--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "mark_roth_505"
<mark@...> wrote:
> I have an 1160 that I thought was ready for the trash heap, but I put
> in clear aftermarket carts w/pigment ink, and now it's back in
> business.
> The trick I found was after removing the CIS, to run several cleaning
> cycles of windex through the heads w/blank carts...this unblocked the
> system. (Something epson would never suggest, so you would have to
> buy one of their new, more expensive printers, BTW.)
> Then replaced with new carts, not made by epson thankfully, with
> pigment ink, and am back in business. Producing great prints again
> w/this printer.
> --- In
> DigitalBlackandWhiteThePrint@...m, "cloudswimmer7774"
> <cloudswimmer@> wrote:
> > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul Roark"
> > <paul.roark@> wrote:
> > > > How does one rinse off the parking pads?I too have an 1160 with
> a
> > > > similar problem
> > > With the printer off, move the gear on the extreme left toward
> you to
> > > release the head assembly. You'll see a little peg near the
> bottom
> > of the
> > > head assembly move down, out of the way. Then you can move the
> head
> > > assembly to the left. This exposes the parking pad. I use a
> > syringe with
> > > Windex in it to rinse the pad. I sometimes use a paper towel to
> > soak up the
> > > Windex-ink mix on the surface.
> > > For unclogging a printer hear, it is sometimes useful to soak the
> > pad and
> > > move the head back over it so that the head sits in the Windex
> > overnight.
> > > Paul
> > > www.PaulRoark.com
> > Paul, thanks for the reply, I moved the assembly to the cart
> changing
> > position with the change ink button, then turned the power off.I
> > looked for the parking pads and couldn't see them in the room light,
> > but with a flash light I did see them but theyre way back down in
> > there.How do you get back down in there with your fingers, theres
> not
> > much room to work down in there.Do I need to take the casing off the
> > printer?Also will plain ol Windex do the trick for the pads?I have
> not
> > used this printer in 5 years and it had sat unused with the original
> > MIS quadtone pre-filled carts in it all this time.I did buy the MIS
> > purging carts last week along with the UT with eboni carts and ran
> > multiple cleaning/purging cycles with the purging carts before
> > installing the inks.Things printed out good till the ink carts got
> > down below 1/4 full, then the nozzle checks started breaking up and
> a
> > purge print showed no ink coming out of the magenta nozzle.I've got
> a
> > new set of UT carts coming in the mail next week and am wondering
> the
> > next step to take to get back up and running.Overall this printer
> has
> > very few hours on it and I'd like to be able to get it running
> > smoothly if possible.Thanks again.....Chris
You mean you bought blank carts like the MIS spongeless carts and
filled them up with windex, loaded them like regular carts, and did
cleaning cycles from the control panel?Did you do purge cycles too
with the windex?Did you use regular windex or no drip?Thanks for the tips!
