Lpc2000
Slow OCD Remote/Insight debugging
2005-09-26 by Blagoj Kupev
Hi there,
I'm beginner in ARM7 world and everything looks strange to me. I've
build wiggler compatible interface and i have MCB2130 from Keil. I have
few questions regarding debuging:
1. Why OCD Remote/Insight combination works 10 times slower compared to
debug speed when i try to debug same SW using Rowley's Cross Studio? (i can not
connect OCD Remote with speed parameter lower than 3).
2. I found some discussion but still it is not clear to me if i can
debug sw in flash with OCD Remote? I read that OCD Remote does not
support hardware breakpoints that is requred for debugging in flash. Is
this true or i'm missing something?
Best regards,
Blagoj
Re: [lpc2000] Slow OCD Remote/Insight debugging
2005-09-26 by sig5534@hotmail.com
I saw the same problem with the wiggler.  Had problems connecting to my LPC2104 at anything but really low speeds.  The OCD is not a professional level debugger.  In order to debug a program that you intend to run in FLASH, you have to download your program into FLASH.  OCD can't do this.
I bought a Signum JTAGJet and it is worth it. It downloads and programs to flash, as well as having a superb C/ASM debugger.   I use the GNUARM for compiling, but I much prefer a professional debugger.
Chris.
  To: lpc2000@yahoogroups.com
  Sent: Monday, September 26, 2005 12:09 AM
  Subject: [lpc2000] Slow OCD Remote/Insight debugging
  Hi there,
  Best regards,
  Blagoj
  SPONSORED LINKS Microprocessor  Microcontrollers  Pic microcontrollers
        8051 microprocessor
  YAHOO! GROUPS LINKS
    a..  Visit your group "lpc2000" on the web.
    b..  To unsubscribe from this group, send an email to:
    c..  Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
2005-09-26 by Michael Johnson
Wigglers work - you just have to choose (perhaps even buy) the
appropriate software to drive them.
Michael
>Chris.
>  ----- Original Message -----
>  From: Blagoj Kupev
>  Hi there,
>  Best regards,
>  Blagoj
>        8051 microprocessor
>  YAHOO! GROUPS LINKS
>Yahoo! Groups Links
And what would that be?  I thought that a download of the OCD app from the same people who make the hardware should likely work.  I can understand some really limited features, but a 4kHz connection speed? That really surprised me.
Chris.
  Sent: Monday, September 26, 2005 4:37 AM
  Subject: Re: [lpc2000] Slow OCD Remote/Insight debugging
  Michael
  >Chris.
  >  From: Blagoj Kupev
  >  Hi there,
  >  Best regards,
  >  Blagoj
  >        8051 microprocessor
  >  YAHOO! GROUPS LINKS
  >Yahoo! Groups Links
  YAHOO! GROUPS LINKS
We've found that you can't drive the signals on a PC parallel port at
more than 4kHz (this is in GPIO/bit bang mode - EPP/ECP is a different
tale). Even with this limitation CrossWorks for ARM has a flash download
speed of 14Kbytes per second to the LPC21xx.
Michael
>Chris.
>  From: Michael Johnson
>  Michael
>  >Chris.
>  >  From: Blagoj Kupev
>  >  Hi there,
>  >  Best regards,
>  >  Blagoj
>  >        8051 microprocessor
>  >  YAHOO! GROUPS LINKS
>  >Yahoo! Groups Links
>  YAHOO! GROUPS LINKS
>Yahoo! Groups Links
Whoops I meant 400Khz.....
>Michael
>>Chris.
>> Michael
>> >Chris.
>> >  From: Blagoj Kupev
>> >  Hi there,
>> >  Best regards,
>> >  Blagoj
>> >        8051 microprocessor
>> >  YAHOO! GROUPS LINKS
>> >Yahoo! Groups Links
>> YAHOO! GROUPS LINKS
>>Yahoo! Groups Links
>Yahoo! Groups Links
2005-09-27 by sig5534@hotmail.com
14K Wow.  And I thought the 1M rate I'm getting with the Signum JetJTAG was slow.  I can't imagine doing tons of debuging at 14K.
Chris.
  Sent: Monday, September 26, 2005 5:58 AM
  Michael
  >Chris.
  >  Michael
  >  >Chris.
  >  >  From: Blagoj Kupev
  >  >  Hi there,
  >  >  Best regards,
  >  >  Blagoj
  >  >        8051 microprocessor
  >  >  YAHOO! GROUPS LINKS
  >  >Yahoo! Groups Links
  >  YAHOO! GROUPS LINKS
  >Yahoo! Groups Links
        8051 microprocessor
  YAHOO! GROUPS LINKS
2005-09-27 by Michael Johnson
Does 1M==1Mbyte or 128Kbyte? Which LPC21xx device are you using? Are you
downloading into flash? How long does it take for you to download 64K
bytes into the flash of an LPC21xx?
Michael
>Chris.
>  Michael
>  >Chris.
>  >  Michael
>  >  >Chris.
>  >  >  From: Blagoj Kupev
>  >  >  Hi there,
>  >  >  Best regards,
>  >  >  Blagoj
>  >  >        8051 microprocessor
>  >  >  YAHOO! GROUPS LINKS
>  >  >Yahoo! Groups Links
>  >  YAHOO! GROUPS LINKS
>  >Yahoo! Groups Links
>        8051 microprocessor
>  YAHOO! GROUPS LINKS
>Yahoo! Groups Links
RE: [lpc2000] Slow OCD Remote/Insight debugging
2005-09-27 by Paul Curtis
Chris,
at
different
> > download  speed of 14Kbytes per second to the LPC21xx.
> debuging at 14K.
> Chris.
So, how fast does your Signum device load into an LPC2000's flash?  Bet
it's not much faster than 14K/second and will never approach a "1M"
rate.  What's an "1M" rate?  Is that a TCK frequency or the programming
speed in bits per second or bytes per second?
The CrossConnect loads at over 180Kbytes/second onto an Evaluator-7T
into RAM, so that equates to a download speed of 1.4Mbit/second.  On
Xscale it's over 200K/second equating to 1.6Mbit/second.  Not too shabby
for a £99 device.  However, the Wiggler or one of its many clones isn't
at all bad for low-end development on small devices--about 1/5th the
speed for 1/5th the price (if you purchase a clone).
-- Paul.
