Beginner questions
Beginner questions
2008-01-23 by frankbickelmeyer
Hello,
my name is frank coming from germany and i am new in this group. I am
interested strongly in B&W fineart printing and startet a few weeks ago
with a cheap epson 1200 with TritonPlus ink (Black and 5 different
grays) and Calumets Museum Satin Matte. The results are very good,
though i am thinking i could be even better? I also tried out Clayton
Jones BO method, but the prints have very strong contrast with no
details in black areas. Is there any workaround related to this (beyond
the fantastic articles from clayton jones of course)? Can i use any
black ink (like the original epson ink for the 1200) or do i need a
special ink. In this case which of them will i get here in germany?
Another question is whether the epson 2100 would be a good advantage
compared to my 1200? I know the 2400 or even the 3800 are state of the
art but i am not able to buy such expensive machines.
Thank you for reading my questions!
Frank
Re: Beginner questions
2008-01-23 by Clayton Jones
Hello Frank,
Welcome to the forum.
>I also tried out Clayton Jones BO method, but the prints have very
>strong contrast with no details in black areas. Is there any
>workaround related to this...
If you see dark zone details on screen you should be able to get them
on paper, whether using BO or any other printing method.  If you're
not it could be caused by various things.  With the BO technique the
trick is to choose an image profile that gets a good screen to print
match, so what you see is what you get (WYSIWYG).  This profile can
vary depending on your monitor/video card, etc. My suggestion of using
DG20 is just a starting point because it's in the middle of the range.
The proof paper you use to set this up is also important because
papers have different contrast curves.  I always recommend using EEM
because it's inexpensive, has good dmax, and has a contrast/density
range that's right in the middle of where many of the best papers are.
 Once you have this properly set up you'll adjust your image to look
good on screen and you'll get very close to that on paper, depending
on which paper you use.  Final prints on other papers sometimes need a
paper curve layer with some slight tweaking to match the proof print.
In article #4 there is a detailed discussion for all this.
Clayton
2008-02-03 by frankbickelmeyer
Clayton you are my man ;-) it´s fantastic, with the settings you
recommend in your article #4 i get wonderful black only prints just
with a cheap black ink (armor ink for just 6 €) on Brilliant Museum
Satin Matte paper. I am very happy now with the results and
astonishing the multigray prints with TritonPlus ink are not better
then the BO!
But is it a good idea to use the cheap ink for my BO prints while
attempting longliving pictures? I want to store them in the dark so
is it ok to use a cheap dye ink or what can i do alternatively with
my Epson 1200? You wrote about the Eboni ink. Which carbon inks are
available for this printer?
Thank you so much for the help!
<cj@...> wrote:
> Hello Frank,
them
using
range.
are.
need a
print.
> Regards,
> Clayton
2008-02-03 by finnkrogvig
Cheap ink is a gamble. I think good images deserves the best
"treatment". Yes, dye ink fade faster and may look greenish or have a
color cast in different type of light. Good images should not be
hidden away due to fading, but hang on a wall.
I don't know the MIS inks so I can't say anything about them. I use
Piezography inks from www.inkjetmall.com in my Epson 1290. That
printer is originally made for dye inks, but I have used pigment inks
in it for 2-3 years without too much trouble. Some 1290s give more
trouble than others (clogging). I don't know how Epson 1200 compare
to 1290 in this respect.  The newest Piezography pigment ink is much
less prone to clogging than the inks I am using right now. It is
called Piezography MPS Selenium K7 which work on both matte and
glossy paper. (I have not tried them yet.) You could buy the black
ink (Shade 1) in bottles and fill it in a refillable cart.
FinnK
"frankbickelmeyer" <bickelmeyer@...> wrote:
> Hello,
am
weeks ago
Clayton
(beyond
any
a
advantage
> Frank
2008-02-04 by Clayton Jones
Hello Frank,
Great.  Glad it's working for you.
I agree with FinnK.  Buying the bulk inks is so inexpensive there's no
reason not to use a good pigment ink.  The Piezo matte black or Eboni
from MIS will both do great.  I think in a 1200 you can use just about
anything - someone else maybe will step in here with more on that...
