AVR-Chat
My Avr
My Avr
2008-03-19 by ei5gtb
Hello, i recently purchased a "my avr" board from http://www.myavr.de/
But much to my disappointment the programming application was in
german. I am just a beginner, and was hoping to use this board to
educate myself. Could anyone advise if this board can be used with
other programming software? and if so, which is the best recommended one.
Many Thanks,
Paul.
Re: [AVR-Chat] My Avr
2008-03-19 by David Kelly
> one.
http://babelfish.altavista.com/ translation of http://www.myavr.de/
says the myAVR 1 board has an "integrated SP12 compatible programmer."
The downloadable PDF documentation is German on the left column, English
on the right.
IMO the ATmega8 CPU on this board is not ideal for learning because it
doesn't support JTAG ICE or DebugWire. Similar or more capable AVRs with
JTAG or DW cost the same or less. With JTAG ICE Cube at $40 and AVR
Dragon at $52, and your time is worth $1/hour, these tools are well
worth the expense.
Study the pinouts, my guess is an ATmega88 or something is available
with DebugWire that fits on that board. DebugWire only needs power,
ground, and Reset to program and source code debug on your chip.
More wires are needed to set the fuses on the chip to put it in DW mode,
but once its there you can leave it alone.
David Kelly N4HHE, dkelly@HiWAAY.net
Whom computers would destroy, they must first drive mad.
2008-03-19 by Sander Pool
I agree that JTAG capability is a must for anyone serious about
programming AVRs. Used to be that Atmel JTAG was pretty costly but now
that clones are available that's no longer true. The time saved using
JTAG to debug is enormous. At least for mere mortals like myself who
write code with the occasional bug. Availability of reliable debugging
is a must for me, no matter what language and platform I code in. At
work we use ruby for test automation and I've been frustrated by the
general unreliability of free (Eclipse, Netbeans) and commercial
(Arachno, Komodo, Ruby in Steel) debuggers. When I was told I needed to
use Python debugging was again an issue.
In any case, my point is that I fully agree with David. The other day I
decided not to use a Mega8 I had laying around for a project I'm working
on for exactly this reason (lack of JTAG). Now when I go to AVRFreaks to
pick a device I make sure JTAG is available. Once I have a Dragon I can
add debugwire to the mix. AVRs are crazy cheap and there's at most a few
$ difference between devices. For development pick a heavy weight
device. If you're developing a commercial application and pennies count
you can develop on a larger device, keeping restrictions of the target
in mind and then down porting it when done.
    Sander
> http://www.myavr.de/ <http://www.myavr.de/>
> > one.
> http://babelfish.altavista.com/ <http://babelfish.altavista.com/>
> translation of http://www.myavr.de/ <http://www.myavr.de/>
> on the right.
> worth the expense.
2008-03-19 by BobGardner@aol.com
I see lots of little British Union Jacks next to the tech bulletins in the suppot section. Maybe those are in English?
To: AVR-Chat@yahoogroups.com
Sent: Wed, 19 Mar 2008 8:47 am
Subject: [AVR-Chat] My Avr
Many Thanks,
Paul.
Yahoo! Groups Links
German flag on the left, British/US flags on the right. Download the PDF
and you'll see the left column in German and the right in English same
as the flag icon.
RE: [AVR-Chat] My Avr
2008-03-19 by Paul Sinclair
Oh, yes, there is English on it, but the actual programming software, i.e to
put the program onto the avr chip,  is in german. I was just wondering if
other programming flashing software could be used.
Debugging is nothing I have really thought abouty. The actual purpose of the
device is to control a rotator for antennas, to take commands from a
computer, and turn the antennas accordingly, and to display information on a
lcd screen. Mabye im thinking it's a little more simple then it is. I
suppose I should really go buy a beginners book. Im 16, and don't have very
much money hanging about, so I bought the cheapest I could find!
Thanks all for your replys,
Paul.
