Doepfer
Re: [Doepfer_a100] Re: starting a modular - Z3000 waveform quality?
2008-11-24 by James Husted
Actually that is not the case. If you make the video full screen you
can see the output of the Z3000 is being used. when he changes
waveforms you can see him re-patch the output cord to the other
waveform jack. Also there is nothing plugged into the External in for
the frequency counter so it is reading the internal VCO and not an
external one. T Cwejman that is in the patch looks like the MMF-1, a
multi-mode filter that is used in the demo also. Maybe it does not
pass a unfiltered signal when set to it's extreme "open" settings. I
would love to see the Z3000 straight into a scope. Don Kim's video
shows similar looking square waves etc. when they are not being
modulated. I am going to check the AS and Doepfer VCOs in me system.
-James
On Nov 24, 2008, at 8:28 AM, Andreas Wetterberg wrote:
> He's mainly using the - very expensive - cwejman oscillator in that
> demo, and using the tiptops as frequency counters.
> Andreas...
> James Husted skrev:
>> I was hot for the Tiptop VCO till I saw this video made about
>> it.    -     http://vimeo.com/2206614
>> That is one of the worst sine waves I've seen and the spectrum
>> display  shows many harmonics that shouldn't be there. I count at
>> least 7 on  the spectrum display. . All I can hope is the
>> distortion is caused by  something downstream between the VCO and
>> the scope. Does anyone who  has a z3000 and a scope and can tell me
>> if this setup was just faulty  or does the unit make sines as shown
>> in the vid? The other waveforms  shown are not to good on this demo
>> either - the sawtooth and triangles  look like they sag and the
>> square waves are not square with flat tops  and bottoms.
>> -James
2008-11-24 by laryn91
Out of curiosity, which euro oscillators have quality sine wave outputs?
All my Doepfer osc's (including the "High-End")  have really crap (useless) sine shapes.
Even my favorite Zeroscillator becomes grossly distorted at lower freq's. And according to
this thread, it looks like ASys and Z3000 are also low quality.
However, *all* my vintage VCOs and LFO's have nice low distortion sines.
> -James
> > Andreas...
> >> -James
2008-11-24 by Argitoth
i dunno how useful this is, but whatever, it's an analogue systems vco test:
http://www.elanhickler.com/misc/AnalogueSystemsVCO.wav (sine first,
triangle second)
http://www.elanhickler.com/misc/analoguesystems_sine.PNG
http://www.elanhickler.com/misc/analoguesystems_tri.PNG
> -James
>> Andreas...
>>> -James
www.elanhickler.com
My Aries modular VCOs have a triangular core that also forms the square and sine output.
There's a second sync'd core for sawtooth output (so no glitch). It's their differential
transistor tri-to-sine converter that makes the high quality sine output.
Moog, Arp, Polyfusion, etc. all used this standard circuit to make their high quality tri-to-
sine conversions. Looking at Doepfer schematics, all his oscillators (except the quadrature)
use that cheap simple diode converter. I'm guessing Dieter chose this for cost rather than
quality reasons. I was expecting the expensive High-End VCO to be better quality.
BTW, I was really tempted to get Tip-Top, but that video shows a distorted sine even
worse than Doepfer! Makes me wonder about the design quality inside...
--- In Doepfer_a100@yahoogroups.com, Argitoth <argitoth@...> wrote:
> So far I think from best to wrost, (but I'm not so sure) it's
> 1. Plan B VCO Sine (good)
> 2. Tip Top Audio VCO (a little better than Analogue Systems? Never
> owned one of these)
> 3. Analogue Systems VCO Sine (bad)
> 4. Doepfer A-110 (worse)
> Laryn91, your vintage MODULES or your vintage tabletop/rack/keyboard
> synths? Don't forget that all my filter modules produce very clean
> sines. Also, I believe the quality of the sine has to do with its
> oscillator core. I think to get a clean sine requires a second VCO
> within a VCO... as in, one module has to house two different
> oscillator cores. One for square,tri,saw, and another separate one for
> sine... but I don't know anything about circuit boards, this is just
> my guess. I think this is easily done in a self-contained synth like
> your vintage gear because it's one whole system, not a bunch of
> modules... or something... know what I mean?
owned one of these)
2008-11-24 by Don Kim
A perfect sine would give you no harmonics.
I'm pretty sure that the harmonics is what gives a sine out of an
oscillator it's character.  The ASys sine is not bad, that's a
personal opinion.  The waveforms on my scope show the M15 as the most
mathematically sine like, the ASys has slightly pointier peaks (and
thus sounds brighter towards a triangle sound), and the Z3000 has the
most "imperfect" waveform of the three mentioned.  However, the Z3000
and M15 FM better than the ASys (which has no dedicated FM input).
The ASys however has a wave shape control that lets you skew waveforms
and morph saws from ramping down to ramping up, and goes into LFO much
slower than the M15.
There are no "bad" tools, just lack of understanding and/or the wrong
tool for that particular job.
I use the scope to see what modulations do to signals, not to judge if
my ears are doing their job.  I hear with my ears, not my eyes.
If mathematical perfection is that important, perhaps CSound is more
what you want.
I was refering to you and your "perfect" sine.
On Mon, Nov 24, 2008 at 3:29 PM, Argitoth <argitoth@gmail.com> wrote:
> Don Kim, all it takes to get a clean sine is to find the right
> oscillator. You shouldn't discourage people looking for a little bit
> of perfection in their modular synth.
man, I feel jipped now. Every oscillator that doesn't have a clean
sine is simply using cheap parts? that suks.
> sine output.
> differential
> the quadrature)
> cost rather than
> quality.
> sine even
>> owned one of these)
www.elanhickler.com
an,
2008-11-25 by achtung_999
Excuse me Argitoth, but if you're so obsessed with pure sine waves, go
digital. Buy Max/MSP or learn SuperCollider.I thought we were using analogue
gear because of its colour and impurities?
At least I am.
And I'll say it again: Buy an A143-9 if you want nice sinewaves.
It goes far into the audiorange.
Check the attached picture.. An A143-9 hooked up straight to my Focusrite
Pro26 firewire interface.
greets,
Ernst
> On Mon, Nov 24, 2008 at 4:43 PM, laryn91 <caymus91@mac.com<caymus91%40mac.com>>
> and
> > sine output.
> their
> > differential
> (except
> > the quadrature)
> > cost rather than
> > quality.
> distorted
> > sine even
> > --- In Doepfer_a100@yahoogroups.com <Doepfer_a100%40yahoogroups.com>,
> >> owned one of these)
> www.elanhickler.com
> an,
2008-11-25 by laryn91
Some of us like the sound of analog because of its continuous (un-encoded) signal - not
because of sloppy or low-quality product designs.
BTW, do you think digital doesn't add color and impurities too? My studio is full of digital
products that add all sorts of audible (unintended)) color and impurities to the sound.
If you sell a VCO that can't make a decent sine wave - maybe label it something else
instead. Sine actually means a wave with NO ADDED COLOR OR IMPURITIES.
My 143-9 doesn't track anywhere near well enough to be useful as a VCO. It's intended to
be used as a LFO.
--- In Doepfer_a100@yahoogroups.com, achtung_999 <heinrich.himmelwasser@...>
> At least I am.
> greets,
> Ernst
<caymus91@...<caymus91%40mac.com>>
> > and
> > > sine output.
> > their
> > > differential
> > (except
> > > the quadrature)
> > > cost rather than
> > > quality.
> > distorted
> > > sine even
> > >> owned one of these)
> > www.elanhickler.com
> > an,
2008-11-25 by Argitoth
laryn91, haha, finally someone on my side. I spent over $3000 on my
analog synth. Some of that money was spent replacing crappy-designed
modules... there are no impurities in analog, only badly designed
circuit boards. The impurity is only in the digital world.
> signal - not
> full of digital
> the sound.
> something else
> intended to
> be used as a LFO.
>> analogue
>> At least I am.
>> greets,
>> Ernst
>> > > square
>> > and
>> > > sine output.
>> > their
>> > > differential
>> > > output.
>> > > their
>> > (except
>> > > the quadrature)
>> > > for
>> > > cost rather than
>> > > better
>> > > quality.
>> > distorted
>> > > sine even
>> > >> owned one of these)
>> > >> for
>> > www.elanhickler.com
>> > an,
www.elanhickler.com
Oh BTW, i don't mean to imply that I think Deopfer modules are sloppy or poor designs -
just the opposite. Deopfer modules appear to be high  quality designs and build, a
massive selection that sound great and manufactured and sold at very economical prices.
And super reliable too - I have 3 G6 racks of Deopfer modules and all have worked 100%
since day one. That's quite an accomplishment from a small engineering company!
But about those "sine" waves... ;-)
> > signal - not
> > full of digital
> > the sound.
> > something else
> > intended to
> > be used as a LFO.
> > --- In Doepfer_a100@yahoogroups.com, achtung_999 <heinrich.himmelwasser@>
> >> analogue
> >> At least I am.
> >> greets,
> >> Ernst
> > <caymus91@<caymus91%40mac.com>>
> >> > > square
> >> > and
> >> > > sine output.
> >> > their
> >> > > differential
> >> > > output.
> >> > > their
> >> > (except
> >> > > the quadrature)
> >> > > for
> >> > > cost rather than
> >> > > better
> >> > > quality.
> >> > distorted
> >> > > sine even
> >> > >> owned one of these)
> >> > >> for
> >> > www.elanhickler.com
> >> > an,
> www.elanhickler.com
2008-11-25 by James Husted
Well after starting this branch of the thread I went down and plugged
in all my VCOs to a scope and they all lack in "perfectness" from the
true waveshapes. I used to teach electronic music back in the 70's
with an Arp 2500 and those old synths had great waveforms if I
remember correctly. And you could keep tacking on CV sources to them
without them sagging and needing buffer amps etc. too. I have AS and
Doepfer analog modules and they all show mis-shaped waveforms from the
true shapes. The talk on this list about one VCO sounding better/worse
than another makes sense for the first time now! I come from a era
where one VCOs waveforms were closer to another's and the differences
were mainly in the tracking and features.
The best analog sine shape I found in my rig was the Doepfer
quadrature VCO and one of the Doepfer LP filters in resonance
feedback. Other than that the best waveform shapes came out of one
piece of kit I own. All of them the expected textbook shapes. As
heretic as it may sound - theses came from my Nord G2. I would have
guessed that though since it is easier to make them from a look-up
table than from circuits.
Please - no Digital vs. Analog religious wars because of that - We
have ALL been there and heard it all already.
-James
James Husted, you come from an era of great synths. Can you tell me if
this lack of quality in today's lower-cost modular synths have
translated to worse quality in overall sound? Or is it that when I rip
out a sweet screaming synth bassline or lead that I am getting a sound
that is honorable in the synth hall of fame? Or will my synth usually
fall short of greatness? How satisfied are you with your modern
modular synth?
2008-11-25 by Bakis Sirros
design them yourself then...
[Doepfer_a100] group owner
www. parallel - worlds - music. com
www. myspace. com/ parallelworldsmusic
www. myspace. com/ interconnectedmusic
www. myspace. com/ memorygeist
www. DiN. org. uk
www. musicamaximamagnetica. com
www. shimarecords. co. uk
www. rubberrecords. gr
Athens - Greece
--- On Tue, 11/25/08, Argitoth <argitoth@gmail.com> wrote:
Subject: Re: [Doepfer_a100] Re: starting a modular - Z3000 waveform quality?
Date: Tuesday, November 25, 2008, 4:24 AM
> signal - not
> full of digital
> products that add all sorts of audible (unintended) ) color and impurities to
> the sound.
> something else
> intended to
> be used as a LFO.
> --- In Doepfer_a100@ yahoogroups. com, achtung_999 <heinrich.himmelwas ser@...>
>> digital. Buy Max/MSP or learn SuperCollider. I thought we were using
>> analogue
>> At least I am.
>> greets,
>> Ernst
> <caymus91@.. .<caymus91% 40mac.com> >
>> > > square
>> > and
>> > > sine output.
>> > their
>> > > differential
>> > > output.
>> > > their
>> > (except
>> > > the quadrature)
>> > > for
>> > > cost rather than
>> > > better
>> > > quality.
