Neutral Prints On 2200
2003-12-09 by Shilesh Jani
Hello All,
I am fairly experienced with using numerous grayscale inks on a
1280.  Having previously used color inks to print b/w, I know how
challenging (and frustrating) it can be.  So I was impressed when a
friend of mine recently showed me a 13 x 19 b/w print he made on his
2200.  It was absolutely neutral and showed no evidence of metamerism.
I went to his home last night and saw first-hand how he stumbled upon
this.  Here goes:
Paper:  DotWorks FineArt HeavyWeight paper
Printer Settings: Enhanced Matte media setting, 1440 dpi, ICM, NCA
Profile:  Downloaded from the dotworks.com website.
That is it!  The image space can be either grayscale or color RGB.
This was the best print I  have seen from a 2200 that did not use
some fancy RIP.  I am not in anyway connected to DotWorks.  But I am
sufficiently impressed and thought you 2200 owners may want to know.
I am going to play with his system some more and see if I can get
such fine prints using the profile on other papers.
Regards.
Shilesh
Re: Neutral Prints On 2200
2003-12-09 by flyfishingusa2002
Shilesh,
If you are setting the printer to ICm then you are using the canned
windows profiles to print with.In order to use the dotworks, or any
other profile you need to set the printer output settings to "no
icm" and select the profile from photoshop or convert you file in
some way.
Seirra Gold
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Shilesh Jani"
<shilesh.jani@s...> wrote:
> Hello All,
a
his
metamerism.
upon
> this.  Here goes:
am
know.
> Regards.
> Shilesh
Re: [Digital BW] Neutral Prints On 2200
2003-12-10 by Richard Sintchak
Tuesday, December 9, 2003, 11:01:53 AM, you wrote:
SJ> Hello All,
SJ> I am fairly experienced with using numerous grayscale inks on a
SJ> 1280.  Having previously used color inks to print b/w, I know how
SJ> challenging (and frustrating) it can be.  So I was impressed when a
SJ> friend of mine recently showed me a 13 x 19 b/w print he made on his
SJ> 2200.  It was absolutely neutral and showed no evidence of metamerism.
SJ> I went to his home last night and saw first-hand how he stumbled upon
SJ> this.  Here goes:
SJ> Paper:  DotWorks FineArt HeavyWeight paper
SJ> Printer Settings: Enhanced Matte media setting, 1440 dpi, ICM, NCA
SJ> Profile:  Downloaded from the dotworks.com website.
SJ> That is it!  The image space can be either grayscale or color RGB.
SJ> This was the best print I  have seen from a 2200 that did not use
SJ> some fancy RIP.  I am not in anyway connected to DotWorks.  But I am
SJ> sufficiently impressed and thought you 2200 owners may want to know.
SJ> I am going to play with his system some more and see if I can get
SJ> such fine prints using the profile on other papers.
SJ> Regards.
SJ> Shilesh
Well, I do not see how one can use ICM and NCA at the same time so I
used NCA with the dotworks FHM profile (assuming that to be
Heavyweight Matte) and with Epson EEM on my 2200 my "neutral" B&W
print came out greenish under incandescent light, and even greener in
daylight....
Shilesh, can you expound a bit more on the workflow and did you truly
examine his print under vastly different lighting?  This sounds so
promising based on your enthusiastic comments but obviously so far I
am disappointed.
Best regards,
 Richard                            mailto:richard@...
2003-12-10 by Shilesh Jani
Richard,
My friend's system is a PC with Win XP, just so you know.  When
setting up the printer, upon choosing ICM, a new set of controls
opens up.  It is here, that NCA was checked.
Then, using "print with preview", keep your image source space
to "grayscale" or "adobe RGB 1998", and print with the DotWorks
profile.
A word of caution:  The profile is probably very specific to the
paper, so unless EEM and the DotWorks paper are identical, you are
highly unlikely to get the same results.