Clayton
I-Trak
2008-02-04 by dlruckus
Frank, I'd recommend your using Eboni and trying your BO prints. Once
you have that working you could go on to Paul's 3MK and/or the Eboni
hex or quad set he's come up with. You don't have to change anything
but the one ink to start. You would want to remove all of the other
inks and substitute cleaning solution for  them./// DO be sure,repeat
sure to fully flush your machine  with a cleaning solution before
running any of the recent inks like Eboni in it. That includes
cleaning the cap station thoroughly as well. The dyes are incompatible
with Eboni.///
Clayton is right. The 1200 will run nearly anything if treated properly.
Duane
2008-02-04 by frankbickelmeyer
Thank you for your advice!
But can anybody tell me where to order the Eboni Ink? I live in
germany so it would be fine if anybody can tell me if here is a
locakldealer for the "right stuff". Is it in cartriges or in Bottles?
If in Bottles, do i nee an empty original epson cartrige?
Thank you again and regards,
Frank
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "dlruckus"
there's no
Eboni
about
that...
Once
sure,repeat
incompatible
> with Eboni.///
properly.
> Regards
> Duane
2008-02-04 by finnkrogvig
Take a look at www.inksupply.com for "MIS" inks (Eboni) and
www.inkjetmall.com for Piezography K7. If you plan to print BO only
the Piezography K7 MPS selenium black might have an advantage because
it goes on both matte and glossy papers. This is not possible with
Eboni as far as I know - check it.
It might be a little difficult to get empty carts made for refilling
from USA (Inksupply) because of some legal issues Epson is running.
Somebody else have to help find other sources for empty refillable
carts.
FinnK
Bottles?
> Frank
Jones"
> there's no
> Eboni
just
> about
> that...
> Once
Eboni
anything
other
> sure,repeat
> incompatible
> > with Eboni.///
> properly.
> > Regards
> > Duane
As i´ve found out in the meantime i can order Ultratone MatteBlack-
ink in bottles from a local dealer here in germany. Is that the same
as MIS Eboni?
But the problem indeed is that i cant find empty cartridges for my
Epson 1200.
When anybody could help i really would appreciate this.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "finnkrogvig"
because
refilling
> carts.
> FinnK
> Bottles?
> > Frank
> Jones"
> > there's no
or
> > Eboni
> just
> > about
> > that...
prints.
> > Once
> Eboni
> anything
> other
> > sure,repeat
before
> > incompatible
> > > with Eboni.///
> > properly.
> > > Regards
> > > Duane
I could get empty carts for the 1270/80/90 but they wont´t fit to the
1200 right?
--- In
DigitalBlackandWhiteThePrint@yahoogroups.com, "frankbickelmeyer"
same
> as MIS Eboni?
> Epson 1200.
only
> because
with
> refilling
running.
refillable
> > carts.
> > FinnK
> > Bottles?
> > > Frank
> > Jones"
> > > there's no
black
> or
> > > Eboni
> > just
> > > about
on
> > > that...
> prints.
> > > Once
> > Eboni
> > anything
> > other
> > > sure,repeat
> before
> > > incompatible
> > > > with Eboni.///
treated
> > > properly.
> > > > Regards
> > > > Duane
2008-02-04 by Tyler Boley
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "finnkrogvig" <reg@...> wrote:
> it goes on both matte and glossy papers. ..
Not exactly, that news would have made headlines.
The set uses a gloss optimizer. QTR "profies" utilizing the GO are in the works and not yet
available to my knowledge. Rolling your own for black only plus GO would be required.
Doable, but you'd be on your own with that unusual task.
Tyler
Re: [Digital BW] Re: Beginner questions
2008-02-04 by Gary Weaver
Frank,
When I got my 1270, I ran the black 'til it ran out, and then, filled the cart with MIS black.
gar
*********** REPLY SEPARATOR  ***********
>as MIS Eboni?
>Epson 1200.
>because
>refilling
>> carts.
>> FinnK
>> Bottles?
>> > Frank
>> Jones"
>> > there's no
>or
>> > Eboni
>> just
>> > about
>> > that...
