2006-05-06 by Bakis Sirros
ok list,
it is brainstorm time again!
if you have any crazy idea about a future exotic A100
module, just say it!
i'll gather all your ideas during the next two weeks
and out of them i'll create some new polls.
i am waiting...
best regards,
Bakis.
Bakis Sirros - Parallel Worlds
[Doepfer_a100] group owner
http://www.shimarecords.co.uk
http://www.rubber.gr
Athens-Greece
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
2006-05-06 by david rothbaum
1)
voltage controlled police scanner.
a gate signal would trigger the search or scan function. attenuated cv
for squelch, volume and tuning. and stepped pot for frequency ranges
which could also be cv controlled like the 107 morphing filter or the
mode cv on the sequencer controller. so you could step through the
ranges triggered by a sequencer, then another gate signal could be
used to scan that bank/range. also if you had storable presets you
could step through specific frequencies controlled by gate signals.
for instance 149-2 could randomly step through say a bank of 100
preset frequencies...
2)
5.1 surround voltage controlled mixer. (posted this idea to the plan b
list a while back)
separate vcas for all 5 outputs. and cv controlled 360 degree panning.
(which could possibly be hooked up to the joystick/Theremin module).
could also be used as a really strange cv mixer. it would be good to
have a summed (folded down) stereo out puts as well as discrete
outputs for each channel.
3)
smokeless ashtray module.
this way you could play a gig somewhere where you are not allowed to
smoke (everywhere?) and if the synth was placed correctly/large enough
you could have a smoke while you played without anyone knowing...
--david
--- In Doepfer_a100@yahoogroups.com, Bakis Sirros
<synth_freak_2000@...> wrote:
> ok list,
> i am waiting...
> best regards,
> Bakis.
> Athens-Greece
> Do You Yahoo!?
2006-05-06 by florian anwander
Hello Bakis,
I already mentioned this some months ago:
I'd like to have something, what I call a general addon module:
This should enhance the input/output-features of mostly audio related
modules.
* For the output I'd like to have simple multiples (three or four sockets).
* For the input section there MUST be a crossfader (real logarithmic
stereo potentiometer - no voltage control). This feature is definitely
necessary for live performance.
* Also two or three additional inputs with gain should be provided. The
inputs should be selectable for AC/DC coupling.
* There should be the possibility to hardwire the inputs and the output
multiples to the corresponding 'main'-module.
Regards, Florian
2006-05-06 by Tim J
Ok, this is pretty far out but bare with me....
Imagine a keyboard that had zero key travel...and was pressure and velocity
sensitive....call it a 'touch keyboard' if you will. This 'keyboard' could
also have sequencer type functions or since it would be incorporated into a
modular environment be used to trigger various sorts of events.
Just a thought.
>ok list,
Hi bakis
> nice idea! before i make a new poll, please, could you
> explain a bit more what the possible applications of
> such a module would be?
basically the idea for this module comes from building modular patches
from the scratch while a live performance. You will want to add more and
more modules to the audio signal path.
If you have a system with a lot of audiomixers and muliples (e.g. the
Roland 100m), this is no problem.
With the A100 this requires everytime to break up the signal path, which
is close to "stop your musical performance". Similar is valid for adding
additional control voltages to a module, which provides only one
adjustable CV input.
The idea of my module is to extend modules like all the VCFs or similar
(VC-Phasers, BBDs, Waveshapers...) with additional audio inputs,
additional CV-inputs and additional outputs.
Additionally to this simple extension, came the thought, that it is not
so easy to crossfade from one source to another with two normal mixer
inputs - a real crossfader is much better.
If you hardwire the summing points of the mixers to the corresponding
main module you even do not need any active elements or powersupply.
I will try to make a sketch drawing of a (block) diagram and a potential
frontplate draft.
Florian
2006-05-07 by Bakis Sirros
hello david,
nice one with the smokeless ashtray module...(how many
cigarettes should it hold, 2, 4, 6, 8, 10?) :-)
i assume that your "VC police scanner module" is a
joke too, right?
regards,
Bakis.
--- david rothbaum <david@davidrothbaum.com> wrote:
> 1)
> frequency ranges
> step through the
> signal could be
> by gate signals.
> bank of 100
> 2)
> idea to the plan b
> list a while back)
> 360 degree panning.
> would be good to
> as discrete
> 3)
> are not allowed to
> anyone knowing...
> --david
> > ok list,
> A100
> weeks
> > i am waiting...
> > best regards,
> > Bakis.
> > Athens-Greece
> > Do You Yahoo!?
> protection around
Athens-Greece
Do You Yahoo!?
2006-05-07 by bty205236
How about an analogue-digital/digital analogue converter module which
in between the two stages makes each bit (i.e. 1s, 2s, 4s, 8s etc)
available for patching on the front panel. This could open up
possibilities for bit swapping (as seen on the frostwave sonic
alienator) use with the A-166 dual logic module and loads of circuit
bending type madness...? should probably include a limiter in it as
well...
> ok list,
> i am waiting...
> best regards,
> Bakis.
> Athens-Greece
> Do You Yahoo!?
2006-05-07 by Julian
vc compressor module (anyone got a patch for this with the current modules?)
more vc (must be as vc as possible) digital modules (did anything ever
become of the bit depth reducer?)
julian
hello florian,
regards,
Bakis.
--- florian anwander <Florian.Anwander@consol.de>
wrote:
> Hello Bakis,
> addon module:
> modules.
> (real logarithmic
> Regards, Florian
Athens-Greece
Do You Yahoo!?
hello julian,
i think that the bit cruncher module is one of the
future a100 modules.
anything more specific regarding your VC digital
modules ideas?
regards,
Bakis
> A100
> (did anything ever
> julian
Athens-Greece
Do You Yahoo!?
2006-05-07 by Michael O.
I would like to see an expanded version of A-185 (Bus Access). It
should be able to output cv/gate to more busboards than one, and also
have a switch to which of the connected boards that will be used.
(Either one or all) I have a large custom case with a total of 4
busboards, with 2 powersources feeding 2 each. -At least 2 outputs are
needed. (I don't want to buy a lot of A-185's)
I have 3 cases in total, 2 of them are homemade. (3rd is original
Doepfer 6HE 19") I guess I don't need one in all of them, but it would
come in handy one day if I wanted to combine all VCO's and ADSR's (Got
5 VCO and 4 ADSR)
It could also have a larger multiple with active connections to prevent
signal loss, either independent of the cv/gate or in combination.
(Simply put: to distribute a signal, either audio or cv to multiple
targets) Sorry if you get confused.. :)
/Michael
hello,
that sounds very interesting!
let me see if i understand what you are thinking:
a new module with an analogue to digital converter,
with analogue cv/audio inputs that accept the input
analogue signals. then the module converts these to
digital logic signals(gates from 0 to 5 volts). if we
say that in this new module will be an 8-bit
converter. (does that means that the A to D converter
changes the analogue input to various combinations of
8 bit's-meaning combinations of 0 and 1's / on and off
gates?) then we could have each of the 8 bits as
digital outputs(0-5volts gate outputs) in the module's
front panel and the user could send these 8 digital
outputs to various processing modules like the a166 or
the a162 gate delay or even the a137, or...... then
the processed 8 bits could then be patched again via
digital front panel minijack inputs to this new module
and be converted by its onboard D to A conveter to
analogue signals(cv's and audio)?
could this be done? dieter/florian?
it sounds like a great idea!
so, this could be an analogue/digital hubrid module
that would offer the "digitized" sound for processing
with the a100 modules(via digital minijack outputs on
the front panel). then it would take the processed
digitized bits(via its front panel digital minijack
inputs) and reconvert them to analogue signals(audio
and cv). right?
i am waiting for your opinion, dieter and florian, in
order for me to create a new poll about that module
too(if it could be created...).
regards,
Bakis.
> 2s, 4s, 8s etc)
> could open up
> frostwave sonic
> loads of circuit
> limiter in it as
> well...
> > ok list,
> A100
> weeks
> > i am waiting...
> > best regards,
> > Bakis.
> > Athens-Greece
> > Do You Yahoo!?
> protection around
Athens-Greece
Do You Yahoo!?
re processing of digital signals with existing modules...
Id imagine the resolution to be an issue? What is the maximum speed (kHz
rating) of the modules in question? Normally we deal with, what, about 20
somthing k max...
Or have i got it totally wrong?
Julian
2006-05-07 by Zoran Bosnjak
My vote goes for resonant equalizer. I have one Gemini DJ mixer at home
(ugly green thing), and it does wonders on middle frequency enhancement - I
assume resonant equalizer would sound even better (never heard one though).
Zoran
>From: Bakis Sirros <synth_freak_2000@yahoo.com>
>Reply-To: Doepfer_a100@yahoogroups.com
>To: Doepfer_a100 group <doepfer_a100@yahoogroups.com>
>Subject: [Doepfer_a100] any more ideas for exotic future A100 modules?
>Date: Sat, 6 May 2006 02:47:26 -0700 (PDT)
>ok list,
>i am waiting...
>best regards,
>Bakis.
>Athens-Greece
>Do You Yahoo!?
hello florian,
yes, please, make a sketch and potential frontplate.
regards,
Bakis.
wrote:
> Hi bakis
> you
> of
> muliples (e.g. the
> is valid for adding
> provides only one
> the VCFs or similar
> audio inputs,
> two normal mixer
> the corresponding
> or powersupply.
> frontplate draft.
> Florian
Athens-Greece
Do You Yahoo!?
hello zoran,
more details, please, in order to understand it and
make a poll for this module?
regards,
Bakis.
> Regards,
> Zoran
> >ok list,
> A100
> weeks
> >i am waiting...
> >best regards,
> >Bakis.
> >Athens-Greece
> >Do You Yahoo!?
> protection around
Athens-Greece
Do You Yahoo!?
2006-05-07 by untiedstates
VC police scanner would be funny... but...
what about a radio noise source? For this the signal reception
doesn't need to be good.. so no external antenna, but maybe a socket
for one if wanted. Manual & VC controlled radio frequency select.
AM/FM bands.
It could be like the A-118 with a random CV derived from the radio
noise signal. Yes, what I'm talking about is utilizing the "static"
that you get when a radio is dialed in between stations as the noise.
