Lpc2000
New Poll started with Wish-List for future devices
2004-06-16 by philips_apps
Hi all,
this group has been such a great pool of help for each other and also
for us at Philips. Some of the questions trigger internal design
investigations, changes in documentation, slides for presentations
and so on. Be assured we are reading and even participating.
The "Philips_Apps" ID is used for "official" purposes only by several
members of our technical team.
Today I would like to pick your brains and get the top-ten charts of
most wanted features in future LPC2000 devices. I promise this will
have an impact on product definition planning if a large number of
you participate.
By the way, some of the listed features are already in development
but we would like to have confirmation we are working on the right
things. The majority in the list however is totally open whether the
features will be implemented in the future or not, your vote counts.
Last but not least let me tell you that the price tag for these
options is very different, e.g. doubling the memory size is a lot
more expensive than adding a serial interface.
Thank you for the great community in the group and for your help
planning upcoming devices.
Looking forward to your numerous responses, Robert
Re: [lpc2000] New Poll started with Wish-List for future devices
2004-06-17 by Rob Chapman
>Hi all,
>you participate.
  I have a few wishes so I'll start with the practical and move from
  there:
    1. Smaller windows into flash so that it can be programmed on a
       finer scale.  Erasing and reprogramming 2K chunks at a time
       is wasteful and 64K chunks are even clumsier.
    2. Don't kill all the flash when programming part of it so that
       the processor can still run code from part of flash while
       programming another.
    3. Programmable blocks instead of all possible peripherals.
       This might take the form of an FPGA and it should come with
       basic programs to implement all the peripherals offered now.
       But it would allow new ways of combining them or one could
       use the programmable logic to extend processor operations or
       implement a different type or number of peripherals.
    4. Digital to Analog converter.
    5. Analog building blocks so that they can be used to process
       analog signals before converting or perhaps some of the analog
       building blocks would be used to make an A/D converter.
    6. On-chip BlueTooth or wireless connection so no cables are
       needed.
  Rob
2004-06-17 by Matthias Weingart
Additional to the poll I would like to see:
small pin count devices (20pins, 8pins) with powerful high speed serial
interfaces (ADC, DAC, I2C-slave, SPI, async - dont strip down the serial
part) - usage as sub controller could simplify designs
integrated 1.8v regulator (mandatory for low pin counts)
2.4GHz RF parts (prefered band, because it is available worldwide)
high res ADC's
schmitt trigger for all inputs
integrated analog parts (comparators, OPamps)
(RTC should have <2uA ;-)
        Matthias
SV: [lpc2000] New Poll started with Wish-List for future devices
2004-06-17 by Lasse Madsen
Oh oh oh ! !
I forgot THE most important thing of all kind !  :D
an LCD controller !!!
I know Philips makes them already but having them inside and being able to
drive for instance a 640x480 panel maybe even with colour or monochrome
would be some of the most awsome thing ... we use Samsung S3BOX44 arm with a
mean lcd controller but could philips come up with something similar that
would simply be perfect.
Best regards
Lasse Madsen
-----Oprindelig meddelelse-----
Fra: philips_apps [mailto:philips_apps@...]
Sendt: 17. juni 2004 01:46
Til: lpc2000@yahoogroups.com
Emne: [lpc2000] New Poll started with Wish-List for future devices
Hi all,
you participate.
Yahoo! Groups Links
Re: New Poll started with Wish-List for future devices
2004-06-17 by Karl Olsen
--- In lpc2000@yahoogroups.com, "philips_apps" <philips_apps@y...>
wrote:
> Hi all,
also
several
of
> you participate.
counts.
Hello philips_apps,
Others have mentioned suggestions which I second:
* An RTC that actually works, i.e. can keep time while the processor
is in power-down.
* An integrated 1.8V regulator.
And I'd like to add:
* Faster GPIO operation.  It takes way too many clocks, even with a
pclk divider of 1.
* An integrated reset/brownout circuit.
* PWM: A way to make new PWMMRx values take effect without waiting
for a PWMMR0 event.  The PWM outputs could then be used to generate
arbitrary, precisely timed pulses.
