Emax
New Emax II user
New Emax II user
2012-09-25 by sofad_1999
Hi all,
I just got a cheap Emax II 2212 model, and am currently wondering if it wasn't such a good deal after all....
FYI - It has a 250mb Apple SCSI drive inside, and the original SCSI floppy drive.
I have the original 2.14 OS disk, and I have also created additional 2.14 OS disks using EMXP
When I power on the Emax II with the OS floppy disk in the drive I get the following messages:
Checking Floppy
Loading Software
Disk Not Formatted
and then a loop of Loading Software/Disk Not Formatted
I can hear the floppy drive clicking every 10-15 seconds. I get red lights on STOP and RECORD.
None of the buttons are functional.
I have tried disconnecting the internal Hard Drive to see if that makes a difference and nothing changes. I have also tried disconnecting the Floppy to see if it will boot from the HD, and again nothing.
Can anyone point me in the right direction as to what may be the problem? I have a floppy drive cleaning kit on order, just in case... and am prepared to splash out on a new floppy drive if that is definitely the problem.
Thanks
Tony
Re: [emax] New Emax II user
2012-09-25 by jammie
if it has an internal drive that should have the os on it and should boot from the hd
dont put a disk in the floppydrive and just have the hd load os
disk not formated means that the floppy drive is being seen and is doing a floppy read when it comes up as not formated its either a bad disk or the floppy drive is shot
do try the cleaning kit first as it can just need a good clean
which i have had todo on a number of old floppy drives
none of the buttons will be functional until the os is present
  To: emax@yahoogroups.com
  Sent: Tuesday, September 25, 2012 5:59 AM
  Subject: [emax] New Emax II user
  Hi all,
  Checking Floppy
  Loading Software
  Disk Not Formatted
  Thanks
  Tony
2012-09-25 by Tony Court
Hi Jammie and thanks for the info.
I'm sure at some stage during my testing I tried just the HD connected and
was getting the same issue..... I will test again tonight and let you know.
If the HD does not have the OS installed, and the Floppy drive is fried....
do you have any recommendations on how to get the OS onto the HD? I
currently have no way of connecting the 50-pin SCSI to my computer, but am
willing to purchase PCI-E cards etc if the price is right ;)
Thanks again for your help so far and I'll let you know about the OS on the
HD when I get home tonight.
I also have a zip100 drive that I have yet to play with, and 2 zip disks
full of sounds. Not sure if the OS might be on one of the zip disks as well?
Tony
> from the hd
> From: sofad_1999
> Hi all,
> drive.
> OS disks using EMXP
> following messages:
> Checking Floppy
> Loading Software
> Disk Not Formatted
> on STOP and RECORD.
> problem.
> Thanks
> Tony
2012-09-25 by Ted Summers
Emax 1 / 2 requires the floppy drive to be attached.
You can't not have a floppy drive unless you jumper the floppy connector-
that will definitely prevent a successful boot.
As to the floppy, you can create a new one with EMX (DOS) or EMXP utilities
and try and boot from it.
You may wish to use this existing floppy as it was probably formatted by
Emax initially and write the OS to it with one of the utilities.
Also, please note that Emax uses DSDD not DSHD disks.
So you have to use either DSDD or cover the hole which indicates
High-density disk.
or you can also buy an Emax OS floppy disk off ebay if the above doesn't
work for you.
Ted
> well?
> Tony
> > from the hd
> a
> > From: sofad_1999
> > Hi all,
> floppy
> > drive.
> > OS disks using EMXP
> the
> > following messages:
> > Checking Floppy
> > Loading Software
> > Disk Not Formatted
> lights
> > on STOP and RECORD.
> Floppy
> > problem.
> > Thanks
> > Tony
> http://www.silveriafamily.comYahoo! Groups Links
2012-09-27 by Tony Court
So..... I have cleaned the floppy drive and tried again with both the OS floppy in (the original E-mu disk and the 2 I made using emxp), I also tried with no floppy disk inserted (but the floppy drive still connected) to see if it would boot from HD.
Unfortunately I still get exactly the same errors. Both the floppy and the hard drive are clicking/spinning up, so they have power.
I was aware that the floppies needed to be DD, not HD, and covered up the relevant holes.
Is there a way to confirm that SCSI is working? Could that be the issue? Or should I go for a replacement floppy drive? I'm a bit stuck now :(
I look forward to your replies!
Tony
> High-density disk.
> work for you.
> Regards,
> Ted
> > well?
> > Tony
> > > from the hd
> > a
> > > From: sofad_1999
> > > Hi all,
> > floppy
> > > drive.
> > > OS disks using EMXP
> > the
> > > following messages:
> > > Checking Floppy
> > > Loading Software
> > > Disk Not Formatted
> > lights
> > > on STOP and RECORD.
> > Floppy
> > > problem.
> > > Thanks
> > > Tony
2012-09-27 by jammie
sounds like you got a dud floppy drive and a bad scsi drive
as the person who owned it before if there was a scsi drive would of definetly put the os on it
have you tried removing the scsi cable
and seeing if the floppy will boot as the hard drive could be on constant seek which would stop the floppy drive from booting
  Sent: Thursday, September 27, 2012 5:50 PM
  Subject: Re: [emax] New Emax II user
  Tony
  > High-density disk.
  > work for you.
  > Regards,
  > Ted
  > > well?
  > > Tony
  > > > from the hd
  > > a
  > > > From: sofad_1999
  > > > Hi all,
  > > floppy
  > > > drive.
  > > > OS disks using EMXP
  > > the
  > > > following messages:
  > > > Checking Floppy
  > > > Loading Software
  > > > Disk Not Formatted
  > > lights
  > > > on STOP and RECORD.
  > > Floppy
  > > > problem.
  > > > Thanks
  > > > Tony
2012-09-27 by Ted Summers
SCSI isn't required to operate the unit.
A SCSI capable OS will still boot a unit with SCSI from floppy if a HD is
not attached, as long as the PAL is there.
Otherwise you get "Wrong Software" or something like that.
> relevant holes.
> Tony
> utilities
> > High-density disk.
> > work for you.
> > Regards,
> > Ted
> and
> know.
> fried....
> but am
> on the
> disks
> > > well?
> > > Tony
> boot
> > > > from the hd
> doing
> > > a
> or the
> > > > From: sofad_1999
> > > > Hi all,
> it
> > > floppy
> > > > drive.
> 2.14
> > > > OS disks using EMXP
> get
> > > the
> > > > following messages:
> > > > Checking Floppy
> > > > Loading Software
> > > > Disk Not Formatted
> > > lights
> > > > on STOP and RECORD.
> makes a
> > > Floppy
> problem?
> the
> > > > problem.
> > > > Thanks
> > > > Tony
I had already tried a floppy boot with the HD disconnected :(
I'm going to take the plunge and order a new floppy drive from route66studios and see if that fixes things.
I'll report back when I've tested it :)
Thanks again for your help.
Tony
> From: Tony Court
> Tony
> > High-density disk.
> > work for you.
> > Regards,
> > Ted
> > > well?
> > > Tony
> > > On Mon, Sep 24, 2012 at 11:57 PM, jammie <jammie.emma@blueyonder.co.uk
> > > > from the hd
> > > a
> > > > From: sofad_1999
> > > > Hi all,
> > > floppy
> > > > drive.
> > > > OS disks using EMXP
> > > the
> > > > following messages:
> > > > Checking Floppy
> > > > Loading Software
> > > > Disk Not Formatted
> > > lights
> > > > on STOP and RECORD.
> > > Floppy
> > > > problem.
> > > > Thanks
> > > > Tony
i would not bother that get your self a slimfloppy and cf drive
the costing wont be much different
  Sent: Thursday, September 27, 2012 9:57 PM
  Tony
  > From: Tony Court
  > Tony
  > > High-density disk.
  > > work for you.
  > > Regards,
  > > Ted
  > > > well?
  > > > Tony
  > > > > from the hd
  > > > a
  > > > > From: sofad_1999
  > > > > Hi all,
  > > > floppy
  > > > > drive.
  > > > > OS disks using EMXP
  > > > the
  > > > > following messages:
  > > > > Checking Floppy
  > > > > Loading Software
  > > > > Disk Not Formatted
  > > > lights
  > > > > on STOP and RECORD.
  > > > Floppy
  > > > > problem.
  > > > > Thanks
  > > > > Tony
Re: New Emax II user
2012-09-28 by sofad_1999
any idea where to purchase them from/instructions/part numbers etc? I'm confident I can do the work, just unsure what parts to get and how to install.
thanks again
>   From: Tony Court
>   Tony
>   > From: Tony Court
>   > Tony
>   > > High-density disk.
>   > > work for you.
>   > > Regards,
>   > > Ted
>   > > > well?
>   > > > Tony
>   > > > > from the hd
>   > > > a
>   > > > > From: sofad_1999
>   > > > > Hi all,
>   > > > floppy
>   > > > > drive.
>   > > > > OS disks using EMXP
>   > > > the
>   > > > > following messages:
>   > > > > Checking Floppy
>   > > > > Loading Software
>   > > > > Disk Not Formatted
>   > > > lights
>   > > > > on STOP and RECORD.
