2004-10-17 by David B. Brooks
Duane,
I began my professional photo career in 1952 so I am probably a bit more the
cantankerous old f..., as well as having an inclination to be a gadfly.
>>It still seems to me that either device requires reduction in its overall
density range to try to match a print on paper. At least to
> me the visual appearance of an image on screen-no matter how carefully
> calibrated- seems more luminous than the resultant print.<<
Even if the print density range and the luminance range of a display is the
same, and with a CRT it is very close, the perceptual effect of light
reflected from a print image compared to an image transmitted by light will
never seem perceptually equivalent. This is a topic that was researched and
discussed at some length in Todd Zakia¹s book on Vision and Perception For
Photographers published by RIT Press. It was also analyzed and discussed in
depth from another perspective by Marshall McLuhan in Understanding Media.
Interestingly, about a dozen years ago there were high quality monochrome
portrait CRT monitors made primarily for the DTP market which had a white
background with a black image (text) which displayed B&W photographs very
realistically². It is maybe too bad these monitors are no longer made<S>.
The real beauty with digital is that you can fine-tune the image file to a
high degree of precision and restructure its characteristic curve ideally,
as well as do all of the image manipulation you would do with burning and
dodging, before ever clicking the Print button. Then it should be relatively
easy to obtain in ink and paper exactly what you expect in your mind¹s eye.
Other than the limitation imposed by color inks, I think maybe we might be
making the solution harder to attain than it needs to be. I know Paul Roark
sees it somewhat from that perspective. However, there is a lot of trial and
error experience and the craft skill that derives from that in what he does.
Regards, David B. Brooks
Shutterbug Magazine
E-mail: fotografx@...
On 10/16/04 7:01 PM, "dlruckus" <dlruckus@...> wrote:
> David,
> Of course you are correct in that the density range of a paper print
> is considerably less than the crt/lcd image can be. That's part of the
> purpose of doing the profiling to begin with. There is no doubt either
> that you cannot get any darker on a crt/lcd than the absence of light
> transmitted, so the appearance depends, as you said, on ambient light
> conditions and the physical surface characteristics of the device. I
> am happy to know that LCDs are advancing so greatly and presumably
> will be easily available soon with the gamma controls you referred to.
> overall density range to try to match a print on paper. At least to
> calibrated- seems more luminous than the resultant print. Thats not to
> say that the difference is huge and unmanageable.
> I see from your other posts on advancements/hopes for more readily
> useful solutions applicable to a larger audience that you feel it is
> at least potentialy possible to get wysiwyg completely. One hopes for
> that also. In the meantime super prints can be made despite all the
> variables. It is still in my mind not much different than attaining
> order and reproducible output(fine prints not consumer) ever was in
> the wet darkroom. There are in fact orders of magnitude more options
> and choices to be made, long learning curves, and much experimentation
> to do, as witness the folks in this group.
> I come from a long ago background in the photo arts and do not need to
> make a living at this so am somewhat dated. The tools I require must
> be fairly simple and low cost to match a retired persons income. That
> is why I commented on skinning the cat in many ways. I believe the
> "workflow" is paramount and there are various possible means to an
> end. They are not always universal or even broadly desirable but
> thankfully can be workable.
> I didn't mean to be disputive or to question your expertise. Just an
> old xxxx looking for more enlightment.
> Best.
> Duane
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "David B. Brooks"
> <fotografx@m...> wrote:
>> > Duane,
>> > I believe you would find that it is not all relative. No matter how much
>> > light you apply to illuminating a print, the density range of the print
>> > remains the same. However, with an LCD the black luminance remains
> little
>> > changed when you up the amount of light pushed through the screen
> with the
>> > backlight, so the maximum luminance climbs producing a much greater
>> > luminance range. In fact some LCD¹s now being sold have a contrast
> ratio of
>> > 600:1. There is no possible way to obtain effective print matching
> with that
>> > kind of display performance. But it does allow a stockbroker to
> easily read
>> > charts and graphs even on a sunny day if he is in a corner office.
>> > Shutterbug Magazine
>> > E-mail: fotografx@m...