>prints.
>> > Once
>> Eboni
>> anything
>> other
>> > sure,repeat
>before
>> > incompatible
>> > > with Eboni.///
>> > properly.
>> > > Regards
>> > > Duane
>Please visit the Group Homepage to check the Files, and other resources as
>they are often being updated.
>http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint
>If you wish to receive no emails or just a daily digest, or you wish to
>unsubscribe, please edit your Membership preferences by visiting this same
>page.
>Please follow these basic guidelines:
>- As threads develop, trim off excess portions of earlier messages to keep
>them short.
>- Good manners are required at all time. No personal attacks or flames.
>Hostile, aggressive or argumentative users may be removed from the
>membership without notice.
>- Keep your posts and threads related to the group topic of digital B&W
>printing. Users who persistently make off-topic posts may be removed from
>the membership.
>- By posting on this forum you agree to abide by the group rules and
>guidelines, and to abide by the actions and decisions of the group Owner
>and Moderators. See “Group Topic, Rules and Guidelines” in the Files
>section:
>http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/
>BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT
>YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE “OWNER” AND
>“MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO
>YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR
>EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF
>PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE
>“OWNER” AND “MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN
>ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE
>OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii)
>UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii)
>STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT
>YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE
>PRINT YAHOO GROUP.
>Yahoo! Groups Links
Does that mean i could try to fill the original epson black catridge
with the MIS black?
And again my question is Ultratone MatteBlack (which i can buy here
in germany in bottles) the same ink as the MIS Eboni?
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Gary Weaver"
<garww@...> wrote:
> Frank,
> gar
same
> >as MIS Eboni?
> >Epson 1200.
only
> >because
with
> >refilling
running.
refillable
> >> carts.
> >> FinnK
in
a
> >> Bottles?
> >> > Frank
> >> > --- In
> >> > <dlruckus@> wrote:
> >> > > --- In
> >> Jones"
inexpensive
> >> > there's no
black
> >or
> >> > Eboni
use
> >> just
> >> > about
on
> >> > that...
> >prints.
> >> > Once
> >> Eboni
> >> anything
> >> other
> >> > sure,repeat
> >before
includes
> >> > incompatible
> >> > > with Eboni.///
treated
> >> > properly.
> >> > > Regards
> >> > > Duane
resources as
wish to
this same
> >page.
to keep
> >them short.
flames.
digital B&W
removed from
> >the membership.
and
Owner
> >and Moderators. See "Group Topic, Rules and Guidelines" in the
Files
> >section:
PRINT
> >YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER"
AND
> >"MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE
LIABLE TO
OF
THE
> >"OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE
BEEN
THE USE
DATA; (iii)
PRINT
THE
> >PRINT YAHOO GROUP.
> >Yahoo! Groups Links
Yes!!
It would be nice to have a clean cart, but I didn't blink an eyelash.
Since the process involves switching from dye ink to pigment ink, you have to make sure the old substance is not allowed to interact with the new ink.
As soon as my dye ink printed very light, I filled it with pigment and printed huge amounts of black to make sure it was flowing freely. I also freely saturated the cart. well nipple with vinegar and/or window ammonia.
Do you have the refill stuff from a old refill kit?
gar
>with the MIS black?
><garww@...> wrote:
>> Frank,
>> gar
>same
>> >as MIS Eboni?
>> >Epson 1200.
>only
>> >because
>with
>> >refilling
>running.
>refillable
>> >> carts.
>> >> FinnK
>in
>a
>> >> Bottles?
>> >> > Frank
>> >> > --- In
>> >> > <dlruckus@> wrote:
>> >> > > --- In
>> >> Jones"
>inexpensive
>> >> > there's no
>black
>> >or
>> >> > Eboni
>use
>> >> just
>> >> > about
>on
>> >> > that...
>> >prints.
>> >> > Once
>the
>> >> Eboni
>> >> anything
>the
>> >> other
>> >> > sure,repeat
>> >before
>includes
>> >> > incompatible
>> >> > > with Eboni.///
>treated
>> >> > properly.