>   > > > Floppy
>   > > > > problem.
>   > > > > Thanks
>   > > > > Tony
Re: [emax] Re: New Emax II user
2012-09-28 by Ted Summers
TEAC FD-05 for slim floppy- check ebay.
JM-215A to convert it for use with Emax
Instructions for modification at my website.
PCD-50b using the PC- Card slot for whatever flash media you choose.
32MB flash media.
Again- see my website.
http://djtbs1.wordpress.com/
thanks again
> From: Tony Court
> Tony
> > From: Tony Court
> > Tony
> > > High-density disk.
> > > work for you.
> > > Regards,
> > > Ted
> > > > well?
> > > > Tony
> > > > > from the hd
> > > > a
> > > > > From: sofad_1999
> > > > > Hi all,
> > > > floppy
> > > > > drive.
> > > > > OS disks using EMXP
> > > > the
> > > > > following messages:
> > > > > Checking Floppy
> > > > > Loading Software
> > > > > Disk Not Formatted
> > > > lights
> > > > > on STOP and RECORD.
> > > > Floppy
> > > > > problem.
> > > > > Thanks
> > > > > Tony
2012-09-28 by Tony Court
Ignore my last message, I found a JM-215A on eBay in the end after more detailed searching :)
Tony
> 32MB flash media.
> thanks again
>> From: Tony Court
>> Tony
>>> From: Tony Court
>>> Tony
>>>> High-density disk.
>>>> work for you.
>>>> Regards,
>>>> Ted
>>>>> well?
>>>>> Tony
>>>>>> from the hd
>>>>> a
>>>>>> From: sofad_1999
>>>>>> Hi all,
>>>>> floppy
>>>>>> drive.
>>>>>> OS disks using EMXP
>>>>> the
>>>>>> following messages:
>>>>>> Checking Floppy
>>>>>> Loading Software
>>>>>> Disk Not Formatted
>>>>> lights
>>>>>> on STOP and RECORD.
>>>>> Floppy
>>>>>> problem.
>>>>>> Thanks
>>>>>> Tony
2012-09-28 by Simon Forsyth
Will the same Teac work in an Emax II?..
Sent: Friday, 28 September 2012, 6:29
Subject: Re: [emax] Re: New Emax II user
32MB flash media.
thanks again
> From: Tony Court
> Tony
> > From: Tony Court
> > Tony
> > > High-density disk.
> > > work for you.
> > > Regards,
> > > Ted
> > > > well?
> > > > Tony
> > > > > from the hd
> > > > a
> > > > > From: sofad_1999
> > > > > Hi all,
> > > > floppy
> > > > > drive.
> > > > > OS disks using EMXP
> > > > the
> > > > > following messages:
> > > > > Checking Floppy
> > > > > Loading Software
> > > > > Disk Not Formatted
> > > > lights
> > > > > on STOP and RECORD.
> > > > Floppy
> > > > > problem.
> > > > > Thanks
> > > > > Tony
2012-09-28 by jammie
yes most of the slin floppies work
i have used both teac and sony
with the same results
but you cant use the cable that comes with the sony as its longer which is nice but the jm-215a
the connector is reversed and thats why you need the connectors on opposite sides
there are slim floppy adapters that have it on the same side
most old laptops used this type of connection
  Sent: Friday, September 28, 2012 5:13 PM
  32MB flash media.
  thanks again
  > From: Tony Court
  > Tony
  > > From: Tony Court
  > > Tony
  > > > High-density disk.
  > > > work for you.
  > > > Regards,
  > > > Ted
  > > > > well?
  > > > > Tony
  > > > > > from the hd
  > > > > a
  > > > > > From: sofad_1999
  > > > > > Hi all,
  > > > > floppy
  > > > > > drive.
  > > > > > OS disks using EMXP
  > > > > the
  > > > > > following messages:
  > > > > > Checking Floppy
  > > > > > Loading Software
  > > > > > Disk Not Formatted
  > > > > lights
  > > > > > on STOP and RECORD.
  > > > > Floppy
  > > > > > problem.
  > > > > > Thanks
  > > > > > Tony
2012-09-28 by cheju_99
Hi forers: I have a Mitsui for paralel port slim floppy drive, how can i use it.....
>   From: Simon Forsyth
>   ________________________________
>   From: Ted Summers <djtbs1@...>
>   32MB flash media.
>   thanks again
>   > From: Tony Court
>   > Tony
>   > > From: Tony Court
>   > > Tony
>   > > > High-density disk.
>   > > > work for you.
>   > > > Regards,
>   > > > Ted
>   > > > On Tue, Sep 25, 2012 at 7:38 AM, Tony Court <anthony.court@> wrote:
>   > > > > well?
>   > > > > Tony
>   > > > > > from the hd
>   > > > > a
>   > > > > > From: sofad_1999
>   > > > > > Hi all,
>   > > > > floppy
>   > > > > > drive.
>   > > > > > OS disks using EMXP
>   > > > > the
>   > > > > > following messages:
>   > > > > > Checking Floppy
>   > > > > > Loading Software
>   > > > > > Disk Not Formatted
>   > > > > lights
>   > > > > > on STOP and RECORD.
>   > > > > Floppy
>   > > > > > problem.
>   > > > > > Thanks
>   > > > > > Tony
Yes, I have this in an Emax keyboard, Emax rack and Emax 2 keyboard.
On Fri, Sep 28, 2012 at 9:13 AM, Simon Forsyth
> 32MB flash media.
> install.
> thanks again
> > From: Tony Court
> > Tony
> > > From: Tony Court
> the relevant holes.
> > > Tony
> connector-
> utilities
> formatted by
> > > > High-density disk.
> doesn't
> > > > work for you.
> > > > Regards,
> > > > Ted
> connected and
> you know.
> fried....
> computer, but am
> OS on the
> disks
> disks as
> > > > > well?
> > > > > Tony
> should boot
> > > > > > from the hd
> is doing
> > > > > a
> disk or the
> > > > > > From: sofad_1999
> > > > > > Hi all,
> wondering if it
> SCSI
> > > > > floppy
> > > > > > drive.
> additional 2.14
> > > > > > OS disks using EMXP
> I get
> > > > > the
> > > > > > following messages:
> > > > > > Checking Floppy
> > > > > > Loading Software
> > > > > > Disk Not Formatted
> red
> > > > > lights
> > > > > > on STOP and RECORD.
> that makes a
> the
> > > > > Floppy
> problem?
> am
> definitely the
> > > > > > problem.
> > > > > > Thanks
> > > > > > Tony
You don't.... I don't know if this interfaces at all.
> use it.....
> opposite sides
> > From: Simon Forsyth
> > 32MB flash media.
> install.
> > thanks again
> > > From: Tony Court
> > > Tony
> > > > From: Tony Court
> > > > Tony
> connector-
> utilities
> formatted by
> > > > > High-density disk.
> doesn't
> > > > > work for you.
> > > > > Regards,
> > > > > Ted
> connected and
> let you know.
> is fried....
> HD? I
> computer, but am
> the OS on the
> zip disks
> disks as
> > > > > > well?
> > > > > > Tony
> should boot
> > > > > > > from the hd
> and is doing
> > > > > > a
> disk or the
> > > > > > > From: sofad_1999
> > > > > > > Hi all,
> wondering if it
> SCSI
> > > > > > floppy
> > > > > > > drive.
> additional 2.14
> > > > > > > OS disks using EMXP
> drive I get
> > > > > > the
> > > > > > > following messages:
> > > > > > > Checking Floppy
> > > > > > > Loading Software
> > > > > > > Disk Not Formatted
> get red
> > > > > > lights
> > > > > > > on STOP and RECORD.
> that makes a
> disconnecting the
> > > > > > Floppy
> the problem?
> and am
> definitely the
> > > > > > > problem.
> > > > > > > Thanks
> > > > > > > Tony
2012-10-05 by Tony Court
So..... I now have all the parts required for the slim floppy and cf upgrade, including a 2nd JM-215A (just in case!). Hopefully I'll get a chance to complete this upgrade tomorrow.
Do you have any recommendations for how to position and secure both drives? The Teac floppy drive is narrower than the PCD-50B. All the pics on Teds website show the floppy on top. How are they secured to each other and then to the original floppy drive mounting?
Thanks
Tony
> 32MB flash media.
> thanks again
>> From: Tony Court
>> Tony
>>> From: Tony Court
>>> Tony
>>>> High-density disk.
>>>> work for you.
>>>> Regards,
>>>> Ted
>>>>> well?
>>>>> Tony
>>>>>> from the hd
>>>>> a
>>>>>> From: sofad_1999
>>>>>> Hi all,
>>>>> floppy
>>>>>> drive.
>>>>>> OS disks using EMXP
>>>>> the
>>>>>> following messages:
>>>>>> Checking Floppy
>>>>>> Loading Software
>>>>>> Disk Not Formatted
>>>>> lights
>>>>>> on STOP and RECORD.
>>>>> Floppy
>>>>>> problem.
>>>>>> Thanks
>>>>>> Tony
2012-10-05 by Ted Summers
The screwholes on the bottom of the PCD drive match the original floppy exactly.
