Wouldn't it be cool?
2006-09-10 by mandcmiller
Wouldn't it be cool if the EXS/ Logic recognised the anchor point of each sample in the EXS
instrument and would allow you to quantize each sample to its anchor point? This would
allow you to keep more of the anticipation in your individual samples, such as the onset of
guitar strums or reverse sounds, and still get them super tight with your groove.
-Matt
Re: Wouldn't it be cool?
2006-09-11 by Pete Thomas
> -Matt
How would that work with live playing I wonder?
Pete Thomas
www.petethomas.co.uk
Logic Tutorials, Hints, Tips, free Icons, Environments
EXS Instruments (donationware)
***Please support my trek in the Andes in aid of APEC***
***info & sponsorship: http://www.justgiving.com/petethomas***
[EXS] Re: Wouldn't it be cool?
2006-09-11 by Hans Hafner
>> -Matt
That's easy: The software knows when you're gonna strike the next key... duuuh... come on, that's not rocket science
LOL
Cheers
Hans
2006-09-11 by mandcmiller
--- In exs-users@yahoogroups.com, Hans Hafner <hanshafner@...> wrote:
the EXS
would
onset of
> >> -Matt
The program Live has a feature where it triggers events to whatever the quantize
resolution is set to (i.e. the next 16th note). So, as long as you don't trigger the sample
too late you'd be OK. This feature wouldn't work for all instruments, but it would for many.
-Matt
I can't believe I have to say this:
you can't play audio _before_ it is triggered. We were talking about live usage of an instrument such as a sampler.
Yes, once it's in the sequencer and the machine can look ahead, no problem and actually that's when I think the original idea of recognising the anchor points in the samplers works and makes sense.
Perhaps my limited brain just doesn't get it.
Cheers
Hans
2006-09-11 by Matt McKenzie-Smith
> with your groove.
Yes, this would be great..... and would maybe allow for the the
sample offset to work the other way around too. Mmm, makes me think
of many possibilities! Nice idea!
Best Regards,
Matt
_   _   _  _ _    ___  __ _   _ _______________
MATT MCKENZIE-SMITH
MUSIC � AUDIO DESIGN � PRODUCTION
PO Box 10395, Adelaide 5000, South Australia.
Ph.+61 416 197 883
iCHATav.  mattrixx@...
http://www.mattrixx.net
_ _   ___  _      ____  _  _ ________________
sample
many.
Of course you can't play audio before it's triggered, but you can trigger audio before it's
supposed to play. That being said, the 'live' application of this idea is severely limited and
was not part of my original concept.
> Cheers
> Hans
Re: [EXS] Re: Wouldn't it be cool?
2006-09-11 by Roman Pirie
>> with your groove.
> Best Regards,
> Matt
> MATT MCKENZIE-SMITH
> MUSIC • AUDIO DESIGN • PRODUCTION
> Ph.+61 416 197 883
And if you have a breakbeat cut up and there is a little bit of a hihat
before the snare because the drummer played the snare late then you
could quantise to the snare but keep the little bit of hihat. I've
thought of this before. Because I cut up breakbeats. A better example
and the reason I thought of this need is when layering snares from
different breakbeats. If one snare sample begins right on the attack
and the other has a little bit of hihat before it then thhey don't peak
at the same time.
I can see the guitar strum example having this need also.
Quantising to the peak of a sound using the anchor would have it's uses.
At the moment I just layer drums in a sample editor to get the peaks in
sync.
Roman.
2006-09-12 by Hans Hafner
BTW: just to take away the wrong impression I'm leaving. The LOL in my first post stood for laughing out loud and should have denoted that what I wrote was supposed to be semi-funny. Now it's nothing new that people don't get me, I think it has to do with me, but nevertheless I have to keep trying, after all, what choice do I have? ;-)
Cheers
Hans
2006-09-12 by Ingo Debus
Am 11.09.2006 um 22:50 schrieb mandcmiller:
> the quantize
The "Touch Tracks" of Logic have that feature too.
I wonder, does it make any sense to use EXS24 with a different
sequencer program than Logic (Live for instance)?
Ingo
2006-09-12 by Chris Coccia
> Ingo
Well unless youve got a rather old copy of the Player version of EXS,
you cant use it in anything other than Logic..
I cant remember whether or not the original EXS was standalone, it was
the only plugin i bought (before they released the 'Pro' upgrade a few
months later) and Ive been using Logic for so long now I never bothered
trying it in anything else..
Chris
http://www.monotrematamusic.com
http://www.myspace.com/monotremata
http://www.descentrecords.com
2006-09-13 by Gérald RYCKEBOER
It wasn't. I bought it (in the same time tan the ES1) when just
available, and it was only Logic plugin.
Gérald