Of course radio stations would be available too if you wanted to add
an antenna to strengthen the signal.
It could be called "Radioactivity" after the Kraftwerk album (an
album that I like a whole lot).
I'm serious.
--- In Doepfer_a100@yahoogroups.com, "david rothbaum" <david@...>
wrote:
> 1)
attenuated cv
ranges
Hi Bakis,
the resonant equalizer is one of the best Serge modules, at least according
to AH archives. I assume it is equivalent of a very good quality mixer eq.
You can read about the Serge one here:
http://www.serge-fans.com/wiz_filt.htm
IMPORTANT: I am NOT suggesting to clone Serge design here. I am not talking
about sounds-sculpting tool, as Serge one looks to be. I imagine much
simpler thing, with controls for hi, mid and low frequencies only. I simply
need good equalizer for my synth sequences, cause I create all these
beautful breathing sequences on MS-20, that could enormously benefit from
enhancing mid-range frequencies. One could say: how come you can't do that
on MS-20? Well, for some reason (and this happened more than once), the
richest sub-harmonic setting (smooth and velvety - sorry, I am not bragging,
that's simply what MS-20 version 2 is capable of) needs to have mid-range
frequencies cranked up. You go for the mids on MS-20, and you lose beauty
(the sound becomes somewhat harsh). Put my ugly Gemini DJ mixer into
equasion, by increasing mids, and the results are extremely pleasant.
Of course I can keep on using that Gemini mixer. Cause it is optimized for
dance music, I guess they set the eq's on it perfectly for my needs (funky
techno). But it would be cool to have good mixer strip on modular itself. I
have been hunting for decent old analog desk, but haven't had luck so far.
And the size factor is the problem. I guess I would rather have one module
instead of giant desk, that takes 1/3 of the valuable studio surface.
And that resonant attribute is certainly intriguing...
Zoran
>Subject: RE: [Doepfer_a100] any more ideas for exotic future A100 modules?
>Date: Sun, 7 May 2006 10:44:39 -0700 (PDT)
>hello zoran,
>regards,
>Bakis.
> > Regards,
> > Zoran
> > >ok list,
> > A100
> > weeks
> > >i am waiting...
> > >best regards,
> > >Bakis.
> > >Athens-Greece
> > >Do You Yahoo!?
> > protection around
>Athens-Greece
>Do You Yahoo!?
2006-05-08 by david rothbaum
Hi Bakis,
No actually, the police scanner was not a joke at all. I use a
(non-cv) version all the time with the synth. as both a source of
audio and a noise/cv source. lots of weird bleeps and blips etc. ham
radio, trnasmissions of the space shuttle and aircraft etc.
though i was serious i can't imagine a huge demand for such a module
and it would be absurdly expensive i think.
but yes was serious...
--david
> hello david,
> joke too, right?
> regards,
> Bakis.
> --- david rothbaum <david@...> wrote:
> > 1)
> > frequency ranges
> > step through the
> > signal could be
> > by gate signals.
> > bank of 100
> > 2)
> > idea to the plan b
> > list a while back)
> > 360 degree panning.
> > would be good to
> > as discrete
> > 3)
> > are not allowed to
> > anyone knowing...
> > --david
> > <synth_freak_2000@> wrote:
> > > ok list,
> > A100
> > weeks
> > > i am waiting...
> > > best regards,
> > > Bakis.
> > > Athens-Greece
> > > Do You Yahoo!?
> > protection around
> Athens-Greece
> Do You Yahoo!?
2006-05-08 by ph@comcast.net
do you just mean a parametric EQ?
maybe like the cwejman VCEQ-3?
http://www.analoguehaven.com/cwejman/vceq3/
best,
phil
2006-05-08 by selfoscillate
hello bakis,
with an a127 you can only add the filter outputs to the original,
but you cannot subtract them. also the a127 doesn't offer
voltage-control of filter width and filter output level.
best wishes
ingo
> hello,
> this seems to me like a three band bandpass filter,
> like the a127 VCRF?
> what's the point for such a module?
> regards,
> Bakis.
> > best,
> > phil
> Athens-Greece
> Do You Yahoo!?
2006-05-08 by ilanode
*If my memory serves me* Dieter mentioned 2 reasons: Such a module
would need an extensive shielding or will easily introduce unwanted
noise into the signal path. Intense regulations for radio
manufacturing would apply for a radio-synth-module make. Regards,
Ingo
> hello,
> i remember a while ago that dieter had explain why
> such a radio module would not be reasonable to make.
> dieter?
> regards,
> Bakis.
> > reception
> > but maybe a socket
> > frequency select.
> > AM/FM bands.
> > from the radio
> > you wanted to add
> > Kraftwerk album (an
> > I'm serious.
> > rothbaum" <david@>
> > wrote:
> > > 1)
> > function.
> > attenuated cv
> > for frequency
> > ranges
> > morphing filter or
> > the
> > step through the
> > signal could be
> > by gate signals.
> > a bank of 100
> Athens-Greece
> Do You Yahoo!?
2006-05-08 by Bakis Sirros
hello,
dieter?
regards,
Bakis.
> reception
> but maybe a socket
> frequency select.
> AM/FM bands.
> from the radio
> you wanted to add
> Kraftwerk album (an
> I'm serious.
> wrote:
> > 1)
> function.
> attenuated cv
> for frequency
> ranges
> morphing filter or
> the
> step through the
> signal could be
> by gate signals.
> a bank of 100
Athens-Greece
Do You Yahoo!?
hello,
like the a127 VCRF?
regards,
Bakis.
> best,
> phil
Athens-Greece
Do You Yahoo!?
hello david,
ok, i'll make a poll about that VC police scanner
module too and see what happens.
bakis
> Hi Bakis,
> all. I use a
> both a source of
> and blips etc. ham
> aircraft etc.
> for such a module
> --david
> > hello david,
> many
> > joke too, right?
> > regards,
> > Bakis.
> > > 1)
> for
> > > frequency ranges
> could
> > > step through the
> gate
> > > signal could be
> controlled
> > > by gate signals.
> say a
> > > bank of 100
> > > 2)
> this
> > > idea to the plan b
> > > list a while back)
> controlled
> > > 360 degree panning.
> it
> > > would be good to
> well
> > > as discrete
> > > 3)
> you
> > > are not allowed to
> > > anyone knowing...
> > > --david
> Sirros
> > > > ok list,
> exotic
> > > A100
> > > weeks
> > > > i am waiting...
> > > > best regards,
> > > > Bakis.
> > > > Athens-Greece
> > > > Do You Yahoo!?
> > > protection around
> > Athens-Greece
> > Do You Yahoo!?
> protection around
Athens-Greece
Do You Yahoo!?
to be honest, i'd like to see the already
announced modules (digital delay, tkb, sequencer,
pitch-to-voltage, sou3, bit cruncher etc...) finished
before we come up with more module ideas.
best wishes
ingo
> ok list,
> i am waiting...
> best regards,
> Bakis.
> Athens-Greece
> Do You Yahoo!?
2006-05-08 by bty205236
yup, you've got the idea of the thing (i apologise for my fairly
limited vocabulary when describing the idea... years of tv seem to
have taken their toll)! i've got to say, i think it would sound
absolutely crazy, (which is a good thing of course)... please please
please can you build me one?
> hello,
> and cv). right?
> regards,
> Bakis.
> > 2s, 4s, 8s etc)
> > could open up
> > frostwave sonic
> > loads of circuit
> > limiter in it as
> > well...
> > > ok list,
> > A100
> > weeks
> > > i am waiting...
> > > best regards,
> > > Bakis.
> > > Athens-Greece
> > > Do You Yahoo!?
> > protection around
> Athens-Greece
> Do You Yahoo!?
2006-05-08 by Florian Anwander
2006-05-08 by Dieter Doepfer
A voltage controlled bit modifier is in the development state (e.g. VC bit
cruncher/bit depth reducer, VC bit exchanger, VC digital wave multiplier ?,
VC digital waveshaper ...). Last week we received the smd adapter board that
contains all smd parts that will be used in the coming universal AD/DA
boards. Probably two types of modules will be designed at first: one without
memory (for "immediate" real-time calculations like bit cruncher, bit
exchanger, wave multiplier, wave shaper, ...) and another with a large
memory for applications like clocked audio delay, clocked CV delay, sampler,
digital sequencer ...
As we are at the beginning we are not yet sure which of the mentioned
functions will make sense (or will actually be possible with the hardware
used). I will keep you informed as soon as I have news.
This is the basic idea:
analog input #1 (mainly audio input, but even a slowly changing CV may be
applied) with attenuator
analog input #2 (CV control input, e.g. for bit cruncher depth, wave
shaping/wave multiplying depth) with manual offset and CV input with
attenuator
clock input (used only for clocked functions)
output (mainly audio output, but even a slowly changing CV appear)
controls (some buttons to select the desired function, maybe a LCD or LED
display)
Best wishes
Dieter Doepfer
> [mailto:Doepfer_a100@yahoogroups.com]Im Auftrag von Julian
> Gesendet: Sonntag, 7. Mai 2006 14:18
> Betreff: Re: [Doepfer_a100] any more ideas for exotic future A100
> modules?
> current modules?)
> julian
We had a radio module at the NAMM (for vocoder demo). It was nothing but a
0.99$ FM radio sticked on a A-100 blind panel and a special cable (3.5mm
stereo -> 2 x 3.5mm mono). Unfortunately it did not work in the basement at
the NAMM (this is why we removed the "module" again). Maybe we will have to
book a booth at first floor next year to demonstrate the "radio module" :-)
It is possible to modify the A-118 to use an external signal for the random
section (instead of the noise source). In combination with the new universal
vactrol module A-101-9 the random rate of the A-118 can even be voltage
controlled.
Best wishes
Dieter Doepfer
> [mailto:Doepfer_a100@yahoogroups.com]Im Auftrag von Bakis Sirros
> Gesendet: Montag, 8. Mai 2006 09:55
> Betreff: Re: [Doepfer_a100] Re: any more ideas for exotic future A100
> modules?
> hello,
> dieter?
> regards,
> Bakis.