>> > On 10/16/04 12:17 PM, "dlruckus" <dlruckus@y...> wrote:
>>> > > David,
>>> > > Thanks for the updating. I am aware of the low end deficiencys
>>> > > (blacks) of CRTs but I was unaware of advances in LCDs in respect to
>>> > > max illumination capabilities. That they now excede the brightest CRTs
>>> > > is interesting. The gamma info is interesting too. I'm not
>>> > > particularly surprised that it all has to be referenced to various and
>>> > > sundry adjustments,profiling etc. Your reference to reflectance versus
>>> > > luminance is what throws me. I suppose it's all relative since one can
>>> > > put as bright a light as desired on a finished print and thereby match
>>> > > the upper end of the scale with whichever screen is used. There are
>>> > > many ways to skin the cat.
>>> > > Best.
>>> > > Duane
>>>>> > >> > Duane,
>>>>> > >> > A typical LCD has a maximum luminance these days of around 250
>>> > > cd/m2, but
>>>>> > >> > usually adjusted for ideal photographic image display LCD¹s are
>>> > > choked down
>>>>> > >> > to between 150 and 180 cd/m2, with a black point between 0.05
> and 0.09.
>>>>> > >> > CRT¹s after calibration and profiling will have a luminance range
>>> > > from 0.07
>>>>> > >> > to 0.90. A fine print¹s density range is much closer, ideally
>>> > > slightly more
>>>>> > >> > measured with a densitometer than the range of a CRT, but very
> much less
>>>>> > >> > than the range of an LCD. However, on a perceptual basis because a
>>> > > print is
>>>>> > >> > viewed by usually less than ideal illumination (diffuse) the
>>> > > perceived tonal
>>>>> > >> > range is even closer to that of a CRT because the CRT display is
>>> > > projected
>>>>> > >> > rather than reflected light (unless contaminated by high levels of
>>> > > ambient
>>>>> > >> > illumination).
>>>>> > >> > Additionally the standard 2.2 gamma setting for displays
> produces a very
>>>>> > >> > different midpoint gray value between a CRT, which closely
> matches a
>>> > > print
>>>>> > >> > midpoint gray, compared to an LCD which with its longer luminance
>>> > > range has
>>>>> > >> > a much brighter midpoint gray. So far as I know Barco is the
> only LCD
>>>>> > >> > offered which has a gamma correction function that adjust for this
>>> > > midpoint
>>>>> > >> > gray discrepancy.
>>>>> > >> > Shutterbug Magazine
>>>>> > >> > On 10/15/04 11:34 AM, "dlruckus" <dlruckus@y...> wrote:
>>>>>>> > >>> > > David,
>>>>>>> > >>> > > One would think that the flat panel LCD screen would be just
>>>>>>> > >>> > > opposite and be closer to paper than the CRT. That has been my
>>>>>>> > >>> > > experience to date but perhaps I'm missing the most recent
> advances in
>>>>>>> > >>> > > that field.
>>>>>>> > >>> > > Best.
>>>>>>> > >>> > > Duane
> B. Brooks"
>>>>>>>>>>> > >>>>> > >> > Bernie,
>>>>>>>>>>> > >>>>> > >> > May I suggest that ³color management² and monitor
> calibration and
>>>>>>> > >>> > > profiling
>>>>>>>>>>> > >>>>> > >> > could at least reduce the discrepancy between what
you see
>>> > > on-screen and
>>>>>>>>>>> > >>>>> > >> > what you obtain in a print even though you are
working with
>>>>>>> > >>> > > grayscale and
>>>>>>>>>>> > >>>>> > >> > not color. I have jumped in here in part because I
was
> just
>>> > > delivered
>>>>>>>>>>> > >>>>> > >> > ColorVision¹s new Spyder2Pro colorimeter and
software,
> and the
>>> > > resulting
>>>>>>>>>>> > >>>>> > >> > calibration and profiling I am now obtaining is
amazingly
>>>>>>> > >>> > > well-matched and
>>>>>>>>>>> > >>>>> > >> > the screen gray is at a neutral balance I¹ve not seen
> before. And
>>>>>>> > >>> > > may I also
>>>>>>>>>>> > >>>>> > >> > suggest that with an LCD flat panel, its grater
> brightness range
>>>>>>> > >>> > > compared to
>>>>>>>>>>> > >>>>> > >> > a CRT, makes it that much more difficult to obtain
> screen matching
>>>>>>> > >>> > > in prints
>>>>>>>>>>> > >>>>> > >> > as there is an inherent gamma discrepancy. CRT¹s are
> much closer in
>>>>>>>>>>> > >>>>> > >> > brightness range and apparent gamma effect to a print
> density
>>> > > range.