However, the thread is different, if I recall.
For mounting you get some flat metal and drill the holes.
The holes front to back are the same for slim and PCD.
The distance is .9 inches up, center to center of the holes on the side of the PCD drive.
Slim floppy drives use 2.6MM screws.
They are used in RC cars also.
Duratrax makes a kit of screws.
Use the shortest screws on the front.
If they are put in too far, they will make the disk appear out of alignment and you will get CRC errors and the disk may not easily eject.
So use 3 washers on the outside of the metal bracket to keep the screws from going in too far.
As to spacers- use some washers or fab them from metal or nylon or use some small nuts.
There isn't anything pre-made for it- you just have to fabricate it.
Thanks
Tony
> 32MB flash media.
> thanks again
>> From: Tony Court
>> Tony
>>> From: Tony Court
>>> Tony
>>>> High-density disk.
>>>> work for you.
>>>> Regards,
>>>> Ted
>>>>> well?
>>>>> Tony
>>>>>> from the hd
>>>>> a
>>>>>> From: sofad_1999
>>>>>> Hi all,
>>>>> floppy
>>>>>> drive.
>>>>>> OS disks using EMXP
>>>>> the
>>>>>> following messages:
>>>>>> Checking Floppy
>>>>>> Loading Software
>>>>>> Disk Not Formatted
>>>>> lights
>>>>>> on STOP and RECORD.
>>>>> Floppy
>>>>>> problem.
>>>>>> Thanks
>>>>>> Tony
2012-10-05 by jammie
are fitting it to rack or keyboard
as both are different ways of doing it
i fit mine with metal brackets with the slim floppy under neath
and i centre the slim floppy with hddrive rubber washers and screws
  Sent: Friday, October 05, 2012 5:23 AM
  Thanks
  Tony
  > 32MB flash media.
  > thanks again
  >> From: Tony Court
  >> Tony
  >>> From: Tony Court
  >>> Tony
  >>>> High-density disk.
  >>>> work for you.
  >>>> Regards,
  >>>> Ted
  >>>>> well?
  >>>>> Tony
  >>>>>> from the hd
  >>>>> a
  >>>>>> From: sofad_1999
  >>>>>> Hi all,
  >>>>> floppy
  >>>>>> drive.
  >>>>>> OS disks using EMXP
  >>>>> the
  >>>>>> following messages:
  >>>>>> Checking Floppy
  >>>>>> Loading Software
  >>>>>> Disk Not Formatted
  >>>>> lights
  >>>>>> on STOP and RECORD.
  >>>>> Floppy
  >>>>>> problem.
  >>>>>> Thanks
  >>>>>> Tony
It's a keyboard version, not rack.
> From: Tony Court
> Thanks
> Tony
> Sent from my iPhone
> > 32MB flash media.
> > thanks again
> >> From: Tony Court
> >> Tony
> >>> From: Tony Court
> >>> Tony
> >>>> High-density disk.
> >>>> work for you.
> >>>> Regards,
> >>>> Ted
> >>>>> well?
> >>>>> Tony
> >>>>>> from the hd
> >>>>> a
> >>>>>> From: sofad_1999
> >>>>>> Hi all,
> >>>>> floppy
> >>>>>> drive.
> >>>>>> OS disks using EMXP
> >>>>> the
> >>>>>> following messages:
> >>>>>> Checking Floppy
> >>>>>> Loading Software
> >>>>>> Disk Not Formatted
> >>>>> lights
> >>>>>> on STOP and RECORD.
> >>>>> Floppy
> >>>>>> problem.
> >>>>>> Thanks
> >>>>>> Tony
Thanks Ted - JM-215A mods completed..... time to fabricate some brackets
and get everything in place :)
> exactly.
> the PCD drive.
> some small nuts.
> Thanks
> Tony
> Sent from my iPhone
> > 32MB flash media.
> install.
> > thanks again
> >> From: Tony Court
> >> Tony
> >>> From: Tony Court
> the relevant holes.
> >>> Tony
> connector-
> utilities
> by
> >>>> High-density disk.
> doesn't
> >>>> work for you.
> >>>> Regards,
> >>>> Ted
> connected and
> you know.
> fried....
> but am
> on the
> disks
> as
> >>>>> well?
> >>>>> Tony
> should boot
> >>>>>> from the hd
> doing
> >>>>> a
> or the
> >>>>>> From: sofad_1999
> >>>>>> Hi all,
> if it
> >>>>> floppy
> >>>>>> drive.
> additional 2.14
> >>>>>> OS disks using EMXP
> get
> >>>>> the
> >>>>>> following messages:
> >>>>>> Checking Floppy
> >>>>>> Loading Software
> >>>>>> Disk Not Formatted
> >>>>> lights
> >>>>>> on STOP and RECORD.
> makes a
> >>>>> Floppy
> problem?
> the
> >>>>>> problem.
> >>>>>> Thanks
> >>>>>> Tony
so - I have the new slim floppy and CF drives installed......
I load the OS from floppy (it's the first time I've seen it load), and I
now get on my screen 'P00 Untitled' and the enter light is flashing.
I have attached my SCSI Zip100 drive with some Emax II sounds on those
disks, but I can't seem to select the drive ('Drive Select' button does
nothing). It's definitely a SCSI zip (it has the 5/6 selector and the
termination switch).
Any ideas how to load the sounds from the SCSI zip drive?
>> exactly.
>> of the PCD drive.
>> some small nuts.
>> Thanks
>> Tony
>> Sent from my iPhone
>> > 32MB flash media.
>> install.
>> > thanks again
>> >> From: Tony Court
>> >> Tony
>> >>> From: Tony Court
>> the relevant holes.
>> >>> Tony
>> connector-
>> utilities
>> formatted by
>> >>>> High-density disk.
>> doesn't
>> >>>> work for you.
>> >>>> Regards,
>> >>>> Ted
>> connected and
>> you know.
>> fried....
>> but am
>> OS on the
>> disks
>> as
>> >>>>> well?
>> >>>>> Tony
>> should boot
>> >>>>>> from the hd
>> doing
>> >>>>> a
>> or the
>> >>>>>> From: sofad_1999
>> >>>>>> Hi all,
>> if it
>> >>>>> floppy
>> >>>>>> drive.
>> additional 2.14
>> >>>>>> OS disks using EMXP
>> get
>> >>>>> the
>> >>>>>> following messages:
>> >>>>>> Checking Floppy
>> >>>>>> Loading Software
>> >>>>>> Disk Not Formatted
>> >>>>> lights
>> >>>>>> on STOP and RECORD.
>> makes a
>> >>>>> Floppy
>> problem?
>> the
>> >>>>>> problem.
>> >>>>>> Thanks
>> >>>>>> Tony
you need the plus os to change scsi id
otherwise it will only see scsi id0 which if you connected the cf drive right that willbe scsi id 0
  Sent: Friday, October 05, 2012 7:54 PM
  >> exactly.
  >> of the PCD drive.
  >> some small nuts.
  >> Thanks
  >> Tony
  >> Sent from my iPhone
  >> > 32MB flash media.
  >> install.
  >> > thanks again
  >> >> From: Tony Court
  >> >> Tony
  >> >>> From: Tony Court
  >> the relevant holes.
  >> >>> Tony
  >> connector-
  >> utilities
  >> formatted by
  >> >>>> High-density disk.
  >> doesn't
  >> >>>> work for you.
  >> >>>> Regards,
  >> >>>> Ted
  >> connected and
  >> you know.
  >> fried....
  >> but am
  >> OS on the
  >> disks
  >> as
  >> >>>>> well?
  >> >>>>> Tony
  >> should boot
  >> >>>>>> from the hd
  >> doing
  >> >>>>> a
  >> or the
  >> >>>>>> From: sofad_1999
  >> >>>>>> Hi all,
  >> if it
  >> >>>>> floppy
  >> >>>>>> drive.
  >> additional 2.14
  >> >>>>>> OS disks using EMXP
  >> get
  >> >>>>> the
  >> >>>>>> following messages:
  >> >>>>>> Checking Floppy
  >> >>>>>> Loading Software
  >> >>>>>> Disk Not Formatted
  >> >>>>> lights
  >> >>>>>> on STOP and RECORD.
  >> makes a
  >> >>>>> Floppy
  >> problem?
  >> the
  >> >>>>>> problem.
  >> >>>>>> Thanks
  >> >>>>>> Tony
But (and I may just not understand things correctly as this is my first
Emax II) NONE of the buttons are responsive.
I currently have JUST the floppy and external Zip 100  connected (for
testing), no CF, no internal HD. With no floppy in the drive, it cycles
through 'Checking SCSI 1-7 but does not boot. With the floppy inserted (OS
2.14) it boots up and displays P00 Untitled, the enter button flashes, and
none of the buttons are responsive.
Are you saying that if I make another OS floppy disk using EMXP and the
emaxplus10.zip from the groups files section, it should boot to the 'plus'
OS, the buttons will become responsive, and I can then manually select to
load sounds from the external zip drive? (SCSI 5)
> From: Tony Court
> >> exactly.
> >> of the PCD drive.
> >> some small nuts.