From: AVR-Chat@yahoogroups.com [mailto:AVR-Chat@yahoogroups.com] On Behalf
Of BobGardner@aol.com
Sent: 19 March 2008 17:30
Subject: Re: [AVR-Chat] My Avr
From: ei5gtb <paul@paulsnet.org <mailto:paul%40paulsnet.org> >
To: AVR-Chat@yahoogroups.com <mailto:AVR-Chat%40yahoogroups.com>
Many Thanks,
Paul.
Yahoo! Groups Links
2008-03-19 by John Samperi
>and
......"do not mention the war". (Basil Fawlty, Hotelier etc..)
John Samperi
Ampertronics Pty. Ltd.
11 Brokenwood Place Baulkham Hills, NSW 2153 AUSTRALIA
Tel. (02) 9674-6495       Fax (02) 9674-8745
Email: john@ampertronics.com.au
Website  http://www.ampertronics.com.au
*Electronic Design * Custom Products * Contract Assembly
Heh, I wasn't sure what to take by your opening comment, but you saved it!
Well, ill not worry too much about the debug capability. I suppose ill work
on learning about the dam things first! Thanks all!
Paul, EI5GTB
Of Philippe Habib
Sent: 19 March 2008 21:56
Subject: RE: [AVR-Chat] My Avr
Just wait 'till you have a 16 year old of your own. Then you'll know what
not much money hanging around really means.
Now that I've got the smart ass comment out of the way, don't worry too much
about the lack of easy debug ability. A former boss used to tell us all not
to rely on that stuff too much. "Just use the computer in your head" he
used to say. Its easy to get caught up in all of the detail a good debugger
can provide and to spend a lot of time looking at every little nit instead
of thinking through the problem and the behavior and figuring out what can
cause that behavior.
I use a debugger at work, but only when code inspection and some simple
tests don't yield results, or after that approach has narrowed down where
the problem is.
From: AVR-Chat@yahoogroups.com <mailto:AVR-Chat%40yahoogroups.com>
[mailto:AVR-Chat@yahoogroups.com <mailto:AVR-Chat%40yahoogroups.com> ] On
Behalf
Of Paul Sinclair
Paul.
Behalf
Of BobGardner@aol.com <mailto:BobGardner%40aol.com>
Many Thanks,
Paul.
Yahoo! Groups Links
Groups related to AVR-Chat
avrclub (829 common members)
http://groups.yahoo.com/group/avrclub?v=1
<http://groups.yahoo.com/group/avrclub?v=1&t=ipt&ch=email&pub=groups&slk=aft
r> &t=ipt&ch=email&pub=groups&slk=aftr
0&sec=recg
Microprocessors/Microcontrollers: Atmel AVR Microcontroller discussion
group!
e-embedded (324 common members)
http://groups.yahoo.com/group/e-embedded?v=1
<http://groups.yahoo.com/group/e-embedded?v=1&t=ipt&ch=email&pub=groups&slk=
a> &t=ipt&ch=email&pub=groups&slk=a
ftr1&sec=recg
Internet/Internet Appliances: Open-membership mailing list for embedded
system d...
piclist (280 common members)
http://groups.yahoo.com/group/piclist?v=1
<http://groups.yahoo.com/group/piclist?v=1&t=ipt&ch=email&pub=groups&slk=aft
2&sec=recg
Microprocessors/Microcontrollers: A discussion group for the PICMicro
microcontrolle...
booksbybibin (193 common members)
http://groups.yahoo.com/group/booksbybibin?v=1
<http://groups.yahoo.com/group/booksbybibin?v=1&t=ipt&ch=email&pub=groups&sl
k> &t=ipt&ch=email&pub=groups&slk
=aftr3&sec=recg
Mechanical/Robotics: This groups contains the books for robotics,parall...
