Printing On Gloss...Possible with Digital B&W?
2006-01-21 by Joanne Emerson
Greetings everyone!
 A photographer friend recommended this group to provide me with
some answers to digital printing on glossy/semi-gloss papers.
I'm a former model who is now working at the other end of the camera
photographing other models to help them build and develop their
books. When I shoot film I have access to a wet darkroom, it's
messy, very time consuming but the results are quite good. For
digital printing (Epson 2200 and high gloss/semi gloss papers) the
results don't compare to silver prints. But I'd prefer to shoot
digital and print on glossy papers, since b&w gloss prints are the
industry standard requested by agencies for modeling portfolios.
Can someone make some recommendations for inks that will improve the
quality of my digital prints on gloss papers. Hope to hear back from
someone soon.
Have a wonderful day!
Jo
Re: Printing On Gloss...Possible with Digital B&W?
2006-01-21 by Shilesh Jani
Jo,
Welcome to this sometimes neurotic, disfunctional group.
I am going to assume you do NOT want to mess with loading your own
inks, and playing around with RIPs, etc. Not knowing what you find
lacking in the 2200 printer (and there are many limitations there), I
can tell you you have 2 options that will give you better Gloss/Semi
Gloss prints straight out of the box:
(1) Epson R2400 using the Epson Advanced Black and White (ABW) mode.
You will get better black density (Dmax) and a more neutral print.
You can make the prints cooler, warmer, or other hues with relative
ease with ABW. The drawback is that there is still some residual
bronzing and gloss differential. But many people live with it, quite
happily.
(2) HP printers with their Vivera inks. Make sure you look at a model
that supports the b/w ink cartridges. You will get excellent gloss,
semi-gloss prints. The drawback is that you are limited to the
recommended HP papers, which are not completely water proof. The
prints dry down just fine after 24 hours.
One way to go about is to take a lap-top loaded with the printer
drivers for the printer (down-load from manufacturer web site), a USB
cable, and head over to CompUsa. Ask them to hook up their display
printers. If the manufacturer rep is around, you may not even have to
buy the paper for the respective printers. Try them out, and see if
they suit your needs.
Hope this helps.
Shilesh
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Joanne Emerson"
<jojo_xmodel@y...> wrote:
> Greetings everyone!
camera
from
> someone soon.
> Jo
Thank you, Shilesh!
Will using a RIP provide more options for me?
I have downloaded and installed a quadtone rip, are there special
inks I can buy for glossy or semi gloss papers if I use this
software?
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Shilesh Jani"
<shileshjani@b...> wrote:
> Jo,
there), I
Gloss/Semi
mode.
relative
quite
> happily.
model
gloss,
USB
to
if
> Hope this helps.
> Shilesh
Emerson"
> > Greetings everyone!
> camera
> the
> from
> > someone soon.
> > Jo
2006-01-21 by mxgo95747
> Thank you, Shilesh!
> software?
Try www.paulroark.com, one of gurus of this forum.  A lot of information on papers, inks,
just general info. for B&W printing. Take a look for recommended inks for the gloss and semi
gloss papers for your printer.  Also note that Kirkland Photo Glossy Paper which you can buy
at Costco makes an excellent proofing paper.  Unfortunatley, it only comes in a 8.5 by 11
size.
Good luck with your search.
Martin
Jo
Having a RIP always provides more options and control. QTR is indeed
great. And yes, you can play around with different inks, but be
forewarned it will seriouly curtail your productivity (making usable
prints)initiallly. And no, I am afraid there are no proven b/w inks
for use with gloss type papers. That does not mean there are no
alternative inks - there are many. But, you will face one of the
following problems (1) gloss differential with pigment type inks from
MIS, InkjetMall, etc or (2) Metamerism from dye type inks from Lyson
The 2400 (or 4800 if you want larger prints) will be such a dramatic
improvement over your current 2200 that you may find all the messing
around rather unnecessary. And yes, you can use QTR will the 2400.
For glossy, semi-glossy prints on the 2200 using Epson inks, QTR will
NOT reduce the pesky problem of bronzing/gloss differential. I forgot
to add earlier that if you are willing to spray coat (or laminate)
your prints than the bronzing/gloss differential can be reduced or
even eliminated. But perfecting spraying techniques is another PhD
project.
I am still under the assumption that you do not want to make a career
out of playing with inks. Currently there are no proven third-party
pigment type b/w inks for the 2200 which will beat the 2400 out-of-
the-box in the bronzing/gloss differential area.
Good luck, and if you can, sign up with Tom O'Connell's monthly print
exchanges. You get to see a variety of inks and papers.
http://groups.yahoo.com/group/DigitalBW-PrintExchanges/
I am working on a potential (unproven, no fade resistance data)
solution with NanoChrome inks, and if you are interested in playing,
send me an email, and I will walk you through it.
Shilesh
> Thank you, Shilesh!
> software?
> > Jo,
own
find
> there), I
> Gloss/Semi
> mode.
print.
> relative
> quite
> > happily.
> model
> gloss,
> USB
display
have
> to
> if
> > Hope this helps.
> > Shilesh
> Emerson"
> > > Greetings everyone!
with
> > camera
> the
> the
portfolios.
improve
> > the
> > from
> > > someone soon.
> > > Jo
2006-01-22 by Joanne Emerson
Oh my! This is starting to sound a little too complicated. What are
these alternative inks you are refering too? Will they work with the
Epson 2200 and gloss papers? How about the quadtone rip? I may be
better off shooting film and using a wet darkroom or buying the 2400.
Please explain.
Thnx!
Jo
> Jo
indeed
usable
inks
from
Lyson
dramatic
messing
will
forgot
> project.
career
party
print
playing,
> Shilesh
Emerson"
> > Thank you, Shilesh!
special
> > software?
Jani"
> > > Jo,
> own
> find
> > there), I
> > Gloss/Semi
> > mode.
> print.
> > relative
residual
> > quite
> > > happily.
a
> > model
> > gloss,
The
printer
site), a
> > USB
> display
> have
> > to
see
> > if
> > > Hope this helps.
> > > Shilesh
> > Emerson"
> > > > Greetings everyone!
> with
> > > camera
their
it's
For
papers)
> > the
shoot
are
> > the
> portfolios.
> improve
> > > the
back
> > > from
> > > > someone soon.
> > > > Jo
RE: [Digital BW] Re: Printing On Gloss...Possible with Digital B&W?
2006-01-22 by Paul Roark
> ... I am afraid there are no proven b/w inks
I find the bronzing and gloss differential with the new MIS inks to be
rather minimal on many glossy papers.
2006-01-22 by Chris Hargens
The alternative inksets are those from InkjetMall, MIS, Lyson, and
others. Each inkset has its strong and weak points. I think Shilesh's
main point is that with the 2400 you can get very good prints out of
the box. (See Clayton Jones' discussion --
http://www.cjcom.net/articles/digiprn9.htm --
of BW printing on the 2400. As for the 2200, I've used MIS PKN
http://www.inksupply.com/roarkslab.cfm
for black only printing on glossy papers and there is very little
bronzing, great dmax, but some dottiness, which isn't necessarily
bad.) Gloss differential/bronzing are not completely eliminated,
however, with the 2400. As far as I know, no pigment inkset completely
eliminates gloss differential/bronzing -- that, as well great dmax,is
why many people are interested in the potential of the Nanochrome inkset.
Chris Hargens
> Please explain.
> Thnx!
> Jo
> > Jo
> indeed
> usable
> inks
> from
> Lyson
> dramatic
> messing
> will
> forgot
> > project.
> career
> party
> print
> playing,
> Paul
> www.PaulRoark.com
What new inks are you referring to -- UT7 with Eboni?
Chris
2006-01-22 by Shilesh Jani
Paul,
How do the new MIS inks compare with the K3 2400 system regarding
bronzing, and on what papers?
