Lpc2000
Olimex LPC2106mt bootloader problem
2006-02-09 by Anders Kjellberg
I'm trying to establish connection with Philips Flash Utility and an Olimex 2106 mt board without success. TheBSL jumper is shorted and the frequency set at 14745kHz (14.7456MHz). Different baudrates have been tried without success. I am not sure about the DTR/RTS settings however. Also I may be using the wrong RS232 cable. Null modem or not? I'll have to check that. I intend to use the bootloader and ICCARM. Any ideas that may help?
Thanks in advance!
/Anders
Re: Olimex LPC2106mt bootloader problem
2006-02-09 by theothervmax
it's not null modem cabel that should be used with this board. You
can make it by yourself.
Take two connectors - DB9F for PC and DB9M for the board. Connect
pins 2, 3 and 5 of the two connectors in this way:
2 <-> 2
3 <-> 3
5 <-> 5
then plug'n'play ;-)
Max
--- In lpc2000@yahoogroups.com, "Anders Kjellberg" <akj@...> wrote:
> Hi,
> Thanks in advance!
> /Anders
2006-02-09 by kjellberg_anders
Thanks!
/Anders
--- In lpc2000@yahoogroups.com, "theothervmax" <vmax@...> wrote:
> Hi,
> 2 <-> 2
> 3 <-> 3
> 5 <-> 5
> Regards,
> Max
> --- In lpc2000@yahoogroups.com, "Anders Kjellberg" <akj@> wrote:
> > Hi,
and
baudrates
> > Thanks in advance!
> > /Anders
2006-02-09 by nma550n
Anders,
I am also having problems with the Philips LPC2000 flash utility
(olimex LPC2106), and was just about to post a message on this board
to see if the problem lies with my development board.
I am just trying to upload the simple blink LED hex file to flash,
and it just comes up with cannot communicate. I too have tried many
different com ports, jumper settings and different reset conditions,
to no avail. This is the first time I have tried to use this board,
so i have no idea if the thing works.
I am almost certain the problem does not lie with the Philips LPC2000
flash utility as I have scoped out the Rx signal (3.3v low, 0v high)
on the board and found it to receive data.
However, my Tx pin on the chip is always at ground and does nothing.
Does anyone know if Tx should be held at 0v???
Not sure if this will help you Anders, but just to let you know your
not alone.
cheers,
Nick
> > Hi,
> > Thanks in advance!
> > /Anders
Nick,
Thanks for letting me know about your LPC 2106 problems. Since I'm
working from home today I do not have any other cables but I'll get
back to you as soon as I have tried a different one. As I wrote
earlier, I have tested different baudrates and made sure that the
comport was correctly setup. I'll check that with a scope tomorrow.
Best regards
/Anders
-- In lpc2000@yahoogroups.com, "nma550n" <nma550n@...> wrote:
> Anders,
board
many
conditions,
board,
LPC2000
high)
nothing.
your
> not alone.
> cheers,
> Nick
> > > Hi,
and
shorted
baudrates
Null
> > > Thanks in advance!
> > > /Anders
2006-02-10 by nma550n
Anders,
You had any luck yet?
Nick
--- In lpc2000@yahoogroups.com, "kjellberg_anders" <akj@...> wrote:
> Nick,
> Best regards
> /Anders
> -- In lpc2000@yahoogroups.com, "nma550n" <nma550n@> wrote:
> > Anders,
> board
flash,
> many
> conditions,
> board,
> LPC2000
> high)
> nothing.
> your
> > not alone.
> > cheers,
> > Nick
> > > > Hi,
> and
> shorted
> baudrates
DTR/RTS
> Null
> > > > Thanks in advance!
> > > > /Anders
2006-02-10 by kjellberg_anders
Nick,
It actually works now! Olimex states 9VDC/6VAC for powering the
board, but when I had a look at the closer look at the schematic it
became obvious that it should be 12V... Let me know if this solves
your problem as well. Otherwise I could post my LPC utility settings.
regards
/Anders
--- In lpc2000@yahoogroups.com, "nma550n" <nma550n@...> wrote:
> Anders,
> Cheers,
> Nick
> --- In lpc2000@yahoogroups.com, "kjellberg_anders" <akj@> wrote:
> > Nick,
I'm
get
tomorrow.
> > Best regards
> > /Anders
> > > Anders,
utility
> > board
> flash,
> > many
> > conditions,
> > board,
> > LPC2000
> > high)
> > nothing.
know
> > your
> > > not alone.