2005-09-28 by sig5534@hotmail.com
I mean 1 MegaByte per second.  That is my JTAG link speed.  I have 2 designs right now I am working with, a LPC2106 and an LPC2124.  The download to the Flash/RAM only takes a couple seconds or less.  But the programming of the flash takes about 6 seconds.  That is due to the internal speed limitations of the flash erase and programming.  My code is too big to run in RAM.  All my code must be run from flash.
But the biggest difference is the Chameleon debugger of Signum.  That OCD is a joke, its not even a debugger, and the GNU Insight debugger ain't much better.  With Chameleon I can watch so many more things going on inside the CPU and it even breaks apart record structures and gives me the value on anything anytime I want, anywhere in my code.  Full display of both C and ASM real time, with both hardware and software breakpoints.  It is a top quality debugger.  One of the best I have ever used.  Feature rich.  Lots of powerful debugging features, in addition to full flash programming.
Moreover, I can control which areas of flash get reprogrammed.  That has turned out to be very useful.  Sometimes I do not want data areas to be changed when I reload the code.  So I skip those address ranges.  Very handy.
Chris.
  Sent: Monday, September 26, 2005 10:42 PM
  Michael
  >Chris.
  >  Michael
  >  >Chris.
  >  >  Michael
  >  >  >Chris.
  >  >  >  From: Blagoj Kupev
  >  >  >  Hi there,
  >  >  >  Best regards,
  >  >  >  Blagoj
  >  >  >        8051 microprocessor
  >  >  >  YAHOO! GROUPS LINKS
  >  >  >Yahoo! Groups Links
  >  >  YAHOO! GROUPS LINKS
  >  >Yahoo! Groups Links
  >        8051 microprocessor
  >  YAHOO! GROUPS LINKS
  >Yahoo! Groups Links
        8051 microprocessor
  YAHOO! GROUPS LINKS
2005-09-28 by Michael Johnson
What is the size of your program that takes 6 seconds to download to flash?
Michael
>Chris.
>  Michael
>  >Chris.
>  >  Michael
>  >  >Chris.
>  >  >  Michael
>  >  >  >Chris.
>  >  >  >  From: Blagoj Kupev
>  >  >  >  Hi there,
>  >  >  >  Best regards,
>  >  >  >  Blagoj
>  >  >  >        8051 microprocessor
>  >  >  >  YAHOO! GROUPS LINKS
>  >  >  >Yahoo! Groups Links
>  >  >  YAHOO! GROUPS LINKS
>  >  >Yahoo! Groups Links
>  >        8051 microprocessor
>  >  YAHOO! GROUPS LINKS
>  >Yahoo! Groups Links
>        8051 microprocessor
>  YAHOO! GROUPS LINKS
>Yahoo! Groups Links
The time is all due to the erase I think.  As I recall it takes about 0.3 Sec per sector and there are about 16 sectors, so that is about 5 seconds right there.   Normally the defaut is to erase the entire part and that is what takes a few seconds.   My code on this one part right now is about 48K.  Moving the data doesn't take anytime at all.  It's waiting for the slow internal LPC flash processing.
Chris.
  Sent: Tuesday, September 27, 2005 11:26 PM
  Michael
  >Chris.
  >  Michael
  >  >Chris.
  >  >  Michael
  >  >  >Chris.
  >  >  >  Michael
  >  >  >  >Chris.
  >  >  >  >  From: Blagoj Kupev
  >  >  >  >  Hi there,
  >  >  >  >  Best regards,
  >  >  >  >  Blagoj
  >  >  >  >        8051 microprocessor
  >  >  >  >  YAHOO! GROUPS LINKS
  >  >  >  >Yahoo! Groups Links
  >  >  >  YAHOO! GROUPS LINKS
  >  >  >Yahoo! Groups Links
  >  >        8051 microprocessor
  >  >  YAHOO! GROUPS LINKS
  >  >Yahoo! Groups Links
  >        8051 microprocessor
  >  YAHOO! GROUPS LINKS
  >Yahoo! Groups Links
        8051 microprocessor
  YAHOO! GROUPS LINKS
2005-09-28 by Paul Curtis
Ok, so 48K in 6 seconds is 8K per second to download and flash.  Gee.
That's way slower than CrossWorks' wiggler implementation which will
erase, download, and flash at 14KB per second on an LPC.  The
CrossConnect will download and flash at 34K per second on an LPC.  So,
if you have 48K, the CrossConnect will erase, download, and complete
flashing within 2s 2s of hitting the Go button.
Seems like the JTAGjet isn't quick so "jet" after all.
-- Paul.
> Chris.
> download to flash?
>   Michael
>   >Chris.
> you using? Are you
> download 64K
>   >  Michael
> debuging at 14K.
>   >  >Chris.
> parallel port at
>   >  >  Michael
>   >  >  >Chris.
> even buy) the
>   >  >  >  Michael
>   >  >  >  >Chris.
>   >  >  >  >  From: Blagoj Kupev
>   >  >  >  >  Hi there,
> strange to me. I've
> OCD Remote does not
>   >  >  >  >  Best regards,
>   >  >  >  >  Blagoj
>   >  >  >  >        8051 microprocessor
>   >  >  >  >  YAHOO! GROUPS LINKS
>   >  >  >  >Yahoo! Groups Links
>   >  >  >  YAHOO! GROUPS LINKS
>   >  >  >Yahoo! Groups Links
> microcontrollers
>   >  >        8051 microprocessor
>   >  >  YAHOO! GROUPS LINKS
>   >  >Yahoo! Groups Links
> microcontrollers
>   >        8051 microprocessor
>   >  YAHOO! GROUPS LINKS
>   >Yahoo! Groups Links
> microcontrollers
>         8051 microprocessor
>   YAHOO! GROUPS LINKS
> Terms of Service.
> --------------------~--> Get Bzzzy! (real tools to help you
> find a job). Welcome to the Sweet Life.
> http://us.click.yahoo.com/A77XvD/vlQLAA/TtwFAA/dN_tlB/TM
2005-09-28 by Blagoj Kupev
As i understand regarding your comments it is much cost effective that i
buy CrossConnect with CrossWorks than to by Seggers JTAGjet?! What about
support from their vendors? I've heard good thoughts about Rowley, what
about Segger?
Blagoj
Na 26.09.2005 09:09 Blagoj Kupev rece:
>Hi there,
>Best regards,
>Blagoj
>Yahoo! Groups Links
>__________ NOD32 1.1232 (20050925) Information __________
>This message was checked by NOD32 antivirus system.