Karl Olsen
2004-06-17 by hodgejackiehank
> is in power-down.
Of course while many options such as a MAC and different memory
configs are simply a question of different blocks, other options such
as 1.8V regulators and possibly RTC's may be influenced by the
physical characteristics of the semiconductor process used to build
the chip (I note that the process is apparently not a fully static one).
It would be nice however if the chip could be designed to work with a
companion device (possibly one of those allready on the marker) which
would provide voltage regulation, reset, brownout and power down in a
single component solution.
2004-06-17 by javaguy11111
Two options I did not see but would like to and would not require
require building any chips.
1. A BSDL file. I know you do not have officially have boundary scan,
but you have a JTAG type inteface to the ICE. It would be nice to have
a file with the idcodes, register sizes, etc. So far everything is
compatible with arm documentation, but it would still be nice to have
a bsdl for those parts that are JTAG instead of me having to hack one
together for my software.
2. Open up the programming interface for the flash instead of making
me have to go through your onboard api. I am not sure why programming
the onboard flash should be anymore difficult than any other flash I
have programmed in the past.
wrote:
> Hi all,
also
several
of
> you participate.
counts.
2004-06-17 by Robert Adsett
>you participate.
As much memory (both flash and ram) as you can cram in without cost or
package size increases :)
More A/Ds (8 10bit A/Ds would be a nice start)
A DMA type interface would be nice, particularly for the A/D.  My ideal A/D
interface would convert the individual channels on a schedule each channel
with it's own post conversion filtering.  Having a single setup to convert
all channels at once and store the result is a nice first step though.
More and more flexible timers, especially more match registers.  Ideally
allow the match registers to work with mutiple timers (I always liked
Intels queue of match type registers) . Allow them to have external clock
sources so they can act as counters.  A quadrature interface could be
useful too.
I have no need for Ethernet MAC or USB
Byteflight and LIN would be nice (There's actually probably enough to do
LIN already).
On-board EE or FRAM would be nice but the external forms are inexpensive so
it's not worth much.  (If it's not 'free' it's probably too much).
Smaller packages (fewer pins), and lower cost versions.
Robert
" 'Freedom' has no meaning of itself.  There are always restrictions,
be they legal, genetic, or physical.  If you don't believe me, try to
chew a radio signal. "
                         Kelvin Throop, III
Good idea.  I have seen micros with the ability to have either Schmitt or
non-Schmitt inputs (programmable). Anyone know why you want to turn them off?
Robert
                         Kelvin Throop, III
Re: [lpc2000] Re: New Poll started with Wish-List for future devices
We'll have to disagree on this one.  I want Philips to keep these details
close to themselves.  The public interface encapsulates the details nicely,
is not difficult to use and should remain the same as the underlying
algorithm changes.  It's also less difficult than most flash programming
interfaces I've had to deal with (no finicity timing to get precisely right).
Robert
                         Kelvin Throop, III
Add cheap and available in relatively small quantities (100's) and you got
my vote.
                         Kelvin Throop, III
2004-06-17 by Shannon Holland
> is in power-down.
> pclk divider of 1.
I would highly second these. Along with my own addition of USB!
The other thing that would be really nice is to not have the primary
JTAG/trace mode use so many pins! Maybe control the trace function with
another pin state on reset? Or enable the trace mode to be turned off
at boot.
Shannon
Re: SV: [lpc2000] New Poll started with Wish-List for future devices
2004-06-17 by David Willmore
> Oh oh oh ! !
If we're going to say 'LCD controller', let's be very clear to differentiate
between 'raw glass' and high level frambuffer 'LCD controllers'.  I'm still
having flashbacks to ATMELs presentation last week where a dozen different
parts said they had 'LCD controllers' on them, and they all means something
different by it.  You sort of had to go by context--AVRs used it to mean
'raw glass' while the ARM9 stuff generally meant framebuffer style.  So,
what should I assume for the ARM7 parts in the middle? ;)
Personally, I have little use for 'raw glass' controllers and I prefer the
framebuffer driver type.
David
2004-06-17 by microbit
I'm about to use TI's TPS70751.
It's intended for DSP. By the time you add up the functions
it does for you, it's much cheaper that way.