>> >> > > Regards
>> >> > > Duane
>resources as
>wish to
>this same
>> >page.
>to keep
>> >them short.
>flames.
>digital B&W
>removed from
>> >the membership.
>and
>Owner
>Files
>> >section:
>PRINT
>AND
>LIABLE TO
>OF
>THE
>BEEN
>THE USE
>DATA; (iii)
>PRINT
>THE
>> >PRINT YAHOO GROUP.
>> >Yahoo! Groups Links
>page.
>them short.
>the membership.
>section:
>PRINT YAHOO GROUP.
>Yahoo! Groups Links
I have not seen MPS ink on any paper yet, and I am curious: is every
shade of MPS ink in need of a different amount of GO to make an
uniform look?
FinnK
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Tyler
Boley" <tyler@...> wrote:
> --- In DigitalBlackandWhiteThePrint@...m,
only
because
would be required.
> Tyler
not sure yet...
Tyler
> uniform look?
> FinnK
> only
> because
> would be required.
> > Tyler
2008-02-05 by frankbickelmeyer
Gary,
thats pretty cool! But no i don´t have any stuff to refill carts.
What will i need therefor? I haven´t refill any carts at all so how
does it work? I can order the Ultratone ink in 100ml Bottles here and
a Syringe with a needle too.
<garww@...> wrote:
> Yes!!
eyelash.
with the new ink.
window ammonia.
> gar
catridge
> >with the MIS black?
here
> ><garww@> wrote:
> >> Frank,
> >> gar
MatteBlack-
> >same
> >> >as MIS Eboni?
my
> >> >Epson 1200.
> >> >--- In
BO
> >only
> >> >because
> >with
> >> >refilling
> >running.
> >refillable
> >> >> carts.
> >> >> FinnK
live
> >in
is
> >a
in
> >> >> Bottles?
> >> >> > Frank
> >> >> > --- In
> >> >> > <dlruckus@> wrote:
> >> >> > > --- In
> >> >> Jones"
> >inexpensive
> >> >> > there's no
> >black
> >> >or
> >> >> > Eboni
> >use
> >> >> just
> >> >> > about
more
> >on
> >> >> > that...
> >> >prints.
> >> >> > Once
and/or
> >the
> >> >> Eboni
change
> >> >> anything
> >the
> >> >> other
> >> >> > sure,repeat
solution
> >> >before
> >includes
> >> >> > incompatible
> >> >> > > with Eboni.///
> >treated
> >> >> > properly.
> >> >> > > Regards
> >> >> > > Duane
> >resources as
> >wish to
visiting
> >this same
> >> >page.
messages
> >to keep
> >> >them short.
> >flames.
> >digital B&W
> >removed from
> >> >the membership.
rules
> >and
group
> >Owner
> >Files
> >> >section:
THE
> >PRINT
THE "OWNER"
> >AND
> >LIABLE TO
CONSEQUENTIAL OR
LOSS
> >OF
IF
> >THE
HAVE
> >BEEN
(i)
> >THE USE
(ii)
> >DATA; (iii)
> >PRINT
BW,
> >THE
> >> >PRINT YAHOO GROUP.
> >> >Yahoo! Groups Links
resources as
wish to
this same
> >page.
to keep
> >them short.
flames.
digital B&W
removed from
> >the membership.
and
Owner
Files
> >section:
PRINT
AND
LIABLE TO
OF
THE
BEEN
THE USE
DATA; (iii)
PRINT
THE
> >PRINT YAHOO GROUP.
> >Yahoo! Groups Links
2008-02-05 by Gary Weaver
Ya!!
I would think that the place that has bulk ink would have a syringe.
I place the cart on a surface designed to absorb spills.
I poke a hole through the epson film on top.
load syringe and slowly transfer ink to cart.
I use the tap/rap method to settle ink and disloge air bubbles. I rap the ink exit flat against the work surface. I look for little "kiss" imprints on the work surface to show that ink is flowing.
gar
On 2/5/08 at 7:38 AM frankbickelmeyer wrote:
>Gary,
><garww@...> wrote:
>> Yes!!