>http://www.eset.com
I guess you missed the point.  The programming time is limited by the internal operation of the LPC CPU.  Erasing sectors is time controlled by the CPU.  The jtag link has nothing to do with this.  Those time delays are the same for any programmer.  Just try doing some IAP yourself from your own internal code and you will understand real quick.  You can't do it any faster even from inside the CPU.
Chris.
  Sent: Wednesday, September 28, 2005 4:41 AM
  Subject: RE: [lpc2000] Slow OCD Remote/Insight debugging
  -- Paul.
  > Chris.
  > download to flash?
  >   Michael
  >   >Chris.
  > you using? Are you
  > download 64K
  >   >  Michael
  > debuging at 14K.
  >   >  >Chris.
  > parallel port at
  >   >  >  Michael
  >   >  >  >Chris.
  > even buy) the
  >   >  >  >  Michael
  >   >  >  >  >Chris.
  >   >  >  >  >  From: Blagoj Kupev
  >   >  >  >  >  Hi there,
  > strange to me. I've
  > OCD Remote does not
  >   >  >  >  >  Best regards,
  >   >  >  >  >  Blagoj
  >   >  >  >  >        8051 microprocessor
  >   >  >  >  >  YAHOO! GROUPS LINKS
  >   >  >  >  >Yahoo! Groups Links
  >   >  >  >  YAHOO! GROUPS LINKS
  >   >  >  >Yahoo! Groups Links
  > microcontrollers
  >   >  >        8051 microprocessor
  >   >  >  YAHOO! GROUPS LINKS
  >   >  >Yahoo! Groups Links
  > microcontrollers
  >   >        8051 microprocessor
  >   >  YAHOO! GROUPS LINKS
  >   >Yahoo! Groups Links
  > microcontrollers
  >         8051 microprocessor
  >   YAHOO! GROUPS LINKS
  > Terms of Service.
        8051 microprocessor
  YAHOO! GROUPS LINKS
Chris,
Well, let's work through it shall we.
Sure.  I understand that.
I'm sorry if I'm a little thick here.  You'll need to help me with the
mathematics.
Here's a little dump of what CrossWorks does when downloading using a
CrossConnect:
Downloading Loader to USB CrossConnect for ARM
Programming 3.6 KB at 0x40000000
Programming completed in 141 ms -- 26,808 bytes/sec
Downloading keil_mcb2140.elf to USB CrossConnect for ARM
Erasing completed in 2.1 s -- 23,499 bytes/sec
Programming 47.4 KB at 0x0
Programming completed in 1.5 s -- 32,575 bytes/sec
Verifying keil_mcb2140.elf on USB CrossConnect for ARM
Verifying completed in 375 ms -- 130,216 bytes/sec
I downloaded 3.6K to RAM in 141ms, then I erased the LPC2k's flash in
2.1s, then I downloaded 47.5K to flash in 1.5s, and then I verified that
it had downloaded correctly in 375ms.
Total time from cold to debugging = 4.1s.
With a wiggler:
Downloading Loader to Macraigor Wiggler (20 Pin)
Programming completed in 312 ms --12,320 bytes/sec
Downloading keil_mcb2140.elf to Macraigor Wiggler (20 Pin)
Erasing completed in 2.0 s -- 24,078 bytes/sec
Programming completed in 2.9 s -- 16,859 bytes/sec
Verifying keil_mcb2140.elf on Macraigor Wiggler (20 Pin)
Verifying completed in 390 ms --126,317 bytes/sec
So, I downloaded 3.6K to RAM in 312ms, then I erased the LPC2k's flash
in 2.0s, then I downloaded 47.5K to flash in 2.9s, and then I verified
that it had downloaded correctly in 390ms.
Total time from cold to debugging = 5.6s.
You said:
"The download to the Flash/RAM only takes a couple seconds or less. But
internal speed..."
Yes, so eight seconds for 48K to download and program.  That compares to
5.6s to download and program on the wiggler and 4.1s on the
CrossConnect.
So, where am I making my mistake, and why is the JTAGjet so much better?
-- Paul.
2005-09-28 by Matthias Hertel
You do flash programming at 1MB/s on an LPC2xxx controller?
> Chris.
> download
>   Michael
>   >Chris.
>   >  Michael
>   >  >Chris.
>   >  >  From: Blagoj Kupev
>   >  >  Hi there,
> I've
> Keil. I have
> compared to
> Studio? (i can not
> i can
> not
> flash. Is
>   >  >  Best regards,
>   >  >  Blagoj
> microcontrollers
>   >  >        8051 microprocessor
>   >  >  YAHOO! GROUPS LINKS
> Terms of Service.
>   >  >Yahoo! Groups Links
>   >  YAHOO! GROUPS LINKS
> of Service.
>   >Yahoo! Groups Links
>         8051 microprocessor
>   YAHOO! GROUPS LINKS
> Service.
> YAHOO! GROUPS LINKS
>     *  Visit your group "lpc2000
>       <http://groups.yahoo.com/group/lpc2000>" on the web.
>     *  To unsubscribe from this group, send an email to:
>       <mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
>     *  Your use of Yahoo! Groups is subject to the Yahoo! Terms of
>       Service <http://docs.yahoo.com/info/terms/>.
2005-09-29 by Blagoj Kupev
Here is my opinion using other MCUs (MPC565, PIC16F, PIC18F) and i think
for LPC the situation is the same regarding programming speeds. There
are two different speeds, one is speed of internal flash module and
other is speed of communication PC to Target MCU. Normally when flash
erase is started speed of erase depends mostly on the speed of flash
module and not on the speed of interface.
But programming of RAM mostly depends on speed of interface since RAM
modules are much, much faster than flash modules.
It is good if both of you can test your interfaces on same target MCU
but with biggest elf file that can be fitted inside flash and/or ram of
target mcu. This way tests will be performed on same mcu and difference
will be only on speed of interface and a bit on speed of used PC. This
way we'll see it JTAGjet really has "jet" spped compared to CrossConnect.
Blagoj
Na 28.09.2005 17:21 Paul Curtis rece:
>Chris,
>mathematics.
>CrossConnect:
>With a wiggler:
>internal speed..."
>CrossConnect.
>-- Paul.
>Yahoo! Groups Links
>__________ NOD32 1.1236 (20050928) Information __________
>http://www.eset.com
2005-09-29 by sig5534@hotmail.com
That is the JTAG link speed setting.  Actual the probe goes to 10M but the LPC would not take that.