I have played with the 2400, and I still do not like the inks sitting
on the surface, even though bronzing has been reduced.
Shilesh
from
> Paul
> www.PaulRoark.com
Re: [Digital BW] Re: Printing On Gloss...Possible with Digital B&W?
2006-01-22 by Carl Schofield
That appears to be one of the more subtle benefits of the Nanochrome
inks.  The image looks like it is embedded into the BO prints I've
been making on Hahnemuhle PR Satin using the Nanochrome K.
Carl
On Jan 21, 2006, at 8:09 PM, Shilesh Jani wrote:
> Paul,
> Shilesh
> from
>> to be
>> Paul
>> www.PaulRoark.com
And......would YOU display prints on these papers without coating them?
from
> Paul
> www.PaulRoark.com
Jo,
Yes it can get complicated. In reality it all depends on your needs.
It sure would help if we knew what you find the 2200 needs to be
improved upon.
If it is the uncontrolable color casts, then QTR will definitely help
a lot.
If you are not happy about the gloss differential, then you can (1)
consider another printer, (2) alternative inks, or (3) coating your
prints.
Your need for glossy prints is, I am afraid, the holy grail for
inkjet b/w. Things are so much better than 2 years ago, but there is
a long way to go yet.
I would be happy to send you some example prints. Others in this
forum would gladly do the same.
Regards.
Shilesh
2400.
> Please explain.
> Thnx!
> Jo
> > Jo
> indeed
> usable
> inks
> from
> Lyson
> dramatic
> messing
2400.
> will
> forgot
laminate)
or
PhD
> > project.
> career
> party
of-
> print
> playing,
> > Shilesh
> Emerson"
> > > Thank you, Shilesh!
> special
> > > software?
> Jani"
> > > > Jo,
your
> > own
> > find
> > > there), I
> > > Gloss/Semi
(ABW)
> > > mode.
> > print.
> > > relative
> residual
it,
> > > quite
> > > > happily.
> a
> > > model
> > > gloss,
> The
> printer
> site), a
> > > USB
> > display
> > have
> > > to
> see
> > > if
> > > > Hope this helps.
> > > > Shilesh
> > > Emerson"
> > > > > Greetings everyone!
> > with
papers.
> the
> > > > camera
> their
> it's
> For
> papers)
> > > the
> shoot
> are
> > > the
> > portfolios.
> > improve
> > > > the
> back
> > > > from
> > > > > someone soon.
> > > > > Jo
2006-01-22 by mxgo95747
> Please explain.
> Thnx!
> Jo
Here is the MIS Associates web page for the Epson 2200 using the QTR RIP:
http://www.inksupply.com/ut2200bh.cfm
  Note, that the inks are strictly for B&W printing.  Others can tell you about bronzing or
gloss differential (if any) with the above inks and QTR.
I have no experience with the Epson 2200.  But I can vouch for the 2400, the glossy prints
are very nice with the Epson k3 inks.
Martin
> > Paul
> > www.PaulRoark.com
About a year ago MIS started using a new base for all the UT type inks, not
the Eboni.  The new base made a very significant improvement in bronzing.
The gloss differential depends on what paper and black is being used.  I,
frankly, thing the dual dark gray ink generation of the black on glossy
paper, like is done with UT7 on the 2200 with curves does a good job of
avoiding the dulling that can happen with MIS PK.  The 2 dark grays can lay
down a dmax that is as good as the PK, but they are lower pigment load inks.
So, I think there is a better coating with the base that makes the
difference.
The uncoated MIS pigs are lower gloss and have less bronzing, but I have not
done a lot of work comparing the color inksets in a 2400.  Again, the PK
gloss differential issue is one I'm not certain on.  The MIS K4 PK uses a
lower load than the older PK.  Whether it can retain the same gloss as the
midtones is something I'm not sure of.  The coated PK seems to have the best
dmax and gloss retention there.  Balancing the gloss differential versus the
dmax is tricky.  That's why I mixed a special PKN for the 220.  I and some
others have tried Epson PK with MIS midtones, but then we tended to get a
transition area between the coated and uncoated pigs that looked rough.  I
think I'm still of the opinion the dual dark gray solution looks the best
with the uncoated pigs -- it's the same inks all the way down, with a
relatively low load of pigs and lots of base to coat them.  However, that
would be with the UT2 and UT7, not the 2400 with color inks.
I use Kirkland glossy paper, un-coated for brochures.  I think they look
fine.  Premium Semimatte and the beta Silver Rag also looked like they'd be
OK un-coated.  For display prints I still use matte paper -- no reflection
at all and easier to mount.  Frankly my reaction to the Silver Rag was that
they may have a paper that comes close to the fabled silver print, but after
getting used to matte papers, I'm not sure I want to go back to the silver
print look for display prints.
2006-01-22 by Clayton Jones
Paul,
>...they may have a paper that comes close to the fabled silver print,
>but after getting used to matte papers, I'm not sure I want to go
>back to the silver print look for display prints.
Exactly my sentiments, and "fabled" is a good word.  I held on to that
standard in my mind for a long time, but last summer I searched
through a box of old fiber base silver prints (mostly on Oriental
Seagull, Ilford MGFB and Galerie) looking for something and was struck
by how distracting and annoying the glare and reflections were.  I'd
forgotten how bad it was and realized how much I've come to love the
completely reflectionless carbon ink prints.
I think that was the final step in completely leaving behind the last
traces of desire to recreate the look of emulsion prints of any sort.
I believe I have now, even subconsciously, fully accepted and
embraced the fact that we are working with a different medium.
Clayton
Hear, hear. Now let us (Epson, or anyone else for that matter)find a
the K ink which gives us Dmax in the 2 range on matte papers.
<cj@c...> wrote:
> Paul,
print,
that
struck
last
sort.
> Regards,
> Clayton
Nanochrome black ink gives dmax on matte papers close to 2.
> <cj@c...> wrote:
>> Paul,
> print,
> that
> struck
> last
> sort.
>> Regards,
>> Clayton
2006-01-22 by Steven Karafyllakis
Matte paper might well be reflectionless held in your hand, with no
glass-but if you put a silver gel print, a semi-matte inkjet print
and a matte inkjet print under glass and hang them on the wall, they
all become equally reflective, since you are now looking at the
reflections of the glass. The factors that do not get equalized are
the more important ones-the tonal range and dmax of the FB print,
the better dmax and shadow detail retention of the semi-matte
inkjet. So I for one (since we seem to be conducting another
impromptu poll) am not ready to write of the FB look and advantages.
I've said it before, I'll say it again: I want it all.
 my 2c worth
Steven Karafyllakis
a
Jones"
> <cj@c...> wrote:
> > Paul,
> print,
go
to
> that
> struck
I'd
> last
> sort.
> > Regards,
> > Clayton
Steve,
Thanks a lot - you've just ruined the "feel-good" I was having!
How's it going? Haven't seen you in a print exchange in a while.
Would love to see more of the Florida Swampland and the Greek Isles.
Shilesh
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Steven
they
advantages.
>  my 2c worth
> Steven Karafyllakis
find
> a
> Jones"
> > <cj@c...> wrote:
> > > Paul,
> > print,
> go
> to
> > that
Oriental
> > struck
were.
> I'd
love
> the
> > last
> > sort.
> > > Regards,
> > > Clayton
2006-01-22 by Steve Kale
Don't put them behind glass...or worse yet, cheap glass.
> From: Shilesh Jani <shileshjani@...>
> Date: Sun, 22 Jan 2006 20:26:11 -0000
> Subject: [Digital BW] Re: Printing On Gloss...Possible with Digital B&W?
> Steve,
> Shilesh
> they
> advantages.
>>  my 2c worth
>> Steven Karafyllakis
2006-01-23 by Steven Karafyllakis
Sorry Shilesh, didn't mean to pop your bubble. I had an interesting
weekend last week: I took part in an outdoor art fair, little white
tent and all. I had both inkjets and FB prints under glass on the
walls, and inkjets only in flip-racks on the side.