It has :
-    Dual 1.8 / 3.3 V output
-    Selectable Power Up sequencing
-    250 mA / 125 mA on Regs
-    Open drain POR with 120 mS delay
-    Open drain Power Good on Reg 1
-    Low noise : 65 uV w/o Bypass cap
-    Quick output cap discharge
-    2 Manual Reset inputs
-    Under Voltage Lockout
-    Thermal shutdown
That seems like a good choice to me, just has the ext WDT
missing.....
-- Kris
>LIN already).
I said Byteflight, I meant Flexray (Flexray is really it's successor and
makes more sense).  I don't know what I was think about when I wrote that :)
Robert
                         Kelvin Throop, III
LIN/Flexray
2004-06-17 by exh_rene
In which markets do you expect LIN and Flexray to be valuable ?
Only automotive ?
René
--- In lpc2000@yahoogroups.com, Robert Adsett <subscriptions@a...>
to do
> >LIN already).
successor and
wrote that :)
2004-06-17 by Owen Mooney
Hi Robert
Your team could look at the I/O system of the PICF877. It is superb in
it's choice of features. This chip was so well featured that microchip
did a general purpose 16 bit processor (18F452) that used exactly the
same I/O structure, and even made it pin compatable. It has:
    RTC with 32Khz Xtal driver and interrupt capable of waking from sleep
    SPI, I2C Serial etc
    A/D PWM
    Interupt on change inputs - these are VERY usefull.
    Abilility to sleep with almost no power, but wake up when anything
    happens.
I have built a 25 microamp data logger with this device.
What neither of these chip have of course is the ARM core and 32 bit
peripherals etc which is why i have migrated to Philips
I am currently designing a system with a LPC2106 and a PICF877 - using
the 877 as an I/O processor for the LPC2106.
Owen Mooney
2004-06-17 by philips_apps
Hi Owen,
we did look at the PIC12C through PIC18C and generated the LPC900 family.
http://www.semiconductors.philips.com/selectionguides/tables/45995.html
If you want to have a look at the LPC935 and compare it with the PIC
you will find quite some competitive features also on the Philips
8-bit device. In particular the pricing combined with analog features,
Real-Time-Clock component ...
http://www.semiconductors.philips.com/pip/P89LPC935FDH.html
or a family overview here:
http://www.semiconductors.philips.com/markets/mms/products/microcontrollers/key_solutions/80c51/index.html#lpc900
This is a different ball game and you mentioned it yourself, the PIC
and the LPC900 are great I/O processors, the ARM architecture is not
optimized for I/O handling (although it is SO MUCH BETTER than DSPs).
It is optimized for data throughput at low power.
You combination preferably with a LPC900 device instead of the PIC ;-)
is totally in line of what we are seeing. A faster high performance
CPU for the math, control, algorithm, what ever you want to call it
and a small I/O slave processor that can stay alife with very low power.
Regards, Robert
--- In lpc2000@yahoogroups.com, Owen Mooney <ojm@s...> wrote:
> Hi Robert
sleep
>     SPI, I2C Serial etc
>     A/D PWM
>     happens.
> Owen Mooney
RE: [lpc2000] New Poll started with Wish-List for future devices
2004-06-18 by James Dabbs
My suggestion:
On low pin count devices, should you ever revisit the concept of a
"secondary JTAG port," reserve a pin that selects the JTAG port at
reset.  Alternatively, make the port with the ETM module the secondary
port, since this is the one that's more difficult to fit into most
designs.  Enabling (what usually amounts to) the main JTAG interface in
software is too fragile for such a debug mechanism.
I realize that subtle debug improvements are hard to sell.  But the
usefulness of the 210X JTAG is really diminished by the way it is
implemented, in my opinion.
2004-06-18 by javaguy11111
How about a chip with less flash, but more sram. Keep enough onboard
flash read from a serial flash device to load the sram. Or maybe drop
the flash altogether and just automatically boot from a flash device
that implements SPI or I2C.
wrote:
> Hi all,
also
several
of
> you participate.
counts.
Re: [lpc2000] LIN/Flexray
2004-06-18 by Robert Adsett
>Only automotive ?