Chris.
  Sent: Wednesday, September 28, 2005 9:33 AM
  > Chris.
  > download
  >   Michael
  >   >Chris.
  >   >  Michael
  >   >  >Chris.
  >   >  >  From: Blagoj Kupev
  >   >  >  Hi there,
  > I've
  > Keil. I have
  > compared to
  > Studio? (i can not
  > i can
  > not
  > flash. Is
  >   >  >  Best regards,
  >   >  >  Blagoj
  > microcontrollers
  >   >  >        8051 microprocessor
  >   >  >  YAHOO! GROUPS LINKS
  > Terms of Service.
  >   >  >Yahoo! Groups Links
  >   >  YAHOO! GROUPS LINKS
  > of Service.
  >   >Yahoo! Groups Links
  >         8051 microprocessor
  >   YAHOO! GROUPS LINKS
  > Service.
  > YAHOO! GROUPS LINKS
        8051 microprocessor
  YAHOO! GROUPS LINKS
2005-09-30 by sig5534@hotmail.com
When I said 5 or 6 seconds, I was not trying to be that precise.  These were not measurements taken with any stop watch or by any elaborate timing method.  That was just my feeling.  It could be anywhere from 3-7 seconds as far as I now.  I don't pay that close attention to it.  I'm always erasing different amounts of memory.  Sometimes it is all 256K, and other times it is just 32K.  It depends.  So I get different times.
But programming is not what my point was about, as far as being JTAG speed.  Reading back the data for large blocks during debugging is where the speed comes in.  Stopping and starting breakpoints is when the data has to be pulled back through the JTAG.  That is a lot faster at 1M than at 14K.  All of my half dozen windows fill quick.
Chris.
  Sent: Wednesday, September 28, 2005 8:21 AM
  Chris,
  mathematics.
  CrossConnect:
  With a wiggler:
  internal speed..."
  CrossConnect.
  -- Paul.
        8051 microprocessor
  YAHOO! GROUPS LINKS
2005-09-30 by Paul Curtis
Chris,
> different times.
You just don't seem to understand.  14K is the flashing rate in bytes
per second and has nothing to do with your "1M rate" which is bits per
second on TDI/TDO and clocking the JTAG state machine  If I told you
that the CrossConnect actually runs a 4MHz clock on TCK that's faster
than your 1M rate isn't it?
You're comparing apples with oranges.  Until you can understand that we
can write data into RAM at 200Kbytes/second (that equates to
1.6Mbit/second), you're just not going to grasp that these pieces of
hardware are comparible and, as far as I can tell form what you've said,
the CrossConnect is faster.
-- Paul.
Re: Slow OCD Remote/Insight debugging
2005-10-01 by John Heenan
The Signum JTAGjet claims download speed in excess of 1 MByte/sec,
not 1Mbit/sec. From the Signum web site
http://www.signum.com/Signum.htm
"Actual speed 1.062 Mbyte/sec tested with ARM Evaluator 7T board and
600 MHz Pentium III PC with USB 2.0 port. Faster PCs may yield faster
downloads."
Since the JTAGjet uses USB 2.0 this is reasonable, provivded the
target device and connections can hold up.
Leaving aside the issue of delays introduced by programming Flash,
which many developers do not need to bother with during development
if all their code fits into RAM, the claimed speed supports what many
developers welcome and which was mentioned by Chris: rapid reading of
data blocks at breakpoints.
The Signum JTAGjet also claims compatibility with all major ARM
debuggers and another version of the JTAGjet supports ETM.
I am simply pointing out factual issues. This is what I welcome from
a newsgroup, along with a balance of relevance and fair
represenstation.
John Heenan
--- In lpc2000@yahoogroups.com, "Paul Curtis" <plc@r...> wrote:
> Chris,
> > different times.
bytes
per
faster
that we
said,
> -- Paul.
Re: [lpc2000] Re: Slow OCD Remote/Insight debugging
2005-10-02 by Rob Jansen
Incredible download speeds ...
If I have to download 64 kB to RAM for running (or flash programming)
the wiggler will do this in 4 secs, the JTAGjet in 0.0000... secs. After
this I spend at least 1800 secs to step through my program for debugging
and most of this time I will just look at what happened with a
flabbergasted look on my face :-) So I am not that concerned with
download speed. I am used to debugging a system with a 204 MHz ARM926
and a megabyte-or-so image using a RealView ICE. Downloading takes a few
secs but stepping through my code is fast - even if I have some watches
out there that do contain large data arrays (something you really want
to avoid).
Hence download speed and flashing memory is not my concern but reading
(preferably) small pieces of RAM after every step is. How fast can you
step through the code with your debugger, do you see any real delays or
can you just step at (full speed) 2 key/mouseclicks per seconds?
Rob
> downloads."
2005-10-02 by Michael Johnson
>downloads."
What's a major debugger?
>represenstation.
The LPC22xx could be used to run programs from an external SRAM - this
is an approach that can be used to avoid the two breakpoints limitation.
It would be useful for someone who has this hardware combination (Signum
JTAGjet and LPC22xx+SRAM) to provide download (and upload) figures.
Michael
>John Heenan
>>Chris,
>>>different times.
>bytes
>per
>faster
>that we
>said,
>>-- Paul.
>Yahoo! Groups Links
>to avoid).
Stepping performance is fine with both wiggler and CrossConnect.
Wigglers work remarkably well in this area since there are no comms
latencies and the CrossConnect is fast at everything. We don't have any
figures for uploading - we'll correct this when we update our
wiggler/CrossConnect performance figures.
Michael
>Rob
>>downloads."
>Yahoo! Groups Links
RE: [lpc2000] Re: Slow OCD Remote/Insight debugging
2005-10-02 by Paul Curtis
John,
> MByte/sec, not 1Mbit/sec.
You can't get anywhere near that on ARM7TDMI-S parts which we are
dicussing, so this claimed speed is irrelevant in this instance.
> http://www.signum.com/Signum.htm "Actual speed 1.062
> Mbyte/sec tested with ARM Evaluator 7T board and 600 MHz
> downloads."
Yes, the Evaluator-7T is a hard core and TCK can be clocked at 10MHz in
this case (or greater in some cases).  However, not all ARM parts
support this.
> the target device and connections can hold up.