>> > distorted
>> > > sine even
>> > > --- In Doepfer_a100@ yahoogroups. com <Doepfer_a100% 40yahoogroups. com>,
>> > >> owned one of these)
>> > >> Laryn91, your vintage MODULES or your vintage tabletop/rack/ keyboard
>> > >> for
>> > www.elanhickler. com
>> > an,
2008-11-25 by Doug
Can someone give me an example of an application that requires a
perfect sine wave? Will a perfect sine do special things when used as
an FM or AM source? I don't think there are too many people doing
additive synthesis, but I can see how it would benefit from perfect
sines.
Another question... why is it that people ascribe a certain sound to
modern modulars? Why a certain sound to vintage? I don't understand
why a modern modular can't sound exactly like a Buchla, or a Serge, or
a fluglehorn, or a pile driver. In theory, with the all of the sound
generating and conditioning elements of a modern modular in place, you
should be able to make any sound. Or have we hit the core issue with
this sine wave discussion? I'm really lost on a lot of these
discussions, but it's probably just because I'm new.
Doug
A good sine assists in the creation of nice soft waveforms, moves you
away from the buzzy, sharp square/saw paradigm, allows you to create
classic "glassy" sounds, sounds with resonances, soft tones, sounds
not easily copyable. To achieve a cleaner sine out of my oscillators
would require me to dedicate a filter to waveshaping. The triangle is
also not a buzzy waveform and seriously, I'd be happy with a perfect
triangle and wouldn't mind of my sine was imperfect. Analogue Systems
VCO triangle gets near perfect. Plan B Model 15 has the perfect
waveforms IMO. It just doesn't track as good as I'd like. So the point
is, it's absolutely possible for a VCO to meet my perfectionist needs.
I'm guessing and hoping that Tip Top Audio VCO has a perfect triangle
(no buzz) and I'm also guessing that its sine is not buzzy either,
just harmonically rich... but I'd need to hear a frequency sweep to
really tell.
2008-11-25 by Frequency Divider
For all sine wave obsessed folks on this list here's some more for you
to read
http://dubshot.blogspot.com/2008/10/basswatch-3-cult-of-sine-wave-enter.html
especially the links to a sinewave shootout and an article by Bernie
Hutchins under 'Digital vs. Analog'
> perfect sine wave?
obsessively clean ring modulation? if you really want to get rid of the
harmonics just filter the damn wave. otherwise go digital
a very coloured and personal comment: why do audiophiles exist? why are
certain people convinced that the sound quality of their stereo improves
if they use cable that costs 500 euro per meter
I don't understand
don't forget that a certain circuit can have a certain unique quality.
2008-11-25 by Guy Drieghe D.
I assume this is a typo ? :
"and I'm also guessing that its sine is not buzzy either, just
harmonically rich"
_g
> really tell.
2008-11-25 by Sean Williams
I would suggest that the individual sound of vintage synths was a
function of their circuit design, especially the filter design, but
since many manufacturers copied one another's designs, you might
expect them to sound identical. You have to look at the selection of
components, not just materials (such as "germanium") but the
tolerances of the components and their effects on the overall circuit
behaviour and stability.
Things like the proximity of power supplies or transformers in the
synth design and relative smoothness of the power supply can also
influence things I should think.
The handmade aspect is also a factor, both then and now, but you
would expect more stability in today's synths. Having said that,
stability is not always what you want. I just had a couple of hours
using a Mark II VCS3 and the unpredictability and general sloppiness
when plugging more pins into the matrix was a joy. The sound seemed
to have a life of its own! So these older synths (and some of the
newer ones too), are individual musical instruments with their own
idiosyncratic sounds. It's maybe not helpful to think of them as
manufactured/replicated items. Each VCS3 has its own character, just
like each cello or violin.
Today's manufacturers are giving us the tools to design our own
unique synths with so many filter types and many more modules
available than ever before. The drive to eliminate "imperfections" is
a factor here in that there is almost always a trade off.
Since the phonograph, companies have been selling equipment which is
less noisy - higher "fidelity".
All I'm saying is beware the hi-fi buff and his synth equivalent.
This is not a healthy obsession, and making the elimination of noise
and esoteric behaviour your god is the path to sterility.
(on the other hand, a pure sine wave is a useful theoretical tool :) )
Trevor Pinch's "Analog Days" is an interesting account of the
evolution of Moog and includes chapters on Arp and others too. Check
it out.
sean
>to read
><http://dubshot.blogspot.com/2008/10/basswatch-3-cult-of-sine-wave-enter.html>http://dubshot.blogspot.com/2008/10/basswatch-3-cult-of-sine-wave-enter.html
>>  perfect sine wave?
>I don't understand
Not at all! I am quite satisfied with the sound of modern synths.  I
have no problems with the sound of new synths. I bought my first synth
in 1974, a Synthi VCS3 (for $500 BTW) an have owned almost every major
brand old school synth since then (Pro-Ones, Oberheim 4 & 2, Arps,
Rolands, more EMS) and I worked at a Synth/Recording gear store and
had daily access to big iron I could never afford (Arp 2500s, Emu, Big
Rolands etc). The sound of perfect waveforms is not the goal - they
are the start. I have never made a patch that didn't change the
waveform anyway. I was just amazed at the differences between the
units I have now. It has been a long time since I put a scope on a
synth but when I taught the hardware part of the electronic music
courses at university, the Arp 2500 and Emus had pretty spot on
waveforms. Like I said earlier, now I understand the comments about
the different "sounds" of different manufacturers. I can compare it to
the different sounds of different brands of guitar strings. They all
work and you work with them to get the sound you want. I just assumed
that when the different brand VCOs said Sawtooth or Square etc. that
the waveforms were the same.
The only time I would think it would get in the way is as mentioned by
another - when used in FM or ring modulation. Control voltage
applications also. But since I seldom do critical FM work that matters
little to me. The main differences I see from the big rigs of the past
and todays models is in other performance interconnection aspects. I
remember on the 2500 for example that I could keep on adding CV
sources to a VCO and it would never sag and need re-scaling. I could
fan a CV source (like the keyboard) to many places and it would just
work. Nowadays at some point you better have a buffer module or things
go wacky. It cost more but the buffering was built into the modules
themselves. Full patching freedom. Except for the EMS stuff that was
ass-backwards from everything else and had the .32V/oct CV range.
So what I'm saying is that now I'm aware that different brand VCOs
will sound different from each other. When building a system now you
will have to have a variety of modules to have a larger variety of
sounds. Some VCOs will sound warmer, brighter, crisper and all the
other words we use to describe the various different starting waveforms.
People have to remember that the old-school vintage synth were VERY
expensive in their day. It is amazing what you can get today and this
is just a side effect of cost cutting. I don't think it is a problem
at all. Every instrument takes time to learn fully and to tap it's
potential. You learn to play the rig you have.
-James
> modular synth?
btw, here's the Tip Top Audio VCO waveform test:
http://www.muffwiggler.com/forum/viewtopic.php?t=2158
Is it just me or does Analogue Systems VCO produce better traingles and sines?
Thanks James,
Laryn91, I just recorded my synth using the filter as a waveshaper.
Good tracking is not needed, you just have to patch a 1v/oct signal
into the filter's VC, but that VC needs an attenuator. You don't want
to give it full VC. Here's the recording:
http://www.elanhickler.com/misc/filter-waveshaping-test.wav
1. Raw sound without filtering.
2. With filtering (notice how you can't hear low notes, that's how it
should be with sine waves, however the problem is that low notes also
have small peaks)
3. With filtering used as a modulator (the lesser peaks means it's not
good as a modulator, not enough volume anymore)
4. Without filtering used as a pitch modulator (this is how the
modulation should sound)
Hmm... Its anyone's guess if a filter is really worth using as a waveshaper.
i would like to suggest the creation of a seperate list or yahoo group
for any future sine wave purity discussions. you could even join the
alternate tunings list for obsessive talk about tuning the vco in cents
and fractions of cents
> <http://www.muffwiggler.com/forum/viewtopic.php?t=2158>
> sines?
> Thanks James,
> <http://www.elanhickler.com/misc/filter-waveshaping-test.wav>
> have small peaks)
> No virus found in this incoming message.
> Checked by AVG - http://www.avg.com
> Version: 8.0.175 / Virus Database: 270.9.10/1810 - Release Date: 11/24/2008 2:36 PM
Interesting - the other scope shots show a difference from what
muffwiggler says. He says "The square wave and saw are perfect as near
as I can see." and all the square wave shots I have seen have slanted
tops and bottoms and the Saws have a sag. Maybe there are differences
in production runs.
My AS VCO has pretty bad overshoot at the bottom of the saw and a
slight glitch at the top of the triangle. I just looked at one of them
though. I will try to do some scope shots (pretty tricky with the
camera I have though).
-James
It would be neat if some massive modular owner, or Shaun at Analogue
Haven, who has access to all these VCOs could do a scope picture of
all waveforms at a median frequency (say middle C - 440) and post them
somewhere. A nice Hi-end scope would be nice. Who knows how much
distortion is being introduced by my old Techtronics scope also.
-James
> and sines?
Frequency Divider, you are missing the point.
1. Discuss Tip Top Audio VCO waveform quality
2. Compate Top Top Audio VCO to other VCOs
3. Discover that Tip Top Audio sine/tri aren't that great
4. Discover that very few VCOs have much better waveshapes
5. Discuss how one might get a better waveshape <-- we are located here
6. Tell everyone to stop discussing these things <-- Frequency Divider
is located here
7. Everyone ends up hating Frequency Divider for the rest of eternity
<-- we are about to get here.
joke joke.
2008-11-25 by Mikhail Novikov
Nice that you stay cheerful, but discussion IS getting annoying. This
discussion already joined my list of holywars among with PC vs Mac and
Gibson vs Fender. I really think discussion about other modulars and
theory of synthesis are okay in this group, but only until they reach
certain point.
No offence, Mikhail
> is located here
> joke joke.
My thoughts indeed.
On Tue, Nov 25, 2008 at 9:12 PM, Herman Pearl <djsoysos@yahoo.com> wrote:
>   Argitoth,
> I'm amazed by your tendency to lecture and complain to
> people with huge modular systems and decades of experience.
> It's really strange.
2008-11-25 by ybl@yahoo.com
+1
This thread has become a brain-sucking ghoul.
Sent via BlackBerry
Date: Tue, 25 Nov 2008 20:31:52
To: <Doepfer_a100@yahoogroups.com>
> sines?
> Thanks James,
> have small peaks)
yes, good idea. i can then NOT join that group...
www. DiN. org. uk
Athens - Greece
Date: Tuesday, November 25, 2008, 9:31 PM
> http://www.muffwigg ler.com/forum/ viewtopic. php?t=2158
> <http://www.muffwigg ler.com/forum/ viewtopic. php?t=2158>
> sines?
> Thanks James,
> http://www.elanhick ler.com/misc/ filter-waveshapi ng-test.wav
> <http://www.elanhick ler.com/misc/ filter-waveshapi ng-test.wav>
> have small peaks)
> Checked by AVG - http://www.avg. com
2008-11-26 by Argitoth
im definitely satisfied with my analog systems VCO. I'm not sure if I
could buy Tip Top Audio VCO, it would have slightly different pitch
tracking... hmm.
well just check out the non-buzzy tones I was getting out of my Analog
Systems VCO today: http://www.elanhickler.com/misc/analog-downbeat.mp3
2008-11-26 by jalmari3
> a perfect sine wave? Will a perfect sine do special things when
> used as an FM or AM source? I don't think there are too many
> people doing additive synthesis, but I can see how it would
> benefit from perfect sines.
In DX7-style FM synthesis perfect sine waves are important. I once
used a softsynth, where second order parabolic functions were used as
approximations for sine. The results were not satisfying, until the
issue was fixed by using higher (up to 8th) order parabolic functions.
Maybe ring modulation and frequency shifting benefit from pure sine
too.
My Cwejman VCO-6 and VCO-2RM make good sine waves by analog
standards. They look perfect in my oscilloscope. However, one can
hear, that VCO-6 has some "buzzy" higher harmonics present. It is not
immediately noticable though. On the other hand, VCO-2RM draws
attention to more pleasant lower harmonics. I would say VCO-6 is
closer to perfect sine.
Z3000 sine certainly doesn't look perfect. If people like it, I would
guess it is not too buzzy.
Skewed sine is is different from triangle or filtered saw and can
sound like a vintage Theremin. It should get progressively more
skewed (brighter) at lower frequencies though.
2008-11-26 by kovski774
or perhaps we can just ban argitoth? the guy's a trainwreck, spoils
every message board he signs up to with inane opinions presented as
fact and a TOTAL lack of self awareness.