The most common question the entire weekend is 'what's a carbon-
pigment inkjet print?' Good opportunity to educate a lot of people.
Many also expressed surprise and amazement at how good the inkjets
looked, on the wall next to some of my best FB prints. But there
were a few-(not many mind you) that immediately said 'yea, they're
good, but I can still see the difference'. That says to me  we (or
at least I) still have that 10% to go, though we are so much closer
than a couple years ago.
And yes, you can make the argument that it is it's own medium and
should be accepted on its own terms, but face it-in most ways, for
most uses, digital printing isn't really going to be a parallel
technology. It is a replacement, and I for one don't want to have to
make any excuses or feel like we have given up anything in quality
for the sake of convenience or whatever. So pardon me if I keep
pushing till we get there! (dirty job... etc.,etc.)
Steve
> Steve,
Isles.
> Shilesh
no
print
> they
are
print,
> advantages.
> >  my 2c worth
> > Steven Karafyllakis
Jani"
> find
> > a
> > Jones"
> > > <cj@c...> wrote:
> > > > Paul,
silver
> > > print,
to
> > go
on
> > to
> > > that
searched
> Oriental
was
> > > struck
> were.
> > I'd
> love
> > the
> the
> > > last
any
> > > sort.
medium.
> > > > Regards,
> > > > Clayton
2006-01-23 by Shilesh Jani
Hell no, it is a pissy, rainy day here anyway - and, I understand.
When newstand magazines such as B&W and Lenswork are routinely
hitting 2.0, it makes me wonder what I am doing accepting the 1.6 -
1.7 range. The last 2 weeks, I have not done much in my spare time
than putz around with NanoChromes. At this time I have given up the
idea that they may be a panacea to all our woes (desires?).
But.....the last hope is to use the NanoChrome K with more
traditional inks in the LK, LLK, LLLK (sorry, I had to do that
because I am working on a Quad set right now). If you push the K far
enough into the shadows, the cool tone of the ink becomes rather moot.
Regards.
Shilesh
to
> Steve
Jani"
> > Steve,
> Isles.
> > Shilesh
with
> no
> print
> > they
> are
> print,
> > advantages.
> > >  my 2c worth
> > > Steven Karafyllakis
> Jani"
> > find
> > > a
> > > Jones"
> > > > <cj@c...> wrote:
> > > > > Paul,
> silver
> > > > print,
want
> to
> > > go
> on
> > > to
> > > > that
> searched
> > Oriental
> was
> > > > struck
> > were.
> > > I'd
> > love
> > > the
behind
> > the
> > > > last
> any
> > > > sort.
and
> medium.
> > > > > Regards,
> > > > > Clayton
2006-01-23 by Carl Schofield
I'll be curious to know how your mixed bag of inks works out.  Are
you intending to use the Nanochrome black with the Epson K3 light
blacks?
Carl
> Regards.
> Shilesh
> to
>> Steve
> Jani"
>>> Steve,
>> Isles.
>>> Shilesh
> with
>> no
>> print
>>> they
>> are
>> print,
>>> advantages.
>>>>  my 2c worth
>>>> Steven Karafyllakis
>> Jani"
>>> find
>>>> a
>>>> Jones"
>>>>> <cj@c...> wrote:
>>>>>> Paul,
>> silver
>>>>> print,
> want
>> to
>>>> go
>> on
>>>> to
>>>>> that
>> searched
>>> Oriental
>> was
>>>>> struck
>>> were.
>>>> I'd
>>> love
>>>> the
> behind
>>> the
>>>>> last
>> any
>>>>> sort.
> and
>> medium.
>>>>>> Regards,
>>>>>> Clayton
2006-01-23 by Clayton Jones
Steve,
Very true, all good points.  I hope someday we do have it all.
Clayton
Carl,
In a few days, as soon as my replacement 2400 arrives, I will be
loading Nanochrome K (as the black ink), the Epson MK (as the
darkest gray), followed by LK, LLK.
My thought is to restrict the Nanochrome K to the very dark end of
the scale so its's color does not impact the overall print.
IAH, I am just playing around.
Regards.
Shilesh
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Carl Schofield
Are
> blacks?
> Carl
understand.
1.6 -
time
far
moot.
> > Regards.
> > Shilesh
interesting
white
people.
inkjets
they're
(or
closer
and
for
have
> > to
quality
> >> Steve
> > Jani"
> >>> Steve,
while.
> >> Isles.
> >>> Shilesh
> > with
> >> no
> >> print
wall,
> >>> they
equalized
> >> are
> >> print,
> >>> advantages.
> >>>>  my 2c worth
> >>>> Steven Karafyllakis
> >> Jani"
matter)
> >>> find
> >>>> a
> >>>> Jones"
> >>>>> <cj@c...> wrote:
> >>>>>> Paul,
> >> silver
> >>>>> print,
> > want
> >> to
> >>>> go
> >> on
> >>>> to
> >>>>> that
> >> searched
> >>> Oriental
> >> was
> >>>>> struck
> >>> were.
> >>>> I'd
> >>> love
> >>>> the
> > behind
> >>> the
> >>>>> last
> >> any
> >>>>> sort.
> > and
> >> medium.
> >>>>>> Regards,
> >>>>>> Clayton
2006-01-23 by hogarth@snappydsl.net
Shilesh Jani wrote:
> Carl,
> Regards.
> Shilesh
Just a dumb question - why aren't you using the NanoChromes as a set?
What advantage do you see in using the K3s for the color inks? Seems
like you must be giving up some gamut width, not to mention the fact
that the NanoChrome K is the correct color to work with the rest of the
NanoChromes.
So I'm lost. What are you trying to accomplish by mixing the inksets?
Bruce Watson
Hello Bruce,
Maybe it's because the Nanos aren't made for the K3 printers - there
is no LLK.
Clayton
2006-01-23 by Chris Hargens
I'd be interesting in seeing how the Nanochrome inkset would work
running QTR on a 2200. Seems to me that the chief advantage of the
2400 -- the ability to print on glossy papers without the usual UC
gloss differential/bronzing problems -- would be disappear. Further,
with the Nanochromes you would get greater dmax on both matte and
glossy papers.
Chris Hargens
<cj@c...> wrote:
> Hello Bruce,
> is no LLK.
> Regards,
> Clayton
2006-01-23 by Steve Kale
Nanochrome K underperforms Epson K3 PK, although not by a large visual
amount.  On certain matte papers it seems, judging from some posts here, to
be only as good as Eboni.
> From: Chris Hargens <chargens@...>
> Date: Mon, 23 Jan 2006 17:39:33 -0000
> glossy papers.
> Chris Hargens
2006-01-23 by Joanne Emerson
Hello everyone, I'm back from out of town.
I can see there's been much discussion about printing b&w on glossy
media while I've been away. Unfortunately, I'm not sure if anyone
has answered my question. Yes,I could purchase a 2400 printer, but
until I do, I'm stuck with this 2200 using QTR or Epson drivers. I'm
just looking for the best possible solution. Will the UT7 inks give
me reduced bronzing? Must I also use a GLOP? I'd like to learn more
about this since printing on glossy or semi glossy media is the
industry standard for what I do. Finding a solution is becoming
quite complex and I'm starting to feel like a really dumb broad, so
please be patient with me.
Have a good day!
Joanne
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Chris Hargens"
Further,
> glossy papers.
> Chris Hargens
Jones"
> <cj@c...> wrote:
> > Hello Bruce,
be
there
> > is no LLK.
> > Regards,
> > Clayton
Thanks for the input, Steve. Are you referring to dmax? I'm not trying
to be argumentative, but how do you account then for Daniel Staver's
post (72934)? Also what about gloss differential/bronzing? The
messages I've read suggest that the Nanochrome inkset outperforms K3
in this area.