USB 2.0 conformance does not imply a high speed device.  CrossConnect is
a USB 2.0 full speed device. Is the JTAGjet a full speed or high speed
device?  Or are you making the assumption that all USB 2.0 devices are
high speed and equating 2.0 devices to be inherently faster than 1.1
devices?  USB 1.1 full speed devices can support 1Mbyte/sec data rates
over USB so the statement "Since the JTAGjet uses USB 2.0 this is
reasonable" holds no weight.
> Flash, which many developers do not need to bother with
> during development if all their code fits into RAM, the
> claimed speed supports what many developers welcome and which
> was mentioned by Chris: rapid reading of data blocks at breakpoints.
We are dicussing speed on the LPC2000--which, by definition, people *do*
need to worry about because many devices have limited RAM, no external
bus, but lots of flash (like the 2148, for instance).  The claimed speed
avantage of the JTAGjet is put to the test in this instance and is below
even the lowly speed of a wiggler.  The original poster said his code
did not fit in RAM and he needed to put in in flash--so the claimed
speed advantage of the JTAGjet is worthless (in this instance).
> ARM debuggers and another version of the JTAGjet supports ETM.
...your point?
-- Paul.
2005-10-05 by sig5534@hotmail.com
[You just don't seem to understand.  14K is the flashing rate in bytes
second on TDI/TDO and clocking the JTAG state machine  ]
I believe that is what I said isnt it?   Programming time is a different
issue.
[If I told you that the CrossConnect actually runs a 4MHz clock on TCK
that's faster
than your 1M rate isn't it?]
4MHz is higher than 1MHz sure, but the JetJTAG goes up to 10MHz as well.
[You're comparing apples with oranges.  Until you can understand that we
the CrossConnect is faster.]
The discussion that was started began about the Wiggler.  I don't know where
this crossconnect thing came into it.  I know nothing about timings or
performance with that unit.  I don't have one.  I have a JetJTAG and a
Wiggler and that was the point of my comments and comparison.
If you have some other unit and love it, hey I'm happy for you.  But that
has nothing to do with the original post I responded to.
Chris.
2005-10-05 by Michael Johnson
>issue.
>that's faster
We've also established that a wiggler used with CrossWorks for ARM will
flash an LPC21xx faster than a JetJTAG.
Michael
>Chris.
>Yahoo! Groups Links
2005-10-06 by John Heenan
> John,
> dicussing,
Comments below!
You made a factual error about the hardware capibility of another
product in the course of sneering the product. You stated words to
the effect "Not so jet after all".
First ETM (Embedded Trace Macrocell) is fitted to all LPC2xxxx
ARM7TDMI-S parts and uses pins independently of JTAG and so TCK. If
LPC2xxxx parts are happy to support ETM speeds, I don't see why the
same parts cannot support very high JTAG speeds. Why should one set
of pins support very high speeds and not another.
Second the JTAG hardware embedded in ARM7TDMI-S parts is not part of
the core hardware. It monitors the buses and bus signals and is
clocked independently of the core with the JTAG TCK.
Third the core hardware is hard hardware. Whether the ARM core is
labelled with S or not for synthesised has nothing to do with the
speed at which the independent JTAG hardware can be clocked at. While
I acknowledge non synthesised designed cores have less risk attached
to them in terms of using proven hardware designs, there is no
inherent reason why synthesised cores cannot have their JTAGS clocked
at well over 1Mhz.
I am not an expert on the limiting issues of maximum JTAG TCK
clocking speeds, however I suspect if there are such issues it is has
to do with factors independent of the part, which may be simply
solved. For example using proper speed cabling and including simple
RC filters to reduce signal crossover at high speeds near part pins.
> > downloads."
10MHz in
> support this.
Hard core or not is not relevant. See above.
CrossConnect is
speed
are
rates
What are you trying to pull off here?  Of course it holds weight.
Since the specs mention capibility up to 480Mbits per second then we
can assume the JTAGjet advertises itself to the USB bus as being able
to support full USB 2.0 speed and not only that, appears to claim
capibility of processing the USB speed offered from and to the
without signalling bottlenecks, if the part allows. Since I don't
have the USB specs to hand I do not know what the highest average
speed that USB 2.0 is capable of supporting from the PC side.
breakpoints.
*do*
external
speed
below
code
It is helpful if we stick to core issues. There is no monopoly on
flash programming techniques, which are relatively simple.
Here is one simple method of programming flash with JTAG that all
JTAG debuggers can use
1. Download flash programming code to RAM
2. Download a portion of code to be programmed through JTAG to RAM
3. Execute code in RAM to program data previously downloaded to RAM
to flash
Steps 1 and 2 are influenced by download speed
Step 3 is not influenced by download speed. Step 3 introduces a
bottleneck that has more of a penalising effect on faster
downloaders. Whatever flash programming method one device uses, so
can the other.
> ...your point?
Relevancy and fair representation.
If your product is used it will only work with your ARM IDE
(including debugger). Signum claim the JTAGjet will work with all
major ARM debugger and compilers such as IAR, GNU, ARM etc. Signum
does not list your product as a major ARM product.
ETM (Embedded Trace Macrocell) is fitted to all the LPC2xxx products
and so it is relevant for debugging. It does not use the JTAG ports
Some additional relevant points
Since JTAG is bi-directional, faster downloads mean fast uploads.
Fast uploads mean fast filling of data blocks at breakpoints, which
is the point Chris mentioned.  Developers examine breakpoints more
often than they download.
Keeping code in RAM means more breakpoints become enabled than the
two breakpoints that are available when debugging code in Flash
(unless fancy tricks are used that reduces flash life).
Even if all code will not fit in RAM, some of the code can be copied
from flash to RAM during startup to run from RAM. The code running
from RAM will also have the luxury of not being limited to two
breakpoints.
I really don't have time for this. It does not earn me bread and
butter. I am not a ARM or any other tools vendor or representative.
I have evaluated an LPC2xxxx part using a Wiggler clone with OCD
Remote/Insight. I am working on projects with another non ARM part
that uses a USB debugger. I know the value of being able to read back
data quickly into a debugger at breakpoints and I know the value of
being able to obtain trace information unobtrusively. I monitor the
group to keep abreast of interesting developments that I may use in
the future. I do not enjoy participating in negative debate.
John Heenan
With regard to improving JTAG clocking speed, I should rephrase as I
acknowledge ARM newsgroups have higher ratios of educated and informed
participants.