--- In Doepfer_a100@yahoogroups.com, Bakis Sirros
> www. DiN. org. uk
> Athens - Greece
> --- On Tue, 11/25/08, Frequency Divider <freq.div@...> wrote:
> From: Frequency Divider <freq.div@...>
quality?
group
cents
traingles and
> > sines?
> > Thanks James,
waveshaper.
signal
want
how it
also
> > have small peaks)
it's not
waveshaper.
11/24/2008 2:36 PM
2008-11-26 by achtung_999
I would say just ignore him. He's just 19 years old so please excuse his
manners.
On Wed, Nov 26, 2008 at 12:42 PM, Florian Anwander <fanwander@mnet-online.de
> wrote:
>   Answer to this direct to Mr. kovski774 and Bakis.
> regards, Florian
2008-11-26 by york luethje
Why ban people? I found the debate lively at first, although it later turned somewhat obnoxious. Dieter Doepfer has given an excellent reply and I think matters should rest there.
York
Sent: Wednesday, November 26, 2008 6:30:55 AM
Subject: [Doepfer_a100] Re: starting a modular - Z3000 waveform quality?
--- In Doepfer_a100@ yahoogroups. com, Bakis Sirros
> www. DiN. org. uk
> www. musicamaximamagneti ca. com
> Athens - Greece
> --- On Tue, 11/25/08, Frequency Divider <freq.div@.. .> wrote:
> From: Frequency Divider <freq.div@.. .>
quality?
> To: Doepfer_a100@ yahoogroups. com
group
cents
traingles and
> > sines?
> > Thanks James,
waveshaper.
signal
want
how it
also
> > have small peaks)
it's not
waveshaper.
11/24/2008 2:36 PM
2008-11-28 by laryn91
I originally asked if anybody sold a VCO with undistorted sine outputs. In summary here
are the replies I got:
1 - Manufactures claim they can spec any wave with rounded peaks as "Sine". Even if you
can clearly hear even harmonic distortion - any roundish looking shape is a close enough
to be called a Sine.
2 - Analog vs. Digital religion states that analog must always remain imprecise because
that is its character. We don't want a clean analog wave with no added harmonics in our
system because that would make it digital.
3 - Finally the topic police posted their overall disapproval of this discussion. Even
banning members was suggested!
So I learned if you want a real sine wave (as defined by Fourier), get Plan-B Model 15...
there.
> York
> From: kovski774 <kovski@...>
> > www. DiN. org. uk
> > Athens - Greece
> > --- On Tue, 11/25/08, Frequency Divider <freq.div@ .> wrote:
> > From: Frequency Divider <freq.div@ .>
> quality?
> group
> the
> cents
> traingles and
> > > sines?
> > > Thanks James,
> waveshaper.
> signal
> want
> how it
> also
> > > have small peaks)
> it's not
> waveshaper.
> 11/24/2008 2:36 PM
Ah... maybe YOU are the one not reading well ;-)
I asked about a VCO (not LFO).
wrote:
> You are not reading well:
> I also said: "Or get an 143-9" I even attached a picture of its near perfect
> sine waves.
> Or wait for Dieter's quadrature VCO.
> And yes the 143-9 does not track well in the 1v/oct world (for anyone
> bothering with that kind of futilities).
> > In summary here
> > Even if you
> > close enough
> > imprecise because
> > harmonics in our
> > discussion. Even
> > Plan-B Model 15...
> > --- In Doepfer_a100@yahoogroups.com <Doepfer_a100%40yahoogroups.com>, york
> > turned somewhat
> > should rest
> > there.
> > > York
> > > From: kovski774 <kovski@>
> > > To: Doepfer_a100@yahoogroups.com <Doepfer_a100%40yahoogroups.com>
> > > > www. DiN. org. uk
> > > > Athens - Greece
> > > quality?
> > > group
> > > the
> > > cents
> > > traingles and
> > > > > sines?
> > > > > Thanks James,
> > > waveshaper.
> > > signal
> > > want
> > > how it
> > > also
> > > > > have small peaks)
> > > it's not
> > > waveshaper.
> > > 11/24/2008 2:36 PM
My ZO starts to distort at lower freqs (looks like a square with rounded corners). So it's a
sine for only part of its range.
I'm not so much interested about whose *distorted* sine wave sounds best, but who's sine
output actually has no audible harmonic distortion (i.e fundamental only).
--- In Doepfer_a100@yahoogroups.com, Bakis Sirros <synth_freak_2000@...> wrote:
> or maybe Cyndustries Zeroscillator...i think that should also have a very good sinewave.
> that said, i also really like a lot the sine of the A111's (i use them all the time!) and the
sine of the AFG (regarding Euro).
> www. DiN. org. uk
> Athens - Greece
> --- On Fri, 11/28/08, laryn91 <caymus91@...> wrote:
> From: laryn91 <caymus91@...>
> Date: Friday, November 28, 2008, 7:17 PM
you
enough
> there.
> > York
> > ____________ _________ _________ __
> > > www. DiN. org. uk
> > > Athens - Greece
> > quality?
> > group
> > the
> > cents
> > traingles and
> > > > sines?
> > > > Thanks James,
> > waveshaper.
> > signal
> > want
> > how it
> > also
> > > > have small peaks)
> > it's not
> > waveshaper.
> > 11/24/2008 2:36 PM
2008-11-28 by achtung_999
sine waves.
> In summary here
> Even if you
> close enough
> imprecise because
> harmonics in our
> discussion. Even
> Plan-B Model 15...
> turned somewhat
> should rest
> there.
> > York
> > > www. DiN. org. uk
> > > Athens - Greece
> > quality?
> > group
> > the
> > cents
> > traingles and
> > > > sines?
> > > > Thanks James,
> > waveshaper.
> > signal
> > want
> > how it
> > also
> > > > have small peaks)
> > it's not
> > waveshaper.
> > 11/24/2008 2:36 PM
2008-11-28 by Bakis Sirros
that said, i also really like a lot the sine of the A111's (i use them all the time!) and the sine of the AFG (regarding Euro).
www. DiN. org. uk
Athens - Greece
there.
> York
> > www. DiN. org. uk
> > Athens - Greece
> quality?
> group
> the
> cents
> traingles and
> > > sines?
> > > Thanks James,
> waveshaper.
> signal
> want
> how it
> also
> > > have small peaks)
> it's not
> waveshaper.
> 11/24/2008 2:36 PM
maybe you should expand your horizons a bit.It acts quite nicely as a VCO.
It actually smashes the A110 concerning sinewaves.
But be like this man..
Your loss.
> perfect
> > sine waves.
> > > In summary here
> "Sine".
> > > Even if you
> is a
> > > close enough
> > > imprecise because
> > > harmonics in our
> > > discussion. Even
> > > Plan-B Model 15...
> > > --- In Doepfer_a100@yahoogroups.com <Doepfer_a100%40yahoogroups.com><Doepfer_a100%
> > > turned somewhat
> matters
> > > should rest
> > > there.
> > > > York
> > > > To: Doepfer_a100@yahoogroups.com <Doepfer_a100%40yahoogroups.com><Doepfer_a100%
> 40yahoogroups.com>
> quality?
> > > > > www. DiN. org. uk
> > > > > Athens - Greece
> > > > quality?
> > > > group
> > > > the
> > > > cents
> > > > traingles and
> > > > > > sines?
> > > > > > Thanks James,
> > > > waveshaper.
> > > > signal
> > > > want
> > > > how it
> > > > also
> > > > > > have small peaks)
> > > > it's not
> > > > waveshaper.
> > > > 11/24/2008 2:36 PM
2008-11-29 by Monroe Eskew
So what is the purpose of this?  Isn't a slightly imperfect sine
impossible to distinguish aurally?  And can't you filter out any
imperfections to near-silence with an LPF?
> only).
> > www. DiN. org. uk
> > Athens - Greece
> quality?
> as "Sine". Even if
> you
> shape is a close
> enough
> matters should rest
> > there.
> > > York
> quality?
> spoils
> as
> > > > www. DiN. org. uk
> > > > Athens - Greece
> waveform
> > > quality?
> > > group
> > > the
> in
> > > cents
> > > traingles and
> > > > > sines?
> > > > > Thanks James,
> > > waveshaper.
> > > signal
> don't
> > > want
> > > how it
> notes
> > > also
> > > > > have small peaks)
> > > it's not
> the
> as a
> > > waveshaper.
> Date:
> > > 11/24/2008 2:36 PM
2008-11-29 by madrayken
Only just joined this curiously tense thread.
Is there something so fundamentally (unintended joke) annoying about
wanting sine waves when spending well over a thousand pounds on a
mono-synth?
*I* want sine waves as pure as possible because I like using ring mod
which tends to sound rather nasty and noisy with anything other than
pure sines. I know because I've tried using things other than sine
waves, not because someone told me so.
I heard the A110 wasn't a pure sine.
I bought an A111 and a dual cwejman instead.
They produce nice non-noisy sines and the ring mod produced sounds
good to my ears.
I am now happy.
I'm happy to hear what solutions other people have found to the
pure-sine dilemma. I'm also happy to hear that other people don't care
about pure sines - that's interesting in itself, and I love hearing
the work-arounds.
Can't we all move on or play nice?
--- In Doepfer_a100@yahoogroups.com, Monroe Eskew <monroe.eskew@...>
> > only).
> > > www. DiN. org. uk
> > > Athens - Greece
> > > --- On Fri, 11/28/08, laryn91 <caymus91@> wrote:
> > > From: laryn91 <caymus91@>
> > quality?
> > as "Sine". Even if
> > you
> > shape is a close
> > enough
> > matters should rest
> > > there.
> > > > York
> > quality?
> > spoils
> > as
> > > > > www. DiN. org. uk
> > > > > Athens - Greece
> > waveform
> > > > quality?
> > > > group
> > > > the
> > in
> > > > cents
> > > > traingles and
> > > > > > sines?
> > > > > > Thanks James,
> > > > waveshaper.
> > > > signal
> > don't
> > > > want
ng-test.wav
> > > > how it
> > notes
> > > > also
> > > > > > have small peaks)
> > > > it's not
> > the
> > as a
> > > > waveshaper.
> > Date:
> > > > 11/24/2008 2:36 PM
2008-11-29 by laryn91
I don't get it either. All I asked is if anyone knows of any euro VCO that can produce a sine
wave without audible harmonic distortion (Plan-B and ZO so far). To me this a very useful
feature.
But my request seems to get hijacked by self-righteous posters who expect everyone to
either adopt their personal analog synthesis religion or justify their inability to hear
harmonic distortion.
> mono-synth?
> good to my ears.
> I am now happy.
> the work-arounds.
> --- In Doepfer_a100@yahoogroups.com, Monroe Eskew <monroe.eskew@>
> > > only).
> > > > www. DiN. org. uk
> > > > Athens - Greece
> > > quality?
> > > as "Sine". Even if
> > > you
> > > shape is a close
> > > enough
> > > matters should rest
> > > > there.
> > > > > York
> > > quality?
> > > spoils
> > > as
> > > > > > www. DiN. org. uk
> > > > > > Athens - Greece
> > > waveform
> > > > > quality?
> > > > > group
> > > > > the
> > > in
> > > > > cents
> > > > > traingles and
> > > > > > > sines?
> > > > > > > Thanks James,
> > > > > waveshaper.
> > > > > signal
> > > don't
> > > > > want
> ng-test.wav
> > > > > how it
> > > notes
> > > > > also
> > > > > > > have small peaks)
> > > > > it's not
> > > the
> > > as a
> > > > > waveshaper.
> > > Date:
> > > > > 11/24/2008 2:36 PM
Actually the high-quality sine circuit is *quite* common. According to my schematic
library, most vintage oscillators used this standard design. For example, my Aries VCOs
produce a pretty good purity sine using this:
http://www.leinermedia.net/aries/AriesSchematics/AR-317s.gif
My guess is modern VCO designs use the cheap low-quality diode circuit instead because:
A - the simple diode circuit requires no calibration where the Hi-Q one has two trim pots
to set (symmetry and purity).
B - According to this thread it appears many analog users are unaware or inexperienced
with quality VCO sines. So there no customer demand.
BTW, nobody is advocating "pure" sines - just ones with no audible harmonic distortion.
That's certainly is easy to design in analog.
--- In Doepfer_a100@yahoogroups.com, Florian Anwander <fanwander@...> wrote:
> Hi laryn91
sine
useful
> > feature.