You've been working with this inkset. What's your impression?
Chris Hargens
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Steve Kale
here, to
> > From: Chris Hargens <chargens@s...>
Digital B&W?
> > glossy papers.
> > Chris Hargens
2006-01-24 by Shilesh Jani
Hello Jo,
I must ask this: have you printed a b/w photograph with the 2200
using either the Epson driver or QTR? If so, what do you find lacking
in the prints? If it is bronzing, then you can spray the prints.
One we know what your exact needs, we can help you further.
Shilesh
I'm
> Have a good day!
> Joanne
Hargens"
> Further,
> > glossy papers.
> > Chris Hargens
> Jones"
> > <cj@c...> wrote:
> > > Hello Bruce,
> be
> there
> > > is no LLK.
> > > Regards,
> > > Clayton
Bruce,
It is along story - suffice to say I have given up on using
NanoChrome as a single universal inkset for color, b/w, matte, and RC
papers because the cool LK is tough to neutralize and take it into
the warm side of neutral. So, along with that goes my ability to
print on RC papers (my desire was not there anyway).
But the NanoChrome K does indeed deliver much greater Dmax (~1.9) on
Hanhnemuhle rag papers, compared to 1.6 for the Epson MK, and perhaps
1.7 for Eboni. Going from 1.7 to 1.9 is rather huge. So my thought is
to create a b/w inkset for matte papers using the NanoChrome K. The
choice of LK, LLK, LLLK, etc is rather a matter of preference. This
is all about b/w prints, so color gamut is moot. I will always keep
the LM and LC (and perhaps Y) for control of tone.
Make sense? I know, it is pure madness!
Shilesh
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, hogarth@s...
wrote:
> Shilesh Jani wrote:
> > Carl,
> > Regards.
> > Shilesh
set?
Seems
fact
> NanoChromes.
inksets?
> Bruce Watson
2006-01-24 by Joanne Emerson
Hi Shilesh, yes, I have. I find the results are good on matte paper
with QTR but not Epson because of the slight color cast. On gloss
paper using the Epson driver, the prints turn out brown with
bronzing...very unsatisfactory. Same more or less with QTR. Now bear
in mind I am using Ultrachrome inks, which is why I'm starting to
investigate other inks for my 2200 that hopefully will give me more
favorable results.
Question: You mention spraying the prints, what do you suggest?
> Hello Jo,
lacking
> Shilesh
Emerson"
glossy
anyone
but
> I'm
give
more
so
> > Have a good day!
> > Joanne
> Hargens"
work
usual UC
> > Further,
and
> > > glossy papers.
> > > Chris Hargens
> > Jones"
> > > <cj@c...> wrote:
> > > > Hello Bruce,
will
> > be
inks?
printers -
> > there
> > > > is no LLK.
> > > > Regards,
> > > > Clayton
Chris,
NanoChrome on a 2200 does work, and you are right you can print
glossy and matte, and NO bronzing. Sounds great doesn't it? But wait
a minute: The K and LK of NanoChrome are rather cold in tone, and can
be neutralized or taken into the warm spectrum only if you add both
LM (or M) AND Y. When you add Y you are in rather sticky situation
becuase the print can swing along the magenta-green axis under
daylight-flourescent lighting conditions. If you accept slightly
green prints under fluro lights, you should be fine.
Seeing such a high Dmax AND absolutely no bronzing in a print is a
joy indeed.
Shilesh
--- In DigitalBlackandWhiteThePrint@...m, "Chris Hargens"
> glossy papers.
> Chris Hargens
> <cj@c...> wrote:
> > Hello Bruce,
there
> > is no LLK.
> > Regards,
> > Clayton
2006-01-24 by Carl Schofield
Shilesh,
I added the Nanochrome black to my Epson 4000 dual piezo quad setup.
Works great and I now have the option of producing prints with cool
shadow tones and a huge dmax on rag papers.  The Nanochrome black
simply replaced the flush cart in the unused PK position.
So, my inks set-up in the 4000 is as now follows (CS = carbon sepia,
k7 = Neutral k7):
MK - Piezo k7 MK
C - Piezo CS dark gray
M - Piezo CS mid gray
Y - Piezo k7 light gray #7
PK - Nanochrome K
LC - Piezo k7 dark gray #3
LM - Piezo k7 mid gray #5
LK - Piezo CS light gray
I now have two K's to choose from and 4 profiles to run these quad
inks.  One set with the piezo MK for k7 neutral and CS and a new
second set with the Nanochrome K.  The latter gives me cool shadows,
but also much deeper blacks (dmax 1.9+ vs 1.6+ with the k7 MK) in the
shadows.  Sort of a subtle split tone appearance in some prints, but
I'm happy so far with this setup.  I might pull the Nanochrome K back
into the shadows a bit more.  Pity I can't access both K channels at
once on the 4000 or I'd use that piezo MK as a very dark gray to
transition from the Nanochrome K to the dark piezo grays.  I sent you
the profiles to look at and the icc's will give you a good softproof
of the print colors.
Carl
On Jan 23, 2006, at 8:34 PM, Shilesh Jani wrote:
> Bruce,
> Shilesh
> wrote:
>> Shilesh Jani wrote:
>>> Carl,
>>> Regards.
>>> Shilesh
> set?
> Seems
> fact
> the
>> NanoChromes.
> inksets?
>> Bruce Watson
Jo,
I am not a sprayer ;-), but I have heard good things about Premier
Art Print Shield. Many months ago, I had painstakingly sprayed an RC
print with some acrylic from the art supply store. It was very nice,
but what a hassle, phew. You can always get prints sprayed
commercially, I guess.
OK, now I know what you have tried, and what you want improved.
Neither Paul Roark nor Inksupply (MIS) represent UT7 inks as free
from bronzing. Infact, Paul talks of using GLOP in the Y position to
help reduce bronzing with this inkset. So my assumption is that as-is
UT7 will not be much help in reducing bronzing. Perhaps a kind soul
in this forum who uses the inkset will volunteer to make a print for
you.
You may want to check messages in thsi forum by Daniel Staver and
Steve Karafyllakis who I know have played with GLOP, and perhaps
others too.
The best, sure-fire bet is to use inks specifically designed to do
what you want, i.e., the Epson K3 inks. You could easily buy the K,
LK, and LLK 220 ml carts for the 4800 printer, suck the inks out,
load them into the 2200 carts, write QTR curves, and viola you've got
the latest and greatest in RC b/w printing. I bet this will produce
the LEAST bronzing on RC papers than any other 3rd party b/w
pigmented inset. Oh, boy I hope I have not vaused a firestorm with
that last statement.
If I were going down that path, here is what I would do:
K2200 = PK4800
C2200 = C4800
M2200 = M4800
LC2200 = L4800
LM2200 = L4800
LK2200 = LK4800
Y2200 = LLK4800.
This allows you to neutralize in QTR the otherwise warm PK, LK, and
LLK.
Sounds like fun, doen't it? Welcome to the neurosis I alluded to
earlier.
Shilesh
bear
> favorable results.
> > Hello Jo,
> lacking
> > Shilesh
> Emerson"
> glossy
> anyone
> but
drivers.
> > I'm
> give
> more
broad,
> so
> > > Have a good day!
> > > Joanne
> > Hargens"
> work
of
> the
> usual UC
> > > Further,
> and
> > > > glossy papers.
> > > > Chris Hargens
> > > Jones"
> > > > <cj@c...> wrote:
> > > > > Hello Bruce,
> will
> > > be
> the
> inks?
> printers -
> > > there
> > > > > is no LLK.
> > > > > Regards,
> > > > > Clayton
2006-01-24 by Clayton Jones
Hello Joanne,
I can't answer your question because I only print matte, but maybe I
can offer some perspective as an interested observer.  From
discussions on this forum over the past 2+ years since the 2200
appeared, it seems that glossy printing has never become perfectly
satisfactory.  All sorts of things have been tried including glop and
various sprays, with various inks from UC to UT7 to custom mixtures,
and various softwares from Epson to QTR/IP/IJC, etc., in every
possible combination.