Simple techniques such as avoiding lengthy PCB tracks, using
appropriate cabling and using termination resistors may be all that is
needed to get dramatic improvements in JTAG clocking speed.
I am sorry if this unleashes the 'holier-than-thous' among us waiting
for an excuse to assert their 'heroic insights'.
John Heenan
2005-10-06 by Paul Curtis
John,
> MByte/sec,
> > > not 1Mbit/sec.
> > dicussing,
> Comments below!
> another product in the course of sneering the product. You
> stated words to the effect "Not so jet after all".
No, I don't think I made that assumption.  I didn't sneer either--I just
said in this instance we've proven that the expensive JTAGjet is slower
than a $20 wiggler when downloading and flashing an LPC229x.  I've even
provided numbers to prove it.
> LPC2xxxx ARM7TDMI-S parts and uses pins independently of JTAG
> and so TCK. If LPC2xxxx parts are happy to support ETM
> speeds, I don't see why the same parts cannot support very
> high JTAG speeds. Why should one set of pins support very
Try this link.  http://www.arm.com/support/faqip/3732.html.  Extracting
the relevent details, "If the RTCK output is not used, it is required
that TCK is running at a maximum of 1/6th the system clock frequency if
only 1 JTAG synchroniser is implemented in the system."  Although the
ETM will run quickly as it's driven from the core, JTAG will not run
quickly because without RTCK you can't send data at more than 1/6th the
system clock frequency.  For an LPC2k at 10MHz, that's 1.67MHz TCK.
> part of the core hardware. It monitors the buses and bus
> signals and is clocked independently of the core with the JTAG TCK.
Correct.
> core is labelled with S or not for synthesised has nothing to
> do with the speed at which the independent JTAG hardware can
> be clocked at. While I acknowledge non synthesised designed
> cores have less risk attached to them in terms of using
> proven hardware designs, there is no inherent reason why
> synthesised cores cannot have their JTAGS clocked at well over 1Mhz.
Read the above.  I didn't say they could not.  I can achieve a 4MHz TCLK
on an ARM7TDMI-S.
> it is has to do with factors independent of the part, which
> may be simply solved. For example using proper speed cabling
> and including simple RC filters to reduce signal crossover at
No, you're completely wrong here.  The factors are part of the JTAG
design on the part, as the above link shows.
> > > http://www.signum.com/Signum.htm "Actual speed 1.062 Mbyte/sec
> > > tested with ARM Evaluator 7T board and 600 MHz Pentium
> III PC with
> > > USB 2.0 port. Faster PCs may yield faster downloads."
> 10MHz in
> > support this.
Yes, it certainly *is* relevant.  The ARM7TDMI is different from an
ARM7TDMI-S and the internal JTAG architecture *is* different.  ARM even
produce a document showing the differences.
> CrossConnect is
> speed
> are
> than 1.1
> rates
> then we can assume the JTAGjet advertises itself to the USB
> bus as being able to support full USB 2.0 speed and not only
> that, appears to claim capibility of processing the USB speed
> offered from and to the without signalling bottlenecks, if
> the part allows. Since I don't have the USB specs to hand I
> do not know what the highest average speed that USB 2.0 is
A USB 2.0 device can run at 12 or 480Mbps.  If you say "full USB 2.0
speed" then that means 12Mbps.  Even so, a full speed device should be
able to transfer data at well over 1MB/second, which is 8Mbps.
> > ...your point?
For now, yes.
> all major ARM debugger and compilers such as IAR, GNU, ARM
> etc. Signum does not list your product as a major ARM product.
I wouldn't want it to.  We are not in the Signum market.
> products and so it is relevant for debugging. It does not use
> the JTAG ports
Pardon?  The ETM connector does use JTAG signals and they are require
for debugging.  The ETM is for tracing.
> which is the point Chris mentioned.  Developers examine
> breakpoints more often than they download.
What does "examining a breakpoint" mean?  How much data do you need to
upload at a breakpoint for heaven's sake?
> than the two breakpoints that are available when debugging
> code in Flash (unless fancy tricks are used that reduces flash life).
I agree here.
> copied from flash to RAM during startup to run from RAM. The
> code running from RAM will also have the luxury of not being
> limited to two breakpoints.
Correct.
Sure you do.  Otherwise you wouldn't have responded.
-- Paul
2005-10-06 by Charles Manning
> at well over 1Mhz.
This is not actually true. The ICEBreaker is part of the core.
Non-S parts have independent clocking for the ICEBreaker and the JTAG speed is
basically as fast as the JTAG/ICEBreaker circuit on the chip will handle (ie
limited by transmission effects, slew rates etc).
S parts use the MCLK to deglitch the JTAG lines. The maximum speed is 1/6 the
MCLK speed.
This is clearly documented in one of the docs on www.arm.com.
This introduces some interesting quirkiness for devices that start on a slow
clock and then switch to a faster clock later.
As for the other points being made: My 2c...
The JTAG or USB speeds are not the only important issue when it codes to
debugging speed. One very important factor is where the core-handling logic
is. For example, if the JTAGger is just a "dumb" JTAG probe then a lot of low
level JTAG transactions need to be passed over the USB link to do anything
useful. If the JTAG probe instead has ARM core smarts built in, then  the
traffic can be much higher level. eg. "We hit a break and here is the
register set". The top-end units (bdi200 and friends) implement the whole lot
in the debugger.
A slow but smart JTAGger will knock the pants off a fast but dumb one any day.
> John,
I just
slower
even
You don't seem to be getting the message. We really don't care if one
device is more optimally used by external software than another for
downloading to flash. A few seconds here or there every 10 minutes or
so is not a big issue. Getting information quickly into a debuuger at
a breakpoint is a big issue.
There is more to the life of developers than downloading to flash and
there are very important uses for JTAG debuggers when higher speeds
are a wonderful convenience.
You know a Wiggler or compatible has no buffering capability, is
clocked under PC software control (via dead simple drivers if W2K or
XP) and is at the mercy of the operating system and PC hardware.
Extracting
required
frequency if
Suppose RTCK is used then the limitation does not apply.
Suppose the system clock frequency is 60Mhz. Then TCK maximum is
10Mhz if RTCK output is not taken advantage of.
See above why this is irrelevant to this posting. LPC2xxx parts are
rated up to 60Mhz and have buffering techniques to minimise wait
states when executing from flash.