> > reception
> > but maybe a socket
> > frequency select.
> > AM/FM bands.
> > from the radio
> > you wanted to add
> > Kraftwerk album (an
> > I'm serious.
> > wrote:
> > > 1)
> > function.
> > attenuated cv
> > for frequency
> > ranges
> > morphing filter or
> > the
> > step through the
> > signal could be
> > by gate signals.
> > a bank of 100
> Athens-Greece
> Do You Yahoo!?
Uuppps, somehow I erased all mailtext :-(
I made a draft for the frontplate and the schemo. You will find it in
the filesection as "Entwurf-Crossfader.jpg". The schemo does not contain
buffer amps, which are not required if the module is hardwaired with
another "main" module (like any vcf, phaser, bbd,...)
Florian
hello zoran,
these cwejman modules are brand-new, i don't think that these
are already shipping, but they should in a few weeks.
have you seen the price of the module? ok, the module
quality is very high, but more than 500 $ is quite expensive.
best wishes
ingo
--- In Doepfer_a100@yahoogroups.com, "Zoran Bosnjak" <dj_allin@...>
wrote:
> I have never seen this Cwejman module before, but that's it. In my
> description, I left out parametric and VC features, to make the
explanation
> simple, and the cost low. But that's exactly what I had on my mind.
> Fascinating - you think of something, and somebody made it already.
> Regards,
> Zoran
> >From: "ph@..." <ph@...>
> >To: "Doepfer_a100@yahoogroups.com" <Doepfer_a100@yahoogroups.com>
> >Subject: FW: [Doepfer_a100] Resonant EQ - reply for Bakis
> >Date: Sun, 07 May 2006 20:27:41 -0700
> >best,
> >phil
hello ingo,
yes, me too, but these will be only future modules
ideas... preliminary ideas for possible future
modules.
best regards,
Bakis.
> finished
> best wishes
> ingo
> > ok list,
> A100
> weeks
> > i am waiting...
> > best regards,
> > Bakis.
> > Athens-Greece
> > Do You Yahoo!?
> protection around
Athens-Greece
Do You Yahoo!?
--- In Doepfer_a100@yahoogroups.com, Florian Anwander
<Florian.Anwander@...> wrote:
> Hi ingo
> and by the way: I saw, that the cwejman EQ does not continuously add
or
> subtract the corresponding band asyou would expect it from a mixing
> console's EQ. You have to switch between add or subtract. So it is
> assumingly nothing else than a A127 plus inverters for the original
mix
> (incl. the switches 5 Euro of material).
> It should be a very simple addon package (one TL064, eight resistors,
> three switches) which would modify the A127.
> Florian
well, yes, and i guess you also need some vca's for
voltage-control of bandwidth and level per filter.
best wishes
ingo
Hi
Sorry, may be I am a stupid one, but: What the heck is a "police scanner"?
I know the police as a public institution for inner the monopole of lordship
I know a scanner as a gear, which converts pictures to image files, or
in a wider meaning as anything that searches for kind of signals.
What does the "police scanner" scan? Is it used by the police to scan
for some things (whatever thy may be), or do you scan the sourrounding
for police men? Sorry, but I just live in country where you do not fear
the police; so this would sound a littlebit ridiculous to me.
Florian
2006-05-08 by Zoran Bosnjak
description, I left out parametric and VC features, to make the explanation
Zoran
>From: "ph@comcast.net" <ph@comcast.net>
>best,
>phil
2006-05-08 by guido de zeeuw
I agree !
and don't put a memory-card in such a module.
> best wishes
> ingo
Yes, it is too pricey for me. I think I will mount my Gemini mixer above my
Doepfer racks, and call it my "Gemini dual equalizer with built-in power
supply" :-)
Zoran
>From: "selfoscillate" <synaptic_music@yahoo.com>
>Subject: Re: FW: [Doepfer_a100] Resonant EQ - reply for Bakis
>Date: Mon, 08 May 2006 12:21:24 -0000
>hello zoran,
>best wishes
>ingo
>explanation
> > Regards,
> > Zoran
> > >best,
> > >phil
Hi ingo
and by the way: I saw, that the cwejman EQ does not continuously add or
assumingly nothing else than a A127 plus inverters for the original mix
Florian
Hi Ingo
You are right (but nevertheless it wouldnt' be that expensive, that it
reaches $550).
Florian
2006-05-08 by Anton Coops
> or
> mix
> > Florian
Hello Florian, Ingo,
Sounds like a good idea for an a-127 expansion module to me!
I agree with Ingo that the ideas that are not yet finished should not
be forgotten, but at the same time it';s fun to think of new modules,
so I actually have several ideas (sorry :)
1. A second A-108, but this time arp-style
2. Equal Temperament Quantizer that does different ET's
3. Timbral Quantizer that can derive (dynamic, real time) scales
from timbres from vco-type modules, like a custom made sinus
bank, fm-operator, or a custom ring modulator.
4. (See 3.) Some oscillators or sound sources that would be
specially built to work togethjer with the timbral quantizer, so you
don't need to do Fourier analysis to derive a scale from a timbre, but
you can derive the spectral information you need from the settings
of the sound source using some (digital) mathematics.
5. expansion-module for both quantisers (maybe even for the a-156)
for creating custom scales and arpeggio's
I'll write down more about idea's 2-5 as soon as possible
Greetings
Anton
2006-05-08 by untiedstates
scale programmer
moog had one of these.. each key of a keyboard could be tuned
individually with a pot in order to achieve whatever tuning system you
wanted.
I know you could just use MIDI, etc.. but then with CV wouldn't you
have more precise tuning control? - no "stepping".
great! i was hoping this was the case...
> hello,
> i think that this function (scale
> programming-tuning/cv pots for each keyboard key) will
> be implemented into the TKS, right dieter?
> regards,
> Bakis.
> > scale programmer
> > be tuned
> > tuning system you
> > wanted.
> > CV wouldn't you
> Athens-Greece
> Do You Yahoo!?
hello anton,
i'll wait for your detailed explanation regarding your
future module suggestions before i make polls about
them.
regarding the ARP filter module: which ARP filter
should this module be modeled around?
regards,
Bakis.
> quite expensive.
> > or
> subtract. So it is
> > mix
> > > Florian
> for
> module to me!
> finished should not
> ET's
> time) scales
> made sinus
> would be
> quantizer, so you
> from a timbre, but
> from the settings
> mathematics.
> for the a-156)
> possible
> Greetings
> Anton
Athens-Greece
Do You Yahoo!?
no i cannot. but dieter maybe can do this! ;-)
regards,
Bakis.
> for my fairly
> of tv seem to
> would sound
> > hello,
> converter,
> input
> to
> we
> converter
> of
> off
> module's
> digital
> a166 or
> then
> via
> module
> module
> processing
> on
> minijack
> signals(audio
> > and cv). right?
> in
> module
> > regards,
> > Bakis.
> 1s,
> > > 2s, 4s, 8s etc)
> > > could open up
> > > frostwave sonic
> and
> > > loads of circuit
> a
> > > limiter in it as
> > > well...
> Sirros
> > > > ok list,
> exotic
> > > A100
> > > weeks
> > > > i am waiting...
> > > > best regards,
> > > > Bakis.
> > > > Athens-Greece
> > > > Do You Yahoo!?
> > > protection around
> > Athens-Greece
> > Do You Yahoo!?
> protection around
Athens-Greece
Do You Yahoo!?
2006-05-08 by matteus_rex
> ok list,
> i am waiting...
> best regards,
> Bakis.
I vote for anything ARP:ish, especially 2600 and the Odyssey.
Filters, osc, all of it. The best of the best...
Matteus
hello,
regards,
Bakis.
> scale programmer
> be tuned
> tuning system you
> wanted.
> CV wouldn't you
Athens-Greece
Do You Yahoo!?
2006-05-08 by Romeo Fahl
The 4012 gets my vote.
On May 8, 2006, at 10:42 AM, Bakis Sirros wrote:
> hello anton,
> them.
> regards,
> Bakis.
>> quite expensive.
>>> or
>> subtract. So it is
>>> mix
>>>> Florian
>> for
>> module to me!
>> finished should not
>> ET's
>> time) scales
>> made sinus
>> would be
>> quantizer, so you
>> from a timbre, but
>> from the settings
>> mathematics.
>> for the a-156)
>> possible
>> Greetings
>> Anton
> Athens-Greece
> Do You Yahoo!?
Hi Bakis,
You're right, this is very important, I was referring to the 'classic' Arp
filter that was used in the later Odysseys and the Axxe from 1975 or
so, and probably it should be *without* the design flaw that
originally cut off frequencies above 11 kHz.
Greetings
Anton
On 8 May 2006, at 10:42, Bakis Sirros wrote:
> hello anton,
> them.
> regards,
> Bakis.
> > quite expensive.
> > > or
> > subtract. So it is
> > > mix
> > > > Florian
> > for
> > module to me!
> > finished should not
> > ET's
> > time) scales
> > made sinus
> > would be
> > quantizer, so you
> > from a timbre, but
> > from the settings
> > mathematics.
> > for the a-156)
> > possible
> > Greetings
> > Anton
> Athens-Greece
> Do You Yahoo!?
No, as the "new" TKB has been reduced to the basic functions and the
"gimmicks" of the first prototype have been removed because of the many
different ideas. These additional features will be (hopefully) included in
the "keyboard" controller that is outlined on our web site (very
preliminary).
But this could be also a job for the AD/DA module as it is able to process
incoming analog voltages in real time. This example would require a look-up
table with the table containing the values for the output voltages in
relation to the input voltages (kind of "CV waveshaper" as it's nothing but
a waveshaper but not audio range but for slowly moving or fixed voltages).
The AD/DA module will be able to do a lot of jobs. The main problem will be
to find suitable controls (manual controls, attenuators, inputs, displays,
outputs) for all these applications.
But I'm sure you all will help us ...
Best wishes
Dieter Doepfer
> Gesendet: Montag, 8. Mai 2006 20:09
> modules?
> hello,
> regards,
> Bakis.
> > scale programmer
> > be tuned
> > tuning system you
> > wanted.
> > CV wouldn't you
> Athens-Greece
> Do You Yahoo!?