My impression is that the latest MIS ink with the new base is about
as good as it has ever been.  But my sense from reading the posts is
that it's still not perfectly satisfactory (and if I'm wrong on any of
this I hope other folks will jump in here and maybe you'll get the
info you need).  My sense is that the search continues, and people try
one thing and aren't fully satisfied and then try something else.  It
seems endless, with regular discussions of the merits/demerits of
various ink/paper/spray/RIP/curve/workflow combinations.
Out of the fog of battle emerges the 2400 (and other K3 printers),
which apparently the glossy folks are very happy about.  From what I
understand, it produces very fine glossy prints without bronzing,
gloss differential and metamerism, and excellent dmax and smoothness,
with complete tone control and without requiring a RIP (again, if I'm
wrong someone jump in here).
If the above is true, then it seems that it comes down to whether your
personal techno-fiddling patience threshold allows you to stick with
the 2200 and duke it out, or whether you're willing to spend the money
to get a 2400 and avoid all the hassles and save time.  Some people
don't mind tinkering and experimenting (some even love it), and others
have no patience for it and just want to do the photography.
What is your time worth?  Will the time you spend experimenting with
the 2200 searching for a satisfactory solution (and the ink/paper cost
of the same) outweigh the cost buying a 2400 and the time/effort of
selling the 2200?
I hope this helps.
Clayton
2006-01-24 by helen_bach2003
Joanne,
Shilesh has described almost exactly what I do, except that I use
IJC/OPM and this is my ink setup:
K2200 = MK4000/4800 (same)
LK2200 = PK4800
C2200 = LK4800
LC2200 = LLK4800
M2200 = LC4800
LM2200 = Krystal Topkote
Y2200 = R800 blue.
I chose the blue and the LC after testing. R800 red is also good, if
you like warm tones. The Topkote and the blue could be switched, of
course. It doesn't matter to me, because I overcoat on a second pass.
I've sent you an email.
Best,
Helen
> Jo,
> K2200 = PK4800
> C2200 = C4800
> M2200 = M4800
> LC2200 = L4800
> LM2200 = L4800
> LK2200 = LK4800
> Y2200 = LLK4800.
> LLK.
> earlier.
> Shilesh
Clayton,
Well put. The only minor clarification: the K3 class of printers have
significantly REDUCED bronzing, not eliminated it. I can see it when
holding prints in my hands, I doubt it will be a factor behind glass.
Shilesh
<cj@c...> wrote:
> Hello Joanne,
glossy
I'm
give
more
so
and
of
try
It
smoothness,
I'm
your
money
others
cost
> selling the 2200?
> I hope this helps.
> Regards,
> Clayton
Way to go, Helen!
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "helen_bach2003"
<helenbach@h...> wrote:
> Joanne,
> LK2200 = PK4800
> C2200 = LK4800
> LC2200 = LLK4800
> M2200 = LC4800
> Y2200 = R800 blue.
pass.
> Best,
> Helen
> > Jo,
do
K,
got
produce
with
> > K2200 = PK4800
> > C2200 = C4800
> > M2200 = M4800
> > LC2200 = L4800
> > LM2200 = L4800
> > LK2200 = LK4800
> > Y2200 = LLK4800.
and
> > LLK.
> > earlier.
> > Shilesh
2006-01-24 by Steven Karafyllakis
Shilesh;
I'm currently using the MIS version of the K3 inks (K4), and my
eperience is that they bronze LESS than the Epsons. At least when I
finally changed out the PK the last of the bronzing went away and
glop became virtually pointless. The downside is that the Epson PK
produces a tiny bit better Dmax, but nothing really significant.
soul
for
> you.
If the K4 PK LK and LLK combination is of interest, I'd be happy to
provide a sample print. Perhaps someone else can provide the
eqivalent in K3 for comparison?
Personally, I think if Jo is game enough to dive into QTR and
refilling, she would do better to go straight to the readily
available and much less expensive MIS K4 rather than draining 4800
Epson carts. The cost difference over the long haul is significant,
and quantity headshots in the modeling world bring in very little $
per print.
> others too.
2006-01-24 by Paul Roark
> ... Paul talks of using GLOP in the Y position to
> UT7 will not be much help in reducing bronzing...
With the current MIS inks -- including UT2 and  UT7 -- I no longer recommend
Glop.
2006-01-24 by Steve Kale
You said on "both matte and glossy papers".  On certain matte papers Nano NK
performs very well, eg HPR and HPR Satin.  It has a "normal" response on
Epson Archival Matte and PremierArt Hot Press.  Epson PK does slightly
better on RC papers but of course you have bronzing and gloss differential
to worry about.
> Date: Mon, 23 Jan 2006 23:50:50 -0000
> in this area.
> Chris Hargens
> here, to
> Digital B&W?
>>> glossy papers.
>>> Chris Hargens
2006-01-24 by John Moody
That sounds like the definition of illuminant metamerism.
Would the following statement be correct?  When printed at the inksets
native gray tone(s), the prints are metamerism free, but when profiled to
produce neutral D50 grays, the prints exhibits illuminant metamerism.
Best regards,
John Moody
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com]On Behalf Of Shilesh
Jani
Sent: Monday, January 23, 2006 8:44 PM
Chris,
joy indeed.
Shilesh
And I'd be happy to send her a 2200/K3 and 2200/K3 + Krystal Topkote.
I had already made the offer by email.
I don't think that the vague bundle of half-baked reasons I have for
using the K3 inks would apply to the headshot business.
Thoughts about doing headshots with a 2200 and QTR: just out of
interest how long does it take to do a letter/A4 sized print with QTR?
Wouldn't it be a good idea to offer colour as well? I do wonder if
this isn't one case where printing onto light-sensitive paper (I'm not
going to call it analogue) is the cheapest and best way of doing it.
Best,
Helen
2006-01-24 by djon43
Silver printing of headshots for serious marketeers (eg for adolescent
models, managers of 50 years old motel lounge rock bands or aging
former starlets) involves hundreds of prints and costs start at around
$2.50 each, dropping  to  $.50 each or less (depending on
middlemen)...the standard and cheapest  when the headshots are
lithographic.
Nobody important cares about gloss for headshots, it's only a
photographer's affectation. It has nothing to do with utility, whether
portfolio or reproduction. In any case, the utility of printed
headshots is vanishing...the main distribution is now online anyway.
Ordinarily the images require captions, which when photographically
printed means they are contact printed for sharpness...they're
sometimes even gang printed (eg 4-up) and cut.
I don't think inkjet printing can do a typical order of, say, 500,
within a time frame that allows the work to be done
economically...even at minimum wage. Better to have the work done in
India.
Check it out. Visit labs or websites that deliver the services.
Djon
>   I do wonder if
> Best,
> Helen
2006-01-24 by Chris Hargens
What you say makes sense. But it leads me to also question the
Nanochrome for color printing since it appears that in color prints
your neutrals would be susceptible to color shifts under changing
lighting conditions. Of course all prints do this to some extent. When
I print color on Entrada Natura and the print emerges from my 2200
under the room's fluorescent light -- I do the PS edit in the dark --
it usually looks slightly yellowish to me; but when I view the print
under natural light, or my Ott-lite, the apparent color cast
disappears. Unlike the metamerism I see in 2200 UC BW prints using the
Epson driver, this change in tone seems like natural phenomena of
lighting rather than a weird byproduct of combining different colored
pigments to achieve a neutral gray.
Chris Hargens
> Chris,
> joy indeed.
> Shilesh
> > glossy papers.
> > Chris Hargens
> > <cj@c...> wrote:
> > > Hello Bruce,
> there
> > > is no LLK.