No you are wrong. Clearly explained above
require
ETM pins ON PARTS are not shared with JTAG pins ON PARTS. A single
Mictor connector may include connections to both set of pins
Tracing is used as a debugging tool.
No I don't have time for this. It brings no benefit to those
supporting my projects and is not productive. While I recognise those
who partake in debates can gain noteriety, that is not my business.
John Heenan
--- In lpc2000@yahoogroups.com, Charles Manning <manningc2@a...>
JTAG speed is
handle (ie
is 1/6 the
> MCLK speed.
Thanks for your comments. However the above limitation only applies
if RTCK is not used.
This is from http://www.arm.com/support/faqip/3732.html
"It is possible to avoid using the RTCK signal shown in the diagram,
however if the RTCK output is not used, it is required that TCK is
running at a maximum of 1/6th the system clock frequency if only 1
JTAG synchroniser is implemented in the system"
Apart from this if takes good board design and connectivity to take
advantage of the JTAG TCK beyond 1Mhz.
Since we are at this advanced level it may be of interest to point
out to readers how JTAG uses its bus monitoring to get instructions
executed and information in and out of memory.
JTAG uses very simple but messy techniques. There is open source
software that clearly demonstrates these techniques.
JTAG not only read buses it can write to them when the core is under
debug control. JTAG can pipe a limited range of instructions into the
JTAG core for execution under JTAG debug control or under subsequent
temporary non debug system control (a signal is set that places the
core straight back into debug control).  Since reading and writing to
memory needs to be carried out at system speed, JTAG pipes in a
single read to registers or write from registers to execute at system
speed.
For writing instructions are piped in prior that load the registers
with values to write
For reading instcutions are piped in afterwards to make the values
read into the registers appear on the bus for monitoring.
Very simple, very effective and very messy.
John Heenan
on a slow
codes to
handling logic
lot of low
anything
then  the
whole lot
> in the debugger.
one any day.
2005-10-07 by John Heenan
The 'max TCK=1/6 MCLK if RTCK not used' rule only appears to apply if
the core is not in a debug state.
If the core is placed in a debug state, such as at a breakpoint,
there is no system clock to syncronise with!
While in a debug state JTAG will need to execute some one-at-a-time
piped instructions at system speed before returning straight into a
debug state (explained in prior posting). This may be an issue if
JTAG is polling for a return to debug state. However there is a hell
a lot work carried out by JTAG debuggers outside this.
John Heenan
> Extracting
> required
> frequency if
2005-10-07 by Charles Manning
That is probably not true. There is still an MCLK, but it is just not being
used to currently execute the core, however it is still there. Various
peripherals etc can still be running off MCLK. Without it SDRAM etc will die.
All register to RAM transfers are done at full clock speed.
I'd have to read it all up again, but from my understanding, the 1/6 rule is
used by the deglitching logic on the outside of (ie. JTAG side of) the
ICEBreaker. There is nothing I have read to suggest that the deglitcher turns
off during debug, so I assume the clock is still there and used.
As for RTCK, this is academic. A synchronous deglitcher will essentially
throttle the RTCK speed to 1/6 anyway.
Very much agree and that is why I made the point of dumb vs smart probes,
Consider the case of writing some data into RAM:
Smart probe:
  Host: Write these bytes to address xxx"
  Probe: Done
Dumb probe:
  Host: Read this jtag register
  Probe: Here it is
  Host: Now Write this jtag register
  Host: Now Run-test-idle
  <above sequence for n times>
  Host: Read status
  Probe: Here it is
  <above until the core returns to debug state>
The dumb probe scenario has had to shovel a lot of data through the host's
drivers and control application. This adds a lot of latency. Smarter probes
can handle the core interaction with no help from the host and can process
the data a lot faster.
Even while the core is running, there is a lot of stuff that should be going
on monitoring the state of the device and servicing the debug communications
channel (DCC). Very few, if any, of the low end JTAG devices do this properly
and I have not seen any that support DCC - probably for that reason [I admit
I have not looked hard]. The "smart" probes will handle all the core state
(including DCC handling) in the probe. "Dumb" probes that send bit wiggles or
low-level JTAG commands over the USB cannot do an effective job of handling
DCC etc.
IMHO a good debugger will spend all its running time reading the debug status.
It should be able to read this approx 20-100k times per second. That can make
a DCC that transfers probably around 100kbytes per second.
A "dumb" probe can probably only read the status 1k times per second and can
probably manage no more than 4 or 5 kbytes per sec over the DCC channel.
Most of the performance in a debugger is linked to its ability to do higher
level activities autonomously. While the JTAG clock is obviously a factor it
is far from being the most important factor.
2005-10-07 by sig5534@hotmail.com
> > dicussing,
Correct.  The maximum speed I can use with the JTAGjet is 4MHz on these LPC parts.
BTW, I was incorrect before, the JTAGjet goes to 30MHz when I checked it again.
It is not as simple as you try to make it.  The Signum Chameleon debugger software has a ton of features, and many different options and capabilities.  The price is not so much for the debugger hardware, as it is for the software.  The software is superb.  Best debugger I have ever used by far.  Price I paid was $1200, and when you compare that to Greenhills and others I think it is a good value and much cheaper.  It also supports a ton of CPUs and DSPs.
Programming can be done in different ways, and each has different advantages and disadvantages.  One method may take longer than another, but the way in which Signum handles this provides great flexibility and control.
I use both the Adaptive clocking (RTCK) and fixed freq on my JTAGjet.  It does both equally well.
Correct.  I have actually tried attaching caps on the JTAG header pins and nothing I did made any difference on the 4MHz speed limitation.
> > a USB 2.0 full speed device. Is the JTAGjet a full speed or high speed device?
It is Full speed.  The USB-2 terminology has become misused, and if you look at the USB.ORG web site you will see a notice that they actually do not want people saying "USB 2.0" if it is only full speed.  Philips makes this same exageration on their own 2148 series parts which say "USB 2.0" but they are Full speed.
>> How much data do you need to upload at a breakpoint for heaven's sake?
A ton.  I have watches on large structures where I need to read 8K blocks of data, and that data must be read whenever I stop the CPU.  There is a lot of data flow, but then Chameleon processes a lot of data.  In some cases I also need to download corrected blocks to RAM.  It's just a whole lot snappier with the JTAGjet than a wiggler.  At least that's what I see.
Chris.
apply if
not being
Thanks for your follow up.
In a debug state there is no system clock activity relevant to JTAG.