Homebrew_PCBs (190 common members)
http://groups.yahoo.com/group/Homebrew_PCBs?v=1
<http://groups.yahoo.com/group/Homebrew_PCBs?v=1&t=ipt&ch=email&pub=groups&s
l> &t=ipt&ch=email&pub=groups&sl
k=aftr4&sec=recg
Engineering/Electrical: Designing, making, etching, soldering, printed
cir...
Yahoo! Groups Links
Checked by AVG.
Version: 7.5.519 / Virus Database: 269.21.7/1335 - Release Date: 3/19/2008
9:54 AM
2008-03-19 by Philippe Habib
the problem is.
Of Paul Sinclair
Paul.
Many Thanks,
Paul.
Yahoo! Groups Links
http://groups.yahoo.com/group/avrclub?v=1&t=ipt&ch=email&pub=groups&slk=aftr
0&sec=recg
group!
http://groups.yahoo.com/group/e-embedded?v=1&t=ipt&ch=email&pub=groups&slk=a
ftr1&sec=recg
system d...
http://groups.yahoo.com/group/piclist?v=1&t=ipt&ch=email&pub=groups&slk=aftr
2&sec=recg
microcontrolle...
http://groups.yahoo.com/group/booksbybibin?v=1&t=ipt&ch=email&pub=groups&slk
=aftr3&sec=recg
http://groups.yahoo.com/group/Homebrew_PCBs?v=1&t=ipt&ch=email&pub=groups&sl
k=aftr4&sec=recg
cir...
Yahoo! Groups Links
Checked by AVG.
9:54 AM
2008-03-19 by Benny Smith
Indeed.  I mentioned it once, but I think I got away with it.
Of John Samperi
Sent: Wednesday, March 19, 2008 2:35 PM
>and
John Samperi
Email: john@ampertronics. <mailto:john%40ampertronics.com.au> com.au
Website http://www.ampertro <http://www.ampertronics.com.au> nics.com.au
Re: My Avr
2008-03-19 by Graham Davies
--- In AVR-Chat@yahoogroups.com, "Philippe Habib" <phabib@...> wrote:
> ... don't worry too much about
> the lack of ... debug ... use
> the computer in your head ...
I don't disagree with you, but I agree much more with those that
advocate debuggers.  Why not use your head and a debugger?  The human
mind is seriously limited when it comes to retaining and manipulating
complex systems.  Working memory is limited to about seven independent
chunks of information.  Try to put one more in and another one falls
out.  So, take away from the brain everything the computer can do for
you and you'll be able to reason about the large structures of the
software much more effectively.  A debugger can draw you tables and
pictures of what's going on inside the system.  As you step through the
code!  In my opinion, it's madness to go without that at a saving of 50
bucks or so.  Even if you have to move to a smaller chip for production
for cost reasons, for heavens sake develop on a chip with a debug
interface.
Mind you, by starting with the absolute cheapest thing out there you've
minimized the money you've wasted when you eventually see the light!
Graham.
RE: [AVR-Chat] Re: My Avr
Hmm,
I'm really not familiar with the debugging of these chips "on a chip with a
debug interface"
But I know I should go rtfm, buts its just too easy to ask. How about
someone - instead of answering the question, will recommend a good book to
buy.
Paul, EI5GTB
Of Graham Davies
Sent: 19 March 2008 23:42
Subject: [AVR-Chat] Re: My Avr
--- In AVR-Chat@yahoogroups.com <mailto:AVR-Chat%40yahoogroups.com> ,
interface.
Graham.
2008-03-19 by Raymond Hurst
The way I understood it here is that the software tools only spoke german.
In which case, that's a big minus for me also.
Have you tried downloading the AVR tools and seeing if they work?
I suspect the USB programmer is just a copy of the Atmel design.
Ray Hurst
Western Digital
20511 Lake Forest Drive
Lake Forest, CA 92630
949-672-9853
Of Paul Sinclair
Sent: Wednesday, March 19, 2008 3:51 PM
Paul, EI5GTB
Behalf
Of Philippe Habib
the problem is.