> > > Regards,
> > > Clayton
--- In
> Joanne,
> LK2200 = PK4800
> C2200 = LK4800
> LC2200 = LLK4800
> M2200 = LC4800
> Y2200 = R800 blue.
if
pass.
> Best,
> Helen
> > Jo,
do
K,
out,
you've got
produce
with
> > K2200 = PK4800
> > C2200 = C4800
> > M2200 = M4800
> > LC2200 = L4800
> > LM2200 = L4800
> > LK2200 = LK4800
> > Y2200 = LLK4800.
and
> > LLK.
> > earlier.
> > Shilesh
Helen, Shilesh...so if I understand you both correctly, you buy ink
carts for the 4800 printer and use these inks in the empty 2200
carts? Man, that sounds messy and quite labor intensive. What about
these Nanochrome inks for the 2200? Is there less bronzing with
them?  How can I find out more about these inks?
Jo
--- In
> Joanne,
> LK2200 = PK4800
> C2200 = LK4800
> LC2200 = LLK4800
> M2200 = LC4800
> Y2200 = R800 blue.
if
pass.
> Best,
> Helen
> > Jo,
do
K,
out,
you've got
produce
with
> > K2200 = PK4800
> > C2200 = C4800
> > M2200 = M4800
> > LC2200 = L4800
> > LM2200 = L4800
> > LK2200 = LK4800
> > Y2200 = LLK4800.
and
> > LLK.
> > earlier.
> > Shilesh
Thank you, Clayton!
<cj@c...> wrote:
> Hello Joanne,
glossy
but
I'm
give
more
so
I
and
mixtures,
is
any of
try
It
I
smoothness,
I'm
your
with
money
others
with
cost
> selling the 2200?
> I hope this helps.
> Regards,
> Clayton
Joanne,
Look at the last posting by Steve Karafyllakis. He has volunteered
to print with MIS K4 inks for you, and I can offer the exact same
photograph printed on a 2400 using Epson K3 inks. Send us an email
with the image you want printed.
Shilesh
Emerson" <jojo_xmodel@y...> wrote:
> Thank you, Clayton!
Jones"
> <cj@c...> wrote:
> > Hello Joanne,
> glossy
anyone
> but
drivers.
> I'm
> give
> more
broad,
> so
maybe
> I
perfectly
glop
> and
> mixtures,
about
posts
> is
> any of
people
> try
else.
> It
printers),
what
> I
> smoothness,
if
> I'm
whether
> your
> with
> money
people
> others
> with
ink/paper
> cost
of
> > selling the 2200?
> > I hope this helps.
> > Regards,
> > Clayton
Jo,
Emptying a 4800 cartridge is no big deal. If you are willing to fill
your own, the extra work involved in emptying the simple cartridges is
trivial.
It looks like you have the opportunity to do an interesting
comparison: K4 inks from Steve, proper K3 from Shilesh and pseudo
K3+Topkote from me.
Best,
Helen
> Jo
Helen, Joanne, Steve,
Would you be interested in a mini technical exchange?
Shilesh
--- In
> Jo,
fill
cartridges is
> trivial.
> K3+Topkote from me.
> Best,
> Helen
Emerson"
ink
about
> > Jo
2006-01-25 by Joanne Emerson
Djon, you are correct in your comment about the economies of scale
of printing offered by labs. But I am not a high volume operator. So
to go that route at this time would not offer me any significant
advantage. And yes, most intermediate to professional models do have
a website, but black and white headshots, full length, 3/4 length,
etc. shots (although it may seem old school) are still the industry
standard for younger models as requested by their agents and
agencies. When I started in the business in my late teens it was a
necessity, maybe not anymore but still quite in demand.
Jo
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "djon43"
adolescent
around
> lithographic.
whether
anyway.
in
> India.
> Djon
> >   I do wonder if
(I'm not
it.
> > Best,
> > Helen
2006-01-25 by Greg
> Jo,
is
> trivial.
Trivial almost makes it sound difficult. Slit the label, pop the
cover, cut a corner off the bad and empty. The now dead empties can
be used to make a CIS by those that are interested in such things.
Shilesh, I'm a little new to this but where can I find more info on
the MIS K4 inks? I've searched their website and cannot find any
reference to these inks. Can you tell me more about them?
Jo
> Joanne,
> Shilesh
> > Thank you, Clayton!
> Jones"
> > <cj@c...> wrote:
> > > Hello Joanne,
> > glossy
> anyone
printer,
> > but
> drivers.
> > I'm
inks
> > give
learn
> > more
becoming
> broad,
> > so
> maybe
> > I
> perfectly
> glop
> > and
> > mixtures,
> about
> posts
> > is
on
> > any of
> the
> people
> > try
> else.
> > It
of
> printers),
> what
> > I
bronzing,
> > smoothness,
> if
> > I'm
> whether
> > your
stick
> > with
> > money
> people
and
> > others
experimenting
> > with
> ink/paper
> > cost
time/effort
> of
> > > selling the 2200?
> > > I hope this helps.
> > > Regards,
> > > Clayton
2006-01-25 by Shilesh Jani
Joanne,
Here it is:
http://www.inksupply.com/arcink_k4.cfm
Please note that this inkset is recommended for 2400, etc printers.
It includes LLK (which your 2200 does not have). So you will have to
sacrifice one of the color ink positions on your 2200. I would get
PK, C, LC, M, LM, LK, and LLK if I were you - you scarifice Y (which
will limit your ability to print sepia). The esesntial inks are PK,
LK, LLK, LM, and LC, the rest is up to you.
MIS does not appear to prefill these inks for the 2200, so you will
have to fill them yourself.
http://www.inksupply.com/epsoncarts_xx.cfm
These do NOT appear to be spongless carts, so there may be some
filling technique issues (vacuum fill?).
Let me know if you are interested in receiving Epson 2400 K3 prints
from me, preferably of one of your images.
Shilesh
> Jo
> > Joanne,
volunteered
email
> > Shilesh
> > > Thank you, Clayton!
> > Jones"
> > > <cj@c...> wrote:
> > > > Hello Joanne,
> > > glossy
> > anyone
> printer,
> > > but
> > drivers.
> > > I'm
> inks
> > > give
> learn
> > > more
> the
> becoming
> > broad,
> > > so
> > maybe
> > > I
2200
> > perfectly
> > glop
> > > and
> > > mixtures,
> > about
> > posts
> > > is
> on
> > > any of
get
> > the
> > people
> > > try
> > else.
> > > It
merits/demerits
> of
> > printers),
> > what
> > > I
> bronzing,
> > > smoothness,
(again,
> > if
> > > I'm
> > whether
> > > your
> stick
> > > with
> the
> > > money
> > people
> and
> > > others
> experimenting
> > > with
> > ink/paper
> > > cost
> time/effort
> > of
> > > > selling the 2200?
> > > > I hope this helps.
> > > > Regards,
> > > > Clayton
Thank you, Shilesh, I'll check it out, don't leave town as I'm sure
I'll have more questions...lol.
Jo
> Joanne,
> Here it is:
printers.
to
(which
PK,
will
prints
> Shilesh
Emerson"
on
> > Jo
Jani"
> > > Joanne,
> volunteered
same
> email
> > > Shilesh
> > > > Thank you, Clayton!
> > > > --- In
> > > Jones"
> > > > <cj@c...> wrote:
> > > > > Hello Joanne,
on
> > > > glossy
if
> > > anyone
> > printer,
> > > > but
> > > drivers.
> > > > I'm
> > inks
> > > > give
> > learn
> > > > more
is
> > the
> > becoming
> > > broad,
> > > > so
but
> > > maybe
> > > > I
> 2200
> > > perfectly
including
> > > glop
> > > > and
> > > > mixtures,
every
is
> > > about
> > > posts
> > > > is
wrong
> > on
> > > > any of
> get
> > > the
and
> > > people
> > > > try
something
> > > else.