2006-05-08 by Michael O.
I wouldn't mind a filter like the 4012.. I got an ARP2600 with that
filter, and that's awesome! I have no other filter that's near that
one.. (And I have a few options to choose from)
/Michael
--- Anton Coops <dubshot@xs4all.nl> skrev:
Hi Bakis,
Arp
Greetings
Anton
> hello anton,
> them.
> regards,
> Bakis.
> > quite expensive.
> > > or
> > subtract. So it is
> > > mix
> > > > Florian
> > for
> > module to me!
> > finished should not
> > ET's
> > time) scales
> > made sinus
> > would be
> > quantizer, so you
> > from a timbre, but
> > from the settings
> > mathematics.
> > for the a-156)
> > possible
> > Greetings
> > Anton
> Athens-Greece
> Do You Yahoo!?
SPONSORED LINKS
Electronic air filter
A100
Midi converter
Modular system Module
YAHOO! GROUPS LINKS
Visit your group "Doepfer_a100" on the web.
Doepfer_a100-unsubscribe@yahoogroups.com
Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service.
hello michael, anton,
so, the "classic" ARP filter is the 4012?
regards,
Bakis.
> ARP2600 with that
> that's near that
> /Michael
> Hi Bakis,
> Arp
> Axxe from 1975 or
> flaw that
> Greetings
> Anton
> > hello anton,
> your
> about
> > them.
> > regards,
> > Bakis.
> is
> > > quite expensive.
> does
> > > > or
> or
> > > subtract. So it is
> > > > mix
> (one
> > > > > Florian
> vca's
> > > for
> filter.
> > > module to me!
> yet
> > > finished should not
> different
> > > ET's
> real
> > > time) scales
> custom
> > > made sinus
> that
> > > would be
> timbral
> > > quantizer, so you
> scale
> > > from a timbre, but
> > > from the settings
> > > mathematics.
> even
> > > for the a-156)
> > > possible
> > > Greetings
> > > Anton
> > Athens-Greece
> > Do You Yahoo!?
> protection around
> > Yahoo! Groups Links
> SPONSORED LINKS
> A100
> Midi converter
> Modular system
> Module
> YAHOO! GROUPS LINKS
> to:
> Yahoo! Terms of
> Service.
Athens-Greece
Do You Yahoo!?
2006-05-08 by Nick Hubben
i'll be devil's advocate: if we're talking ARP filters, why not go
all the way and give them SLIDERS!
some of you will hopefully agree that sliders/faders are far more
ergonomic and ultimately musical than knobs. when i was forming a
modular strategy awhile back, i went as far as calling Paul Schreiber/
MOTM and asking if he'd be interested in building me a filter box
with two sets of controls, knobs + sliders, that'd be switchable...
in essence having two sets of cutoff/Q controls and the ability to
switch between settings.
sounded pretty cool to me, Paul didn't agree. ARP's were the first
'pro' analog synths i had (2 Axxe's + a Quadra) and i'll always miss
being able to throw the sliders around.
yeah, i know good sliders/faders are expensive and get dirty and all
that good stuff.... that's why i decided to go Doepfer and wait for
my fantasy filter box. still, you gotta admit they're fun.
i love the 'exotic' module threads.. sorry i've nothing else to offer
at this time
cheers
nick
> /Michael
hello dieter,
yes, that's what i meant, the keyboard controller rack
module that will be connected with the normal cv/gate
keyboard or the touch plate keyboard. anyway, this
"scale" function will be included in this future
keyboard controller.
so, should i make a poll about a separate "scale
programmer" module, or not?
regards,
Bakis.
> functions and the
> because of the many
> web site (very
> preliminary).
> output voltages in
> Best wishes
> Dieter Doepfer
> von Bakis Sirros
> exotic future A100
> > modules?
> > hello,
> will
> > regards,
> > Bakis.
> > > scale programmer
> could
> > > be tuned
> whatever
> > > tuning system you
> > > wanted.
> with
> > > CV wouldn't you
> "stepping".
> > Athens-Greece
> > Do You Yahoo!?
> protection around
> > Yahoo! Groups Links
Athens-Greece
Do You Yahoo!?
2006-05-08 by Adam-V
scanner"?
of lordship
files, or
scan
sourrounding
fear
> Florian
Not such a stupid question Florian.
"scanner" in this instance refers to a radio scanner that allows you
to listen in on radio broadcasts outside the normal commercial
broadcast range. This includes police radio transmissions, aircraft
transmissions etc.
Adam-V
The 4012 was probably the best known. Other ARP classic VCFs are the
4035 and 4072/4075. There's schematics and info at:
http://www.till.com/arptech/modmain.htm
> regards,
> Bakis.
>> ARP2600 with that
>> that's near that
>> /Michael
>> Hi Bakis,
>> Arp
>> Axxe from 1975 or
>> flaw that
>> Greetings
>> Anton
>>> hello anton,
>> your
>> about
>>> them.
>>> regards,
>>> Bakis.
>> is
>>>> quite expensive.
>> does
>>>>> or
>> or
>>>> subtract. So it is
>>>>> mix
>> (one
>>>>>> Florian
>> vca's
>>>> for
>> filter.
>>>> module to me!
>> yet
>>>> finished should not
>> different
>>>> ET's
>> real
>>>> time) scales
>> custom
>>>> made sinus
>> that
>>>> would be
>> timbral
>>>> quantizer, so you
>> scale
>>>> from a timbre, but
>>>> from the settings
>>>> mathematics.
>> even
>>>> for the a-156)
>>>> possible
>>>> Greetings
>>>> Anton
>>> Athens-Greece
>>> Do You Yahoo!?
>> protection around
>>> Yahoo! Groups Links
>> SPONSORED LINKS
>> A100
>> Midi converter
>> Modular system
>> Module
>> YAHOO! GROUPS LINKS
>> to:
>> Yahoo! Terms of
>> Service.
> Athens-Greece
> Do You Yahoo!?
2006-05-09 by Anton Coops
Hi Bakis,
Actually it's not....and I thought this was gonna be an easy one ;-)
The basic idea would be to use the A-108 as a 'template', but I think
we would have to vote seperately about the filter (sliders doesn't
seem a realistic option to me).
See also this site:
http://www.emulatorarchive.com/AM/AnalogArticles/ARPFilters/arpfilt
ers.html
The most popular choices are probably the 4012 and the 4072/75
By the way, I will also write down some details about a
scale/arpeggio module as soon as I have more time
Greetings
Anton
> regards,
> Bakis.
> > ARP2600 with that
> > that's near that
> > /Michael
> > Hi Bakis,
> > Arp
> > Axxe from 1975 or
> > flaw that
> > Greetings
> > Anton
> > > hello anton,
> > your
> > about
> > > them.
> > > regards,
> > > Bakis.
> > is
> > > > quite expensive.
> > does
> > > > > or
> > or
> > > > subtract. So it is
> > > > > mix
> > (one
> > > > > > Florian
> > vca's
> > > > for
> > filter.
> > > > module to me!
> > yet
> > > > finished should not
> > different
> > > > ET's
> > real
> > > > time) scales
> > custom
> > > > made sinus
> > that
> > > > would be
> > timbral
> > > > quantizer, so you
> > scale
> > > > from a timbre, but
> > > > from the settings
> > > > mathematics.
> > even
> > > > for the a-156)
> > > > possible
> > > > Greetings
> > > > Anton
> > > Athens-Greece
> > > Do You Yahoo!?
> > protection around
> > > Yahoo! Groups Links
> > SPONSORED LINKS
> > A100
> > Midi converter
> > Modular system
> > Module
> > YAHOO! GROUPS LINKS
> > to:
> > Yahoo! Terms of
> > Service.
> Athens-Greece
> Do You Yahoo!?
2006-05-09 by anatronn
the 4012 was a transistor ladder "moog" filter and doepfer already has
that (A-120) so go for the 24db (cascade of integrators) 4072 or 4075
(these two are almost identical)
/A
2006-05-09 by selfoscillate
well, i fully disagree.
sliders are a pain on a synthesizer.
but well, it's a matter of taste.
best wishes
ingo
2006-05-09 by Florian Anwander
Hi Nick,
I definitely do not agree. It is a well known fact, that sliders are far
less ergonomic. You can differ a lot more positions on rotary movements
than on straigt line formed movements (imagine a car with a fader for
steering instead a wheel - and imagine the increase of assurance rates
if every car had a steering fader ;-)).
Sliders may have the advantage of a fast access and a high visuality of
the selected value, but they are very bad in the detailing of settings.
Florian
Hi Adam
> transmissions etc.
Ok, a simple radio receiver.
Florian
2006-05-09 by Dieter Doepfer
It will be a problem to re-built the 4012 ARP filter as many of the parts
used in this filter (similar to the Moog transistor ladder but with special
dual FETs and dual transistors that are no longer available). One could use
other dual FETs and dual transistors (or even single FETs and transistors)
but it would not be the same.
Best wishes
Dieter Doepfer
> [mailto:Doepfer_a100@yahoogroups.com]Im Auftrag von Michael O.
> Gesendet: Montag, 8. Mai 2006 23:50
> Betreff: SV: [Doepfer_a100] Arp module suggestion
> /Michael
> Hi Bakis,
> Arp
> Greetings
> Anton
> > hello anton,
> > them.
> > regards,
> > Bakis.
> > > quite expensive.
> > > > or
> > > subtract. So it is
> > > > mix
> > > > > Florian
> > > for
> > > module to me!
> > > finished should not
> > > ET's
> > > time) scales
> > > made sinus
> > > would be
> > > quantizer, so you
> > > from a timbre, but
> > > from the settings
> > > mathematics.
> > > for the a-156)
> > > possible
> > > Greetings
> > > Anton
> > Athens-Greece
> > Do You Yahoo!?
> > Yahoo! Groups Links
> SPONSORED LINKS
> A100
> Midi converter
> YAHOO! GROUPS LINKS
> Service.
2006-05-09 by fabio delben
A string filter like moog.
Fabio Delben
Bakis Sirros <synth_freak_2000@yahoo.com> ha scritto:
ok list,
i am waiting...
best regards,
Bakis.