> pics on
> and
> >> Thanks
> >> Tony
> >> Sent from my iPhone
> >> > 32MB flash media.
> I'm
> >> install.
> >> > thanks again
> >> >> From: Tony Court
> >> >> Tony
> >> >>> From: Tony Court
> the
> also
> connected)
> up
> >> the relevant holes.
> now :(
> >> >>> Tony
> >> connector-
> >> utilities
> >> formatted by
> >> >>>> High-density disk.
> >> doesn't
> >> >>>> work for you.
> >> >>>> Regards,
> >> >>>> Ted
> >> connected and
> >> you know.
> >> fried....
> I
> computer,
> >> but am
> >> OS on the
> >> disks
> disks
> >> as
> >> >>>>> well?
> >> >>>>> Tony
> >> should boot
> >> >>>>>> from the hd
> is
> >> doing
> >> >>>>> a
> disk
> >> or the
> >> >>>>>> From: sofad_1999
> >> >>>>>> Hi all,
> >> if it
> SCSI
> >> >>>>> floppy
> >> >>>>>> drive.
> >> additional 2.14
> >> >>>>>> OS disks using EMXP
> I
> >> get
> >> >>>>> the
> >> >>>>>> following messages:
> >> >>>>>> Checking Floppy
> >> >>>>>> Loading Software
> >> >>>>>> Disk Not Formatted
> red
> >> >>>>> lights
> >> >>>>>> on STOP and RECORD.
> >> makes a
> the
> >> >>>>> Floppy
> >> problem?
> am
> definitely
> >> the
> >> >>>>>> problem.
> >> >>>>>> Thanks
> >> >>>>>> Tony
sorry i miss understood i thought you were talking about a emax1
no the emax 2 os is fine
To: <emax@yahoogroups.com>
Sent: Friday, October 05, 2012 8:31 PM
>> From: Tony Court
>> > brackets
>> >> floppy
>> >> exactly.
>> >> side
>> >> of the PCD drive.
>> >> eject.
>> >> screws
>> >> some small nuts.
>> pics on
>> >> other
>> and
>> >> Thanks
>> >> Tony
>> >> Sent from my iPhone
>> >> > 32MB flash media.
>> I'm
>> >> install.
>> >> > thanks again
>> >> >> From: Tony Court
>> >> >> Tony
>> >> >>> of
>> >> >>> From: Tony Court
>> the
>> also
>> connected)
>> up
>> >> the relevant holes.
>> now :(
>> >> >>> Tony
>> >> connector-
>> >> utilities
>> >> formatted by
>> >> >>>> High-density disk.
>> >> doesn't
>> >> >>>> work for you.
>> >> >>>> Regards,
>> >> >>>> Ted
>> >> connected and
>> >> >>>>> let
>> >> you know.
>> >> >>>>> is
>> >> fried....
>> >> >>>>> HD?
>> I
>> computer,
>> >> but am
>> >> >>>>> the
>> >> OS on the
>> >> >>>>> zip
>> >> disks
>> disks
>> >> as
>> >> >>>>> well?
>> >> >>>>> Tony
>> >> should boot
>> >> >>>>>> from the hd
>> is
>> >> doing
>> >> >>>>> a
>> disk
>> >> or the
>> >> >>>>>> From: sofad_1999
>> >> >>>>>> Hi all,
>> >> >>>>>> wondering
>> >> if it
>> SCSI
>> >> >>>>> floppy
>> >> >>>>>> drive.
>> >> additional 2.14
>> >> >>>>>> OS disks using EMXP
>> >> >>>>>> drive
>> I
>> >> get
>> >> >>>>> the
>> >> >>>>>> following messages:
>> >> >>>>>> Checking Floppy
>> >> >>>>>> Loading Software
>> >> >>>>>> Disk Not Formatted
>> red
>> >> >>>>> lights
>> >> >>>>>> on STOP and RECORD.
>> >> >>>>>> that
>> >> makes a
>> the
>> >> >>>>> Floppy
>> >> >>>>>> the
>> >> problem?
>> >> >>>>>> and
>> am
>> definitely
>> >> the
>> >> >>>>>> problem.
>> >> >>>>>> Thanks
>> >> >>>>>> Tony
Thanks for your reply... so, if I'm using the correct OS for the Emax II
(2.14), any idea why none of the buttons are responsive and all I can get
after booting from floppy is the default P00 Untitled?
> From: "Tony Court" <anthony.court@...>
> (OS
> and
> 'plus'
> >> From: Tony Court
> >> > brackets
> >> >> floppy
> >> >> exactly.
> >> >> side
> >> >> of the PCD drive.
> >> >> eject.
> >> >> screws
> use
> >> >> some small nuts.
> a
> >> pics on
> >> >> other
> >> and
> >> >> Thanks
> >> >> Tony
> >> >> Sent from my iPhone
> choose.
> >> >> > 32MB flash media.
> >> I'm
> >> >> install.
> >> >> > thanks again
> >> >> >> From: Tony Court
> >> >> >> Tony
> would
> >> >> >>> of
> >> >> >>> From: Tony Court
> >> the
> >> also
> >> connected)
> floppy
> covered
> >> up
> >> >> the relevant holes.
> >> now :(
> >> >> >>> Tony
> >> >> connector-
> EMXP
> >> >> utilities
> >> >> formatted by
> >> >> >>>> High-density disk.
> >> >> doesn't
> >> >> >>>> work for you.
> >> >> >>>> Regards,
> >> >> >>>> Ted
> >> >> connected and
> >> >> >>>>> let
> >> >> you know.
> >> >> >>>>> is
> >> >> fried....
> >> >> >>>>> HD?
> >> I
> >> computer,
> >> >> but am
> >> >> >>>>> the
> >> >> OS on the
> >> >> >>>>> zip
> >> >> disks
> >> disks
> >> >> as
> >> >> >>>>> well?
> >> >> >>>>> Tony
> >> >> should boot
> >> >> >>>>>> from the hd
> os
> and
> >> is
> >> >> doing
> >> >> >>>>> a
> >> disk
> >> >> or the
> >> >> >>>>>> From: sofad_1999
> >> >> >>>>>> Hi all,
> >> >> >>>>>> wondering
> >> >> if it
> >> SCSI
> >> >> >>>>> floppy
> >> >> >>>>>> drive.
> >> >> additional 2.14
> >> >> >>>>>> OS disks using EMXP
> >> >> >>>>>> drive
> >> I
> >> >> get
> >> >> >>>>> the
> >> >> >>>>>> following messages:
> >> >> >>>>>> Checking Floppy
> >> >> >>>>>> Loading Software
> >> >> >>>>>> Disk Not Formatted
> get
> >> red
> >> >> >>>>> lights
> >> >> >>>>>> on STOP and RECORD.
> >> >> >>>>>> that
> >> >> makes a
> disconnecting
> >> the
> >> >> >>>>> Floppy
> >> >> >>>>>> the
> >> >> problem?
> >> >> >>>>>> and
> >> am
> >> definitely
> >> >> the
> >> >> >>>>>> problem.
> >> >> >>>>>> Thanks
> >> >> >>>>>> Tony
p00 is the defualt program now if you are pressing buttons but nothing
happens there could be a problem with the keyboard scanner ic chip
this deals with the scanning of the keyboard and all buttons and led control
if it fails you basically cant do anything
have you checked that the ribboncable is seated correctly
Sent: Friday, October 05, 2012 9:02 PM
>> (OS
>> and
>> 'plus'
>> > to
>> >> drive
>> >> From: Tony Court
>> >> I
>> >> does
>> >> > brackets
>> >> >> floppy
>> >> >> exactly.
>> >> >> side
>> >> >> of the PCD drive.
>> >> >> eject.
>> >> >> screws
>> use
>> >> >> some small nuts.
>> >> >> it.
>> >> >> cf
>> >> >> get
>> a
>> >> pics on
>> >> >> other
>> >> and
>> >> >> Thanks
>> >> >> Tony
>> >> >> Sent from my iPhone
>> choose.
>> >> >> > 32MB flash media.
>> >> >> > etc?
>> >> I'm
>> >> >> to
>> >> >> install.
>> >> >> > thanks again
>> >> >> >> From: Tony Court
>> >> >> >> Tony
>> would
>> >> >> >>> of
>> >> >> >>> on
>> >> >> >>> From: Tony Court
>> >> >> >>> both
>> >> the
>> >> >> I
>> >> also
>> >> connected)
>> floppy
>> covered
>> >> up
>> >> >> the relevant holes.
>> >> >> >>> the
>> >> >> stuck
>> >> now :(
>> >> >> >>> Tony
>> >> >> connector-
>> EMXP
>> >> >> utilities
>> >> >> formatted by
>> >> >> >>>> utilities.
>> >> >> >>>> indicates
>> >> >> >>>> High-density disk.
>> >> >> >>>> above
>> >> >> doesn't
>> >> >> >>>> work for you.
>> >> >> >>>> Regards,
>> >> >> >>>> Ted
>> >> >> >>>> <anthony.court@...>
>> >> >> connected and
>> >> >> >>>>> let
>> >> >> you know.
>> >> >> >>>>> drive
>> >> >> >>>>> is
>> >> >> fried....