> > > > It
> merits/demerits
> > of
> > > printers),
From
> > > what
> > > > I
> > bronzing,
> > > > smoothness,
> (again,
> > > if
> > > > I'm
> > > whether
> > > > your
> > stick
> > > > with
spend
> > the
> > > > money
Some
> > > people
it),
> > and
> > > > others
photography.
> > experimenting
> > > > with
> > > ink/paper
> > > > cost
> > time/effort
> > > of
> > > > > selling the 2200?
> > > > > I hope this helps.
> > > > > Regards,
> > > > > Clayton
2006-01-25 by Clayton Jones
There is no issue with the MIS 2200 carts with sponges.  I don't know
where this irrational obsession with spongless carts has come from.
The MIS refillable 2200 carts are great and easy to use.  Just top
fill with a syringe through the hole and put in the plug.  Done.  No
muss, no fuss, no priming, no vacuum anything.
When you put them in the slot, let the ink carriage sit for 5 minutes
before pressing the ink button.  This allows the new ink to work its
way down into the head.  Press the ink button too soon and you'll have
air in the heads and get bad nozzle tests and have to do cleaning
cycles and waste ink.  Just wait 5 minutes or so and you'll rarely
have to do cleaning cycles.  I usually insert the new carts and then
head for the kitchen for a snack.
Clayton
2006-01-25 by Steven Karafyllakis
Clayton:
>  I don't know
Having suffered it myself, I'd say it is "post traumatic stress
syndrome" brought on by having to repeatedly suck foam out of the
1270/1280 carts in order to refill them. It even sounds gross, doesn't
it? (G)
Steve Karafyllakis
http://www.stevekphoto.com
2006-01-25 by Steve Kale
They're shite and I won't touch them.  I'm using spongeless carts from
Mandev in the UK and they work a treat.  If any air gets in via the poppet
valve, say when loading or unloading, it can make its way to the top of the
cart.  Basic stuff and it works well.  The sponge carts trap air around the
poppet valve.  Avoid them if you can.
> From: Clayton Jones <cj@...>
I'm not seeing any colour shifts between varying degrees of sunlight and
halogen - other than the warmth of paper white.
> From: John Moody <moodymz3@...>
> Date: Tue, 24 Jan 2006 07:38:37 -0500
> Subject: RE: [Digital BW] Re: Printing On Gloss...Possible with Digital B&W?
> Best regards,
> John Moody
2006-01-25 by John Moody
Thanks for sharing the observation.
It might be interesting to place a colorchecker on both the nano print and
one from Epson ABW and take a picture of them in different light with the
1Ds-MII.
Best regards,
John Moody
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com]On Behalf Of Steve Kale
Sent: Wednesday, January 25, 2006 4:01 AM
Subject: Re: [Digital BW] Re: Printing On Gloss...Possible with Digital B&W?
B&W?
> Best regards,
> John Moody
2006-01-25 by dlruckus
Hi Steve.
One would think that there should be given that true neutrals usually
reflect the impinging illuminant ie: "red sails at sunset" and all
that stuff.
Duane
2006-01-26 by ferdinand_paris
I'm not yet a refiller, as I've been waiting for the spongeless carts.
 My reading of the posts in this and related groups is that some
people like Clayton seem to get lucky and have a good run with the
spongey carts, whereas others have problems. It's hard to know whether
this is luck or technique.  I decided not to risk it, and wait for the
spongeless carts.
When I decided to wait, I thought it would not be long.  However MIS
have been promising spongeless carts for the 2100/2200 for ages, and
most recently promised me them early in 2006.  I'm not holding my
breath.  Ironically you can get them from MIS for the newer 2400, but
not yet for the older 2100/2200.
Steve - Do you have any problems getting Les at Mandev to reply to
your emails?  He didn't reply to mine.  He may not wish to ship abroad.
Joanne - you're not a dumb broad.  Your questions are informed,
intelligent and articulate.  I have the same sort of problem/question,
and based on what I've read so far, I'm inclined to try and get some
spongeless carts from Mandev and K4 inks from MIS and see what
happens.  If you're worred about making the whole thing too technical
and trial-and-error, rest assured that refilling the spongeless carts
seems to be a breeze **from what I've read**.
Ferdinand  (lurking and learning)
poppet
of the
around the
> > From: Clayton Jones <cj@c...>
Digital B&W?
2006-01-26 by John
Spongeless carts are available from US Sublimation
  john_e
spongeless carts.
poppet
of the
around the
Digital B&W?
- By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See “Group Topic, Rules and Guidelines” in the Files section:
BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE “OWNER” AND “MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  “OWNER” AND “MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
  SPONSORED LINKS
        Digital wedding photography   Learn digital photography   Digital photography college     Digital photography   Digital photography web site   Digital photography course
  YAHOO! GROUPS LINKS
    Visit your group "DigitalBlackandWhiteThePrint" on the web.
2006-01-26 by Steve Kale
No problems: les@...
> From: ferdinand_paris <ferdinand_paris@...>
2006-01-26 by Howard Shaw
Be persistent. First time I emailed Les I didn't get a reply but on the
second attempt he was very helpful and the cartridges arrived promptly
and to my surprise included specially designed colour coded syringes. I
haven't actually tried them yet but they look a lot better designed than
the MIS sponge ones with proper removable plugs etc.
Howard
Thanks to both of you for the advice and encouragement.
F_P
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Howard Shaw
<glassman@b...> wrote:
> Steve Kale wrote:
> > No problems: les@m...
> >> From: ferdinand_paris <ferdinand_paris@y...>
abroad.
than
> Howard
2006-01-26 by John Moody
For the 2200, the sponge provides capillary action that reduces the ink
pressure at the head, preventing the ink from dripping out of it.
Without the sponge, the cart design must provide some other mechanism to
reduce the pressure at the exit port.  MIS may be having trouble developing
a workable design that does not infringe on patented designs.
Best regards,
John Moody
ferdinand_paris
Sent: Wednesday, January 25, 2006 10:58 PM
spongeless carts.
2006-01-26 by Chris Hargens
John,
I searched the US Sublimation website but couldn't find any reference
to spongeless carts for the 2200.
Chris Hargens
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, John
>   john_e
> spongeless carts.
> poppet
> of the
> around the
> Digital B&W?
know
this same page.
to keep them short.
Owner and Moderators. See "Group Topic, Rules and Guidelines" in the
Files section:
PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER"
AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE
LOSSES (EVEN IF THE  "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT
>   SPONSORED LINKS
>   YAHOO! GROUPS LINKS
Service.
Are you serious?  About the only reason I can think of for the sponge is an
anti-spill mechanism.  Air must enter the cartridge in order for ink to exit
but you don't want ink to spill out the top...  At any rate, 2100 spongeless
carts have been around for a while in the UK.
> Date: Thu, 26 Jan 2006 06:13:09 -0500
> Best regards,
> John Moody
Absolutely serious.  There are drawbacks to the sponge, but that is the
function it performs.  Epson had sponge in prior 2200 carts; the improvement
over prior art is described in their patent.
Best regards,
John Moody
Sent: Thursday, January 26, 2006 12:52 PM
B&W?
developing
> Best regards,
> John Moody
page.
them short.
the membership.