>>>>>>>>>>> > >>>>> > >> > Shutterbug Magazine
>>>>>>>>>>> > >>>>> > >> > On 10/15/04 4:17 AM, "Bernie Ess" <albatros-@...>
> wrote:
>>>>>>>>>>>>>>> > >>>>>>> > >>> > > When I started b&w printing on an Epson, I
thought
> one of the
>>>>>>>>>>>>>>> > >>>>>>> > >>> > > advantages over the darkroom was that once
its
> well set up,
>>> > > there
>>>>>>>>>>>>>>> > >>>>>>> > >>> > > would be no trying and experimenting and
that I
> would have
>> > 100%
>>>>>>>>>>>>>>> > >>>>>>> > >>> > > predictable results.
>>>>>>>>>>>>>>> > >>>>>>> > >>> > > Now, a few hundreds or probably thousands of
> prints later I
>>> > > find that
>>>>>>>>>>>>>>> > >>>>>>> > >>> > > this is
>>>>>>>>>>>>>>> > >>>>>>> > >>> > > not exactly the case. On my 2100/UT7
workflow I
> find the
>>> > > following
>>>>>>>>>>>>>>> > >>>>>>> > >>> > > issues:
>>>>>>>>>>>>>>> > >>>>>>> > >>> > > 1. My output from the file + Roark curves is
> roughly, but
>> > never
>>>>>>>>>>>>>>> > >>>>>>> > >>> > > exactly what I see on my monitor. When I
look at the
>>> > > grayscale on my
>>>>>>>>>>>>>>> > >>>>>>> > >>> > > flat panel the 100% to 0%
>>>>>>>>>>>>>>> > >>>>>>> > >>> > > steps are quite well separated, but in the
> uncorrected print
>>> > > the deep
>>>>>>>>>>>>>>> > >>>>>>> > >>> > > shadows (around 95%
>>>>>>>>>>>>>>> > >>>>>>> > >>> > > black) are not well resolved, 95% comes out
totally
>>>>>>>>>>>>>>> > >>>>>>> > >>> > > black: So I had to make a curve that boosts
> deep shadows.
>>>>>>>>>>>>>>> > >>>>>>> > >>> > > 2. I often find myself having to do several
prints
> of the
>>> > > same photo,
>>>>>>>>>>>>>>> > >>>>>>> > >>> > > because the general "look" of the print is
not
> like on the
>>> > > screen, see
>>>>>>>>>>>>>>> > >>>>>>> > >>> > > also my other message about the foliage and
trees.
>>>>>>>>>>>>>>> > >>>>>>> > >>> > > 3. The most mysterious thing is that my
output
> seems to vary
>>> > > from time
>>>>>>>>>>>>>>> > >>>>>>> > >>> > > to time. Sometimes I find the prints too
dark
> compared to
>>> > > the screen,
>>>>>>>>>>>>>>> > >>>>>>> > >>> > > sometimes they are slightly too light.
>>>>>>>>>>>>>>> > >>>>>>> > >>> > > Finally its not that different from the
darkroom,
> I would say
>>>>>>>>>>>>>>> > >>>>>>> > >>> > > gradually more predictable (maybe even by a
large
> margin,
>>> > > but that is
>>>>>>>>>>>>>>> > >>>>>>> > >>> > > probably because my traditional darkroom
skills
> are so poor).
>>>>>>>>>>>>>>> > >>>>>>> > >>> > > So, do you have a 100% WYSIWYG workflow?