> > > cheers,
> > > Nick
wrote:
> > > > > Hi,
Utility
> > and
> > shorted
> > baudrates
> DTR/RTS
> > Null
> > > > > Thanks in advance!
> > > > > /Anders
2006-02-11 by nma550n
Anders,
Great to hear you got your board working! I have not tried upping the
voltage as yet, will give it a try later. The only thing that stopped
me thinking that the voltage would make any differenct was that the
board was getting 1.8v for the core and 3.3v for the peripherals.
Are you saying it requires 12v for RS232?
Also, what is voltage on your Tx pin on the LPC2106 (at default)?
Nick
> Nick,
settings.
> regards
> /Anders
> --- In lpc2000@yahoogroups.com, "nma550n" <nma550n@> wrote:
> > Anders,
> > Cheers,
> > Nick
> > > Nick,
> I'm
> get
> the
> tomorrow.
> > > Best regards
> > > /Anders
> > > > Anders,
> utility
this
> > > board
> > flash,
tried
> > > many
> > > conditions,
> > > board,
> > > LPC2000
0v
> > > high)
> > > nothing.
> know
> > > your
> > > > not alone.
> > > > cheers,
> > > > Nick
> wrote:
> > > > > > Hi,
> Utility
> > > and
> > > shorted
> > > baudrates
> > DTR/RTS
cable.
> > > Null
> > > > > > Thanks in advance!
> > > > > > /Anders
2006-02-11 by kjellberg_anders
Nick,
I get 0V on the TX pin at 9V.
It is clear from the schematic that the board won't work at 9V. I
was also a bit afraid of upping the voltage as the current increased
a lot. The trick is to start at 12V since the regulators draw very
much current when fed below nominal voltage. After the rectifying
bridge there is 7805(and the schematic says 12V there!). There is
also a 1N4733 5V zener-diode. Thus, att 9V there's only 4V left for
the LM1117 3.3V regulator which has a minimum voltage drop of about
1.0-1.2V minimum (4.3-4.5V in). The core may get the correct voltage
but the peripherals won't.
Cheers
/Anders
> Anders,
stopped
> Regards,
> Nick
> > Nick,
it
solves
> settings.
> > regards
> > /Anders
> > > Anders,
> > > Cheers,
> > > Nick
wrote:
> > > > Nick,
Since
> > I'm
I'll
> > get
that
> > the
> > tomorrow.
> > > > Best regards
> > > > /Anders
> > > > > Anders,
> > utility
> this
> > > > board
to
> > > flash,
> tried
> > > > many
> > > > conditions,
this
> > > > board,
Philips
> > > > LPC2000
low,
> 0v
> > > > high)
does
> > > > nothing.
> > know
> > > > your
> > > > > not alone.
> > > > > cheers,
> > > > > Nick
<akj@>
> > wrote:
> > > > > > > Hi,
> > Utility
> > > > and
is
> > > > shorted
Different
> > > > baudrates
> > > DTR/RTS
> cable.
> > > > Null
> > > > > > > Thanks in advance!
> > > > > > > /Anders
Anders,
I actually have the P2106 board and not the 2106mt board. I
originally did not think the problem with the boot loader was
anything hardware.
I'm not sure if this will sort out the problem with my board, as
there is no need to have the voltage as high as 12v (as far as i can
see).
I will still give this a go though.
You say at 9 v your Tx line is 0v. What is it at 12v?
Just trying to tie things together here. At work at the moment and
can't test things till I get home.
Thanks for all your help.
Nick
> Nick,
increased
voltage
> Cheers
> /Anders
> > Anders,
> the
> stopped
> the
> > Regards,
> > Nick
> > > Nick,
schematic
> it
> solves
> > settings.
> > > regards
> > > /Anders
> > > --- In lpc2000@...m, "nma550n" <nma550n@> wrote:
> > > > Anders,
> > > > Cheers,
> > > > Nick
> wrote:
> > > > > Nick,
> Since
> > > I'm
> I'll
> > > get
> that
> > > the
> > > tomorrow.
> > > > > Best regards
> > > > > /Anders
> > > > > > Anders,
> > > utility
> > this
> > > > > board
> to
> > > > flash,
> > tried
> > > > > many
> > > > > conditions,
> this
> > > > > board,
> Philips
> > > > > LPC2000
> low,
> > 0v
> > > > > high)
> does
> > > > > nothing.
you
> > > know
> > > > > your
> > > > > > not alone.