> I don't know that there would exist any schematic for this. I never have
> seen a schematic for a pure sine oscillator that is V/Oct voltage
> controlled. I may be wrong, but I think it is not really possible.
> Florian
> Hi laryn91
sine
useful
> > feature.
> Florian
2008-11-29 by Florian Anwander
Hi laryn91
> feature.
Florian
Isn't it true that in theory, analog should have purer waveforms than
digital?  Digitally produced waves are limited by the bit resolution,
so on a small scale they are step functions.  Analog oscillators may
produce distorted shapes but at least they are truly smooth
functions.  Right?
> mono-synth?
> good to my ears.
> I am now happy.
> the work-arounds.
> sounds
> fundamental
> > > only).
> have
> use
> > > > www. DiN. org. uk
> > > > Athens - Greece
> > > quality?
> > > as "Sine". Even if
> > > you
> > > shape is a close
> > > enough
> Fourier),
> it
> think
> > > matters should rest
> > > > there.
> > > > > York
> waveform
> > > quality?
> > > spoils
> presented
> > > as
> Geist
> > > > > > www. DiN. org. uk
> > > > > > Athens - Greece
> > > waveform
> > > > > quality?
> yahoo
> > > > > group
> even join
> > > > > the
> vco
> > > in
> > > > > cents
> > > > > traingles and
> > > > > > > sines?
> > > > > > > Thanks James,
> > > > > waveshaper.
> oct
> > > > > signal
> > > don't
> > > > > want
> test.wav
> ng-test.wav
> that's
> > > > > how it
> > > notes
> > > > > also
> > > > > > > have small peaks)
> means
> > > > > it's not
> how
> > > the
> using
> > > as a
> > > > > waveshaper.
> > > Date:
> > > > > 11/24/2008 2:36 PM
What is the consensus on the AS RS-95?  I don't have an oscilloscope
or a spectrum analyzer, but the sines from mine sound pretty clean,
and when I run it through a filter and sweep the cutoff frequency
above the fundamental, I can't hear any changes, which suggests
harmonic purity.
On Nov 29, 2008, at 9:49 AM, Florian Anwander wrote:
> Hi laryn91
> > feature.
> have
> Florian
Hi Monroe
I don't have the schematics, but estimating from the features in the
owners manual, this sine is derived from the triangle - or it is a
wavetable which is read from a highest quality highspeed VCO (which I
again doubt for this price).
Florian
2008-11-29 by Nicholas Gregorich
In theory maybe you're correct, but what really matters is in practice,
right? ;)
A digital sinusoid can easily be made to have a spurious-free response
greater than the dynamic range of any DAC I know of (and probably
greater than the dynamic range of the analog system the signal ends up
in). In fact with a couple neat tricks I've seen a digital sinusoid
built with a spurious-free response in excess of 150 dB.
Nick
> functions.  Right?
>> mono-synth?
>> good to my ears.
>> I am now happy.
>> the work-arounds.
>> sounds
>> fundamental
>>>> only).
>> have
>> use
>>>>> www. DiN. org. uk
>>>>> Athens - Greece
>>>> quality?
>>>> as "Sine". Even if
>>>> you
>>>> shape is a close
>>>> enough
>> Fourier),
>> it
>> think
>>>> matters should rest
>>>>> there.
>>>>>> York
>> waveform
>>>> quality?
>>>> spoils
>> presented
>>>> as
>> Geist
>>>>>>> www. DiN. org. uk
>>>>>>> Athens - Greece
>>>> waveform
>>>>>> quality?
>> yahoo
>>>>>> group
>> even join
>>>>>> the
>> vco
>>>> in
>>>>>> cents
>>>>>> traingles and
>>>>>>>> sines?
>>>>>>>> Thanks James,
>>>>>> waveshaper.
>> oct
>>>>>> signal
>>>> don't
>>>>>> want
>> test.wav
>> ng-test.wav
>> that's
>>>>>> how it
>>>> notes
>>>>>> also
>>>>>>>> have small peaks)
>> means
>>>>>> it's not
>> how
>>>> the
>> using
>>>> as a
>>>>>> waveshaper.
>>>> Date:
>>>>>> 11/24/2008 2:36 PM
Please give more details - which Euro VCOs are using this circuit?  I don't see this in any
Doepfer VCO nor any of m  ASys. I'm guessing Plan-B and ZO do use it. Who else?
Ask Dieter if it adding 2 additional trimpots, a matched transistor pair and the labor to
calibrate and set two additions parameters  would make a any difference in the price of his
VCOs?
--- In Doepfer_a100@yahoogroups.com, Anthony Rolando <goldenechos@...> wrote:
> I hate to break it to you, but there is nothing terribly different, complex or expensive
about the SINE circuit in the schematic linked below. Pretty common stuff.
> TOny
> > From: caymus91@...
> > Date: Sat, 29 Nov 2008 18:18:24 +0000
VCOs
because:
pots
inexperienced
distortion.
> > --- In Doepfer_a100@yahoogroups.com, Florian Anwander <fanwander@> wrote:
> > > Hi laryn91
produce a
> > sine
very
> > useful
> > > > feature.
> > > Florian
> > Yahoo! Groups Links
> _________________________________________________________________
> Proud to be a PC? Show the world. Download the "I'm a PC" Messenger themepack now.
> hthttp://clk.atdmt.com/MRT/go/119642558/direct/01/
RE: [Doepfer_a100] Re: starting a modular - Z3000 waveform quality?
2008-11-29 by Anthony Rolando
I hate to break it to you, but there is nothing terribly different, complex or expensive about the SINE circuit in the schematic linked below. Pretty common stuff.
TOny
> From: caymus91@mac.com
> > Hi laryn91
> sine
> useful
> > > feature.
> > Florian
Proud to be a PC? Show the world. Download the �I�m a PC� Messenger themepack now.
2008-11-30 by Florian Anwander
Hi Laryn
Sorry, these are converters, but no sine oscillators. it is a sine-like
waveform, but not a sine. Every frequency modulation affects the core
oscillator, not the sine. So the result will be what the waveform
converter makes out of the fm'ed core waveform, but will not be a fm'ed
sine.
Florian
2008-11-30 by laryn91
Hi Florian,
Maybe I don't understand the issue, but seems to me this should FM correctly. The sine
converter *always* maintains an exact phase lock with the tri core. So however the core is
modulated the correct sine phase is produced. Do you have a specific example where this
wouldn't work for FM?
Looking at a the Synclavier FM oscillator design, looks like they too used a triangle-to-
sine converter but in the digital domain. The phase index is a ramp generator (triangle)
that feeds a triangle-to-sine wave lookup table to generate the final sine shape. They
called it "phase modulation" so Yamaha won't sue them, but sounds like pretty good FM to
me.
> Hi Laryn
VCOs
> sine.
> Florian
AW: [Doepfer_a100] Re: starting a modular - Z3000 waveform quality?
2008-12-01 by yahoo@doepfer.de
> Hi laryn91
> > feature.
It's possible. The A-143-9 does this job (kind of a filter in
self-resonance). The only thing we would have to add is the temperature
compensation of the exponential generator to obtain a stable 1V/oct
characteristics. Maybe we can design a A-143-9 Version 2 with this
additional feature.
Best wishes
Dieter Doepfer
2008-12-01 by Monroe Eskew
I'm just curious what relevance to music is.  It doesn't make sense to
complain when a flute doesn't produce a pure sine.  Each instrument
has its own character and musical desirability.  Lots of the best
tones from analog synths are far from pure sine.  I can see why
someone would want that pure sine sound in a particular musical
application, but can't you approximate it well enough for musical
purposes with standard equipment like A111 or RS95, or as you mention
M15 or ZO?  If you run it through a strong LPF with no resonance then
you further shape the wave towards sine perfection.
I'm just wondering if you are interested in musical applications or
maybe scientific applications instead?  Or are you just a
perfectionist?  (It's OK if you are.)
Monroe
> feature.
> expect everyone to
> > mono-synth?
> mod
> > good to my ears.
> > I am now happy.
> care
> > the work-arounds.
> sounds
> fundamental
> > > > only).
> also have
> (i use
> > > > > www. DiN. org. uk
> > > > > Athens - Greece
> waveform
> > > > quality?
> peaks
> > > > as "Sine". Even if
> > > > you
> looking
> > > > shape is a close
> > > > enough
> with no
> disapproval of
> Fourier),
> although it
> think
> > > > matters should rest
> > > > > there.
> > > > > > York
> waveform
> > > > quality?
> > > > spoils
> presented
> > > > as
> Geist
> > > > > > > www. DiN. org. uk
> > > > > > > Athens - Greece
> > > > waveform
> > > > > > quality?
> or yahoo
> > > > > > group
> even join
> > > > > > the
> the vco
> > > > in
> > > > > > cents
> better
> > > > > > traingles and
> > > > > > > > sines?
> > > > > > > > Thanks James,
> > > > > > waveshaper.
> 1v/oct
> > > > > > signal
> You
> > > > don't
> > > > > > want
> test.wav
> > ng-test.wav
> notes, that's
> > > > > > how it
> low
> > > > notes
> > > > > > also
> > > > > > > > have small peaks)
> peaks means
> > > > > > it's not
> is how
> > > > the
> using
> > > > as a
> > > > > > waveshaper.
> Release
> > > > Date:
> > > > > > 11/24/2008 2:36 PM
2008-12-01 by Argitoth
perfect sines can create sound that only perfect sines can create,
musical and non-musical.
> Monroe
>> feature.
>> expect everyone to
>> > mono-synth?
>> mod
>> > good to my ears.
>> > I am now happy.
>> care
>> > the work-arounds.
>> sounds
>> fundamental
>> > > > only).
>> also have
>> (i use
>> > > > > www. DiN. org. uk
>> > > > > Athens - Greece
>> waveform
>> > > > quality?
>> peaks
>> > > > as "Sine". Even if
>> > > > you
>> looking
>> > > > shape is a close
>> > > > enough
>> with no
>> disapproval of
>> Fourier),
>> although it
>> think
>> > > > matters should rest
>> > > > > there.
>> > > > > > York
>> waveform
>> > > > quality?
>> > > > spoils
>> presented
>> > > > as
>> Geist
>> > > > > > > www. DiN. org. uk
>> > > > > > > Athens - Greece
>> > > > waveform
>> > > > > > quality?
>> or yahoo
>> > > > > > group
>> even join
>> > > > > > the
>> the vco
>> > > > in
>> > > > > > cents
>> better
>> > > > > > traingles and
>> > > > > > > > sines?
>> > > > > > > > Thanks James,
>> > > > > > waveshaper.
>> 1v/oct
>> > > > > > signal
>> You
>> > > > don't
>> > > > > > want
>> test.wav
>> > ng-test.wav
>> notes, that's
>> > > > > > how it
>> low
>> > > > notes
>> > > > > > also
>> > > > > > > > have small peaks)
>> peaks means
>> > > > > > it's not
>> is how
>> > > > the
>> using
>> > > > as a
>> > > > > > waveshaper.
>> Release
>> > > > Date:
>> > > > > > 11/24/2008 2:36 PM
www.elanhickler.com
VC electro-motor?
2008-12-01 by Denis Gökdag
Hi all,
i want to build myself a little VC electro motor, you know, one of
these little model-plane 12V motors but with VC RPM. It's not supposed
to track V/oct cleanly, just be somewhat predictably controllable via
a CV.
I'm not much of an electronics genius, but i figured that i would use
a non-inverting amp based on an OP-amp to buffer the CV, then use the
output as the voltage to drive the motor (the second connector of the
motor being connected to ground).  Obviously, the Op-amp would be
powered by the a-100 +/-12 V, so the design should be able to output
-12...12V to drive the motor (with the negative voltage reversing
direction).
Does that sound about right?
cheers,
denis
You could say that about any waveform, instrument, songbird, or
Christopher Walken.
> to
> mention
> > Monroe
> >> feature.
> >> expect everyone to
> about
> >> > mono-synth?
> >> mod
> than
> sine
> sounds
> >> > good to my ears.
> >> > I am now happy.
> >> care
> hearing
> >> > the work-arounds.
> with
> >> sounds
> >> fundamental
> >> > > > only).
> >> also have
> >> (i use
> Geist
> >> > > > > www. DiN. org. uk
> >> > > > > Athens - Greece
> >> waveform
> >> > > > quality?
> sine
> >> peaks
> >> > > > as "Sine". Even if
> >> > > > you
> >> looking
> >> > > > shape is a close
> >> > > > enough
> always
> >> with no
> >> disapproval of
> >> Fourier),
> >> although it
> and I
> >> think
> >> > > > matters should rest
> >> > > > > there.