>>>>>>>>>>>>>>> > >>>>>>> > >>> > > Thanks for your input,
>>>>>>>>>>>>>>> > >>>>>>> > >>> > > Bernhard
>>>>>>>>>>>>>>> > >>>>>>> > >>> > > Please visit the Group Homepage to check the
> Files, and other
>>>>>>> > >>> > > resources as
>>>>>>>>>>>>>>> > >>>>>>> > >>> > > they are often being updated.
>>>>>>>>>>>>>>> > >>>>>>> > >>> > > If you wish to receive no emails or just a
daily
> digest, or
>> > you
>>>>>>> > >>> > > wish to
>>>>>>>>>>>>>>> > >>>>>>> > >>> > > unsubscribe, please edit your Membership
> preferences by
>> > visiting
>>>>>>> > >>> > > this same
>>>>>>>>>>>>>>> > >>>>>>> > >>> > > page.
>>>>>>>>>>>>>>> > >>>>>>> > >>> > > Please follow these basic guidelines:
>>>>>>>>>>>>>>> > >>>>>>> > >>> > > - As threads develop, trim off excess
portions of
> earlier
>>> > > messages
>>>>>>> > >>> > > to keep
>>>>>>>>>>>>>>> > >>>>>>> > >>> > > them short.
>>>>>>>>>>>>>>> > >>>>>>> > >>> > > - Good manners are required at all time. No
> personal attacks
>> > or
>>>>>>> > >>> > > flames.
>>>>>>>>>>>>>>> > >>>>>>> > >>> > > Hostile, aggressive or argumentative users
may be
> removed
>>> > > from the
>>>>>>> > >>> > > membership
>>>>>>>>>>>>>>> > >>>>>>> > >>> > > without notice.
>>>>>>>>>>>>>>> > >>>>>>> > >>> > > - Keep your posts and threads related to the
group
> topic of
>>>>>>> > >>> > > digital B&W
>>>>>>>>>>>>>>> > >>>>>>> > >>> > > printing. Users who persistently make
off-topic
> posts may be
>>>>>>> > >>> > > removed from the
>>>>>>>>>>>>>>> > >>>>>>> > >>> > > membership.
>>>>>>>>>>>>>>> > >>>>>>> > >>> > > - By posting on this forum you agree to
abide by
> the group
>>> > > rules and
>>>>>>>>>>>>>>> > >>>>>>> > >>> > > guidelines, and to abide by the actions and
> decisions of the
>>> > > group
>>>>>>> > >>> > > Owner and
>>>>>>>>>>>>>>> > >>>>>>> > >>> > > Moderators. See "Group Topic, Rules and
> Guidelines" in the
>> > Files
>>>>>>> > >>> > > section:
>>> > > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/
>>>>>>>>>>>>>>> > >>>>>>> > >>> > > BY PARTICIPATING IN AND/OR POSTING MESSAGES
TO THE
> DIGITAL
>>> > > BW, THE
>>>>>>> > >>> > > PRINT
>>>>>>>>>>>>>>> > >>>>>>> > >>> > > YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND
AGREE
> THAT THE
>>> > > "OWNER" AND
>>>>>>>>>>>>>>> > >>>>>>> > >>> > > "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO
GROUP
> SHALL NOT BE
>>>>>>> > >>> > > LIABLE TO YOU
>>>>>>>>>>>>>>> > >>>>>>> > >>> > > FOR ANY DIRECT, INDIRECT, INCIDENTAL,
SPECIAL,
> CONSEQUENTIAL
>> > OR
>>>>>>> > >>> > > EXEMPLARY
>>>>>>>>>>>>>>> > >>>>>>> > >>> > > DAMAGES, INCLUDING BUT NOT LIMITED TO,
DAMAGES FOR
> LOSS OF
>>>>>>> > >>> > > PROFITS, GOODWILL,
>>>>>>>>>>>>>>> > >>>>>>> > >>> > > USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN
IF THE
> "OWNER" AND
>>>>>>> > >>> > > "MODERATORS" OF
>>>>>>>>>>>>>>> > >>>>>>> > >>> > > DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN
> ADVISED OF THE
>>>>>>> > >>> > > POSSIBILITY OF SUCH
>>>>>>>>>>>>>>> > >>>>>>> > >>> > > DAMAGES), RESULTING FROM: (i) THE USE OR THE
> INABILITY TO
>>> > > USE THE
>>>>>>> > >>> > > DIGITAL BW,
>>>>>>>>>>>>>>> > >>>>>>> > >>> > > THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED
ACCESS TO
> OR >>>>>>>
>> > ALTERATION
>>>>>>> > >>> > > OF YOUR
>>>>>>>>>>>>>>> > >>>>>>> > >>> > > TRANSMISSIONS OR DATA; (iii) STATEMENTS OR
CONDUCT
> OF ANY
>> > THIRD
>>>>>>> > >>> > > PARTY ON THE
>>>>>>>>>>>>>>> > >>>>>>> > >>> > > DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv)
ANY
> OTHER MATTER
>>>>>>> > >>> > > RELATING TO THE
>>>>>>>>>>>>>>> > >>>>>>> > >>> > > DIGITAL BW, THE PRINT YAHOO GROUP.
