Questions about targets
2009-05-04 by Jacob
I'm trying to figure out QTR, getting ready to print target.
eye-one-readme.pdf says:
The 21x4 target is recommended for the best accuracy. It has 4 patches for each
step value and the QTR software will automatically average the 4 measurements
which gives a more accurate result.
My question is: what will be more accurate with this target - measurements or
printer profile? I understand that every patch measured 4 times and averaged
gives more accurate measurement but will profile be better than with 51-step
target?
And for that matter - is 51-steps enough for quality printer profile? Bob Atkins
for example uses 4096-step target for RGB profile.
Thank you,
Jacob
http://www.photo3dart.com
Re: Questions about targets
2009-05-04 by pr_roark
> It has 4 patches for each step value and the QTR software
> - measurements or printer profile? I understand that every
> patch measured 4 times and averaged gives more accurate
> target?
I think multiple sampling will just give a better read of the target.  I don't use strip reading at this point and find a single read of the 21-step test file with my Print Fix Pro spectro is fine most of the time.
> printer profile?
If the curves going into the linearization step were well done, 21 steps is enough.
I've recently been profiling Arches un-coated watercolor paper where I hold the ink limits of the midtones down to avoid bleed.  This keeps the midtone inks in their relatively more linear areas.  When I set the relative densities based on these midtone reads, the pre-linearized QTR profile is nearly linear already.
> Bob Atkins for example uses 4096-step target for RGB profile.
RGB is 3 dimensional, whereas the grayscale is a single dimension.  21-steps to the third power may give you a better idea of what would be equal.
I found the QTR 51-step profile target did not produce a better profile.  In fact, it was rather saw-toothed.  I'm not sure where that is coming from.  A modified, vertical target helped, but it was not worth the effort.
A properly made QTR profile using just 21-step test strips should work very well.
2009-05-04 by Jacob
Thank you Paul.
Now I've got a problem.
I'm trying to print targets with gray wedges through QTRprinter on my 7880 but prints look very strange - very pale, hardly visible and colored.
All I did is to open file in PS CS3, select 'no color management", QTR printer, select "QTR calibration" and printed.
ABW driver printed OK.
Any ideas?
Thanks, Jacob
2009-05-05 by pr_roark
> Thank you Paul.
> Any ideas?
> Thanks, Jacob
It sounds like you're on a Mac.  I'm PC, so a Mac QTR user will have to handle this one.
2009-05-05 by robert49brake
> > Any ideas?
> Paul
> www.PaulRoark.com
Jacob, I think what you've done is print a b&w 21 stepwedge through the Calibration mode in QTR, does that sound correct?  If so, the Calibration mode is only used on special files that determine ink limits.
Go to Applications>QuadToneRIP>CurveDesign>Images and there you will find the special inkseperation files that are run in the calibration mode to drive each head individually so that you can determine ink limits.  That process is spelled out in a file called Calibration.pdf also found in the CurveDesign folder.  When building a custom profile you would print 21 stepwedges as you would print any normal file, that is through QTR with your choice of profile.  If you are new to QTR I would suggest reading Roy Harrington's Basic Tutorial Quadtone RIP on Mac OS X found on the QTR website.  I would also suggest printing at first on a paper/inkset that has already been profiled.  You can find those listed under Applications>QuadToneRIP>Profiles under your printer and inkset (ex: 4880-7880-9880-UC for Epson Ultrachrome Inkset.  There is generally enough info in the profile name to identify the paper, resolution, tone etc.  If you are jumping directly into custom profile making it will be a bit daunting (but doable) although  you'll probably be a lot more copmfortable using the ready made materials first.  The pre-made profiles may be all that you need unless you have a custom inkset and/or very specific papers.  QTR also has many, many advanced and older features that aren't relative unless you are doing things like unusual papers/inksets and can be extremely distracting for someone new to the RIP.  The QTR forum, although not nearly as busy as this one, does get traffic from experienced users and specific questions usually get answered eventually.  As Paul mentioned, QTR on OS X and QTR using the Windows GUI program are two completely different beasts so always mention your OS.
Good luck!
2009-05-06 by Jacob
Robert, thank you very much, you are very helpful.
Yes, it's Mac. QTR is so confusing, more than Maya which is not easy to learn. There are bits and pieces of information.