> >> > > > > > York
> >> waveform
> >> > > > quality?
> trainwreck,
> >> > > > spoils
> >> presented
> >> > > > as
> Memory
> >> Geist
> >> > > > > > > www. DiN. org. uk
> >> > > > > > > Athens - Greece
> Z3000
> >> > > > waveform
> >> > > > > > quality?
> >> or yahoo
> >> > > > > > group
> >> even join
> >> > > > > > the
> >> the vco
> >> > > > in
> >> > > > > > cents
> t=2158
> t=2158
> >> better
> >> > > > > > traingles and
> >> > > > > > > > sines?
> >> > > > > > > > Thanks James,
> as a
> >> > > > > > waveshaper.
> >> 1v/oct
> >> > > > > > signal
> attenuator.
> >> You
> >> > > > don't
> >> > > > > > want
> ng-
> >> test.wav
> >> > ng-test.wav
> >> notes, that's
> >> > > > > > how it
> that
> >> low
> >> > > > notes
> >> > > > > > also
> >> > > > > > > > have small peaks)
> >> peaks means
> >> > > > > > it's not
> >> is how
> >> > > > the
> >> using
> >> > > > as a
> >> > > > > > waveshaper.
> >> Release
> >> > > > Date:
> >> > > > > > 11/24/2008 2:36 PM
> www.elanhickler.com
2008-12-01 by laryn91
By your question, I'm guessing you're either unfamiliar with or never designed sounds
using Additive Synthesis. But quality sines are a necessary component for these cool class
of sounds. For example, if you wanted to create a sound similar in character and dynamics
of a flute, you could probably make a pretty good one controlling 3 or 4 sine wave
oscillators as the excitation. There are many sources for info on the web about Additive
Synthesis if you're interested. You can't make the same type of dynamic sounds with only
subtractive synthesis.
I also find the sine very useful as a natural sounding modulation source. The A-111
rounded peak triangle wave lacks that natural characteristic. And if you want more fine
and subtle control for FM, nothing beats a sine!
A sine wave is useful as building block only if it contains the fundamental and no
overtones. An audibly distorted sine wave is not "character", but imprecision and
sloppiness. If the A-111 outputs a triangle-with-rounded-peaks, it should not mislead
customers and spec it as a "Sine". Call it Tri2 or Soft Tri instead. A Sine means something
very specific:
http://en.wikipedia.org/wiki/Sine_wave
If the A-111 produced ramped or rounded edge waves at its "Square" wave out jack -
would you think that's "character " or just a faulty or bad design?
> Monroe
> > feature.
> > expect everyone to
> > --- In Doepfer_a100@yahoogroups.com, "madrayken" <dene.carter@>
> > > mono-synth?
> > mod
> > > good to my ears.
> > > I am now happy.
> > care
> > > the work-arounds.
> > sounds
> > fundamental
> > > > > only).
> > also have
> > (i use
> > > > > > www. DiN. org. uk
> > > > > > Athens - Greece
> > waveform
> > > > > quality?
> > peaks
> > > > > as "Sine". Even if
> > > > > you
> > looking
> > > > > shape is a close
> > > > > enough
> > with no
> > disapproval of
> > Fourier),
> > although it
> > think
> > > > > matters should rest
> > > > > > there.
> > > > > > > York
> > waveform
> > > > > quality?
> > > > > spoils
> > presented
> > > > > as
> > Geist
> > > > > > > > www. DiN. org. uk
> > > > > > > > Athens - Greece
> > > > > waveform
> > > > > > > quality?
> > or yahoo
> > > > > > > group
> > even join
> > > > > > > the
> > the vco
> > > > > in
> > > > > > > cents
> > better
> > > > > > > traingles and
> > > > > > > > > sines?
> > > > > > > > > Thanks James,
> > > > > > > waveshaper.
> > 1v/oct
> > > > > > > signal
> > You
> > > > > don't
> > > > > > > want
> > test.wav
> > > ng-test.wav
> > notes, that's
> > > > > > > how it
> > low
> > > > > notes
> > > > > > > also
> > > > > > > > > have small peaks)
> > peaks means
> > > > > > > it's not
> > is how
> > > > > the
> > using
> > > > > as a
> > > > > > > waveshaper.
> > Release
> > > > > Date:
> > > > > > > 11/24/2008 2:36 PM
Re: [Doepfer_a100] VC electro-motor?
2008-12-01 by achtung_999
I'd say check out how much current this baby is going to suck from the a100.You
don't want to blow the powersupply in your a100, I guess.
P = I * U
So check the wattage of the motor.
But you probably already did.
Greets
Ernst
On Mon, Dec 1, 2008 at 4:05 PM, Denis Gökdag <q-art@gmx.net> wrote:
>   Hi all,
> a CV.
> direction).
> cheers,
> denis
Good point, i guess i'll want to use some PC power supply for the motor.
Cheers!
d
> the a100.You
> P = I * U
> Greets
> Ernst
> > Hi all,
> supposed
> via
> > a CV.
> use
> the
> the
> > direction).
> > cheers,
> > denis
You must fall into this group:
" I'm guessing you're either unfamiliar with or never
> designed sounds
> using Additive Synthesis. "
I and many others successfully use Additive techniques on our analog synthesizers every
day. Just because YOU can't or don't know how, you shouldn't make pompus blanket
statements like yours below.
It only exposes your lack of depth in analog synthesis techniques ;-)
wrote:
> "For example, if you wanted to create a sound similar in character and
> dynamics
> sine wave
> about Additive
> Synthesis if you're interested."
> I think it is rather extremely naïve that you think you can model natural
> sounds with additive synthesis.History has proven that many people thought
> it was possible but failed in the end.
> Why?
> They could not get the phases of the seperate sine building blocks correctly
> lined up with analog oscillators.
> I guess you could do with reading some of monsieur Fourier's theory.
> It wasn't until computers got significantly powerful enough that Fourier's
> theories could be implemented fully.
> And then still....
> I have nothing against additive synthesis and i understand your need for
> true sine function oscillators for this.
> But please don't act like additive synthesis is going to give you a good
> imitation of an 'existing real life' sound..
> Greetings,
> Ernst
> > designed sounds
> > these cool class
> > sine wave
> > about Additive
> > sounds with only
> > The A-111
> > want more fine
> > and no
> > imprecision and
> > not mislead
> > means something
> > very specific:
> > jack -
> > > Monroe
> > > > feature.
> > > > expect everyone to
> > > > > mono-synth?
> > > > mod
> > > > > good to my ears.
> > > > > I am now happy.
> > > > care
> > > > > the work-arounds.
> > > > sounds
> > > > fundamental
> > > > > > > only).
> > > > > > > --- In
Doepfer_a100@yahoogroups.com<Doepfer_a100%40yahoogroups.com>,
> > Bakis Sirros
> > > > also have
> > > > (i use
> > > > > > > > www. DiN. org. uk
> > > > > > > > Athens - Greece
> > > > waveform
> > > > > > > quality?
> > > > > > > > To:
> > > > peaks
> > > > > > > as "Sine". Even if
> > > > > > > you
> > > > looking
> > > > > > > shape is a close
> > > > > > > enough
> > > > with no
> > > > disapproval of
> > > > Fourier),
> > > > although it
> > > > think
> > > > > > > matters should rest
> > > > > > > > there.
> > > > > > > > > York
> > > > waveform
> > > > > > > quality?
> > > > > > > spoils
> > > > presented
> > > > > > > as
> > > > Geist
> > > > > > > > > > www. DiN. org. uk
> > > > > > > > > > Athens - Greece
> > > > > > > waveform
> > > > > > > > > quality?
> > > > or yahoo
> > > > > > > > > group
> > > > even join
> > > > > > > > > the
> > > > the vco
> > > > > > > in
> > > > > > > > > cents
> > php?t=2158
> > > > better
> > > > > > > > > traingles and
> > > > > > > > > > > sines?
> > > > > > > > > > > Thanks James,
> > > > > > > > > waveshaper.
> > > > 1v/oct
> > > > > > > > > signal
> > > > You
> > > > > > > don't
> > > > > > > > > want
> > > > test.wav
> > > > > ng-test.wav
> > > > notes, that's
> > > > > > > > > how it
> > > > low
> > > > > > > notes
> > > > > > > > > also
> > > > > > > > > > > have small peaks)
> > > > peaks means
> > > > > > > > > it's not
> > > > is how
> > > > > > > the
> > > > using
> > > > > > > as a
> > > > > > > > > waveshaper.
> > > > Release
> > > > > > > Date:
> > > > > > > > > 11/24/2008 2:36 PM
2008-12-01 by Derek Holzer
I've been using this PWM circuit to run motors:
http://solorb.com/elect/pwm/pwm1/
Main thing is to use a transistor to do the actual PWM instead of
running too much current through the opamps themselves. You could
replace the potentiometer for the PWM with a vactrol of some sort and it
should work fine for VC. It's something I mean to try myself. I run six
of these circuits and six 12V cassette player motors from a 12V 0.3 amp
wall wart, so the draw isn't that heavy at all. You don't want the PWM
mixed in with your synthesizer grounds however, since it's super noisy!
So yes, use another PSU, but it doesn't need to be so heavy duty.
Unfortunately, this circuit doesn't do reverse. For that, you will need
to investigate an IC called an H-Bridge, which can switch from positive
to negative. Most datasheets of an H Bridge will give a simple app for
this. You should also look at the documentation of the Arduino project
for simple PWM motor control circuits, there should be one with an H
Bridge in there as well.
best!
Derek
Denis Gökdag wrote:
> Hi all,
> a CV.
> direction).
> cheers,
> denis
derek holzer ::: http://www.umatic.nl ::: http://blog.myspace.com/macumbista
---Oblique Strategy # 137:
"Repetition is a form of change"
Ooooooorrrrrrr....... use the PWM out of one of your oscillators to
control the MOSFET transistor directly. That would be the most simple
solution, then you could get rid of everything to the left of R9 in that
schematic, as that is the part which makes the square wave PWM. In that
case, just use your separate 12V PSU connected via the protection diodes
to the "D" of the transistor.
Still doesn't do reverse, but that's where the H Bridge would come in.
best,
d.
> best!
> Derek
> Denis Gökdag wrote:
>> Hi all,
>> a CV.
>> direction).
>> cheers,
>> denis
>> Yahoo! Groups Links
---Oblique Strategy # 153:
"The inconsistency principle"
dynamics
sine wave
about Additive
Why?
And then still....
Greetings,
Ernst
> designed sounds
> these cool class
> sine wave
> about Additive
> sounds with only
> The A-111
> want more fine
> and no
> imprecision and
> not mislead
> means something
> very specific:
> jack -
> > Monroe
> > > feature.
> > > expect everyone to
> > > > mono-synth?
> > > mod
> > > > good to my ears.
> > > > I am now happy.
> > > care
> > > > the work-arounds.
> > > sounds
> > > fundamental
> > > > > > only).
> > > > > > --- In Doepfer_a100@yahoogroups.com<Doepfer_a100%40yahoogroups.com>,
> Bakis Sirros
> > > also have
> > > (i use
> > > > > > > www. DiN. org. uk
> > > > > > > Athens - Greece
> > > waveform
> > > > > > quality?
> > > > > > > To: Doepfer_a100@yahoogroups.com<Doepfer_a100%40yahoogroups.com>
> > > peaks
> > > > > > as "Sine". Even if
> > > > > > you
> > > looking
> > > > > > shape is a close
> > > > > > enough
> > > with no
> > > disapproval of
> > > Fourier),
> > > although it
> > > think
> > > > > > matters should rest
> > > > > > > there.
> > > > > > > > York
> > > waveform
> > > > > > quality?
> > > > > > spoils
> > > presented
> > > > > > as
> > > Geist
> > > > > > > > > www. DiN. org. uk
> > > > > > > > > Athens - Greece
> > > > > > waveform
> > > > > > > > quality?
> > > or yahoo
> > > > > > > > group
> > > even join
> > > > > > > > the
> > > the vco
> > > > > > in
> > > > > > > > cents
> php?t=2158
> > > better
> > > > > > > > traingles and
> > > > > > > > > > sines?
> > > > > > > > > > Thanks James,
> > > > > > > > waveshaper.