>> >> >> >>>>> HD?
>> >> I
>> >> computer,
>> >> >> but am
>> >> >> >>>>> the
>> >> >> OS on the
>> >> >> >>>>> 2
>> >> >> >>>>> zip
>> >> >> disks
>> >> disks
>> >> >> as
>> >> >> >>>>> well?
>> >> >> >>>>> Tony
>> >> >> >>>>>> and
>> >> >> should boot
>> >> >> >>>>>> from the hd
>> os
>> and
>> >> is
>> >> >> doing
>> >> >> >>>>> a
>> >> >> >>>>>> bad
>> >> disk
>> >> >> or the
>> >> >> >>>>>> clean
>> >> >> >>>>>> present
>> >> >> >>>>>> From: sofad_1999
>> >> >> >>>>>> Hi all,
>> >> >> >>>>>> wondering
>> >> >> if it
>> >> >> >>>>>> original
>> >> SCSI
>> >> >> >>>>> floppy
>> >> >> >>>>>> drive.
>> >> >> additional 2.14
>> >> >> >>>>>> OS disks using EMXP
>> >> >> >>>>>> drive
>> >> I
>> >> >> get
>> >> >> >>>>> the
>> >> >> >>>>>> following messages:
>> >> >> >>>>>> Checking Floppy
>> >> >> >>>>>> Loading Software
>> >> >> >>>>>> Disk Not Formatted
>> get
>> >> red
>> >> >> >>>>> lights
>> >> >> >>>>>> on STOP and RECORD.
>> >> >> >>>>>> that
>> >> >> makes a
>> disconnecting
>> >> the
>> >> >> >>>>> Floppy
>> >> >> >>>>>> the
>> >> >> problem?
>> >> >> >>>>>> and
>> >> am
>> >> definitely
>> >> >> the
>> >> >> >>>>>> problem.
>> >> >> >>>>>> Thanks
>> >> >> >>>>>> Tony
ok - so I'm thinking it may be that :(
I get P00 Untitled on both rows of the display, a cursor flashing on the
first 0 on the lower row, flashing Red light next to the 'Enter' button. No
response from either the piano keys (no sound), or the buttons.
Is this scanner IC chip replaceable and are they still available?
> control
> first
> cycles
> >> (OS
> >> and
> the
> >> 'plus'
> select
> >> > to
> >> >> drive
> >> >> From: Tony Court
> and
> >> >> I
> those
> >> >> does
> >> >> > brackets
> >> >> >> floppy
> >> >> >> exactly.
> >> >> >> side
> >> >> >> of the PCD drive.
> >> >> >> eject.
> >> >> >> screws
> >> use
> >> >> >> some small nuts.
> >> >> >> it.
> >> >> >> cf
> >> >> >> get
> >> a
> both
> the
> >> >> pics on
> >> >> >> other
> >> >> and
> >> >> >> Thanks
> >> >> >> Tony
> >> >> >> Sent from my iPhone
> >> choose.
> >> >> >> > 32MB flash media.
> >> >> >> > etc?
> >> >> I'm
> how
> >> >> >> to
> >> >> >> install.
> >> >> >> > thanks again
> >> >> >> >> From: Tony Court
> >> >> >> >> Tony
> >> would
> >> >> >> >>> of
> >> >> >> >>> on
> >> >> >> >>> From: Tony Court
> >> >> >> >>> both
> >> >> the
> emxp),
> >> >> >> I
> >> >> also
> >> >> connected)
> >> floppy
> >> covered
> >> >> up
> >> >> >> the relevant holes.
> >> >> >> >>> the
> >> >> >> stuck
> >> >> now :(
> >> >> >> >>> Tony
> floppy
> >> >> >> connector-
> >> EMXP
> >> >> >> utilities
> >> >> >> formatted by
> >> >> >> >>>> utilities.
> >> >> >> >>>> indicates
> >> >> >> >>>> High-density disk.
> >> >> >> >>>> above
> >> >> >> doesn't
> >> >> >> >>>> work for you.
> >> >> >> >>>> Regards,
> >> >> >> >>>> Ted
> >> >> >> >>>> <anthony.court@...>
> >> >> >> connected and
> and
> >> >> >> >>>>> let
> >> >> >> you know.
> >> >> >> >>>>> drive
> >> >> >> >>>>> is
> >> >> >> fried....
> the
> >> >> >> >>>>> HD?
> >> >> I
> >> >> computer,
> >> >> >> but am
> about
> >> >> >> >>>>> the
> >> >> >> OS on the
> and
> >> >> >> >>>>> 2
> >> >> >> >>>>> zip
> >> >> >> disks
> zip
> >> >> disks
> >> >> >> as
> >> >> >> >>>>> well?
> >> >> >> >>>>> Tony
> >> >> >> >>>>>> and
> >> >> >> should boot
> >> >> >> >>>>>> from the hd
> load
> >> os
> >> and
> >> >> is
> >> >> >> doing
> >> >> >> >>>>> a
> >> >> >> >>>>>> bad
> >> >> disk
> >> >> >> or the
> >> >> >> >>>>>> clean
> >> >> >> >>>>>> present
> >> >> >> >>>>>> From: sofad_1999
> >> >> >> >>>>>> Hi all,
> >> >> >> >>>>>> wondering
> >> >> >> if it
> >> >> >> >>>>>> original
> >> >> SCSI
> >> >> >> >>>>> floppy
> >> >> >> >>>>>> drive.
> >> >> >> additional 2.14
> >> >> >> >>>>>> OS disks using EMXP
> >> >> >> >>>>>> drive
> >> >> I
> >> >> >> get
> >> >> >> >>>>> the
> >> >> >> >>>>>> following messages:
> >> >> >> >>>>>> Checking Floppy
> >> >> >> >>>>>> Loading Software
> >> >> >> >>>>>> Disk Not Formatted
> >> get
> >> >> red
> >> >> >> >>>>> lights
> >> >> >> >>>>>> on STOP and RECORD.
> if
> >> >> >> >>>>>> that
> >> >> >> makes a
> >> disconnecting
> >> >> the
> >> >> >> >>>>> Floppy
> be
> >> >> >> >>>>>> the
> >> >> >> problem?
> case...
> >> >> >> >>>>>> and
> >> >> am
> >> >> definitely
> >> >> >> the
> >> >> >> >>>>>> problem.
> >> >> >> >>>>>> Thanks
> >> >> >> >>>>>> Tony
have you tried pressing the enter button
becuase the p00 untitled programmight be blank
hence why you are getting no response from keys
Sent: Friday, October 05, 2012 9:23 PM
> No
> On Fri, Oct 5, 2012 at 1:07 PM, jammie <jammie.emma@...>
>> control
>> > II
>> > get
>> first
>> cycles
>> >> > inserted
>> >> (OS
>> >> > flashes,
>> >> and
>> the
>> >> 'plus'
>> select
>> >> > to
>> >> >> drive
>> >> >> From: Tony Court
>> and
>> >> >> I
>> >> >> flashing.
>> those
>> >> >> does
>> >> >> the
>> >> >> <anthony.court@...
>> >> >> > brackets
>> >> >> >> floppy
>> >> >> >> exactly.
>> >> >> >> the
>> >> >> >> side
>> >> >> >> of the PCD drive.
>> >> >> >> of
>> >> >> >> easily
>> >> >> >> eject.
>> >> >> >> screws
>> >> >> >> or
>> >> use
>> >> >> >> some small nuts.
>> >> >> >> it.
>> >> >> >> and
>> >> >> >> cf
>> >> >> >> get
>> >> a
>> both
>> the
>> >> >> pics on
>> >> >> >> each
>> >> >> >> other
>> >> >> and
>> >> >> >> Thanks
>> >> >> >> Tony
>> >> >> >> Sent from my iPhone
>> >> choose.
>> >> >> >> > 32MB flash media.
>> >> >> >> > etc?
>> >> >> I'm
>> how
>> >> >> >> to
>> >> >> >> install.
>> >> >> >> > thanks again
>> >> >> >> >> drive
>> >> >> >> >> From: Tony Court
>> >> >> >> >> from
>> >> >> >> >> Tony
>> >> would
>> >> >> >> >>> of
>> >> >> >> >>> be
>> >> >> >> >>> on
>> >> >> >> >>> From: Tony Court
>> >> >> >> >>> both
>> >> >> the
>> emxp),
>> >> >> >> I
>> >> >> also
>> >> >> connected)
>> >> floppy
>> >> covered
>> >> >> up
>> >> >> >> the relevant holes.
>> >> >> >> >>> be
>> >> >> >> >>> the
>> >> >> >> stuck
>> >> >> now :(
>> >> >> >> >>> Tony
>> floppy
>> >> >> >> connector-
>> >> >> >> >>>> or
>> >> EMXP
>> >> >> >> utilities
>> >> >> >> formatted by
>> >> >> >> >>>> utilities.
>> >> >> >> >>>> indicates
>> >> >> >> >>>> High-density disk.
>> >> >> >> >>>> above
>> >> >> >> doesn't
>> >> >> >> >>>> work for you.