Behalf
Of Paul Sinclair
Paul.
Behalf
Many Thanks,
Paul.
Yahoo! Groups Links
<http://groups.yahoo.com/group/avrclub?v=1>
0&sec=recg
group!
<http://groups.yahoo.com/group/e-embedded?v=1>
ftr1&sec=recg
system d...
<http://groups.yahoo.com/group/piclist?v=1>
2&sec=recg
microcontrolle...
<http://groups.yahoo.com/group/booksbybibin?v=1>
=aftr3&sec=recg
<http://groups.yahoo.com/group/Homebrew_PCBs?v=1>
k=aftr4&sec=recg
cir...
Yahoo! Groups Links
Checked by AVG.
9:54 AM
Re: My Avr
> chip with a debug interface"
Maybe you've used a hosted software development environment, like
Visual Studio or Elipse.  Working on a chip with a JTAG interface is
very much like this, except that LEDs flash and motors spin.  You
make a change to the code.  You punch the "build" button and the new
code is compiled.  You set some breakpoints by right-clicking on a
line of code.  You punch run.  There's a pause while the binary file
is transferred to the target microcontroller, then off we go.  When
the breakpoint is hit, execution stops and you can bring up various
views of memory, registers, variables, ports, etc. to see what's
going on.  Single step, step into functions, step out of functions
and run again. I haven't used debugWIRE as much, but it's pretty much
the same if a bit slower.
On the other hand, without a debugger, when you've re-built the
program you have to pop up a separate tool to take the binary file
and transfer it to the target.  When that's done, you disconnect from
the target and reset it.  Then things either work or they don't.  If
they don't, you have to figure out why either using pure brain power
or with the aid of extra bits of code inserted to make the invisible
visible.  For each trial, it's build, load, reset and ponder all over
again.
Don't get me wrong, a debugger isn't a panacea. There are problems,
particularly in hard real-time systems, that aren't helped a whole
lot by a debugger.  But, I've done projects with them and projects
without and by-and-large I much prefer to work with.
Graham.
Re: My Avr
2008-03-20 by Graham Davies
--- In AVR-Chat@yahoogroups.com, "ei5gtb" <paul@...> wrote:
> ... i recently purchased a "my avr"
> board from http://www.myavr.de/ ...
Wait a minute, I've just followed the link to the myAVR.  Did this cost
you $80?  Can you send it back?  I've succeeded so far in not "touting
my own stuff", but, just as an example, if you bought an Atmel AVR
Dragon you'd have ISP and High Voltage programming plus both JTAG and
debugWIRE debugging.  Mate it with (here I go) a Dragon Rider and you
can pick and choose among quite a few target devices, including the
ATmega88 mentioned earlier.  This would only cost you a few bucks more,
depending on how you count postage.  This is just an example.  Brian
Dean has good stuff at BDMicro, too, and there's also Smiley Micros,
all friends of this and other AVR-based discussion groups.  I may be
misunderstanding, but I don't see how the myAVR is a cost-effective
starting point for you.  (Boy I hope the people at myAVR aren't in this
group.)
Graham.
Re: [AVR-Chat] Re: My Avr
2008-03-20 by Sander Pool
No need for a book. Read the AVR Studio documentation for JTAGICE or
Dragon. Read about how to start debugging in AVR Studio, setting break
points and watches etc. There are other methods to do the same thing but
AVR Studio is a good place to start. Read more about JTAG and DW
capabilities in the datasheet of a capable device.
    Sander
Paul Sinclair wrote:
> Hmm,
> with a
> debug interface"
> buy.
> Paul, EI5GTB
Re: My Avr
--- In AVR-Chat@yahoogroups.com, "paul sinclair" <paul@...> wrote:
> Jeepers no, it cost me 20 euro on ebay!! :P
OK, that's reasonable then.  I was looking at list price.  Forget my
previous post.