I will play with the printer some more and post any other
clarifications, as necessary.
Regards.
Shilesh
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Richard Sintchak
> SJ> Hello All,
how
when a
on his
metamerism.
stumbled upon
NCA
RGB.
use
I am
know.
get
> SJ> Regards.
> SJ> Shilesh
in
> daylight....
truly
> am disappointed.
> Best regards,
>  Richard                            mailto:richard@c...
2003-12-10 by flyfishingusa2002
I don't know what version of the Epson driver your friend is using,
but on my XP systems when you select "ICM" no further controls are
shown. Why would they? Choosing to use "ICM" means that you are
wanting windows to select the printer colotr management.
You mail looks like a plug for dotworks papers to me.
Injetmall has been trying to produce a ICC profile to obtain b/w
prints from a 2200, so far they have not managed it.
They only way to do this is to use a RIP of somekind. QTR is my
choice because it works and its free.
Sierra Gold
> Richard,
> profile.
> Regards.
> Shilesh
Sintchak
> > SJ> Hello All,
on a
know
> how
> when a
made
> on his
> metamerism.
> stumbled upon
ICM,
> NCA
color
> RGB.
not
> use
But
> I am
to
> know.
can
> get
> > SJ> Regards.
> > SJ> Shilesh
so I
greener
> in
> > daylight....
> truly
so
far I
> > am disappointed.
> > Best regards,
RE: [Digital BW] Neutral Prints On 2200
2003-12-10 by Daniel Staver
As far as I know the new version of the 2200 driver changed around the
controls a bit, and moved several options under the title "ICM". With
the 2100 (which I have) and the old 2200 driver "ICM" is just a single
option.
Daniel Staver
http://daniel.staver.no
2003-12-10 by Ken Schuster
Apparently so, if you don't want to consider Septone, PiezoTone and others.
Sent: Wednesday, December 10, 2003 1:16 PM
Subject: Re: [Digital BW] Neutral Prints On 2200
...snip...
"They only way to do this is to use a RIP of somekind. QTR is my
choice because it works and its free."
...snip...
Shilesh,
Something does not seem right here.  First I do not remember there
being any options after I clicked ICM (not at my home computer right
now) but you also mention to keep the image source space to grayscale
or sdobe RGB, but if I do that where does one apply the dotworks
profile?  Maybe I'm misunderstanding something here...
Richard
> Richard,
> profile.
> Regards.
> Shilesh
Sintchak
> > SJ> Hello All,
a
> how
> when a
> on his
> metamerism.
> stumbled upon
ICM,
> NCA
> RGB.
> use
But
> I am
to
> know.
> get
> > SJ> Regards.
> > SJ> Shilesh
so I
greener
> in
> > daylight....
> truly
far I
> > am disappointed.
> > Best regards,
2003-12-10 by njfranknj
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Ken Schuster"
others.
> From: flyfishingusa2002
> ...snip...
> ...snip...
May I again offer a different possibility?
I just printed a grayscale using the description of this method next
to one of my 4 ink grayscale "duotones" on a 2200 with PS4.0 and MIS
7600 inks and have to say that there is no comparison - the duotone
method step scales have none of the color shifts that are quite
obviously displayed by the RGB/ColorMatch method.
Is it as good as a RIP? I don't know. Septone? Probably nowhere near.
Is it good enough for somebody who wants 1 printer to do both while
giving the flexibility of making toned B&W prints? Well, how about
checking it out for yourself?
My color vision in not good enough to see subtle tones or shifts, so,
would someone using the same printer/ink setup please take the time
to do a test. Since it requires curves and ink definitions that I
have developed, you'll have to write me for a return e-mail with a
description of the process and attached Photoshop curve/ink info. It
is much simpler than the conversion needed for a quadtone ink printer.
By the way, this does not work on a 1200 and may not on the later
12xx series, either.