Athens-Greece
Do You Yahoo!?
SPONSORED LINKS
A100 Modular system Electronic payment Electronic test equipment Guitar synthesizer Voice synthesizer
YAHOO! GROUPS LINKS
Yahoo! Mail: gratis 1GB per i messaggi, antispam, antivirus, POP3
Chiacchiera con i tuoi amici in tempo reale!
http://it.yahoo.com/mail_it/foot/*http://it.messenger.yahoo.com
2006-05-09 by Bakis Sirros
hello fabio,
what's this?
details please.
regards,
Bakis.
> Fabio Delben
> scritto:
> ok list,
> A100
> i am waiting...
> best regards,
> Bakis.
> Athens-Greece
> Do You Yahoo!?
> protection around
> SPONSORED LINKS
> Voice synthesizer
> YAHOO! GROUPS LINKS
> to:
> antivirus, POP3
> removed]
Athens-Greece
Do You Yahoo!?
> i must say, i've always appreciated the openness to crazy opinions
on
> this board versus AH... danke.
you're very welcome :-)
> saving money for another portable cabinet,
thats never a bad thing :-)
best wishes
ingo
It was a particular resonant equalizer for strings simulation. The moog rack series like phaser and the parametric equalizer. Pretty rare.
Ciao
Fabio Delben
hello fabio,
what's this?
details please.
regards,
Bakis.
> Fabio Delben
> scritto:
> ok list,
> A100
> i am waiting...
> best regards,
> Bakis.
> Athens-Greece
> Do You Yahoo!?
> protection around
> SPONSORED LINKS
> Voice synthesizer
> YAHOO! GROUPS LINKS
> to:
> antivirus, POP3
> removed]
Athens-Greece
Do You Yahoo!?
SPONSORED LINKS
Electronic air filter A100 Midi converter Modular system Module
YAHOO! GROUPS LINKS
Yahoo! Messenger with Voice: chiama da PC a telefono a tariffe esclusive
sounds good :-)
--- In Doepfer_a100@yahoogroups.com, "Dieter Doepfer" <hardware@...>
wrote:
> An intermediate solution for DIYs would be to wire the address
A0/A1/A2
> outputs of the A-154 and the "old" A-155 controller unit to jack
sockets as
> well as the address inputs of the A-155. It's only mechanics and
some wiring
> (P.S. we offer unprinted but punched A-180 4HP front panels since 2
weeks
> for such applications in addition to the unprinted/punched standard
8HP
> panels). Adding protection resistors (~ 1k) to avoid short circuit
problems
> at the address outputs will be a good idea.
> In this way you are able to control the A-155 from the address
source you
> want.
> If there are sufficient inquiries we could manufacture such passive
adapter
> modules that make the address in- and outputs available at jack
sockets.
> Best wishes
> Dieter Doepfer
> > [mailto:Doepfer_a100@yahoogroups.com]Im Auftrag von Florian
Anwander
> > Gesendet: Dienstag, 9. Mai 2006 16:13
> > modules?-> Modular Sequencing System
> > Hi
> > I think the A154/155 is great, but I'd like to have it more
modular.
> > * Clock controlled address counter (= masterclock)
> > * CV adress generators (this might be the module Andrew Maunder
was
> > thinking about when asking for editable digital signals)
> > * Possibilities to modify address busses on digital level
(partially
> > with already existing digital modules could be used)
> > * 16 step switch row scanner (=trigger sequencer) with 4bit
adress input
> > and option for stacking. Should work bidirectional (one input is
> > distributed via address to 16 outputs anc vice versa).
> > * 16 step potentiometer row scanner (=CV sequencer), all features
as the
> > switch scanner.
> > * Interfaces for the existing A155 and A154.
> > * optional relais interface or MIDI-Out-Interface (Dieter could
use
> > parts from the OEM series).
> > More Ideas to come...
> > Yahoo! Groups Links
Hi
I think the A154/155 is great, but I'd like to have it more modular.
* CV adress generators (this might be the module Andrew Maunder was
* Possibilities to modify address busses on digital level (partially
* 16 step switch row scanner (=trigger sequencer) with 4bit adress input
* 16 step potentiometer row scanner (=CV sequencer), all features as the
switch scanner.
* optional relais interface or MIDI-Out-Interface (Dieter could use
2006-05-09 by Nick Hubben
gents
i certainly see your points - i do feel a lot more akin to on-the-fly
performance style with my synths, i'm not sure i've ever written down
a setting in my life. i developed mild tendonitis years back from
working with rack-mount samplers and mixers, so i think working with
the sliders on ARP's was always a relief - and i've always had more
fun with them live then any other synth.
i must say, i've always appreciated the openness to crazy opinions on
Nick
On May 9, 2006, at 3:45 AM, Florian Anwander wrote:
> Hi Nick,
> are far
> movements
> visuality of
> settings.
> Florian
> ------------------------ Yahoo! Groups Sponsor --------------------
> Everything you need is one click away. Make Yahoo! your home page
> now.
> http://us.click.yahoo.com/AHchtC/4FxNAA/yQLSAA/QnLolB/TM
I'd like to have a DIN-Sync to trigger interface. Just a simple thing:
- An incoming DIN-Sync should be given as seperate signals on 3,5mm sockets
- The DIN-Sync Start/Stop Gate-signal should be given additionally as
separate Start and Stop triggers (required for A-155).
- The DIN-Sync clock should be available also diveded to selectable
clock rates (1/1, 1/2, 1/3, 1/4, 1/6, 1/8, 1/12, 1/16, ...) in
rhythmical usable relations[*]! Perhaps also pseudo-shuffled (for 1/12:
1,3,4,6,7,9,10,12, for 1/16: 1,4,5,8,9,12,13,16)
- counter controlled slave-start/stop action. This is a feature I
learned to know with the mungo enterprises sync2 (see
http://home.netspeed.com.au/aistorm/sync2.html): an internal counter
remembers which clock is the first beat of a bar. If you hit the stop
button, the clock will go on until the next bar and stop to the first
hit of the next bar. If you then hit the start button the feature will
wait until the next bar and start then. (I have to admit, that I don't
know how I could live without this feature the last thirty years. ;-))
- I wouldn't mind if this module also had MIDI-In
Florian
[*] Pay attention: the A-162 does NOT provide this, because the rising
edges of the different divider outs are not synced to the first clock
in, but to the second rising edge of the logical stage above.
An intermediate solution for DIYs would be to wire the address A0/A1/A2
outputs of the A-154 and the "old" A-155 controller unit to jack sockets as
well as the address inputs of the A-155. It's only mechanics and some wiring
(P.S. we offer unprinted but punched A-180 4HP front panels since 2 weeks
for such applications in addition to the unprinted/punched standard 8HP
panels). Adding protection resistors (~ 1k) to avoid short circuit problems
In this way you are able to control the A-155 from the address source you
want.
If there are sufficient inquiries we could manufacture such passive adapter
modules that make the address in- and outputs available at jack sockets.
Best wishes
Dieter Doepfer
> [mailto:Doepfer_a100@yahoogroups.com]Im Auftrag von Florian Anwander
> Hi
> switch scanner.
Hi Nick
Me too. I never write down a setting. But sometimes the decision whether
a sound is lush f*rt in the wind or a million seller hit ;-) depends on
a decaytime of some nanoseconds faster than my actual setting. With
slider based synths like the Roland 100m or a ARP Odyssee (I never had
an 2600 for longer time) I never could reach this point of perfect sound
- or better: Either I had reached it occasionally or I would never reach
it. In the opposite a Minimoog (which of course has to be in perfect
shape) whose rotary knobs allow you exactly this required minimal
changes of sounds which make it.
Wait until the day that you recognize the vans with the black windows in
front of your door. ;-)
Florian
2006-05-09 by unknown freak
Yup, I agree completely. I find sliders ill-suited to very fine
adjustments.
--Chuck
_____
From: Doepfer_a100@yahoogroups.com [mailto:Doepfer_a100@yahoogroups.com] On
Behalf Of Florian Anwander
Sent: Tuesday, May 09, 2006 11:15 AM
Subject: Re: [Doepfer_a100] Arp module : SLIDERS!
Hi Nick
Florian
SPONSORED LINKS
Electronic
<http://groups.yahoo.com/gads?t=ms&k=Electronic+air+filter&w1=Electronic+air
+filter&w2=A100&w3=Midi+converter&w4=Modular+system&w5=Module&c=5&s=89&.sig=
4z4o_X8-pJMV_ZkWpcUzfQ> air filter
A100
<http://groups.yahoo.com/gads?t=ms&k=A100&w1=Electronic+air+filter&w2=A100&w
3=Midi+converter&w4=Modular+system&w5=Module&c=5&s=89&.sig=vkZk9oMwSYA6JVt7j
MKACg>
Midi
<http://groups.yahoo.com/gads?t=ms&k=Midi+converter&w1=Electronic+air+filter
&w2=A100&w3=Midi+converter&w4=Modular+system&w5=Module&c=5&s=89&.sig=8wIjtHr
gvO_CLHjOsXjwXA> converter
Modular
<http://groups.yahoo.com/gads?t=ms&k=Modular+system&w1=Electronic+air+filter
&w2=A100&w3=Midi+converter&w4=Modular+system&w5=Module&c=5&s=89&.sig=k_-XvCu
WrHEHytqPA5h6eQ> system
Module
<http://groups.yahoo.com/gads?t=ms&k=Module&w1=Electronic+air+filter&w2=A100
&w3=Midi+converter&w4=Modular+system&w5=Module&c=5&s=89&.sig=wsqwVmN_jTYb6sP
VmjGuHg>
_____
YAHOO! GROUPS LINKS
* Visit your group "Doepfer_a100
<http://groups.yahoo.com/group/Doepfer_a100> " on the web.
* To unsubscribe from this group, send an email to:
<mailto:Doepfer_a100-unsubscribe@yahoogroups.com?subject=Unsubscribe>
* Your use of Yahoo! Groups is subject to the Yahoo!
<http://docs.yahoo.com/info/terms/> Terms of Service.