Automotive is certainly their origin but I do expect to see other
uses.  Flexray I would expect to enter certain industrial markets just as
CAN did.  The question there is how big a niche it can find when compared
to existing CAN implementations and various other fieldbuses.
CAN is being adopted in the industrial electric vehicle market (it's
actually being used for some drive-by-wire applications), Flexray would
actually be a better fit there but it will take some time to grow into it.
LIN I see being used (at least the signalling layer) just about everywhere
that needs a cheap 1-wire serial bus.  I'm working on some stuff that would
make use of LIN, whether it will ever see the light of day is still open to
question at the moment but the bus makes sense in the application.
Robert
                         Kelvin Throop, III
I used the TPS70851PWP in my design. It has similar specs.
--- In lpc2000@yahoogroups.com, "microbit" <microbit@c...> wrote:
> Hi,
with a
which
in a
> It has :
> -    Thermal shutdown
> missing.....
> -- Kris
2004-06-18 by Matthias Weingart
SRAM - static RAM - is expensive - at least 6 times more space is needed as
for flash. I think this is the reason for the little RAM on available uC's.
But DRAM is as small as Flash - I dont know why we see no DRAM in
controllers. The additional power consumption (for refresh) is little
higher; static operation is only required for deep sleep mode, probably
process reasons?
        Matthias
Why does it need to be a JTAG port - with no possibility for boundary scans
(on a controller you can use firmware to do the scan) the JTAG port can
replaced by a single pin.
M.
2004-06-18 by hodgejackiehank
Used this sort of setup on AD2105 devices, but the number is a
coincedence, they are DSP's. It is a good scheme allthougth the RAM
requires more chip area than flash. Even so, with todays densities I
would not imagine it is much of a problem.
I think the chips that use this method don't use a bootloader but a
simple state machine to clock in the contents from an SPI device.
Re: LIN/Flexray
2004-06-18 by Tutors of ESAcademy
As already mentioned, the nice thing about LIN is the simple 1-wire
signal layer - this is really made for the smallest controllers with
limited horsepower (makes you wonder why we talk about it in this
group :-)
In order to make the protocol more interchangeable with "embedded
networks" we came up with MicroMessaging – one could say a subset of
CANopen. So a MicroMessaging network could use LIN (or other lowest
cost serial channels like I2C), but could also be interfaced to
CANopen – providing a transparent network infrastructure across
serial network technologies.
For more info see www.MicroMessaging.com and www.MicroCANopen.com
Olaf
Tutor at ESAcademy
www.esacademy.com
> >Only automotive ?
just as
compared
(it's
would
into it.
everywhere
that would
open to
> Robert
restrictions,
to
>                          Kelvin Throop, III
2004-06-18 by Stephen Pelc
>    From: "philips_apps" <philips_apps@...>
> of most wanted features in future LPC2000 devices. I promise this
> will have an impact on product definition planning if a large
> number of you participate.
Since we can easily fit our web server with CGI and ASP in a
2106 with serial EEPROM for page storage, Ethernet would be
great. A proper RTC would be nice, but there are plenty of I2C
solutions. Most of our industrial clients want Ethernet or USB.
However, for USB the FTDI devices are fairly cheap and avoid all
the hassle of writing PC device drivers. If you provide USB,
please make it that easy.
But above all, make the GPIO faster and document the interaction
between LDR/STR instructions, the VPB and the MAM. As a compiler
vendor, I'm spending too much time writing app notes that should
be in the user manual. As an application writer, I'm reinventing
the wheel far too often. This wasted time increases the cost of
2xxx development for us and our clients.
Again for fast GPIO use, when we use several GPIO pins as a bus
we have to go through contortions. If there were OPDATA and
OPMASK registers life would be simple, especially if writing to
the OPMASK register also set the direction register - we spend
too much time doing read/modify/writes and the three cycle LDR
plus VPB overhead kills us.
Since someone at Philips has already written test code, it
should easy to provide a simple example (10-30 lines) in the
user manual for each peripheral. Just the basics, no interrupts,
just simple initialisation and use IN ASSEMBLER. You've got that
lovely I2C hardware, but the referred example is for an 8051 and
porting our bit-banged master code took less than hour, so we
didn't bother. Old-timers fondly remember the days when monitor
listings were included in CPU data sheets.