> > > 1v/oct
> > > > > > > > signal
> > > You
> > > > > > don't
> > > > > > > > want
> > > test.wav
> > > > ng-test.wav
> > > notes, that's
> > > > > > > > how it
> > > low
> > > > > > notes
> > > > > > > > also
> > > > > > > > > > have small peaks)
> > > peaks means
> > > > > > > > it's not
> > > is how
> > > > > > the
> > > using
> > > > > > as a
> > > > > > > > waveshaper.
> > > Release
> > > > > > Date:
> > > > > > > > 11/24/2008 2:36 PM
I agree. My professional expertise is in speech research and speech synthesis and studies
have shown the human ear cannot distinguish static phase relationships in a monophonic
signal.
BTW, looking at many of the posts for this thread (not yours), I notice arguments are often
extreme black and white from the usual confrontational posters. If you can't do Additive
synthesis 100% on analog then it's useless. If you can't make a pure 0% THD sine, then
they are useless. Useful sines can only be generated by sine cores, etc...
I find a lot of utility with my 1% THD triangle converted sines in Additive and FM
applications :-)
--- In Doepfer_a100@yahoogroups.com, Chris Muir <cbm@...> wrote:
> > natural
> > thought
> There have a number of pretty good additive synthesis and resynthesis
> projects. Several systems, albeit digital, allowed phases to roll
> freely. There have price barriers in commercializing these, though.
> There are certainly challenges in implementing an additive system with
> analog electronics, but keeping phase relationships might not be as
> important as you think, though.
> - C
> Chris Muir
> cbm@...
> http://www.xfade.com
Go on be naive.
> > designed sounds
> synthesizers every
> blanket
> > dynamics
> > sine wave
> > about Additive
> thought
> > Why?
> correctly
> Fourier's
> > And then still....
> > Greetings,
> > Ernst
> > > designed sounds
> for
> > > these cool class
> 4
> > > sine wave
> web
> > > about Additive
> > > sounds with only
> source.
> > > The A-111
> you
> > > want more fine
> fundamental
> > > and no
> > > imprecision and
> should
> > > not mislead
> Sine
> > > means something
> > > very specific:
> out
> > > jack -
> 40yahoogroups.com>,
> > > > Monroe
> > > > > feature.
> > > > > expect everyone to
> > > > > --- In Doepfer_a100@yahoogroups.com<Doepfer_a100%40yahoogroups.com><Doepfer_a100%
> 40yahoogroups.com>,
> about
> > > > > > mono-synth?
> > > > > mod
> than
> sine
> sounds
> > > > > > good to my ears.
> > > > > > I am now happy.
> > > > > care
> hearing
> > > > > > the work-arounds.
> with
> > > > > sounds
> > > > > fundamental
> > > > > > > > only).
> > > > > > > > --- In
> > > Bakis Sirros
> > > > > also have
> > > > > (i use
> Geist
> > > > > > > > > www. DiN. org. uk
> > > > > > > > > Athens - Greece
> > > > > waveform
> > > > > > > > quality?
> > > > > > > > > To:
> sine
> > > > > peaks
> > > > > > > > as "Sine". Even if
> > > > > > > > you
> > > > > looking
> > > > > > > > shape is a close
> > > > > > > > enough
> always
> > > > > with no
> > > > > disapproval of
> > > > > Fourier),
> > > > > although it
> I
> > > > > think
> > > > > > > > matters should rest
> > > > > > > > > there.
> > > > > > > > > > York
> > > > > waveform
> > > > > > > > quality?
> trainwreck,
> > > > > > > > spoils
> > > > > presented
> > > > > > > > as
> Memory
> > > > > Geist
> > > > > > > > > > > www. DiN. org. uk
> > > > > > > > > > > Athens - Greece
> Z3000
> > > > > > > > waveform
> > > > > > > > > > quality?
> > > > > or yahoo
> > > > > > > > > > group
> > > > > even join
> > > > > > > > > > the
> > > > > the vco
> > > > > > > > in
> > > > > > > > > > cents
> php?t=2158
> > > php?t=2158
> > > > > better
> > > > > > > > > > traingles and
> > > > > > > > > > > > sines?
> > > > > > > > > > > > Thanks James,
> a
> > > > > > > > > > waveshaper.
> > > > > 1v/oct
> > > > > > > > > > signal
> attenuator.
> > > > > You
> > > > > > > > don't
> > > > > > > > > > want
> ng-
> > > > > test.wav
> > > > > > ng-test.wav
> > > > > notes, that's
> > > > > > > > > > how it
> that
> > > > > low
> > > > > > > > notes
> > > > > > > > > > also
> > > > > > > > > > > > have small peaks)
> > > > > peaks means
> > > > > > > > > > it's not
> > > > > is how
> > > > > > > > the
> > > > > using
> > > > > > > > as a
> > > > > > > > > > waveshaper.
> > > > > Release
> > > > > > > > Date:
> > > > > > > > > > 11/24/2008 2:36 PM
You are really trolling eh?
Maybe you should open up and try to see what people are trying to tell you.
As you read on the bottom I have nothing against additive synthesis as
a creative
tool.
But scientificly additive synthesis does not make sense in the analog
domain.
Unless you have  total control over the phase domain.
It is not for nothing that the history of hands on additive synthesis starts
at the synclavier.
But hey, history is boring when you are 19 eh?
On Mon, Dec 1, 2008 at 7:20 PM, achtung_999 <heinrich.himmelwasser@gmail.com
> wrote:
> Go on be naive.
>> > designed sounds
>> synthesizers every
>> blanket
>> > dynamics
>> > sine wave
>> web
>> > about Additive
>> natural
>> thought
>> > Why?
>> correctly
>> Fourier's
>> > And then still....
>> > Greetings,
>> > Ernst
>> > > designed sounds
>> for
>> > > these cool class
>> 4
>> > > sine wave
>> web
>> > > about Additive
>> dynamic
>> > > sounds with only
>> source.
>> > > The A-111
>> you
>> > > want more fine
>> fundamental
>> > > and no
>> > > imprecision and
>> should
>> > > not mislead
>> Sine
>> > > means something
>> > > very specific:
>> wave out
>> > > jack -
>> 40yahoogroups.com>,
>> to
>> mention
>> > > > Monroe
>> To
>> > > > > feature.
>> > > > > expect everyone to
>> 40yahoogroups.com>,
>> about
>> a
>> > > > > > mono-synth?
>> ring
>> > > > > mod
>> than
>> sine
>> sounds
>> > > > > > good to my ears.
>> > > > > > I am now happy.
>> don't
>> > > > > care
>> hearing
>> > > > > > the work-arounds.
>> sine
>> any
>> with
>> > > > > sounds
>> > > > > fundamental
>> > > > > > > > only).
>> > > > > > > > --- In
>> > > Bakis Sirros
>> > > > > also have
>> > > > > (i use
>> Geist
>> > > > > > > > > www. DiN. org. uk
>> > > > > > > > > Athens - Greece
>> > > > > waveform
>> > > > > > > > quality?
>> > > > > > > > > To:
>> sine
>> > > > > peaks
>> > > > > > > > as "Sine". Even if
>> > > > > > > > you
>> > > > > looking
>> > > > > > > > shape is a close
>> > > > > > > > enough
>> always
>> > > > > with no
>> > > > > disapproval of
>> > > > > Fourier),
>> > > > > although it
>> I
>> > > > > think
>> > > > > > > > matters should rest
>> > > > > > > > > there.
>> > > > > > > > > > York
>> > > > > waveform
>> > > > > > > > quality?
>> trainwreck,
>> > > > > > > > spoils
>> > > > > presented
>> > > > > > > > as
>> Memory
>> > > > > Geist
>> > > > > > > > > > > www. DiN. org. uk
>> > > > > > > > > > > Athens - Greece
>> Z3000
>> > > > > > > > waveform
>> > > > > > > > > > quality?
>> list
>> > > > > or yahoo
>> > > > > > > > > > group
>> > > > > even join
>> > > > > > > > > > the
>> > > > > the vco
>> > > > > > > > in
>> > > > > > > > > > cents
>> php?t=2158
>> > > php?t=2158
>> > > > > better
>> > > > > > > > > > traingles and
>> > > > > > > > > > > > sines?
>> > > > > > > > > > > > Thanks James,
>> as a
>> > > > > > > > > > waveshaper.
>> a
>> > > > > 1v/oct
>> > > > > > > > > > signal
>> attenuator.
>> > > > > You
>> > > > > > > > don't
>> > > > > > > > > > want
>> ng-
>> > > > > test.wav
>> > > > > > ng-test.wav
>> > > > > notes, that's
>> > > > > > > > > > how it
>> that
>> > > > > low
>> > > > > > > > notes
>> > > > > > > > > > also
>> > > > > > > > > > > > have small peaks)
>> > > > > peaks means
>> > > > > > > > > > it's not
>> > > > > is how
>> > > > > > > > the
>> worth
>> > > > > using
>> > > > > > > > as a
>> > > > > > > > > > waveshaper.
>> > > > > Release
>> > > > > > > > Date:
>> > > > > > > > > > 11/24/2008 2:36 PM
2008-12-01 by Chris Muir
> natural
> thought
- C
Chris Muir
cbm@well.com
I'm actually agreeing with you. I was referring to the common argument since a pure sine
is not possible, so the crappy 10%-20% THD sines from Deopfer, Tip Top, ASys etc.
should be good enough for us.
Maybe try to do better since it's been known for 40 years that it's easy and simple to get
cleaner sines with less than 1% THD.
> ... I don't understand why people can't accept the fact some of us
> desire perfection.
> On Mon, Dec 1, 2008 at 12:22 PM, achtung_999
> <heinrich.himmelwasser@...> wrote:
> > I don't intend to be a 'confrontational' poster. Have never been in this
> > board but this thread has too much people talking past eachother.I'm off
> > this thread, have fun splitting hairs.
> >> a
> >> monophonic
> >> signal.
> >> arguments are often
> >> can't do Additive
> >> THD
> >> sine, then
> >> Additive
> >> and FM
> >> applications :-)
> >> > > natural
> >> > > thought
> >> > - C
> >> > Chris Muir
> >> > cbm@
> www.elanhickler.com
Thanks for that Chris.I know of some very good systems myself too.
Try SPEAR: http://www.klingbeil.com/spear/
But the aim of my message was to find out why these people are on one hand
hammering on a true scientificly perfect sine wave generator and then on the
other hand ignore the scientific part of additive synthesis.
> > natural
> > thought
> - C
> Chris Muir
> cbm@well.com <cbm%40well.com>
2008-12-01 by york luethje
Additive synthesis? Why, I'd NEVER heard of that! What a cool concept. You mean one can construct sounds by adding, rather than substracting? Fascinating. A whole new world just opened up for me. Thank you! Thank you!
Sent: Monday, December 1, 2008 11:49:15 AM
sloppiness. If the A-111 outputs a triangle-with- rounded-peaks, it should not mislead
very specific:
http://en.wikipedia .org/wiki/ Sine_wave
--- In Doepfer_a100@ yahoogroups. com, Monroe Eskew <monroe.eskew@ ...> wrote:
> Monroe
> > feature.
> > expect everyone to
> > --- In Doepfer_a100@ yahoogroups. com, "madrayken" <dene.carter@ >
> > > mono-synth?
> > mod
> > > good to my ears.
> > > I am now happy.
> > care
> > > the work-arounds.
> > > --- In Doepfer_a100@ yahoogroups. com, Monroe Eskew <monroe.eskew@ >
> > sounds
> > fundamental
> > > > > only).
> > > > > > or maybe Cyndustries Zeroscillator. ..i think that should
> > also have
> > (i use
> > > > > > www. DiN. org. uk
> > > > > > Athens - Greece
> > waveform
> > > > > quality?
> > peaks
> > > > > as "Sine". Even if
> > > > > you
> > looking
> > > > > shape is a close
> > > > > enough
> > with no
> > disapproval of
> > Fourier),
> > although it
> > think
> > > > > matters should rest
> > > > > > there.
> > > > > > > York
> > waveform
> > > > > quality?
> > > > > spoils
> > presented
> > > > > as
> > Geist
> > > > > > > > www. DiN. org. uk
> > > > > > > > Athens - Greece
> > > > > waveform
> > > > > > > quality?
> > or yahoo
> > > > > > > group
> > even join
> > > > > > > the
> > the vco
> > > > > in
> > > > > > > cents
> > better
> > > > > > > traingles and
> > > > > > > > > sines?
> > > > > > > > > Thanks James,
> > > > > > > waveshaper.