_____
probably because this board has a crazy moderator?
regards,
Bakis
--- Nick Hubben <nick@prod4ever.com> wrote:
> gents
> akin to on-the-fly
> ever written down
> years back from
> think working with
> always had more
> crazy opinions on
> Nick
> > Hi Nick,
> filters, why not go
> fact, that sliders
> > are far
> positions on rotary
> > movements
> and a high
> > visuality of
> detailing of
> > settings.
> > Florian
> > now.
> > Yahoo! Groups Links
Athens-Greece
Do You Yahoo!?
2006-05-09 by Brandon Daniel
Maybe, though the 4012 in my 2600 always sounded quite different than the
filter in my mini.
-Brandon
2006-05-09 by Zoran Bosnjak
I think that Modcan has very good-sounding Arp 4075 filter already. Regards,
http://www.modcan.com/bseries/modulesb.html
Than click on 4075 LPF 36B.
Zoran
>From: Brandon Daniel <bdu@fdiskc.com>
>Subject: Re: SV: [Doepfer_a100] Arp module suggestion
>Date: Tue, 9 May 2006 11:59:20 -0700 (PDT)
>filter in my mini.
>-Brandon
2006-05-10 by sfrules
My 2 centimes...
In addition to my previous wishes for a more discriminating quantizer
similar to what Anton has suggested, and my spike and ripple module...
One synth that I have always lusted after was the RMI Harmonic
Synthesizer.
http://www.jarrography.free.fr/details_equipement_audio.php?id_equip=7
It had a keyboard and 2 oscillators, but what made it unique was that
for each oscillator
you had separate sliders for the FUNDAMENTAL and 16 OVERTONES!
I am not a great fan of sliders-I would prefer knobs.
2 ins 1 out. 17 potentiometers. It would probably fit into 20hp.
I think a single VCO with this capability for additive synthesis
would be
unique and highly marketable.
...and to coin a phrase: I'll take two!!!
sfrules
2006-05-10 by Bakis Sirros
hello dieter,
that would be great to offer such simple and usefull
modules.
regards,
Bakis.
> want.
> Best wishes
> Dieter Doepfer
> exotic future A100
> > Hi
> Andrew Maunder was
> signals)
> used)
> (one input is
> versa).
> > switch scanner.
> (Dieter could use
> > Yahoo! Groups Links
> You can search right from your browser? It's easy
> and it's free. See how.
http://us.click.yahoo.com/_7bhrC/NGxNAA/yQLSAA/QnLolB/TM
Athens-Greece
Do You Yahoo!?
hello,
just try the excellent rs370/rs375 from AS.
this is such a module. you have a digital osc with 32
partials of which the 16 of them are controlable by 16
knobs plus 16 cv inputs! plus many many other
features.
btw, i would not find of course if doepfer would want
to make an additive osc too, as it would have
different features i guess! :-)
regards,
Bakis.
--- sfrules <sfrules@together.net> wrote:
> My 2 centimes...
> RMI Harmonic
> Synthesizer.
> it unique was that
> for each oscillator
> OVERTONES!
> knobs.
> fit into 20hp.
> additive synthesis
> would be
> sfrules
Athens-Greece
Do You Yahoo!?
Hi, Dudes
rs370/rs375?
Looks like a wonderful module, but it is too polyphonic, too complex,
too big, and too pricey!!
Give me mastery over ONE note and I will be happy! I am not really
sure you need
to have 32 overtones. Unless you are playing infra-bass, the last
dozen or so would be
performing for bats and other small undesirable species, nicht var?
<signed>
poor johnny one-note
hello,
no. additive synths have up to 128 harmonics for each
voice.
having more harmonics gives you much more control over
the sound's timbre.
so, at least for me, it would be usefull to have at
least 32 harmonics for an additive machine/module.
regards,
Bakis.
> Hi, Dudes
> rs370/rs375?
> I am not really
> sure you need
> species, nicht var?
> <signed>
Athens-Greece
Do You Yahoo!?
2006-05-10 by threeseatmoon
Hi everone,
How about a digital envelope generator/modulation source
allowing you to save patches/mixtures for live recall. Possibly
offering different multistage (2/4/6/8) envelopes, 1/2 voltage
control ins assignable to functions (rather than one per),optionally
L.F.O., noise, sample and hold,random ect ,as a single or multiple
module, maybe even with midi patch recall. (with slewed/filtered outs
to avoid steping).
<synth_freak_2000@...> wrote:Show quoted textHide quoted text
> ok list,
> i am waiting...
> best regards,
> Bakis.
> Athens-Greece
> Do You Yahoo!?
Bakis!
I stand, er, sit corrected!
many thanks,
sfrules
2006-05-11 by Florian Anwander
Hi threeseatmoon
> allowing you to save patches/mixtures for live recall.[..andotherstufffromdigital...]
I do own such a piece: the HARMS MAC-16 MIDI-CV Interface. But I found
out, that one doesn't use this feature, simply because you do not mixup
the way of access to an instrument. If you have a modular synth with
knobs and cables, you don't want to jump over to a handling like editing
the Yamaha DX7.
And also regard economy: It would be quite expensive to develope such a
unit. The MAC 16 costed 10 years ago around 1400 Deutschmarks, which is
equivalent to a todays price of 1000 Euro. Hey, for 1000 Euro you get an
fully polyphonic nord modular on the used market or any new VA-synth.
Finally the nord modular is the solution I have chosen for programmable
modular synthesizing.
Florian
2006-05-11 by Bakis Sirros
hello fabio,
i have already created a poll about a resonant EQ
module. would it make sense to create another poll for
a specialized string simulation resonant EQ module?
won't the proposed "general" resonant EQ module be
able to make this string simulation that you're
talking about?
regards,
Bakis.
> Ciao
> Fabio Delben
> scritto:
> hello fabio,
> what's this?
> details please.
> regards,
> Bakis.
> > Fabio Delben
> > scritto:
> > ok list,
> > A100
> weeks
> > i am waiting...
> > best regards,
> > Bakis.
> > Athens-Greece
> > Do You Yahoo!?
> > protection around
> > SPONSORED LINKS
> > Voice synthesizer
> > YAHOO! GROUPS LINKS
> > to:
> > antivirus, POP3
> > removed]
> Athens-Greece
> Do You Yahoo!?
> protection around
> SPONSORED LINKS
> YAHOO! GROUPS LINKS
> to:
> a tariffe esclusive
> removed]
Athens-Greece
Do You Yahoo!?
hello florian, dieter,
so, taking into account the recent email from dieter
telling how he could make an expansion module to brign
the a0,a1,a2,a3 addresses of the a154 and a155 clock
to the front panel, should i, or should i not, create
a new poll about a modular sequencer?
regards,
Bakis.
--- Florian Anwander <Florian.Anwander@consol.de>
wrote:
> Hi
> it more modular.
> Andrew Maunder was
> signals)
> level (partially
> (one input is
> versa).
> all features as the
> switch scanner.
> (Dieter could use
Athens-Greece
Do You Yahoo!?
2006-05-12 by Florian Anwander
Hi Bakis,
I am in developping a sketch for such a system, which would extend the
A-154/5. So lets wait until I finished it and lets do the poll then later.
Florian
> regards,
> Bakis.
> wrote:
>>Hi
>>it more modular.
>>Andrew Maunder was
>>signals)
>>level (partially
>>(one input is
>>versa).
>>all features as the
>>switch scanner.
>>(Dieter could use
> Athens-Greece
> Do You Yahoo!?
Florian Anwander |ConSol
Tel. +49(89)45841-133 |Consulting&Solutions Software GmbH
Fax +49(89)45841-111 |Franziskanerstr. 38, D-81669 München
email: florian.anwander@consol.de |http://www.consol.de
2006-05-12 by Dieter Doepfer
> regards,
> Bakis.
For the moment I'd recommend a poll concerning an additional front panel
that makes available the address and clock in/outputs of A-154 and A-155 as
this could be realized within a short time provided that there are
sufficient inquiries (because of the initial charges for the pcb and front
panel). Another solution would be a corresponding note on the DIY page if
there are not sufficient inquiries. It's no electronic but only mechanics
(drilling holes into blind panels, screwing sockets to the holes) and wiring
the sockets to the ribbon cables that are normally used to connect A-154 and
A-155.
Best wishes
Dieter Doepfer
P.S. We added a note on the DIY page how to modify the Wasp filter A-124 for
self-oscillation.
One could try the combination of A-127 and a polarizing mixer A-138c to
emulate an equalizer:
Audio Source -> A-127 Audio In and Input #1 of A-138c
A-127 Audio Out #1 -> Input #2 of A-138c
A-127 Audio Out #2 -> Input #3 of A-138c
A-127 Audio Out #3 -> Input #4 of A-138c
Input #1 of A-138c is used to control the original share of the signal.
Inputs #2...4 are used to add or subtract the filter shares to the original
signal.
From the theory it should work but maybe the phase relations between audio
in and out of the A-127 thwart the plan (with the VC polarizer A-133 even a
voltage controlled version could be realized). Sorry I have no time to try
this out within the next few days (the A-101-9 manual has to be written,
especially the examples have to be tested and written down). If it works we
could think about a revision of the A-127 with polarizers instead of the
normal attenuators (the controls labelled "Audio Level"). Last week we
received new A-100 potentiometer samples with center tap and center click
position for such applications (they work like two separate potentiometer
for left and right half of the rotation angle).
Best wishes
Dieter Doepfer
Doepfer Musikelektronik GmbH
Email address: hardware@doepfer.de
Web Site: www.doepfer.com
> Gesendet: Donnerstag, 11. Mai 2006 23:40
> modules?
> hello fabio,
> talking about?
> regards,
> Bakis.
2006-05-12 by Bakis Sirros
hello florian,
ok, great.
regards,
Bakis.
wrote:
> Hi Bakis,
> Florian
> dieter
> brign
> clock
> create
> > regards,
> > Bakis.
> > wrote:
> >>Hi
> have
> >>it more modular.
> >>Andrew Maunder was
> >>signals)
> digital
> >>level (partially
> used)
> >>(one input is
> >>versa).
> sequencer),
> >>all features as the
> >>switch scanner.
> >>(Dieter could use
> > Athens-Greece
> > Do You Yahoo!?