>> >> >> >> >>>> Regards,
>> >> >> >> >>>> Ted
>> >> >> >> >>>> <anthony.court@...>
>> >> >> >> >>>>> HD
>> >> >> >> connected and
>> and
>> >> >> >> >>>>> let
>> >> >> >> you know.
>> >> >> >> >>>>> drive
>> >> >> >> >>>>> is
>> >> >> >> fried....
>> the
>> >> >> >> >>>>> HD?
>> >> >> I
>> >> >> computer,
>> >> >> >> but am
>> about
>> >> >> >> >>>>> the
>> >> >> >> OS on the
>> and
>> >> >> >> >>>>> 2
>> >> >> >> >>>>> zip
>> >> >> >> disks
>> zip
>> >> >> disks
>> >> >> >> as
>> >> >> >> >>>>> well?
>> >> >> >> >>>>> Tony
>> >> >> >> >>>>>> and
>> >> >> >> should boot
>> >> >> >> >>>>>> from the hd
>> load
>> >> os
>> >> >> >> >>>>>> seen
>> >> and
>> >> >> is
>> >> >> >> doing
>> >> >> >> >>>>> a
>> >> >> >> >>>>>> bad
>> >> >> disk
>> >> >> >> or the
>> >> >> >> >>>>>> clean
>> >> >> >> >>>>>> present
>> >> >> >> >>>>>> From: sofad_1999
>> >> >> >> >>>>>> Hi all,
>> >> >> >> >>>>>> wondering
>> >> >> >> if it
>> >> >> >> >>>>>> original
>> >> >> SCSI
>> >> >> >> >>>>> floppy
>> >> >> >> >>>>>> drive.
>> >> >> >> additional 2.14
>> >> >> >> >>>>>> OS disks using EMXP
>> >> >> >> >>>>>> the
>> >> >> >> >>>>>> drive
>> >> >> I
>> >> >> >> get
>> >> >> >> >>>>> the
>> >> >> >> >>>>>> following messages:
>> >> >> >> >>>>>> Checking Floppy
>> >> >> >> >>>>>> Loading Software
>> >> >> >> >>>>>> Disk Not Formatted
>> >> >> >> >>>>>> I
>> >> get
>> >> >> red
>> >> >> >> >>>>> lights
>> >> >> >> >>>>>> on STOP and RECORD.
>> if
>> >> >> >> >>>>>> that
>> >> >> >> makes a
>> >> disconnecting
>> >> >> the
>> >> >> >> >>>>> Floppy
>> be
>> >> >> >> >>>>>> the
>> >> >> >> problem?
>> case...
>> >> >> >> >>>>>> and
>> >> >> am
>> >> >> definitely
>> >> >> >> the
>> >> >> >> >>>>>> problem.
>> >> >> >> >>>>>> Thanks
>> >> >> >> >>>>>> Tony
yes the chips are available from epr electronics $40
> No
>> control
>> > II
>> > get
>> first
>> cycles
>> >> > inserted
>> >> (OS
>> >> > flashes,
>> >> and
>> the
>> >> 'plus'
>> select
>> >> > to
>> >> >> drive
>> >> >> From: Tony Court
>> and
>> >> >> I
>> >> >> flashing.
>> those
>> >> >> does
>> >> >> the
>> >> >> <anthony.court@...
>> >> >> > brackets
>> >> >> >> floppy
>> >> >> >> exactly.
>> >> >> >> the
>> >> >> >> side
>> >> >> >> of the PCD drive.
>> >> >> >> of
>> >> >> >> easily
>> >> >> >> eject.
>> >> >> >> screws
>> >> >> >> or
>> >> use
>> >> >> >> some small nuts.
>> >> >> >> it.
>> >> >> >> and
>> >> >> >> cf
>> >> >> >> get
>> >> a
>> both
>> the
>> >> >> pics on
>> >> >> >> each
>> >> >> >> other
>> >> >> and
>> >> >> >> Thanks
>> >> >> >> Tony
>> >> >> >> Sent from my iPhone
>> >> choose.
>> >> >> >> > 32MB flash media.
>> >> >> >> > etc?
>> >> >> I'm
>> how
>> >> >> >> to
>> >> >> >> install.
>> >> >> >> > thanks again
>> >> >> >> >> drive
>> >> >> >> >> From: Tony Court
>> >> >> >> >> from
>> >> >> >> >> Tony
>> >> would
>> >> >> >> >>> of
>> >> >> >> >>> be
>> >> >> >> >>> on
>> >> >> >> >>> From: Tony Court
>> >> >> >> >>> both
>> >> >> the
>> emxp),
>> >> >> >> I
>> >> >> also
>> >> >> connected)
>> >> floppy
>> >> covered
>> >> >> up
>> >> >> >> the relevant holes.
>> >> >> >> >>> be
>> >> >> >> >>> the
>> >> >> >> stuck
>> >> >> now :(
>> >> >> >> >>> Tony
>> floppy
>> >> >> >> connector-
>> >> >> >> >>>> or
>> >> EMXP
>> >> >> >> utilities
>> >> >> >> formatted by
>> >> >> >> >>>> utilities.
>> >> >> >> >>>> indicates
>> >> >> >> >>>> High-density disk.
>> >> >> >> >>>> above
>> >> >> >> doesn't
>> >> >> >> >>>> work for you.
>> >> >> >> >>>> Regards,
>> >> >> >> >>>> Ted
>> >> >> >> >>>> <anthony.court@...>
>> >> >> >> >>>>> HD
>> >> >> >> connected and
>> and
>> >> >> >> >>>>> let
>> >> >> >> you know.
>> >> >> >> >>>>> drive
>> >> >> >> >>>>> is
>> >> >> >> fried....
>> the
>> >> >> >> >>>>> HD?
>> >> >> I
>> >> >> computer,
>> >> >> >> but am
>> about
>> >> >> >> >>>>> the
>> >> >> >> OS on the
>> and
>> >> >> >> >>>>> 2
>> >> >> >> >>>>> zip
>> >> >> >> disks
>> zip
>> >> >> disks
>> >> >> >> as
>> >> >> >> >>>>> well?
>> >> >> >> >>>>> Tony
>> >> >> >> >>>>>> and
>> >> >> >> should boot
>> >> >> >> >>>>>> from the hd
>> load
>> >> os
>> >> >> >> >>>>>> seen
>> >> and
>> >> >> is
>> >> >> >> doing
>> >> >> >> >>>>> a
>> >> >> >> >>>>>> bad
>> >> >> disk
>> >> >> >> or the
>> >> >> >> >>>>>> clean
>> >> >> >> >>>>>> present
>> >> >> >> >>>>>> From: sofad_1999
>> >> >> >> >>>>>> Hi all,
>> >> >> >> >>>>>> wondering
>> >> >> >> if it
>> >> >> >> >>>>>> original
>> >> >> SCSI
>> >> >> >> >>>>> floppy
>> >> >> >> >>>>>> drive.
>> >> >> >> additional 2.14
>> >> >> >> >>>>>> OS disks using EMXP
>> >> >> >> >>>>>> the
>> >> >> >> >>>>>> drive
>> >> >> I
>> >> >> >> get
>> >> >> >> >>>>> the
>> >> >> >> >>>>>> following messages:
>> >> >> >> >>>>>> Checking Floppy
>> >> >> >> >>>>>> Loading Software
>> >> >> >> >>>>>> Disk Not Formatted
>> >> >> >> >>>>>> I
>> >> get
>> >> >> red
>> >> >> >> >>>>> lights
>> >> >> >> >>>>>> on STOP and RECORD.
>> if
>> >> >> >> >>>>>> that
>> >> >> >> makes a
>> >> disconnecting
>> >> >> the
>> >> >> >> >>>>> Floppy
>> be
>> >> >> >> >>>>>> the
>> >> >> >> problem?
>> case...
>> >> >> >> >>>>>> and
>> >> >> am
>> >> >> definitely
>> >> >> >> the
>> >> >> >> >>>>>> problem.
>> >> >> >> >>>>>> Thanks
>> >> >> >> >>>>>> Tony
yup - I tried pressing the 'enter' key, no response and it just keeps
flashing red :( Nothing is responsive, buttons or keys :(
Where is the IC scanner chip located? Is there any way to test if it might
have failed?
> From: "Tony Court" <anthony.court@gmail.com>
> > No
> >> control
> >> > II
> >> > get
> >> first
> (for
> >> cycles
> >> >> > inserted
> >> >> (OS
> >> >> > flashes,
> >> >> and
> >> the
> >> >> 'plus'
> >> select
> >> >> > to
> >> >> >> drive
> >> >> >> From: Tony Court
> >> and
> >> >> >> I
> >> >> >> flashing.
> >> those
> >> >> >> does
> >> >> >> the
> >> >> >> <anthony.court@...
> >> >> >> > brackets
> original
> >> >> >> >> floppy
> >> >> >> >> exactly.
> >> >> >> >> the
> >> >> >> >> side
> >> >> >> >> of the PCD drive.
> >> >> >> >> of
> >> >> >> >> easily
> >> >> >> >> eject.
> the
> >> >> >> >> screws
> nylon
> >> >> >> >> or
> >> >> use
> >> >> >> >> some small nuts.