Graham.
2008-03-20 by paul sinclair
I dont have the tools here, but the "flashing" tool is definetly only in
german.
 There are some other tools, like avr notepad and a few things (dont have
them here, its pc only, and im on my mac at the minute) but i cant quite
remember.
Why is this a minus for you? did you buy one of these units also?
Paul, EI5GTB
> Ray Hurst
> Western Digital
> 949-672-9853
> From: AVR-Chat@yahoogroups.com <AVR-Chat%40yahoogroups.com> [mailto:
> AVR-Chat@yahoogroups.com <AVR-Chat%40yahoogroups.com>] On Behalf
> Of Paul Sinclair
> To: AVR-Chat@yahoogroups.com <AVR-Chat%40yahoogroups.com>
> work
> Paul, EI5GTB
> From: AVR-Chat@yahoogroups.com <AVR-Chat%40yahoogroups.com> <mailto:
> [mailto:AVR-Chat@yahoogroups.com <AVR-Chat%40yahoogroups.com> <mailto:
> Behalf
> Of Philippe Habib
> To: AVR-Chat@yahoogroups.com <AVR-Chat%40yahoogroups.com> <mailto:
> much
> not
> debugger
> the problem is.
> Behalf
> Of Paul Sinclair
> Paul.
> Behalf
> Of BobGardner@aol.com <BobGardner%40aol.com> <mailto:BobGardner%40aol.com>
> From: ei5gtb <paul@paulsnet.org <paul%40paulsnet.org> <mailto:
> Many Thanks,
> Paul.
> 0&sec=recg
> group!
> ftr1&sec=recg
> system d...
> 2&sec=recg
> microcontrolle...
> =aftr3&sec=recg
> k=aftr4&sec=recg
> cir...
> Checked by AVG.
> 9:54 AM
Thank you for the informitave reply. I understand the debugging process now,
i have used debugging in software development enviroments, just never in
microprocessors, mind you, iv done very little in the microprocessors, iv
always done everything with relays or transistors or what have you. But my
latest project calls for some more brains!
Ill give you a run down of what im doing,
2 sensors (elevation and rotation) feed a variable voltage into the device,
it turns them into a variable. The device listens on the com port for
commands from the computer, it will parse that and convert it into commands.
The device then decides the quickest way to get to the desired location
(clockwise / anti-clockwise) taking into account the fact i dont want the
rotator turing around and around constantly, as the wires would get tangled.
Then it rotates the rotator until the sensor variables match the desired
ones. There will be an lcd screen to readout the current position, for
aiding in manual operation, and mabye someday will have a primitive menu
system for calibration of the sensors and variouos other things.
I always love thingking how things will work, but i hate learning how to do
them! but the more i think about this project the more i want to get it
done. I was going to use a pic chip, but i really didnt like the look of
assembly, and i have used C and C++ quite extencivley in the past, so it
would not need much learning for me to apply that knowledge to embedded
systems design, or so i hope!
Paul, EI5GTB.
On 3/20/08, Graham Davies <Yahoo37849@ecrostech.com> wrote:
> --- In AVR-Chat@yahoogroups.com <AVR-Chat%40yahoogroups.com>, "Paul
> again.
> Graham.
> --- In AVR-Chat@yahoogroups.com <AVR-Chat%40yahoogroups.com>, "ei5gtb"
> group.)
> Graham.
no worries,
I did have a programmer homebrewed on a piece of breadboard, but i thought,
rather than hooking up xtals and all the rest, i would remove the variable
and possible problems of my circuit design and go with a dev kit. But i
overlooked the software side of things. i suppose its just as important!
Paul.
> --- In AVR-Chat@yahoogroups.com <AVR-Chat%40yahoogroups.com>, "paul
> previous post.
> Graham.
2008-03-20 by David Kelly
> interface.