>>>>>>>>>>>>>>> > >>>>>>> > >>> > > Yahoo! Groups Sponsor
>>>>>>>>>>>>>>> > >>>>>>> > >>> > > ADVERTISEMENT
> <http://us.ard.yahoo.com/SIG=129jjh7kv/M=315388.5497957.6576270.3001176/D=grou
> ps/S=1705019182:HM/EXP=1097925477/A=2372354/R=0/SIG=12id813k2/*https://www.orc
>>> > > hardbank.com/hcs/hcsapplication?pf=PLApply&media=EMYHNL40F21004SS>
>>>>>>>>>>>>>>> > >>>>>>> > >>> > > Yahoo! Groups Links
>>>>>>>>>>>>>>> > >>>>>>> > >>> > > * To visit your group on the web, go to:
>>>>>>>>>>>>>>> > >>>>>>> > >>> > > * To unsubscribe from this group, send an
email to:
> DigitalBlackandWhiteThePrint-unsubscribe@yahoogroups.com
> <mailto:DigitalBlackandWhiteThePrint-unsubscribe@yahoogroups.com?subject=Unsub
>>>>>>>>>>>>>>> > >>>>>>> > >>> > > scribe>
>>>>>>>>>>>>>>> > >>>>>>> > >>> > > * Your use of Yahoo! Groups is subject to
> Yahoo! Terms
>>> > > of Service
>>>>>>>>>>>>>>> > >>>>>>> > >>> > > <http://docs.yahoo.com/info/terms/> .
>>>>>>>>>>> > >>>>> > >> > [Non-text portions of this message have been removed]
>>>>>>> > >>> > > Please visit the Group Homepage to check the Files, and other
>>> > > resources as
>>>>>>> > >>> > > If you wish to receive no emails or just a daily digest, or
you
>>> > > wish to
>>>>>>> > >>> > > unsubscribe, please edit your Membership preferences by
visiting
>>> > > this same
>>>>>>> > >>> > > page.
>>>>>>> > >>> > > - As threads develop, trim off excess portions of earlier
> messages
>>> > > to keep
>>>>>>> > >>> > > them short.
>>>>>>> > >>> > > - Good manners are required at all time. No personal attacks
or
>>> > > flames.
>>>>>>> > >>> > > Hostile, aggressive or argumentative users may be removed
> from the
>>> > > membership
>>>>>>> > >>> > > without notice.
>>>>>>> > >>> > > - Keep your posts and threads related to the group topic of
>>> > > digital B&W
>>>>>>> > >>> > > printing. Users who persistently make off-topic posts may be
>>> > > removed from the
>>>>>>> > >>> > > membership.