As I see now workflow is following:
1. To make custom curves - print ink separation file (why it looks so different from the one in calibration.pdf? and why there 4 of them: pdf, tiff, 6.tiff, 8.tiff?) in calibration mode, use it to make ink file like described in calibration.pdf
2. Linearize this file - I'm not sure how yet.
3. Print gray wedge using this curve, make ICC profile - this is easy part.
4. Print images using the curve and ICC profile
Am I close?
What I'm really close to is to forget about QTR and print with ABW.
Thanks again, Jacob
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "robert49brake" <robert49brake@...> wrote:
> > > Any ideas?
> > Paul
> > www.PaulRoark.com
> Good luck!
Soft-proof "profile" for Piezotones?
2009-05-06 by Mark Savoia
Had a client request a grayscale "profile" for soft-proofing a file he
is sending me for a print. My setup is StudioPrint with Piezotones. I
told him I knew of nothing for him to go by or I can send him. Am I
wrong?
Mark
http://www.stillrivereditions.com
RE: [Digital BW] Soft-proof "profile" for Piezotones?
2009-05-06 by David Whistance
I think you can use the QTR "Create ICC" program to produce a profile for
softproofing a grayscale.
David Whistance
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com]On Behalf Of Mark
Savoia
  Sent: 06 May 2009 20:30
  Subject: [Digital BW] Soft-proof "profile" for Piezotones?
  wrong?
  Mark
Re: [Digital BW] Soft-proof "profile" for Piezotones?
But how would that reflect what my setup is, and where would you use
it in Photoshop?
Mark
> profile for
> David Whistance
>  -----Original Message-----
>  From: DigitalBlackandWhiteThePrint@yahoogroups.com
> Savoia
> he
>  wrong?
>  Mark
> If you wish to receive no emails or just a daily digest, or you wish
> this same page.
> - As threads develop, trim off excess portions of earlier messages
> to keep them short.
> flames. Hostile, aggressive or argumentative users may be removed
> from the membership without notice.
> - Keep your posts and threads related to the group topic of digital
> B&W printing. Users who persistently make off-topic posts may be
> removed from the membership.
> guidelines, and to abide by the actions and decisions of the group
> Owner and Moderators. See “Group Topic, Rules and Guidelines” in the
> Files section:
> BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE
> PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE
> “OWNER” AND “MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL
> NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
> CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO,
> DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE
> LOSSES (EVEN IF THE  “OWNER” AND “MODERATORS” OF DIGITAL BW, THE
> PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH
> DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE
> DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR
> ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR
> CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP;
> OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO
> GROUP.
2009-05-06 by amadou diallo
Mark,
Print out the QTR 21x4 target using your normal SP setup. Measure the
target with MeasureTool and drag the resulting text file onto the
QTR-Create-ICC droplet. Send the profile to your client. It will
preview ink hue, paper color and ink density. They can use it for
soft-proofing but NOT for printing.
On Wed, May 6, 2009 at 3:44 PM, Mark Savoia <mark@stillrivereditions.com> wrote:
> it in Photoshop?
> Mark
>> profile for
>> David Whistance
>> Savoia
>> he
>>  wrong?
>>  Mark
>> this same page.
>> to keep them short.
>> Files section:
>> GROUP.
>> Yahoo! Groups Links
> - By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See “Group Topic, Rules and Guidelines” in the Files section:
> BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE “OWNER” AND “MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  “OWNER” AND “MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
amadou diallo
www.blogfiftygreatestphotos.com
I see. I will give it a try.
Mark
On May 6, 2009, at 3:54 PM, amadou diallo wrote:
> Mark,
> On Wed, May 6, 2009 at 3:44 PM, Mark Savoia <mark@...
>> it in Photoshop?
>> Mark
>>> profile for
>>> David Whistance
>>> Mark
>>> Savoia
>>> he
>>> Piezotones. I
>>>  wrong?
>>>  Mark
>>> this same page.
>>> to keep them short.
>>> Files section:
>>> GROUP.
>>> Yahoo! Groups Links
>> to keep them short.
>> PRINT YAHOO GROUP.
>> Yahoo! Groups Links
> amadou diallo
> this same page.
> to keep them short.
> Files section:
> GROUP.