The point I was making below is that apart from when JTAG must allow
some instructions to execute at system speed, the rule does not
appear to have relevance. Of course there may be other limiting
factors, but hardly the synchronising one since there is nothing to
synchronise with.
John Heenan
Various
will die.
1/6 rule is
deglitcher turns
essentially
time
a
hell
probes,
> Smart probe:
>   Probe: Done
> Dumb probe:
>   Probe: Here it is
>   Host: Read status
>   Probe: Here it is
host's
Smarter probes
process
be going
communications
this properly
[I admit
core state
wiggles or
handling
> DCC etc.
debug status.
That can make
second and can
channel.
do higher
factor it
are
> > > dicussing,
these LPC parts.
checked it again.
There has been no information provivded or pointed to that puts the
limiting factor on the ARM7TDMI-S part itself.
Adaptive RTCK use overcomes the 1/6 rule when the core is not in a
debug state. In a debug state there is no clock relevant to JTAG to
synchronise to.  Yes I am aware of the 'switch to system speed and
back to debug' issue.
There are lots of reasons why speed becomes maxed out. Not the least
of which is wiring.
It would be nice to know what the limiting factor is to investigate
if it can be overcome and so use the more capable debug tools to
their full capacity.
John Heenan
Extracting
required
frequency if
JTAG
limitation.
I am sorry but I don't regard this as conclusive.
John Heenan
Re: Slow OCD Remote/Insight debugging. Hard information from logic diagrams
2005-10-08 by John Heenan
I have closely examined JTAG synchronisation logic diagrams for
synthesized cores on the official ARM web site
Reading logic diagrams is a skill I first learnt at university in
Ireland in the seventies from an enthusiastic and fresh lecturer from
England whose career was sadly cut short following his death in a car
accident in France.
The synchronisation logic ENFORCES the following.
1. An enforcement of maximum possible TCK frequency of 1/6 of the
internal clock frequency.
2. An enforcement that internal clock must be applied to the logic
when the core is in a debug state and the core is not been clocked
itself.
3. An enforcement that RTCK, which can be used to trigger CLK, is a
maximum possible of 1/6 the internal clock
So I acknowledge
1. Use of RTCK cannot raise throughput during the non debug state
2. During debug state the 1/6 rule applies
However I will not acknowledge that the entire set of enforcements is
strictly necessary.
So far I have not been able to find out why ARM insists on
enforcement of the 1/6 rule for synthesized cored. My guess is that
the rules are grossly conservative and not due for any inherent
property of synthesized cores as opposed to 'hard' cores.
I have included some quotes from ARM from links below. I have doubts
whether the quotes make complete sense given the enforcement nature
of the logic. However I have no wish to spend time debating this.
Also the enforcement nature of the logic lends supports that problems
reaching 1/6 MCLK are due to problems external to the part, such
using cabling and termination that is inappropriate for the speed.
Informative links are
http://www.arm.com/support/faqdev/4170.html
(How does the JTAG synchronisation logic work? / How does adaptive
clocking work?)
and
http://www.arm.com/support/faqdev/1321.html
(What is the maximum TCK frequency that I can set up with Multi-ICE?)
The Multi-ICE debugger is the 'official' JTAG debugger of ARM. The
information is relevant to other debuggers.
Multi-ICE can generate a maximum TCK frequency of 10MHz
For hard macrocells ARM states:
"You should normally be able to work with TCK faster than 1MHz".
For synthesizable cores ARM states:
"The three sampling flip-flops set the theoretical maximum TCK
frequency, which is one sixth of the core clock frequency (one eighth
in ARM11)..."
and
"The real maximum TCK frequency will be lower than this and will
depend on the core clock frequency, the delays on the JTAG signals
and the setup time of Multi-ICE and the ASIC."
Also
"If your target provides RTCK, you can also configure Multi-ICE in
adaptive clocking mode. Multi-ICE will automatically work at a TCK
frequency close to the maximum possible one."
John Heenan
> are
> > > > dicussing,
> these LPC parts.
> checked it again.
least
> of which is wiring.
> John Heenan
> Extracting
> required
> frequency if
> JTAG
> limitation.
> John Heenan
Re: [lpc2000] Re: Slow OCD Remote/Insight debugging. Hard information from logic diagrams
2005-10-08 by Rob Jansen
John Heenan writes:
>  So I acknowledge
>  strictly necessary.
Agree, but I am not sure how the DBGTCKEN is used by the EmbeddedICE module.
If what I think is true you would be able to clock in data at a higher
speed (up to CLK?) after having your first positive edge on RTCK. This may
- or may not - work and I'm not in the mood for trying this out myself.
I'm currently using an lpc21xx to control the JTAG of the next one using
software. If you start using a TCK > 1/6 CLK (if possible at all ...) then
you need to take care of RTCK synchronization in a completely different
way.
Thanks, I had not seen the timing diagrams (they were not in my pdf file)
but I have figured things out from the schematics. My software is also
using the adaptive clocking mode as described in software:
    - set TMS & TDI to correct values
    - raise TCK
    - wait for RTCK
    - drop TCK
And then wait for RTCK to be low before the next bit to write.
This works, I am able to talk to the EmbeddedICE registers without any
problem. Communication with the Debug Communication Channel (DCC) is also
no problem.
I am now reading that part of the spec where it tells me how to clock the
instructions into the chain. It's all about reading the documentation
carefully ...
Rob
I should explain what I mean by enforcement logic.
What the synchronization logic really does is deliberately distort
your triggering UNLESS you stick to the 1/6 rule.
It is like a policeman that says we don't care if you break the speed
limit and if the speed limit is too low, as we have speed detectors
that will trigger lasers to destroy your car if you go over the
limit.
The combination of three edge triggered D flip-flops with a logic
gate that requires the input to the final flip-flop to be different
to what was latched on the prior triggering clock edge to the same
flip-flop means that you must stick to the 1/6 rule to ensure the
output from the logic reflects the TCK input.
John Heenan
from
car
> accident in France.
> itself.
> So I acknowledge
is
> strictly necessary.
doubts
problems
> clocking work?)
> and
ICE?)
eighth
> in ARM11)..."
> and
> Also
> John Heenan
we
> > are
> > > > > dicussing,
on
> > these LPC parts.
> > checked it again.
a
to
and
> least
> > of which is wiring.
investigate
> > John Heenan
> > Extracting
> > required
> > frequency if
at
> > JTAG
header
> > limitation.
> > John Heenan
