. :-)
I have the old chip resetter, evidently. Seems to work fine.
Do you think there is any advantage to getting a newer one?
I didn't realize there were any issues with the old model.
david
Steve,
I have yet to see get my hands on any of the new 2200 carts.  All I did for
the C86 carts was modify the plastic resetter guide so that the chip
contacts hit the resetter pins.  So, when you get some, just see if they are
lining up.
___________________
> Richard,
> Take a look at
cc
but
> year or more.
is
valve
example,
> Paul
> www.PaulRoark.com
page.
them short.
the membership.
Yahoo! Groups Links
David,
I don't know if the newer re-setters are better or not.  MIS made a comment
to me that seemed to indicate the re-setter with the light that changes from
red to green as the chip is re-set is the best.  I had several re-setters,
only one of which fit that description, and my batting average on resetting
in general was less than perfect.  So, I started to use just the one with
the light that changes colors, and so far with the C86 chips it has been
successful every time.  There may, however, be other factors, such as the
batch of C86 chips MIS sent.
So, I'd just see if yours works OK before replacing it.
Sent: Wednesday, November 17, 2004 5:54 AM
Subject: Re: [Digital BW] refill-friendly carts?
bottom filling. :-)
david
page.
them short.
the membership.
Yahoo! Groups Links
2004-11-17 by Jake Hellbach
Paul and David,
The re-setter I bought from MIS is the one that has the light that changes from red to green. I use in on
the 2200 empty carts I bought from them. I also used it on the original Epson carts and it works great
every time.
Now, if I could only get all the foam out the carts I would be back in business.
I did get an email from MIS tech support and the carts I bought was just before they got the clear ones. I
may buy those since the older ones like I have seem to have a lot of foam problems.
Jake
  David,
Thanks - I was coming at this from the point of view of someone who doesn't
yet own a resetter ie should I wait for modifications to be made in the
production model.  From another post from Jake Hellbach it seems that the
current model works well with the 2200 carts.  As I have limited
opportunities to purchase stuff in the US and pick it up there and bring it
back to the UK I may go ahead and order a set of carts and the resetter.
> Date: Wed, 17 Nov 2004 08:18:22 -0800
> Steve,
> lining up.
> Paul
> www.PaulRoark.com
> ___________________