This is all from a distant memory, however: - The Create ICC function merely
creates a profile from a set of readings that you give to it.  The readings
are made from a grey step tablet that you print through your system so the
ICC created will reflect your set-up.  What it won't do, unless I remember
incorrectly, is allow you to soft proof any toning that is present in your
inks, ie it is a greyscale only so whilst it will help your client to adjust
his file so that it prints as he expects on your printer, it will not
represent on screen what the finished print will look like.  I'm sorry but
its a long time since I used this function so my memory may be a little
hazy!  Still I hope this is of some help.  Why not ask on the QTR Group or
check with Roy Harrington directly - I'm sure you will get some better
informed answers.
David Whistance
Savoia
Sent: 06 May 2009 20:45
Subject: Re: [Digital BW] Soft-proof "profile" for Piezotones?
it in Photoshop?
Mark
> profile for
> David Whistance
> Savoia
> he
>  wrong?
>  Mark
> this same page.
> to keep them short.
> Owner and Moderators. See \ufffdGroup Topic, Rules and Guidelines\ufffd in the
> Files section:
> \ufffdOWNER\ufffd AND \ufffdMODERATORS\ufffd OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL
> LOSSES (EVEN IF THE  \ufffdOWNER\ufffd AND \ufffdMODERATORS\ufffd OF DIGITAL BW, THE
> GROUP.
page.
them short.
the membership.
Moderators. See \ufffdGroup Topic, Rules and Guidelines\ufffd in the Files section:
YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE \ufffdOWNER\ufffd AND
\ufffdMODERATORS\ufffd OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU
GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  \ufffdOWNER\ufffd AND
\ufffdMODERATORS\ufffd OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE
Yahoo! Groups Links
Just downloaded QTR. Only thing that does not look like it will work
is I do not own an EyeOne, I have an X-Rite DTP-41. Is there a chart
that is configured for that? Also, is the MeasureTool you speak of a
Eye-One thing too or do I need to get software from X-Rite?
Mark
> Mark,
>> it in Photoshop?
>> Mark
>>> profile for
>>> David Whistance
>>> Mark
>>> Savoia
>>> he
>>> Piezotones. I
>>>  wrong?
>>>  Mark
>>> this same page.
>>> to keep them short.
>>> Files section:
>>> GROUP.
>>> Yahoo! Groups Links
>> to keep them short.
>> PRINT YAHOO GROUP.
>> Yahoo! Groups Links
> amadou diallo
> this same page.
> to keep them short.
> Files section:
> GROUP.
2009-05-06 by C D Tobie
> wrong?
If you have Spyder3Print, you could see if building a 225 patch
profile from a target you printed via your usual Piezo workflow would
produce a useful preview.
C. David Tobie
Global Product Technology Manager
Digital Imaging & Home Theater
CDTobie@...
Datacolor
www.datacolor.com/Spyder3
I have a DTP-41 only.
Mark
>> he
>> wrong?
> C. David Tobie
> CDTobie@...
> Datacolor
> this same page.
> to keep them short.
> Files section:
> GROUP.
2009-05-06 by Tyler Boley
I can't help specificallt for the dtp-41, but I'll trade ya my old i1 for it and then you have this solved...
You know, I went to great effort to make preview profiles for every PTone StudioPrint ink setup I have here, warm, Selenium, splits, blends, the whole dealy-bob, thinking I'm supplying a helpful tool for my clients to use for file prep.
No one, not one, that I can recall since I started Custom Digital, has requested one, and when I've suggested it, never used one.
Your StudioPrint output is probably meticulously and beautifully linearized, and no doubt matches your working space on the monitor just fine given the ability to target a given dot gain "out".
Soft proof icc based is just not necessary.
Just in case, if you do proceed, make sure they check "preserve color numbers" since you won't be printing with the profile.
Tyler
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Mark Savoia <mark@...> wrote:
> Mark
> >> he
> >> wrong?
> > C. David Tobie
> > CDTobie@...
> > Datacolor
> > this same page.
> > to keep them short.
> > Owner and Moderators. See "Group Topic, Rules and Guidelines" in the
> > Files section:
> > "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL
> > LOSSES (EVEN IF THE  "OWNER" AND "MODERATORS" OF DIGITAL BW, THE
> > GROUP.
> > Yahoo! Groups Links
MeasureTool is from Xrite's ProfileMaker Pro. You have to download the
app and then run it in demo mode. I don't know if it supports your
spectro, though. But there is a folder in the reference files for the
DTP41 so it might be worth a try.