>eyelash.
>with the new ink.
>window ammonia.
>> gar
>catridge
>> >with the MIS black?
>here
>> ><garww@> wrote:
>> >> Frank,
>> >> gar
>MatteBlack-
>> >same
>> >> >as MIS Eboni?
>my
>> >> >Epson 1200.
>> >> >--- In
>BO
>> >only
>> >> >because
>> >with
>> >> >refilling
>> >running.
>> >refillable
>> >> >> carts.
>> >> >> FinnK
>live
>> >in
>is
>> >a
>in
>> >> >> Bottles?
>> >> >> > Frank
>> >> >> > --- In
>> >> >> > <dlruckus@> wrote:
>> >> >> > > --- In
>> >> >> Jones"
>> >inexpensive
>> >> >> > there's no
>> >black
>> >> >or
>> >> >> > Eboni
>> >use
>> >> >> just
>> >> >> > about
>more
>> >on
>> >> >> > that...
>> >> >prints.
>> >> >> > Once
>and/or
>> >the
>> >> >> Eboni
>change
>> >> >> anything
>> >the
>> >> >> other
>> >> >> > sure,repeat
>solution
>> >> >before
>> >includes
>> >> >> > incompatible
>> >> >> > > with Eboni.///
>> >treated
>> >> >> > properly.
>> >> >> > > Regards
>> >> >> > > Duane
>> >resources as
>> >wish to
>visiting
>> >this same
>> >> >page.
>messages
>> >to keep
>> >> >them short.
>> >flames.
>the
>> >digital B&W
>> >removed from
>> >> >the membership.
>rules
>> >and
>group
>> >Owner
>> >Files
>> >> >section:
>THE
>> >PRINT
>THE "OWNER"
>> >AND
>> >LIABLE TO
>CONSEQUENTIAL OR
>LOSS
>> >OF
>IF
>> >THE
>HAVE
>> >BEEN
>(i)
>> >THE USE
>(ii)
>> >DATA; (iii)
>> >PRINT
>BW,
>> >THE
>> >> >PRINT YAHOO GROUP.
>> >> >Yahoo! Groups Links
>resources as
>wish to
>this same
>> >page.
>to keep
>> >them short.
>flames.
>digital B&W
>removed from
>> >the membership.
>and
>Owner
>Files
>> >section:
>PRINT
>AND
>LIABLE TO
>OF
>THE
>BEEN
>THE USE
>DATA; (iii)
>PRINT
>THE
>> >PRINT YAHOO GROUP.
>> >Yahoo! Groups Links
>page.
>them short.
>the membership.
>section:
>PRINT YAHOO GROUP.
>Yahoo! Groups Links
Gary,
thank you again!
Then i will try out this method to refill. How big should the hole be
on top of the cart? just as big enough for the needle of the syringe
i guess? Should i seal the hole then with a tape? And can anybody
please answer my question if the MIS Ultratone MatteBlack (which i
can buy here in germany in bottles) is the same as the MIS Eboni?
Frank
<garww@...> wrote:
> Ya!!
flowing.
> gar
> >Gary,
how
and
> ><garww@> wrote:
> >> Yes!!
> >eyelash.
ink,
> >with the new ink.
pigment
freely.
> >window ammonia.
> >> gar
> >catridge
> >> >with the MIS black?
> >here
Weaver"
> >> ><garww@> wrote:
> >> >> Frank,
then,
> >> >> gar
> >MatteBlack-
> >> >same
> >> >> >as MIS Eboni?
for
> >my
> >> >> >Epson 1200.
> >> >> >--- In
and
print
> >BO
> >> >only
advantage
> >> >> >because
possible
> >> >with
> >> >> >refilling
> >> >running.
> >> >refillable
> >> >> >> carts.
> >> >> >> FinnK
> >live
> >> >in
here
> >is
> >> >a
or
> >in
> >> >> >> Bottles?
> >> >> >> > Frank
> >> >> >> > --- In
> >> >> >> > <dlruckus@> wrote:
> >> >> >> > > --- In
> >> >> >> Jones"
> >> >inexpensive
> >> >> >> > there's no
matte
> >> >black
> >> >> >or
> >> >> >> > Eboni
can
> >> >use
> >> >> >> just
> >> >> >> > about
> >more
> >> >on
> >> >> >> > that...