Moderators. See Group Topic, Rules and Guidelines in the Files section:
YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE OWNER AND
MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU
GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  OWNER AND
MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE
SPONSORED LINKS
<http://groups.yahoo.com/gads?t=ms&k=Digital+wedding+photography&w1=Digital+
wedding+photography&w2=Learn+digital+photography&w3=Digital+photography+coll
ege&w4=Digital+photography&w5=Digital+photography+web+site&w6=Digital+photog
raphy+course&c=6&%20>
<http://groups.yahoo.com/gads?t=ms&k=Learn+digital+photography&w1=Digital+we
dding+photography&w2=Learn+digital+photography&w3=Digital+photography+colleg
e&w4=Digital+photography&w5=Digital+photography+web+site&w6=Digital+photogra
phy+course&c=6&s=%20>
<http://groups.yahoo.com/gads?t=ms&k=Digital+photography+college&w1=Digital+
Digital photography
<http://groups.yahoo.com/gads?t=ms&k=Digital+photography&w1=Digital+wedding+
photography&w2=Learn+digital+photography&w3=Digital+photography+college&w4=D
igital+photography&w5=Digital+photography+web+site&w6=Digital+photography+co
urse&c=6&s=188&.s%20>
<http://groups.yahoo.com/gads?t=ms&k=Digital+photography+web+site&w1=Digital
+wedding+photography&w2=Learn+digital+photography&w3=Digital+photography+col
lege&w4=Digital+photography&w5=Digital+photography+web+site&w6=Digital+photo
graphy+course&c=6%20>
<http://groups.yahoo.com/gads?t=ms&k=Digital+photography+course&w1=Digital+w
edding+photography&w2=Learn+digital+photography&w3=Digital+photography+colle
ge&w4=Digital+photography&w5=Digital+photography+web+site&w6=Digital+photogr
aphy+course&c=6&s%20>
  _____
YAHOO! GROUPS LINKS
*          Visit your group " DigitalBlackandWhiteThePrint
<http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint> " on the web.
*          To unsubscribe from this group, send an email to:
<mailto:DigitalBlackandWhiteThePrint-unsubscribe@yahoogroups.com?subject=Uns
ubscribe>
*          Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service <http://docs.yahoo.com/info/terms/> .
  _____
Hmmm I don't recall any in Epson carts when I last pulled one to pieces.
I'll take another look when I get an empty.
> Date: Thu, 26 Jan 2006 13:14:16 -0500
> Best regards,
> John Moody
That's right, as I said, they improved the carts by taking the sponge out.
They are now spongless.  Epson is very proud of the clever way they control
the ink pressure at the outlet as it empties.  Take a real good look at the
cart, it's a plumbing marvel.  Somewhere I had a picture of the internal
plumbing and valves that made it clear how it worked.  Maybe I can find it
later.
Best regards,
John Moody
Sent: Thursday, January 26, 2006 1:51 PM
B&W?
improvement
> Best regards,
> John Moody
OK well for what it's worth the spongeless 21/2200 carts I've been using
don't have any issues with ink leaking out into the printer.  They have two
holes in the top that come shipped with plugs in them.  The stopper for the
primary filling chamber is replaced once the cartridge is full.  The second
stopper over the hole at the top of the spill chamber where air comes in
remains out (and can act as a spare if you lose the one for the filling
chamber).  The carts are certainly considerably more sophisticated than the
MIS ones but not as complicated as Epson's.  I prime them with an MIS bottom
fill adaptor when they are brand new - it's not necessary to do this when
refilling.  I have noticed some drops of ink coming out the poppet valve on
some carts when refilling if the poppet valve is not properly sealed when
the cartridge is out of the printer.  This just requires some monitoring and
is easily corrected when noticed.  Of course the poppet valve is depressed
when they're in the printer.  I'm very happy with these cartridges and would
never want to go back to the MIS sponge ones.
> Date: Thu, 26 Jan 2006 14:56:19 -0500
> later.
> Best regards,
> John Moody
The Mandev carts sound good.
I dug up the link that explains the fancy valving.
http://www.epson.co.jp/e/technology/sankei_7.htm
In the US, WeInk has some that I have read mixed reviews on, and they are
somewhat expensive, $155US for 8 with a refill tool.  The comments have been
that they work well, but may require shims to hold them motionless relative
to the carriage.
Best regards,
John Moody
Sent: Thursday, January 26, 2006 3:27 PM
B&W?
control
> later.
> Best regards,
> John Moody
Steve What spongeless cartridges are you using?
2006-01-26 by Joe
Teve what spongless cartridges are you using?
using
have two
stopper for the
The second
comes in
filling
than the
MIS bottom
this when
valve on
sealed when
monitoring and
depressed
and would
> > From: John Moody <moodymz3@y...>
Digital B&W?
sponge out.
they control
look at the
internal
can find it
> > later.
> > Best regards,
> > John Moody
Re: [Digital BW] Steve What spongeless cartridges are you using?
21/2200 carts sold in the UK by Mandev (les at mandev.co.uk)
> From: Joe <drjoe2@...>
> Date: Thu, 26 Jan 2006 21:05:26 -0000
> Subject: [Digital BW] Steve What spongeless cartridges are you using?
2006-01-27 by ferdinand_paris
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "ferdinand_paris"
> I'm inclined to try and get some spongeless carts from
> Mandev and K4 inks from MIS and see what happens.
This was in relation to the 2100/2200, but it's dawned on me that
perhaps one shouldn't use the K4 inks in the 2100/2200.  There was
some suggestion to this effect in the archives, but nothing conclusive.
Does anyone have any more up-to-date infor on this?  Is it still the
case that the MIS Pro inks are preferred for the 2100/2200 if I want
UC equivalent, and the K4 should be avoided?
F_P
2006-01-27 by Chris Hargens
In what respects -- dmax, bronzing? -- are the MIS Pro and MIS K4 PK
different? I ask because I'm considering each of these inksets for BW
printing on glossy paper.
Chris Hargens
> > ...  Is it still the
> My tests suggest the colors are the same.  The PK is different.
> Paul
> www.PaulRoark.com
My question was about whether there was some risk to the printer, or
perhaps whether using them in the 2100 with a different print head
than they were designed for may have an adverse effect on the print.
After all, there must be some reason that MIS recommend Pro for the
2100/2200, and K4 for the 2400.
My reading of this group is that people are saying better things about
K4 than they are about Pro (esp bronzing and gloss differential, and
this thread is about printing on gloss after all), although this may
simply reflect the relative newness of K4.
So:
1. Is K4 safe for the 2100/2200?
2. Are there any adverse impacts on the print of using K4 in 2100/2200?
3. In a printer which can use both (if one exists) which is better?
F_P
> Chris Hargens
> > > ...  Is it still the
> > Paul
> > www.PaulRoark.com
2006-01-28 by Paul Roark
> different?
The K4 PK is a lower load ink than the MP PK.  I also had to lower the load
for the R220.  It's odd that something in the dither of the latest printers
requires a lower load than the old ones.  Optimizing that load is one key to
getting the best dmax -- like optimizing the ink limit.
> > > ...  Is it still the
> > Paul
> > www.PaulRoark.com
> page.
> them short.
> the membership.
> and Moderators. See "Group Topic, Rules and Guidelines" in the Files
> section:
> YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND
> "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO
> "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN
> PRINT YAHOO GROUP.
2006-01-28 by Bob Frost
Steve,
Surely it is obvious that unless something is done to keep the ink in the
cartridge, it will simply flow out through the printhead under the influence
of gravity. The system is open; a hole in the top of the cart, and holes in
the printhead, so liquid will flow out the bottom if nothing is done to stop
it. Users of CIS systems often suffer from this. The level of liquid in the
ink bottles has to be carefully balanced against the level of the printhead.
Too high and the inks simply runs straight through into the waste chamber.
Too low and the printhead can't generate enough pressure to lift the ink
from the bottles.
So the foam in the old carts, and the valves in the new carts, reduce the
head of ink, and thus the tendency to flow out of the printhead while idle.
Since the holes in the printhead are very small, surface tension effects may
help prevent leakage, but given enough head of ink (or touch the printhead
on the ink pad at rest) and the ink will surely flow if there is a
sufficient head of ink.
I always thought the long wiggly channels on the top of old carts through
which the air enters the carts might also have something to do with reducing
the inflow of air, and thus the tendency of the ink to flow out, but I'm not
sure on this.
Bob Frost.