> > > > > > cheers,
> > > > > > Nick
> <akj@>
> > > wrote:
> > > > > > > > Hi,
> > > Utility
> > > > > and
> is
> > > > > shorted
> Different
> > > > > baudrates
> > > > DTR/RTS
> > cable.
> > > > > Null
> the
> > > > > > > > Thanks in advance!
> > > > > > > > /Anders
Re: [lpc2000] Re: Olimex LPC2106mt bootloader problem
2006-02-11 by Uwe Arends
Nick
> anything hardware.
> see).
unless you shorten the zener Z1, 9VDC will not be enough to make the
3.3V regulator work reliably (9V - 0.7V - 5.1V = 3.2V left for the
regulators, while the minimum dropout voltage of the LM1117 is about
1.1V, thus requiring a minimum of 4.4V to produce 3.3V). So the minimum
DC requirement would be 4.4V + 5.1V + 0.7V = 10.3V for this constellation.
If you shorten Z1 by installing J1, 4.4V + 0.7V = 5.1V min. would be
sufficient.
hth
-uwe
2006-02-12 by kjellberg_anders
Nick,
I did not expect anything like this either...
I had a look at the P2106 schematics and apparently it is similar to
the mt board in this respect. The same 5V zenerdiode followed by a
3.3V regulator. This regulator feeds the RS232 chip, no RS232 -no
bootloader. Both the mt and the P schematics actually say 9VAC, but
the documentation says 6VAC 9VDC.
Good luck!
Anders
> Anders,
> anything hardware.
can
> see).
> Nick
> > Nick,
I
> increased
very
rectifying
is
for
about
> voltage
> > Cheers
> > /Anders
> > > Anders,
upping
> > the
> > stopped
that
> > the
peripherals.
default)?
> > > Regards,
> > > Nick
wrote:
> > > > Nick,
> schematic
> > it
> > solves
> > > settings.
> > > > regards
> > > > /Anders
> > > > > Anders,
> > > > > Cheers,
> > > > > Nick
> > wrote:
> > > > > > Nick,
> > Since
> > > > I'm
but
> > I'll
> > > > get
I
> > that
> > > > the
scope
> > > > tomorrow.
> > > > > > Best regards
> > > > > > /Anders
wrote:
> > > > > > > Anders,
flash
> > > > utility
on
> > > this
> > > > > > board
file
> > to
> > > > > flash,
have
> > > tried
> > > > > > many
reset
> > > > > > conditions,
use
> > this
> > > > > > board,
> > Philips
> > > > > > LPC2000
> > low,
> > > 0v
> > > > > > high)
> > does
> > > > > > nothing.
> you
> > > > know
> > > > > > your
> > > > > > > not alone.
> > > > > > > cheers,
> > > > > > > Nick
> > <akj@>
> > > > wrote:
> > > > > > > > > Hi,
Flash
> > > > Utility
> > > > > > and
jumper
> > is
> > > > > > shorted
> > Different
> > > > > > baudrates
> the
> > > > > DTR/RTS
RS232
> > > cable.
> > > > > > Null
use
> > the
> > > > > > > > > Thanks in advance!
> > > > > > > > > /Anders
removed]
Nick,
I forgot. There should be a jumper J1 on your board. It shorts the
diode! I have not checked the documentation (there´s no jumper on my
board) but this might be a clue. Check my previous post if you
haven´t already.
Anders
> Nick,
to
but
> Good luck!
> Anders
> > Anders,
> > anything hardware.
> can
> > see).
and
> > Nick
> > > Nick,
9V.
> I
> > increased
> very
> rectifying
> is
left
> for
> about
> > voltage
> > > Cheers
> > > /Anders
> > > > Anders,
> upping
> > > the
that
> > > stopped
> that
> > > the
> peripherals.
> default)?
> > > > Regards,
> > > > Nick
> wrote:
> > > > > Nick,
powering
> the
> > schematic
> > > it
this
> > > solves
utility
> > > > settings.
> > > > > regards
> > > > > /Anders
> > > > > > Anders,
> > > > > > Cheers,
> > > > > > Nick
<akj@>
> > > wrote:
> > > > > > > Nick,
problems.
> > > Since
> > > > > I'm
> but
> > > I'll
> > > > > get
As
> I
sure
> > > that
> > > > > the
> scope
> > > > > tomorrow.