On Wed, May 6, 2009 at 4:17 PM, Mark Savoia <mark@stillrivereditions.com> wrote:
> Mark
>> Mark,
>>> it in Photoshop?
>>> Mark
>>>> profile for
>>>> David Whistance
>>>> Mark
>>>> Savoia
>>>> he
>>>> Piezotones. I
>>>>  wrong?
>>>>  Mark
>>>> this same page.
>>>> to keep them short.
>>>> Files section:
>>>> GROUP.
>>>> Yahoo! Groups Links
>>> to keep them short.
>>> PRINT YAHOO GROUP.
>>> Yahoo! Groups Links
>> amadou diallo
>> this same page.
>> to keep them short.
>> Files section:
>> GROUP.
>> Yahoo! Groups Links
amadou diallo
2009-05-06 by Greg
> Mark
You can get measurement data out of Colorport, but you will need to make the target in Colorport first. As to what software to use to correctly portray your print, I don't have an answer.
You are always the guy of reason. I don't know why I want to do this
either. This always happens when a new client wants to "outfox" me
thinking he has a better way to do it. And you are right, 99% of
clients don't know how to use it anyway, while 99% never need me to
make any adjustments to their files, it IS almost perfect. Damn I hate
when your right!
Although I appreciate the grounding, you can NOT have my DTP-41 :)
Mark
> Tyler
> ... you can NOT have my DTP-41 :)
d#%n!!!
Well, you can't blame me for trying.
Um, can I at least see it? I'll give it right back, I just want to look at it.
I think you'd be quite happy with my i1, honest, it's a good one
T
2009-05-07 by Terry Ritz
Should you decide to do this after all Mark. . . .   You just need to find a
way to get the LAB values out of your spectro for a 21 step wedge. These
need to populate a relatively simple text file, which is then used to create
the soft proof.
For the other poster who felt that ink and paper toning might not
represented, they are. With the QTR Create-ICC tools you can make profiles
that contain only LAB "L" data, or profiles with LAB "L", "A", and "B" data.
I have found the soft proofs to be very useful, at leaset for my own
purposes. I can compare various toned and split toned approaches on screen
before I make my print. More recently, Jon Cone's folks sent me soft proofs
for his Special Edition inks, one for a six ink version and one for a seven
ink version. I could see how the two differed, and compare them with the
inkset I had at the time. Of course I followed up by having some real prints
made before a purchase, but I learned enough with the soft proofs to keep
going.
Terry.
> when your right!
> Mark
>> Tyler
2009-05-08 by Jon Cone
Mark,
Buy they EyeOne and you can make a soft proof profile in minutes. It's the best instrument for my money and you can segue it into StudioPrint linearizations if you wish, make RGB and CMYK profiles as well as calibrate monitors, etc...  QTR is setup for it to make the ICC softproofs and you do not have to fool around with another brand which is not as suitable to making the QTR Create-ICCs.
Super easy...
Jon Cone
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Terry Ritz <t.ritz@...> wrote:
> the soft proof.
> going.
> Terry.
> > when your right!
> > Mark
> >> Tyler
2009-05-08 by Mark Savoia
Jon,
I made the decision when Tyler informed me he went through the whole
process for a bunch of paper and ink combos to provide to his clients
and either they did not know how to use them or never asked. The
client who was quizzing me turned out not to know much about anything,
had just heard the buzzword "soft proof" at some seminar. The scans he
provided me to make 30x40 prints were unusable, ....such crap people
are getting  from certain "scan services". I requested the neg so we
can scan it ourselves but he was too nervous to let it travel via
FEDEX or other means, he is out of state. So for now, I will do what I
always do, make the client a small proof first and 99%  of the time
they love it and OK it.
Mark
On May 8, 2009, at 3:06 PM, Jon Cone wrote:
> Mark,
> Super easy...
> Jon Cone
>> to find a
>> These
>> to create
>> the soft proof.
>> profiles
>> "B" data.
>> screen
>> soft proofs
>> a seven
>> with the
>> real prints
>> to keep
>> going.
>> Terry.
>>> hate
>>> when your right!
>>> Mark
>>>> Tyler
> this same page.
> to keep them short.
> Files section:
> GROUP.