> > 1v/oct
> > > > > > > signal
> > You
> > > > > don't
> > > > > > > want
> > test.wav
> > > ng-test.wav
> > notes, that's
> > > > > > > how it
> > low
> > > > > notes
> > > > > > > also
> > > > > > > > > have small peaks)
> > peaks means
> > > > > > > it's not
> > is how
> > > > > the
> > using
> > > > > as a
> > > > > > > waveshaper.
> > Release
> > > > > Date:
> > > > > > > 11/24/2008 2:36 PM
> monophonic
> signal.
> arguments are often
> can't do Additive
> sine, then
> and FM
> applications :-)
> > > natural
> > > thought
> > - C
> > Chris Muir
> > cbm@...
desire perfection.
>> a
>> monophonic
>> signal.
>> arguments are often
>> can't do Additive
>> THD
>> sine, then
>> Additive
>> and FM
>> applications :-)
>> > > natural
>> > > thought
>> > - C
>> > Chris Muir
>> > cbm@...
www.elanhickler.com
2008-12-02 by p. hendricks
> desire perfection.
Duke Ellington: "If it sounds good, it IS good."
perfect anything doesn't mean it sounds good, it just all will sound the
same, plenty of great pre-amps out there, but classics are always quite
colored like the the Neve. There are plenty of pre-amp with better specs
than the neve for $100, but a Neve is still a $3000+ preamp.
If you want perfect, that is software/digital the only reason analog still
exists is because it often sounds better, why, the imperfections.
Analog: tweaked until it sounds good
Digital: tweaked until it looks good
as for that sine, no one cared about that poor sine wave until about 10
years ago. Many synths don't offer it, even Blacet wasn't going to include
it on their VCO, until enough of us asked about it. So it probably is an
after-thought on many modules especially on designs older than 5 years. The
sine was really dead until microsound folks like Ryoji Ikeda started to
exploit it. Still those "perfect" sterile waves were from test equipment or
computers, as it took a mammoth $5000.00 test osc to produce such perfect
sines for them or the computer which could easily do it. But without out
even the subtle imperfections that analog will always exhibit and gives it
it's uniqueness often "warmth."
Since you're result is audio, I'd kinda think you you should base your
direction and opinions on what sounds good to you.
-p
2008-12-02 by Argitoth
p. hendricks, Analog sines can be perfect enough as proven by some of
the modules out now and in production, nothing more needs to be said.
All we need now is good 1v/oct for whatever modules are producing
those sines.
>> desire perfection.
> -p
www.elanhickler.com
if it's perfect, digital is much more efficient/cheaper and more perfect.
> those sines.
why's that? is someone going to hear them in a musical application? then You
probably don't want perfect as they won't have character or sound good....
if you want perfect, digital is where it's at... simple.
if a digital perfect sine sounds good to you why would you want the 100,000+
fold expense of re-creating something so mathematically simple and sterile
in with analog components?  We now have computers that can do this math,
it's perfect... but do you like how it sounds.
What are you trying to achieve?
Sine wave discussion
2008-12-02 by yahoo@doepfer.de
I will not participate in the emotional discussion about sine waves but want
to mention some technical details (some of these have been already mentioned
earlier):
All standard VCO circuits I know are based on a sawtooth or triangle core.
When the sine wave is derived from one of these VCO cores you will never
obtain a perfect sine. The antiparallel diodes are the simplest solution to
derive a sine-like wave from a triangle, the FET circuit is a bit better but
even far away from beeing perfect. Each kind of waveform converter is a
compromise (except rectangle). If you want a perfect sine you need a VCO
with a sine core. And in return: if you want a perfect triangle you need a
VCO with a triangle core, if you want a perfect sawtooth ...
The A-143-9 is the only oscillator in the A-100 that uses a sine core.
Though it was not planned as a VCO but mainly VCLFO it can be (ab)used as
sine VCO. The main drawback of the A-143-9 is the missing temperature
compensation of the exponential generator. We consider to develop a sine VCO
based on the A-143-9 circuit but with a temperature compensated exponential
generator. I expect that the price would be in the Euro 100 range. We are
also working on a VCO with sine core and linear FM with thru-zero feature.
But this is another "construction site" because the linear FM and thru-zero
feature is much more complicated than adding "only" the temperature
compensation.
And we will point out in the module information and user's guide of A-110
and A-111 that the sine outputs should be called more precisely "sine-like".
But even rectangles or triangles are not perfect (each rectangle is kind of
trapezoid as each rising and falling edge has a slope that depends on the
inherent slew limiting characteristic of analog circuitry).
Best wishes
Dieter Doepfer
AW: [Doepfer_a100] VC electro-motor?
> Hi all,
> a CV.
> direction).
> cheers,
> denis
Denis,
I don't think that a standard opamp can do the job unless you use a motor
that requires only a few milliamperes.
The next step would be to add a power output to a standard opamp. For motor
control 2 power transistors added to the opamp output (one npn and one pnp)
should do the job. I can send you the schematics directly if you want.
But this will not generate a RPM that's reasonably proportional to the
applied voltage. Each motor has an "offset" voltage. Below this voltage the
motor will not work, i.e. you have to apply e.g. 6V before a 12V motor will
begin to run. Only in the working range (e.g. +6...+12V) you will have a
behaviour with RPM reasonably proportional to the applied voltage.
Best wishes
Dieter Doepfer
2008-12-02 by Denis Gökdag
Hey Derek,
excellent advice....thanks :-)  PWM makes a lot of sense, and that
circuit looks like i may actually be able to get that soldered *grin*
What are you dong with those tape motors?
d
> that
> that
> diodes
> best,
> d.
> and it
> run six
> 0.3 amp
> PWM
> noisy!
> need
> positive
> for
> project
> > best!
> > Derek
> > Denis Gökdag wrote:
> >> Hi all,
> supposed
> via
> >> a CV.
> use
> the
> the
> output
> >> direction).
> >> cheers,
> >> denis
> >> Yahoo! Groups Links
Re: AW: [Doepfer_a100] VC electro-motor?
Hi Dieter,
thanks for the advice. The PWM-based circuit that Derek mentioned
should help overcome that "offset" voltage in the motor, right? (as in
such a pulse-based circuit, you always apply the full 12V
voltage.....just not all the time).
Basically the idea is to use a CV to modulate the PW of a VCO (the
a-111 goes from 0% PW to 100% PW IIRC), then use this VCO to drive a
power amp as shown here http://solorb.com/elect/pwm/
pwm1/    .....which basically is similar to controlling RPM with the CV.
(omitting the comparator circuit, and plugging the 111 into R9).
This is gonna be fun :-)
denis
On Dec 2, 2008, at 10:26 AM, <yahoo@doepfer.de> <yahoo@doepfer.de>
wrote:
> > Hi all,
> supposed
> via
> > a CV.
> use
> the
> the
> > direction).
> > cheers,
> > denis
> Denis,
> motor
> For motor
> one pnp)
> voltage the
> motor will
> have a
> Best wishes
> Dieter Doepfer
AW: AW: [Doepfer_a100] VC electro-motor?
> Hi Dieter,
> Cheers,
> denis
I'm not sure if the PWM will solve the offset problem. After all the motor
works as a "low pass" filter for the PWM. Consequently e.g. a 25% PWM
voltage with 12V level should cause the same result as 3V DC. As far as I
know the main reason for PWM was the power dissipation of the control
electronics as switching causes much less unneeded heat than linear DC
control. It's the same for switching power supplies vs. linear power
supplies (e.g. smaller heat sinks for switching supplies). But I'm not the
motor specialist and maybe I'm wrong.
Dieter
btw. we did some VC motor applications for Kraftwerk but in this
appliactions servo motors were used and the CV controls the position of the
robot elements (via Midi-CV) rather than the RPM.
Re: AW: AW: [Doepfer_a100] VC electro-motor?
2008-12-02 by Derek Holzer
I get a fairly useful range using the circuit I provided the link for.
My next step will be to rig up some voltage control as well, maybe with
vactrols or maybe just with CV or PWM to a transistor. But yes, the
motor stalls at a certain point, and I would say that the response is
much more "linear" than "exponential" ;-) For extremely detailed control
over motors, you should look into stepper/servo motors, but in that case
you'd be better controlling it with some kind of microcontroller like an
Arduino.
What I use the motors for, BTW:
http://www.umatic.nl/tonewheels.html
best!
Derek
yahoo@doepfer.de wrote:
>> Hi Dieter,
>> Cheers,
>> denis
> Dieter
---Oblique Strategy # 105:
"Listen to the quiet voice"
Re: Sine wave discussion
2008-12-02 by laryn91
Dieter,
It's probably just me, but where do you point that out for the A-111? In my A-111 manual
you say just the opposite:
"Sine waves are pure waves: they just contain the
fundamental, without any harmonics (see Fig. 5).
They are thus not suitable for subtractive synthesis
(shaping sound with a filter) - as there's nothing to take
away!"
To the contrary, the A-111 sine is still suitable for subtractive synthesis. To be accurate,
you should say "not suitable for additive synthesis" instead.
> with a sine core.
Instead of an impossible "perfect sine", how about just a sine with no *audible* overtones
(<1% THD) like Arp,  Moog, Aries, Polyfusion, EML,etc. used to make? That would now
make the A-111 useful for additive synthesis and FM.
All you need to do is copy their simple but superior triangle-to-sine converter design. ;-)
> earlier):
> compensation.
> Best wishes
> Dieter Doepfer
Re: [Doepfer_a100] Sine wave discussion
2008-12-02 by Alex Pearson
Great post Dieter, and for the record I love that my A-143-9 doesn't have
temperature compensation. It makes for very organic changes over long
periods.
> want
> mentioned
> earlier):
> but
> VCO
> compensation.
> "sine-like".
> Best wishes
> Dieter Doepfer
The analog sine actually has a more prominent roll in EM history than that. In the 40's and
50', most oscillators in studios were sine because that's what test equipment usually
provided.
Later, in the analog golden era, most modular and many monosynths provided quality
sines (Arp, Moog, EML, Aries Polyfusion, etc.). You can hear the widespread use of the sine
in a lot of EM music written back then.
The analog revival in the 80'sand 90's was primarily driven by analog bass requirements.
That meant a very *fat* sawtooth oscillator driving a hi-Q LPF.
From looks of it, it's still pretty much the same requirement today.I'm guessing it's why
many on this thread can't imagine why a musician would want a dull and "sterile" wave like
the sine.
And probably why vendors like Doepfer put no engineering effort into sines - customers
want fat unstable waves - not precise thin waves!
--- In Doepfer_a100@yahoogroups.com, "p. hendricks" <ph@...> wrote:
> > desire perfection.
> -p
That's in the A-110 info page - NOT the A-111. Right?
--- In Doepfer_a100@yahoogroups.com, Pieter Volger <volger@...> wrote:
> RTFM
> "_Technical remarks:
> _The core of the A-110 is a sawtooth oscillator (in contrast to the
> A-111-1 <http://www.doepfer.de/a111.htm>, which is based on a triangle
> oscillator). The other waveforms are derived from the sawtooth by
> internal waveform converters. As the sawtooth reset (i.e. the
> back-to-zero slope) is not infinite fast but takes a little bit of time
> the derived waveforms triangle and sine are not perfect ! At the top of
> the waveform they have a small glitch or notch that is caused by the
> sawtooth reset and cannot be eliminated by the waveform converters. The
> sine is derived from the triangle by a simple diode-based converter and
> the sine shape is not perfect (only a rounded triangle).
> If a perfect triangle is required the A-111-1
> <http://www.doepfer.de/a111.htm> is recommended. For a perfect sine the
> quadrature LFO/VCO A-143-9 <http://www.doepfer.de/a1439.htm> is recommended.
> > A-110
> > "sine-like".
> > Dieter,
> > In my A-111 manual
> > away!"
> > > with a sine core.
> > *audible* overtones
> > That would now
> > but want
> > mentioned
> > > earlier):
> > core.
> > solution to
> > better but
> > need a
> > (ab)used as
> > sine VCO
> > exponential
> > We are
> > feature.
> > thru-zero
> > > compensation.
> > A-110
> > "sine-like".
> > kind of
> > on the
> > > Best wishes
> > > Dieter Doepfer
Re: [Doepfer_a100] Re: Sine wave discussion
2008-12-02 by Pieter Volger
RTFM
> A-110
> "sine-like".
> Dieter,
> In my A-111 manual
> away!"
> > with a sine core.
> *audible* overtones
> That would now
> but want
> mentioned
> > earlier):
> core.