You can always put standard example drivers on your web site.
When you do this, please make sure that they work - debugging
the Samsung S3C4510B Ethernet driver example still haunts me!
Have a look at the Atmel PDC as an alternative to full-blown DMA.
But, despite all this it's a great series. The bad news for
Philips will only be that as far as we are concerned the 8051 is
dead. When an ARM is as good as an 8051 at bit-banging that will
be truly something.
Stephen
Stephen Pelc, stephen@...
MicroProcessor Engineering Ltd - More Real, Less Time
133 Hill Lane, Southampton SO15 5AF, England
tel: +44 23 80 631441, fax: +44 23 80 339691
web: http://www.mpeltd.demon.co.uk - free VFX Forth downloads
Re: [lpc2000] Re: LIN/Flexray
>group :-)
Well, I'm thinking  of it using ARMs mostly as master devices using LIN
slaves for remote sensor/actuator.  Although I do have a case where
reducing the number of connections is a big plus and the amount of
communication is small so....
>networks" we came up with MicroMessaging ­ one could say a subset of
>CANopen.
Have you read though the LIN 2.0 spec?  I just recently got it.  I had
previously been through the 1.3 spec at an earlier job.  They have updated
the higher levels in particular.  The LIN spec very nearly weaves itself
into the application layer.  I can see where that would be quite useful
when you are integrating multiple third party slaves.  With proper tools
the complete network interface would conceivably be built in a matter of
minutes.
                         Kelvin Throop, III
2004-06-20 by Peter Jakacki
This thread has become something of a wish list and although I would
probably add my 3 wishes to the list I guess there is a question we
could all ask ourselves. What would make me actually consider anything
other than a 2000 for a particular project? The 2000 line has to be a
competitive line for Philips, it does not matter if it were a great chip
or a throwback (take your pic), as long as it was good business.
Anyway, I could answer that question very quickly, it would be Ethernet
and USB (along with DMA). These are two devices which if implemented
externally would complicate what could of been a clean solution. At
present I must either choose something like Atmel or OKI, or else an
external bus 2000 coupled to these peripherals. Personally, I'd like to
stick to the 2000 line and what better incentive would there be then if
Uncle Phil could cook up some hot chips served along with the Mayonnaise
(Dutch thing).
Something else that whilst it does not seem as important does severely
curtail the use of the 2000 as a more general-purpose micro. This has
been brought up before and it is the I/O speed. Yeah, despite all those
yummy peripherals we still need to bit-bang sometimes, the faster the
better. This would mean little if the 2000 did not have an efficient
manner in which to execute these operations either and this has been
covered also.
When it comes to regulators and brownout reset circuits it is always
advantageous to have these incorporated on the device. But failing that
why can't Philips come out with a nice little dual regulator perhaps in
combo with the reset circuit. The use of LM117s in SOT-22(many)3 packs
is seemingly out of step with the low-power and size of the 2000. Yes,
TI have some nice regs which I have used, yet Philips can and really
should provide what amounts to companion chips that form part of the
product family.
When it comes to more UARTs, ADCs, etc., well, where do you draw the
line? I know I could use more UARTs but there are ways around this like
chaining multiple devices together over the SPI or I2C bus. But Uncle
Phil mentioned I2S and that caught my attention. I'd like to do audio
work with an ARM and what better way than to have a simple connection to
what are typically DSP peripherals.
As for the rest, well;
* Boundary Scan
    Don't need it
* Combo Flash and RAM
    Maybe less rather than more because that would also mean cheaper and
so I could replace my little micros as well with an LPC2002??!!!
* EEPROM
    Would be nice but I can do this with external I2C devices easily.
Maybe the internal Flash could have a couple of small independent pages
perhaps?
* SDRAM, LCD, 80MHz
    This is not the market for the 2000 now although it may become that.
There are plenty of manufacturers out there doing this now with ARM.
* Low and micro-power
    This is always hard to define properly as to what is acceptable.