BO
> >> >> >prints.
> >> >> >> > Once
> >and/or
> >> >the
> >> >> >> Eboni
> >change
> >> >> >> anything
of
> >> >the
> >> >> >> other
be
> >> >> >> > sure,repeat
> >solution
> >> >> >before
> >> >includes
are
> >> >> >> > incompatible
> >> >> >> > > with Eboni.///
> >> >treated
> >> >> >> > properly.
> >> >> >> > > Regards
> >> >> >> > > Duane
other
> >> >resources as
you
> >> >wish to
> >visiting
> >> >this same
> >> >> >page.
> >messages
> >> >to keep
> >> >> >them short.
or
> >> >flames.
from
> >the
> >> >digital B&W
> >> >removed from
> >> >> >the membership.
> >rules
> >> >and
> >group
> >> >Owner
> >> >Files
> >> >> >section:
BW,
> >THE
> >> >PRINT
> >THE "OWNER"
> >> >AND
BE
> >> >LIABLE TO
> >CONSEQUENTIAL OR
> >LOSS
> >> >OF
(EVEN
> >IF
> >> >THE
GROUP
> >HAVE
> >> >BEEN
> >(i)
> >> >THE USE
GROUP;
> >(ii)
OR
> >> >DATA; (iii)
THE
> >> >PRINT
DIGITAL
> >BW,
> >> >THE
> >> >> >PRINT YAHOO GROUP.
> >> >> >Yahoo! Groups Links
> >resources as
> >wish to
visiting
> >this same
> >> >page.
messages
> >to keep
> >> >them short.
> >flames.
> >digital B&W
> >removed from
> >> >the membership.
rules
> >and
group
> >Owner
> >Files
> >> >section:
THE
> >PRINT
THE "OWNER"
> >AND
> >LIABLE TO
CONSEQUENTIAL OR
LOSS
> >OF
IF
> >THE
HAVE
> >BEEN
(i)
> >THE USE
(ii)
> >DATA; (iii)
> >PRINT
BW,
> >THE
> >> >PRINT YAHOO GROUP.
> >> >Yahoo! Groups Links
resources as
wish to
this same
> >page.
to keep
> >them short.
flames.
digital B&W
removed from
> >the membership.
and
Owner
Files
> >section:
PRINT
AND
LIABLE TO
OF
THE
BEEN
THE USE
DATA; (iii)
PRINT
THE
> >PRINT YAHOO GROUP.
> >Yahoo! Groups Links
Frank,
I don't know about the MIS ink. I would write down part numbers from the MIS site. Go by the part numbers. You need to know this anyway. You will want numbers for the Eboni and UT matt so you can be sure which is which. I'm still using the old quadtone black and it's dated but not bad. When I finish that off, I'll be going BO eboni for the 1270.
You can examine the top of the black cart and see the indent for the fill hole under the "decal". With the 640, I covered the fill hole. With the 1270, I leave it not air tight.
gar
On 2/5/08 at 6:05 PM frankbickelmeyer wrote:
>Gary,
>thank you again!
>Frank
><garww@...> wrote:
>> Ya!!
>flowing.
>> gar
>> >Gary,
>how
>and
>> ><garww@> wrote:
>> >> Yes!!
>> >eyelash.
>ink,
>> >with the new ink.
>pigment
>freely.
>> >window ammonia.
>> >> gar
>> >catridge
>> >> >with the MIS black?
>> >here
>Weaver"
>> >> ><garww@> wrote:
>> >> >> Frank,
>then,
>> >> >> gar
>> >MatteBlack-
>the
>> >> >same
>> >> >> >as MIS Eboni?
>for
>> >my
>> >> >> >Epson 1200.
>> >> >> >--- In
>and
>print
>> >BO
>> >> >only
>advantage
>> >> >> >because
>possible
>> >> >with
>> >> >> >refilling
>> >> >running.
>> >> >refillable
>> >> >> >> carts.