> solution to
> better but
> need a
> (ab)used as
> sine VCO
> exponential
> We are
> feature.
> thru-zero
> > compensation.
> A-110
> "sine-like".
> kind of
> on the
> > Best wishes
> > Dieter Doepfer
Not sure why you found it relevant to quote the A-110 manual. My post below refers to
the A-111.
> RTFM
> > A-110
> > "sine-like".
> > Dieter,
> > In my A-111 manual
> > away!"
> > > with a sine core.
> > *audible* overtones
> > That would now
> > but want
> > mentioned
> > > earlier):
> > core.
> > solution to
> > better but
> > need a
> > (ab)used as
> > sine VCO
> > exponential
> > We are
> > feature.
> > thru-zero
> > > compensation.
> > A-110
> > "sine-like".
> > kind of
> > on the
> > > Best wishes
> > > Dieter Doepfer
Sorry, I missed the "will" part  :-p
I had this link to the Aries VCO in one of the posts on this (endless) thread. This is an
excellent tri-to-sine converter (I can't hear any additional overtones). Better than the more
common 3080 converter and significantly better than your diode converter. Aries claimed
to produce <1% THD.
I'm not sure why you found adding a slightly filtered triangle sounding wave useful when
there's already a triangle wave output. My suggestion is if your customers are not
interested in a clean Sine output, use the panel real estate for something more useful.
> You find my answers written inline.
> Best wishes
> Dieter Doepfer
> > -----Ursprüngliche Nachricht-----
> > Von: Doepfer_a100@yahoogroups.com
> > [mailto:Doepfer_a100@yahoogroups.com]Im Auftrag von laryn91
> > Gesendet: Dienstag, 2. Dezember 2008 17:20
> > An: Doepfer_a100@yahoogroups.com
> > Betreff: [Doepfer_a100] Re: Sine wave discussion
> A-110
> "sine-like".
> > Dieter,
> I wrote that "we will", not that "we did". That's the future tense from what
> I learned in scool - but I'm not a native speaker.
> > >If you want a perfect sine you need a VCO with a sine core.
> *audible* overtones
> would now
> Though I can't believe that they really reach <1% THD (but indeed I never
> measured it): do you (or anybody else in the group) know the circuitry of
> these converters. Are they made with diodes, OTAs or the JFET circuit (these
> are the three triangle-to-sine converter principles I know). I don't have
> the schematics of these VCOs.
> We would have offered a VCO with a more perfect sine in the past. But it
> took more than 12 years (the A-111 is available since spring 1996) until
> someone complained about the poor sine. I'll see what we can do. Maybe we
> offer a small tri-to-sine converter board for the A-111-1 that can be used
> instead of the simple diode converter.
> There was a similar discussion about 2 years ago (~ September 2006) and Tim
> Stinchcombe suggested an improved sine wave converter based on the JFET
> principle. We have built a prototype of this converter in 2006 but the
> discussion fell asleep very soon and it seemed that nobody was interested
> anymore. We could dig this design and offer it as an addendum to the A-111-1
> or equip all new A-111-1 with this board. The additional charges would be in
> the 15 Euro range (about 10 electronical parts mounted on a small board).
> Best wishes
> Dieter Doepfer
AW: [Doepfer_a100] Re: Sine wave discussion
Best wishes
Dieter Doepfer
A-110
"sine-like".
> Dieter,
*audible* overtones
would now
Best wishes
Dieter Doepfer
the sine story continues ...
sines - customers
We will put efforts into sines and we already have ! We have the existing
A-143-9 quadrature oscillator which has probably a more perfect sine than
all the other oscillators your mentioned. And you also ignored my suggestion
to improve the A-143-9 by adding a temperature compensation. We definitely
listen to what our customers want to have. Most of the newer A-100 modules
are based on ideas and suggestions of this group ! But it needs to be more
than one interested user before start a new design or redesign. So lets
start with a poll how many users would be interested in
a) improved tri-to-sine converter for A-111-1 (about Euro 15 additional
charges)
b) temperature compensated exponential generator for the A-143-9 (about Euro
30 additional charges)
I think that's much more constructive than to offend other users.
Best wishes
Dieter Doepfer
2008-12-02 by James Husted
The part of this circuit that does the conversion seems pretty
straight ahead and looks simple enough to make as a stan-alone module.
If one was needing to make sines and had a triangle VCO already (that
made a decent Triangle wave) then a converter module would work fine -
a bit esoteric for mass production though.
-James
PS - sorry to all for starting this thread with my Z3000 post. I had
my questions answered a long time ago.
> to produce <1% THD.
> customers are not
> > Best wishes
> > Dieter Doepfer
> guide of
> > A-110
> > "sine-like".
> > > Dieter,
> A-111?
> from what
> with no
> > *audible* overtones
> make? That
> > would now
> I never
> circuitry of
> circuit (these
> don't have
> But it
> until
> Maybe we
> be used
> 2006) and Tim
> JFET
> the
> interested
> the A-111-1
> would be in
> board).
> > Best wishes
> > Dieter Doepfer
sorry, you are right.
my fault!
> <mailto:Doepfer_a100%40yahoogroups.com>, Pieter Volger <volger@...> wrote:
> > RTFM
> <http://www.doepfer.de/a111.htm>>, which is based on a triangle
> > <http://www.doepfer.de/a111.htm <http://www.doepfer.de/a111.htm>> is
> <http://www.doepfer.de/a1439.htm>> is recommended.
> > > A-110
> > > "sine-like".
> > > Dieter,
> > > In my A-111 manual
> > > away!"
> > > > with a sine core.
> with no
> > > *audible* overtones
> > > That would now
> > > but want
> > > mentioned
> > > > earlier):
> triangle
> > > core.
> will never
> > > solution to
> > > better but
> converter is a
> need a VCO
> > > need a
> core.
> > > (ab)used as
> temperature
> > > sine VCO
> > > exponential
> > > We are
> > > feature.
> > > thru-zero
> > > > compensation.
> > > A-110
> > > "sine-like".
> > > kind of
> > > on the
> > > > Best wishes
> > > > Dieter Doepfer
2008-12-02 by Monroe Eskew
Couldn't we just use a standard LPF for this?
> -James
> > to produce <1% THD.
> > customers are not
> > > Best wishes
> > > Dieter Doepfer
> > guide of
> > > A-110
> precisely
> > > "sine-like".
> > > > Dieter,
> > A-111?
> > from what
> > with no
> > > *audible* overtones
> > make? That
> > > would now
> > I never
> > circuitry of
> > circuit (these
> > don't have
> > But it
> > until
> > Maybe we
> > be used
> > 2006) and Tim
> > JFET
> > the
> > interested
> > the A-111-1
> > would be in
> > board).
> > > Best wishes
> > > Dieter Doepfer
2008-12-02 by Adam-V
Would it be possible to offer two sine outputs - the existing sine
output for those of us who like it's character AND a new improved one
for those wanting something more clinical?
Adam-V
and Tim
interested
A-111-1
would be in
board).
> Best wishes
> Dieter Doepfer
Re: [Doepfer_a100] Re: Sine wave discussion - Poll suggestion
2008-12-02 by york luethje
Couldn't we just have a poll? My suspicion is that the practical value of very good analogue sine waves will be high for only some. As Dieter posted, an  earlier discussion then fizzled out and didn't result in any product modifications. Maybe the discussion has shown there there is indeed a lot of (commercially tangible) interest in an oscillator with a very good sine output. On the other hand, maybe the interest is more intellectual and doesn't incite people to actually part with their money and buy the new design. A poll could give us at least an indication. I suggest something like this
"Do you want Doepfer to modify the sine-converter in the A-111 to produce a purer sine wave? The cost increase would be in the 5% - 10% range."
York
Sent: Tuesday, December 2, 2008 3:39:52 PM
Subject: Re: [Doepfer_a100] Re: Sine wave discussion
> -James
> > to produce <1% THD.
> > http://www.leinerme dia.net/aries/ AriesSchematics/ AR-317s.gif
> > customers are not
> > > Best wishes
> > > Dieter Doepfer
> > > > -----Ursprüngliche Nachricht--- --
> > > > Von: Doepfer_a100@ yahoogroups. com
> > > > [mailto:Doepfer_a100@ yahoogroups. com]Im Auftrag von laryn91
> > > > An: Doepfer_a100@ yahoogroups. com
> > guide of
> > > A-110
> precisely
> > > "sine-like".
> > > > Dieter,
> > A-111?
> > from what
> > with no
> > > *audible* overtones
> > make? That
> > > would now
> > > > triangle-to- sine converter design. ;-)
> > I never
> > circuitry of
> > circuit (these
> > > are the three triangle-to- sine converter principles I know). I
> > don't have
> > But it
> > until
> > Maybe we
> > be used
> > 2006) and Tim
> > JFET
> > the
> > interested
> > the A-111-1
> > would be in
> > board).
> > > Best wishes
> > > Dieter Doepfer
Re: [Doepfer_a100] Re: Sine wave discussion - EOD?
2008-12-02 by Florian Anwander
Hi laryn91
I think you should turn around and think about another group to bother.
You don't understand any word someone is telling you. As already
explained: additive synthesis with pure sines is not a topic for
analogue synths, because you cannot frequency lock the single partial
frequencies.
But I doubt the technical side is your main interest - it is about being
right and about knowing it better than the others. So I offer to you:
Yes you are better than we all, we all are little idiots compared to you
- but please shut down this topic.
Otherwise I really I think it is time for Bakis to intervene...
Florian
Couldn't you lock partials if you designed a complex clock divider/osc
sync? Actually, what if you designed a module similar to a filterbank,
but produced sines instead of boosting a particular band of
frequencies?
On Tue, Dec 2, 2008 at 3:19 PM, Florian Anwander
<fanwander@mnet-online.de> wrote:
> Hi laryn91
> frequencies.
> Florian
www.elanhickler.com
2008-12-02 by Brandon Daniel
> frequencies?
What if you just bought a DX7 already?
I apologize, I thought I could keep my composure, but this thread just
keeps on going and going and...
-Brandon
http://www.analoguesystems.co.uk/modules/rs370.htm
Sent: Tuesday, December 2, 2008 5:31:07 PM
Subject: Re: [Doepfer_a100] Re: Sine wave discussion - EOD?
frequencies?
<fanwander@mnet- online.de> wrote:
> Hi laryn91
> frequencies.
> Florian
www.elanhickler. com
2008-12-02 by Bakis Sirros
the A111 IS useful for linear FM as it is now.
i am using my A111's for linear FM for 8 years now...
[Doepfer_a100] group owner
www. parallel - worlds - music. com
www. myspace. com/ parallelworldsmusic
www. myspace. com/ interconnectedmusic
www. myspace. com/ memorygeist
www. DiN. org. uk
www. musicamaximamagnetica. com
www. shimarecords. co. uk
www. rubberrecords. gr
Athens - Greece
--- On Tue, 12/2/08, laryn91 <caymus91@mac.com> wrote:
Subject: [Doepfer_a100] Re: Sine wave discussion
Date: Tuesday, December 2, 2008, 6:19 PM
Dieter,
away!"
> with a sine core.
All you need to do is copy their simple but superior triangle-to- sine converter design. ;-)
> earlier):
> compensation.
> Best wishes
> Dieter Doepfer
2008-12-02 by Chris Muir
Not really the same thing. Some of the cooler early Buchla stuff from
Morton Subotnick relied on a lot of fairly high quality sines out of
Buchla 258 oscillators. I see nothing wrong with wanting high quality
sines from an analog oscillator.
I agree that this is more like an Analog Heaven thread than a Doepfer
list thread, but you're always free to skip it.
- C
Chris Muir
cbm@well.com
Re: [Doepfer_a100] the sine story continues ...
2008-12-03 by Bakis Sirros
hi Dieter,
ok, i'll make this poll soon.
thanks,
Bakis. (a Very Tolerant moderator)
www. DiN. org. uk
Athens - Greece
--- On Tue, 12/2/08, yahoo@doepfer.de <yahoo@doepfer.de> wrote:
Subject: [Doepfer_a100] the sine story continues ...
Date: Tuesday, December 2, 2008, 8:13 PM
sines - customers
charges)
Best wishes
Dieter Doepfer
AW: [Doepfer_a100] the sine story continues ...
2008-12-03 by yahoo@doepfer.de
> hi Dieter,
> thanks,
Thank you. I hope it will to put some oil on troubled waters :-)
Dieter