> protection around
> > Yahoo! Groups Links
> 38, D-81669 München
Athens-Greece
Do You Yahoo!?
hello dieter,
ok, i'll wait for florian's sketch and then make a
poll.
best regards,
Bakis.
> dieter
> brign
> clock
> create
> > regards,
> > Bakis.
> that there are
> A-155.
> Best wishes
> Dieter Doepfer
> self-oscillation.
Athens-Greece
Do You Yahoo!?
2006-05-15 by Bakis Sirros
hello dieter,
so, this would be a poll about an "expansion" module
that would bring the a0,a1,a2 addresses of the a155 to
the front panel as inputs and the a0,a1,a2 addresses
of the a155 clock and a154 clock as outputs?(does this
ssentence makes sense? i am not an electronics
engineer)
please confirm.
best regards,
Bakis.
> dieter
> brign
> clock
> create
> > regards,
> > Bakis.
> that there are
> A-155.
> Best wishes
> Dieter Doepfer
> self-oscillation.
Athens-Greece
Do You Yahoo!?
2006-05-16 by sfrules
Hi, chilluns!
This idea is simple, cheap, and desperately needed:
A switch trigger In and Out Conversion module for interface with
Moog equipment. Appropriate Cinch-Jones jacks would be
nice, too.
The A-165 Trigger Modifier won't do it.
Someone mentioned a simple, but untested,
modification that would do it.
Some months ago I sent my A-165 back to my dealer, who sent it
to Dieter & Co for the circuit mod.
Still waiting...
sfrules
2006-05-16 by vogelscheiss
You can convert an S-trig in with the A166 dual logic module, whose
inverters apparently are different from the A175 inverters.
--Chuck
_____
Behalf Of sfrules
Sent: Monday, May 15, 2006 10:11 PM
Subject: [Doepfer_a100] Any more ideas for exotic future A100 modules?
Hi, chilluns!
nice, too.
Still waiting...
sfrules
_____
YAHOO! GROUPS LINKS
_____
Thanks, Chuck!
In my ignorance I didn't even
consider the A-175! Just as well, eh?
But I can say I lusted after the A-166
not even realizing it might solve my problem.
Still, it would be a blessing to be able to
do it in 4 HP.
Thanks, again!
sfrules
2006-05-16 by Florian Anwander
Hi Bakis
Please do it at least 4 bit
Basically it should be every internally wired clock, address or trigger
connection offered as an normalled insert.
Florian
2006-05-16 by Dieter Doepfer
Yes, and maybe the address and clock signals of the "old" A-155 controller
that is used if the A-155 runs without A-154. The expansion module would
have these sockets available:
A0 In A-155
A1 In A-155
A2 In A-155
Clock In A-155
A0 Out A-154
A1 Out A-154
A2 Out A-154
Clock Out A-154
A0 Out A-155 (controller board of A-155)
A1 Out A-154 (controller board of A-155)
A2 Out A-154 (controller board of A-155)
Clock Out A-154 (controller board of A-155)
It's very simple to built this "module" as an DIY project (no electronics
necessary, only wiring of the sockets to certain terminals of the pc
boards).
Best wishes
Dieter Doepfer
> Gesendet: Montag, 15. Mai 2006 19:44
> Betreff: Re: AW: [Doepfer_a100] any more ideas for exotic future A100
> modules? -> Modular Sequencing System
> hello dieter,
> engineer)
> please confirm.
> best regards,
> Bakis.
> > dieter
> > brign
> > clock
> > create
> > > regards,
> > > Bakis.
> > that there are
> > A-155.
> > Best wishes
> > Dieter Doepfer
> > self-oscillation.
> Athens-Greece
> Do You Yahoo!?
sfrules,
we never received such a module for "modification". Who is your dealer and
are you sure that he has sent it?
It's nothing but a resistor and transistor as described on our FAQ pages
(www.doepfer.com > FAQ > Converting Gate to Switched Trigger. Maybe your
dealer can do this modification as the shipping charges will be a multiple
of the modification costs (a few cents only for the parts and a maybe 5-10
minutes of working time).
Best wishes
Dieter Doepfer
> [mailto:Doepfer_a100@yahoogroups.com]Im Auftrag von sfrules
> Gesendet: Dienstag, 16. Mai 2006 04:11
> Betreff: [Doepfer_a100] Any more ideas for exotic future A100 modules?
> Hi, chilluns!
> nice, too.
> Still waiting...
> sfrules
Hello,
Responding off list.
sfrules
2006-05-16 by Bakis Sirros
ok, now i'm confused.
the internal a155 addreses and a155, a154 clocks are 3
bits(ao,a1,a2) right? how can an expansion nmodule for
these could be 4 bits then?
also, dieter and florian,
how my new poll should be in the end?
with the outputs/inputs that dieter suggested, or with
the "every internally wired clock,
address or trigger connection offered as an normalled
insert" that florian suggested? help!
best regards,
Bakis.
wrote:
> Hi Bakis
> module
> this
> address or trigger
> Florian
Bakis Sirros - Parallel Worlds
[Doepfer_a100] group owner
http://www.shimarecords.co.uk
http://www.rubber.gr
Athens-Greece
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
Hi Bakis
Sorry for the confusion ;-). I don't have the schemoes here, and I do
not own a A154, but I thought the 1-8/9-16 is direct connected from the
A154 to the A155. This is the fourths bit.
of course MY suggestion ;-)))) No honestly: I assume Dieter listed
everything, that is worth to be brought to the surface (and doable
without electronic effort from the technical side).
Florian
> Gesendet: Dienstag, 16. Mai 2006 15:14
In addition to the addresses a0, a1 and a2 you also need the clock signal.
It is used for the trigger outputs (the clock pulsewidth is responsible for
the length of the trigger pulses).
a3 is only necessary of two A-155 are in use (the A-154 has details
concerning the usage of A3 with VC switches).
Best wishes
Dieter Doepfer
Hi Dieter
The idea of such an interface module, would be to provide not only the
controll lines which are used for a A155, but all available.
e.g you could use the adress data as gates for envelopes or what ever.
btw: the outputs should be made as multiples (at least two outs per line)
Florian
> Best wishes
> Dieter Doepfer
2006-05-17 by untiedstates
I like to create patterns that have nothing to do with standard
sequencing or keyboard playing - so keep that in mind with this module
idea - it is nice to have modulation sources that are meant to be
controlled in real time as opposed to setting them and leaving the
patch... so on that note...
I'd love to see a module that could take an incoming signal and "skip"
a manually set number of peaks in order to derive new patterns or
waveforms.
I'll explain with an example... let's say you took an LFO with a
rectangular or pulse waveform and wanted to trigger an envelope with
it but skip every 3rd pulse. You'd be able to set the module to
somehow derive an irregular waveform from the regular pulse of the
input... and this could be manually set for however many peaks you'd
like to "skip".
.. and this could function with LFO rates or audio rates to process CV
or audio.
I don't know how this would technically work, but I hope the idea
makes sense. I'd imagine you could use a couple modules to come close
to this idea but wouldn't it have to be a digital control in order to
exactly specify the number of "skips" and then how could the waveform
be smoothed? some type of slewing?
hmmm.. would it be something like an envelope follower into a digital
device that reads the frequency and then applies a slew to the input
according to the manually set number of "skips"???
2006-05-17 by Dieter Doepfer
If I understand everything this should be possible with an A-155:
LFO pulse out -> step in A-155
gate out #4 of A-155 -> reset of A-155 (limits the length to 3 steps)
The trigger rows (steps 1-3) are used to define which of the LFO pulses are
skipped or passed on.
Instead of the LFO you could use the gate output of an external input module
A-119 that generates the "peaks" of an audio signal.
Best wishes
Dieter Doepfer
> [mailto:Doepfer_a100@yahoogroups.com]Im Auftrag von untiedstates
> Gesendet: Mittwoch, 17. Mai 2006 17:46
> waveforms.
> like to "skip".
> or audio.
2006-05-18 by untiedstates
Hello Dieter... the A-155 would do part of what I want, defining
pulses to be skipped, but I wanted to deal with audio as well. I
just realized that I might be able to "skip" LFO pulses and audio
frequency pulses with the A-151 switch since it can handle fast VCO
rates. So it looks like what I want already exists in a way.
thanks,
Bryan K.
steps)
pulses are
input module
> Best wishes
> Dieter Doepfer
module
and "skip"
> > waveforms.
with
you'd
> > like to "skip".
process CV
> > or audio.
close
order to
waveform
digital
input
> > Yahoo! Groups Links
2006-05-18 by bty205236
Sorry, yet more random ideas, but would some (very) basic video
processing modules be out of the question?
Although i'm not too fantastically hot on the subject of video
processing, some kind of video mixing/filtering/switching/whatever
modules might sell (or not, who knows). Its just interesting to see
that no-one has ever developed a modular video system!
--- In Doepfer_a100@yahoogroups.com, Bakis Sirros
> ok list,
> it is brainstorm time again!
> if you have any crazy idea about a future exotic A100
> module, just say it!
> i'll gather all your ideas during the next two weeks
> and out of them i'll create some new polls.
> i am waiting...
> best regards,
> Bakis.
> Athens-Greece
> Do You Yahoo!?
videosizer
http://www.emsrehberg.de/VIDEOSIZER/videosizer.html
EMS video synthesizer (!)
--- In Doepfer_a100@yahoogroups.com, "bty205236" <andrew.maunder@...>
> > ok list,
> > i am waiting...
> > best regards,
> > Bakis.
> > Athens-Greece
> > Do You Yahoo!?
2006-05-19 by mritenburg
Here are some ideas:
1. looping multi-stage ADSR
2. somthing like the Buchla 296 programmable spectral processor
3. quad/triple parametric eq -possibly resonant
4. 16bit wave table module with multiple banks and CV selection of bank.
$.02
Matthew
2006-05-22 by nicholas_kent
I once saw a for modular voltage controlled one back in the mid 80s that was built in the
70s, individulal modules and patchcords. I didn't see it in operation though. I'm trying to
remember the name. Also for what it's worth MFB (Fricke) the drum machine and synth
maker had something very simple for video processing shown as Musik Messe.