2009-05-08 by Cdtobie
The "other brand" makes great CreateICC profiles, actually. It's what
Paul Roark uses for all his measuring.
C. D. Tobie
Global Product Technology Mngr.
Datacolor.com
CDTobie@...
On May 8, 2009, at 3:06 PM, "Jon Cone" <jon@...> wrote:
> Mark,
> Super easy...
> Jon Cone
>> to find a
>> These
>> to create
>> the soft proof.
>> profiles
>> "B" data.
>> screen
>> soft proofs
>> a seven
>> with the
>> real prints
>> to keep
>> going.
>> Terry.
>>> hate
>>> when your right!
>>> Mark
>>>> Tyler
> this same page.
> to keep them short.
> the Files section:
2009-05-09 by Jon Cone
David, do you guys sell a transmissive spectrophotomete?
Jon
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Cdtobie <CDTobie@...> wrote:
> C. D. Tobie
> Datacolor.com
> CDTobie@...
> > Mark,
> > Super easy...
> > Jon Cone
> >> to find a
> >> These
> >> to create
> >> the soft proof.
> >> profiles
> >> "B" data.
> >> screen
> >> soft proofs
> >> a seven
> >> with the
> >> real prints
> >> to keep
> >> going.
> >> Terry.
> >>> hate
> >>> when your right!
> >>> Mark
> >>>> Tyler
> > this same page.
> > to keep them short.
> > the Files section:
> > Yahoo! Groups Links
2009-05-09 by Cdtobie
Was anyone discussing transmissive profiles?
C. D. Tobie
Datacolor.com
CDTobie@Datacolor.com
> Jon
>> C. D. Tobie
>> Datacolor.com
>> CDTobie@...
>>> Mark,
>>> Super easy...
>>> Jon Cone
>>>> to find a
>>>> These
>>>> to create
>>>> the soft proof.
>>>> profiles
>>>> "B" data.
>>>> own
>>>> screen
>>>> soft proofs
>>>> a seven
>>>> with the
>>>> real prints
>>>> to keep
>>>> going.
>>>> Terry.
>>>>> this
>>>>> to
>>>>> hate
>>>>> when your right!
>>>>> Mark
>>>>>> old
>>>>>> every
>>>>>> tool
>>>>>> Digital,
>>>>>> monitor
>>>>>> Tyler
>>> this same page.
>>> to keep them short.
>>> Guidelines” in
>>> the Files section:
>>> PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE ‚
>>> ÄúOWNE
>>> YAHOO GROUP SHALL
>>> Yahoo! Groups Links
> this same page.
> to keep them short.
> Owner and Moderators. See ìGroup Topic, Rules and Guidelinesî in the
>  Files section:
> PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE ìOWNE
> Rî AND ìMODERATORSî OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT
> S (EVEN IF THE  ìOWNERî AND ìMODERATORSî OF DIGITAL BW, THE PRINT
David,
You're constantly sales pitching your products. I'm in the market for one. I thought to take the direct approach with you and just ask a simple question whether you sell transmissive spectros.
Jon
> C. D. Tobie
> Datacolor.com
> CDTobie@...
> > Jon
> >> C. D. Tobie
> >> Datacolor.com
> >> CDTobie@
> >> On May 8, 2009, at 3:06 PM, "Jon Cone" <jon@> wrote:
> >>> Mark,
> >>> Super easy...
> >>> Jon Cone
> >>>> to find a
> >>>> These
> >>>> to create
> >>>> the soft proof.
> >>>> profiles
> >>>> "B" data.
> >>>> own
> >>>> screen
> >>>> soft proofs
> >>>> a seven
> >>>> with the
> >>>> real prints
> >>>> to keep
> >>>> going.
> >>>> Terry.
> >>>>> this
> >>>>> to
> >>>>> hate
> >>>>> when your right!
> >>>>> Mark
> >>>>>> old
> >>>>>> every
> >>>>>> tool
> >>>>>> Digital,
> >>>>>> monitor
> >>>>>> Tyler
> >>> this same page.
> >>> to keep them short.
> >>> Guidelines” in
> >>> the Files section:
> >>> ÄúOWNE
> >>> YAHOO GROUP SHALL
> >>> Yahoo! Groups Links
> > this same page.
> > to keep them short.
