Everything affects the sound. Whatever you sampled with ADC coming in is
going to come out.
Which means you add something sampling in, and you add something sounding
out.
On Thu, Feb 16, 2012 at 12:27 PM, jammie <jammie.emma@...>wrote:
> actually the adc are much better in the newer samplers with over sampling
> with the older samplers they used noiser products opamps lower rate dacs
> noisier cmos chips
> and specialist voice chips now its the specialist voice chips that are the
> biz and give the character to the samplers
> the later samplers were basically computers with softsynthesis engines
> From: "el macaco" <elmacaco@...>
> To: <emax@yahoogroups.com>
> Sent: Thursday, February 16, 2012 5:12 PM
> Subject: RE: [emax] Re: How can I dither samples to 12 bit for EMAX?
> > I think that back then the ADC in the samplers were just built to a
> higher
> > standard because they were new and chasing the best fidelity to cost
> > ratio, the technology hadn't developed enough to make them cheaper.
> > Just my theory though.
> > To: emax@yahoogroups.com
> > From: jammie.emma@....uk
> > Date: Thu, 16 Feb 2012 16:59:30 +0000
> > Subject: Re: [emax] Re: How can I dither samples to 12 bit for EMAX?
> > for me its the outputs that give the emax sound and the e chip
> > From: el macaco
> > Sent: Thursday, February 16, 2012 4:24 PM
> > Agree 100%. Transfering samples in sounds good/ok. Sampling in is the
> > business, sounds SO GOOD, over driven, clean, whatever, the ADC is the
> > gold in the Emax for me.
> >> From: francis.cote@...
> >> Date: Thu, 16 Feb 2012 10:53:24 -0500
> >> It's great you found a solution.
> >> Understand I don't agree or disagree, I just want to take
> >> this opportunity to ask others how they feel about what I'm about to
> >> write.
> >> I feel that if you are bypassing part of the sampling process of a
> >> hardware
> >> sampler, be it an Emax, E4, Akai, whatever, you are also bypassing part
> >> of
> >> the character of the machine as well. This is, again that's me, what
> >> makes
> >> an Emax an Emax.
> >> What do you people think?
> >> Francis
> >> On Thu, Feb 16, 2012 at 10:34 AM, zrennaya <zrennaya@...> wrote:
> >> > Hi!
> >> > Thanks for your input! I gave up on the 12 bit render thing as you
> >> > mentioned there's no tool that converts to 12 bits.
> >> > On the other hand I experimented with some dithering types and I
> >> > actually
> >> > managed to reach the quality of factory samples in terms of noise and
> >> > aliasing (using the L1). So far I couldn't get that quality from the
> >> > emax
> >> > ADC inputs!
> >> > --- In emax@yahoogroups.com, "jammie" <jammie.emma@...> wrote:
> >> > > there 8bits compressed then the e chip renders the 8bit compressed
> >> > > audio
> >> > to 12bit digital output that the dacs render to analog then they go
> to
> >> > the
> >> > filters
> >> > > there are no reconstruction filters for aliasing or stepping of the
> >> > > dac
> >> > waveforms aand rely on the analog filters to do this
> >> > > where as most samplers use a reconstruction filter to filter out
> >> > > these
> >> > stepped artifacts and aliasing
> >> > > now the korg dss1 is 12bits but they still use 16bit memory same as
> >> > > the
> >> > ensoniq eps just 0 after the 12bits
> >> > > there is no 12bit convertors if you want the 12bits then you need
> to
> >> > > use
> >> > the internal adc and inputs
> >> > > as the dump will be 16bits and emxp converts to the 8bit compressed
> >> > format
> >> > > From: zrennaya
> >> > > Sent: Friday, February 10, 2012 12:34 PM
> >> > > Subject: [emax] How can I dither samples to 12 bit for EMAX?
> >> > > Hello to all,
> >> > > I'm trying to convert my WAV files for the Emax but keep running
> into
> >> > the same issue. I have a mac running Logic which would allow me to
> >> > bounce
> >> > either 8 bit or 16 bit wav but not 12 bit. The Waves L1 plugin does
> 12
> >> > bit
> >> > quantize with dither and noise shaping but it's useless, since I can
> >> > only
> >> > bounce the results in either 8 or 16 bits. The problem with this is
> >> > that
> >> > the 8 bit renders are way too lo-fi and the 16 bit ones will
> >> > automatically
> >> > reduce with no dithering in EMXP when I transfer them to EM1 floppys
> on
> >> > my
> >> > PC and the no-dither artifacts are audible again. This is very
> audible
> >> > in
> >> > percussive samples. Simply recording them through the Emax input
> won't
> >> > help
> >> > either..
> >> > > So I read it on a site about s900 samplers using 12 bit samples that
> >> > mixing white noise into the audio at very low levels can actually do
> >> > the
> >> > same as dithering (don't quite understand why), tried that, same
> >> > results
> >> > except I had slightly noisier samples then :)
> >> > > I'm starting to wonder if Emax uses 12 bit samples at all. It' a
> >> > > little
> >> > confusing that it it uses 12 bit audio "stored" in 8 bits, or as I
> read
> >> > somewhere else, it uses 8 bit samples with 12 bit converters?!
> >> > > If 8 bit is the case, how come I cannot convert premium quality
> >> > > samples,
> >> > using great quality dithering and noise shaping to 8 bit and still
> not
> >> > get
> >> > the cleanness of the factory Emax samples? Or if it's 12 bit, how can
> I
> >> > render my samples to 12 bit and not let EMXP mess up my 16 bit
> samples?
> >> > I've tried some of the Sound Designer installs available here, but
> >> > couldn't
> >> > get them to work on either the mac classic emulator for windows, or
> >> > emulators for OSX. It seems like I must have been a programmer to be
> >> > able
> >> > to get them running so I gave up. Does anyone know of alternatives?
> >> > > Thank you for your attention!
> >> > > [Non-text portions of this message have been removed]
> >> Emax and Emax II User's Group Website
> >> http://www.silveriafamily.comYahoo! Groups Links