> you've
Several years ago I got my start in AVR designing a replacement for a
product that used a COP8 that cost about $8 and was O.T.P.
Initial estimates at throwing away the existing assembly in favor of
avr-gcc indicated 24k to 32k of code size. Our distributor priced the
ATmega64L at less than $4 for 10k/year. I had a lot of big decisions
to make and would have stuck to the ATmega64L for $4 even if a
ATmega32 was free. If I had designed for a 16 or 32 and something
bigger was needed the cost in redesign, re-qualification, and time-to-
market was much greater than 10,000 chips at $4 each.
Of course you guessed it, when product shipped the code image was 14k.
I don't believe they ever changed the chip to something cheaper. The
fact the 64L works is not worth saving $1 for the expense of changing
the PCB. That would change if they started shipping 100,000 units per
year.
> have
> quite
> remember.
There are a number of users of avr-gcc on MacOS X, that also use USB
to serial converters to drive JTAG ICE. I don't, but I do most of my
editing on Mac, commit via SVN, update my working directory on PC with
"svn update", recompile, debug, "svn commit", repeat.
Guessing http://www.bsdhome.com/avrdude/ would be able to drive the
parallel port programmer on your myAVR.
2008-03-21 by Raymond Hurst
I can't speak or read german.
Ray Hurst
Western Digital
949-672-9853
Of paul sinclair
Sent: Wednesday, March 19, 2008 5:42 PM
german.
remember.
Paul, EI5GTB
> Ray Hurst
> Western Digital
> 949-672-9853
> Of Paul Sinclair
> work
> Paul, EI5GTB
> Behalf
> Of Philippe Habib
> much
> not
> debugger
> the problem is.
> Behalf
> Of Paul Sinclair
> Paul.
> Behalf
> <http://www.myavr.de/ <http://www.myavr.de/> >
> Many Thanks,
> Paul.
<http://groups.yahoo.com/group/avrclub?v=1> >
> 0&sec=recg
> group!
<http://groups.yahoo.com/group/e-embedded?v=1> >
> ftr1&sec=recg
> system d...
<http://groups.yahoo.com/group/piclist?v=1> >
> 2&sec=recg
> microcontrolle...
<http://groups.yahoo.com/group/booksbybibin?v=1> >
> =aftr3&sec=recg
<http://groups.yahoo.com/group/Homebrew_PCBs?v=1> >
> k=aftr4&sec=recg
> cir...
> Checked by AVG.
> 9:54 AM
Re: My Avr
2008-06-10 by dingley76
This is an old topic, but I have also purchased the MyAVR programmer
board and was also disappointed by the fact that the accompanying
software was in German. I have not tried the board yet (I haven't
really got into AVR programming yet!), but looking at the documentation
it appears that as long as the board is connected, AVR Studio can be
set-up to communicate with it. The documentation states:
QUOTE
Use with AVR Studio Version 4.12.498
If you use the AVR studio, please choose "AVR Prog" in
the menu Tools. The programmer has to be connected if
you select the menu item. AVR Prog will find the mySmartUSB
automatically.
AVR-Prog is looking only at the COM-Ports 1 to 4. If the
virtual COM-Port of mySmartUSB is higher then 4 AVR
studio will not find it. In this case you need to select a valid
COM-port in the system settings.
Follow this procedure:
• open the device manager
• open the rubric: Ports (COM and LPT) themed open
  USB controller
• choose driver: "CP210x USB to UART Bridge Controller
  (COMx)"
• right mouse button -> Properties-> Port settings
-> Advanced
• modify and confirm COM-port number
• we recommend COM3 or COM4, Please notice possible
driver conflicts
END QUOTE
The MyAVR document from which this was found was: techb_mysmartusb.pdf
Gavin
one.
> Many Thanks,
> Paul.
2008-06-11 by paul sinclair
hi Gavin,
hmm, i might take a look at that. i only recently got a cable for it. and i
really want to start programming it. So this might be the motivation i need.