Sometimes it is fine if the whole chip is halted and oscillators stopped
as long as it can be woken up with a GPIO input change. Other times we
want to keep some power hungry peripheral active (Uart, Ethernet) and
have the unused sections sleep. Others want 32KHz RTC operation. Having
an on-board RC oscillator is prepatory to any low-power (and watchdog)
considerations. Stability, at least in the short-term vs accuracy is
more important in this regard. The RC oscillator can be calibrated
against the cystal allowing the crystal oscillator to be shut-down so
that timing can be maintained for some peripherals. Good or bad, at
least an RC watchdog circuit can wake-up the rest of the chip.
my2cents
Peter Jakacki
2004-06-20 by Owen Mooney
Thanks for that feedback Robert. If I can suggest 1 PIC idea, it is the interrupt on change. The level trigged interupts on the LPC21xx don't map well into typical microcontroller circuits. Edge triggered are much better. My suggestion is 2 registers for edge triggered interrupts, giving each of the 32 I/O lines 4 options for interrupts:- none, rising edge, falling edge, either edge.
Owen
Message: 9
   Date: Thu, 17 Jun 2004 23:10:46 -0000
Subject: Re: New Poll started with Wish-List for future devices
Hi Owen,
Regards, Robert
--- In lpc2000@yahoogroups.com, Owen Mooney  wrote:
> Hi Robert
sleep
>     SPI, I2C Serial etc
>     A/D PWM
>     happens.
> Owen Mooney
2004-06-20 by trick260173
That's nice to see that Philips will improve the LPC21xx series, but
only hope that it will be soon because Atmel will release the
AT91SAM7S64 around August, with most of features from this whishlist:
FYI:
Clock Speed (MHz)* 	 55 (Max clock speed @ +85°C)
SRAM (Bytes)		 16K
Flash (Bytes)		 64K
Enhanced USART (PDC)	 2
SPI (PDC)		 1
TWI			 1
SSC (PDC)		 1
USB Device (Full Speed)	 1
16-bit Timers		 3
PWM Controller		 4
Period Inteval Timer	 1
Watchdog Timer		 1
RTC / RTT		 -/1
10-bit ADC Channel (PDC) 8
Power-On Reset		 1
Brown Out Detection	 1
On-chip RC Oscillator	 1
High Current Pads	 4
I/O Pins		 32
Power Supply (V)	 3.0-3.6 (1.8v on-chip regulator)
Package			 QFP64
Glossary:
RTC/RTT: Real Time Clock / Real Time Timer
Enhanced USART: supports RS485, ISO7816, IrDA and modem control lines.
TWI: Two Wire Interface, interconnects components on a two-wire bus
(I2C compatible).
SSC: Serial Synchronous Controller, supports many serial synchronous
communications protocols used in audio and telecom applications such
as I2S, short or long frame sync.
16-bit Timers: Capture/Compare, Waveform generation and PWM modes.
PDC: Peripheral Data Controller (DMA), transfers data between on-chip
USART, SSC, SPI, ADC and the on and off-chip memories without CPU
intervention.
Bye
2004-06-21 by skykotech
but
whishlist:
<snip>
That's nice, but the Sharp chip (LH79525) blows it out of the water.
ARM720T core
77.4mhz
16k sram
10/100 ethernet mac
full speed usb 2.0
ten input 10 bit A/D
Four DMA channels
SDRAM controller
three 16C550 uarts
BUFFERED SPI port DMA supported (woo hoo!, finally)
I2C
on chip 3.3V to 1.8 volt regulator
three 16 bit timers with PWM
real time 32khz clock
external bus
color lcd controller
Darn it, they forgot the kitchen sink....
2004-06-21 by Shannon Holland
> ARM720T core
> 77.4mhz
> 16k sram
> 10/100 ethernet mac
> full speed usb 2.0
> Four DMA channels
> SDRAM controller
> three 16C550 uarts
> I2C
> external bus
Yes, it has lots of stuff (I worked with the LH79520 before and it was
quite nice). But it also comes in a 176 pin package, has no flash and
costs around $12/10k. Different beast.
Don't get me wrong - I love all these features, just small and cheap
are great things!
Shannon