> > > > > > > Best regards
> > > > > > > /Anders
> wrote:
> > > > > > > > Anders,
> flash
> > > > > utility
message
> on
> > > > this
> > > > > > > board
> file
> > > to
> > > > > > flash,
> have
> > > > tried
> > > > > > > many
> reset
> > > > > > > conditions,
> use
> > > this
> > > > > > > board,
> > > Philips
> > > > > > > LPC2000
(3.3v
> > > low,
> > > > 0v
> > > > > > > high)
and
> > > does
> > > > > > > nothing.
let
> > you
> > > > > know
> > > > > > > your
> > > > > > > > not alone.
> > > > > > > > cheers,
> > > > > > > > Nick
> > > <akj@>
> > > > > wrote:
> > > > > > > > > > Hi,
> Flash
> > > > > Utility
> > > > > > > and
> jumper
> > > is
> > > > > > > shorted
> > > Different
> > > > > > > baudrates
about
> > the
> > > > > > DTR/RTS
> RS232
> > > > cable.
> > > > > > > Null
> use
> > > the
> > > > > > > > > > Thanks in advance!
> > > > > > > > > > /Anders
> removed]
2006-02-13 by nma550n
Anders & Uwe,
I have had the jumper installed all the time. The regulators give 1.8
& 3.3v always.
I think this is a problem with the board.
Can anyone confirm the voltage present on Tx.
Cheers
Nick
> Nick,
my
> haven´t already.
> Anders
> > Nick,
> to
a
> but
> > Good luck!
> > Anders
> > > Anders,
> > > anything hardware.
as
i
> > can
> > > see).
> and
> > > Nick
> > > > Nick,
> 9V.
> > I
> > > increased
> > very
> > rectifying
There
> > is
> left
> > for
> > about
> > > voltage
> > > > Cheers
> > > > /Anders
> > > > > Anders,
> > upping
> > > > the
> that
> > > > stopped
> > that
> > > > the
> > peripherals.
> > default)?
> > > > > Regards,
> > > > > Nick
> > wrote:
> > > > > > Nick,
> powering
> > the
> > > schematic
> > > > it
> this
> > > > solves
> utility
> > > > > settings.
> > > > > > regards
> > > > > > /Anders
wrote:
> > > > > > > Anders,
> > > > > > > Cheers,
> > > > > > > Nick
> <akj@>
> > > > wrote:
> > > > > > > > Nick,
> problems.
> > > > Since
> > > > > > I'm
cables
> > but
> > > > I'll
> > > > > > get
> As
> > I
> sure
> > > > that
> > > > > > the
> > scope
> > > > > > tomorrow.
> > > > > > > > Best regards
> > > > > > > > /Anders
> > wrote:
> > > > > > > > > Anders,
> > flash
> > > > > > utility
> message
> > on
> > > > > this
> > > > > > > > board
board.
> > file
> > > > to
> > > > > > > flash,
> > have
> > > > > tried
> > > > > > > > many
> > reset
> > > > > > > > conditions,
> > use
> > > > this
> > > > > > > > board,
> the
> > > > Philips
> > > > > > > > LPC2000
> (3.3v
> > > > low,
> > > > > 0v
> > > > > > > > high)
> and
> > > > does
> > > > > > > > nothing.
> let
> > > you
> > > > > > know
> > > > > > > > your
> > > > > > > > > not alone.
> > > > > > > > > cheers,
> > > > > > > > > Nick
Kjellberg"
> > > > <akj@>
> > > > > > wrote:
> > > > > > > > > > > Hi,
> > Flash
> > > > > > Utility
> > > > > > > > and
> > jumper
> > > > is
> > > > > > > > shorted
> > > > Different
> > > > > > > > baudrates
> about
> > > the
> > > > > > > DTR/RTS
> > RS232
> > > > > cable.
> > > > > > > > Null
to
> > use
> > > > the
> > > > > > > > > > > Thanks in advance!
> > > > > > > > > > > /Anders
> > removed]
2006-02-13 by Uwe Arends
Nick,
out of reset, the TX pin is at 'low' level on my board
with the BSL jumper installed.
If I then issue a "read device id" command from within
the LPC200 flash utility, theres some traffic on the line
and the utility reports the part id read successfully.
TX is high afterwards.
If I then reset the board again, TX goes back to low
and the next "Read device ID" fails, leaving TX in high
state.
The next "Read device ID" then is again successful, even
if ignoring the request to reset the board.