Paul EI5GTB
On Tue, Jun 10, 2008 at 12:49 PM, dingley76 <dingley76@yahoo.com> wrote:
>   Hi,
> QUOTE
> automatically.
> � open the device manager
> � open the rubric: Ports (COM and LPT) themed open
> USB controller
> � choose driver: "CP210x USB to UART Bridge Controller
> (COMx)"
> � right mouse button -> Properties-> Port settings
> -> Advanced
> � modify and confirm COM-port number
> � we recommend COM3 or COM4, Please notice possible
> driver conflicts
> END QUOTE
> Cheers,
> Gavin
> one.
> > Many Thanks,
> > Paul.
Gavin, just went to try this now. Are you using the LPT programmer, or the
usb programmer?
Paul.
2008-06-11 by Gavin Dingley
Hi Paul,
I have not tried this yet, but I have the USB board - mySmartUSB, not a printer parallel port version (didn't know there was one). The document is at: http://www.myavr.info/download/techb_mysmartusb.pdf
see page 11 for details for using it with AVR studio. A such you select a virtual COM port, as is the usual way with USB.
Gavin
paul sinclair <paul@paulsnet.org> wrote:                             Gavin, just went to try this now. Are you using the LPT programmer, or the
 usb programmer?
 Paul.
aha, i see. Im still waiting on avr studio to download. i downloaded the
wrong one first. i just wasted another two  hours of my life on
http://icanhascheezburger.com/
Ahh, the joy of the internet. its hard to get out of my procrastination
habbit!
Paul.
On Wed, Jun 11, 2008 at 11:36 PM, Gavin Dingley <dingley76@yahoo.com> wrote:
>   Hi Paul,
> Cheers,
> Gavin
> paul sinclair <paul@paulsnet.org <paul%40paulsnet.org>> wrote: Gavin, just
> usb programmer?
> Paul.
Generate Boundary scan SVF file
2008-06-12 by Qboll
Hi All,
I want to do a boundaryscan test with my AVR project in production.
Does anyone have/know a tool to generate a SVF file where I can toggle
I/O pins?
(access boundryscan cells)
I googled already a few hours but I didn't found it.
I have already a JTAG SVF file player.
Programming is no problem. Atmel supplied a AVR2SVF generator, But
it does only programming not boundaryscan testing.
Thanks for the help,
Pascal
2008-06-13 by paul sinclair
i tried this with mine. But it has to be the usb version. SO back to the
drawing board for me. I might need to invest in a proper development board
Paul.
>   Hi Paul,
> Cheers,
> Gavin
> usb programmer?
> Paul.
Re: [AVR-Chat] Generate Boundary scan SVF file
2008-06-14 by Raymond Hurst
I downloaded some BSD files from the Atmel website a while back.
I haven't had time to look at them. Let me know ig that's what you're
looking for.
Ray
Qboll wrote:
> Hi All,
> I/O pins?
> Pascal
RE: [AVR-Chat] Generate Boundary scan SVF file
2008-06-15 by Qboll
Hi Raymond,
Do you have a information of how to read a BSD file?
I also found these files for the avr but I don't know how to read it.
Pascal
Behalf Of Raymond Hurst
Sent: 14 June 2008 18:15
Subject: Re: [AVR-Chat] Generate Boundary scan SVF file
looking for.
Ray
Qboll wrote:
> Hi All,
> I/O pins?
> Pascal
2008-06-15 by Raymond Hurst
Nope. That was what I was going to do when I got back to it.
Ray
Qboll wrote:
> Hi Raymond,
> Thanks,
> Pascal
> [mailto:AVR-Chat@yahoogroups.com <mailto:AVR-Chat%40yahoogroups.com>] On
> looking for.
> Ray
> Qboll wrote:
>  > Hi All,
>  > I/O pins?
>  > Pascal