The big problem though is unlike audio so much of a video signal has to stay unprocessed
to just display an image. And the "good" part that contains the image is herterodyned
together. You can't process the entire raw video signal and get much that isn't instantly
totally scrambled or no image at all. For the most part just end up being able to modulate
the kind of parameters you have on a TV, you know the hue, brightness, saturation after
you've built special equipment to do it. If you've seen a 70s or 80s TV mixer and imagine
voltage control on it's parameters then that's the range of voltage control processing that
one can expect (wipes, luma key, etc.). Note how much the EMS Rehberg device resembles
a video mixer.
Some of the more radical early video art tended to be voltage control of electromagnets
around a TV display rather than processing the signal itself. That let you bend the picture
around. Of course that meant you had to re-phoptograph your monitor if you wanted to
record the results. If you think about it, while there are a few artists still doing this sort of
thing sometimes there are a few too many limitations that keep something from really
catching on. (you spend a lot of time and money to get limited results)
Arguably to get into really synthesizing a picture you need a frame buffer, in other words
to convert the whole image into a raster and then process a frame as a whole bitmap
frames one at a time rather than linearly like audio.
2006-06-27 by Bakis Sirros
hello dieter, florian, ingo and the whole list!
so, should i create a poll about a "scale programmer"
module(like the one mentioned below)? or this function
will be implemented into the TKS?
Best regards,
Bakis.
> scale programmer
> be tuned
> tuning system you
> wanted.
> CV wouldn't you
Athens-Greece
Do You Yahoo!?
hello,
so, about the first idea: the a143-1 and a143-2 can do
looping and multistage envelopes, right? should i
creaste such a poll then?
about idea 2:what can the buchla 296 can do that is
special?
idea 3: there is already a poll about something like
this, right?
idea 4: so, should i create a poll about a wavetable
osc module like this dieter?(with multiple banks and
vc selection of bank?)
best regards,
Bakis.
> spectral processor
> $.02
> Matthew
Athens-Greece
Do You Yahoo!?
2006-06-27 by levka0
So as I understand it from the post below,
a scale programmer could be made according to a cv in, a series of 12
pots (for re-tuning) of each note and a CV out ?
Nice concept !
I also still like the concept of a quantizer with a cv in, 12 on/off
switches for each note and a cv out, but this would pronbably also be
possible with the concept above with more flexibility ?
a programmable scale programmer could be based on one of these
concepts with memory locations that could be switched according to VC
(like the A-107)
There seem to be quite a lot of possibilities, maybe too much to
include all in a poll ?
Best regards
Joost
> Best regards,
> Bakis.
> > scale programmer
> > be tuned
> > tuning system you
> > wanted.
> > CV wouldn't you
> Athens-Greece
> Do You Yahoo!?
2006-06-28 by Dieter Doepfer
Bakis,
yes a poll concerning a wavetable module would be interesting (especially as
we have such a prototype already available, it was made about 10 years ago
before the A-112 was developed - i.e. before this group was "born"). But
only 8 bit and I'm not sure if a 16 bit wavetable makes sense. You would
need wavetables with 65536 instead of 256 in length!
Best wishes
Dieter Doepfer
> Gesendet: Dienstag, 27. Juni 2006 19:17
> modules?
> hello,
> special?
> this, right?
> best regards,
> Bakis.
> > spectral processor
> > $.02
> > Matthew
> Athens-Greece
> Do You Yahoo!?
This function will be probably available in the planned keyboard/sequencer
controller, i.e. a separate potentiometer for each step/position with the
step/position controlled by the keyboard connected to the controller
(expansion for the planned A-100 keyboards).
Best wishes
Dieter Doepfer
> Gesendet: Dienstag, 27. Juni 2006 19:00
> modules?
> Best regards,
> Bakis.
> > scale programmer
> > be tuned
> > tuning system you
> > wanted.
> > CV wouldn't you
> Athens-Greece
> Do You Yahoo!?
2006-06-28 by untiedstates
ooooo.. what about an octave switch in addition to each of the 12 CV
tuners?
that way you could not only create interesting interval relationships,
but also switch individual notes to different octaves - especially
good for playing a sequence and changing an interval relationship from
"closed" to "open".
to really make it precise (and fun):
"rough" CV tuning control
fine tuning
octave switch
... interface with a controller/keyboard/sequencer of choice.
> Nice concept !
> (like the A-107)
> Best regards
> Joost
> > Best regards,
> > Bakis.
> > --- untiedstates <untiedstates@> wrote:
> > > scale programmer
> > > be tuned
> > > tuning system you
> > > wanted.
> > > CV wouldn't you
> > Athens-Greece
> > Do You Yahoo!?
2006-07-03 by erase
a "pure" wavetable module would be very tasty indeed!
On 28 jun 2006, at 10.26, Dieter Doepfer wrote:
> Bakis,
> (especially as
> years ago
> "born"). But
> would
> Best wishes
> Dieter Doepfer
www.myspace.com/djerase
email: info@erasemusic.com
msn: erasemusic@msn.com
aim: erasemusic@mac.com
icq: 344917989
yahoo: erasemusic@yahoo.com
skype: erasemusic
2006-07-03 by q v s f u e k p s v h s l w
i would just love a Ppg wavetable osc and i'm amazed no ones selling one or is that what the blacet and others can do with the right rom ? i would love a bit of ' ppg 'in my modular.
erase <list@erasemusic.com> wrote: a "pure" wavetable module would be very tasty indeed!
> Bakis,
> (especially as
> years ago
> "born"). But
> would
> Best wishes
> Dieter Doepfer
icq: 344917989
skype: erasemusic
All new Yahoo! Mail "The new Interface is stunning in its simplicity and ease of use." - PC Magazine
2006-07-03 by Florian Anwander
Hi
I could imagine, that there are some kind of copyrights on the original
PPG wavetables.
Florian
2006-07-09 by Bakis Sirros
hello matthew,
please, if you want that i make a poll about a module
in the style of buchla's 296 spectral processor that
you mentioned, explain to us what are the special
functions of this module.
thank you,
best regards,
Bakis.
> spectral processor
> $.02
> Matthew
Athens-Greece
Do You Yahoo!?
2006-10-16 by ilanode
> Does anyone think this is a useful module?
> Regards, Florian
It definately is, Regards, Ingo
2006-10-16 by Florian Anwander
by occasion I ran over my sketch for a module idea, which i put in May
to the file section, while we were discussing the thread "any more ideas
for exotic future A100 modules"
(http://launch.groups.yahoo.com/group/Doepfer_a100/files/Entwurf-Crossfader.jpg).
Somehow we never started a poll on this.
So let me suggest this very simple module once again (most text is taken
from my mail from 08-May-2006):
Basically the idea for this module comes from building modular patches
from the scratch while a live performance. You will want to add more and
more modules to the audio signal path. If you have a system with
audiomixers and multiples on each module (e.g. the Roland 100m), this
is no problem. With the A100 this requires everytime to break up the
signal path, which is close to "stop your musical performance". Similar
is valid for adding additional control voltages to a module, which
provides only one adjustable CV input.
The idea of my module is to extend modules like all the VCFs or similar
(VC-Phasers, BBDs, Waveshapers...) with additional audio inputs,
additional CV-inputs and additional outputs. Also I thought, that it is
not so easy to crossfade from one source to another with two normal
mixer inputs - a real crossfader is much better.
Technically it is a kind of 3-1-2 mixer. Three inputs can be level
controlled and switched individually to two busses. The crossfader poti
is fix wired to one bus in my sketch, but an additional switch for
routing it also should be possible. If you hardwire the summing points
of the mixers to the corresponding main module you even do not need any
active elements or powersupply for this module.
Regards, Florian
2006-10-16 by guido de zeeuw
very usefull indeed, but I would build this outside
of the rack. Something like a DJ-mixer in front of your rack.
And then three or four little mixers with crossfader, and don't forget
the inverters ( with a switch )
You can build this yourself, and maybe you need some buffer amps or
adders, I don't
know, I'm not an electronic.
good luck
On Oct 16, 2006, at 15:22, Florian Anwander wrote:
> Hi,
> ideas
> Crossfader.jpg).
> taken
> and
> Regards, Florian
2006-10-17 by selfoscillate
hello florian,
yes, this would be a cool module.
best wishes
ingo
> Hi,
May
ideas
Crossfader.jpg).
taken
patches
more and
this
Similar
similar
it is
poti
points
any
> Regards, Florian
2006-10-17 by Florian Anwander
Hi Guido
> of the rack.
I think, it would become very inconvenient. Imagine a very simple audio
chain with VCO-VCF-VCA-VCBBD. This would require three external
crossfaders with at least nine cables to the system. Not to speak, that
there is no additional mixerinput wired.
It might make sense to use VCAs for the crossfader, and external faders,
which deliver CV. But this would require active electronics in the
module. Up to now, this is a completeley passive module which should be
very cheap.
Florian
> adders, I don't
> good luck
2006-10-17 by guido de zeeuw
I just thought, in your example vco-vcf-vca-
3 audio signals from vco, crossfade to vcf or vca
3 cv from anywhere, crossfade to vcf or vca
and then you want inverter-switches, lag-time ?
cables you have to run anyway, (?)
Dynamic mixing ( LIVE! ) in a rack ? I can't, and I like diy-boxes,
good luck,
guido
On Oct 17, 2006, at 9:25, Florian Anwander wrote:
> Hi Guido
> > of the rack.
> audio
> that
> faders,
> be
> very cheap.
> Florian
> forget
> > adders, I don't
> > good luck
Hmmm,.... Either you misundertood the concept of my modul or I
misunderstand your english.
I mean originally there are
VCO -> 12db-VCF -> VCA -> BBD
Then you insert the addon/Xfade modules and add a 24DB VCF parallel to
the 12dB.
VCO -> X -> 12db-VCF -> X -> VCA -> X -> BBD
\ 24db-VCF /
Now you can crossfade over to the 24db-VCF and remove the 12dB-VCF. The
VCF has to be controlled by some other CVs than the 12dB Filter.
The same is valid for changing the VCO or inserting something between
VCA and BBD.
Florian
blindplate + crossfader
guido
> the 12dB.
> \ 24db-VCF /
> The
> VCA and BBD.
> Florian