>> >> >> >> FinnK
>> >live
>> >> >in
>here
>> >is
>> >> >a
>or
>> >in
>> >> >> >> Bottles?
>> >> >> >> > Frank
>> >> >> >> > --- In
>> >> >> >> > <dlruckus@> wrote:
>> >> >> >> > > --- In
>> >> >> >> Jones"
>> >> >inexpensive
>> >> >> >> > there's no
>matte
>> >> >black
>> >> >> >or
>> >> >> >> > Eboni
>can
>> >> >use
>> >> >> >> just
>> >> >> >> > about
>> >more
>> >> >on
>> >> >> >> > that...
>BO
>> >> >> >prints.
>> >> >> >> > Once
>> >and/or
>> >> >the
>> >> >> >> Eboni
>> >change
>> >> >> >> anything
>of
>> >> >the
>> >> >> >> other
>be
>> >> >> >> > sure,repeat
>> >solution
>> >> >> >before
>> >> >includes
>are
>> >> >> >> > incompatible
>> >> >> >> > > with Eboni.///
>> >> >treated
>> >> >> >> > properly.
>> >> >> >> > > Regards
>> >> >> >> > > Duane
>other
>> >> >resources as
>you
>> >> >wish to
>> >visiting
>> >> >this same
>> >> >> >page.
>> >messages
>> >> >to keep
>> >> >> >them short.
>or
>> >> >flames.
>from
>> >the
>> >> >digital B&W
>> >> >removed from
>> >> >> >the membership.
>> >rules
>> >> >and
>> >group
>> >> >Owner
>the
>> >> >Files
>> >> >> >section:
>BW,
>> >THE
>> >> >PRINT
>> >THE "OWNER"
>> >> >AND
>BE
>> >> >LIABLE TO
>> >CONSEQUENTIAL OR
>> >LOSS
>> >> >OF
>(EVEN
>> >IF
>> >> >THE
>GROUP
>> >HAVE
>> >> >BEEN
>> >(i)
>> >> >THE USE
>GROUP;
>> >(ii)
>OR
>> >> >DATA; (iii)
>THE
>> >> >PRINT
>DIGITAL
>> >BW,
>> >> >THE
>> >> >> >PRINT YAHOO GROUP.
>> >> >> >Yahoo! Groups Links
>> >resources as
>> >wish to
>visiting
>> >this same
>> >> >page.
>messages
>> >to keep
>> >> >them short.
>> >flames.
>the
>> >digital B&W
>> >removed from
>> >> >the membership.
>rules
>> >and
>group
>> >Owner
>> >Files
>> >> >section:
>THE
>> >PRINT
>THE "OWNER"
>> >AND
>> >LIABLE TO
>CONSEQUENTIAL OR
>LOSS
>> >OF
>IF
>> >THE
>HAVE
>> >BEEN
>(i)
>> >THE USE
>(ii)
>> >DATA; (iii)
>> >PRINT
>BW,
>> >THE
>> >> >PRINT YAHOO GROUP.
>> >> >Yahoo! Groups Links
>resources as
>wish to
>this same
>> >page.
>to keep
>> >them short.
>flames.
>digital B&W
>removed from
>> >the membership.
>and
>Owner
>Files
>> >section:
>PRINT
>AND
>LIABLE TO
>OF
>THE
>BEEN
>THE USE
>DATA; (iii)
>PRINT
>THE
>> >PRINT YAHOO GROUP.
>> >Yahoo! Groups Links
>page.
>them short.
>the membership.
>section:
>PRINT YAHOO GROUP.
>Yahoo! Groups Links
2008-02-06 by dlruckus
<garww@...> wrote:
> Frank,
Hi Gary. When you do finish with the old MIS quad black and go to
Eboni it will be a mistake if you just print the cart down and push
Eboni into it. The old quad blacks have some dye in them. Eboni will
gel in the presence of dyes. That will happen in the heads as well as
in the cart.