>>>>>>> > >>> > > - By posting on this forum you agree to abide by the group
> rules and
>>>>>>> > >>> > > guidelines, and to abide by the actions and decisions of the
> group
>>> > > Owner and
>>>>>>> > >>> > > Moderators. See "Group Topic, Rules and Guidelines" in the
Files
>>> > > section:
>>>>>>> > >>> > > BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL
> BW, THE
>>> > > PRINT
>>>>>>> > >>> > > YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE
> "OWNER" AND
>>>>>>> > >>> > > "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE
>>> > > LIABLE TO YOU
>>>>>>> > >>> > > FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL
OR
>>> > > EXEMPLARY
>>>>>>> > >>> > > DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF
>>> > > PROFITS, GOODWILL,
>>>>>>> > >>> > > USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE "OWNER" AND
>>> > > "MODERATORS" OF
>>>>>>> > >>> > > DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE
>>> > > POSSIBILITY OF SUCH
>>>>>>> > >>> > > DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO
> USE THE
>>> > > DIGITAL BW,
>>>>>>> > >>> > > THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR >>>>>>>
ALTERATION
>>> > > OF YOUR
>>>>>>> > >>> > > TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY
THIRD
>>> > > PARTY ON THE
>>>>>>> > >>> > > DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER
>>> > > RELATING TO THE
>>>>>>> > >>> > > ADVERTISEMENT
> <http://us.ard.yahoo.com/SIG=129rtuo5b/M=315388.5497957.6576270.3001176/D=grou
> ps/S=1705019182:HM/EXP=1097951722/A=2372354/R=0/SIG=12id813k2/*https://www.orc
>>>>>>> > >>> > > Yahoo! Groups Links
>>>>>>> > >>> > > * http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/
>>>>>>> > >>> > > * To unsubscribe from this group, send an email to:
>>>>>>> > >>> > > * DigitalBlackandWhiteThePrint-unsubscribe@yahoogroups.com
>>>>>>> > >>> > > scribe>
>>>>>>> > >>> > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms
> of Service
> resources as
>>> > > If you wish to receive no emails or just a daily digest, or you
> wish to
>>> > > unsubscribe, please edit your Membership preferences by visiting
> this same
>>> > > page.
>>> > > - As threads develop, trim off excess portions of earlier messages
> to keep
>>> > > them short.
>>> > > - Good manners are required at all time. No personal attacks or
> flames.
>>> > > Hostile, aggressive or argumentative users may be removed from the
> membership
>>> > > without notice.
> digital B&W
> removed from the
>>> > > membership.
>>> > > - By posting on this forum you agree to abide by the group rules and
>>> > > guidelines, and to abide by the actions and decisions of the group
> Owner and
>>> > > Moderators. See "Group Topic, Rules and Guidelines" in the Files
> section:
>>> > > BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE
> PRINT
>>> > > YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER" AND
> LIABLE TO YOU
>>> > > FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR
> EXEMPLARY
> PROFITS, GOODWILL,
> "MODERATORS" OF
> POSSIBILITY OF SUCH
>>> > > DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE
> DIGITAL BW,
>>> > > THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION
> OF YOUR
>>> > > TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD
> PARTY ON THE
> RELATING TO THE
>>> > > ADVERTISEMENT
> <http://us.ard.yahoo.com/SIG=1292jc4rb/M=315388.5500238.6578046.3001176/D=grou
> ps/S=1705019182:HM/EXP=1098040637/A=2372354/R=0/SIG=12id813k2/*https://www.orc
>>> > > Yahoo! Groups Links
>>> > > scribe>
>>> > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
> page.
> them short.
> Hostile, aggressive or argumentative users may be removed from the membership
> without notice.
> printing. Users who persistently make off-topic posts may be removed from the
> membership.
> guidelines, and to abide by the actions and decisions of the group Owner and
> Moderators. See Group Topic, Rules and Guidelines in the Files section:
> YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE OWNER AND
> MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU
> FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY
> DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL,
> USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE OWNER AND MODERATORS OF
> DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH
> DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW,
> THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR
> TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE
> DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE
> ADVERTISEMENT
> <http://us.ard.yahoo.com/SIG=129jvsdp5/M=315388.5497957.6576270.3001176/D=grou
> ps/S=1705019182:HM/EXP=1098064915/A=2372354/R=0/SIG=12id813k2/*https://www.orc
> scribe>