> fabricate
> >> >> >> >> it.
> >> >> >> >> and
> >> >> >> >> cf
> I'll
> >> >> >> >> get
> >> >> a
> >> both
> >> the
> >> >> >> pics on
> >> >> >> >> each
> >> >> >> >> other
> >> >> >> and
> >> >> >> >> Thanks
> >> >> >> >> Tony
> >> >> >> >> Sent from my iPhone
> >> >> choose.
> >> >> >> >> > 32MB flash media.
> numbers
> >> >> >> >> > etc?
> >> >> >> I'm
> >> how
> >> >> >> >> to
> >> >> >> >> install.
> >> >> >> >> > thanks again
> >> >> >> >> >> drive
> >> >> >> >> >> From: Tony Court
> >> >> >> >> >> from
> >> >> >> >> >> Tony
> >> >> would
> >> >> >> >> >>> of
> >> >> >> >> >>> be
> >> >> >> >> >>> on
> >> >> >> >> >>> From: Tony Court
> with
> >> >> >> >> >>> both
> >> >> >> the
> >> emxp),
> >> >> >> >> I
> >> >> >> also
> >> >> >> connected)
> >> >> floppy
> power.
> >> >> covered
> >> >> >> up
> >> >> >> >> the relevant holes.
> >> >> >> >> >>> be
> >> >> >> >> >>> the
> >> >> >> >> stuck
> >> >> >> now :(
> >> >> >> >> >>> Tony
> >> floppy
> >> >> >> >> connector-
> >> >> >> >> >>>> or
> >> >> EMXP
> >> >> >> >> utilities
> probably
> >> >> >> >> formatted by
> >> >> >> >> >>>> utilities.
> >> >> >> >> >>>> indicates
> >> >> >> >> >>>> High-density disk.
> >> >> >> >> >>>> above
> >> >> >> >> doesn't
> >> >> >> >> >>>> work for you.
> >> >> >> >> >>>> Regards,
> >> >> >> >> >>>> Ted
> >> >> >> >> >>>> <anthony.court@...>
> the
> >> >> >> >> >>>>> HD
> >> >> >> >> connected and
> >> and
> >> >> >> >> >>>>> let
> >> >> >> >> you know.
> >> >> >> >> >>>>> drive
> >> >> >> >> >>>>> is
> >> >> >> >> fried....
> >> the
> >> >> >> >> >>>>> HD?
> >> >> >> I
> >> >> >> computer,
> >> >> >> >> but am
> right
> >> about
> >> >> >> >> >>>>> the
> >> >> >> >> OS on the
> >> and
> >> >> >> >> >>>>> 2
> >> >> >> >> >>>>> zip
> >> >> >> >> disks
> >> zip
> >> >> >> disks
> >> >> >> >> as
> >> >> >> >> >>>>> well?
> >> >> >> >> >>>>> Tony
> it
> >> >> >> >> >>>>>> and
> >> >> >> >> should boot
> >> >> >> >> >>>>>> from the hd
> >> load
> >> >> os
> >> >> >> >> >>>>>> seen
> >> >> and
> >> >> >> is
> >> >> >> >> doing
> >> >> >> >> >>>>> a
> a
> >> >> >> >> >>>>>> bad
> >> >> >> disk
> >> >> >> >> or the
> >> >> >> >> >>>>>> clean
> >> >> >> >> >>>>>> present
> >> >> >> >> >>>>>> From: sofad_1999
> >> >> >> >> >>>>>> Hi all,
> >> >> >> >> >>>>>> wondering
> >> >> >> >> if it
> >> >> >> >> >>>>>> original
> >> >> >> SCSI
> >> >> >> >> >>>>> floppy
> >> >> >> >> >>>>>> drive.
> created
> >> >> >> >> additional 2.14
> >> >> >> >> >>>>>> OS disks using EMXP
> >> >> >> >> >>>>>> the
> >> >> >> >> >>>>>> drive
> >> >> >> I
> >> >> >> >> get
> >> >> >> >> >>>>> the
> >> >> >> >> >>>>>> following messages:
> >> >> >> >> >>>>>> Checking Floppy
> >> >> >> >> >>>>>> Loading Software
> >> >> >> >> >>>>>> Disk Not Formatted
> seconds.
> >> >> >> >> >>>>>> I
> >> >> get
> >> >> >> red
> >> >> >> >> >>>>> lights
> >> >> >> >> >>>>>> on STOP and RECORD.
> see
> >> if
> >> >> >> >> >>>>>> that
> >> >> >> >> makes a
> >> >> disconnecting
> >> >> >> the
> >> >> >> >> >>>>> Floppy
> may
> >> be
> >> >> >> >> >>>>>> the
> >> >> >> >> problem?
> >> case...
> >> >> >> >> >>>>>> and
> >> >> >> am
> >> >> >> definitely
> >> >> >> >> the
> >> >> >> >> >>>>>> problem.
> >> >> >> >> >>>>>> Thanks
> >> >> >> >> >>>>>> Tony
This one?
http://www.eprelectronics.com/store/IC-MOS-R6500-11-Microcomputer-1-chip-p72.html
> > No
> >> control
> >> From: "Tony Court" <anthony.court@...m>
> >> > II
> >> > get
> >> first
> (for
> >> cycles
> >> >> > inserted
> >> >> (OS
> >> >> > flashes,
> >> >> and
> >> the
> >> >> 'plus'
> >> select
> >> >> > to
> >> >> >> drive
> >> >> >> From: Tony Court
> >> and
> >> >> >> I
> >> >> >> flashing.
> >> those
> >> >> >> does
> >> >> >> the
> >> >> >> <anthony.court@...
> >> >> >> > brackets
> original
> >> >> >> >> floppy
> >> >> >> >> exactly.
> >> >> >> >> the
> >> >> >> >> side
> >> >> >> >> of the PCD drive.
> >> >> >> >> of
> >> >> >> >> easily
> >> >> >> >> eject.
> the
> >> >> >> >> screws
> nylon
> >> >> >> >> or
> >> >> use
> >> >> >> >> some small nuts.
> fabricate
> >> >> >> >> it.
> >> >> >> >> and
> >> >> >> >> cf
> I'll
> >> >> >> >> get
> >> >> a
> >> both
> >> the
> >> >> >> pics on
> >> >> >> >> each
> >> >> >> >> other
> >> >> >> and
> >> >> >> >> Thanks
> >> >> >> >> Tony
> >> >> >> >> Sent from my iPhone
> >> >> choose.
> >> >> >> >> > 32MB flash media.
> numbers
> >> >> >> >> > etc?
> >> >> >> I'm
> >> how
> >> >> >> >> to
> >> >> >> >> install.
> >> >> >> >> > thanks again
> >> >> >> >> >> drive
> >> >> >> >> >> From: Tony Court
> >> >> >> >> >> from
> >> >> >> >> >> Tony
> >> >> would
> >> >> >> >> >>> of
> >> >> >> >> >>> be
> >> >> >> >> >>> on
> >> >> >> >> >>> From: Tony Court
> with
> >> >> >> >> >>> both
> >> >> >> the
> >> emxp),
> >> >> >> >> I
> >> >> >> also
> >> >> >> connected)
> >> >> floppy
> power.
> >> >> covered
> >> >> >> up
> >> >> >> >> the relevant holes.
> >> >> >> >> >>> be
> >> >> >> >> >>> the
> >> >> >> >> stuck
> >> >> >> now :(
> >> >> >> >> >>> Tony
> >> floppy
> >> >> >> >> connector-
> >> >> >> >> >>>> or
> >> >> EMXP
> >> >> >> >> utilities
> probably
> >> >> >> >> formatted by
> >> >> >> >> >>>> utilities.
> >> >> >> >> >>>> indicates
> >> >> >> >> >>>> High-density disk.
> >> >> >> >> >>>> above
> >> >> >> >> doesn't
> >> >> >> >> >>>> work for you.
> >> >> >> >> >>>> Regards,
> >> >> >> >> >>>> Ted
> >> >> >> >> >>>> <anthony.court@...>
> the
> >> >> >> >> >>>>> HD
> >> >> >> >> connected and
> >> and
> >> >> >> >> >>>>> let
> >> >> >> >> you know.
> >> >> >> >> >>>>> drive
> >> >> >> >> >>>>> is
> >> >> >> >> fried....
> >> the
> >> >> >> >> >>>>> HD?
> >> >> >> I
> >> >> >> computer,
> >> >> >> >> but am
> right
> >> about
> >> >> >> >> >>>>> the
> >> >> >> >> OS on the
> >> and
> >> >> >> >> >>>>> 2
> >> >> >> >> >>>>> zip
> >> >> >> >> disks
> >> zip
> >> >> >> disks
> >> >> >> >> as
> >> >> >> >> >>>>> well?