So, if your TX stays low, no matter what you do, I guess
you have a faulty board, either controller damaged, line
shortened or transceiver damaged.
I'd inspect the soldering to see if there are some shorts,
especially the "expansion" connector, that carries TXD0
next to GND.
hth
-uwe
uwe,
Thanks man, that has helped alot. Will check it out later.
Nick
--- In lpc2000@yahoogroups.com, "Uwe Arends" <nospam@...> wrote:
> Nick,
> state.
> next to GND.
> hth
> -uwe
2006-02-14 by kjellberg_anders
Uwe & Nick,
I have the same experience as Uwe. I would check the TX line on the
low level side of the ST3232(pin 11). Other than that you could
perhaps try a JTAG interface before throwing the poor board away.
Anders
> uwe,
> Nick
> --- In lpc2000@yahoogroups.com, "Uwe Arends" <nospam@> wrote:
> > Nick,
> > state.
> > next to GND.
> > hth
> > -uwe
bootloader for external flash
2006-02-14 by Branko Karaklajic
Hello to everyone,
I need to download program to external flash connected on LPC2292 over
RS232. Before I start to write it, maybe some solution already exist
for that.
Any idea?
Thanx in advance
 branek
USB Mass Storage and Serial Device
2006-02-14 by James Dabbs
Is it possible (and practical) to use an LPC2148 to be both a USB
mass storage device and a USB serial communications device?
[This is a rackmount box.  We want to use USB instead of the more
traditional DB9 console port.  The idea is to allow an administrator
with a PC to copy configuration files into the device and also to run
hyperterminal shell session.  Any other comments are welcome.]
Re: [lpc2000] USB Mass Storage and Serial Device
2006-02-14 by 42Bastian Schick
AFAIK it depends on the number of end-points a device offers. For a
mass-storage you need two bulk end-points for CDC IIRC 3 end-points.
I don't know the 2148, but if it has >= 6 it should work.
42Bastian
2006-02-14 by Bertrik Sikken
The LPC2148 has 16 logical endpoints.
Can a USB device be programmed to be two devices at once?
Alternatively you could configure USB for serial port emulation
at boot and then use a shell command to switch the USB interface
to do USB mass storage.
If it's just configuration files to transfer, perhaps you can
use xmodem over the serial line emulation, it's quite simple.
Bertrik
Re: USB Mass Storage and Serial Device
2006-02-14 by Gus
You can have one USB port act as 2 complete separate devices. I
remember seeing a document from microchip that shows how to do so on
their PICs.
Gus
USB
more
administrator
to run
For a
points.
> Regards,
> Bertrik
2006-02-15 by Clyde Stubbs
Yes, this is known as a "composite" device. It will have two or
more interfaces within a configuration. Each interface associates
with a specific device driver on the host.
A composite device uses the same control endpoint (endpoint 0)
for all of its interfaces, so the number of endpoints required is
less than the sum of the endpoints that separate devices would
require.
Clyde
Clyde Stubbs                     |            HI-TECH Software
Email: clyde@...          |          Phone            Fax
WWW:   http://www.htsoft.com/    | USA: (408) 490 2885  (408) 490 2885
PGP:   finger clyde@...   | AUS: +61 7 3722 7777 +61 7 3722 7778
HI-TECH C: compiling the real world.
RE: [lpc2000] USB Mass Storage and Serial Device
2006-02-15 by Joel Winarske
The Phillips Apps dual serial port example is a working example of a
composite USB device example.
Also the recent IAR mass storage example is a composite device.  Two disk
drives, one RAM the other SD card.
You might refer to either example to get a better understanding of how to
write a composite device.  Perhaps add the serial emulation to the IAR
example.  That would be the quickest route.
Joel
Re: [lpc2000] bootloader for external flash
2006-02-16 by Branko Karaklajic
Hello,
Any solution for my question? Or some another way to program external
flash!
Thanx, again! :)
BK> Hello to everyone,
BK> I need to download program to external flash connected on LPC2292 over
BK> RS232. Before I start to write it, maybe some solution already exist
BK> for that.
BK> Any idea?
BK> Thanx in advance
 branek
Re: bootloader for external flash
2006-02-18 by sonny945852001
www.sparkfun.com and check out their 2294.
Sonny
--- In lpc2000@yahoogroups.com, Branko Karaklajic <branek@...> wrote:
> Hello,
> flash!
> Thanx, again! :)
LPC2292 over
> BK> for that.
> BK> Any idea?
>  branek