> >  Files section:
> > Yahoo! Groups Links
2009-05-09 by C D Tobie
Given that nonsequeter, the answer is: no Datacolor does not sell 0/45
transmissive devices, though I've always had an interest in it. It
would certainly be possible to build one based on our current product,
but the market  for it is so  small, we have never been able to
justify it. Besides, for the type of work I have tested this for,
doing a reflective profile and editing as needed seems to be about as
effective as building a transmissive profile, making it even less
justifiable. But thanks for your interest.
C. David Tobie
CDTobie@...
Datacolor
2009-05-09 by Greg
> Jon,
Mark, I would still suggest you download Colorport and learn how to get the data out in the format that you want. Colorport is FREE from Xrite so all you would possibly lose is some time. Not sure what software you are using for color profiles, but it integrates directly with Profiler Gold and Platinum if installed on the same computer. Data can be saved to work with PrintOpen and probably the Gretag software too. You could probably even save in a format that works with the Colorvision software.
I find the chart builder options extremely valuable, the default patch sizes in Profiler are never ideal unless you are selling paper and ink. You can import charts from a text file, or create your own by typing in the values. it is also a nice light weight measurement application so you can run the measurement portion on really old computers with really slow processors.
You probably meant "non sequitur", similar to the disjointed universal conclusion you made in regard to your testing one for the type of work you do, and my need for one in the type of work I do. Nonetheless, you remind me of young Frankie McCourt during his postal position in Angela's Ashes.
Pending any last word from you on the subject of transmissive spectros or nonsequeter/non sequitur, we can just kill the transmissive spectrophotometer topic-within-a-topic that should have been a new topic and my apologies to the moderator and other readers for my apparent abuse of topic comingling.
Jon
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, C D Tobie <CDTobie@...> wrote:
> C. David Tobie
> CDTobie@...
> Datacolor
Jon, please stay on topic, and avoid personal insults.
C. D. Tobie
Datacolor.com
CDTobie@...
> Jon
>> 0/45
>> product,
>> C. David Tobie
>> CDTobie@...
>> Datacolor
> this same page.
> to keep them short.
> the Files section:
you've got to be kidding me...
"Was anyone discussing transmissive profiles?"
David, we all have to practice civility. Even you do.
Jon
Did any--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Cdtobie <CDTobie@...> wrote:
> C. D. Tobie
> Datacolor.com
> CDTobie@...
> > Jon
> >> 0/45
> >> product,
> >> C. David Tobie
> >> CDTobie@
> >> Datacolor
> > this same page.
> > to keep them short.
> > the Files section:
> > Yahoo! Groups Links
2009-05-09 by Ernst Dinkla
> informed answers.
> David Whistance
It actually does softproof the toning so represents the final print
quite well if the customer knows how soft proofing in PS should work.
For printing from Photoshop it will not use the a and b curves but only
the greyscale curve, the toning is hard coded in the media preset of
QTR. Like it is when used with Epson ABW or the HP B&W modes of the
B9180 and Z models.
Tyler will not use the profile in his Studioprint workflow so when the
profile is created from a QTR target printed through Studioprint it will
be a softproof profile only but usable for that task. Any Spectrometer
will be usable tp create the profile.
Met vriendelijke groeten,   Ernst
New: Dinkla Canvas Wrap Actions
|      Dinkla Grafische Techniek      |
|         www.pigment-print.com        |
|                 ( unvollendet )                 |
2009-05-09 by Tyler Boley
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Ernst Dinkla <edinkla@...> wrote:
> quite well...
A major unsung attribute of QTR Create Icc is that it will characterize any monochromatic output system. This is useful in many many ways.
One, for example- Assign the profile to your grayscale files, then convert to sRGB for accurate ink/paper hue representation of your prints on line.
Whether StudioPrint, TrueB&W, QuadtoneRIP, any number of output systems,  it softproofs nicely with Preserve numbers even if it's not used for printing. Conversions can be utilized in any number of ways, standard of course, but also for building special output systems like spot channel setups after everything has been worked out.
For my K + spot setups, the action that does the file build for final RIP output includes converting to a profile made from the that final setup, before adding other channels etc.. so luminosity remains accurate even after all the other inks have been added.
I also build more patch count charts and reference files, including redundant patches for averaging..
Great tool, endlessly useful, we're all indebted to Roy.
Tyler
http://www.custom-digital.com/