> >> >> >> >> >>>>> Tony
> it
> >> >> >> >> >>>>>> and
> >> >> >> >> should boot
> >> >> >> >> >>>>>> from the hd
> >> load
> >> >> os
> >> >> >> >> >>>>>> seen
> >> >> and
> >> >> >> is
> >> >> >> >> doing
> >> >> >> >> >>>>> a
> a
> >> >> >> >> >>>>>> bad
> >> >> >> disk
> >> >> >> >> or the
> >> >> >> >> >>>>>> clean
> >> >> >> >> >>>>>> present
> >> >> >> >> >>>>>> From: sofad_1999
> >> >> >> >> >>>>>> Hi all,
> >> >> >> >> >>>>>> wondering
> >> >> >> >> if it
> >> >> >> >> >>>>>> original
> >> >> >> SCSI
> >> >> >> >> >>>>> floppy
> >> >> >> >> >>>>>> drive.
> created
> >> >> >> >> additional 2.14
> >> >> >> >> >>>>>> OS disks using EMXP
> >> >> >> >> >>>>>> the
> >> >> >> >> >>>>>> drive
> >> >> >> I
> >> >> >> >> get
> >> >> >> >> >>>>> the
> >> >> >> >> >>>>>> following messages:
> >> >> >> >> >>>>>> Checking Floppy
> >> >> >> >> >>>>>> Loading Software
> >> >> >> >> >>>>>> Disk Not Formatted
> seconds.
> >> >> >> >> >>>>>> I
> >> >> get
> >> >> >> red
> >> >> >> >> >>>>> lights
> >> >> >> >> >>>>>> on STOP and RECORD.
> see
> >> if
> >> >> >> >> >>>>>> that
> >> >> >> >> makes a
> >> >> disconnecting
> >> >> >> the
> >> >> >> >> >>>>> Floppy
> may
> >> be
> >> >> >> >> >>>>>> the
> >> >> >> >> problem?
> >> case...
> >> >> >> >> >>>>>> and
> >> >> >> am
> >> >> >> definitely
> >> >> >> >> the
> >> >> >> >> >>>>>> problem.
> >> >> >> >> >>>>>> Thanks
> >> >> >> >> >>>>>> Tony
So - I played around a bit more, removed and reseated all the boards,
re-seated the scanner IC, and........ I now have responsive keys, can load
sounds, play sounds etc.... :)
I do have a really bad digital noise in the left channel when using the
stereo headphone socket (with headphones).... I get silence in the left
channel, then a digital noise/echo sound, then really distorted version of
what 'm hearing on the right channel, then back to no sound again.... I
plugged my headphones into  the L/R output and I get prfect sound from the
right channel, and no sound/digitally distorted sound from the left output.
Any ideas what I should be looking for regarding this? I can upload an
audio sample of it in a few hours if necessary
> have failed?
>> button.
>> > No
>> >> control
>> Emax
>> >> > II
>> can
>> >> > get
>> >> >> To: <emax@...m>
>> >> first
>> (for
>> >> cycles
>> >> >> > inserted
>> >> >> (OS
>> >> >> > flashes,
>> >> >> and
>> and
>> >> the
>> the
>> >> >> 'plus'
>> >> select
>> >> >> > to
>> >> >> >> drive
>> >> >> >> From: Tony Court
>> load),
>> >> and
>> >> >> >> I
>> >> >> >> flashing.
>> >> those
>> button
>> >> >> >> does
>> and
>> >> >> >> the
>> >> >> >> <anthony.court@...
>> >> >> >> > brackets
>> original
>> >> >> >> >> floppy
>> >> >> >> >> exactly.
>> on
>> >> >> >> >> the
>> >> >> >> >> side
>> >> >> >> >> of the PCD drive.
>> out
>> >> >> >> >> of
>> >> >> >> >> easily
>> >> >> >> >> eject.
>> the
>> >> >> >> >> screws
>> nylon
>> >> >> >> >> or
>> >> >> use
>> >> >> >> >> some small nuts.
>> fabricate
>> >> >> >> >> it.
>> >> >> >> >> and
>> >> >> >> >> cf
>> I'll
>> >> >> >> >> get
>> >> >> a
>> >> both
>> All
>> >> the
>> >> >> >> pics on
>> >> >> >> >> each
>> >> >> >> >> other
>> >> >> >> and
>> >> >> >> >> Thanks
>> >> >> >> >> Tony
>> >> >> >> >> Sent from my iPhone
>> >> >> >> >> On Sep 27, 2012, at 22:29, Ted Summers <djtbs1@gmail.com>
>> >> >> choose.
>> >> >> >> >> > 32MB flash media.
>> numbers
>> >> >> >> >> > etc?
>> >> >> >> I'm
>> >> how
>> >> >> >> >> to
>> >> >> >> >> install.
>> >> >> >> >> > thanks again
>> >> >> >> >> >> drive
>> >> >> >> >> >> From: Tony Court
>> >> >> >> >> >> from
>> >> >> >> >> >> Tony
>> drive
>> drive
>> >> >> would
>> >> >> >> >> >>> of
>> could
>> >> >> >> >> >>> be
>> >> >> >> >> >>> on
>> >> >> >> >> >>> From: Tony Court
>> with
>> >> >> >> >> >>> both
>> >> >> >> the
>> >> emxp),
>> >> >> >> >> I
>> >> >> >> also
>> >> >> >> connected)
>> the
>> >> >> floppy
>> power.
>> >> >> covered
>> >> >> >> up
>> >> >> >> >> the relevant holes.
>> that
>> >> >> >> >> >>> be
>> >> >> >> >> >>> the
>> bit
>> >> >> >> >> stuck
>> >> >> >> now :(
>> >> >> >> >> >>> Tony
>> >> floppy
>> >> >> >> >> connector-
>> (DOS)
>> >> >> >> >> >>>> or
>> >> >> EMXP
>> >> >> >> >> utilities
>> probably
>> >> >> >> >> formatted by
>> >> >> >> >> >>>> utilities.
>> >> >> >> >> >>>> indicates
>> >> >> >> >> >>>> High-density disk.
>> the
>> >> >> >> >> >>>> above
>> >> >> >> >> doesn't
>> >> >> >> >> >>>> work for you.
>> >> >> >> >> >>>> Regards,
>> >> >> >> >> >>>> Ted
>> >> >> >> >> >>>> <anthony.court@...>
>> the
>> >> >> >> >> >>>>> HD
>> >> >> >> >> connected and
>> tonight
>> >> and
>> >> >> >> >> >>>>> let
>> >> >> >> >> you know.
>> >> >> >> >> >>>>> drive
>> >> >> >> >> >>>>> is
>> >> >> >> >> fried....
>> onto
>> >> the
>> >> >> >> >> >>>>> HD?
>> >> >> >> I
>> my
>> >> >> >> computer,
>> >> >> >> >> but am
>> right
>> >> about
>> >> >> >> >> >>>>> the
>> >> >> >> >> OS on the
>> >> and
>> >> >> >> >> >>>>> 2
>> >> >> >> >> >>>>> zip
>> >> >> >> >> disks
>> the
>> >> zip
>> >> >> >> disks
>> >> >> >> >> as
>> >> >> >> >> >>>>> well?
>> >> >> >> >> >>>>> Tony
>> it
>> >> >> >> >> >>>>>> and
>> >> >> >> >> should boot
>> >> >> >> >> >>>>>> from the hd
>> >> load
>> >> >> os
>> >> >> >> >> >>>>>> seen
>> >> >> and
>> >> >> >> is
>> >> >> >> >> doing
>> >> >> >> >> >>>>> a
>> either a
>> >> >> >> >> >>>>>> bad
>> >> >> >> disk
>> >> >> >> >> or the
>> good
>> >> >> >> >> >>>>>> clean
>> >> >> >> >> >>>>>> present
>> >> >> >> >> >>>>>> From: sofad_1999
>> >> >> >> >> >>>>>> Hi all,
>> >> >> >> >> >>>>>> wondering
>> >> >> >> >> if it
>> >> >> >> >> >>>>>> original
>> >> >> >> SCSI
>> >> >> >> >> >>>>> floppy
>> >> >> >> >> >>>>>> drive.
>> created
>> >> >> >> >> additional 2.14
>> >> >> >> >> >>>>>> OS disks using EMXP
>> >> >> >> >> >>>>>> the
>> >> >> >> >> >>>>>> drive
>> >> >> >> I
>> >> >> >> >> get
>> >> >> >> >> >>>>> the
>> >> >> >> >> >>>>>> following messages:
>> >> >> >> >> >>>>>> Checking Floppy
>> >> >> >> >> >>>>>> Loading Software
>> >> >> >> >> >>>>>> Disk Not Formatted
>> seconds.
>> >> >> >> >> >>>>>> I
>> >> >> get
>> >> >> >> red
>> >> >> >> >> >>>>> lights
>> >> >> >> >> >>>>>> on STOP and RECORD.
>> see
>> >> if
>> >> >> >> >> >>>>>> that
>> >> >> >> >> makes a
>> >> >> disconnecting
>> >> >> >> the
>> >> >> >> >> >>>>> Floppy
>> may
>> >> be
>> >> >> >> >> >>>>>> the
>> >> >> >> >> problem?
>> >> case...
>> >> >> >> >> >>>>>> and
>> >> >> >> am
>> >> >> >> definitely
>> >> >> >> >> the
>> >> >> >> >> >>>>>> problem.
>> >> >> >> >> >>>>>> Thanks
>> >> >> >> >> >>>>>> Tony