   -----------Isss baaad juju ;)-------------
You need to clear the old inks out first including remnants left in
the heads and on the cap station. Hence the recommendation of cleaning
cart first. I believe that, at this point in time, MIS is no longer
selling the old types of ink so there will soon be no choice but to do
this if you want to preserve your printer. (Note: I have two 1200s and
know whereof I speak :) )
Duane
2008-02-06 by Gary Weaver
Thanks for the advice, Duane!
I don't know what to do about replacing the Quadtone in the 3000 yet. To get my feet BO wet, I just used the black from the quad in the 1270 because I'm CHEAP!!!
I suppose I'll have to mix the quad black myself because MIS is too damn lazy and has abandoned it's hallmark inks.
gar
On 2/6/08 at 12:23 AM dlruckus wrote:
>--- In DigitalBlackandWhiteThePrint@...m, "Gary Weaver"
><garww@...> wrote:
>> Frank,
>in the cart.
>Regards
>Duane
>page.
>them short.
>the membership.
>section:
>PRINT YAHOO GROUP.
>Yahoo! Groups Links
2008-02-06 by fran leblanc, www.steamtractionart.com, w
syringe - available most any drug store
On Feb 5, 2008 9:53 AM, Gary Weaver <garww@...> wrote:
>   Ya!!
fran...
www.artbyleblanc.com
2008-02-07 by dlruckus
> gar
It's not all that difficult to mix your own if you have enough black
ink. Take a look at Paul's site for info. His 4:3 H2O/glycerin base
mix works very well in the older machines like the 1200 and your 3000
as well. I also have a 3000 and I used a self mixed version of his VM
quads for quite a while in both my 1200 and the 3000. There were no
particular problems with it. I then went to the UT quads and that is
where I learned of the Eboni problem. Although I cleaned the heads and
the carts thoroughly, I didn't get the cap station on the 3000 clean
enough and it would gunk up constantly. I finally did a good job on it
and no problems since.
You can rinse out your old 3000 carts with a 10:1 mix of distilled
water and clear household ammonia. Just flush them with 20 or 30 ml
several times and leave them lay on their side overnight with some in.
Then do a final flush with distilled H2O.
Duane
2008-02-07 by Gary Weaver
Hi Duane,
Great insight. My "working" 3000 came from a eBay seller with blocked damper and a shot head(the 1270 didn't work either) .
I just want original quadtone on the 3000 - I could care less about innovation . Where do I find ESC-Q-100%-4-K?
The 1270 will eventually get Eboni for BO, if they don't phase that out.
I've been cutting stiff posterboard (22x28", 10sheets for $4) and running it though QTR on the transparency/film setting. I'm quite happy with it. So, I don't want to change this match-up :  ) Who needs HPR??
>> gar
>Regards
>Duane
2008-02-07 by frankbickelmeyer
In the meantime i ordered the MIS Eboni in Bottles and a syringe. The
dealer told me that his ink is the matte Ultratone which is the
Eboni. I have an empty black cart here. I´ve found out that there is
no need to screw a hole into it, because i can put the needle into
the opening (vents) on the upside of the cart. But there are 2
openings on the upside, does anybody know which one i should use? Is
the black cart of the Epson 1200 1-chamber or 2-chamber? At the MIS
Homepage is a completely different approach: filling the card from
the bottom (into the opening where the ink comes out).
Somewhere else its recommended not to fill the ink with pressure, but
to let the cart dig the ink through the syringe by itself, what could
take several minutes...
I think i am confused.
<garww@...> wrote:
> Hi Duane,
out.
needs HPR??
too
> >> gar
black
3000
VM
is
and
clean
on it
in.
> >Regards
> >Duane
2008-02-09 by Gary Weaver
It is confusing, but you just have to think each step through.
I've only done top fill and it's a slow process - maybe a minute.
If there is a problem with Eboni interacting with epson dye, it should be covered on the MIS site.
gar
><garww@...> wrote:
>> Hi Duane,
>out.
>needs HPR??
>the
>too
>> >> gar
>black
>3000
>VM
>is
>and
>clean
>on it
>in.
>> >Regards
>> >Duane
>page.
>them short.
>the membership.
>section:
>PRINT YAHOO GROUP.
>Yahoo! Groups Links