Frank
2003-12-11 by janishilesh
Hello Richard,
The 2200 driver used was version 5.40.  When you go into the
click "advanced", the "ICM" option is bow available.  Upon
cliccking "ICM", one of the options is "No Color Correction".  That
is what I chose.  Then, in PS 7.0, "print with preview", and here is
where you choose the profile.
Someone mentioned that the printer driver has been changes quite a
bit recently.  But since I don't own a 2200, I cannot be sure.
Regards.
Shilesh
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Richard
Sintchak" <richcontaxg@s...> wrote:
> Shilesh,
right
grayscale
> Richard
> > Richard,
> > profile.
are
> > Regards.
> > Shilesh
> Sintchak
> > > SJ> Hello All,
on
> a
know
> > how
impressed
> > when a
made
> > on his
> > metamerism.
> > stumbled upon
> ICM,
> > NCA
color
> > RGB.
not
> > use
> But
> > I am
> to
> > know.
can
> > get
> > > SJ> Regards.
> > > SJ> Shilesh
> so I
B&W
> greener
> > in
> > > daylight....
> > truly
so
> far I
> > > am disappointed.
> > > Best regards,
2003-12-13 by charliemb
I ordered the 15 mil Nature Jet Coated and downloaded the profile.  I
could not find the paper on the dotworks site but after emailing them
they pointed me to dotinkjet.com and the Nature Jet papers found
under "Fine Art."  About a buck a sheet.
While I wait for it to arrive I am playing with the dotworks
2200_FHM.icm profile on Epson Enh.Matte.  With this "wrong paper" I
also am getting greenish print, but the density matches my
clalibrated monitor well.
Regards, Charlie
2003-12-22 by Charlie Bustamante
This is my report on the dotworks paper and profile.  I ordered the
paper as soon as I heard the report posted here.  The paper arrived
promptly after ordering it, within the week.  The paper itself is
very heavy and appears to be very nice.  Its white point is more
yellow than the Epson enhanced Matte and that may be why it
experiences less metamerizm.  That is, perhaps less yellow ink is
needed since the paper is yellowish to begin with, and as a result,
less metamerizm is produced.  Who knows, but it does appear to be the
case that the paper exhibits less metamerizm than anything printed on
the Epson enhanced Matte.
It turns out that on my printer, the prints turn out a little
yellowish green.  Okay, more than just a little.  The prints appear
less yellowish green than on Epson enhanced Matte paper using the
same profile but still not quite neutral.  Your mileage may vary.
The exact name of the paper I am using is "Nature Jet Coated Inkjet
Paper 100% Cotton 15 Mil."  I did experience a problem using the
matte black cartridge on this dotworks paper.  It turns out the paper
cannot handle too much of the matte black ink.  The darkest 1/8th of
a gray test pattern that I use turns glossy and dMax is impaired.
This problem is alleviated by using the photo black ink cart but then
the dMax suffers because of the photo black on Matte paper (flat,
very flat).  So, the bottom line for me is, I switched back over to
the Epson enhanced Matte paper and this dotworks profile to see what
I could do.
I have to say though, the prints are quite nice on Epson enhanced
Matte paper with this profile (2200_FHM.icm).  For Qimage users who
want to play around with this profile on Epson enhanced Matte paper,
I developed a quick curve that tends to neutralize this profile
on Epson enhanced Matte paper even further.  It is still a moss-toned
print (mostly in the upper mids), but the overall print seems to
work.  Actually I have three curves: '6, '4, and 'Latest, '6 should
be more neutral than '4 and 'Latest is like '4 only warmer.  Just
copy the files to the Qimage "filters" folder and apply the filter
(which is a curve) either as a filter for the image or as a print
filter.
You can find the Qimage curves here:
http://tiyoweh.ugate.net/2200_FHM6.flt
http://tiyoweh.ugate.net/2200_FHM4.flt
http://tiyoweh.ugate.net/2200_FHM-latest.flt
Regards,  Charlie
upon
> this.  Here goes:
am
